  4. Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T
    6.7k
17trackamazonbriefedhldpdglsups
1.6k Beiträge 129 Kommentatoren 730.8k Aufrufe 117 Beobachtet
  • ostseereiterO ostseereiter
    @tombox wie gesagt die 10 läuft nun wieder auf die 12 und rot
    im Log finde ich nur das:
    	2022-03-17 14:39:42.325	error	instance system.adapter.parcel.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.debian
    2022-03-17 14:39:42.325	error	Caught by controller[0]: }
    host.debian
    2022-03-17 14:39:42.325	error	Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
    host.debian
    2022-03-17 14:39:42.325	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12) {
    host.debian
    2022-03-17 14:39:42.324	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
    host.debian
    2022-03-17 14:39:42.324	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
    host.debian
    2022-03-17 14:39:42.324	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
    host.debian
    2022-03-17 14:39:42.324	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
    host.debian
    2022-03-17 14:39:42.324	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
    host.debian
    2022-03-17 14:39:42.323	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
    host.debian
    2022-03-17 14:39:42.323	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
    host.debian
    2022-03-17 14:39:42.323	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
    host.debian
    2022-03-17 14:39:42.323	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1144:18)
    host.debian
    2022-03-17 14:39:42.323	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    host.debian
    2022-03-17 14:39:42.322	error	Caught by controller[0]: NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
    host.debian
    2022-03-17 14:39:42.322	error	Caught by controller[0]: NODE_MODULE_VERSION 72. This version of Node.js requires
    host.debian
    2022-03-17 14:39:42.321	error	Caught by controller[0]: was compiled against a different Node.js version using
    host.debian
    2022-03-17 14:39:42.321	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
    host.debian
    2022-03-17 14:39:42.321	error	Caught by controller[0]: ^
    host.debian
    2022-03-17 14:39:42.320	error	Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
    host.debian
    2022-03-17 14:39:42.320	error	Caught by controller[0]: internal/modules/cjs/loader.js:1144
    #614
    @ostseereiter
    Neubauen lassen. War glaube ich weiter oben schon mal Thema.
    Und/oder deine node-Installation aktualisieren.
    ostseereiterO B 2 Antworten Letzte Antwort
      @ostseereiter
      ostseereiterO Offline
      ostseereiter
      #615
      danke das war die Lösung:
      cd /opt/iobroker
      npm install canvas
      Gruß OSR
      Plattform
      • G Offline
        Gruter
        #616
        Hi, ich habe bei Amazon aktuell noch "Altdaten" unter Objekte.
        Unter parcel.0.amazon.sendungen01.detailedState
        habe ich noch ein Ordner mapTracking, in diesem sind Daten vom 02.03. angezeigt, diese gehören nicht zur aktuellen Bestellung.
        in der JSON gibt es aktuell auch keinen Eintrag zu mapTracking.
          @ostseereiter
          bob der 1.
          schrieb am zuletzt editiert von bob der 1.
          #617
          Habe genau das gleiche Problem mit den Adapter Versionen 0.0.10&0.0.12, Node Version v14.19.1
          bei
          cd /opt/iobroker/node_modules
          npm list canvas
          bekomme ich als Ausgabe
          iobroker.inst@3.0.0 /opt/iobroker
          ├── canvas@2.9.0
          ├─┬ iobroker.echarts@1.0.3
          │ └── canvas@2.8.0
          ├─┬ iobroker.iot@1.8.24
          │ └── canvas@2.9.0  deduped
          ├─┬ iobroker.mihome-vacuum@3.3.5 (github:iobroker-community-adapters/ioBroker.mi                                     home-vacuum#_____________)
          │ └── canvas@2.9.0
          └─┬ iobroker.parcel@0.0.10
          anschließend
          cd /opt/iobroker
          npm install canvas
          Ausgabe
          [.......[..................] / loadDep:simple-get: sill removeObsoleteDep removing nan@2.15.0 from the tree as its be
          > canvas@2.9.0 install /opt/iobroker/node_modules/canvas
          > node-pre-gyp install --fallback-to-build
          node-pre-gyp ERR! install response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.9.0/canvas-v2.9.0-node-v83-linux-glibc-arm.tar.gz
          node-pre-gyp WARN Pre-built binaries not installable for canvas@2.9.0 and node@14.19.1 (node-v83 ABI, glibc) (falling back to source compile with node-gyp)
          node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/Automattic/node-canvas/releases/download/v2.9.0/canvas-v2.9.0-node-v83-linux-glibc-arm.tar.gz
          make: Entering directory '/opt/iobroker/node_modules/canvas/build'
            SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
            COPY Release/canvas-postbuild.node
            CXX(target) Release/obj.target/canvas/src/backend/Backend.o
            CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
            CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
            CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
            CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
          ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:
          ../src/bmp/BMPParser.cc:186:16: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare]
             E(ptr - data > imgdOffset, "image data overlaps with another structure");
          ../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’
           #define E(cond, msg) if(cond) return setErr(msg)
          ../src/bmp/BMPParser.cc:201:27: warning: comparison of integer expressions of different signedness: ‘uint32_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare]
             E(ptr - data + imgdSize > len, "not enough image data");
            CXX(target) Release/obj.target/canvas/src/Backends.o
            CXX(target) Release/obj.target/canvas/src/Canvas.o
            CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
            CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
            CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
            CXX(target) Release/obj.target/canvas/src/closure.o
            CXX(target) Release/obj.target/canvas/src/color.o
            CXX(target) Release/obj.target/canvas/src/Image.o
            CXX(target) Release/obj.target/canvas/src/ImageData.o
            CXX(target) Release/obj.target/canvas/src/init.o
            CXX(target) Release/obj.target/canvas/src/register_font.o
            SOLINK_MODULE(target) Release/obj.target/canvas.node
            COPY Release/canvas.node
          make: Leaving directory '/opt/iobroker/node_modules/canvas/build'
          npm WARN http-cookie-agent@1.0.5 requires a peer of tough-cookie@^4.0.0 but none is installed. You must install peer dependencies yourself.
