Orange Pi Plus 2e
Er spricht mit mir und ist unzufireden mit mir. Sieht aus wie die dritte Boot-Option:
U-Boot SPL 2017.01-armbian (Feb 02 2017 - 02:57:05) DRAM: 2048 MiB Trying to boot from MMC1 U-Boot 2017.01-armbian (Feb 02 2017 - 02:57:05 +0100) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi 2 I2C: ready DRAM: 2 GiB MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: phy interface0 eth0: ethernet@1c30000 Hit any key to stop autoboot: 0 6944 bytes read in 165 ms (41 KiB/s) switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 2652 bytes read in 194 ms (12.7 KiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 0 bytes read in 136 ms (0 Bytes/s) 3789966 bytes read in 461 ms (7.8 MiB/s) 4754648 bytes read in 527 ms (8.6 MiB/s) ** File not found /boot/.next ** ** File not found .next ** 34964 bytes read in 476 ms (71.3 KiB/s) ## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 3789902 Bytes = 3.6 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Starting kernel ... Error: unrecognized/unsupported machine ID (r1 = 0x00000000). Available machine support: ID (hex) NAME 00001029 sun8i Please check your kernel config and/or bootloader.Vielleicht ist jetzt die SD-Karte durch das viele Steckerziehen defekt, teste mal eine neue.
Neue Karte, neues Glück
[00] U-Boot SPL 2017.01-armbian (Feb 02 2017 - 02:57:05) DRAM: 2048 MiB Trying to boot from MMC1 U-Boot 2017.01-armbian (Feb 02 2017 - 02:57:05 +0100) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi 2 I2C: ready DRAM: 2 GiB MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: phy interface0 eth0: ethernet@1c30000 Hit any key to stop autoboot: 0 6944 bytes read in 151 ms (43.9 KiB/s) switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 2652 bytes read in 186 ms (13.7 KiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 123 bytes read in 127 ms (0 Bytes/s) 3789966 bytes read in 443 ms (8.2 MiB/s) 4754648 bytes read in 506 ms (9 MiB/s) ** File not found /boot/.next ** ** File not found .next ** 34964 bytes read in 433 ms (78.1 KiB/s) ## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 3789902 Bytes = 3.6 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Using machid 0x1029 from environment Starting kernel ... [sun8i_fixup]: From boot, get meminfo: Start: 0x40000000 Size: 2048MB ion_carveout reserve: 160m@0 256m@0 130m@1 200m@1 ion_reserve_select: ion chipid [0x2c00081! ion_reserve_common: ion reserve: [0xb0000000, 0xc0000000]! Loading, please wait... Begin: Loading essential drivers ... done. Begin: Running /scripts/init-premount ... done. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Begin: Will now check root file system ... fsck from util-linux 2.25.2 [/sbin/fsck.ext4 (1) -- /dev/mmcblk0p1] fsck.ext4 -a -C0 /dev/mmcblk0p1 /dev/mmcblk0p1: clean, 48367/78080 files, 218810/312064 blocks done. done. Begin: Running /scripts/local-bottom ... done. Begin: Running /scripts/init-bottom ... done. Welcome to [1B][1mDebian GNU/Linux 8 (jessie)[1B][0m! Expecting device dev-ttyS0.device... [[1B][32m OK [1B][0m] Reached target Remote File Systems (Pre). [[1B][32m OK [1B][0m] Set up automount Arbitrary Executable File Formats F...utomount Point. [[1B][32m OK [1B][0m] Reached target Encrypted Volumes. [[1B][32m OK [1B][0m] Reached target Paths. [[1B][32m OK [1B][0m] Reached target Swap. [[1B][32m OK [1B][0m] Created slice Root Slice. [[1B][32m OK [1B][0m] Listening on /dev/initctl Compatibility Named Pipe. [[1B][32m OK [1B][0m] Listening on Delayed Shutdown Socket. [[1B][32m OK [1B][0m] Listening on Journal Socket (/dev/log). [[1B][32m OK [1B][0m] Created slice User and Session Slice. [[1B][32m OK [1B][0m] Listening on udev Control Socket. [[1B][32m OK [1B][0m] Listening on udev Kernel Socket. [[1B][32m OK [1B][0m] Listening on Journal Socket. [[1B][32m OK [1B][0m] Created slice System