  4. [Anleitung] Selbstbau Wemos D1 mini und Helligkeitssensor BH1750
    1.0k
123 Beiträge 24 Kommentatoren 43.4k Aufrufe 43 Beobachtet
  • S smarthome2020
    @opensourcenomad
    Neben dem log von eben kommt dann ergänzend nur :
    [22:25:23][V][mdns:086]:   Services:
    [22:25:23][V][mdns:088]:   - _esphomelib, _tcp, 6053
    [22:25:23][V][mdns:090]:     TXT: version = 2022.1.3
    [22:25:23][V][mdns:090]:     TXT: mac = bcff4d191c18
    [22:25:23][V][mdns:090]:     TXT: platform = ESP8266
    [22:25:23][V][mdns:090]:     TXT: board = d1_mini
    [22:26:12][D][api:098]: Accepted 192.168.xxx.xx
    [22:26:12][V][api.connection:763]: Hello from client: 'raspberrypi (192.168.xxx.xx)'
    [22:26:12][D][api.connection:779]: raspberrypi (192.168.xxx.xx): Connected successfully
    Im Hauptlog des ioBroker kommt aber immer wieder:
    ESPHome client 192.168.xxx.xx Error: connect EISCONN 192.168.xxx.xx:6053 - Local (192.168.xxx.xx:48714)
    OpenSourceNomadO Offline
    OpenSourceNomad
    Most Active Gesperrt
    #113
    @smarthome2020 said in [Anleitung] Selbstbau Wemos D1 mini und Helligkeitssensor BH1750:
    und minütlich kommt nix bezüglich der bh1750 component? Zur not noch very_verbose versuchen.
    • OpenSourceNomadO OpenSourceNomad
      smarthome2020
      schrieb am zuletzt editiert von smarthome2020
      #114
      @opensourcenomad
      [22:43:28][VV][scheduler:185]: Running interval '' with interval=60000 last_execution=6490 (now=66490)
      [22:43:33][D][api:098]: Accepted 192.168.xxx.x
      [22:43:33][VV][api.service:337]: on_ping_request: PingRequest {}
      [22:43:33][VV][api.service:043]: send_ping_response: PingResponse {}
      [22:43:33][VV][api.service:301]: on_hello_request: HelloRequest {
        client_info: 'raspberrypi'
      [22:43:33][V][api.connection:763]: Hello from client: 'raspberrypi (192.168.xxx.x)'
      [22:43:33][VV][api.service:013]: send_hello_response: HelloResponse {
        api_version_major: 1
        api_version_minor: 6
        server_info: 'esp8266-lux (esphome v2022.1.3)'
      [22:43:33][VV][api.service:310]: on_connect_request: ConnectRequest {
        password: 'xxx'
      [22:43:33][D][api.connection:779]: raspberrypi (192.168.xxx.x): Connected successfully
      [22:43:33][VV][api.service:019]: send_connect_response: ConnectResponse {
        invalid_password: NO
      [22:43:33][VV][api.service:355]: on_device_info_request: DeviceInfoRequest {}
      [22:43:33][VV][api.service:049]: send_device_info_response: DeviceInfoResponse {
        uses_password: YES
        mac_address: 'Xxx'
        esphome_version: '2022.1.3'
        compilation_time: 'Mar 18 2022, 22:41:21'
        model: 'd1_mini'
        has_deep_sleep: NO
        project_name: ''
        project_version: ''
        webserver_port: 0
      [22:43:33][VV][api.service:364]: on_list_entities_request: ListEntitiesRequest {}
      [22:43:33][VV][api.service:132]: send_list_entities_sensor_response: ListEntitiesSensorResponse {
        object_id: 'lux'
        key: 914478924
        unique_id: 'esp8266-luxsensorlux'
        icon: ''
        unit_of_measurement: 'lx'
        accuracy_decimals: 1
        force_update: NO
        device_class: 'illuminance'
        state_class: STATE_CLASS_MEASUREMENT
        legacy_last_reset_type: LAST_RESET_NONE
        disabled_by_default: NO
        entity_category: ENTITY_CATEGORY_NONE
      [22:43:33][VV][api.service:373]: on_subscribe_states_request: SubscribeStatesRequest {}
