  3. Einsteigerfragen
  4. Problem mit Admin und so
    5.5k
71 Beiträge 7 Kommentatoren 9.2k Aufrufe 5 Beobachtet
  • wendy2702W wendy2702
    @marcus-hamburg Leider fehlt da die über die hälfte aller Ausgaben.
    Marcus HamburgM Offline
    Marcus Hamburg
    @wendy2702
    pi@raspberrypi:~ $ sudo iob stop
    pi@raspberrypi:~ $ sudo iob fix
    library: loaded
    Library version=2022-02-10
        Welcome to the ioBroker installation fixer!
        Script version: 2022-02-13
        Installing prerequisites (1/3)
    OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    OK:2 http://archive.raspberrypi.org/debian buster InRelease
    OK:3 https://deb.nodesource.com/node_16.x buster InRelease
    Installed gcc-c++
        Checking ioBroker user and directory permissions (2/3)
        Checking autostart (3/3)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    pi@raspberrypi:~ $ sudo iob start
    pi@raspberrypi:~ $ sudo iob list instances
      system.adapter.admin.0                  : admin                 : raspberrypi                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
      system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      system.adapter.habpanel.0               : habpanel              : raspberrypi                              -  enabled
      system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
      system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
      system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      system.adapter.mihome.0                 : mihome                : raspberrypi                              -  enabled, port: 9898, bind: 0.0.0.0
      system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
      system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
      system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
      system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 192.168.178.21, run as: admin
    + instance is alive
    pi@raspberrypi:~ $ sudo iob update
    Used repository: stable
    hash unchanged, use cached sources
    update done
    Adapter    "admin"         : 5.3.1    , installed 5.2.3 [Updateable]
    Adapter    "alexa2"        : 3.11.2   , installed 3.11.2
    Adapter    "backitup"      : 2.3.3    , installed 2.2.3 [Updateable]
    Adapter    "discovery"     : 2.7.5    , installed 2.7.3 [Updateable]
    Adapter    "habpanel"      : 0.4.3    , installed 0.4.3
    Adapter    "hmip"          : 1.15.4   , installed 1.15.2 [Updateable]
    Adapter    "hue"           : 3.6.5    , installed 3.5.31 [Updateable]
    Adapter    "ical"          : 1.11.4   , installed 1.11.4
    Adapter    "info"          : 1.9.8    , installed 1.9.8
    Adapter    "javascript"    : 5.2.21   , installed 5.2.21
    Controller "js-controller" : 4.0.21   , installed 3.3.22 [Updateable]
    Adapter    "mihome"        : 1.3.7    , installed 1.3.7
    Adapter    "openweathermap": 0.1.0    , installed 0.1.0
    Adapter    "simple-api"    : 2.6.2    , installed 2.6.1 [Updateable]
    Adapter    "socketio"      : 3.1.5    , installed 3.1.5
    Adapter    "tankerkoenig"  : 2.1.1    , installed 2.1.1
    Adapter    "tr-064"        : 4.2.15   , installed 4.2.14 [Updateable]
    Adapter    "trashschedule" : 1.4.1    , installed 1.4.1
    Adapter    "web"           : 3.4.16   , installed 3.4.16
    • Marcus HamburgM Marcus Hamburg
      @wendy2702
      library: loaded
      Installed gcc-c++
      Autostart enabled!
      + instance is alive
      update done
      @marcus-hamburg
      NICHT mit sudo und iob zugleich hantieren.
      Der iobroker wird nicht per sudo angepackt.
      Gleichnochmal...
      iobroker stop
      iobroker fix
        @marcus-hamburg
        Gleichnochmal...
        iobroker stop
        iobroker fix
        wendy2702W Offline
        wendy2702W Offline
        @thomas-braun sagte in Problem mit Admin und so:
        @marcus-hamburg
        Du warst schneller.
        @Marcus-Hamburg
        iob start admin.0
        Marcus HamburgM 1 Antwort Letzte Antwort
          @marcus-hamburg
          Du warst schneller.
          @Marcus-Hamburg
          iob start admin.0
          Marcus Hamburg
          @wendy2702 Ihr seit die Helden des Tages. Danke 👍 👍 👍
            @marcus-hamburg
            Dann geh jetzt den Rest an:
            35 nicht aktualisiert.
            sudo apt update
            sudo apt full-upgrade
            iobroker stop
            sudo reboot
            Und dann die Adapter auf Stand bringen.
              @marcus-hamburg
              sudo apt update
              iobroker stop
              sudo reboot
              Marcus Hamburg
              @thomas-braun ok hätte ich gerne, hab da jedoch noch ne m
              meldung
              npm ERR! code ENOTEMPTY
              die Meldung erscheint bei jeden Adapter update
                meldung
                @marcus-hamburg
                Mehr Kontext. Mit dem Einzeiler kann man nix anfangen.
