  3. Einsteigerfragen
  4. Frage zu Instanz web.0
    5.6k
24 Beiträge 6 Kommentatoren 2.5k Aufrufe 4 Beobachtet
  • David G.D Online
    David G.D Online
    David G.
    Habe den selben Fehler in einer frischen iob Installation.
    Aber noch nichts bei gedacht..... ^^.
    Hier der Debug-Log bei Adapterneustart:
    web.0
    2022-02-27 11:38:57.953	warn	State "web.0.info.connected" has no existing object, this might lead to an error in future versions
    web.0
    2022-02-27 11:38:56.965	info	http server listening on port 8082
    web.0
    2022-02-27 11:38:56.950	debug	Activating web files from objectDB
    web.0
    2022-02-27 11:38:56.950	debug	Activating extensions
    web.0
    2022-02-27 11:38:56.950	info	socket.io server listening on port 8082
    web.0
    2022-02-27 11:38:56.911	debug	Activating IOSocket
    web.0
    2022-02-27 11:38:56.908	debug	Using http createServer
    web.0
    2022-02-27 11:38:56.907	debug	Activating states & socket info
    web.0
    2022-02-27 11:38:56.805	info	starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v14.19.0, js-controller: 4.0.15
    web.0
    2022-02-27 11:38:56.587	debug	Plugin sentry Initialize Plugin (enabled=true)
    web.0
    2022-02-27 11:38:56.559	debug	States connected to redis: 127.0.0.1:9000
    web.0
    2022-02-27 11:38:56.553	debug	States create User PubSub Client
    web.0
    2022-02-27 11:38:56.552	debug	States create System PubSub Client
    web.0
    2022-02-27 11:38:56.548	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    web.0
    2022-02-27 11:38:56.538	debug	Objects connected to redis: 127.0.0.1:9001
    web.0
    2022-02-27 11:38:56.534	debug	Objects client initialize lua scripts
    web.0
    2022-02-27 11:38:56.522	debug	Objects create User PubSub Client
    web.0
    2022-02-27 11:38:56.522	debug	Objects create System PubSub Client
    web.0
    2022-02-27 11:38:56.520	debug	Objects client ready ... initialize now
    web.0
    2022-02-27 11:38:56.476	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    host.iobroker
    2022-02-27 11:38:55.923	info	instance system.adapter.web.0 started with pid 151704
    host.iobroker
    2022-02-27 11:38:53.362	info	instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.iobroker
    2022-02-27 11:38:52.839	info	stopInstance system.adapter.web.0 send kill signal
    web.0
    2022-02-27 11:38:52.834	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    web.0
    2022-02-27 11:38:52.834	debug	Plugin sentry destroyed
    web.0
    2022-02-27 11:38:52.833	info	terminating
    web.0
    2022-02-27 11:38:52.833	info	terminated http server on port 8082
    web.0
    2022-02-27 11:38:52.833	debug	terminating http server on port 8082
    web.0
    2022-02-27 11:38:52.832	info	Got terminate signal TERMINATE_YOURSELF
    host.iobroker
    2022-02-27 11:38:52.828	info	stopInstance system.adapter.web.0 (force=false, process=true)
    • David G.D David G.
      web.0
      web.0
      web.0
      web.0
      web.0
      web.0
      web.0
      web.0
      web.0
      web.0
      web.0
      web.0
      web.0
      web.0
      web.0
      web.0
      web.0
      web.0
      web.0
      web.0
      host.iobroker
      host.iobroker
      host.iobroker
      web.0
      web.0
      web.0
      web.0
      web.0
      web.0
      host.iobroker
      @david-g sagte in Frage zu Instanz web.0:
      welchen?
      ich sehe keinen Fehler.
      @erich-1 sagte in Frage zu Instanz web.0:
      Wie mache ich das?
      Was?
        welchen?
        Wie mache ich das?
        Was?
        David G.D Online
        David G.D Online
        David G.
        Dass die Instanz wie beim TE gelb bleibt (jedoch wunderbar funktioniert).
        Meine Vermutung war, dass es was mit dem
        web.0
        zu tun hat.
          web.0
          zu tun hat.
          web.0 2022-02-27 11:38:57.953 warn State "web.0.info.connected" has no existing object, this might lead to an error in future
          zu tun hat.
          nein!
          diese Warnung ist für die Entwickler, dass dort ein Objekt fehlt, was gefixt werden muss
            zu tun hat.
            nein!
            David G.D Online
            David G.D Online
            David G.
            Okay. Dann hat es nichts mit zu tun.
            Dann gibt der Debug wohl keine Meldung, warum die Instanz gelb bleibt.
            @homoran sagte in Frage zu Instanz web.0:
            Wie mache ich das?
            Was?
            Das debug log.
              @erich-1 vorweg:
              da ist kein einziger debug-Eintrag.
              Hast du wirklich unter Instanzen die Logstufe des Web-Adapters auf debug geschaltet?
              und wie vermutet warn: web.0 (60946) State "web.0.info.connected" has no existing object, this might lead to an error in future versions ist dies nur ein warn.
              einen Error sehe ich auch nirgends
              der webserver läuft, und habpanel auch
              2022-02-27 11:26:10.165 - info: web.0 (60946) socket.io server listening on port 8082
               2022-02-27 11:26:10.168 - info: web.0 (60946) habpanel server listening on port 8082
               2022-02-27 11:26:10.169 - info: web.0 (60946) habpanel web extension - Install extension on /rest/habpanel/
              2022-02-27 11:26:10.170 - info: web.0 (60946) Connect extension "habpanel/lib/habpanelapi.js"
              2022-02-27 11:26:10.184 - info: web.0 (60946) http server listening on port 8082
              Erich 1
              @homoran said in Frage zu Instanz web.0:
              @erich-1 vorweg:
              Das meinte ich mit "Wie macht man das?" ...
