  4. Adapter Update-Schleife bzw. wird nicht aktualisiert
    6.0k
52 Beiträge 4 Kommentatoren 5.7k Aufrufe 4 Beobachtet
    @blade1987 sagte in Adapter Update-Schleife bzw. wird nicht aktualisiert:
    Bin da gerne für Verbesserungen offen
    Einen Standarduser anlegen?
    BTT:
    iobroker stop
    iobroker fix
    iobroker upgrade
    iobroker upgrade self
    iobroker start
    Blade1987
    @thomas-braun said in Adapter Update-Schleife bzw. wird nicht aktualisiert:
    BTT:
    iobroker stop
    iobroker fix
    iobroker upgrade
    iobroker start
    Hier das gesamte Log der Befehle
    iobroker@iobroker:/opt/iobroker$ iobroker stop
    iobroker@iobroker:/opt/iobroker$ iobroker fix
    library: loaded
    Library version=2022-02-10
        Welcome to the ioBroker installation fixer!
        Script version: 2022-02-13
        You might need to enter your password a couple of times.
        Installing prerequisites (1/3)
    OK:1 http://security.debian.org/debian-security bullseye-security InRelease
    OK:2 http://deb.debian.org/debian bullseye InRelease
    Holen:3 http://deb.debian.org/debian bullseye-updates InRelease [39,4 kB]
    Holen:4 http://ftp.debian.org/debian bullseye-backports InRelease [44,2 kB]
    OK:5 https://deb.nodesource.com/node_14.x bullseye InRelease
    Holen:6 http://ftp.debian.org/debian bullseye-backports/main amd64 Packages.diff/Index [63,3 kB]
    Holen:7 http://ftp.debian.org/debian bullseye-backports/main Translation-en.diff/Index [63,3 kB]
    Holen:8 http://ftp.debian.org/debian bullseye-backports/main amd64 Packages T-2022-03-07-2012.38-F-2022-03-07-2012.38.pdiff [3.878 B]
    Holen:9 http://ftp.debian.org/debian bullseye-backports/main Translation-en T-2022-03-07-2012.38-F-2022-03-07-2012.38.pdiff [3.142 B]
    Es wurden 217 kB in 1 s geholt (207 kB/s).
    Installed gcc-c++
    Installed python-dev
        Checking ioBroker user and directory permissions (2/3)
    [sudo] Passwort für iobroker:
        Checking autostart (3/3)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    iobroker@iobroker:/opt/iobroker$ iobroker upgrade
    This upgrade of "deconz" will introduce the following changes:
    -> 1.3.20:
    add retry if gateway is busy
    change min/max range for offset
    updated translations
    fix link for overview page
    fix parameter can not be set since deConz 2.11.5
    fix xy is invalid: #289 #295
    remove Sentry
    Would you like to upgrade deconz from @1.3.19 to @1.3.20 now? [(y)es, (n)o]: y
    Update deconz from @1.3.19 to @1.3.20
    NPM version: 6.14.16
    Installing iobroker.deconz@1.3.20... (System call)
    > authenticate-pam@1.0.2 install /opt/iobroker/node_modules/authenticate-pam
    > node-gyp rebuild
    make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird betreten
      CXX(target) Release/obj.target/authenticate_pam/authenticate_pam.o
    make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird verlassen
    > iobroker.xbox@0.7.7 install /opt/iobroker/node_modules/iobroker.xbox
    > npip install
    No python_modules directory; installing pip locally if needed.
    Update "system.adapter.deconz.0"
    upload [13] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/deconz.png deconz.png image/png
    upload [12] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [11] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [10] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [9] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [8] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [7] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [6] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [5] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [4] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [3] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [2] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/index_m.html index_m.html text/html
    upload [1] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/instruction.png instruction.png image/png
    upload [0] deconz.admin /opt/iobroker/node_modules/iobroker.deconz/admin/words.js words.js application/javascript
    This upgrade of "alias-manager" will introduce the following changes:
    -> 1.2.6:
    Updated dependencies.
    Fixed saving of common.custom
    -> 1.2.5:
    Added All and None Buttons to select Datapoint while autocreating alias.
    Some GUI-Enhancements and fixes for dark mode.
    Would you like to upgrade alias-manager from @1.2.4 to @1.2.6 now? [(y)es, (n)o]: y
    Update alias-manager from @1.2.4 to @1.2.6
    Installing iobroker.alias-manager@1.2.6... (System call)
    > node-gyp rebuild
    > npip install
    INFO: Directory "/opt/iobroker/node_modules/iobroker.alias-manager/www" was not found! Nothing was uploaded or deleted.
    Update "system.adapter.alias-manager.0"
    upload [21] alias-manager.admin /opt/iobroker/node_modules/iobroker.alias-manager/admin/adapter-settings.js adapter-settings.js application/javascript
    upload [20] alias-manager.admin /opt/iobroker/node_modules/iobroker.alias-manager/admin/admin.d.ts admin.d.ts video/mp2t
    upload [19] alias-manager.admin /opt/iobroker/node_modules/iobroker.alias-manager/admin/alias-manager.png alias-manager.png image/png
    upload [18] alias-manager.admin /opt/iobroker/node_modules/iobroker.alias-manager/admin/alias-manager_big.png alias-manager_big.png image/png
    upload [17] alias-manager.admin /opt/iobroker/node_modules/iobroker.alias-manager/admin/fancytree/react/channel.pdn fancytree/react/channel.pdn null
    upload [16] alias-manager.admin /opt/iobroker/node_modules/iobroker.alias-manager/admin/fancytree/react/channel.png fancytree/react/channel.png image/png
    upload [15] alias-manager.admin /opt/iobroker/node_modules/iobroker.alias-manager/admin/fancytree/react/device.pdn fancytree/react/device.pdn null
    upload [14] alias-manager.admin /opt/iobroker/node_modules/iobroker.alias-manager/admin/fancytree/react/device.png fancytree/react/device.png image/png
    upload [13] alias-manager.admin /opt/iobroker/node_modules/iobroker.alias-manager/admin/fancytree/react/icons.gif fancytree/react/icons.gif image/gif
    upload [12] alias-manager.admin /opt/iobroker/node_modules/iobroker.alias-manager/admin/fancytree/react/icons_original.gif fancytree/react/icons_original.gif image/gif
    upload [11] alias-manager.admin /opt/iobroker/node_modules/iobroker.alias-manager/admin/fancytree/react/loading.gif fancytree/react/loading.gif image/gif
    upload [10] alias-manager.admin /opt/iobroker/node_modules/iobroker.alias-manager/admin/fancytree/react/state.pdn fancytree/react/state.pdn null
    upload [9] alias-manager.admin /opt/iobroker/node_modules/iobroker.alias-manager/admin/fancytree/react/state.png fancytree/react/state.png image/png
    upload [8] alias-manager.admin /opt/iobroker/node_modules/iobroker.alias-manager/admin/fancytree/react/ui.fancytree.jquery.min.css fancytree/react/ui.fancytree.jquery.min.css text/css
    upload [7] alias-manager.admin /opt/iobroker/node_modules/iobroker.alias-manager/admin/fancytree/react/ui.fancytree.min-win7.css fancytree/react/ui.fancytree.min-win7.css text/css
    upload [6] alias-manager.admin /opt/iobroker/node_modules/iobroker.alias-manager/admin/fancytree/react/ui.fancytree.min.css fancytree/react/ui.fancytree.min.css text/css
    upload [5] alias-manager.admin /opt/iobroker/node_modules/iobroker.alias-manager/admin/img/info-big.png img/info-big.png image/png
    upload [4] alias-manager.admin /opt/iobroker/node_modules/iobroker.alias-manager/admin/index_m.html index_m.html text/html
    upload [3] alias-manager.admin /opt/iobroker/node_modules/iobroker.alias-manager/admin/index_m.js index_m.js application/javascript
    upload [2] alias-manager.admin /opt/iobroker/node_modules/iobroker.alias-manager/admin/style.css style.css text/css
    upload [1] alias-manager.admin /opt/iobroker/node_modules/iobroker.alias-manager/admin/type-detector.js type-detector.js application/javascript
    upload [0] alias-manager.admin /opt/iobroker/node_modules/iobroker.alias-manager/admin/words.js words.js application/javascript
    This upgrade of "admin" will introduce the following changes:
    -> 5.3.1:
    Support of IPv6 address by links (vis, material, end so on)
    Corrected errors in the base settings
    Corrected error with the pre-selected language in wizard
    -> 5.3.0:
    Enable http compression in webserver
    Removed deprecated package "request"
    Added JSONL option for base settings
    Added small improvements
    Added the file viewer for binary states
    Would you like to upgrade admin from @5.2.3 to @5.3.1 now? [(y)es, (n)o]: y
    Update admin from @5.2.3 to @5.3.1
    host.iobroker Adapter "system.adapter.admin.0" is stopped.
