  4. Test Adapter sureflap v3.4.2
154 Beiträge 17 Kommentatoren 44.5k Aufrufe 19 Beobachtet
  • Thomas BraunT Online
    @matis
    Der Adapter liegt im Beta-Repo vor.
    pi@chet:~ $ iobroker add sureflap
    NPM version: 8.1.4
    npm install iobroker.sureflap@1.0.8 --loglevel error --prefix "/opt/iobroker" (System call)
    host.chet install adapter sureflap
    upload [5] sureflap.admin /opt/iobroker/node_modules/iobroker.sureflap/admin/words.js words.js application/javascript
    upload [4] sureflap.admin /opt/iobroker/node_modules/iobroker.sureflap/admin/sureflap.png sureflap.png image/png
    upload [3] sureflap.admin /opt/iobroker/node_modules/iobroker.sureflap/admin/style.css style.css text/css
    upload [2] sureflap.admin /opt/iobroker/node_modules/iobroker.sureflap/admin/index_m.html index_m.html text/html
    upload [1] sureflap.admin /opt/iobroker/node_modules/iobroker.sureflap/admin/admin.d.ts admin.d.ts video/mp2t
    upload [0] sureflap.admin /opt/iobroker/node_modules/iobroker.sureflap/admin/SureFlap_Pet_Door_Connect_Hub_Phone.png SureFlap_Pet_Door_Connect_Hub_Phone.png image/png
    host.chet object system.adapter.sureflap created/updated
    host.chet create instance sureflap
    host.chet object sureflap.0.info.last_update created
    host.chet object sureflap.0.info.all_devices_online created
    host.chet object sureflap.0.info.connection created
    host.chet object sureflap.0.info created
    host.chet object system.adapter.sureflap.0.logLevel created
    host.chet object system.adapter.sureflap.0.sigKill created
    host.chet object system.adapter.sureflap.0.eventLoopLag created
    host.chet object system.adapter.sureflap.0.outputCount createdhost.chet object system.adapter.sureflap.0.inputCount created
    host.chet object system.adapter.sureflap.0.uptime created
    host.chet object system.adapter.sureflap.0.memRss created
    host.chet object system.adapter.sureflap.0.memHeapTotal created
    host.chet object system.adapter.sureflap.0.memHeapUsed createdhost.chet object system.adapter.sureflap.0.cputime created
    host.chet object system.adapter.sureflap.0.cpu created
    host.chet object system.adapter.sureflap.0.compactMode createdhost.chet object system.adapter.sureflap.0.connected created
    host.chet object system.adapter.sureflap.0.alive created
    host.chet Set default value of sureflap.0.info.last_update: false
    host.chet Set default value of sureflap.0.info.all_devices_online: false
    host.chet Set default value of sureflap.0.info.connection: false
    host.chet object system.adapter.sureflap.0 created
    pi@chet:~ $
    Ergo:
    pi@chet:~ $ iobroker list adapters | grep sureflap
    system.adapter.sureflap                : sureflap       - v1.0.8
    pi@chet:~ $
    Ganz ohne git.
      @matis
      NPM version: 8.1.4
      pi@chet:~ $
      Ergo:
      pi@chet:~ $
      Ganz ohne git.
      Matis
      @thomas-braun ... habs auf Beta umgestellt, dann ist das in der Tat einfacher, merci.
      • M Matis
        @thomas-braun ja, das Update läßt sich nicht installieren und bei einer Neuinstallation kommen die gleichen Fehler.
        Ich finde der Adapter ist ausgereift genug, dass man ihn mal in das offizielle Listing in iobroker aufnehme könnte.
        Sickboy78S Offline
        Sickboy78S Offline
        Sickboy78
        @matis Pull Request für die Aufnahme ins Stable Repository ist schon gestellt und wartet aufs Review: https://github.com/ioBroker/ioBroker.repositories/pull/1479
        Sickboy78S 1 Antwort Letzte Antwort
        • Sickboy78S Sickboy78
          Sickboy78S Offline
          Sickboy78S Offline
          Sickboy78
          schrieb am zuletzt editiert von Sickboy78
          Version 1.1.0 is officially in the stable repository!
          It contains a bugfix for remaining food in feeder not updating, some dependency security updates and some minor code improvements.
