  4. Backup einspielen
    6.0k
Backup einspielen
53 Beiträge 5 Kommentatoren 5.5k Aufrufe 3 Beobachtet
  • F Offline
    Fanny 0
    das steht jetzt im Logfile
    2022-03-01 16:00:28.369  - info: host.iobroker iobroker _restart
    2022-03-01 16:00:29.378  - info: host.iobroker iobroker Starting node restart.js
    2022-03-01 16:00:33.804  - info: host.iobroker iobroker.js-controller version 4.0.15 js-controller starting
    2022-03-01 16:00:33.811  - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2022-03-01 16:00:33.812  - info: host.iobroker hostname: iobroker, node: v14.19.0
    2022-03-01 16:00:33.813  - info: host.iobroker ip addresses: 192.168.178.137 2001:9e8:e5fd:7a00:1a56:80ff:fe05:a6cc fe80::1a56:80ff:fe05:a6cc
    2022-03-01 16:00:33.881  - info: host.iobroker-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
    2022-03-01 16:01:03.832  - error: host.iobroker No connection to databases possible, restart
    2022-03-01 16:01:03.858  - info: host.iobroker iobroker _restart
    2022-03-01 16:01:04.864  - info: host.iobroker iobroker Starting node restart.js
    2022-03-01 16:01:09.304  - info: host.iobroker iobroker.js-controller version 4.0.15 js-controller starting
    2022-03-01 16:01:09.311  - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2022-03-01 16:01:09.312  - info: host.iobroker hostname: iobroker, node: v14.19.0
    2022-03-01 16:01:09.312  - info: host.iobroker ip addresses: 192.168.178.137 2001:9e8:e5fd:7a00:1a56:80ff:fe05:a6cc fe80::1a56:80ff:fe05:a6cc
    2022-03-01 16:01:09.380  - info: host.iobroker-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
    2022-03-01 16:01:39.331  - error: host.iobroker No connection to databases possible, restart
    2022-03-01 16:01:39.337  - info: host.iobroker iobroker _restart
    2022-03-01 16:01:44.784  - info: host.iobroker iobroker.js-controller version 4.0.15 js-controller starting
    2022-03-01 16:01:44.792  - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2022-03-01 16:01:44.793  - info: host.iobroker hostname: iobroker, node: v14.19.0
    2022-03-01 16:01:44.793  - info: host.iobroker ip addresses: 192.168.178.137 2001:9e8:e5fd:7a00:1a56:80ff:fe05:a6cc fe80::1a56:80ff:fe05:a6cc
    2022-03-01 16:01:44.857  - info: host.iobroker-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
    2022-03-01 16:02:14.813  - error: host.iobroker No connection to databases possible, restart
    2022-03-01 16:02:14.838  - info: host.iobroker iobroker _restart
    2022-03-01 16:02:15.844  - info: host.iobroker iobroker Starting node restart.js
    2022-03-01 16:02:20.296  - info: host.iobroker iobroker.js-controller version 4.0.15 js-controller starting
    2022-03-01 16:02:20.303  - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2022-03-01 16:02:20.304  - info: host.iobroker hostname: iobroker, node: v14.19.0
    2022-03-01 16:02:20.304  - info: host.iobroker ip addresses: 192.168.178.137 2001:9e8:e5fd:7a00:1a56:80ff:fe05:a6cc fe80::1a56:80ff:fe05:a6cc
    2022-03-01 16:02:20.371  - info: host.iobroker-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
    2022-03-01 16:02:50.323  - error: host.iobroker No connection to databases possible, restart
    2022-03-01 16:02:50.330  - info: host.iobroker iobroker _restart
    2022-03-01 16:02:51.317  - info: host.iobroker iobroker Starting node restart.js
    • F Fanny 0
      @fanny-0 Die IP Adresse ist richtig und die Firewall ist aus!!
      wendy2702W Online
      wendy2702W Online
      @fanny-0 und es ist egal ob http oder https ?
      hast du nach allem mal den ganzen Server neu gestartet?
      Sonst mal versuchen einen zweiten Admin zu installieren
      iob add admin
      versuchen mit dem neuen Port zu verbinden
      • F Fanny 0
        @fanny-0 sagte in Backup einspielen:
        Da läuft noch/schon was auf dem Port.
        sudo ss -tulwn | grep LISTEN
        Und setz die Systemzeit/Zeitzone richtig. Offenbar steht die auf London.
        F 1 Antwort Letzte Antwort
        • F Fanny 0
          hast du da noch was auf Port 9001 oder zwei Installationen
            Fanny 0
            @homoran nein nur eine
              Fanny 0
              @thomas-braun Was soll mir das denn jetzt sagen??
              broker@iobroker:/opt/iobroker$ sudo ss -tulwn | grep LISTEN
              [sudo] password for broker:
              tcp   LISTEN 0      4096                              0.0.0.0:111       0.0.0.0:*
              tcp   LISTEN 0      4096                        127.0.0.53%lo:53        0.0.0.0:*
              tcp   LISTEN 0      128                               0.0.0.0:22        0.0.0.0:*
              tcp   LISTEN 0      511                             127.0.0.1:9000      0.0.0.0:*
              tcp   LISTEN 0      511                             127.0.0.1:9001      0.0.0.0:*
              tcp   LISTEN 0      4096                                 [::]:111          [::]:*
              tcp   LISTEN 0      128                                  [::]:22           [::]:*
              • F Fanny 0
                @fanny-0
                Da läuft schon was auf Port 9000 und 9001.