    Installing iobroker.admin@5.3.1... (System call)
    > node-gyp rebuild
    > npip install
    Update "system.adapter.admin.0"
    upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
    upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
    upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
    upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json jsonConfig.json application/json
    upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
    host.iobroker Adapter "system.adapter.admin.0" is started
    This upgrade of "zigbee" will introduce the following changes:
    -> 1.6.16:
    admin dep fix
    -> 1.6.15:
    Battery status was changed
    Would you like to upgrade zigbee from @1.6.14 to @1.6.16 now? [(y)es, (n)o]: y
    Update zigbee from @1.6.14 to @1.6.16
    Installing iobroker.zigbee@1.6.16... (System call)
    > node-gyp rebuild
    > npip install
    upload [311] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
    upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
    upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/bitron_motion_a.png img/bitron_motion_a.png image/png
    upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hs1ht.png img/hs1ht.png image/png
    upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lifecontrol_air-sensor.png img/lifecontrol_air-sensor.png image/png
    upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_ensis.png img/philips_ensis.png image/png
    upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_argenta_2.png img/philips_hue_argenta_2.png image/png
    upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_fuzo.png img/philips_hue_fuzo.png image/png
    upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_lwo001.png img/philips_hue_lwo001.png image/png
    upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/q-flag_led_panel.png img/q-flag_led_panel.png image/png
    upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sensor_switch_aq2.png img/sensor_switch_aq2.png image/png
    upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/smoke.png img/smoke.png image/png
    upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/tuya_RH3052.png img/tuya_RH3052.png image/png
    upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unavailable.png img/unavailable.png image/png
    upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unknown.png img/unknown.png image/png
    upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/wemo.png img/wemo.png image/png
    upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_plug_eu.png img/xiaomi_plug_eu.png image/png
    upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_wireless_switch.png img/xiaomi_wireless_switch.png image/png
    upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27.png img/zbt_e27.png image/png
    upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27_rgbw.png img/zbt_e27_rgbw.png image/png
    upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_led_panel.png img/zbt_led_panel.png image/png
    upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_remote.png img/zbt_remote.png image/png
    upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_smart_switch.png img/zbt_smart_switch.png image/png
    upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zemismart_sw2.png img/zemismart_sw2.png image/png
    upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index.html index.html text/html
    upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index_m.html index_m.html text/html
    upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/moment.min.js moment.min.js application/javascript
    upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/shuffle.min.js shuffle.min.js application/javascript
    upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/tab_m.html tab_m.html text/html
    upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.css vis-network.min.css text/css
    upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.js vis-network.min.js application/javascript
    upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/words.js words.js application/javascript
    upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.png zigbee.png image/png
    upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.svg zigbee.svg image/svg+xml
    This upgrade of "javascript" will introduce the following changes:
    -> 5.3.3:
    Added async functions: createStateAsync, deleteStateAsync
    -> 5.3.2:
    fix problem that scripts were not starting when scriptsEnabled State was triggered (or startScript was used)
    Make sure callbacks on startScript/stopScript work and Async variants also resolve
    Make sure startScriptAsync, stopScriptAsync and runScriptAsync resolve in debug mode too
    -> 5.3.1:
    Add missing callback check in setObject
    -> 5.3.0:
    Prevent some crash cases reported by Sentry (IOBROKER-JAVASCRIPT-A3)
    Fix Enum Updates
    Optimize making sure data are current for synchronous return of states/objects even for asynchronous action cases before
    Make sure admin files is cleaned up on update
    update channel/device structures for $ selector on object updates
    Adjustments for js-controller 4.0
    Would you like to upgrade javascript from @5.2.21 to @5.3.3 now? [(y)es, (n)o]: y
    Update javascript from @5.2.21 to @5.3.3
    Installing iobroker.javascript@5.3.3... (System call)
    > node-gyp rebuild
    > npip install
    Update "system.adapter.javascript.0"
    Update "system.adapter.javascript.1"
    upload [103] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
    upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE null
    upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.wav google-blockly/media/delete.wav audio/wav
    upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/quote1.png google-blockly/media/quote1.png image/png
    upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/pt.js google-blockly/msg/js/pt.js application/javascript
    upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_time.js google-blockly/own/blocks_time.js application/javascript
    upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/fr.js google-blockly/own/msg/fr.js application/javascript
    upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/plugins/bundle.js plugins/bundle.js application/javascript
    upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/runtime-main.367f9424.js static/js/runtime-main.367f9424.js application/javascript
    upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/configure.js vs/configure.js application/javascript
    upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.css vs/editor/editor.main.css text/css
    upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.js vs/editor/editor.main.js application/javascript
    upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.de.js vs/editor/editor.main.nls.de.js application/javascript
    upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.es.js vs/editor/editor.main.nls.es.js application/javascript
    upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.fr.js vs/editor/editor.main.nls.fr.js application/javascript
    upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.it.js vs/editor/editor.main.nls.it.js application/javascript
    upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
    upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
    upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
    upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
    upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
    upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
    upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
    upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
    upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
    upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
    upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
    upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
    upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
    upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
    This upgrade of "info" will introduce the following changes:
    -> 1.9.19:
    Fix audio, USB, bluetooth and printer view
    Would you like to upgrade info from @1.9.18 to @1.9.19 now? [(y)es, (n)o]: y
    Update info from @1.9.18 to @1.9.19
    Installing iobroker.info@1.9.19... (System call)
    > node-gyp rebuild
    > npip install
    upload [90] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [80] info.admin /opt/iobroker/node_modules/iobroker.info/admin/index_m.html index_m.html text/html
    upload [70] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/hourhand.png lib/img/clock/hourhand.png image/png
    upload [60] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/memory.png lib/img/icons/memory.png image/png
    upload [50] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/coreos.png lib/img/logos/coreos.png image/png
    upload [40] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/manjaro.png lib/img/logos/manjaro.png image/png
    upload [30] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/slackware.png lib/img/logos/slackware.png image/png
    upload [20] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/bootstrap.min.js lib/js/bootstrap.min.js application/javascript
    upload [19] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/chartist.min.js lib/js/chartist.min.js application/javascript
    upload [18] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/clock.js lib/js/clock.js application/javascript
    upload [17] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/commons.js lib/js/commons.js application/javascript
    upload [16] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/documentation.js lib/js/documentation.js application/javascript
    upload [15] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/feednami.min.js lib/js/feednami.min.js application/javascript
    upload [14] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/format-google-calender.js lib/js/format-google-calender.js application/javascript
    upload [13] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/forum.js lib/js/forum.js application/javascript
    upload [12] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/githubData.js lib/js/githubData.js application/javascript
    upload [11] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/helper.js lib/js/helper.js application/javascript
    upload [10] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/hostInfo.js lib/js/hostInfo.js application/javascript
    upload [9] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/info.js lib/js/info.js application/javascript
    upload [8] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/news.js lib/js/news.js application/javascript
    upload [7] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/popupnews.js lib/js/popupnews.js application/javascript
    upload [6] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/searchGithub.js lib/js/searchGithub.js application/javascript
    upload [5] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
    upload [4] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/simplemde.min.js lib/js/simplemde.min.js application/javascript
    upload [3] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/systemInformation.js lib/js/systemInformation.js application/javascript
    upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/updateAdapter.js lib/js/updateAdapter.js application/javascript
    upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/tab_m.html tab_m.html text/html
    upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/words.js words.js application/javascript
    This upgrade of "influxdb" will introduce the following changes:
    -> 2.6.2:
    Correctly handle db names with hyphens for InfluxDB 1
    Fix getHistory for non boolean fields
    Adjust shard group duration to influxdb proposals
    -> 2.6.1:
    Address issue with updating retention policy for influxDB 1
    Would you like to upgrade influxdb from @2.6.0 to @2.6.2 now? [(y)es, (n)o]: y
    Update influxdb from @2.6.0 to @2.6.2
    Installing iobroker.influxdb@2.6.2... (System call)
    > node-gyp rebuild
    > npip install
    upload [15] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/custom_m.html custom_m.html text/html
    upload [14] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [13] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [12] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [11] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [10] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [9] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [8] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [7] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [6] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [5] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [4] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/index_m.html index_m.html text/html
    upload [3] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/influxdb.png influxdb.png image/png
    upload [2] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/jsonConfig.json jsonConfig.json application/json
    upload [1] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/jsonCustom.json jsonCustom.json application/json
    upload [0] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/words.js words.js application/javascript
    iobroker@iobroker:/opt/iobroker$ iobroker upgrade self
    Update js-controller from @4.0.15 to @4.0.19
    Stopped Objects DB
    Stopped States DB
    Installing iobroker.js-controller@4.0.19... (System call)
    > iobroker.js-controller@4.0.19 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    > node-gyp rebuild
    > iobroker.js-controller@4.0.19 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    Successfully migrated 93264 objects to Redis Sets
    object _design/system updated
      "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----\r\nMIIEowIBAAKCAQEAvPNynbhQLelR6zakRoT+GvZy4dgHNJUfJPAYRZKW0cfwMDWI\r\nWQ3+FkGNLS6gDgEx6s8WgEedap40mVbCPaoP17l+LJBWIeR0WIMeYUjUyIprr/WF\r\nrzuNcw/D9X6t5neaRBBeuemE14VWorvOu126oFYVrWCscBMexKuBgZMARHvzhy1f\r\nJMapjM58qEQAv9a48j0kVMF3DJv0LA6npeGnx7D2Y42/0HRoBUqKcxE+UzxmfidH\r\n/uSDvPDzTqylqTngUBnm9Rs5FJX+m9qtQKHe2MuAUp9UQvKXGsN2YkaFKTeoLmUK\r\nq2n1ykxxEYU0pKoMboKPKZLDvvP8nUR+pmYdgwIDAQABAoIBACS2sOiQbZPeJ/qq\r\nDVVedflLNZtIXG4NI5YLyMuL5h4w2Syk2i9jlqFAb2v+CT9vYAGd52NZhu62esXo\r\no6lTp+xksG18RiAjwa+JGpgQjLfCnZX9ANLBoYRf5dWHncaQKrta6uz4wMUXtXO9\r\nRjgFyENrNp8Pj7HfJTVVlb5Vj9G+Zb+QKFoX3mqxCx7qo0FwBqI5sCDixBjv7VgI\r\n0bH5t7hFMK/8P8b+9QGENICROligk8oKcuRWGvHDD/PpKQWXCKYAcxUrdZ5n9Fcu\r\nImxgsLL/swjSsOtqVVeQnivtW5FawxrNDGJKTI5sqBkyydAS15l0EBkWgRIzBFO5\r\noWuov+ECgYEA+LSbm7hF56CoEwpaiK/Z0mrr/o6bNlYc3PIhbaY6JvUvM27Ji4Pk\r\nNmLWKvSJVR69f/XPoYlYYCVyFShvJvhoh3rs76Y5ryXHoYgyejyfFzaBo4hRCJDn\r\n5Q8pwYx0UOLoszQo4PVDV6BT7+6uNNKgc7p42iSxvYm0rYBWC+Y6mWkCgYEAwn4t\r\nFgEvaGjiTh2nzpZLdtPdgRLEP26lPegPsI3W1VacHkiUcVlVnJ3jBe/heXjKFG/Z\r\n8YKs14/6B01W7WgU4/gslRbcfz2KZfCWMcJKKpckoTuTS+9AmSi2GRnxF/RRrosE\r\nu8H/jzuEVcFcBmWqZGM6XfJzsoW9lvLV0X5OlgsCgYBhGJHPv6d7AJvdoyMpTg4q\r\nOhgcb6xlEEWAdP9cAZOedgaRe+UvlLRaD0gxyPp8wt2UwXDoTei00KmzXO/YNQ8K\r\nJZGvFiRbHtLLW5LpahVqSJtgLu4D/B6srLjOmXknww66N9jlypsZ8LwUZgiZEsoV\r\npG1eLQk/SC3DtuDhEGc8UQKBgDwQ27vAAfQs8DdP0VNr90JrjC0grpsogL/tu2q7\r\nY23fobd4kt+ux1HnMQXUX740H7TQFm8P/HFWddFrgT0wt8LwElS5CsABMYzqEHit\r\nmFou85EX5RW+fiTO/e4ipOLRAaj2JjAWaebCasxROyp+m3EFdDEvf6vSwgqsVHyu\r\nlXahAoGBAMMLVbrgYmCHa3EWc4u90x59CNUiFFRbZsM9jlVVjTUm7xGVctUmbpvW\r\nmHMOZ4oaw1JUYn9g4vpzjTWAbq43MGndlxIdUsSx6PC3XgWiJuNjTMGurMjZp204\r\nOJ5yj/RcmO5k+4r1/mCWuHwF47FA5gU83Ua3j5uo5juQf84IAq/r\r\n-----END RSA PRIVATE KEY-----\r\n",
      "defaultPublic": "-----BEGIN CERTIFICATE-----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\r\n065Uka7f9fOBWPpWoMtB/m4zrnD2FUVQlJqIFRgmser5gQ==\r\n-----END CERTIFICATE-----\r\n"
    Update certificate defaultPrivate
    The object "system.certificates" was updated successfully.
