  4. Adapter für VELUX KLF-200 Interface
393 Beiträge 82 Kommentatoren 134.5k Aufrufe 64 Beobachtet
  • M marios774
    seit gestern ist mein KLF tiefrot und das log quillt über.
    2022-01-30 18:09:40.381 - error: host.iobroker Caught by controller[0]: internal/modules/cjs/loader.js:905
    2022-01-30 18:09:40.382 - error: host.iobroker Caught by controller[0]: throw err;
    2022-01-30 18:09:40.382 - error: host.iobroker Caught by controller[0]: ^
    2022-01-30 18:09:40.383 - error: host.iobroker Caught by controller[0]: Error: Cannot find module 'node-schedule'
    2022-01-30 18:09:40.383 - error: host.iobroker Caught by controller[0]: Require stack:
    2022-01-30 18:09:40.383 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.klf200/build/main.js
    2022-01-30 18:09:40.383 - error: host.iobroker Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
    2022-01-30 18:09:40.384 - error: host.iobroker Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:746:27)
    2022-01-30 18:09:40.384 - error: host.iobroker Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
    2022-01-30 18:09:40.384 - error: host.iobroker Caught by controller[0]: at require (internal/modules/cjs/helpers.js:93:18)
    2022-01-30 18:09:40.384 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.klf200/build/main.js:10:25)
    2022-01-30 18:09:40.384 - error: host.iobroker Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
    2022-01-30 18:09:40.384 - error: host.iobroker Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
    2022-01-30 18:09:40.385 - error: host.iobroker Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
    2022-01-30 18:09:40.385 - error: host.iobroker Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
    2022-01-30 18:09:40.385 - error: host.iobroker Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:76:12) {
    2022-01-30 18:09:40.385 - error: host.iobroker Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    2022-01-30 18:09:40.385 - error: host.iobroker Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.klf200/build/main.js' ]
    2022-01-30 18:09:40.385 - error: host.iobroker Caught by controller[0]: }
    2022-01-30 18:09:40.385 - error: host.iobroker instance system.adapter.klf200.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2022-01-30 18:09:40.386 - info: host.iobroker Restart adapter system.adapter.klf200.0 because enabled
    Ich habe neben einem apt-get update nur einige andere Adapter über den Admin deinstalliert. Selbst ein Backup auf den Stand von Freitag, wo ich zumindest noch den Rollo nutzen konnte führt nun zu der Meldung....
    Bitte um Hilfe.
    # npm -v
    6.14.15
    # node -v
    v14.18.3
    # nodejs -v
    v12.22.9
    #139
    @marios774 sagte in Adapter für VELUX KLF-200 Interface:
    # npm -v
    6.14.15        # node -v
    v14.18.3
    # nodejs -v
    v12.22.9
    Du bist nicht zufällig als root unterwegs?
    NodeJS krumm/falsch installiert. Schau genauer damit nach:
    which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      # npm -v
      6.14.15        # node -v
      v14.18.3
      # nodejs -v
      v12.22.9
      marios774
      #140
      @thomas-braun sagte in Adapter für VELUX KLF-200 Interface:
      /usr/bin/nodejs
      /usr/local/bin/node
      /usr/local/bin/npm
      v12.22.9
      v14.18.3
      6.14.15
      root
      /opt/iobroker/iobroker-data
      OK:1 http://security.debian.org/debian-security stretch/updates InRelease
      OK:2 http://phoscon.de/apt/deconz stretch InRelease
      OK:3 https://deb.nodesource.com/node_12.x stretch InRelease
      Ign:4 http://ftp.us.debian.org/debian stretch InRelease
      OK:5 http://ftp.us.debian.org/debian stretch-updates InRelease
      OK:6 http://ftp.us.debian.org/debian stretch Release
      Alle Pakete sind aktuell.
      nodejs:
        Installiert:           12.22.9-1nodesource1
        Installationskandidat: 12.22.9-1nodesource1
        Versionstabelle:
       *** 12.22.9-1nodesource1 500
              500 https://deb.nodesource.com/node_12.x stretch/main amd64 Packages
           4.8.2~dfsg-1 500
              500 http://ftp.us.debian.org/debian stretch/main amd64 Packages
      root@iobroker:/opt/iobroker/iobroker-data#
      Das hat bisher über ein Jahr so geklappt als root..
      • M marios774
        /usr/bin/nodejs
        /usr/local/bin/node
        /usr/local/bin/npm
        v12.22.9
        v14.18.3
        6.14.15
        root
        nodejs:
          Versionstabelle:
             4.8.2~dfsg-1 500
        #141
        @marios774
        Gleich drei Baustellen:
        1. root login
        2. Stretch ist tot
        3. NodeJS ist falsch installiert
          @marios774
          1. root login
          2. Stretch ist tot
          marios774
          #142
          ... ich bekomme leider keinen geraden linux Befehl hin ohne Vorgabe, da habe ich wohl beim update irgendwo einen Fehler gemacht.
          Soll / muss ich nun erst auf Buster upgraden, oder direkt auf Bullseye?
          • M marios774
            #143
            @marios774
            Bei den Vorbedingungen:
            Installier Bullseye direkt neu.
            Ohne aktiven root.
              @marios774
              Ohne aktiven root.
              marios774
              #144
              das mit dem root...
              auf meinem alte MacMini läuft Debian in einer Parallel Umgebung...
              Etwas krude, da ich für Mac aber irgendwie kein Tutorial für Docker und co. gefunden habe und meine Synology zu klein ist, war das nach einem Crash auf dem nativen Mac die schnellste und einfachste Lösung.