            Matt77CHE
            @sickboy78
            Hallo;
            Ich habe - gefühlt seit dem letzten App-Update - im Log den Eintrag "undefined is not a valid state value for id "sureflap.0.Home.Home_Cat_Hub.Buero_neu.assigned_pets.Charlie.control.type""
            Habe auf Github einen Eintag (#18) gemacht.
            Habt Ihr seit dem Update (App) auch immer wieder Verbindungsprobleme zum Konto?
            Wie kann man eigentlich den Hub updaten? - Falls es denn je einmal ein update gibt - die stehen ja in diesem Bereich so ziemlich aufm Schlauch bei denen....
            Gruss
            Matt
            • M Matt77CHE
              @sickboy78
              Hallo;
              Gruss
              Matt
              Sickboy78S Offline
              Sickboy78S Offline
              Sickboy78
              Hallo @matt77che ,
              wie auf github erwähnt, kam der Eintrag im Log daher, dass ich die Funktion, ein Tier als Wohnungstier oder Freigänger zu setzen, in Version 1.0.6 ergänzt hatte. Allerdings ist erst später aufgefallen, dass das nur von der Katzenklappe, aber nicht von der Haustierklappe unterstützt wird. Daher kam bei Haustierklappen diese Fehlermeldung.
              Ich hab das in Version 1.1.1 korrigiert und die Funktion für Haustierklappen wieder entfernt.
              Meinst du mit App die Smartphone App oder den Adapter? Wie äußern sich die Verbindungsprobleme?
              Ich glaube, der Hub updated sich selbstständig, zumindest finde ich im Handbuch nur folgende Info dazu:
              "Beide Ohren leuchten durchgehend rot: Die Firmware Ihres Hubs wird gerade aktualisiert. Haben Sie etwas Geduld. Ihr Hub wird in Kürze neu gestartet und funktioniert dann wie gewohnt." Beobachtet habe ich es allerdings noch nicht ...
              Sebastian
                Matt77CHE
                Das War die App - die hatten wieder einmal Probleme mit den Servern. - Hatte sich aber auch auf den Adapter ausgewirkt..
                  Matt77CHE
                  schrieb am zuletzt editiert von Matt77CHE
                  Ich habe ein kniffliges Problem:
                  Topographisch bedingt musste ich einen zweiten Hub bei mir Zuhause zulegen (um dort dann den Felaqua zu verbinden).
                  Meines Wissens ist es nicht möglich in einem Haushalt mehr als einen Hub zu haben (richtig?).
                  Also habe ich unter einer anderen Emailadresse ein weiteres Home (Home 2) erstellt, dort den Hub hinzugefügt, den Felaqua damit verbunden und nun im Ersten Home das Zweite hinzugefügt. (man kann ja auch nicht 2 mal die selbe App auf dem Smartphone haben..)
                  Im Home 2 musste ich natürlich alle Katzen auch hinzufügen (die Selben wie im Home).
                  Wenn ich nun im iobroker den Adapter öffne (die Instanz), werden mir die Katzen nun doppelt angezeigt (Fotos) (von Home und Home 2). - Das leuchtet mir noch ein.
                  Unter den Objekten wird nun auch Home 2 mit dem Hub 2 aufgeführt, inkl. den Katzen.
                  ABER: unter Home werden die Datenpunkte unter pets / Katzenname / inside & since nicht mehr aktualisiert......
                  Ich habe mal den Adapter auf debug gestellt und das Log angehängt: (höllisch viel)
                  Sureflap.txt
                  Wenn der Sureflap Adapter den Felaqua unterstützen würde, könnte ich das zusammenführen der beiden Haushalte weglassen, da ich dann ja 2 Adapter im iobroker installieren könnte (1 x Home mit Klappe; 1 x Home 2 mit Felaqua) und mir das Ganze in der Vis anzeigen lassen.... 😬
                  Gibt es eine Erklärung, wieso die Datenpunkte nicht aktualisiert werden?
                  Ist dies ein bis anhin unbekannter Bug (noch keiner 2 Haushalte Verknüpft)?
                  Gibt es eine Möglichkeit 2 Hubs in einem Haushalt zu betreiben?
                  Kann dies im Adapter behoben werden?
                  andere Lösungsvorschläge?
                  • Als kurzfristige Übergangslösung werde ich jetzt mal das Home 2 im Home 1 löschen und mit einem Tablet arbeiten welches nur das Home 2 bedient (nebst dem Smatphone mit Home 1).