    Update certificate defaultPublic
    > npip install
    iobroker@iobroker:/opt/iobroker$ iob start
    Adapterübersicht nach Start
      Vielleicht liegt es daran das ich beim installieren von Debian den IoBroker demensprechend als Hautnutzer mit angelegt habe
      Siehe die Anmerkung von @crunchip , dass iobroker als Standard user name nicht die beste Wahl ist.
      Maßgeblich ist zwar die uid/gid für die Besitzverhältnisse der Dateien, übersichtlicher macht es die ganze Angelegenheit jedenfalls nicht. Sollte man gerade vermeiden, wenn man nicht absolut sattelfest ist.
      Blade1987
      Ist das aber in dem Fall überhaupt lösbar ohne neu aufzusetzen ?
      Fürs nächste mal weiß ich es definitiv irgend etwas anderes zu nehmen als root, admin oder iobroker :)
      Linux ist leider nach wie vor noch eine Herausforderung für mich, aber wie sagt man so schön man wächst mit seinen Aufgaben.
      • B Blade1987
        admin
        Könntest du sogar nehmen, der ist nicht vorbelastet. Ich würde den trotzdem nicht nehmen.
        Kann man natürlich. Einfach einen user anlegen und den bestehenden 'iobroker' / uid=1000 korrigieren. Ist aber was für einen eigenen Thread.
        Irgendwo klemmt da noch der xbox-Kram drin.
        Installier den nochmal:
        iobroker add xbox auto --host iobroker
        Am Rande: iobroker ist auch kein guter Hostname. Führt auch zu Verwirrung, wenn da alles 'iobroker' heißt.
        iobroker@iobroker iobroker TUT_DIES
        ist total unübersichtlich, imho.
          admin
          Blade1987
          schrieb am zuletzt editiert von Blade1987
          admin
          Werde ich mir auf die ToDo setzen, Hostnamen kann man ja auch ändern, aufgrund der Übersicht gebe ich dir da vollkommen recht, das iobroker kommt recht häufig vor. Parallel mache ich mich trotzdem mal mit dem Gedanken vertraut evtl. eine neue VM aufzusetzen mit Standarduser und anderem Hostnamen.
          Beim XBox Adapter kommt wieder das Python Thema zum tragen warum auch immer.....
          iobroker@iobroker:/opt/iobroker$ iobroker add xbox auto --host iobroker
          Installing iobroker.xbox@0.7.8... (System call)
          > iobroker.js-controller@4.0.15 preinstall /opt/iobroker/node_modules/iobroker.js-controller
          > node-gyp rebuild
          > iobroker.js-controller@4.0.15 install /opt/iobroker/node_modules/iobroker.js-controller
          Successfully migrated 93120 objects to Redis Sets
            "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----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\r\nP1QwYF3+A6saFXB4Uoxvw6aGAx/1uLS8fXDaVBJH6muswZVZWHflaw==\r\n-----END RSA PRIVATE KEY-----\r\n",
            "defaultPublic": "-----BEGIN CERTIFICATE-----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\r\naGQ2A7pA0vCXHsxMbNJGAKLeX4XmMtjL+buE4o1EOwxRpQ==\r\n-----END CERTIFICATE-----\r\n"
          > iobroker.xbox@0.7.8 install /opt/iobroker/node_modules/iobroker.xbox
          > npip install
          host.iobroker Cannot install iobroker.xbox@0.7.8: 1
          Wenn ich es oben richtig lese hat er das upgrade self auch wieder ignoriert und ist auf 4.0.15 geblieben
          • B Blade1987
            admin
            > node-gyp rebuild
            > npip install
            @blade1987
            apt policy python3 build-essential libssl-dev libffi-dev python3-dev
              @blade1987
              Blade1987
              iobroker@iobroker:/opt/iobroker$ apt policy python3 build-essential libssl-dev libffi-dev python3-dev
              python3:
                Installiert:           3.9.2-3
                Installationskandidat: 3.9.2-3
                Versionstabelle:
               *** 3.9.2-3 500
                      500 http://deb.debian.org/debian bullseye/main amd64 Packages
              build-essential:
                Installiert:           12.9
                Installationskandidat: 12.9
                Versionstabelle:
               *** 12.9 500
              libssl-dev:
                Installiert:           (keine)
                Installationskandidat: 1.1.1k-1+deb11u1
                Versionstabelle:
                   1.1.1k-1+deb11u1 500
                      500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
              libffi-dev:
                Installiert:           3.3-6
                Installationskandidat: 3.3-6
                Versionstabelle:
               *** 3.3-6 500
              python3-dev:
                Versionstabelle:
               *** 3.9.2-3 500
              • B Blade1987
                python3:
                  Versionstabelle:
                 *** 3.9.2-3 500
                build-essential:
                  Installiert:           12.9
                  Versionstabelle:
                 *** 12.9 500
                libssl-dev:
                  Versionstabelle:
                libffi-dev:
                  Installiert:           3.3-6
                  Versionstabelle:
                 *** 3.3-6 500
                python3-dev:
                  Versionstabelle:
                 *** 3.9.2-3 500
                @blade1987
                Siehe Edit oben.
                  @blade1987
                  Siehe Edit oben.
                  Blade1987
                  @thomas-braun hab es auch nochmal editiert :)
                  • B Blade1987
                    @blade1987
                    sudo apt update
                    sudo apt install libssl-dev
                    cd /opt/iobroker
                    npm i iobroker.xbox --unsafe-perm
                      @blade1987
                      sudo apt update
                      cd /opt/iobroker
                      Blade1987
                      iobroker@iobroker:/opt/iobroker$ sudo apt update
                      OK:3 http://deb.debian.org/debian bullseye-updates InRelease
                      OK:4 http://ftp.debian.org/debian bullseye-backports InRelease
                      Alle Pakete sind aktuell.
