  4. Backup einspielen
    6.0k
Backup einspielen
53 Beiträge 5 Kommentatoren 5.5k Aufrufe 3 Beobachtet
  • F Fanny 0
    @thomas-braun Was soll mir das denn jetzt sagen??
    broker@iobroker:/opt/iobroker$ sudo ss -tulwn | grep LISTEN
    [sudo] password for broker:
    tcp   LISTEN 0      4096                              0.0.0.0:111       0.0.0.0:*
    tcp   LISTEN 0      4096                        127.0.0.53%lo:53        0.0.0.0:*
    tcp   LISTEN 0      128                               0.0.0.0:22        0.0.0.0:*
    tcp   LISTEN 0      511                             127.0.0.1:9000      0.0.0.0:*
    tcp   LISTEN 0      511                             127.0.0.1:9001      0.0.0.0:*
    tcp   LISTEN 0      4096                                 [::]:111          [::]:*
    tcp   LISTEN 0      128                                  [::]:22           [::]:*
    @fanny-0
    Da läuft schon was auf Port 9000 und 9001.
    Versuch mal
    sudo ss -tulpn | grep LISTEN
    das ist wohl besser.
    • F Offline
      Fanny 0
      Habe Iobroker nun noch einmal komplett neu rauf gespielt. Das steht jetzt in dem Logfile.
      2022-03-01 17:17:34.895  - info: host.iobroker iobroker.js-controller version 4.0.15 js-controller starting
      2022-03-01 17:17:34.902  - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2022-03-01 17:17:34.903  - info: host.iobroker hostname: iobroker, node: v14.19.0
      2022-03-01 17:17:34.903  - info: host.iobroker ip addresses: 192.168.178.137 2001:9e8:e5fd:7a00:1a56:80ff:fe05:a6cc fe80::1a56:80ff:fe05:a6cc
      2022-03-01 17:17:35.028  - info: host.iobroker Objects protocol version has changed, disconnecting!
      2022-03-01 17:17:35.053  - error: host.iobroker Cannot read system.config: null (OK when migrating or restoring)
      2022-03-01 17:17:35.109  - error: host.iobroker Cannot find view "system" for search "host"
      2022-03-01 17:17:35.201  - info: host.iobroker connected to Objects and States
      2022-03-01 17:17:35.238  - info: host.iobroker Node.js version has changed from unknown to 14.19.0
      2022-03-01 17:17:35.278  - info: host.iobroker Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
      2022-03-01 17:17:35.286  - info: host.iobroker added notifications configuration of host
      2022-03-01 17:17:35.298  - error: host.iobroker Cannot find view "system" for search "instance"
      2022-03-01 17:17:35.299  - error: host.iobroker Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
      2022-03-01 17:17:35.319  - info: host.iobroker Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2022-03-01 17:17:35.369  - error: host.iobroker Cannot find view "system" for search "host"
      2022-03-01 17:17:35.397  - error: host.iobroker Cannot find view "system" for search "state"
      2022-03-01 17:17:35.398  - error: host.iobroker Cannot find view "system" for search "instance"
      2022-03-01 17:17:35.401  - error: host.iobroker Could not collect system.host.iobroker states to check for obsolete states: Error: Cannot find view "system"
      2022-03-01 17:17:35.402  - error: host.iobroker  _design/system missing - call node iobroker.js setup
      2022-03-01 17:17:35.403  - info: host.iobroker  no instances found
      2022-03-01 17:17:35.819  - info: host.iobroker Created UUID: bdbaf7ff-d9fc-9810-ed9a-7aea65009f1a
      • F Fanny 0
        wendy2702W Online
        wendy2702W Online
        @fanny-0 Geht der Admin jetzt?
        sonst
        iob list instances
        F 1 Antwort Letzte Antwort
        • wendy2702W wendy2702
          sonst
          iob list instances
          Fanny 0
          @wendy2702 nein es geht gar nichts
          broker@iobroker:/opt/iobroker$ iobroker list instances
          + instance is alive
          • F Fanny 0
            + instance is alive
            wendy2702W Online
            wendy2702W Online
            @fanny-0 wie hast du installiert?
            Ist das Docker oder wo läuft iobroker ?
            Mach mal nach der Anleitung:
            https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht?_=1646139745215
              Fanny 0
              @wendy2702 Ich habe einen Ubuntu Server laufen. Den habe ich ganz frisch auf einen Intel NUC aufgesetzt. Die Installation habe ich über Putty gemacht!!
              wendy2702W HomoranH 2 Antworten Letzte Antwort
              • F Fanny 0
                wendy2702W Online
                wendy2702W Online
                @fanny-0 Ubuntu Server... mit GUI ?
                Wie installiert über Putty?
                  Fanny 0
                  @wendy2702 über diesen Befehl über Putty
                  broker@iobroker:/opt/iobroker$ curl -sLf https://iobroker.net/install.sh | bash -
                  HomoranH FredFF 2 Antworten Letzte Antwort
                  • F Fanny 0
                    @fanny-0 sagte in Backup einspielen:
                    in eine komplett neue Linux-Umgebung?
                    ohne dass vorher etwas drauf war?
                      Fanny 0
                      @homoran ja komplett neu
                      • F Fanny 0
                        @fanny-0 seltsam.
                        Nicht dass ich wüsste, was das bedeutet, aber mich wundert:
                        vielleicht ist ein Hostname iobroker vielleicht auch nicht so toll, wenn der Systemuser schon so heisst
                          @fanny-0 seltsam.
                          @homoran sagte in Backup einspielen:
                          Und es auch noch Kommandos mit gleichem Namen gibt...
                            Fanny 0
                            @thomas-braun ok...wie kann ich das ändern??
                            • F Fanny 0
                              und der Server läuft nicht in einem Container?
                              Muss es Ubuntu sein?
                              • F Fanny 0
                                @fanny-0
                                https://linuxize.com/post/how-to-change-hostname-on-ubuntu-20-04/
                                  @fanny-0
                                  Fanny 0
                                  den Hostnamen habe ich geändert
                                  • F Fanny 0
                                    FredFF Online
                                    FredFF Online
                                    FredF
                                    Most Active Forum Testing
                                    schrieb am zuletzt editiert von FredF
                                    Wenn das ein neu installierter Ubuntu Server ist - woher kommt dieses Verzeichniss her?
                                    Das wird erst NACH Ausführung der ioBroker Installationsroutine angelegt.
                                    • FredFF FredF
                                      Fanny 0
                                      @fredf
                                      Habe den Iobroker bereits mehrfach installiert. Aber sofern ich ein Backup einspiele geht nichts mehr
                                      • F Fanny 0
                                        @fredf
                                        FredFF Online
                                        FredFF Online
                                        FredF
                                        @fanny-0
                                        Backup per Backit-up Adapter?
                                        Dann mach dein (von mir aus Ubuntu, gerne Debian 🤓 ) noch mal neu, installiere ioBroker mit der Routine, Backup über den Backit-up Adapter und das Log Fenster auflassen. Backup restore dauert... Geduld bitte
                                        • FredFF FredF
                                          @fanny-0
                                          Fanny 0
                                          @fredf
                                          das war mein erster Weg. Über Backitup sehe ich das LogFenster nicht.Im Browser öffnet sich kein zweites Fenster. POP up Blocker sind aus.
                                          Aber auch das Backup über Putty geht nicht