          + canvas@2.9.0
          updated 1 package in 95.966s
          70 packages are looking for funding
            run `npm fund` for details
          Adapter gelöscht,beide Versionen versucht ...nichts!
            skokarl
            #618
            wofür, oder wann wird bei Amazon der Token benötigt ?
            Was ist wenn man bei Amazon 2 Konten hat..... z.B. für Ehefrau?
            sorry, aber 617 Beiträge durchsichen ist echt übel .....
            G DJMarc75D 2 Antworten Letzte Antwort
            • S skokarl
              guergen
              #619
              @skokarl Mal vorsichtig gesagt, zwei Instanzen anlegen....
              • S skokarl
                DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                #620
                @skokarl said in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                eine Instanz des Adapters kann nur ein Konto, egal welcher Dienstleister, abarbeiten, also wie @guergen geschrieben hat dann dementsprechend viele Instanzen installieren.
                Lehrling seit 1975 !!!
                  michaelxhoffmann
                  schrieb am zuletzt editiert von michaelxhoffmann
                  #621
                  Hi, habe den Adapter heute installiert. Hätte da eine Frage zur DHL Benachrichtigung. Wie bekomme ich die SMS bzw. Mail? Wann erhalte ich die? Email und Passwort habe ich korrekt eingegeben, aber die PIN fehlt mir irgendwie. Die Instanz bleibt auch konsequent rot.Ich habe die DHL App auf meinem Iphone installiert, Dort funktioniert sie auch.
                  Danke für Eure Hilfe
                  Homematic CCU2 - Raspberry Pi 4 - IOS (siri) - Amazon Echo 3rd Gen.
                  Thomas BraunT DJMarc75D 2 Antworten Letzte Antwort
                  • M michaelxhoffmann
                    #622
                    @michaelxhoffmann sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                    Die kommt beim Versuch sich einzuloggen automatisch. Sollte Sie zumindest.
                      DJMarc75D Offline
                      DJMarc75D Offline
                      DJMarc75
                      #623
                      @michaelxhoffmann said in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                      warte mal ne halbe Stunde und dann nochmal die Daten eingeben.
                      • Jabba_the_HuttJ Offline
                        Jabba_the_Hutt
                        schrieb am zuletzt editiert von Jabba_the_Hutt
                        #624
                        npm: 8.5.0
                        node.js: 16.14.2
                        Der Adapter lässt sich nicht installieren.
                        Fehler:
                        Der rebuild verläuft dann auch in einem Error.
                        Rebuild for adapter system.adapter.parcel.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                        sigi234S T 2 Antworten Letzte Antwort
                        • Jabba_the_HuttJ Jabba_the_Hutt
                          npm: 8.5.0
                          node.js: 16.14.2
                          Fehler:
                          sigi234S Online
                          sigi234S Online
                          #625
                          @jabba_the_hutt
                          Steh ja eh da, FALSCHE Version von Node:
                          Empfohlene sind:
                          NODE.JS: V14.19.1
                          NPM: 6.14.16
                          Jabba_the_HuttJ 1 Antwort Letzte Antwort
                            npm: 8.5.0
                            node.js: 16.14.2
                            Fehler:
                            tombox
                            #626
                            @jabba_the_hutt
                            Also node 16 ist kein problem aber npm 8 ist nocht nicht komplett getestet
                            cd /opt/iobroker
                            npm rebuild
                            npm install canvas
                            probiert?
                            • DJMarc75D Offline
                              DJMarc75D Offline
                              DJMarc75
                              #627
                              @tombox
                              Frage:
                              Kann man in der Konfig die einzelnen Dienstleister mit eine Checkbox zum de- oder aktivieren versehen ?
                              So muss man nicht jedesmal, wenn man einen Dienst an- oder ausschalten möchte die Zugangsdaten löschen oder neu eingeben.
                              • Rene RR Offline
                                Rene RR Offline
                                Rene R
                                #628
                                Hallo Liebe CSSler,
                                Ich bräuchte eure Hilfe....
                                Ich habe vor in dem CSS ( HTML ) beim Header wo Amazon Bestell Status steht davor und daneben ein kleines Amazon Logo hinzufügen.
                                und wäre es möglich die Gelieferten Bestellungen zu verstecken?