      [22:43:33][VV][api.service:055]: send_list_entities_done_response: ListEntitiesDoneResponse {}
      [22:43:33][VV][api.service:140]: send_sensor_state_response: SensorStateResponse {
        key: 914478924
        state: 12.9167
        missing_state: NO
      [22:43:36][VV][api.service:337]: on_ping_request: PingRequest {}
      [22:43:36][VV][api.service:043]: send_ping_response: PingResponse {}
      [22:43:48][VV][api.service:337]: on_ping_request: PingRequest {}
      [22:43:48][VV][api.service:043]: send_ping_response: PingResponse {}
      Und :
      d1_mini
      [22:50:04][VV][api.service:337]: on_ping_request: PingRequest {}
      [22:50:04][VV][api.service:043]: send_ping_response: PingResponse {}
      [22:50:09][VV][scheduler:185]: Running interval 'update' with interval=60000 last_execution=407236 (now=467236)
      [22:50:09][VV][i2c.arduino:124]: 0x23 TX 21
      [22:50:09][VV][i2c.arduino:148]: TX failed: not acknowledged
      [22:50:13][VV][api.service:337]: on_ping_request: PingRequest {}
      [22:50:13][VV][api.service:043]: send_ping_response: PingResponse {}
      [22:50:19][VV][api.service:337]: on_ping_request: PingRequest {}
      [22:50:19][VV][api.service:043]: send_ping_response: PingResponse {}
      [22:50:28][VV][scheduler:185]: Running interval '' with interval=60000 last_execution=426490 (now=486492)
      [22:50:29][VV][api.service:337]: on_ping_request: PingRequest {}
      [22:50:29][VV][api.service:043]: send_ping_response: PingResponse {}
      [22:50:34][VV][api.service:337]: on_ping_request: PingRequest {}
      [22:50:34][VV][api.service:043]: send_ping_response: PingResponse {}
      [22:50:44][VV][api.service:337]: on_ping_request: PingRequest {}
      [22:50:44][VV][api.service:043]: send_ping_response: PingResponse {}
      [22:50:49][VV][api.service:337]: on_ping_request: PingRequest {}
      [22:50:49][VV][api.service:043]: send_ping_response: PingResponse {}
      OpenSourceNomadO 1 Antwort Letzte Antwort
        Hat einer eine Idee?
        Hat einer Logs?
        Die neuste esphome version (2022.03) hat übrigens eine interessante Änderung bezüglich des bh1750:
        BH1750 dynamically calculate options #3214
        Until now for BH1750 you had to set static resolution/measurement_duration values - and so either optimize for low-light or bright scenes. Instead, dynamically calculate those options now by first doing a quick l-resolution measurement, then switch to the optimal mode/mtreg values.
        smarthome2020
        #115
        @opensourcenomad sagte in [Anleitung] Selbstbau Wemos D1 mini und Helligkeitssensor BH1750:
        Wie sehe ich, welche Version aufgespielt ist? Habe eben alle esphome Geräte aktualisiert… finde nur nirgends was von 2022.03..
        • S smarthome2020
          @opensourcenomad
            password: 'xxx'
            uses_password: YES
            mac_address: 'Xxx'
            model: 'd1_mini'
            has_deep_sleep: NO
            project_name: ''
            project_version: ''
            webserver_port: 0
            object_id: 'lux'
            key: 914478924
            icon: ''
            force_update: NO
            key: 914478924
            state: 12.9167
            missing_state: NO
          Und :
          d1_mini
          OpenSourceNomad
          #116
          Wie vermutet hackt es an der Kommunikation. Eventuell mal pull up am gpio aktivieren?