              • E Erich 1
                @erich-1 vorweg:
                • Instanzen
                • expertenmodus
                • Instanz web.0
                • Logstufe auf debug ändern
                E 1 Antwort Letzte Antwort
                  • Instanzen
                  • expertenmodus
                  • Instanz web.0
                  Erich 1
                  2022-02-27 00:00:43.369 - info: web.0 (54312) <== Disconnect system.user.admin from ::ffff:192.168.178.45 habpanel.0
                  2022-02-27 00:00:44.397 - warn: web.0 (54312) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
                  2022-02-27 00:00:46.709 - info: web.0 (54312) ==> Connected system.user.admin from ::ffff:192.168.178.45
                  2022-02-27 00:00:47.710 - warn: web.0 (54312) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
                  2022-02-27 00:01:33.567 - info: web.0 (54312) <== Disconnect system.user.admin from ::ffff:192.168.178.45 habpanel.0
                  2022-02-27 00:01:34.570 - warn: web.0 (54312) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
                  2022-02-27 00:22:30.245 - info: web.0 (54312) <== Disconnect system.user.admin from ::ffff:192.168.178.91 habpanel.0
                  2022-02-27 00:22:30.484 - info: web.0 (54312) ==> Connected system.user.admin from ::ffff:192.168.178.91
                  2022-02-27 00:22:31.247 - warn: web.0 (54312) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
                  2022-02-27 00:40:46.383 - info: web.0 (54312) <== Disconnect system.user.admin from ::ffff:192.168.178.91 habpanel.0
                  2022-02-27 00:40:47.388 - warn: web.0 (54312) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
                  2022-02-27 00:41:09.600 - info: web.0 (54312) ==> Connected system.user.admin from ::ffff:192.168.178.91
                  2022-02-27 00:41:10.602 - warn: web.0 (54312) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
                  2022-02-27 00:41:45.864 - info: web.0 (54312) <== Disconnect system.user.admin from ::ffff:192.168.178.91 habpanel.0
                  2022-02-27 00:41:46.868 - warn: web.0 (54312) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
                  2022-02-27 01:29:18.663 - info: web.0 (54312) ==> Connected system.user.admin from ::ffff:192.168.178.45
                  2022-02-27 01:29:19.665 - warn: web.0 (54312) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
                  2022-02-27 01:29:20.610 - info: web.0 (54312) <== Disconnect system.user.admin from ::ffff:192.168.178.45 habpanel.0
                  2022-02-27 01:29:20.970 - info: web.0 (54312) ==> Connected system.user.admin from ::ffff:192.168.178.45
                  2022-02-27 01:29:21.614 - warn: web.0 (54312) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
                  2022-02-27 01:30:08.637 - info: web.0 (54312) <== Disconnect system.user.admin from ::ffff:192.168.178.45 habpanel.0
                  2022-02-27 01:30:09.640 - warn: web.0 (54312) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
                  2022-02-27 07:00:43.842 - info: email.0 (13210) Send email: {"text":"Guten Morgen! Die Sonne ist in Laaber gerade aufgegangen!","to":"erich.kuttenberger@gmx.de","subject":"Sonnenaufgang","from":"ioBroker"}
                  2022-02-27 07:00:44.156 - info: email.0 (13210) sent to erich.kuttenberger@gmx.de
                  2022-02-27 09:05:50.692 - info: host.raspberrypi iobroker add fritzdect --host raspberrypi
                  2022-02-27 09:05:53.122 - info: host.raspberrypi iobroker NPM version: 6.14.16
                  2022-02-27 09:05:53.133 - info: host.raspberrypi iobroker npm install iobroker.fritzdect@2.2.3 --loglevel error --prefix "/opt/iobroker" (System call)
                  2022-02-27 09:06:08.752 - info: host.raspberrypi iobroker host.raspberrypi install adapter fritzdect
                  2022-02-27 09:06:08.796 - info: host.raspberrypi iobroker upload [4] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/words.js words.js application/javascript
                  2022-02-27 09:06:08.892 - info: host.raspberrypi iobroker upload [3] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/style.css style.css text/css
                  2022-02-27 09:06:08.952 - info: host.raspberrypi iobroker upload [2] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/index_m.html index_m.html text/html
                  2022-02-27 09:06:09.010 - info: host.raspberrypi iobroker upload [1] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/fritzdect_logo.png fritzdect_logo.png image/png
                  2022-02-27 09:06:09.076 - info: host.raspberrypi iobroker upload [0] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/admin.d.ts admin.d.ts video/mp2t
                  2022-02-27 09:06:09.171 - info: host.raspberrypi "system.adapter.vis.0" disabled
                  2022-02-27 09:06:09.204 - info: host.raspberrypi "system.adapter.vis.0" enabled
                  2022-02-27 09:06:09.209 - info: host.raspberrypi iobroker Adapter "system.adapter.vis.0" restarted.
                  2022-02-27 09:06:09.318 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.fritzdect created/updated
                  2022-02-27 09:06:09.386 - info: host.raspberrypi "system.adapter.vis.0" disabled
                  2022-02-27 09:06:09.388 - info: host.raspberrypi stopInstance system.adapter.vis.0 (force=false, process=true)
                  2022-02-27 09:06:09.421 - info: host.raspberrypi "system.adapter.vis.0" enabled
                  2022-02-27 09:06:09.422 - info: host.raspberrypi stopInstance system.adapter.vis.0 (force=false, process=true)
                  2022-02-27 09:06:09.427 - info: host.raspberrypi iobroker Adapter "system.adapter.vis.0" restarted.