                      iobroker@iobroker:/opt/iobroker$ sudo apt install libssl-dev
                      Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                        ant-contrib bsdmainutils cpp-8 cracklib-runtime enchant fonts-dejavu fonts-lato fonts-linuxlibertine fonts-sil-gentium fonts-sil-gentium-basic
                        geoip-database gir1.2-gst-plugins-base-1.0 gstreamer1.0-alsa gstreamer1.0-pulseaudio hp-ppd icoutils kate-data kde-runtime-data
                        kde-style-qtcurve-qt5 kdelibs5-data libasan5 libbasicusageenvironment1 libbctoolbox1 libbind9-161 libboost-atomic1.67.0 libboost-chrono1.67.0
                        libboost-date-time1.67.0 libboost-filesystem1.67.0 libboost-iostreams1.67.0 libboost-locale1.67.0 libboost-system1.67.0 libboost-thread1.67.0
                        libbrlapi0.6 libbsh-java libbzrtp0 libcdio18 libcfitsio7 libcodec2-0.8.1 libcrack2 libcroco3 libcrystalhd3 libdc1394-22 libdlrestrictions1
                        libdns1104 libdns1110 libdouble-conversion1 libdvdread4 libebml4v5 libenchant1c2a libevent-2.1-6 libexiv2-14 libfluidsynth1 libgadu3 libgeoip1
                        libgit2-27 libglew2.1 libgpgme++2v5 libgps23 libgrantlee-textdocument5 libgroupsock8 libgssdp-1.0-3 libgupnp-1.0-4 libhavege1 libhttp-parser2.8
                        libicu63 libigdgmm5 libilmbase23 libisc1100 libisc1105 libisccc161 libisccfg163 libisl19 libjim0.77 libkaccounts1 libkdecorations2private6
                        libkf5emoticons-bin libkf5emoticons-data libkf5emoticons5 libkf5jsembed-data libkf5jsembed5 libkf5libkdepimakonadi5 libkf5xmlrpcclient-data
                        libkf5xmlrpcclient5 libkwineffects11 libkwinglutils11 libkwinxrenderutils11 liblivemedia64 libllvm7 liblouis17 liblouisutdml8 liblwres161
                        libmatroska6v5 libmeanwhile1 libmpdec2 libmpx2 libmypaint-1.3-0 libmysofa0 libnfs12 libntrack0 libokular5core8 libopenexr23 liborcus-0.14-0
                        libotr5 libperl5.28 libplacebo7 libplymouth4 libpoppler82 libprotobuf-lite17 libpwquality-common libpwquality1 libpython3.7 libpython3.7-dev
                        libpython3.7-minimal libpython3.7-stdlib libqpdf21 libqtcurve-utils2 libraw19 libre2-5 libreadline5 libreadline7 libreoffice
                        libreoffice-avmedia-backend-gstreamer libreoffice-kde5 libreoffice-librelogo libreoffice-nlpsolver libreoffice-script-provider-bsh
                        libreoffice-script-provider-js libreoffice-script-provider-python libreoffice-wiki-publisher libruby2.5 libruby2.7 libsane libsisu-guice-java
                        libsisu-ioc-java libsnmp30 libtidy5deb1 libtss2-udev libturbojpeg0 libu2f-udev libusageenvironment3 libusbmuxd4 libutempter0 libvpx5 libx264-155
                        libx265-165 libxcb-util0 linux-image-4.19.0-16-amd64 linux-image-4.19.0-17-amd64 linux-image-5.10.0-8-amd64 ntrack-module-libnl-0
                        oxygen-icon-theme phonon-backend-gstreamer-common polkit-kde-1 printer-driver-hpijs python3-gst-1.0 python3-sip python3.7-minimal
                        qml-module-qtquick-controls-styles-breeze qtcore4-l10n rake ruby ruby-did-you-mean ruby-minitest ruby-net-telnet ruby-power-assert ruby-rubygems
                        ruby-test-unit ruby-xmlrpc ruby2.7 rubygems-integration
                      Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                      Vorgeschlagene Pakete:
                        libssl-doc
                      Die folgenden NEUEN Pakete werden installiert:
                        libssl-dev
                      0 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                      Es müssen 1.810 kB an Archiven heruntergeladen werden.
                      Nach dieser Operation werden 8.161 kB Plattenplatz zusätzlich benutzt.
                      Holen:1 http://deb.debian.org/debian bullseye/main amd64 libssl-dev amd64 1.1.1k-1+deb11u1 [1.810 kB]
                      Es wurden 1.810 kB in 0 s geholt (18,0 MB/s).
                      Vormals nicht ausgewähltes Paket libssl-dev:amd64 wird gewählt.
                      (Lese Datenbank ... 221719 Dateien und Verzeichnisse sind derzeit installiert.)
                      Vorbereitung zum Entpacken von .../libssl-dev_1.1.1k-1+deb11u1_amd64.deb ...
                      Entpacken von libssl-dev:amd64 (1.1.1k-1+deb11u1) ...
                      libssl-dev:amd64 (1.1.1k-1+deb11u1) wird eingerichtet ...
                      iobroker@iobroker:/opt/iobroker$ cd /opt/iobroker
                      iobroker@iobroker:/opt/iobroker$ npm i iobroker.xbox --unsafe-perm
                      > node-gyp rebuild
                      ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:
                      ../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                        107 |   Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args);
                      In file included from ../authenticate_pam.cc:23:
                      ../../nan/nan.h:1026:46: note: declared here
                       1026 |   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
                      ../authenticate_pam.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Authenticate(Nan::NAN_METHOD_ARGS_TYPE)’:
                      ../authenticate_pam.cc:147:83: error: no matching function for call to ‘v8::Array::Get(v8::Local<v8::String>)’
                        147 |   Local<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecked());
                      In file included from /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:67,
                                       from ../../nan/nan.h:56,
                      /home/iobroker/.cache/node-gyp/14.19.0/include/node/v8.h:3717:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, v8::Local<v8::Value>)’
                       3717 |   V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context,
                      /home/iobroker/.cache/node-gyp/14.19.0/include/node/v8.h:3717:43: note:   candidate expects 2 arguments, 1 provided
                      /home/iobroker/.cache/node-gyp/14.19.0/include/node/v8.h:3720:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, uint32_t)’
                       3720 |   V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context,
                      /home/iobroker/.cache/node-gyp/14.19.0/include/node/v8.h:3720:43: note:   candidate expects 2 arguments, 1 provided
                      ../authenticate_pam.cc:150:30: error: cannot convert ‘char [128]’ to ‘v8::Isolate*’
                        150 |    serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1);
                            |                              char [128]
                      /home/iobroker/.cache/node-gyp/14.19.0/include/node/v8.h:3037:26: note:   initializing argument 1 of ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’
                       3037 |   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,
                      ../authenticate_pam.cc:152:69: error: no matching function for call to ‘v8::Array::Get(v8::Local<v8::String>)’
                        152 |   res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked());
                      ../authenticate_pam.cc:155:29: error: cannot convert ‘char [128]’ to ‘v8::Isolate*’
                        155 |    remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1);
                            |                             char [128]
                      ../authenticate_pam.cc:160:25: error: cannot convert ‘char [128]’ to ‘v8::Isolate*’
                        160 |  username->WriteUtf8(m->username, sizeof(m->username) - 1);
                            |                         char [128]
                      ../authenticate_pam.cc:161:25: error: cannot convert ‘char [128]’ to ‘v8::Isolate*’
                        161 |  password->WriteUtf8(m->password, sizeof(m->password) - 1);
                            |                         char [128]
                      ../authenticate_pam.cc: At global scope:
                      ../authenticate_pam.cc:170:6: error: variable or field ‘init’ declared void
                        170 | void init(Handle<Object> exports) {
                      ../authenticate_pam.cc:170:11: error: ‘Handle’ was not declared in this scope
                      ../authenticate_pam.cc:170:24: error: expected primary-expression before ‘>’ token
                      ../authenticate_pam.cc:170:26: error: ‘exports’ was not declared in this scope
                      In file included from ../../nan/nan.h:56,
                      ../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope; did you mean ‘int’?
                        175 | NODE_MODULE(authenticate_pam, init);
                      /home/iobroker/.cache/node-gyp/14.19.0/include/node/node.h:793:36: note: in definition of macro ‘NODE_MODULE_X’
                        793 |       (node::addon_register_func) (regfunc),                          \
                      ../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’
                      make: *** [authenticate_pam.target.mk:111: Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
                      gyp ERR! build error
                      gyp ERR! stack Error: `make` failed with exit code: 2
                      gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
                      gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
                      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)
                      gyp ERR! System Linux 5.10.0-11-amd64
                      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                      gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
                      gyp ERR! node -v v14.19.0
                      gyp ERR! node-gyp -v v5.1.0
                      gyp ERR! not ok
                      > npip install
                      Traceback (most recent call last):
                        File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 20061, in <module>
                          main()
                        File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 194, in main
                          bootstrap(tmpdir=tmpdir)
                        File "/opt/iobroker/node_modules/nopy/src/get-pip.py", line 82, in bootstrap
                          import pip
                        File "/tmp/tmp2bd262ko/pip.zip/pip/__init__.py", line 26, in <module>
                        File "/tmp/tmp2bd262ko/pip.zip/pip/utils/__init__.py", line 23, in <module>
                        File "/tmp/tmp2bd262ko/pip.zip/pip/locations.py", line 9, in <module>
                      ImportError: cannot import name 'sysconfig' from 'distutils' (/usr/lib/python3.7/distutils/__init__.py)
                      Error: Exited with code 1.
                          at ChildProcess.<anonymous> (/opt/iobroker/node_modules/nopy/src/api.js:277:20)
                          at maybeClose (internal/child_process.js:1058:16)
                          at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)
                      npm WARN @material-ui/pickers@3.3.10 requires a peer of @material-ui/core@^4.0.0 but none is installed. You must install peer dependencies yourself.
                      npm WARN @material-ui/pickers@3.3.10 requires a peer of react@^16.8.0 || ^17.0.0 but none is installed. You must install peer dependencies yourself.
                      npm WARN @material-ui/pickers@3.3.10 requires a peer of react-dom@^16.8.0 || ^17.0.0 but none is installed. You must install peer dependencies yourself.
                      npm WARN react-transition-group@4.4.2 requires a peer of react@>=16.6.0 but none is installed. You must install peer dependencies yourself.
                      npm WARN react-transition-group@4.4.2 requires a peer of react-dom@>=16.6.0 but none is installed. You must install peer dependencies yourself.
                      npm WARN rifm@0.7.0 requires a peer of react@>=16.8 but none is installed. You must install peer dependencies yourself.
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                      npm ERR! code ELIFECYCLE
                      npm ERR! errno 1
                      npm ERR! iobroker.xbox@0.7.8 install: `npip install`
                      npm ERR! Exit status 1
                      npm ERR!
                      npm ERR! Failed at the iobroker.xbox@0.7.8 install script.
                      npm ERR!     /home/iobroker/.npm/_logs/2022-03-07T22_03_58_598Z-debug.log
                      • B Blade1987
                          libssl-doc
                          libssl-dev
                        > node-gyp rebuild
                              |                              char [128]
                              |                             char [128]
                              |                         char [128]
                              |                         char [128]
                        gyp ERR! not ok
                        > npip install
                            main()
                            import pip
                        npm ERR! errno 1
                        npm ERR!
                        Ach du je....
                        sudo apt autoremove
                        sudo reboot
                        Und ein Server wird ohne Desktop betrieben!
                        cd /opt/iobroker
                        npm ls authenticate-pam
                          Ach du je....
                          sudo apt autoremove
                          sudo reboot
                          cd /opt/iobroker
                          Blade1987
                          ich weiß :( wie oben beschrieben aus Fehlern lernt man
                          iobroker@iobroker:/opt/iobroker$ sudo apt autoremove
                          Die folgenden Pakete werden ENTFERNT:
                          0 aktualisiert, 0 neu installiert, 170 zu entfernen und 0 nicht aktualisiert.