                  @marcus-hamburg
                  Marcus Hamburg
                  pi@raspberrypi:/opt/iobroker $ iob upgrade self
                  Update js-controller from @3.3.22 to @4.0.21
                  NPM version: 8.3.1
                  npm install iobroker.js-controller@4.0.21 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                  npm ERR! syscall rename
                  npm ERR! path /opt/iobroker/node_modules/iobroker.javascript
                  npm ERR! dest /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
                  npm ERR! errno -39
                  npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript' -> '/opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn'
                  npm ERR!     /home/iobroker/.npm/_logs/2022-03-16T13_07_27_428Z-debug-0.log
                  host.raspberrypi Cannot install iobroker.js-controller@4.0.21: 217
                    NPM version: 8.3.1
                    npm ERR! errno -39
                    @marcus-hamburg sagte in Problem mit Admin und so:
                    Damit kann man was anfangen. Und die Lösung ist auch gleich mit angegeben:
                    Hast du denn VOR dem upgrade self die Adapter aktualisiert?
                      @wendy2702 ok und das kommt nun raus.
                      pi@raspberrypi:~ $ sudo apt policy nodejs
                      nodejs:
                        Installiert:           17.1.0-deb-1nodesource1
                        Installationskandidat: 17.1.0-deb-1nodesource1
                        Versionstabelle:
                       *** 17.1.0-deb-1nodesource1 100
                           16.14.0-deb-1nodesource1 500
                              500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                           10.24.0~dfsg-1~deb10u1 500
                      pi@raspberrypi:~ $
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @Thomas-Braun
                      Installiert: 17.1.0
                      NPM version: 8.3.1
                      Da passt doch etwas nicht !?
                        Marcus Hamburg
                        @thomas-braun nein das ging eben nicht und bei rename passiert nichts.
                          Was genau passiert denn bei 'passiert nichts'?
                          Ich kann die Konsolenausgaben nicht sehen, die musst du schon hier reinkopieren.
                            @marcus-hamburg
                            Jetzt schauen wir erstmal ob die Basis sauber ist:
                            which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                              @marcus-hamburg
                              Marcus Hamburg
                              pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                              ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                              pi@raspberrypi:~ $
                              pi@raspberrypi:~ $
                              pi@raspberrypi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                              /usr/bin/nodejs
                              /home/pi/.config/nvm/versions/node/v17.1.0/bin/node
                              /home/pi/.config/nvm/versions/node/v17.1.0/bin/npm
                              v16.14.0
                              v17.1.0
                              8.5.4
                              pi
                              /home/pi
                              OK:1 http://archive.raspberrypi.org/debian buster InRelease
                              OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                              Alle Pakete sind aktuell.
                              nodejs:
                                Installiert:           16.14.0-deb-1nodesource1
                                Installationskandidat: 16.14.0-deb-1nodesource1
                                Versionstabelle:
                               *** 16.14.0-deb-1nodesource1 500
                              pi@raspberrypi:~ $
                                Marcus Hamburg
                                pi@raspberrypi:~ $ rename '/opt/iobroker/node_modules/iobroker.javascript' -> '/                                opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn'
                                -bash: /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn: Ist ein Verzeic                                hnis
                                  @marcus-hamburg
                                  NodeJS ist krumm und schief installiert.
                                  Das hast du irgendwie mit nvm in das System geballert.
                                  Deinstallieren, wie auch immer das geht.
                                  Verzeichnisse werden so umbenannt:
                                  sudo -u iobroker mv /opt/iobroker/node_modules/iobroker.javascript /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
                                    @marcus-hamburg
                                    wendy2702W Offline
                                    wendy2702W Offline
                                    @marcus-hamburg
                                    Ich hatte extra zu Beginn deine Anleitung verlinkt.
                                      @marcus-hamburg
                                      @wendy2702
                                      Die ist ja auch umgesetzt worden (so halb jedenfalls). Nur war nie die Rede von 'wild per nvm' installierten Versionen. Die stehen da jetzt noch in der falschen Gegend rum.
                                        @wendy2702
                                        Marcus Hamburg
                                        @thomas-braun tut mir leid, dass ich chaos produziere. Ich möchte nur meine pi für das Smarthome nutzen und leider bin ich doch eher der eine IOS System nutzt. :-(
                                        Was müsste ich nun machen. Die Anleitung von Anfang habe ich soweit ich es verstanden haben umgesetzt.
                                        Marcus HamburgM Thomas BraunT 2 Antworten Letzte Antwort
                                          Marcus Hamburg
                                          schrieb am zuletzt editiert von Marcus Hamburg
                                          Wenn ich ein Adapter update, kommt folgende Meldung
                                          $ iobroker upgrade backitup@2.3.3
                                          Update backitup from @2.2.3 to @2.3.3
                                          NPM version: 8.3.1
                                          npm install iobroker.backitup@2.3.3 --loglevel error --prefix "/opt/iobroker" (System call)
                                          npm ERR! code ENOTEMPTYnpm ERR! syscall renamenpm ERR! path /opt/iobroker/node_modules/typescriptnpm ERR! dest /opt/iobroker/node_modules/.typescript-rKKYB1QGnpm ERR! errno -39npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/typescript' -> '/opt/iobroker/node_modules/.typescript-rKKYB1QG'npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-03-16T14_23_28_020Z-debug-0.log
                                          host.raspberrypi Cannot install iobroker.backitup@2.3.3: 217
                                          ERROR: Process exited with code 25