Slice. Starting Increase datagram queue length... Starting Restore / save the current clock... Starting udev Coldplug all Devices... Mounting POSIX Message Queue File System... Mounting Debug File System... Starting Create list of required static device nodes...rrent kernel... [[1B][32m OK [1B][0m] Created slice system-serial\x2dgetty.slice. Starting Load Kernel Modules... Starting LSB: Set keymap... [[1B][32m OK [1B][0m] Reached target Slices. [[1B][32m OK [1B][0m] Mounted Debug File System. [[1B][32m OK [1B][0m] Mounted POSIX Message Queue File System. [[1B][32m OK [1B][0m] Started Increase datagram queue length. [[1B][32m OK [1B][0m] Started Restore / save the current clock. [[1B][32m OK [1B][0m] Started Create list of required static device nodes ...current kernel. [[1B][32m OK [1B][0m] Started Load Kernel Modules. [[1B][32m OK [1B][0m] Started LSB: Set keymap. [[1B][32m OK [1B][0m] Started udev Coldplug all Devices. Starting Apply Kernel Variables... Mounting FUSE Control File System... Starting Create Static Device Nodes in /dev... [[1B][32m OK [1B][0m] Listening on Syslog Socket. Starting Journal Service... [[1B][32m OK [1B][0m] Started Journal Service. [[1B][32m OK [1B][0m] Mounted FUSE Control File System. [[1B][32m OK [1B][0m] Started Apply Kernel Variables. [[1B][32m OK [1B][0m] Started Create Static Device Nodes in /dev. Starting udev Kernel Device Manager... [[1B][32m OK [1B][0m] Started udev Kernel Device Manager. Starting Copy rules generated while the root was ro... Starting LSB: Tune IDE hard disks... Starting LSB: Set preliminary keymap... [[1B][32m OK [1B][0m] Started Copy rules generated while the root was ro. [[1B][32m OK [1B][0m] Found device /dev/ttyS0. [[1B][32m OK [1B][0m] Reached target Sound Card. [[1B][32m OK [1B][0m] Started LSB: Tune IDE hard disks. [[1B][32m OK [1B][0m] Created slice system-ifup.slice. [[1B][32m OK [1B][0m] Created slice system-systemd\x2drfkill.slice. [[1B][32m OK [1B][0m] Started LSB: Set preliminary keymap. Starting Remount Root and Kernel File Systems... [[1B][32m OK [1B][0m] Started Remount Root and Kernel File Systems. Starting Load/Save RF Kill Switch Status of rfkill0... Starting Various fixups to make systemd work better on Debian... Starting Load/Save Random Seed... [[1B][32m OK [1B][0m] Reached target Local File Systems (Pre). Mounting /tmp... [[1B][32m OK [1B][0m] Started Load/Save RF Kill Switch Status of rfkill0. [[1B][32m OK [1B][0m] Started Various fixups to make systemd work better on Debian. [[1B][32m OK [1B][0m] Started Load/Save Random Seed. [[1B][32m OK [1B][0m] Mounted /tmp. [[1B][32m OK [1B][0m] Reached target Local File Systems. Starting Armbian enhanced Log2Ram... Starting Create Volatile Files and Directories... [[1B][32m OK [1B][0m] Reached target Remote File Systems. Starting Trigger Flushing of Journal to Persistent Storage... Starting LSB: Prepare console... Starting LSB: Raise network interfaces.... [[1B][32m OK [1B][0m] Started Armbian enhanced Log2Ram. [[1B][32m OK [1B][0m] Started Create Volatile Files and Directories. [[1B][32m OK [1B][0m] Started LSB: Prepare console. [[1B][32m OK [1B][0m] Started Trigger Flushing of Journal to Persistent Storage. Starting LSB: Set console font and keymap... Starting Update UTMP about System Boot/Shutdown... [[1B][32m OK [1B][0m] Started Update UTMP about System Boot/Shutdown. [[1B][32m OK [1B][0m] Started LSB: Raise network interfaces.. Starting ifup for eth0... [[1B][32m OK [1B][0m] Started ifup for eth0. [[1B][32m OK [1B][0m] Reached target Network. [[1B][32m OK [1B][0m] Reached target Network is Online. [[1B][32m OK [1B][0m] Started LSB: Set console font and keymap. [[1B][32m OK [1B][0m] Reached target System Initialization. [[1B][32m OK [1B][0m] Listening on D-Bus System Message Bus Socket. [[1B][32m OK [1B][0m] Reached target Sockets. [[1B][32m OK [1B][0m] Reached target Timers. Starting Armbian filesystem resize service... Starting Restore Sound Card State... [[1B][32m OK [1B][0m] Started Restore Sound Card State. [[1B][32m OK [1B][0m] Started Armbian filesystem resize service. [[1B][32m OK [1B][0m] Reached target Basic System. Starting Entropy daemon using the HAVEGE algorithm... [[1B][32m OK [1B][0m] Started Entropy daemon using the HAVEGE algorithm. Starting Regular background program processing daemon... [[1B][32m OK [1B][0m] Started Regular background program processing daemon. Starting System Logging Service... Starting OpenBSD Secure Shell server... [[1B][32m OK [1B][0m] Started OpenBSD Secure Shell server. Starting Network Manager... Starting Armbian first run tasks... [[1B][32m OK [1B][0m] Started Armbian first run tasks. [[1B][32m OK [1B][0m] Created slice system-getty.slice. Starting /etc/rc.local Compatibility... Starting D-Bus System Message Bus... [[1B][32m OK [1B][0m] Started D-Bus System Message Bus. Starting Login Service... Starting Permit User Sessions... Starting LSB: Start NTP daemon... Starting LSB: Start/stop sysstat's sadc... Starting LSB: Armbian gathering hardware information... Starting LSB: Advanced IEEE 802.11 management daemon... Starting LSB: disk temperature monitoring daemon... Starting LSB: Starts LIRC daemon.... Starting LSB: Load kernel modules needed to enable cpufreq scaling... [[1B][32m OK [1B][0m] Started System Logging Service. [[1B][32m OK [1B][0m] Started /etc/rc.local Compatibility. [[1B][32m OK [1B][0m] Started Permit User Sessions. [[1B][32m OK [1B][0m] Started LSB: Start NTP daemon. [[1B][32m OK [1B][0m] Started LSB: Start/stop sysstat's sadc. [[1B][32m OK [1B][0m] Started LSB: Advanced IEEE 802.11 management daemon. [[1B][32m OK [1B][0m] Started LSB: disk temperature monitoring daemon. [[1B][32m OK [1B][0m] Started LSB: Armbian gathering hardware information. [[1B][32m OK [1B][0m] Started LSB: Starts LIRC daemon.. [[1B][32m OK [1B][0m] Started LSB: Load kernel modules needed to enable cpufreq scaling. [[1B][32m OK [1B][0m] Started Login Service. Starting Authenticate and Authorize Users to Run Privileged Tasks... Starting LSB: set CPUFreq kernel parameters... Starting Getty on tty1... [[1B][32m OK [1B][0m] Started Getty on tty1. Starting Serial Getty on ttyS0... [[1B][32m OK [1B][0m] Started Serial Getty on ttyS0. [[1B][32m OK [1B][0m] Reached target Login Prompts. [[1B][32m OK [1B][0m] Started Authenticate and Authorize Users to Run Privileged Tasks. [[1B][32m OK [1B][0m] Started LSB: set CPUFreq kernel parameters. Starting LSB: Set sysfs variables from /etc/sysfs.conf... Stopping LSB: Starts LIRC daemon.... [[1B][32m OK [1B][0m] Started Network Manager. [[1B][32m OK [1B][0m] Started LSB: Set sysfs variables from /etc/sysfs.conf. [[1B][32m OK [1B][0m] Stopped LSB: Starts LIRC daemon.. Starting LSB: Starts LIRC daemon.... [[1B][32m OK [1B][0m] Started LSB: Starts LIRC daemon.. [[1B][32m OK [1B][0m] Reached target Multi-User System. [[1B][32m OK [1B][0m] Reached target Graphical Interface. Starting Update UTMP about System Runlevel Changes... [[1B][32m OK [1B][0m] Started Update UTMP about System Runlevel Changes. Debian GNU/Linux 8 orangepi2 ttyS0 orangepi2 login:Als Laie würde ich sagen, er hat Eth gefunden und mein Netzwerk. Aber nichts Neues in der Fritte.
Starting ifup for eth0…
[[1B][32m OK [1B][0m] Reached target Network is Online. `
Sehe ich auch so, aber er hat auch noch keine IP-Adresse bezogen :(
das Ganze gefällt mir nicht :(
Noch zwei Dinge:
@klassisch:Model: Xunlong Orange Pi 2 `
Keine Ahnung wie sich der plus 2e melden sollte, aber ggf. erkennt Armbian ihn falsch und lädt falsche Pakete.HDMI ist doch kein Hokuspokus. Alle meine Monitore sind darüber mit den PCs verbunden.
nur einer über DVI und den freien HDMI-Eingang benutze ich dann für die "Kleinen".