                          Nach dieser Operation werden 1.359 MB Plattenplatz freigegeben.
                          Möchten Sie fortfahren? [J/n] y
                          (Lese Datenbank ... 221836 Dateien und Verzeichnisse sind derzeit installiert.)
                          Entfernen von ant-contrib (1.0~b3+svn177-12) ...
                          Entfernen von bsdmainutils (12.1.7+nmu3) ...
                          Entfernen von cpp-8 (8.3.0-6) ...
                          Entfernen von cracklib-runtime (2.9.6-3.4) ...
                          Entfernen von enchant (1.6.0-11.1+b1) ...
                          Entfernen von fonts-dejavu (2.37-2) ...
                          Entfernen von fonts-lato (2.0-2.1) ...
                          dpkg: Warnung: Während Entfernens von fonts-lato ist Verzeichnis »/usr/share/fonts/truetype/lato« nicht leer, wird daher nicht gelöscht
                          Entfernen von fonts-linuxlibertine (5.3.0-6) ...
                          Entfernen von fonts-sil-gentium (20081126:1.03-4) ...
                          dpkg: Warnung: Während Entfernens von fonts-sil-gentium ist Verzeichnis »/usr/share/fonts/truetype/gentium« nicht leer, wird daher nicht gelöscht
                          Entfernen von fonts-sil-gentium-basic (1.102-1.1) ...
                          dpkg: Warnung: Während Entfernens von fonts-sil-gentium-basic ist Verzeichnis »/usr/share/fonts/truetype/gentium-basic« nicht leer, wird daher nicht gelöscht
                          Entfernen von geoip-database (20191224-3) ...
                          Entfernen von python3-gst-1.0 (1.18.3-1) ...
                          Entfernen von gir1.2-gst-plugins-base-1.0:amd64 (1.18.4-2) ...
                          Entfernen von gstreamer1.0-alsa:amd64 (1.18.4-2) ...
                          Entfernen von gstreamer1.0-pulseaudio:amd64 (1.18.4-2) ...
                          Entfernen von hp-ppd (0.9+nmu1) ...
                          Entfernen von icoutils (0.32.3-3) ...
                          Entfernen von kate-data (4:4.14.3-5) ...
                          Entfernen von kde-runtime-data (4:17.08.3-2.1) ...
                          Entfernen von kde-style-qtcurve-qt5:amd64 (1.9-7+b2) ...
                          Entfernen von kdelibs5-data (4:4.14.38-3) ...
                          Entfernen von libasan5:amd64 (9.3.0-22) ...
                          Entfernen von liblivemedia64:amd64 (2018.11.26-1.1) ...
                          Entfernen von libgroupsock8:amd64 (2018.11.26-1.1) ...
                          Entfernen von libbasicusageenvironment1:amd64 (2018.11.26-1.1) ...
                          Entfernen von libbzrtp0:amd64 (4.4.13-2) ...
                          Entfernen von libbctoolbox1:amd64 (4.4.13-2) ...
                          Entfernen von libbind9-161:amd64 (1:9.11.19+dfsg-2.1) ...
                          Entfernen von libboost-locale1.67.0:amd64 (1.67.0-13+deb10u1) ...
                          Entfernen von libboost-thread1.67.0:amd64 (1.67.0-13+deb10u1) ...
                          Entfernen von libboost-atomic1.67.0:amd64 (1.67.0-13+deb10u1) ...
                          Entfernen von libboost-chrono1.67.0:amd64 (1.67.0-13+deb10u1) ...
                          Entfernen von libboost-date-time1.67.0:amd64 (1.67.0-13+deb10u1) ...
                          Entfernen von liborcus-0.14-0:amd64 (0.14.1-6) ...
                          Entfernen von libboost-filesystem1.67.0:amd64 (1.67.0-13+deb10u1) ...
                          Entfernen von libboost-iostreams1.67.0:amd64 (1.67.0-13+deb10u1) ...
                          Entfernen von libboost-system1.67.0:amd64 (1.67.0-13+deb10u1) ...
                          Entfernen von libbrlapi0.6:amd64 (5.6-10+deb10u1) ...
                          Entfernen von libreoffice-script-provider-bsh (1:7.0.4-4+deb11u1) ...
                          Entfernen von libbsh-java (2.0b4-20) ...
                          Entfernen von libcdio18:amd64 (2.0.0-2) ...
                          Entfernen von libcfitsio7:amd64 (3.450-3) ...
                          Entfernen von libcodec2-0.8.1:amd64 (0.8.1-2) ...
                          Entfernen von libpwquality1:amd64 (1.4.4-1) ...
                          Entfernen von libcrack2:amd64 (2.9.6-3.4) ...
                          Entfernen von libcroco3:amd64 (0.6.12-3) ...
                          Entfernen von libcrystalhd3:amd64 (1:0.0~git20110715.fdd2f19-13) ...
                          Entfernen von libdc1394-22:amd64 (2.2.5-1) ...
                          Entfernen von libdlrestrictions1 (0.15.32) ...
                          Entfernen von libdns1104:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u5) ...
                          Entfernen von libisccfg163:amd64 (1:9.11.19+dfsg-2.1) ...
                          Entfernen von libdns1110:amd64 (1:9.11.19+dfsg-2.1) ...
                          Entfernen von libdouble-conversion1:amd64 (3.1.0-3) ...
                          Entfernen von libdvdread4:amd64 (6.0.1-1) ...
                          Entfernen von libmatroska6v5:amd64 (1.4.9-1+deb10u1) ...
                          Entfernen von libebml4v5:amd64 (1.3.6-2) ...
                          Entfernen von libenchant1c2a:amd64 (1.6.0-11.1+b1) ...
                          Entfernen von libevent-2.1-6:amd64 (2.1.8-stable-4) ...
                          Entfernen von libexiv2-14:amd64 (0.25-4+deb10u2) ...
                          Entfernen von libfluidsynth1:amd64 (1.1.11-1+deb10u1) ...
                          Entfernen von libgadu3 (1:1.12.2-5) ...
                          Entfernen von libisc1100:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u5) ...
                          Entfernen von libgeoip1:amd64 (1.6.12-7) ...
                          Entfernen von libgit2-27:amd64 (0.27.7+dfsg.1-0.2) ...
                          Entfernen von libglew2.1:amd64 (2.1.0-4+b1) ...
                          Entfernen von libgpgme++2v5 (4:4.14.10-11) ...
                          Entfernen von libgps23:amd64 (3.17-7) ...
                          Entfernen von libgrantlee-textdocument5:amd64 (5.2.0-3) ...
                          Entfernen von libgupnp-1.0-4:amd64 (1.0.5-0+deb10u1) ...
                          Entfernen von libgssdp-1.0-3:amd64 (1.0.5-0+deb10u1) ...
                          Entfernen von libhavege1:amd64 (1.9.1-7) ...
                          Entfernen von libhttp-parser2.8:amd64 (2.8.1-1) ...
                          Entfernen von libicu63:amd64 (63.1-6+deb10u1) ...
                          Entfernen von libigdgmm5:amd64 (18.4.1+ds1-1) ...
                          Entfernen von libopenexr23:amd64 (2.2.1-4.1+deb10u1) ...
                          Entfernen von libilmbase23:amd64 (2.2.1-2) ...
                          Entfernen von libisccc161:amd64 (1:9.11.19+dfsg-2.1) ...
                          Entfernen von libisc1105:amd64 (1:9.11.19+dfsg-2.1) ...
                          Entfernen von libisl19:amd64 (0.20-2) ...
                          Entfernen von libjim0.77:amd64 (0.77+dfsg0-3) ...
                          Entfernen von libkaccounts1:amd64 (4:17.08.3-1) ...
                          Entfernen von libkdecorations2private6 (4:5.14.5-1) ...
                          Entfernen von libkf5emoticons-bin (5.78.0-2) ...
                          Entfernen von libkf5emoticons5:amd64 (5.78.0-2) ...
                          Entfernen von libkf5emoticons-data (5.78.0-2) ...
                          Entfernen von libkf5jsembed5:amd64 (5.78.0-2) ...
                          Entfernen von libkf5jsembed-data (5.78.0-2) ...
                          Entfernen von libkf5libkdepimakonadi5:amd64 (4:18.08.3-2) ...
                          Entfernen von libkf5xmlrpcclient5:amd64 (5.78.0-2) ...
                          Entfernen von libkf5xmlrpcclient-data (5.78.0-2) ...
                          Entfernen von libkwineffects11 (4:5.14.5-1) ...
                          Entfernen von libkwinglutils11 (4:5.14.5-1) ...
                          Entfernen von libkwinxrenderutils11 (4:5.14.5-1) ...
                          Entfernen von libllvm7:amd64 (1:7.0.1-8+deb10u2) ...
                          Entfernen von liblouisutdml8:amd64 (2.7.0-5+b1) ...
                          Entfernen von liblouis17:amd64 (3.8.0-2) ...
                          Entfernen von liblwres161:amd64 (1:9.11.19+dfsg-2.1) ...
                          Entfernen von libmeanwhile1:amd64 (1.1.1-2) ...
                          Entfernen von libpython3.7-dev:amd64 (3.7.3-2+deb10u3) ...
                          Entfernen von libpython3.7:amd64 (3.7.3-2+deb10u3) ...
                          Entfernen von libpython3.7-stdlib:amd64 (3.7.3-2+deb10u3) ...
                          Entfernen von libmpdec2:amd64 (2.4.2-2) ...
                          Entfernen von libmpx2:amd64 (8.3.0-6) ...
                          Entfernen von libmypaint-1.3-0:amd64 (1.3.0-2.1) ...
                          Entfernen von libmysofa0:amd64 (0.6~dfsg0-3+deb10u1) ...
                          Entfernen von libnfs12:amd64 (3.0.0-2) ...
                          Entfernen von libokular5core8 (4:17.12.2-2.2+deb10u1) ...