                  2022-02-27 09:06:09.447 - info: host.raspberrypi iobroker host.raspberrypi create instance fritzdect
                  2022-02-27 09:06:09.464 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.fritzdect.0.logLevel created
                  2022-02-27 09:06:09.499 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.fritzdect.0.sigKill created
                  2022-02-27 09:06:09.535 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.fritzdect.0.eventLoopLag created
                  2022-02-27 09:06:09.569 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.fritzdect.0.outputCount created
                  2022-02-27 09:06:09.603 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.fritzdect.0.inputCount created
                  2022-02-27 09:06:09.639 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.fritzdect.0.uptime created
                  2022-02-27 09:06:09.675 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.fritzdect.0.memRss created
                  2022-02-27 09:06:09.711 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.fritzdect.0.memHeapTotal created
                  2022-02-27 09:06:09.749 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.fritzdect.0.memHeapUsed created
                  2022-02-27 09:06:09.785 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.fritzdect.0.cputime created
                  2022-02-27 09:06:09.824 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.fritzdect.0.cpu created
                  2022-02-27 09:06:09.863 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.fritzdect.0.compactMode created
                  2022-02-27 09:06:09.899 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.fritzdect.0.connected created
                  2022-02-27 09:06:09.939 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.fritzdect.0.alive created
                  2022-02-27 09:06:09.986 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.fritzdect.0 created
                  2022-02-27 09:06:10.541 - info: vis.0 (60471) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.vis, node: v14.19.0, js-controller: 3.3.22
                  2022-02-27 09:06:10.573 - error: vis.0 (60471) No license found for vis. Please get one on https://iobroker.net !
                  2022-02-27 09:06:10.648 - info: vis.0 (60471) config.js changed. Upload.
                  2022-02-27 09:06:10.818 - info: vis.0 (60471) Changes in index.html detected => update cache.manifest
                  2022-02-27 09:06:10.860 - info: vis.0 (60471) Upload vis anew, while changes detected...
                  2022-02-27 09:06:11.027 - info: host.raspberrypi iobroker exit 0
                  2022-02-27 09:06:12.387 - info: host.raspberrypi "system.adapter.vis.0" disabled
                  2022-02-27 09:06:12.388 - info: host.raspberrypi stopInstance system.adapter.vis.0 (force=false, process=true)
                  2022-02-27 09:06:12.412 - info: host.raspberrypi "system.adapter.vis.0" enabled
                  2022-02-27 09:06:12.413 - info: host.raspberrypi stopInstance system.adapter.vis.0 (force=false, process=true)
                  2022-02-27 09:06:19.377 - info: vis.0 (60471) Uploaded. 0
                  2022-02-27 09:06:19.889 - info: vis.0 (60471) Terminated (NO_ERROR): Without reason
                  2022-02-27 09:06:20.448 - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
                  2022-02-27 09:07:55.747 - info: host.raspberrypi "system.adapter.fritzdect.0" enabled
                  2022-02-27 09:07:55.830 - info: host.raspberrypi instance system.adapter.fritzdect.0 started with pid 60498
                  2022-02-27 09:07:57.033 - info: fritzdect.0 (60498) starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v14.19.0, js-controller: 3.3.22
                  2022-02-27 09:07:57.062 - info: fritzdect.0 (60498) fritzdect entered ready
                  2022-02-27 09:07:57.095 - error: fritzdect.0 (60498) *** Adapter running, but doing nothing, credentials missing in Adaptper Settings !!! ***
                  2022-02-27 09:08:31.207 - info: web.0 (54312) Adapter is disabled => stop
                  2022-02-27 09:08:31.210 - info: host.raspberrypi "system.adapter.web.0" disabled
                  2022-02-27 09:08:31.212 - info: host.raspberrypi stopInstance system.adapter.web.0 (force=false, process=true)
                  2022-02-27 09:08:31.213 - info: web.0 (54312) terminated http server on port 8082
                  2022-02-27 09:08:31.245 - info: web.0 (54312) Got terminate signal TERMINATE_YOURSELF
                  2022-02-27 09:08:31.246 - info: host.raspberrypi stopInstance system.adapter.web.0 send kill signal
                  2022-02-27 09:08:31.248 - info: web.0 (54312) terminating
                  2022-02-27 09:08:31.252 - info: web.0 (54312) Terminated (NO_ERROR): Without reason
                  2022-02-27 09:08:31.803 - info: host.raspberrypi instance system.adapter.web.0 terminated with code 0 (NO_ERROR)
                  2022-02-27 09:08:32.938 - info: host.raspberrypi "system.adapter.web.0" enabled
                  2022-02-27 09:08:32.998 - info: host.raspberrypi instance system.adapter.web.0 started with pid 60514
                  2022-02-27 09:08:34.521 - info: web.0 (60514) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v14.19.0, js-controller: 3.3.22
                  2022-02-27 09:08:34.749 - info: web.0 (60514) socket.io server listening on port 8082
                  2022-02-27 09:08:34.756 - info: web.0 (60514) habpanel server listening on port 8082
                  2022-02-27 09:08:34.757 - info: web.0 (60514) habpanel web extension - Install extension on /rest/habpanel/
                  2022-02-27 09:08:34.758 - info: web.0 (60514) Connect extension "habpanel/lib/habpanelapi.js"
                  2022-02-27 09:08:34.771 - info: web.0 (60514) http server listening on port 8082
                  2022-02-27 09:08:35.752 - warn: web.0 (60514) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
                  2022-02-27 09:15:33.026 - info: web.0 (60514) ==> Connected system.user.admin from ::ffff:192.168.178.91