HDMI ist doch kein Hokuspokus. Alle meine Monitore sind darüber mit den PCs verbunden. ` Ja, aber ein unzuverlässiger Krampf. Seit unsere Beamer in der Firma auf HDMI umgestellt wurden braucht man immer länger um eine stabile Verbindung zu erreichen - und manchmal gehts nur mit VGA/DVI.
Und privat habe ich nur Notebook und keinen Monitor - also auch kein HDMI. Also brauche ich Zugriff auf einen Fernseher. Zwar muß ich die TV-Zwangsabgebe bezahlen aber ich habe keinen. Deshalb versuche ich immer möglichst rasch auf headless zu kommen oder UltraVNC oder sowas.
So, eine SD vom neuen Download gebrannt und an einen freien TV geschlichen. Sieht gleich viel freundlicher aus. Router hate einen neuen Eintrag "orangepiplus2e" mit 1GBit/s. Gerade formatiert er seine eMMC.
Mal sehen wie es weiter geht. Werde Dann mit Deiner RasPi Anleitung weiter machen.
Nur zu Info, jetzt sieht das Boot-log auf der seriellen so aus:
U-Boot SPL 2017.01-armbian (Feb 02 2017 - 03:03:34) DRAM: 2048 MiB Trying to boot from MMC1 U-Boot 2017.01-armbian (Feb 02 2017 - 03:03:34 +0100) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi Plus 2E I2C: ready DRAM: 2 GiB MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 *** Warning - bad CRC, using default environment HDMI connected: Setting up a 1920x1080 hdmi console (overscan 0x0) hdmi enabled Error: no valid bmp image at 66000000 In: serial Out: vga Err: vga Net: phy interface7 eth0: ethernet@1c30000 Hit any key to stop autoboot: 0 6944 bytes read in 166 ms (40 KiB/s) switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 2652 bytes read in 204 ms (12.7 KiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 123 bytes read in 141 ms (0 Bytes/s) 3789974 bytes read in 473 ms (7.6 MiB/s) 4754648 bytes read in 538 ms (8.4 MiB/s) ** File not found /boot/.next ** ** File not found .next ** 36808 bytes read in 536 ms (66.4 KiB/s) ## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 3789910 Bytes = 3.6 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Using machid 0x1029 from environment Starting kernel ... [sun8i_fixup]: From boot, get meminfo: Start: 0x40000000 Size: 2048MB ion_carveout reserve: 160m@0 256m@0 130m@1 200m@1 ion_reserve_select: ion chipid [0x2c00081! ion_reserve_common: ion reserve: [0xb0000000, 0xc0000000]! Loading, please wait... Begin: Loading essential drivers ... done. Begin: Running /scripts/init-premount ... done. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Begin: Will now check root file system ... fsck from util-linux 2.25.2 [/sbin/fsck.ext4 (1) -- /dev/mmcblk0p1] fsck.ext4 -a -C0 /dev/mmcblk0p1 /dev/mmcblk0p1: clean, 48367/78080 files, 218799/312064 blocks done. done. Begin: Running /scripts/local-bottom ... done. Begin: Running /scripts/init-bottom ... done. Welcome to [1B][1mDebian GNU/Linux 8 (jessie)[1B][0m! Expecting device dev-ttyS0.device... [[1B][32m OK [1B][0m] Reached target Remote File Systems (Pre). [[1B][32m OK [1B][0m] Set up automount Arbitrary Executable File Formats F...utomount Point. [[1B][32m OK [1B][0m] Reached target Paths. [[1B][32m OK [1B][0m] Reached target Encrypted Volumes. [[1B][32m OK [1B][0m] Reached target Swap. [[1B][32m OK [1B][0m] Created slice Root Slice. [[1B][32m OK [1B][0m] Listening on /dev/initctl Compatibility Named Pipe. [[1B][32m OK [1B][0m] Listening on Delayed Shutdown Socket. [[1B][32m OK [1B][0m] Listening on Journal Socket (/dev/log). [[1B][32m OK [1B][0m] Created slice User and Session Slice. [[1B][32m OK [1B][0m] Listening on udev Control Socket. [[1B][32m OK [1B][0m] Listening on udev Kernel Socket. [[1B][32m OK [1B][0m] Listening on Journal Socket. [[1B][32m