                          Entfernen von libotr5:amd64 (4.1.1-4) ...
                          Entfernen von libsnmp30:amd64 (5.7.3+dfsg-5+deb10u2) ...
                          Entfernen von libperl5.28:amd64 (5.28.1-6+deb10u1) ...
                          Entfernen von libplacebo7:amd64 (1.7.0-2) ...
                          Entfernen von libplymouth4:amd64 (0.9.4-1.1) ...
                          Entfernen von libpoppler82:amd64 (0.71.0-5) ...
                          Entfernen von libprotobuf-lite17:amd64 (3.6.1.3-2) ...
                          Entfernen von libpwquality-common (1.4.4-1) ...
                          Entfernen von python3.7-minimal (3.7.3-2+deb10u3) ...
                          Unlinking and removing bytecode for runtime python3.7
                          Entfernen von libpython3.7-minimal:amd64 (3.7.3-2+deb10u3) ...
                          Entfernen von libqpdf21:amd64 (8.4.0-2) ...
                          Entfernen von libqtcurve-utils2:amd64 (1.9-7+b2) ...
                          Entfernen von libraw19:amd64 (0.19.2-2) ...
                          Entfernen von libre2-5:amd64 (20190101+dfsg-2) ...
                          Entfernen von libreadline5:amd64 (5.2+dfsg-3+b13) ...
                          Entfernen von libruby2.5:amd64 (2.5.5-3+deb10u3) ...
                          Entfernen von libreadline7:amd64 (7.0-5) ...
                          Entfernen von libreoffice (1:7.0.4-4+deb11u1) ...
                          Entfernen von libreoffice-avmedia-backend-gstreamer (1:7.0.4-4+deb11u1) ...
                          Entfernen von libreoffice-kde5 (1:7.0.4-4+deb11u1) ...
                          Entfernen von libreoffice-librelogo (1:7.0.4-4+deb11u1) ...
                          Entfernen von libreoffice-nlpsolver (0.9+LibO7.0.4-4+deb11u1) ...
                          Entfernen von libreoffice-script-provider-js (1:7.0.4-4+deb11u1) ...
                          Entfernen von libreoffice-script-provider-python (1:7.0.4-4+deb11u1) ...
                          Entfernen von libreoffice-wiki-publisher (1.2.0+LibO7.0.4-4+deb11u1) ...
                          Entfernen von libsane:amd64 (1.0.31-4.1) ...
                          Entfernen von libsisu-ioc-java (2.3.0-11) ...
                          Entfernen von libsisu-guice-java (4.2.0-1) ...
                          Entfernen von libtidy5deb1:amd64 (2:5.6.0-11) ...
                          Entfernen von libtss2-udev (2.1.0-4) ...
                          Entfernen von libturbojpeg0:amd64 (1:2.0.6-4) ...
                          Entfernen von libu2f-udev (1.1.10-3) ...
                          Entfernen von libusageenvironment3:amd64 (2018.11.26-1.1) ...
                          Entfernen von libusbmuxd4:amd64 (1.1.0~git20181007.07a493a-1) ...
                          Entfernen von libutempter0:amd64 (1.2.1-2) ...
                          Entfernen von libvpx5:amd64 (1.7.0-3+deb10u1) ...
                          Entfernen von libx264-155:amd64 (2:0.155.2917+git0a84d98-2) ...
                          Entfernen von libx265-165:amd64 (2.9-4) ...
                          Entfernen von libxcb-util0:amd64 (0.3.8-3+b2) ...
                          Entfernen von linux-image-4.19.0-16-amd64 (4.19.181-1) ...
                          /etc/kernel/postrm.d/initramfs-tools:
                          update-initramfs: Deleting /boot/initrd.img-4.19.0-16-amd64
                          /etc/kernel/postrm.d/zz-update-grub:
                          Generating grub configuration file ...
                          Found background image: /usr/share/images/desktop-base/desktop-grub.png
                          Found linux image: /boot/vmlinuz-5.10.0-11-amd64
                          Found initrd image: /boot/initrd.img-5.10.0-11-amd64
                          Found linux image: /boot/vmlinuz-5.10.0-9-amd64
                          Found initrd image: /boot/initrd.img-5.10.0-9-amd64
                          Found linux image: /boot/vmlinuz-5.10.0-8-amd64
                          Found initrd image: /boot/initrd.img-5.10.0-8-amd64
                          Found linux image: /boot/vmlinuz-4.19.0-17-amd64
                          Found initrd image: /boot/initrd.img-4.19.0-17-amd64
                          done
                          Entfernen von linux-image-4.19.0-17-amd64 (4.19.194-3) ...
                          update-initramfs: Deleting /boot/initrd.img-4.19.0-17-amd64
                          done
                          Entfernen von linux-image-5.10.0-8-amd64 (5.10.46-5) ...
                          update-initramfs: Deleting /boot/initrd.img-5.10.0-8-amd64
                          done
                          Entfernen von oxygen-icon-theme (5:5.78.0-2) ...
                          Entfernen von phonon-backend-gstreamer-common:amd64 (4:4.10.0-1) ...
                          Entfernen von polkit-kde-1 (4:5.14.5-1) ...
                          Entfernen von printer-driver-hpijs (3.21.2+dfsg1-2) ...
                          Entfernen von python3-sip (4.19.25+dfsg-1) ...
                          Entfernen von qml-module-qtquick-controls-styles-breeze (4:5.14.5-1) ...
                          Entfernen von qtcore4-l10n (4:4.8.7+dfsg-18+deb10u1) ...
                          Entfernen von ruby-did-you-mean (1.2.1-1) ...
                          Entfernen von ntrack-module-libnl-0 (016-1.4) ...
                          Entfernen von ruby2.7 (2.7.4-1+deb11u1) ...
                          Entfernen von libruby2.7:amd64 (2.7.4-1+deb11u1) ...
                          Entfernen von rake (13.0.3-1) ...
                          Entfernen von ruby (1:2.7+2) ...
                          Entfernen von ruby-rubygems (3.2.5-2) ...
                          Entfernen von ruby-minitest (5.13.0-1) ...
                          Entfernen von ruby-net-telnet (0.1.1-2) ...
                          Entfernen von ruby-test-unit (3.3.9-1) ...
                          Entfernen von ruby-power-assert (1.1.7-2) ...
                          Entfernen von ruby-xmlrpc (0.3.0-2) ...
                          Entfernen von rubygems-integration (1.18) ...
                          Entfernen von libntrack0 (016-1.4) ...
                          Trigger für hicolor-icon-theme (0.17-2) werden verarbeitet ...
                          Trigger für cups (2.3.3op2-3+deb11u1) werden verarbeitet ...
                          Trigger für libc-bin (2.31-13+deb11u2) werden verarbeitet ...
                          Trigger für man-db (2.9.4-2) werden verarbeitet ...
                          Trigger für libreoffice-common (1:7.0.4-4+deb11u1) werden verarbeitet ...
                          Trigger für dbus (1.12.20-2) werden verarbeitet ...
                          Trigger für shared-mime-info (2.0-1) werden verarbeitet ...
                          Trigger für mailcap (3.69) werden verarbeitet ...
                          Trigger für fontconfig (2.13.1-4.2) werden verarbeitet ...
                          iobroker@iobroker:/opt/iobroker$ sudo reboot
                          iobroker@iobroker:~$ cd /opt/iobroker
                          iobroker@iobroker:/opt/iobroker$ npm ls authenticate-pam
                          iobroker.inst@3.0.0 /opt/iobroker
                          └─┬ iobroker.terminal@0.1.2
                            └── UNMET OPTIONAL DEPENDENCY authenticate-pam@1.0.2
                          iobroker@iobroker:/opt/iobroker$ npm ls authenticate_pam
                          └── (empty)
                          • B Blade1987
                            @thomas-braun said in Adapter Update-Schleife bzw. wird nicht aktualisiert:
                            done
                            done
                            done
                            └── (empty)
                            @blade1987 sagte in Adapter Update-Schleife bzw. wird nicht aktualisiert:
                            iobroker.terminal
                            Der schleppt den authenticate-pam Kram an.
                            cd /opt/iobroker
                            npm uninstall iobroker.terminal
                              iobroker.terminal
                              cd /opt/iobroker
                              Blade1987
                              iobroker@iobroker:/opt/iobroker$ npm uninstall iobroker.terminal
                              > iobroker.xbox@0.7.7 install /opt/iobroker/node_modules/iobroker.xbox
                              > npip install
                              No python_modules directory; installing pip locally if needed.
                                Cache entry deserialization failed, entry ignored
                              Successfully completed pip check.