                  2022-02-27 09:15:34.029 - warn: web.0 (60514) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
                  2022-02-27 09:45:12.385 - info: shelly.0 (8011) State value to set for "shelly.0.SHSW-1#E8DB84D7335E#1.ext.switch1" has to be type "boolean" but received type "number"
                  2022-02-27 09:46:00.866 - info: shelly.0 (8011) State value to set for "shelly.0.SHSW-1#E8DB84D7335E#1.ext.switch1" has to be type "boolean" but received type "number"
                  2022-02-27 10:17:46.644 - info: host.raspberrypi iobroker add cloud --host raspberrypi
                  2022-02-27 10:17:49.139 - info: host.raspberrypi iobroker NPM version: 6.14.16
                  2022-02-27 10:17:49.141 - info: host.raspberrypi iobroker npm install iobroker.cloud@4.1.0 --loglevel error --prefix "/opt/iobroker" (System call)
                  2022-02-27 10:18:09.629 - info: host.raspberrypi iobroker host.raspberrypi install adapter cloud
                  2022-02-27 10:18:09.669 - info: host.raspberrypi iobroker upload [17] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/words.js words.js application/javascript
                  2022-02-27 10:18:09.757 - info: host.raspberrypi iobroker upload [16] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/jsonConfig.json jsonConfig.json application/json
                  2022-02-27 10:18:09.819 - info: host.raspberrypi iobroker upload [15] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/index_m.html index_m.html text/html
                  2022-02-27 10:18:09.878 - info: host.raspberrypi iobroker upload [14] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/img/info-big.png img/info-big.png image/png
                  2022-02-27 10:18:09.939 - info: host.raspberrypi iobroker upload [13] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                  2022-02-27 10:18:10.007 - info: host.raspberrypi iobroker upload [12] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                  2022-02-27 10:18:10.070 - info: host.raspberrypi iobroker upload [11] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                  2022-02-27 10:18:10.130 - info: host.raspberrypi iobroker upload [10] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                  2022-02-27 10:18:10.190 - info: host.raspberrypi iobroker upload [9] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                  2022-02-27 10:18:10.253 - info: host.raspberrypi iobroker upload [8] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/it/translations.json i18n/it/translations.json application/json
                  2022-02-27 10:18:10.311 - info: host.raspberrypi iobroker upload [7] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                  2022-02-27 10:18:10.372 - info: host.raspberrypi iobroker upload [6] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/es/translations.json i18n/es/translations.json application/json
                  2022-02-27 10:18:10.432 - info: host.raspberrypi iobroker upload [5] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/en/translations.json i18n/en/translations.json application/json
                  2022-02-27 10:18:10.491 - info: host.raspberrypi iobroker upload [4] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/de/translations.json i18n/de/translations.json application/json
                  2022-02-27 10:18:10.549 - info: host.raspberrypi iobroker upload [3] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/cloud.png cloud.png image/png
                  2022-02-27 10:18:10.608 - info: host.raspberrypi iobroker upload [2] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/blockly.js blockly.js application/javascript
                  2022-02-27 10:18:10.666 - info: host.raspberrypi iobroker upload [1] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/alexalogo.png alexalogo.png image/png
                  2022-02-27 10:18:10.723 - info: host.raspberrypi iobroker upload [0] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/actions.js actions.js application/javascript
                  2022-02-27 10:18:10.848 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.cloud created/updated
                  2022-02-27 10:18:10.906 - info: host.raspberrypi iobroker host.raspberrypi create instance cloud
                  2022-02-27 10:18:10.914 - info: host.raspberrypi iobroker host.raspberrypi object cloud.0.services created
                  2022-02-27 10:18:10.946 - info: host.raspberrypi iobroker host.raspberrypi object cloud.0.info.remoteTill created
                  2022-02-27 10:18:10.977 - info: host.raspberrypi iobroker host.raspberrypi object cloud.0.info.userOnCloud created
                  2022-02-27 10:18:11.010 - info: host.raspberrypi iobroker host.raspberrypi object cloud.0.info.connection created
                  2022-02-27 10:18:11.041 - info: host.raspberrypi iobroker host.raspberrypi object cloud.0.info created
                  2022-02-27 10:18:11.076 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.cloud.0.logLevel created
                  2022-02-27 10:18:11.108 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.cloud.0.sigKill created
                  2022-02-27 10:18:11.141 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.cloud.0.eventLoopLag created
                  2022-02-27 10:18:11.175 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.cloud.0.outputCount created
                  2022-02-27 10:18:11.209 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.cloud.0.inputCount created
                  2022-02-27 10:18:11.241 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.cloud.0.uptime created
                  2022-02-27 10:18:11.276 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.cloud.0.memRss created
                  2022-02-27 10:18:11.326 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.cloud.0.memHeapTotal created
                  2022-02-27 10:18:11.352 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.cloud.0.memHeapUsed created
                  2022-02-27 10:18:11.386 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.cloud.0.cputime created