                Versuch mal
                sudo ss -tulpn | grep LISTEN
                das ist wohl besser.
                • F Offline
                  Fanny 0
                  Habe Iobroker nun noch einmal komplett neu rauf gespielt. Das steht jetzt in dem Logfile.
                  2022-03-01 17:17:34.895  - info: host.iobroker iobroker.js-controller version 4.0.15 js-controller starting
                  2022-03-01 17:17:34.902  - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                  2022-03-01 17:17:34.903  - info: host.iobroker hostname: iobroker, node: v14.19.0
                  2022-03-01 17:17:34.903  - info: host.iobroker ip addresses: 192.168.178.137 2001:9e8:e5fd:7a00:1a56:80ff:fe05:a6cc fe80::1a56:80ff:fe05:a6cc
                  2022-03-01 17:17:35.028  - info: host.iobroker Objects protocol version has changed, disconnecting!
                  2022-03-01 17:17:35.053  - error: host.iobroker Cannot read system.config: null (OK when migrating or restoring)
                  2022-03-01 17:17:35.109  - error: host.iobroker Cannot find view "system" for search "host"
                  2022-03-01 17:17:35.201  - info: host.iobroker connected to Objects and States
                  2022-03-01 17:17:35.238  - info: host.iobroker Node.js version has changed from unknown to 14.19.0
                  2022-03-01 17:17:35.278  - info: host.iobroker Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
                  2022-03-01 17:17:35.286  - info: host.iobroker added notifications configuration of host
                  2022-03-01 17:17:35.298  - error: host.iobroker Cannot find view "system" for search "instance"
                  2022-03-01 17:17:35.299  - error: host.iobroker Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
                  2022-03-01 17:17:35.319  - info: host.iobroker Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                  2022-03-01 17:17:35.369  - error: host.iobroker Cannot find view "system" for search "host"
                  2022-03-01 17:17:35.397  - error: host.iobroker Cannot find view "system" for search "state"
                  2022-03-01 17:17:35.398  - error: host.iobroker Cannot find view "system" for search "instance"
                  2022-03-01 17:17:35.401  - error: host.iobroker Could not collect system.host.iobroker states to check for obsolete states: Error: Cannot find view "system"
                  2022-03-01 17:17:35.402  - error: host.iobroker  _design/system missing - call node iobroker.js setup
                  2022-03-01 17:17:35.403  - info: host.iobroker  no instances found
                  2022-03-01 17:17:35.819  - info: host.iobroker Created UUID: bdbaf7ff-d9fc-9810-ed9a-7aea65009f1a
                  • F Fanny 0
                    wendy2702W Online
                    wendy2702W Online
                    @fanny-0 Geht der Admin jetzt?
                    sonst
                    iob list instances
                    • wendy2702W wendy2702
                      sonst
                      iob list instances
                      Fanny 0
                      @wendy2702 nein es geht gar nichts
                      broker@iobroker:/opt/iobroker$ iobroker list instances
                      + instance is alive
                      • F Fanny 0
                        + instance is alive
                        wendy2702W Online
                        wendy2702W Online
                        @fanny-0 wie hast du installiert?
                        Ist das Docker oder wo läuft iobroker ?
                        Mach mal nach der Anleitung:
                        https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht?_=1646139745215
                          Fanny 0
                          @wendy2702 Ich habe einen Ubuntu Server laufen. Den habe ich ganz frisch auf einen Intel NUC aufgesetzt. Die Installation habe ich über Putty gemacht!!
                          wendy2702W HomoranH 2 Antworten Letzte Antwort
                          • F Fanny 0
                            wendy2702W Online
                            wendy2702W Online
                            @fanny-0 Ubuntu Server... mit GUI ?
                            Wie installiert über Putty?
                              Fanny 0
                              @wendy2702 über diesen Befehl über Putty
                              broker@iobroker:/opt/iobroker$ curl -sLf https://iobroker.net/install.sh | bash -
                              HomoranH FredFF 2 Antworten Letzte Antwort
                              • F Fanny 0
                                in eine komplett neue Linux-Umgebung?
                                ohne dass vorher etwas drauf war?
                                  Fanny 0
                                  @homoran ja komplett neu
                                  • F Fanny 0
                                    @fanny-0 seltsam.
                                    Nicht dass ich wüsste, was das bedeutet, aber mich wundert:
                                    vielleicht ist ein Hostname iobroker vielleicht auch nicht so toll, wenn der Systemuser schon so heisst
                                      @fanny-0 seltsam.
                                      @homoran sagte in Backup einspielen:
                                      Und es auch noch Kommandos mit gleichem Namen gibt...
                                        Fanny 0
                                        @thomas-braun ok...wie kann ich das ändern??
                                        • F Fanny 0
                                          und der Server läuft nicht in einem Container?
                                          Muss es Ubuntu sein?