                              Collecting xbox-smartglass-core>=1.3.0
                                Using cached xbox_smartglass_core-1.3.0-py2.py3-none-any.whl (85 kB)
                              Requirement already satisfied: requests>=2.25.1 in /usr/lib/python3/dist-packages (2.25.1)
                              Collecting pydantic==1.7.1
                                Downloading pydantic-1.7.1-cp39-cp39-manylinux2014_x86_64.whl (10.2 MB)
                                   ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 10.2/10.2 MB 24.0 MB/s eta 0:00:00
                              Collecting construct==2.10.56
                                Using cached construct-2.10.56.tar.gz (54 kB)
                                Preparing metadata (setup.py) ... done
                              Collecting cryptography==3.2.1
                                Using cached cryptography-3.2.1-cp35-abi3-manylinux2010_x86_64.whl (2.6 MB)
                              Collecting uvicorn==0.12.2
                                Using cached uvicorn-0.12.2-py3-none-any.whl (45 kB)
                              Collecting fastapi==0.61.1
                                Using cached fastapi-0.61.1-py3-none-any.whl (48 kB)
                              Collecting aioconsole==0.3.0
                                Using cached aioconsole-0.3.0.tar.gz (14 kB)
                              Collecting dpkt==1.9.4
                                Using cached dpkt-1.9.4-py3-none-any.whl (149 kB)
                              Collecting xbox-webapi==2.0.9
                                Using cached xbox_webapi-2.0.9-py2.py3-none-any.whl (53 kB)
                              Collecting urwid==2.1.2
                                Using cached urwid-2.1.2.tar.gz (634 kB)
                              Collecting cffi!=1.11.3,>=1.8
                                Downloading cffi-1.15.0-cp39-cp39-manylinux_2_12_x86_64.manylinux2010_x86_64.whl (444 kB)
                                   ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 444.3/444.3 KB 14.7 MB/s eta 0:00:00
                              Requirement already satisfied: six>=1.4.1 in /usr/lib/python3/dist-packages (from cryptography==3.2.1->xbox-smartglass-core>=1.3.0) (1.16.0)
                              Collecting starlette==0.13.6
                                Using cached starlette-0.13.6-py3-none-any.whl (59 kB)
                              Collecting h11>=0.8
                                Downloading h11-0.13.0-py3-none-any.whl (58 kB)
                                   ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 58.2/58.2 KB 2.4 MB/s eta 0:00:00
                              Collecting click==7.*
                                Using cached click-7.1.2-py2.py3-none-any.whl (82 kB)
                              Collecting ms-cv
                                Using cached ms_cv-0.1.1.tar.gz (2.6 kB)
                              Collecting aiohttp
                                Downloading aiohttp-3.8.1-cp39-cp39-manylinux_2_5_x86_64.manylinux1_x86_64.manylinux_2_12_x86_64.manylinux2010_x86_64.whl (1.2 MB)
                                   ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 1.2/1.2 MB 24.4 MB/s eta 0:00:00
                              Collecting ecdsa
                                Downloading ecdsa-0.17.0-py2.py3-none-any.whl (119 kB)
                                   ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 119.3/119.3 KB 6.6 MB/s eta 0:00:00
                              Collecting appdirs
                                Using cached appdirs-1.4.4-py2.py3-none-any.whl (9.6 kB)
                              Collecting pycparser
                                Downloading pycparser-2.21-py2.py3-none-any.whl (118 kB)
                                   ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 118.7/118.7 KB 6.1 MB/s eta 0:00:00
                              Collecting async-timeout<5.0,>=4.0.0a3
                                Downloading async_timeout-4.0.2-py3-none-any.whl (5.8 kB)
                              Collecting multidict<7.0,>=4.5
                                Downloading multidict-6.0.2-cp39-cp39-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (114 kB)
                                   ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 114.2/114.2 KB 5.5 MB/s eta 0:00:00
                              Collecting yarl<2.0,>=1.0
                                Downloading yarl-1.7.2-cp39-cp39-manylinux_2_5_x86_64.manylinux1_x86_64.manylinux_2_12_x86_64.manylinux2010_x86_64.whl (304 kB)
                                   ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 304.5/304.5 KB 11.6 MB/s eta 0:00:00
                              Collecting frozenlist>=1.1.1
                                Downloading frozenlist-1.3.0-cp39-cp39-manylinux_2_5_x86_64.manylinux1_x86_64.manylinux_2_17_x86_64.manylinux2014_x86_64.whl (156 kB)
                                   ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 156.2/156.2 KB 8.2 MB/s eta 0:00:00
                              Collecting attrs>=17.3.0
                                Downloading attrs-21.4.0-py2.py3-none-any.whl (60 kB)
                                   ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 60.6/60.6 KB 2.9 MB/s eta 0:00:00
                              Collecting charset-normalizer<3.0,>=2.0
                                Downloading charset_normalizer-2.0.12-py3-none-any.whl (39 kB)
                              Collecting aiosignal>=1.1.2
                                Downloading aiosignal-1.2.0-py3-none-any.whl (8.2 kB)
                              Requirement already satisfied: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp->xbox-webapi==2.0.9->xbox-smartglass-core>=1.3.0) (2.10)
                              Building wheels for collected packages: aioconsole, construct, urwid, ms-cv
                                Building wheel for aioconsole (setup.py) ... done
                                Created wheel for aioconsole: filename=aioconsole-0.3.0-py3-none-any.whl size=16277 sha256=e7d179dcf96aedd683f8ab3dce63549bbb3007d7a670e7bad38be66360f2b709
                                Stored in directory: /home/iobroker/.cache/pip/wheels/02/0e/84/37d966c9aff6b4a4ca99b4cfc8b461a76cbaef9c4611d87cb5
                                Building wheel for construct (setup.py) ... done
                                Created wheel for construct: filename=construct-2.10.56-py3-none-any.whl size=56893 sha256=6533096f0bbb3e2939c39e35ac9f24e627382ed9b71250b2acadca77392e4369
                                Stored in directory: /home/iobroker/.cache/pip/wheels/8f/63/dc/68b683feabe9c3abc402f7c93d5ef3837fef15dca9ab31cb76
                                Building wheel for urwid (setup.py) ... done
                                Created wheel for urwid: filename=urwid-2.1.2-cp39-cp39-linux_x86_64.whl size=255245 sha256=9b4e14b98f99ef4312749fc4b325dfb912b409eee130f96981323eed716e7046
                                Stored in directory: /home/iobroker/.cache/pip/wheels/44/ec/04/2c1080c3ee4e80e76d662ac35f0594a2a86f9df12095b05cb3
                                Building wheel for ms-cv (setup.py) ... done
                                Created wheel for ms-cv: filename=ms_cv-0.1.1-py2.py3-none-any.whl size=2645 sha256=8fa771dd5680413c758f3066e2ff277dfd4cfa51a5cc45757c010abecdb41672
                                Stored in directory: /home/iobroker/.cache/pip/wheels/32/83/cd/fe405ef05ee7114a26f690f9605ae663645a5bb3072cd2e576
                              Successfully built aioconsole construct urwid ms-cv
                              Installing collected packages: urwid, ms-cv, dpkt, appdirs, starlette, pydantic, pycparser, multidict, h11, frozenlist, ecdsa, construct, click, charset-normalizer, attrs, async-timeout, aioconsole, yarl, uvicorn, fastapi, cffi, aiosignal, cryptography, aiohttp, xbox-webapi, xbox-smartglass-core
                              Successfully installed aioconsole-0.3.0 aiohttp-3.8.1 aiosignal-1.2.0 appdirs-1.4.4 async-timeout-4.0.2 attrs-21.4.0 cffi-1.15.0 charset-normalizer-2.0.12 click-7.1.2 construct-2.10.56 cryptography-3.2.1 dpkt-1.9.4 ecdsa-0.17.0 fastapi-0.61.1 frozenlist-1.3.0 h11-0.13.0 ms-cv-0.1.1 multidict-6.0.2 pycparser-2.21 pydantic-1.7.1 starlette-0.13.6 urwid-2.1.2 uvicorn-0.12.2 xbox-smartglass-core-1.3.0 xbox-webapi-2.0.9 yarl-1.7.2
                              added 1 package from 1 contributor and removed 56 packages in 60.329s
                              223 packages are looking for funding
                                run `npm fund` for details
                              • B Blade1987
                                > npip install
                                Collecting h11>=0.8
                                Collecting ms-cv
                                Collecting aiohttp
                                Collecting ecdsa
                                Collecting appdirs
                                @blade1987
                                Okay, das hatten wir noch nicht.
                                Ich vermute, der xbox-Adapter ist jetzt installiert worden.
                                iobroker update
                                iobroker upgrade
                                läuft jetzt auch?
                                  @blade1987
                                  iobroker update
                                  iobroker upgrade
                                  läuft jetzt auch?