                  2022-02-27 10:18:11.422 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.cloud.0.cpu created
                  2022-02-27 10:18:11.457 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.cloud.0.compactMode created
                  2022-02-27 10:18:11.490 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.cloud.0.connected created
                  2022-02-27 10:18:11.523 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.cloud.0.alive created
                  2022-02-27 10:18:11.555 - info: host.raspberrypi iobroker host.raspberrypi Set default value of cloud.0.info.userOnCloud: false
                  2022-02-27 10:18:11.585 - info: host.raspberrypi iobroker host.raspberrypi Set default value of cloud.0.info.connection: false
                  2022-02-27 10:18:11.632 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.cloud.0 created
                  2022-02-27 10:18:12.678 - info: host.raspberrypi iobroker exit 0
                  2022-02-27 11:21:33.614 - info: shelly.0 (8011) State value to set for "shelly.0.SHSW-1#E8DB84D7335E#1.ext.switch1" has to be type "boolean" but received type "number"
                  2022-02-27 11:25:25.537 - info: shelly.0 (8011) State value to set for "shelly.0.SHSW-1#E8DB84D7335E#1.ext.switch1" has to be type "boolean" but received type "number"
                  2022-02-27 11:25:55.191 - info: web.0 (60514) <== Disconnect system.user.admin from ::ffff:192.168.178.91 habpanel.0
                  2022-02-27 11:25:56.208 - warn: web.0 (60514) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
                  2022-02-27 11:26:04.196 - info: web.0 (60514) Adapter is disabled => stop
                  2022-02-27 11:26:04.201 - info: web.0 (60514) terminated http server on port 8082
                  2022-02-27 11:26:04.200 - info: host.raspberrypi "system.adapter.web.0" disabled
                  2022-02-27 11:26:04.209 - info: host.raspberrypi stopInstance system.adapter.web.0 (force=false, process=true)
                  2022-02-27 11:26:04.244 - info: web.0 (60514) Got terminate signal TERMINATE_YOURSELF
                  2022-02-27 11:26:04.244 - info: host.raspberrypi stopInstance system.adapter.web.0 send kill signal
                  2022-02-27 11:26:04.248 - info: web.0 (60514) terminating
                  2022-02-27 11:26:04.251 - info: web.0 (60514) Terminated (NO_ERROR): Without reason
                  2022-02-27 11:26:04.805 - info: host.raspberrypi instance system.adapter.web.0 terminated with code 0 (NO_ERROR)
                  2022-02-27 11:26:08.110 - info: host.raspberrypi "system.adapter.web.0" enabled
                  2022-02-27 11:26:08.179 - info: host.raspberrypi instance system.adapter.web.0 started with pid 60946
                  2022-02-27 11:26:09.933 - info: web.0 (60946) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v14.19.0, js-controller: 3.3.22
                  2022-02-27 11:26:11.169 - warn: web.0 (60946) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
                  2022-02-27 12:12:22.624 - info: web.0 (60946) ==> Connected system.user.admin from ::ffff:192.168.178.91
                  2022-02-27 12:12:23.627 - warn: web.0 (60946) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
                  2022-02-27 12:44:40.669 - info: host.raspberrypi "system.adapter.web.0" disabled
                  2022-02-27 12:44:40.673 - info: host.raspberrypi stopInstance system.adapter.web.0 (force=false, process=true)
                  2022-02-27 12:44:40.690 - info: web.0 (60946) Got terminate signal TERMINATE_YOURSELF
                  2022-02-27 12:44:40.694 - info: host.raspberrypi stopInstance system.adapter.web.0 send kill signal
                  2022-02-27 12:44:40.694 - info: web.0 (60946) terminated http server on port 8082
                  2022-02-27 12:44:40.696 - info: web.0 (60946) terminating
                  2022-02-27 12:44:40.698 - info: web.0 (60946) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2022-02-27 12:44:41.308 - info: host.raspberrypi instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2022-02-27 12:46:07.355 - info: host.raspberrypi "system.adapter.web.0" enabled
                  2022-02-27 12:46:07.441 - info: host.raspberrypi instance system.adapter.web.0 started with pid 61214
                  2022-02-27 12:46:08.960 - info: web.0 (61214) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v14.19.0, js-controller: 3.3.22
                  2022-02-27 12:46:09.183 - info: web.0 (61214) socket.io server listening on port 8082
                  2022-02-27 12:46:09.187 - info: web.0 (61214) habpanel server listening on port 8082
                  2022-02-27 12:46:09.187 - info: web.0 (61214) habpanel web extension - Install extension on /rest/habpanel/
                  2022-02-27 12:46:09.188 - info: web.0 (61214) Connect extension "habpanel/lib/habpanelapi.js"
                  2022-02-27 12:46:09.203 - info: web.0 (61214) http server listening on port 8082
                  2022-02-27 12:46:10.187 - warn: web.0 (61214) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
                  2022-02-27 12:46:12.745 - info: web.0 (61214) ==> Connected system.user.admin from ::ffff:192.168.178.91
                  2022-02-27 12:46:13.215 - info: web.0 (61214) ==> Connected system.user.admin from ::ffff:192.168.178.91
                  2022-02-27 12:46:13.748 - warn: web.0 (61214) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
                  2022-02-27 12:46:17.231 - info: web.0 (61214) <== Disconnect system.user.admin from ::ffff:192.168.178.91 habpanel.0
                  2022-02-27 12:46:18.235 - warn: web.0 (61214) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
                  2022-02-27 12:48:42.734 - info: web.0 (61214) <== Disconnect system.user.admin from ::ffff:192.168.178.91
                  2022-02-27 12:48:43.738 - warn: web.0 (61214) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
                  2022-02-27 14:26:37.635 - info: admin.0 (7983) Adapter rating updated
                  2022-02-27 14:26:47.760 - info: admin.0 (7983) Request actual repository...