              Wie immer.. Provisorium für die Ewigkeit.
              • M marios774
                das mit dem root...
                #145
                @marios774
                Wie auch immer...
                Provisorium ausknipsen, aktuelle Version neuinstallieren.
                • O Online
                  O Online
                  oxident
                  #146
                  Gerade den Adapter in Betrieb genommen. Klappt einwandfrei!
                  Da frage ich mich, wie visualisiert ihr das?
                  Bei mir sind elektrische Fenster und mir ist nichts besseres eingefallen, als eine Kombination zwischen jqui-mfd's "Roof window" zur Anzeige und drei Material Design Widgets "State buttons", jeweils eins für "zu", "halb" und "auf":
                  Den derzeitig aktiven Status blende ich aus. Aber irgendwie haut mich das nicht um ;-)
                  • O Online
                    O Online
                    oxident
                    #147
                    Puhh, lese leider erst jetzt, dass das HW-Interface ganz schön zickig ist. Bin heute auch das erste Mal in die Situation gekommen, dass der Adapter auf Rot springt und im Log nur noch "Login failed" erscheint ... trotz aktiviertem Reboot.
                    Wie löst Ihr das? Schaltbarer Zwischenstecker um einen "Hardreset" zu machen?
                    • O oxident
                      amg_666A Offline
                      amg_666A Offline
                      amg_666
                      #148
                      @oxident siehe mein Post oben (Screenshot). Ich habe im Adapter "enable reboot" gesetzt und einen cron-job immer um 3 Uhr Nachts für Reboot, seitdem läufts stabil.
                      Und den Zwischenstecker habe ich zusätzlich, den habe ich im letzten Jahr einmal gebraucht als nix mehr ging und dann habe ich remote aus- und wieder angeschaltet. Das mache ich aber manuell da habe ich kein Skript oder ähnliches.
                      • O oxident
                        amg_666A Offline
                        amg_666A Offline
                        amg_666
                        #149
                        @oxident das visualisiere ich mit vis-icontwo:
                        O 1 Antwort Letzte Antwort
                        • amg_666A amg_666
                          O Online
                          O Online
                          oxident
                          #150
                          @amg_666 Sehr cool. Danke für die Tipps!
                          Werde jetzt einfach einen PoE-Splitter für die Stromversorgung nehmen. Hatte zwar auch den Reboot um 3 Uhr, ist dann aber um 8 Uhr dennoch abgestürzt. War vielleicht auch nur Zufall...
                          • O oxident
                            amg_666A Offline
                            amg_666A Offline
                            amg_666
                            #151
                            @oxident Steuerst du den Adapter direkt (also über Skripte) ? Da hab ich nur schlechte Erfahrungen mit gemacht. Seit ich shuttercontrol nutze läuft das stabil.
                            • amg_666A amg_666
                              O Online
                              O Online
                              oxident
                              #152
                              @amg_666 Bisher habe ich ihn nur manuell, also über Vis, gesteuert.
                              Aber shuttercontrol klingt interessant, zumal zu den Fensteröffnern jetzt auch Jalousien hinzukommen.
                              • O oxident
                                amg_666A Offline
                                amg_666A Offline
                                amg_666
                                #153
                                @oxident Als ich das noch manuell/per Skript gemacht habe musste ich jeden Tag einmal einen "Hard Reset" mchen. Wenn du also weiterhin manuell steuern willst solltest du einen Zwischenstecker nehmen und einmal nachts ein-/ausschalten
                                • amg_666A amg_666
                                  K Online
                                  K Online
                                  Kuddel
                                  #154
                                  seit ca. 4 Wochen läuft bei mir der Adapter für 4 Dachfenster im OG.
                                  Leider habe ich hin und wieder Probleme beim steuern der Rolladen per Blockly.
                                  In den DPs vom KLF wird der Status dann als "Unknown(255)" angezeigt.
                                  Eine manuelle Steuerung per Fernbedigung geht aber immer.
                                  Kennt jemand das Problem und kann helfen?
                                  Können es evtl. Empfangsprobleme sein ?
                                    memberx
                                    #155
                                    Ich habe soeben auch das KLF200 und ioBroker Adapter installiert. Habe einen Somfy IO ZipScreen und ein Faltdach (Horizontalmarkise).
                                    Der Zipscreen funktioniert ohne Probleme auch mit Prozentpositionen. Das Faltdach reagiert aber überhaupt nicht. Jemand eine Idee?
                                    Danke im Voraus
                                      M.M.
                                      #156
                                      Habt ihr eine aktuelle Bezugsquelle für die KLF-200? Mich verwundert, dass Velux die im eigenen Shop aktuell nicht listet.
                                      amg_666A K 2 Antworten Letzte Antwort
                                      • M M.M.
                                        amg_666A Offline
                                        amg_666A Offline
                                        amg_666
                                        #157
                                        @m-m Ich hatte meinen bei ebay gekauft, das war ein gewerblicher Anbieter aus Polen, Versand hat etwas gedauert aber ansonsten alles top. Wenn du bei ebay nach "velux klf" suchst zeigt er dir diverse Händler an, die den Adpater im Angebot haben.
                                        • M M.M.
                                          K Online
                                          K Online
                                          Kuddel
                                          #158
                                          @m-m habe bei uns gerade 4 Fenster getauscht und das Teil direkt mitgeordert. Alles ohne Probleme