                                  Blade1987
                                  iobroker upgrade
                                  iobroker@iobroker:/opt/iobroker$ iobroker update
                                  Used repository: beta
                                  Adapter    "adguard"      : 0.0.8    , installed 0.0.8
                                  Adapter    "admin"        : 5.3.1    , installed 5.2.3  [Updatable]
                                  Adapter    "alexa2"       : 3.12.0   , installed 3.12.0
                                  Adapter    "alias-manager": 1.2.6    , installed 1.2.4  [Updatable]
                                  Adapter    "asterisk"     : 1.0.6    , installed 1.0.6
                                  Adapter    "backitup"     : 2.3.5    , installed 2.3.5
                                  Adapter    "benchmark"    : 0.5.1    , installed 0.5.1
                                  Adapter    "ble"          : 0.12.0   , installed 0.12.0
                                  Adapter    "bring"        : 1.7.13   , installed 1.7.13
                                  Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
                                  Adapter    "cloud"        : 4.1.1    , installed 4.1.1
                                  Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                                  Adapter    "daswetter"    : 3.0.9    , installed 3.0.9
                                  Adapter    "deconz"       : 1.3.20   , installed 1.3.19 [Updatable]
                                  Adapter    "device-reminder": 1.2.9  , installed 1.2.9
                                  Adapter    "devices"      : 1.0.10   , installed 1.0.10
                                  Adapter    "discovery"    : 2.8.0    , installed 2.8.0
                                  Adapter    "echarts"      : 1.0.3    , installed 1.0.3
                                  Adapter    "ecovacs-deebot": 1.3.4   , installed 1.3.4
                                  Adapter    "email"        : 1.0.10   , installed 1.0.10
                                  Adapter    "eusec"        : 0.8.5    , installed 0.8.5
                                  Adapter    "eventlist"    : 0.5.4    , installed 0.5.4
                                  Adapter    "firetv"       : 1.0.0    , installed 1.0.0
                                  Adapter    "flot"         : 1.10.7   , installed 1.10.7
                                  Adapter    "fullybrowser" : 2.0.14   , installed 2.0.14
                                  Adapter    "ham"          : 4.0.2    , installed 4.0.2
                                  Adapter    "history"      : 1.11.0   , installed 1.11.0
                                  Adapter    "hm-rega"      : 3.0.37   , installed 3.0.37
                                  Adapter    "hm-rpc"       : 1.15.8   , installed 1.15.8
                                  Adapter    "homeconnect"  : 0.0.37   , installed 0.0.37
                                  Adapter    "ical"         : 1.11.6   , installed 1.11.6
                                  Adapter    "icons-mfd-png": 1.0.2    , installed 1.0.2
                                  Adapter    "icons-mfd-svg": 1.0.2    , installed 1.0.2
                                  Adapter    "influxdb"     : 2.6.3    , installed 2.6.0  [Updatable]
                                  Adapter    "info"         : 1.9.19   , installed 1.9.18 [Updatable]
                                  Adapter    "iot"          : 1.9.7    , installed 1.9.7
                                  Adapter    "javascript"   : 5.3.3    , installed 5.2.21 [Updatable]
                                  Controller "js-controller": 4.0.19   , installed 4.0.15 [Updatable]
                                  Adapter    "lg-thinq"     : 0.0.4    , installed 0.0.4
                                  Adapter    "linkeddevices": 1.4.3    , installed 1.4.3
                                  Adapter    "linux-control": 1.1.4    , installed 1.1.4
                                  Adapter    "logparser"    : 1.1.0    , installed 1.1.0
                                  Adapter    "lovelace"     : 2.1.4    , installed 2.1.4
                                  Adapter    "material"     : 1.1.2    , installed 1.1.2
                                  Adapter    "moma"         : 1.2.9    , installed 1.2.9
                                  Adapter    "mytime"       : 0.7.12   , installed 0.7.12
                                  Adapter    "net-tools"    : 0.1.7    , installed 0.1.7
                                  Adapter    "netatmo"      : 1.4.4    , installed 1.4.4
                                  Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                                  Adapter    "node-red"     : 2.4.2    , installed 2.4.2
                                  Adapter    "nuki-extended": 2.4.0    , installed 2.4.0
                                  Adapter    "nut"          : 1.5.1    , installed 1.5.1
                                  Adapter    "octoprint"    : 3.2.0    , installed 3.1.0  [Updatable]
                                  Adapter    "onkyo"        : 2.1.1    , installed 2.1.1
                                  Adapter    "onvif"        : 0.4.4    , installed 0.4.4
                                  Adapter    "openweathermap": 0.1.0   , installed 0.1.0
                                  Adapter    "parser"       : 1.0.7    , installed 1.0.7
                                  Adapter    "paw"          : 0.3.2    , installed 0.3.2
                                  Adapter    "philips-air"  : 0.1.0    , installed 0.1.0
                                  Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
                                  Adapter    "psa"          : 0.0.10   , installed 0.0.10
                                  Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
                                  Adapter    "sainlogic"    : 0.8.1    , installed 0.8.1
                                  Adapter    "schoolfree"   : 1.0.1    , installed 1.0.1
                                  Adapter    "seq"          : 0.2.10   , installed 0.2.10
                                  Adapter    "simple-api"   : 2.6.3    , installed 2.6.3
                                  Adapter    "smartcontrol" : 1.2.1    , installed 1.2.1
                                  Adapter    "smartmeter"   : 3.3.3    , installed 3.3.3
                                  Adapter    "snmp"         : 0.5.0    , installed 0.5.0
                                  Adapter    "socketio"     : 4.1.4    , installed 4.1.4
                                  Adapter    "sonoff"       : 2.4.7    , installed 2.4.7
                                  Adapter    "sony-bravia"  : 1.0.5    , installed 1.0.5
                                  Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                                  Adapter    "spotify-premium": 1.1.4  , installed 1.1.4
                                  Adapter    "sql"          : 1.16.2   , installed 1.16.2
                                  Adapter    "statistics"   : 1.0.10   , installed 1.0.10
                                  Adapter    "synology"     : 1.1.3    , installed 1.1.3
                                  Adapter    "systeminfo"   : 0.3.1    , installed 0.3.1
                                  Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
                                  Adapter    "telegram"     : 1.11.1   , installed 1.11.1
                                  Adapter    "text2command" : 2.2.1    , installed 2.2.1
                                  Adapter    "trashschedule": 1.4.3    , installed 1.4.3
                                  Adapter    "tuya"         : 3.6.15   , installed 3.6.15
                                  Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
                                  Adapter    "unifi"        : 0.5.10   , installed 0.5.10
                                  Adapter    "valuetrackerovertime": 0.6.2, installed 0.6.2
                                  Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
                                  Adapter    "vis"          : 1.4.12   , installed 1.4.12
                                  Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
                                  Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
                                  Adapter    "vis-google-fonts": 1.0.3 , installed 1.0.3
                                  Adapter    "vis-hqwidgets": 1.1.9    , installed 1.1.9
                                  Adapter    "vis-icontwo"  : 0.87.0   , installed 0.87.0
                                  Adapter    "vis-inventwo" : 3.3.0    , installed 3.2.8  [Updatable]
                                  Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                                  Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                                  Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                                  Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                                  Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
                                  Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                                  Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
                                  Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
                                  Adapter    "weatherunderground": 3.3.1, installed 3.3.1
                                  Adapter    "web"          : 4.2.0    , installed 4.2.0
                                  Adapter    "whatsapp-cmb" : 0.1.6    , installed 0.1.6
                                  Adapter    "wifilight"    : 1.1.0    , installed 1.1.0
                                  Adapter    "windows-control": 0.1.5  , installed 0.1.5
                                  Adapter    "wiobrowser"   : 1.1.2    , installed 1.1.2
                                  Adapter    "ws"           : 1.2.0    , installed 1.2.0
                                  Adapter    "xbox"         : 0.7.8    , installed 0.7.7  [Updatable]
                                  Adapter    "xterm"        : 0.2.0    , installed 0.2.0
                                  Adapter    "zigbee"       : 1.6.16   , installed 1.6.14 [Updatable]
                                  Adapter    "zoneminder"   : 0.3.3    , installed 0.3.3
                                  This upgrade of "xbox" will introduce the following changes:
                                  -> 0.7.8:
                                  we now set `unsafePerm` flag to ensure compatibility with future controller
                                  updated dependencies
                                  Would you like to upgrade xbox from @0.7.7 to @0.7.8 now? [(y)es, (n)o]: y
                                  Update xbox from @0.7.7 to @0.7.8
                                  NPM version: 6.14.16
                                  > npip install
                                    Using cached pydantic-1.7.1-cp39-cp39-manylinux2014_x86_64.whl (10.2 MB)
                                    Using cached construct-2.10.56-py3-none-any.whl
                                    Using cached urwid-2.1.2-cp39-cp39-linux_x86_64.whl
                                    Using cached aioconsole-0.3.0-py3-none-any.whl
                                    Using cached cffi-1.15.0-cp39-cp39-manylinux_2_12_x86_64.manylinux2010_x86_64.whl (444 kB)
                                  Collecting h11>=0.8
                                    Using cached h11-0.13.0-py3-none-any.whl (58 kB)
                                  Collecting aiohttp
                                    Using cached aiohttp-3.8.1-cp39-cp39-manylinux_2_5_x86_64.manylinux1_x86_64.manylinux_2_12_x86_64.manylinux2010_x86_64.whl (1.2 MB)
                                  Collecting ecdsa
                                    Using cached ecdsa-0.17.0-py2.py3-none-any.whl (119 kB)
                                  Collecting ms-cv
                                    Using cached ms_cv-0.1.1-py2.py3-none-any.whl
                                  Collecting appdirs
                                    Using cached pycparser-2.21-py2.py3-none-any.whl (118 kB)
                                    Using cached frozenlist-1.3.0-cp39-cp39-manylinux_2_5_x86_64.manylinux1_x86_64.manylinux_2_17_x86_64.manylinux2014_x86_64.whl (156 kB)
                                    Using cached multidict-6.0.2-cp39-cp39-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (114 kB)
                                    Using cached aiosignal-1.2.0-py3-none-any.whl (8.2 kB)
                                    Using cached async_timeout-4.0.2-py3-none-any.whl (5.8 kB)
                                    Using cached attrs-21.4.0-py2.py3-none-any.whl (60 kB)
                                    Using cached yarl-1.7.2-cp39-cp39-manylinux_2_5_x86_64.manylinux1_x86_64.manylinux_2_12_x86_64.manylinux2010_x86_64.whl (304 kB)
                                    Using cached charset_normalizer-2.0.12-py3-none-any.whl (39 kB)
                                  + iobroker.xbox@0.7.8
                                  added 4 packages from 6 contributors and updated 2 packages in 54.298s
                                  INFO: Directory "/opt/iobroker/node_modules/iobroker.xbox/admin" was not found! Nothing was uploaded or deleted.
                                  This upgrade of "vis-inventwo" will introduce the following changes:
                                  -> 3.3.0:
                                  New widget: configurable colorpicker for HEX, RGB, HSL, HSV and CIE/XY
                                  Would you like to upgrade vis-inventwo from @3.2.8 to @3.3.0 now? [(y)es, (n)o]:
                                  • B Blade1987
                                    iobroker upgrade
                                    -> 0.7.8:
                                    > npip install
                                    Collecting h11>=0.8
                                    Collecting aiohttp
                                    Collecting ecdsa
                                    Collecting ms-cv
                                    Collecting appdirs
                                    -> 3.3.0:
                                    @blade1987
                                    Hau die Updates durch.
                                      @blade1987
                                      Blade1987
                                      @thomas-braun bin ich grad dabei sieht aber so aus als wenn die Liste nun wirklich kleiner wird und auch bleibt poste gleich nochmal das komplette Log.
                                      Würde bedeuten danach auch wieder iob stop iob upgrade self und neu starten
                                      • B Blade1987
                                        @blade1987
                                        Um alles auf Stand zu haben: Ja.
                                        Wäre
                                        iobroker stop
                                        iobroker update
                                        iobroker start
                                        für den js-controller. Aber zuerst die Adapter aktualisieren.
                                        • B Blade1987
                                          @blade1987
                                          Am Ende sollte
                                          iobroker update -u
                                          keine Adapter mehr anzeigen. Ungefähr so:
                                          echad@chet:/opt/iobroker $ iobroker update -u
                                          Used repository: live-beta