                                Ich habe es versucht über den VIS OWL das hinzubekommen aber klappt irgendwie nicht weil ich nur geringen platz haben höhe und breite 200px
                                hier den CSS CODE:
                                <style type="text/css">
                                #{wid} .tg {
                                 border-collapse:collapse;border-color:#9ABAD9;border-spacing:0;
                                #{wid} .tg td{
                                 background-color:;border-color:#9ABAD9;border-style:solid;border-width:0px;color:white;
                                 font-family:Comic Sans MS, sans-serif;font-size:10pxpx;overflow:hidden;padding:10px 5px;word-break:normal;
                                #{wid} .tg th{
                                 background-color:#409cff;border-color:#9ABAD9;border-style:solid;border-width:0px;color:#fff;
                                 font-family:Comic Sans MS, sans-serif;font-size:10px;font-weight:normal;overflow:hidden;padding:10px 5px;word-break:normal;
                                #{wid} .tg .tg-vn85{
                                 border-color:ffcc67;text-align:left;vertical-align:top
                                #{wid} .tg-sort-header::-moz-selection{
                                 background:0 0}
                                #{wid} .tg-sort-header::selection{
                                 background:0 0}.tg-sort-header{
                                 cursor:pointer
                                #{wid} .tg-sort-header:after{
                                 content:'';float:right;margin-top:7px;border-width:0 5px 5px;border-style:solid;
                                 border-color:#404040 transparent;visibility:hidden
                                #{wid} .tg-sort-header:hover:after{
                                 visibility:visible}
                                #{wid} .tg-sort-asc:after,.tg-sort-asc:hover:after,.tg-sort-desc:after{
                                 visibility:visible;opacity:.4
                                #{wid} .tg-sort-desc:after{
                                border-bottom:none;border-width:5px 5px 0
                                }</style>
                                <table id="tg-noEOi" class="tg">
                                <thead>
                                 <tr>
                                <th class="tg-vn85">Amazon Bestell Status</th>
                                 </tr>
                                </thead>
                                <tbody>
                                 <tr>
                                 <td class="tg-vn85">{parcel.0.amazon.sendungen01.status}</td>
                                 </tr>
                                 <tr>
                                 <td class="tg-vn85">{parcel.0.amazon.sendungen02.status}</td>
                                 </tr>
                                 <tr>
                                 <td class="tg-vn85">{parcel.0.amazon.sendungen03.status}</td>
                                 </tr>
                                 <tr>
                                 <td class="tg-vn85">{parcel.0.amazon.sendungen04.status}</td>
                                 </tr>
                                </tbody>
                                </table>
                                Wäre super wenn einer von euch mir helfen könnte.
                                Liebe Grüße
                                Rene
                                P.S der Adapter ist super
                                • sigi234S sigi234
                                  @jabba_the_hutt
                                  Empfohlene sind:
                                  NODE.JS: V14.19.1
                                  NPM: 6.14.16
                                  Jabba_the_Hutt
                                  #629
                                  @sigi234
                                  Ist mir schon klar, dass für NICHT Betatester andere Versionen vorgesehen sind.
                                  • Rene RR Rene R
                                    Hallo Liebe CSSler,
                                    hier den CSS CODE:
                                    #{wid} .tg {
                                    #{wid} .tg td{
                                    #{wid} .tg th{
                                     background:0 0}
                                     cursor:pointer
                                     visibility:visible}
                                    }</style>
                                    <thead>
                                     <tr>
                                     </tr>
                                    </thead>
                                    <tbody>
                                     <tr>
                                     </tr>
                                     <tr>
                                     </tr>
                                     <tr>
                                     </tr>
                                     <tr>
                                     </tr>
                                    </tbody>
                                    </table>
                                    Liebe Grüße
                                    Rene
                                    Buchi
                                    #630
                                    @rene-r sagte in Adapter Paketverfolgung DHL, Briefe, Amazon, DPD,GLS,UPS,17T:
                                    Hallo Liebe CSSler,
                                    Warum sollte das mit owl nicht gehen? Alles einstellbar :)
                                    Beste Grüße
                                    Gerhard
                                    Rene RR 1 Antwort Letzte Antwort
                                    • T tombox
                                      @jabba_the_hutt
                                      cd /opt/iobroker
                                      npm rebuild
                                      npm install canvas
                                      probiert?
                                      Jabba_the_Hutt
                                      #631
                                      @tombox
                                      Ja, habe ich versucht. Hilft leider auch nichts.
                                      • B Buchi
                                        Hallo Liebe CSSler,
                                        Rene RR Offline
                                        Rene RR Offline
                                        Rene R
                                        #632
                                        @buchi
                                        Ja schon aber das einstellen und VIS ist neuland für mich und css erst recht bräuchte da echt hilfe beim coden.
                                        -1
                                        • Rene RR Rene R
                                          @buchi
                                          Buchi
                                          #633
                                          @buchi
                                          Dann solltest einfach mal im Thread fragen. Bisher wurde noch jedem geholfen ;)
                                          Beste Grüße
                                          Gerhard
                                          Rene RR ChaotC 2 Antworten Letzte Antwort
