  4. [gelöst] mal wieder: No connection to databases possible ...
    5.6k
connectiondatabase
93 Beiträge 7 Kommentatoren 17.2k Aufrufe 5 Beobachtet
  • D DGR
    sudo -H -u iobroker npm install iobroker.js-controller
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    > iobroker.js-controller@4.0.21 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.14.16
    > authenticate-pam@1.0.2 install /opt/iobroker/node_modules/authenticate-pam
    > node-gyp rebuild
    make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird betreten
      CXX(target) Release/obj.target/authenticate_pam/authenticate_pam.o
    In file included from ../authenticate_pam.cc:23:
    ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
    ../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
    ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:
    ../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
       Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args);
    ../../nan/nan.h:1024:46: note: declared here
       NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
    ../authenticate_pam.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Authenticate(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../authenticate_pam.cc:147:83: error: no matching function for call to ‘v8::Array::Get(v8::Local<v8::String>)’
       Local<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecked());
    In file included from /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:67,
                     from ../../nan/nan.h:54,
    /home/iobroker/.cache/node-gyp/14.19.0/include/node/v8.h:3717:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, v8::Local<v8::Value>)’
       V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context,
    /home/iobroker/.cache/node-gyp/14.19.0/include/node/v8.h:3717:43: note:   candidate expects 2 arguments, 1 provided
    /home/iobroker/.cache/node-gyp/14.19.0/include/node/v8.h:3720:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, uint32_t)’
    /home/iobroker/.cache/node-gyp/14.19.0/include/node/v8.h:3720:43: note:   candidate expects 2 arguments, 1 provided
    ../authenticate_pam.cc:150:69: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’
        serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1);
    /home/iobroker/.cache/node-gyp/14.19.0/include/node/v8.h:3037:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’
       int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,
    /home/iobroker/.cache/node-gyp/14.19.0/include/node/v8.h:3037:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’
    ../authenticate_pam.cc:152:69: error: no matching function for call to ‘v8::Array::Get(v8::Local<v8::String>)’
       res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked());
    ../authenticate_pam.cc:155:66: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’
        remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1);
    ../authenticate_pam.cc:160:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’
      username->WriteUtf8(m->username, sizeof(m->username) - 1);
    ../authenticate_pam.cc:161:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’
      password->WriteUtf8(m->password, sizeof(m->password) - 1);
    ../authenticate_pam.cc: At global scope:
    ../authenticate_pam.cc:170:11: error: variable or field ‘init’ declared void
     void init(Handle<Object> exports) {
    ../authenticate_pam.cc:170:11: error: ‘Handle’ was not declared in this scope
    ../authenticate_pam.cc:170:11: note: suggested alternative: ‘rand_r’
               rand_r
    ../authenticate_pam.cc:170:24: error: expected primary-expression before ‘>’ token
    ../authenticate_pam.cc:170:26: error: ‘exports’ was not declared in this scope
    In file included from ../../nan/nan.h:54,
    ../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope
     NODE_MODULE(authenticate_pam, init);
    /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:793:36: note: in definition of macro ‘NODE_MODULE_X’
           (node::addon_register_func) (regfunc),                          \
    ../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’
    ../authenticate_pam.cc:175:31: note: suggested alternative: ‘int’
    make: *** [authenticate_pam.target.mk:109: Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
    make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird verlassen
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)
    gyp ERR! System Linux 5.10.103-v7l+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
    gyp ERR! node -v v14.19.0
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    > iobroker.js-controller@4.0.21 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    npm ERR! code ELIFECYCLE
    npm ERR! errno 22
    npm ERR! iobroker.js-controller@4.0.21 install: `node iobroker.js setup first`
    npm ERR! Exit status 22
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@4.0.21 install script.
    npm ERR!     /home/iobroker/.npm/_logs/2022-03-15T14_56_11_790Z-debug.log
    @dgr
    Deinstallier den Adapter 'terminal'.
    Und verwende CodeTags!