          Z.b. im Dashboard footer
          • S smarthome2020
            Dieter_P
            #117
            @smarthome2020
            Bei mir hat sich der BH1750 nach einigen Messungen/Ergebnissen immer wieder verabschiedet (Der I2C Teilnehmer wurde nicht mehr gefunden). Die Lösung war eine Pufferung der 5V Versorgungsspannung direkt am BH1750 mit einem kleinen Elko (100uF).
              klassisch
              schrieb am zuletzt editiert von klassisch
              #118
              Erfahrungsbericht:
              Betreibe 2 BH1750 Sensoren seit Jahren. Einer sitzt unter einem Dachfenster und schaut unter 25° Dachneigung nach Norden. Der andere scheut durch ein Giebelfenster (also 90° Neigung) nach Osten.
              SW ist noch alt und selbstgefrickelt. Müßte man heute so nicht mehr machen, aber läuft stabil.
              Ale meine ESPs D1 Mini bekommen vom Start weg jeweils einen 1000µF Kondensators an den 3.3V und 5V. Nicht optimiert, wahrscheinlich überdimensioniert, aber eben stabil.
              Nett sind dann die Jahresansichten. Ansonsten habe ich wenige praktische Anwendungen.
              Für meine Lichtsteuerung in den Zimmern nutze ich aqara Zigbee Helligkeitssensoren an das Fenster geklebt.
              Hier noch eine Mehrjahresansicht, seit Aufzeichnung mit ioBroker. Die CCU.io Daten konnte ich leider nicht konvertieren.
              • D Dieter_P
                @smarthome2020
                smarthome2020
                #119
                @dieter_p
                Ich hab den Sensor an den 3,3V angeklemmt. Meinst du, dass das zu wenig ist und die Ursache sein könnte?
                Ansonsten muss ich einen Kondensator besorgen. Bisher lief alles ohne Kondensatoren/Widerständen stabil.
                OpenSourceNomadO D 2 Antworten Letzte Antwort
                • S smarthome2020
                  @dieter_p
                  OpenSourceNomad
                  #120
                  Immer 5V wenn der Sensor (breakoutboard) das kann.
                    smarthome2020
                    #121
                    @opensourcenomad
                    Auf 5V angekoppelt ist der Sensor gar nicht erreichbar.
                    Geht nur auf 3,3V.
                    Ich muss nachher mal einen anderen BH1750 nutzen bzw. ein anderes Board. Nicht, dass Hardware daran schuld ist.
                    • S smarthome2020
                      @opensourcenomad
                      Geht nur auf 3,3V.
                      smarthome2020
                      #122
                      @smarthome2020 sagte in [Anleitung] Selbstbau Wemos D1 mini und Helligkeitssensor BH1750:
                      @opensourcenomad
                      Geht nur auf 3,3V.
                      --> es scheint an der Hardware zu liegen. Hab an einem anderen ESP mal einen BH1750 angeschlossen und da geht es einwandfrei.
                      • S smarthome2020
                        @dieter_p
                        Dieter_P
                        #123
                        @dieter_p
                        Es gibt verschiedene Versionen. Ich nutze diese:
                        Die ist mit 5V Versorgungsspannung spezifiziert und auf 3,3V lief er gar nicht bei mir. Der I2C Bus ist zugegeben recht lang bei mir, wofür er im Ursprung nie gedacht war. Aber lokal die 5V gepuffert lässt ihn problemlos betreiben.
                        Da Du von 3,3V und D1 Mini sprichst, klingt dass eher nach einem Problem durch diese D1 Mini Kopien mit sehr billigem/schwachen Spannungsregler 5V -> 3,3V. Hierdurch gibt es oft Probleme, da der Spannungsregler gerade für den Betrieb des D1 Mini reicht, aber nicht noch zur Versorgung weiterer Sensoren. Evtl. hilft ein Pufferkondensator aber ein besserer D1 Mini ist auch eine sehr gute Sache.
