  4. Terminal Adapter
    6.0k
Terminal Adapter
31 Beiträge 6 Kommentatoren 3.3k Aufrufe 6 Beobachtet
    @atticus vnc braucht kein Mensch auf einem Server.
    Atticus68
    @thomas-braun ok, vnc kann runter, ändert aber nichts an der Sache
    • A Atticus68
      Atticus68
      Hab den VNC deaktiviert
      pi@ioBroker482:~ $ sudo netstat -tulpe
      Aktive Internetverbindungen (Nur Server)
      Proto Recv-Q Send-Q Local Address           Foreign Address         State       Benutzer   Inode      PID/Program name
      tcp        0      0 ioBroker482.fritz.:2001 0.0.0.0:*               LISTEN      iobroker   22855      1313/io.hm-rpc.0
      tcp        0      0 127.0.0.53:domain       0.0.0.0:*               LISTEN      systemd-resolve 17517      321/systemd-resolve
      tcp        0      0 0.0.0.0:ssh             0.0.0.0:*               LISTEN      root       16107      480/sshd
      tcp        0      0 localhost:ipp           0.0.0.0:*               LISTEN      root       15809      358/cupsd
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      iobroker   23722      1233/node-red
      tcp        0      0 ioBroker482:pipe-server 0.0.0.0:*               LISTEN      iobroker   23919      1321/io.hm-rpc.1
      tcp        0      0 ioBroker482.fritz.:8701 0.0.0.0:*               LISTEN      iobroker   20419      1332/io.hm-rpc.2
      tcp        0      0 ioBroker482.fritz.:8702 0.0.0.0:*               LISTEN      iobroker   20464      1365/io.hm-rpc.3
      tcp        0      0 localhost:9000          0.0.0.0:*               LISTEN      iobroker   19947      456/iobroker.js-con
      tcp        0      0 localhost:9001          0.0.0.0:*               LISTEN      iobroker   21868      456/iobroker.js-con
      tcp        0      0 0.0.0.0:hostmon         0.0.0.0:*               LISTEN      systemd-resolve 17511      321/systemd-resolve
      tcp        0      0 ioBroker482.fritz:18701 0.0.0.0:*               LISTEN      iobroker   22973      1377/io.hm-rpc.4
      tcp6       0      0 [::]:tproxy             [::]:*                  LISTEN      iobroker   22274      1034/io.admin.0
      tcp6       0      0 [::]:8084               [::]:*                  LISTEN      iobroker   27936      1816/io.socketio.0
      tcp6       0      0 [::]:ssh                [::]:*                  LISTEN      root       16109      480/sshd
      tcp6       0      0 [::]:8087               [::]:*                  LISTEN      iobroker   26886      1801/io.simple-api.
      tcp6       0      0 localhost:ipp           [::]:*                  LISTEN      root       15808      358/cupsd
      tcp6       0      0 [::]:hostmon            [::]:*                  LISTEN      systemd-resolve 17514      321/systemd-resolve
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           iobroker   23123      1510/io.shelly.0
      udp        0      0 127.0.0.53:domain       0.0.0.0:*                           systemd-resolve 17516      321/systemd-resolve
      udp        0      0 0.0.0.0:44141           0.0.0.0:*                           avahi      15797      371/avahi-daemon: r
      udp        0      0 0.0.0.0:ipp             0.0.0.0:*                           root       16167      453/cups-browsed
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           iobroker   24719      1434/io.mihome-vacu
      udp        0      0 224.0.0.251:mdns        0.0.0.0:*                           pi         19431      669/index.html?l%5B
      udp        0      0 0.0.0.0:mdns            0.0.0.0:*                           avahi      15795      371/avahi-daemon: r
      udp        0      0 0.0.0.0:hostmon         0.0.0.0:*                           systemd-resolve 17510      321/systemd-resolve
      udp        0      0 ioBroker482.fritz:45815 0.0.0.0:*                           pi         27111      669/index.html?l%5B
      udp6       0      0 [::]:mdns               [::]:*                              avahi      15796      371/avahi-daemon: r
      udp6       0      0 [::]:hostmon            [::]:*                              systemd-resolve 17513      321/systemd-resolve
      udp6       0      0 [::]:44848              [::]:*                              avahi      15798      371/avahi-daemon: r
      pi@ioBroker482:~ $
      • A Atticus68
        pi@ioBroker482:~ $
        @atticus
        sudo netstat -tulpen
        Das n am Ende ist wichtig!