                  2022-02-27 14:26:48.020 - info: host.raspberrypi Updating repository "default" under "http://download.iobroker.net/sources-dist.json"
                  2022-02-27 14:26:49.233 - info: admin.0 (7983) Repository received successfully.
                  2022-02-27 14:28:32.405 - info: host.raspberrypi "system.adapter.web.0" disabled
                  2022-02-27 14:28:32.419 - info: host.raspberrypi stopInstance system.adapter.web.0 (force=false, process=true)
                  2022-02-27 14:28:32.437 - info: web.0 (61214) Got terminate signal TERMINATE_YOURSELF
                  2022-02-27 14:28:32.440 - info: host.raspberrypi stopInstance system.adapter.web.0 send kill signal
                  2022-02-27 14:28:32.443 - info: web.0 (61214) terminated http server on port 8082
                  2022-02-27 14:28:32.445 - info: web.0 (61214) terminating
                  2022-02-27 14:28:32.448 - info: web.0 (61214) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2022-02-27 14:28:33.001 - info: host.raspberrypi instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2022-02-27 14:28:59.149 - info: host.raspberrypi "system.adapter.web.0" enabled
                  2022-02-27 14:28:59.241 - info: host.raspberrypi instance system.adapter.web.0 started with pid 61493
                  2022-02-27 14:29:00.667 - info: web.0 (61493) Plugin sentry Sentry Plugin disabled for this process because data reporting is disabled on instance
                  2022-02-27 14:29:00.721 - info: web.0 (61493) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v14.19.0, js-controller: 3.3.22
                  2022-02-27 14:29:00.971 - info: web.0 (61493) socket.io server listening on port 8082
                  2022-02-27 14:29:00.977 - info: web.0 (61493) habpanel server listening on port 8082
                  2022-02-27 14:29:00.977 - info: web.0 (61493) habpanel web extension - Install extension on /rest/habpanel/
                  2022-02-27 14:29:00.978 - info: web.0 (61493) Connect extension "habpanel/lib/habpanelapi.js"
                  2022-02-27 14:29:00.985 - info: web.0 (61493) http server listening on port 8082
                  2022-02-27 14:29:01.974 - warn: web.0 (61493) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
                  2022-02-27 14:30:36.205 - info: host.raspberrypi stopInstance system.adapter.web.0 (force=false, process=true)
                  2022-02-27 14:30:36.234 - info: web.0 (61493) Got terminate signal TERMINATE_YOURSELF
                  2022-02-27 14:30:36.237 - info: host.raspberrypi stopInstance system.adapter.web.0 send kill signal
                  2022-02-27 14:30:36.242 - info: web.0 (61493) terminated http server on port 8082
                  2022-02-27 14:30:36.244 - info: web.0 (61493) terminating
                  2022-02-27 14:30:36.248 - info: web.0 (61493) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2022-02-27 14:30:36.800 - info: host.raspberrypi instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2022-02-27 14:30:39.288 - info: host.raspberrypi instance system.adapter.web.0 started with pid 61510
                  2022-02-27 14:30:40.359 - debug: web.0 (61510) Redis Objects: Use Redis connection: 127.0.0.1:9001
                  2022-02-27 14:30:40.400 - debug: web.0 (61510) Objects client ready ... initialize now
                  2022-02-27 14:30:40.404 - debug: web.0 (61510) Objects create System PubSub Client
                  2022-02-27 14:30:40.416 - debug: web.0 (61510) Objects create User PubSub Client
                  2022-02-27 14:30:40.417 - debug: web.0 (61510) Objects client initialize lua scripts
                  2022-02-27 14:30:40.432 - debug: web.0 (61510) Objects connected to redis: 127.0.0.1:9001
                  2022-02-27 14:30:40.441 - debug: web.0 (61510) objectDB connected
                  2022-02-27 14:30:40.444 - debug: web.0 (61510) Redis States: Use Redis connection: 127.0.0.1:9000
                  2022-02-27 14:30:40.456 - debug: web.0 (61510) States create System PubSub Client
                  2022-02-27 14:30:40.457 - debug: web.0 (61510) States create User PubSub Client
                  2022-02-27 14:30:40.465 - debug: web.0 (61510) States connected to redis: 127.0.0.1:9000
                  2022-02-27 14:30:40.466 - debug: web.0 (61510) statesDB connected
                  2022-02-27 14:30:40.705 - debug: web.0 (61510) Plugin sentry Initialize Plugin (enabled=true)
                  2022-02-27 14:30:40.707 - info: web.0 (61510) Plugin sentry Sentry Plugin disabled for this process because data reporting is disabled on instance
                  2022-02-27 14:30:40.762 - info: web.0 (61510) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v14.19.0, js-controller: 3.3.22
                  2022-02-27 14:30:40.897 - debug: web.0 (61510) Activating states & socket info
                  2022-02-27 14:30:40.900 - debug: web.0 (61510) Using http createServer
                  2022-02-27 14:30:40.904 - debug: web.0 (61510) Activating IOSocket