    • D DGR
      > node-gyp rebuild
                 rand_r
      gyp ERR! not ok
      npm ERR! errno 22
      npm ERR!
      DGR
      @dgr sorry, unerwartet ist Besuch da gewesen. Offenbar habe ich das Reinkopieren wohl doch nicht korrekt gemacht.
      • D DGR
        AlCalzoneA Offline
        AlCalzoneA Offline
        AlCalzone
        @dgr Kannst auch mal folgendes probieren:
        cd /opt/iobroker
        npm i iobroker.js-controller --ignore-scripts
        iobroker.json anpassen, damit connectTimeout höher ist
        iobroker setup first
          @dgr
          DGR
          in /opt/iobroker/node_modules sehe ich keinen Adapter "terminal", zumindest nicht unter diesem Namen.
          ansonsten wäre "sudo rm -r /opt/iobroker/node_modules/iobroker.terminal" richtig ?
          Nebenfrage:
          Wenn bei "Submit" für eine Antwort Error und Forbidden rechts unten erscheint - was ist das für ein Problem ?
          • AlCalzoneA AlCalzone
            cd /opt/iobroker
            DGR
            @alcalzone
            + iobroker.js-controller@4.0.21
            added 79 packages from 34 contributors in 46.591s
            67 packages are looking for funding
              run `npm fund` for details
            /opt/iobroker $ iobroker setup first
            kann das ganze eine Rechtefrage sein ?
            • D DGR
              @alcalzone
              @dgr
              cd /opt/iobroker
              npm ls authenticate-pam
                @dgr
                cd /opt/iobroker
                DGR
                /opt/iobroker $ npm ls authenticate-pam
                iobroker.inst@2.0.3 /opt/iobroker
                └─┬ iobroker.terminal@0.1.2
                  └── authenticate-pam@1.0.2
                • D DGR
                  Nebenfrage:
                  @dgr sagte in mal wieder: No connection to databases possible ...:
                  ein bekannter Bug mit unbekannter Ursache!
                  einfach Browser neu laden und gut ist
                  • D DGR
                    @dgr
                    Da isser doch!
                    iobroker del terminal
                      @dgr
                      Da isser doch!
                      DGR
                      /opt/iobroker $ iobroker del terminal
                      • D DGR
                        AlCalzoneA Offline
                        AlCalzoneA Offline
                        AlCalzone
                        @dgr Hast du denn jetzt schon den connection timeout hochgestellt?
                        D 2 Antworten Letzte Antwort
                          DGR
                          @alcalzone
                          "objects": {
                              "type": "jsonl",
                              "typeComment": "Possible values: 'file' - [port 9001], redis - [port 6379], couch - [port 5984].",
                              "host": "127.0.0.1",
                              "port": 9001,
                              "user": "",
                              "pass": "",
                              "noFileCache": false,
                              "connectTimeout": 30000,
                              "options": {
                                "auth_pass": null,
                                "retry_max_delay": 2000
                            DGR
                            @alcalzone stand noch so von gestern
                            • D DGR
                              DGR
                              @dgr
                              Die Wahrscheinlichkeit einer erfolgreichen Reparatur schätze ich nach den ganzen Versuchen als nicht mehr so hoch ein.
                              Ein restore mit dem "aktuellen" Backup wäre noch eine Versuch wert:
                              iob restore /opt/iobroker/iobroker_2021_12_29-02_00_10_backupiobroker.tar.gz
                              Sonst bleibt noch die iobroker-Neuinstallation:
                              1. Wichtig: Vorher würde ich gerne noch einiges retten wenn möglich (wie ???), z.B. Scripte, Datenpunkte, vis, - was wäre noch sinnvoll ?