OK [1B][0m] Created slice System Slice. Starting Increase datagram queue length... Starting Restore / save the current clock... Starting udev Coldplug all Devices... Starting Create list of required static device nodes...rrent kernel... Mounting Debug File System... Mounting POSIX Message Queue File System... [[1B][32m OK [1B][0m] Created slice system-serial\x2dgetty.slice. Starting Load Kernel Modules... Starting LSB: Set keymap... [[1B][32m OK [1B][0m] Reached target Slices. [[1B][32m OK [1B][0m] Mounted POSIX Message Queue File System. [[1B][32m OK [1B][0m] Mounted Debug File System. [[1B][32m OK [1B][0m] Started Increase datagram queue length. [[1B][32m OK [1B][0m] Started Restore / save the current clock. [[1B][32m OK [1B][0m] Started Create list of required static device nodes ...current kernel. [[1B][32m OK [1B][0m] Started Load Kernel Modules. [[1B][32m OK [1B][0m] Started LSB: Set keymap. [[1B][32m OK [1B][0m] Started udev Coldplug all Devices. Starting Apply Kernel Variables... Mounting FUSE Control File System... Starting Create Static Device Nodes in /dev... [[1B][32m OK [1B][0m] Listening on Syslog Socket. Starting Journal Service... [[1B][32m OK [1B][0m] Started Journal Service. [[1B][32m OK [1B][0m] Mounted FUSE Control File System. [[1B][32m OK [1B][0m] Started Apply Kernel Variables. [[1B][32m OK [1B][0m] Started Create Static Device Nodes in /dev. Starting udev Kernel Device Manager... [[1B][32m OK [1B][0m] Started udev Kernel Device Manager. Starting Copy rules generated while the root was ro... Starting LSB: Set preliminary keymap... Starting LSB: Tune IDE hard disks... [[1B][32m OK [1B][0m] Started Copy rules generated while the root was ro. [[1B][32m OK [1B][0m] Started LSB: Tune IDE hard disks. [[1B][32m OK [1B][0m] Found device /dev/ttyS0. [[1B][32m OK [1B][0m] Created slice system-systemd\x2drfkill.slice. [[1B][32m OK [1B][0m] Reached target Sound Card. [[1B][32m OK [1B][0m] Created slice system-ifup.slice. [[1B][32m OK [1B][0m] Started LSB: Set preliminary keymap. Starting Remount Root and Kernel File Systems... [[1B][32m OK [1B][0m] Started Remount Root and Kernel File Systems. Starting Load/Save RF Kill Switch Status of rfkill0... Starting Various fixups to make systemd work better on Debian... Starting Load/Save Random Seed... [[1B][32m OK [1B][0m] Reached target Local File Systems (Pre). Mounting /tmp... [[1B][32m OK [1B][0m] Started Load/Save RF Kill Switch Status of rfkill0. [[1B][32m OK [1B][0m] Started Various fixups to make systemd work better on Debian. [[1B][32m OK [1B][0m] Started Load/Save Random Seed. [[1B][32m OK [1B][0m] Mounted /tmp. [[1B][32m OK [1B][0m] Reached target Local File Systems. Starting Armbian enhanced Log2Ram... Starting Create Volatile Files and Directories... [[1B][32m OK [1B][0m] Reached target Remote File Systems. Starting Trigger Flushing of Journal to Persistent Storage... Starting LSB: Prepare console... Starting LSB: Raise network interfaces.... [[1B][32m OK [1B][0m] Started Armbian enhanced Log2Ram. [[1B][32m OK [1B][0m] Started Create Volatile Files and Directories. [[1B][32m OK [1B][0m] Started LSB: Prepare console. Starting LSB: Set console font and keymap... Starting Update UTMP about System Boot/Shutdown... [[1B][32m OK [1B][0m] Started Trigger Flushing of Journal to Persistent Storage. [[1B][32m OK [1B][0m] Started Update UTMP about System Boot/Shutdown. [[1B][32m OK [1B][0m] Started LSB: Raise network interfaces.. Starting ifup for eth0... [[1B][32m OK [1B][0m] Started ifup for eth0. [[1B][32m OK [1B][0m] Reached target Network. [[1B][32m OK [1B][0m] Reached target Network is Online. [[1B][32m