                  • M Matt77CHE
                    Sureflap.txt
                    Sickboy78S Offline
                    Sickboy78S Offline
                    Sickboy78
                    Hallo @matt77che ,
                    ich hab versucht den Adapter so universell wie möglich zu programmieren und auch theoretisch auf mehrere Haushalte vorbereitet. Praktisch konnte ich allerdings nur raten, wie die Datenstrukturen bei mehreren Haushalten aussehen.
                    Das es generell funktioniert, ist schonmal gut. Warum es bei den Pets hapert, müsste ich mir genauer anschauen.
                    Dazu bräuchte ich mal die vom Aufruf https://app.api.surehub.io/api/me/start zurückgelieferte Datenstruktur.
                    Wie man diese mittels des Browsers und der Entwicklerkonsole bekommt, hab ich hier im 2. Kommentar beschrieben: https://github.com/Sickboy78/ioBroker.sureflap/issues/22
                    Wäre super, wenn du mir die komplett als Text zukommen lassen könntest. (Private Daten wie Email etc. kannst du gerne rauslöschen)
                    Sebastian
                      Hallo @matt77che ,
                      Sebastian
                      Matt77CHE
                      @sickboy78
                      Ok, werde ich dir liefern - dauert aber leider mind. 3 Wochen, da ich selber in dieser Zeit keinen Zugang zum Tablet mit dem Home 2 habe (bin abwesend).....
                      • M Matt77CHE
                        @sickboy78
                        Sickboy78S Offline
                        Sickboy78S Offline
                        Sickboy78
                        Version 1.1.4 unterstützt jetzt auch den Felaqua Wasserspender.
                        Ähnlich wie beim Futterautomat wird die verbleibende Menge Wasser in ml angezeigt und beim Tier wie oft und wieviel heute getrunken wurde.
                          Sickboy78S Offline
                          Sickboy78S Offline
                          Sickboy78
                          Noch ein kleines Update hinterher.
                          Version 1.1.5 zeigt jetzt die Seriennummern des Hub und der Geräte an.
                            berryforhome
                            Hallo @Sickboy78
                            vielen Dank für den Adapter, ich habe zwei Mietzen und beide lassen sich damit sozusagen steuern; hier eine kleine Seite, die auf kleines Display passt, was immer auf dem Schreibtisch steht und an ist.
                            Der Zugriff über den Adapter / VIS ist um Welten besser als per App von Sureflap .. da habe ich immer ohne Ende gesucht, wenn ich
                            die Klappe sperren wollte z.B. wenn mal wieder einer der Mietzen mit einer Maus in Richtung Klappe untwerwegs ist.
                            Jetzt gibt es einfach einen schnellen Mausalarm-Schalter !
                            Und IOBroker sendet mir eine Pushover-Nachricht, wenn die Batterie zur Neige geht .. etwas, was ich immer in der App übersehe
                            Z 1 Antwort Letzte Antwort
                            • Z Offline
                              Z Offline
                              zariomahn
                              Hallo @Sickboy78
                              bin begeistert von deiner Arbeit und habe auch schon so manches umgesetzt.
                              Leider bekomme ich seit ein paar Tagen eine Fehlermeldung :-(
                              Die Instant zeigt aber:
                              Was stimmt jetzt :-) , Benutzer und Passwort sind die selben wie in der App...
                              Dann noch eine Frage, auf Github existiert eine Version 1.1.6, im Iobroker aber noch nicht..
                              viele Grüße
                              und Danke für deine Arbeit
                              MZ
                              • B berryforhome
                                Hallo @Sickboy78
                                Z Offline
                                Z Offline
                                zariomahn
                                #66
                                @berryforhome sagte in Test Adapter sureflap v1.0.x GitHub:
                                Hallo @Sickboy78
                                Hallo @berryforhome
                                ich arbeite ebenfalls mit VIS und Blockly, stehe auch vor dem Problem mit den Mäusen :-)
                                Meinst Du könntest mir das Skript zukommen lassen, wäre super nett ;-)
                                liebe Grüße
                                Mario
                                • Z zariomahn
                                  Hallo @Sickboy78
                                  Hallo @berryforhome
                                  liebe Grüße
                                  Mario
                                  Z Offline
                                  Z Offline
                                  zariomahn
                                  #67
                                  @berryforhome
                                  Hi, habe es nun geschafft den Adapter so zu benutzen dass ich die Klappe steuern kann .