                              2. Sollte vor einer Neuinstallation irgendwas bereinigt/gelöscht werden ?
                              3. Gibt es einen link zu einer Anleitung für eine Neuinstallation iobroker ?
                              4. Meine Vorgehensweise wäre sonst:
                              sudo apt-get update
                              sudo apt-get upgrade
                              sudo apt-get --purge remove node nodejs
                              sudo apt-get autoremove
                              sudo -s
                              curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash -
                              exit
                              sudo apt-get install -y nodejs
                              node -v (zum Test)
                              cd /opt/iobroker
                              curl -sLf https://iobroker.net/install.sh | bash -
                              iobroker start
                              • D DGR
                                @dgr
                                sudo apt-get update
                                sudo -s
                                exit
                                node -v (zum Test)
                                cd /opt/iobroker
                                iobroker start
                                wendy2702W Online
                                wendy2702W Online
                                @dgr Node JS wird bei Verwendung des "einzeilers"
                                in der richtigen Version mit installiert. Sollte nicht vorher manuell ausgeführt werden.
                                Du kannst dir diese beiden Dateien sichern wie im Mini how to beschrieben
                                https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host?_=1647414866222
                                Wenn auf dem System nur iobroker lief würde ich aber komplett von vorne beginnen mit einem frischen bullseye
                                • wendy2702W wendy2702
                                  DGR
                                  @wendy2702
                                  Danke, werde ich dann so anpassen (curl...)
                                  bullseye nach der Anleitung erscheint mir dann auch sinnvoll.
                                  Nur wie rette ich meine Scripte (Blockly) und evtl. andere Einstellungen für eine weitere Nutzung nach Neuinstallation ?
                                  • D DGR
                                    @wendy2702
                                    wendy2702W Online
                                    wendy2702W Online
                                    Kannst entweder wie geschrieben die beiden Files sichern, alles manuell exportieren/kopieren oder aber du spielst dein Backup wieder ein.
                                    Vielleicht am einfachsten eine weitere SD Karte für die neue installation verwenden oder von der alten ein Image erstellen. Dann kannst du im Bedarfsfall zurück wechseln.
                                    • apollon77A Online
                                      apollon77A Online
                                      Ok @DGR ... nichts ist verloren ... und ich finde es immer wieder erstaunlich (sorry) wie in einem Thread an verschiedensten (ggf komplett unrelated) Themen parallel versucht wird zu arbeiten ohne sich erstmal auf eins zu konzentrieren :-)
                                      Also dann nochmal ... alles einen Schritt zurück und Konzentration auf das "no connection to db" issue!
                                      1.) "iob version" ... ist es jetzt ein 4.0.21 oder welche Version nutzt du :-)
                                      2.) Nochmal: Wie gross sind AKTUELL die objects.jsonl und states.jsonl?
                                      3.) Wenn Du ein Kommando startest was in dem Fehler endet - jetzt mit 30s timeouts - dauert es auch ca. 30s bis die Meldung kommt? Bitte mal in einem zweiten Shell-Fenster parallel "top" laufen lassen. Es müsste wenn Du das Kommando startest dann ein node Prozess kommen. Verbraucht der viel CPU? Wieviel RAM?
                                      4.) WENN der Prozess kommt und quasi 30s viel CPU braucht und dann abgebrochen wird dann bitte das Timeout setting weiter erhöhen. Mach ruhig 90000 draus.
                                      5.) Dann nochmal ... geht es dann? Oder braucht der dann 90s so viel CPU und es geht weiter nicht? Wenn es danach tat ... wie gross sind die beiden Files objects.jsonl und states.jsonl jetzt?
                                      • apollon77A apollon77
                                        wendy2702W Online
                                        wendy2702W Online
                                        #66
                                        @apollon77 sagte in mal wieder: No connection to databases possible ...:
                                        Verstehe ich nicht.
                                        Kannst du eventuell kurz erläutern was aus deiner Sicht hier nicht hin gehört?
                                          Verstehe ich nicht.
                                          apollon77A Online
                                          apollon77A Online
                                          #67
                                          @wendy2702 Die terminal Adapter deinstallation, überhaupt controller neu installieren ... sowas :-)
                                          Ich weiss, alle wollen helfen und das finde ich super und mag ich seehr doll hier im Forum!!
                                          In dem Fall "lenkt es ab" (meiner Meinung nach) ... Auch für mich der dann viel länger braucht um durchzusteigen :-)