OK [1B][0m] Started LSB: Set console font and keymap. [[1B][32m OK [1B][0m] Reached target System Initialization. [[1B][32m OK [1B][0m] Listening on D-Bus System Message Bus Socket. [[1B][32m OK [1B][0m] Reached target Sockets. [[1B][32m OK [1B][0m] Reached target Timers. Starting Armbian filesystem resize service... Starting Restore Sound Card State... [[1B][32m OK [1B][0m] Started Restore Sound Card State. [[1B][32m OK [1B][0m] Started Armbian filesystem resize service. [[1B][32m OK [1B][0m] Reached target Basic System. Starting Entropy daemon using the HAVEGE algorithm... [[1B][32m OK [1B][0m] Started Entropy daemon using the HAVEGE algorithm. Starting OpenBSD Secure Shell server... [[1B][32m OK [1B][0m] Started OpenBSD Secure Shell server. Starting Network Manager... Starting Regular background program processing daemon... [[1B][32m OK [1B][0m] Started Regular background program processing daemon. Starting Armbian first run tasks... [[1B][32m OK [1B][0m] Started Armbian first run tasks. [[1B][32m OK [1B][0m] Created slice system-getty.slice. Starting System Logging Service... Starting /etc/rc.local Compatibility... Starting D-Bus System Message Bus... [[1B][32m OK [1B][0m] Started D-Bus System Message Bus. Starting Permit User Sessions... Starting Login Service... Starting LSB: Starts LIRC daemon.... Starting LSB: Load kernel modules needed to enable cpufreq scaling... Starting LSB: Start/stop sysstat's sadc... Starting LSB: disk temperature monitoring daemon... Starting LSB: Advanced IEEE 802.11 management daemon... Starting LSB: Start NTP daemon... Starting LSB: Armbian gathering hardware information... [[1B][32m OK [1B][0m] Started System Logging Service. [[1B][32m OK [1B][0m] Started /etc/rc.local Compatibility. [[1B][32m OK [1B][0m] Started Permit User Sessions. [[1B][32m OK [1B][0m] Started LSB: Starts LIRC daemon.. [[1B][32m OK [1B][0m] Started LSB: Load kernel modules needed to enable cpufreq scaling. [[1B][32m OK [1B][0m] Started LSB: Start/stop sysstat's sadc. [[1B][32m OK [1B][0m] Started LSB: disk temperature monitoring daemon. [[1B][32m OK [1B][0m] Started LSB: Advanced IEEE 802.11 management daemon. [[1B][32m OK [1B][0m] Started LSB: Start NTP daemon. [[1B][32m OK [1B][0m] Started Login Service. Starting Authenticate and Authorize Users to Run Privileged Tasks... Starting LSB: set CPUFreq kernel parameters... Starting Getty on tty1... [[1B][32m OK [1B][0m] Started Getty on tty1. Starting Serial Getty on ttyS0... [[1B][32m OK [1B][0m] Started Serial Getty on ttyS0. [[1B][32m OK [1B][0m] Reached target Login Prompts. [[1B][32m OK [1B][0m] Started LSB: Armbian gathering hardware information. [[1B][32m OK [1B][0m] Started LSB: set CPUFreq kernel parameters. [[1B][32m OK [1B][0m] Started Authenticate and Authorize Users to Run Privileged Tasks. Starting LSB: Set sysfs variables from /etc/sysfs.conf... [[1B][32m OK [1B][0m] Started Network Manager. [[1B][32m OK [1B][0m] Started LSB: Set sysfs variables from /etc/sysfs.conf. [[1B][32m OK [1B][0m] Reached target Multi-User System. [[1B][32m OK [1B][0m] Reached target Graphical Interface. Starting Update UTMP about System Runlevel Changes... [[1B][32m OK [1B][0m] Started Update UTMP about System Runlevel Changes. Stopping LSB: Starts LIRC daemon.... [[1B][32m OK [1B][0m] Stopped LSB: Starts LIRC daemon.. Starting LSB: Starts LIRC daemon.... [[1B][32m OK [1B][0m] Started LSB: Starts LIRC daemon.. Debian GNU/Linux 8 orangepiplus2e ttyS0 orangepiplus2e login: -
Ein paar Quäntchen weiter.
Mit
sudo nand-sata-installwird die eMMC in Betrieb genommen, formatiert und BS übertragen. SD-Card kann dann raus.