                  2022-02-27 14:30:41.007 - info: web.0 (61510) socket.io server listening on port 8082
                  2022-02-27 14:30:41.008 - debug: web.0 (61510) Activating extensions
                  2022-02-27 14:30:41.011 - info: web.0 (61510) habpanel server listening on port 8082
                  2022-02-27 14:30:41.011 - info: web.0 (61510) habpanel web extension - Install extension on /rest/habpanel/
                  2022-02-27 14:30:41.012 - info: web.0 (61510) Connect extension "habpanel/lib/habpanelapi.js"
                  2022-02-27 14:30:41.013 - debug: web.0 (61510) Activating web files from objectDB
                  2022-02-27 14:30:41.020 - info: web.0 (61510) http server listening on port 8082
                  2022-02-27 14:30:42.011 - warn: web.0 (61510) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
                  2022-02-27 14:30:44.484 - info: host.raspberrypi "system.adapter.web.0" disabled
                  2022-02-27 14:30:44.487 - info: host.raspberrypi stopInstance system.adapter.web.0 (force=false, process=true)
                  2022-02-27 14:30:44.497 - info: web.0 (61510) Got terminate signal TERMINATE_YOURSELF
                  2022-02-27 14:30:44.503 - info: host.raspberrypi stopInstance system.adapter.web.0 send kill signal
                  2022-02-27 14:30:44.500 - debug: web.0 (61510) terminating http server on port 8082
                  2022-02-27 14:30:44.501 - info: web.0 (61510) terminated http server on port 8082
                  2022-02-27 14:30:44.502 - info: web.0 (61510) terminating
                  2022-02-27 14:30:44.504 - debug: web.0 (61510) Plugin sentry destroyed
                  2022-02-27 14:30:44.505 - info: web.0 (61510) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2022-02-27 14:30:45.055 - info: host.raspberrypi instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2022-02-27 14:30:46.321 - info: host.raspberrypi "system.adapter.web.0" enabled
                  2022-02-27 14:30:46.387 - info: host.raspberrypi instance system.adapter.web.0 started with pid 61525
                  2022-02-27 14:30:47.479 - debug: web.0 (61525) Redis Objects: Use Redis connection: 127.0.0.1:9001
                  2022-02-27 14:30:47.521 - debug: web.0 (61525) Objects client ready ... initialize now
                  2022-02-27 14:30:47.534 - debug: web.0 (61525) Objects create System PubSub Client
                  2022-02-27 14:30:47.536 - debug: web.0 (61525) Objects create User PubSub Client
                  2022-02-27 14:30:47.537 - debug: web.0 (61525) Objects client initialize lua scripts
                  2022-02-27 14:30:47.550 - debug: web.0 (61525) Objects connected to redis: 127.0.0.1:9001
                  2022-02-27 14:30:47.558 - debug: web.0 (61525) objectDB connected
                  2022-02-27 14:30:47.561 - debug: web.0 (61525) Redis States: Use Redis connection: 127.0.0.1:9000
                  2022-02-27 14:30:47.569 - debug: web.0 (61525) States create System PubSub Client
                  2022-02-27 14:30:47.570 - debug: web.0 (61525) States create User PubSub Client
                  2022-02-27 14:30:47.578 - debug: web.0 (61525) States connected to redis: 127.0.0.1:9000
                  2022-02-27 14:30:47.579 - debug: web.0 (61525) statesDB connected
                  2022-02-27 14:30:47.789 - debug: web.0 (61525) Plugin sentry Initialize Plugin (enabled=true)
                  2022-02-27 14:30:47.791 - info: web.0 (61525) Plugin sentry Sentry Plugin disabled for this process because data reporting is disabled on instance
                  2022-02-27 14:30:47.845 - info: web.0 (61525) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v14.19.0, js-controller: 3.3.22
                  2022-02-27 14:30:47.973 - debug: web.0 (61525) Activating states & socket info
                  2022-02-27 14:30:47.975 - debug: web.0 (61525) Using http createServer
                  2022-02-27 14:30:47.980 - debug: web.0 (61525) Activating IOSocket
                  2022-02-27 14:30:48.077 - info: web.0 (61525) socket.io server listening on port 8082
                  2022-02-27 14:30:48.078 - debug: web.0 (61525) Activating extensions
                  2022-02-27 14:30:48.081 - info: web.0 (61525) habpanel server listening on port 8082
                  2022-02-27 14:30:48.081 - info: web.0 (61525) habpanel web extension - Install extension on /rest/habpanel/
                  2022-02-27 14:30:48.082 - info: web.0 (61525) Connect extension "habpanel/lib/habpanelapi.js"
                  2022-02-27 14:30:48.083 - debug: web.0 (61525) Activating web files from objectDB
                  2022-02-27 14:30:48.089 - info: web.0 (61525) http server listening on port 8082
                  2022-02-27 14:30:49.080 - warn: web.0 (61525) State "web.0.info.connected" has no existing object, this might lead to an error in future versions
                  • H Offline
                    hausautomation.digital
                    Selbes Problem mit web.0 bei mir. Blöderweise startet VIS nicht.