                                  Was ich noch nicht herausgefunden habe, wie kann ich einzelne Katzen zum Hausarrest verdonnern :-)
                                  viele Grüße
                                  Mario
                                  • Z zariomahn
                                    Hallo @Sickboy78
                                    viele Grüße
                                    MZ
                                    Sickboy78S Offline
                                    Sickboy78S Offline
                                    Sickboy78
                                    #68
                                    Hallo @zariomahn,
                                    da war noch ein Bug drin, wenn kein Foto für das Tier hinterlegt war.
                                    Die Fehlermeldung war irreführend, Adapter sollte aber trotzdem funktioniert haben.
                                    Ist in Version 1.1.7 korrigiert.
                                    ioBroker bietet dir standardmäßig die aktuelle stable Version (1.1.5) an.
                                    Du kannst aber in den Systemeinstellungen – Repositories auf Beta (latest) wechseln – auf eigene Gefahr. Dann bekommst du immer die neuesten, aber evtl. noch nicht ausgereiften Versionen angeboten. Wenn ich eine neue Version erstelle, lasse ich sie immer erst ein paar Wochen bei mir laufen, bevor ich sie zu stable hinzufüge, um halbwegs sicher zugehen, dass ich nichts verschlimmbessert hab.
                                    Alternativ kannst du im Adapter Menu auch in den Experten-Modus wechseln, dann erscheint ein neuer Button „Installieren aus eigener URL“. Dort kannst du über Auswahl oder Benutzerdefiniert und URL (z.B. https://github.com/Sickboy78/ioBroker.sureflap/) auch direkt einen Adapter aktualisieren.
                                    • Z zariomahn
                                      @berryforhome
                                      viele Grüße
                                      Mario
                                      Sickboy78S Offline
                                      Sickboy78S Offline
                                      Sickboy78
                                      #69
                                      Hallo @zariomahn,
                                      Das geht leider nur mit der Katzenklappe. Die größere Haustierklappe hat das Feature leider nicht.
                                      Wenn deine Klappe es unterstützt, dann findest du bei Objekte unterhalb der Klappe assigned_pets dann dein Tier und dann control und type. Den type kannst du von OUTDOOR PET auf INDOOR PET ändern.
                                      • M-A HuebM Offline
                                        M-A HuebM Offline
                                        M-A Hueb
                                        schrieb am zuletzt editiert von M-A Hueb
                                        #70
                                        Guten Morgen,
                                        seit gestern Mittag 15:51 Uhr funktioniert der Adaptert nicht mehr.
                                        Adapter steht auf Logstufe Debug. Das steht im Log. Logindaten habe ich verifiziert. Das passt, es werden die Katzen aufgelistet.
                                        Wenn man in die Sureflap-App schaut passt alles.
                                        An was kann das liegen?
                                        iobroker unter Win11. NPM 10.9.3 Node.js v22.18.0 js-controller 7.0.7
                                        S Sickboy78S 2 Antworten Letzte Antwort
                                        • M-A HuebM M-A Hueb
                                          Guten Morgen,
                                          Strobelix
                                          schrieb am zuletzt editiert von Strobelix
                                          #71
                                          @m-a-hueb kann ich bestätigen! Liegt aber nicht wirklich am Adapter, denn ich bekomme die Fehlermeldung auch, wenn ich per javascript eine API Abfrage mache unter iobroker.
                                          Allerdings kann ich von einem anderen Gerät mit api call zugreifen. Ich vermute, dass iobroker geblockt wird!?
                                          Ich habe schon einen Fehler gefunden:
                                          Der API Post Header muss einen User-Agent enthalten, das war bisher nicht so
                                          mit 'User-Agent': 'Mozilla/5.0' funktioniert zumindest die Tokenabfrage wieder
                                          Schnelle Lösung:
                                          Diese Datei unter /opt/iobroker/node_modules/iobroker.sureflap austauschen
                                          main.js
                                          oder diesen fork von github installieren
                                          https://github.com/Strobelix80/ioBroker.sureflap
                                          Raspberrymatic, Homematic & Homematic IP Aktoren, ioBroker auf NUC i3, Nuki, Harmony Hub, Digitalstrom, Diverse Sonoff (Tasmota) und Shellies
                                          M-A HuebM 1 Antwort Letzte Antwort