Ab jetzt geht es auch headless über SSH
Die update/upgrade Sachen gehen im Vergleich zu einen Raspi rasend schnell.
ioBroker Installation dauert dann wieder etwas länger und bringt Fehlermeldungen wie diese
npm install iobroker.js-controller --production --prefix /opt/iobroker npm WARN deprecated localhost.daplie.com-certificates@1.2.5: Moved to localhost.daplie.me-certificates npm install iobroker.admin --production --prefix /opt/iobroker npm install iobroker.discovery --production --prefix /opt/iobroker node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v46-linux-arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@4.8.2 (node-v46 ABI) (falling back to source compile with node-gyp) Write "./iobroker start" to start the ioBroker : No such file or directory Auto-start was enabled. Write "update-rc.d -f iobroker.sh remove" to disable auto-start iobroker is started. Go to "http://ip-addr:8081" to open the admin UI. iobroker@0.9.0 node_modules/iobroker └── yargs@7.0.2 (get-caller-file@1.0.2, decamelize@1.2.0, camelcase@3.0.0, y18n@3.2.1, which-module@1.0.0, set-blocking@2.0.0, yargs-parser@5.0.0, require-main-filename@1.0.1, require-directory@2.1.1, os-locale@1.4.0, cliui@3.2.0, string-width@1.0.2, read-pkg-up@1.0.1) root@orangepiplus2e:/opt/iobroker#dennoch läßt sich ioBroker per ssh starten und meldet sich dann auch auf der website.
Ist da etwas schief gelaufen und muß ich noch etwas korigieren?
Ansonsten müßte ich noch
die SSD einbinden und einem festen USB Port zuordnen (für History)
Backup vom alten ioBroker auf dem Raspi machen
das Backup auf dem Orange Pi einspielen
alten Raspi stillsetzen
USB-Stick mit History-Daten vom Raspi auf dei SSD kopieren
Die SSD als Standarddrive für History einstellen
weiter laufen lassen.
Erstmal Stück für Stück (ich lese während ich tippe!):
@klassisch:Sieht gleich viel freundlicher aus `
Gut:
@klassisch:Model: Xunlong Orange Pi Plus 2E `
Jetzt wurde die Hardware auch richtig erkannt.wird die eMMC in Betrieb genommen, formatiert und BS übertragen. SD-Card kann dann raus.
Ab jetzt geht es auch headless über SSH `
Habe ich mich beim Cubie noch nicht getraut. Bei 16gb nand aber die beste Wahl vor allem für die Geschwindigkeit.Ist da etwas schief gelaufen und muß ich noch etwas korigieren? `
Nein, das ist "normal" :DNa dann mal herzlichen Glückwunsch!
So kenne ich armbian.
Das NAND müsste wesentlich stabiler sein als eine SD-Karte und vor allem deutlich schneller.
Schließlich sind die Internen Speicher bei Tablets und Handys so aufgebaut und da werden auch duernd Daten geschoben.
Ich würde als erstes den rpi2 Adapter installieten, auch wenn es erst mal Fehlermeldungen gibt, und die CPU Temperatur loggen.
Viel Spaß damit
Nein, das ist "normal" :D ` Vielen Dank, hat mich irritiert
@Homoran:Ich würde als erstes den rpi2 Adapter installieten, auch wenn es erst mal Fehlermeldungen gibt, und die CPU Temperatur loggen. ` Habe jetzt zuerst mechanische Arbeiten vorgenommen; ordentliche Versorgung; provisorisches Gehäuse, Kühlkörper zugeschnitten und aufgeklebt. Hat sich offensichtlich gelohnt, denn der RPi Adapter sagt bei der Temp 0,03 und das bei ca. 17°C ambient. Scheint ein Peltier Elemewnt zu sein :D .
Kühlkörper: https://de.aliexpress.com/item/Black-Co … Title=true
Jetzt gehts an die SSD - oder raus und rumradeln.
SSD: KingDian S100+ bei gearbest gekauft
Allerdings zickt bei meinen Produktiv-ioBroker das Backup.
Hat sich offensichtlich gelohnt, denn der RPi Adapter sagt bei der Temp 0,03 und das bei ca. 17°C ambient. Scheint ein Peltier Elemewnt zu sein . `
Ok, dann gehört er zu den Kandidaten bei denen der Adapter modifiziert werden muss :(Faktor 1000, also im niedrigen 30° Bereich.
Wenn du willst sage ich dir wie.