        • A Atticus68
          pi@ioBroker482:~ $
          crunchipC Offline
          crunchipC Offline
          @atticus geb den Befehl nichmal richtig ein, ansonsten stell den Adapter auf 8089, dann sollte es funktionieren
            Atticus68
            @crunchip ich hab den Port auf 8089 geändert, geht auch nicht.
            pi@ioBroker482:~ $ sudo netstat -tulpen
            tcp        0      0 192.168.2.238:2001      0.0.0.0:*               LISTEN      1001       22855      1313/io.hm-rpc.0
            tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        17517      321/systemd-resolve
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16107      480/sshd
            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15809      358/cupsd
            tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       23722      1233/node-red
            tcp        0      0 192.168.2.238:2010      0.0.0.0:*               LISTEN      1001       23919      1321/io.hm-rpc.1
            tcp        0      0 192.168.2.238:8701      0.0.0.0:*               LISTEN      1001       20419      1332/io.hm-rpc.2
            tcp        0      0 192.168.2.238:8702      0.0.0.0:*               LISTEN      1001       20464      1365/io.hm-rpc.3
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       19947      456/iobroker.js-con
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       21868      456/iobroker.js-con
            tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      102        17511      321/systemd-resolve
            tcp        0      0 192.168.2.238:18701     0.0.0.0:*               LISTEN      1001       22973      1377/io.hm-rpc.4
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       22274      1034/io.admin.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       34095      2294/io.web.0
            tcp6       0      0 :::8084                 :::*                    LISTEN      1001       27936      1816/io.socketio.0
            tcp6       0      0 :::22                   :::*                    LISTEN      0          16109      480/sshd
            tcp6       0      0 :::8087                 :::*                    LISTEN      1001       26886      1801/io.simple-api.
            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15808      358/cupsd
            tcp6       0      0 :::5355                 :::*                    LISTEN      102        17514      321/systemd-resolve
            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       23123      1510/io.shelly.0
            udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        17516      321/systemd-resolve
            udp        0      0 0.0.0.0:44141           0.0.0.0:*                           108        15797      371/avahi-daemon: r
            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16167      453/cups-browsed
            udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       24719      1434/io.mihome-vacu
            udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1000       19431      669/index.html?l%5B
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15795      371/avahi-daemon: r
            udp        0      0 0.0.0.0:5355            0.0.0.0:*                           102        17510      321/systemd-resolve
            udp6       0      0 :::5353                 :::*                                108        15796      371/avahi-daemon: r
            udp6       0      0 :::5355                 :::*                                102        17513      321/systemd-resolve
            udp6       0      0 :::44848                :::*                                108        15798      371/avahi-daemon: r
            pi@ioBroker482:~ $
            • A Atticus68
              pi@ioBroker482:~ $
              @atticus
              Neben der (sich eigentlich nicht stellenden) Sinnfrage des Desktops, wozu braucht es den Terminal-Adapter eigentlich? Der sorgt auch anderen Stellen gerne für Probleme. Würde ich (neben dem Desktop) eh rauswerfen.
              • A Atticus68
                pi@ioBroker482:~ $
                crunchipC Offline
                crunchipC Offline
                @atticus sagte in Terminal Adapter:
                geht auch nicht
                Mit welcher Meldung?
                Starte den Pi mal neu und probier nochmal.
                Ich sehe da nichts was weder den default Port noch den anderen belegen sollte.
                Oder mal so probieren
                sudo netstat -lntup | grep ":8088"
                  geht auch nicht
                  Atticus68
                  @crunchip sagte in Terminal Adapter:
                  pi@ioBroker482:~ $ sudo netstat -lntup | grep ":8088"
                  pi@ioBroker482:~ $
                    @atticus
                    Atticus68
                    @thomas-braun ich hab an dem Raspberry ein Display angeschlossen, das die Weboberfläche des iobrokers anzeigt.
                    Zum zweiten hatte ich schon mal den Fall, da hast du auch geantwortet, das der Raspberry durch einen Stromausfall nicht mehr richtig funktioniert, ich konnte mich am Raspberry nicht mehr anmelden, der iobroker lief aber noch, da konnte ich durch das Terminal im iobroker versuchen, den Raspbery zu retten.
                    • A Atticus68
                      HomoranH Offline
                      HomoranH Offline
                      das geht such über ein SSH Terminal am PC (puTTY oder Powershell)
                        Atticus68
                        @homoran ja, im normalfall, schon. Glaub mir, es war so, ich konnte mich an dem Raspberry mit keiner Anmeldung verbinden, der iobroker lief jedoch beim Starten des Raspberrys an, und über das Terminal im iobroker konnte man versuchen, den Raspberry zu retten. Eine Anmeldung über putty etc. war nicht möglich.
                        • A Atticus68
                          Dann läuft da auch eine bash/Terminal
                            liv-in-skyL Offline
                            liv-in-skyL Offline
                            @thomas-braun Ich nutze den terminal Adapter auch nicht mehr
                            Leider - das er sehr brauchbar war beim testen der exec function, da man ja mit dem iobroker user arbeitet und Probleme mit rechten leicht sieht
                            • A Atticus68
                              pi@ioBroker482:~ $
                              crunchipC Offline
                              crunchipC Offline
                              war falsch, mach mal nur auf Port 80
                              netstat -lntup | grep ":80"
                              • A Atticus68
                                @crunchip ja, ich hab schon einige Ports eingegeben, bei jedem kommt die o.g. Meldung. Es sieht also so aus, das der Fehler bei jedem Port auftritt. Ich habe natürlich nicht alle möglichen Ports getestet, aber wenn ich eine (mehrere) willkürliche Portadresse verwende, und immer kommt die gleiche Fehlermeldung, ist das schon seltsam, oder?
                                @atticus fix schon auf github. Release kommt heute