                    Log web.0
                    2022-03-10 21:30:10.592 - info: host.homebutler stopInstance system.adapter.web.0 (force=false, process=true)
                    2022-03-10 21:30:10.601 - info: web.0 (27805) Got terminate signal TERMINATE_YOURSELF
                    2022-03-10 21:30:10.608 - info: host.homebutler stopInstance system.adapter.web.0 send kill signal
                    2022-03-10 21:30:10.604 - debug: web.0 (27805) terminating http server on port 8082
                    2022-03-10 21:30:10.605 - info: web.0 (27805) terminated http server on port 8082
                    2022-03-10 21:30:10.606 - info: web.0 (27805) terminating
                    2022-03-10 21:30:10.608 - debug: web.0 (27805) Plugin sentry destroyed
                    2022-03-10 21:30:10.609 - info: web.0 (27805) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2022-03-10 21:30:11.185 - info: host.homebutler instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2022-03-10 21:30:13.705 - info: host.homebutler instance system.adapter.web.0 started with pid 28352
                    2022-03-10 21:30:15.267 - debug: web.0 (28352) Redis Objects: Use Redis connection: 127.0.0.1:9001
                    2022-03-10 21:30:15.308 - debug: web.0 (28352) Objects client ready ... initialize now
                    2022-03-10 21:30:15.311 - debug: web.0 (28352) Objects create System PubSub Client
                    2022-03-10 21:30:15.313 - debug: web.0 (28352) Objects create User PubSub Client
                    2022-03-10 21:30:15.334 - debug: web.0 (28352) Objects client initialize lua scripts
                    2022-03-10 21:30:15.342 - debug: web.0 (28352) Objects connected to redis: 127.0.0.1:9001
                    2022-03-10 21:30:15.368 - debug: web.0 (28352) Redis States: Use Redis connection: 127.0.0.1:9000
                    2022-03-10 21:30:15.378 - debug: web.0 (28352) States create System PubSub Client
                    2022-03-10 21:30:15.379 - debug: web.0 (28352) States create User PubSub Client
                    2022-03-10 21:30:15.391 - debug: web.0 (28352) States connected to redis: 127.0.0.1:9000
                    2022-03-10 21:30:15.428 - debug: web.0 (28352) Plugin sentry Initialize Plugin (enabled=true)
                    2022-03-10 21:30:15.815 - info: web.0 (28352) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v14.19.0, js-controller: 4.0.19
                    2022-03-10 21:30:15.939 - debug: web.0 (28352) Activating states & socket info
                    2022-03-10 21:30:15.942 - debug: web.0 (28352) Using http createServer
                    2022-03-10 21:30:15.949 - debug: web.0 (28352) Activating extensions
                    2022-03-10 21:30:15.950 - debug: web.0 (28352) Activating web files from objectDB
                    2022-03-10 21:30:15.956 - info: web.0 (28352) http server listening on port 8082
                    Log VIS
                    2022-03-10 21:35:46.655 - info: host.homebutler "system.adapter.vis.0" enabled
                    2022-03-10 21:35:48.047 - debug: vis.0 (3261) Redis Objects: Use Redis connection: 127.0.0.1:9001
                    2022-03-10 21:35:48.099 - debug: vis.0 (3261) Objects client ready ... initialize now
                    2022-03-10 21:35:48.102 - debug: vis.0 (3261) Objects create System PubSub Client
                    2022-03-10 21:35:48.104 - debug: vis.0 (3261) Objects create User PubSub Client
                    2022-03-10 21:35:48.132 - debug: vis.0 (3261) Objects client initialize lua scripts
                    2022-03-10 21:35:48.139 - debug: vis.0 (3261) Objects connected to redis: 127.0.0.1:9001
                    2022-03-10 21:35:48.164 - debug: vis.0 (3261) Redis States: Use Redis connection: 127.0.0.1:9000
                    2022-03-10 21:35:48.172 - debug: vis.0 (3261) States create System PubSub Client
                    2022-03-10 21:35:48.174 - debug: vis.0 (3261) States create User PubSub Client
                    2022-03-10 21:35:48.184 - debug: vis.0 (3261) States connected to redis: 127.0.0.1:9000
                    2022-03-10 21:35:48.248 - info: vis.0 (3261) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.vis, node: v14.19.0, js-controller: 4.0.19
                    2022-03-10 21:35:48.628 - info: vis.0 (3261) vis license is OK.
                    2022-03-10 21:35:49.239 - info: vis.0 (3261) Terminated (NO_ERROR): Without reason
                    2022-03-10 21:35:49.779 - info: host.homebutler instance system.adapter.vis.0 terminated while should be started once
                    Ergebnis:
                    • crunchipC Offline
                      crunchipC Offline
                      @hausautomation-digital was zeigt die Browserconsole?
                      H 2 Antworten Letzte Antwort
                        @crunchip said in Frage zu Instanz web.0:
                        Was meinst Du damit? 👶
                          Browserconsole
                          Sorry, hab mich grad erst schlau gemacht. ;)
                          AbortError: Actor 'Conduits' destroyed before query 'RuntimeMessage' was resolved 2 ConduitsParent.jsm:362
                          Unchecked lastError value: Error: Could not establish connection. Receiving end does not exist. SymBfw.js:115
                          Unchecked lastError value: Error: Could not establish connection. Receiving end does not exist. 2 SymBfw.js:116
                          Unchecked lastError value: Error: Could not establish connection. Receiving end does not exist. SymBfw.js:116
                          Unchecked lastError value: Error: Could not establish connection. Receiving end does not exist. 2 SymBfw.js:115
                          TypeError: a is undefined BfwNotificationCenterProxy.js:6:65
                          Alternate Service Mapping found: https://adservice.google.de:-1 to https://googleads.g.doubleclick.net:443 2
                          Promise rejected after context unloaded: Actor 'Conduits' destroyed before query 'RuntimeMessage' was resolved
                          SymBfwCS.js:90
                          AbortError: Actor 'Conduits' destroyed before query 'RuntimeMessage' was resolved 12 ConduitsParent.jsm:362
                          3 SymBfwCS.js:90
                          Unchecked lastError value: Error: Could not establish connection. Receiving end does not exist. 4 SymBfw.js:115
                          AbortError: Actor 'ExtensionContent' destroyed before query 'DetectLanguage' was resolved 5 ExtensionCommon.jsm:727
                          SymBfwCS.js:90
                              sendMessage moz-extension://c0d11057-17ed-4a1d-881e-c84a0db224c7/content/scripts/SymBfwCS.js:90
                          Unchecked lastError value: Error: An unexpected error occurred 5 SymBfw.js:102