Wofür willst du ei e SSD bei 16GB NAND?
Faktor 1000, also im niedrigen 30° Bereich. `
26°C sagte er beim Booten
@Homoran:Wenn du willst sage ich dir wie. `
Wenn es Dir nicht zu viel Mühe macht
@Homoran:Wofür willst du ei e SSD bei 16GB NAND? `
War im Zulauf, ursprünglich für den RasPi geplant als Ersatz für den USB Stick für History.Ich will die History Dtaen auf FAT und einen externen LW haben.
Mein Pi ist wieder hin. Hat kein Backup mehr gemacht, dann habe ich ihn mit shutdown offiziell runtergefahren, aber er ist nicht mehr hochgekommen.
Wie gut, daß ich History noch auf dem Stick habe.
Jetzt nehme ich halt die kleine SSD für die History-Daten.
Und bevor ich nicht weiß, ob der OPi zuverlässiger ist als die RasPis bleibt das erst mal extern.
Wenn es Dir nicht zu viel Mühe macht `
Keineswegs! Ich habe mich über diesen Adapter versucht in javascript einzuarbeiten und je nach Hardware diverse Änderungen eingebaut. Habe sogar schon versucht einen Pine64 Adapter zu bauen, der lief solange bis ich übermütig wurde und ihm noch die Konfiguration verpassen wollte.Im Moment spiele ich mit vielen verschiedenen Hardwaredaten und versuche an diese heranzukommen z.B. beim Cubietruck die Festplattenkapazität und der HDD Name und Temp.
Wenn ich dann mal irgendwann js kapiere wird es vielleicht auch von mir einen Adapter geben :lol:
Reicht es heute abend wenn ich am PC bin?
Reicht es heute abend wenn ich am PC bin? ` Es eilt nicht. Mein taktiles Humanthermometer sagt "noch alles kühl" und ansonsten gäbe es noch genügend messfähige HW. Der Kühlkörper ist recht formatfüllend und deckt die RAMs auch mit Hier und da gesägt und gefeilt und die Bauteile drunter mit Kaptonband abgeklebt. Sollte funktionieren.
Unter Objekte gibt es eine Karteikarte rax (nur für experten). Warscheinlich muß man da was rechnen und ändern.
Bin jetzt so weit umgezogen und starte gerade History neu. Dann mal beobachten, ob alles schön aufgezeichnet wird.
Vis scheint zu laufen.
Ich hoffe, das Teil läuft stabiler als der RasPi.
Es scheint jetzt einiges zu laufen. Bei den Reitern HMM und terminal.0 bekomme ich Fehlermeldungen aber ansonsten sieht es auf den ersten Blick nicht schlecht aus.
So da bin ich wieder.
Solltest du noch Fehlermeldungen im log zum rpi2 haben wäre das jetzt die Gelegenheit dies direkt mit zu ändern.
Du editierst die Datei /opt/iobroker/node_modules/iobroker.rpi2/io-package.json
in Zeile 180 löschst du die /1000
"temperature": { "soc_temp": { "command": "cat /sys/devices/virtual/thermal/thermal_zone0/temp", "regexp": "(.*)", "post": "$1/1000" }Dann schreibst du die Datei zurück, löschst deine Instanz, gehst auf die Konsole und machst ein
sudo iobroker stop rpi2 sudo iobroker upload rpi2 sudo iobroker start rpi2dann installierst du die Instanz neu
Ah, habs verstanden, das ist der RPi2 Monitor
die
sudo iobroker stop rpi2 sudo iobroker start rpi2hat es bei mir gar nicht mehr gebraucht, weil ich ja die Instanz per Browser schon gelöscht habe und per Admin neu angelegt habe.
sudo iobroker upload rpi2 ````war wohl essentiell `Jedenfalls zeigte er eben 31, jetzt nur noch 26 an. Wahrscheinlich langweilt er sich…
Reicht ja auch. Die in den Halbleitern integrierten Sensoren sind ohnehin nicht so genau.
Vielen Dank nochmals!
Gesendet von meinem ZTE A2016 mit Tapatalk
Schlechte Neuigkeiten!
Opi ist heute Nacht vom Netz gegangen und scheint auch nicht mehr hochzufahren.
Keine Reaktion auf Browser, Putty, Winscp. Die Fritte listet ihn unter ungenutzte Verbindungen.
Gerade solche Sachen wollte ich vermeiden.
