  4. Probleme beim Sichern von Javascript mit Backitup
    1.7k
  • Weihnachtsangebot 2025! 🎄
    2.1k
10 Beiträge 4 Kommentatoren 732 Aufrufe 3 Watching
  • F Offline
    Franzosenfranz
    Hallo Zusammen,
    nach dem ich nun alle Lösungansätze aus deisem Forum durch habe, weis ich nicht mehr weiter.
    Bei mir bleibt Backitup auch immer beim Sichern von Javascript hängen:
    Started iobroker ...
    [DEBUG] [mount] - noserverino option: true
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,noserverino,rw,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.153.101/fritz.nas/iobroker_backup/backupDir /opt/iobroker/backups"
    [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,noserverino,rw,file_mode=0777,dir_mode=0777 //192.168.153.101/fritz.nas/iobroker_backup/backupDir /opt/iobroker/backups"
    [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=iobroker,password=****,noserverino,rw,file_mode=0777,dir_mode=0777 //192.168.153.101/fritz.nas/iobroker_backup/backupDir /opt/iobroker/backups
    Unable to resolve /opt/iobroker/backups to canonical path: No such file or directory
    [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount -t cifs -o username=iobroker,password=****,noserverino,rw,file_mode=0777,dir_mode=0777 //192.168.153.101/fritz.nas/iobroker_backup/backupDir /opt/iobroker/backups
    [DEBUG] [iobroker] - host.raspberrypi 4423 states saved
    [DEBUG] [iobroker] - host.raspberrypi 4082 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2022_01_30-15_29_52_backupiobroker.tar.gz
    [DEBUG] [iobroker] - done
    [DEBUG] [historyDB] - compress from historyDB started ...
    [DEBUG] [historyDB] - Packed 18MB so far...
    [DEBUG] [historyDB] - Packed 43MB so far...
    [DEBUG] [historyDB] - Packed 53MB so far...
    [DEBUG] [historyDB] - Backup created: /opt/iobroker/backups/historyDB_2022_01_30-15_30_00_backupiobroker.tar.gz
    [DEBUG] [historyDB] - done
    [DEBUG] [javascripts] - Try deleting the old javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
    [DEBUG] [javascripts] - old javascript_tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
    [DEBUG] [javascripts] - Created javascript_tmp directory
    [DEBUG] [javascripts] - found Script: Licht_über_Kafffeemaschine2
    [DEBUG] [javascripts] - found Script: Licht_Haustür_über_Gartentür_und_Tore
    [DEBUG] [javascripts] - found Script: Licht_Abfahrt_über_Tor_Abfahrt
    [DEBUG] [javascripts] - found Script: Astro
    [DEBUG] [javascripts] - Packed 0MB so far...
    MOD-EDIT: Code in codetags gesetzt!
    Wenn ich Javascript aus der Sicherung herausnehme, läuft das Backup ohne Probleme.
    Plattform linux
    Betriebssystem linux
    Architektur arm
    CPUs 4
    Geschwindigkeit 900 MHz
    Modell ARMv7 Processor rev 3 (v7l)
    RAM 7.69 GB
    System-Betriebszeit 94 T. 07:23:16
    Node.js v14.18.3
    NPM 6.14.15
    Datenträgergröße 58.25 GB
    freier Festplattenspeicher 50.96 GB
    Anzahl der Adapter 386
    Betriebszeit 7 T. 23:48:16
    Aktive Instanzen 16
    location/opt/iobroker/
    Hostname raspberrypi
    Sicherung läuft auf eien USB-HDD am Fritzbox USB Port (FritzNAS)
    Hat jemand eine Idee?
    Thomas BraunT HomoranH U 3 Antworten Letzte Antwort
    • F Franzosenfranz
      Hallo Zusammen,
      Plattform linux
      Architektur arm
      CPUs 4
      RAM 7.69 GB
      Node.js v14.18.3
      NPM 6.14.15
      Aktive Instanzen 16
      @franzosenfranz sagte in Probleme beim Sichern von Javascript mit Backitup:
      Bitte setz den Auszug aus der Konsole in CodeTags.
      Was liefert
      ls -l /opt/iobroker/backups
      zurück?
      Zeit für ein Upgrade...
      sudo apt update
      sudo apt full-upgrade
      sudo reboot
      F 1 Antwort Letzte Antwort
      • F Franzosenfranz
        Hallo Zusammen,
        Plattform linux
        Architektur arm
        CPUs 4
        RAM 7.69 GB
        Node.js v14.18.3
        NPM 6.14.15
        Aktive Instanzen 16
        HomoranH Offline
        HomoranH Offline
        noserverino
        hast du die Option Serverino auf false?
        bei der Fritte muss die aktiviert sein
          noserverino
          • Thomas BraunT Online
            Sind die cifs-utils installiert?
            apt policy cifs-utils
            • F Franzosenfranz
              Hallo Zusammen,
              Plattform linux
              Architektur arm
              CPUs 4
              RAM 7.69 GB
              Node.js v14.18.3
              NPM 6.14.15
              Aktive Instanzen 16
              U Offline
              U Offline
              UV-on-fire
              schrieb am zuletzt editiert von UV-on-fire
              @franzosenfranz
              Hatte exakt das gleiche Problem. Lösung siehe hier
              https://forum.iobroker.net/topic/51365/gelöst-backitup-hängt-bei-javascript-backup?_=1643555483582
              Hups, gerade gesehn das weiter oben schon der Hinweis auf noserverino steht. Sorry für den doppel Post.
                Was liefert
                zurück?
                sudo apt update
                sudo reboot
                Franzosenfranz
                BackItUp:
                Eine neue iobroker Sicherung wurde am 31. Januar 2022 um 08:50 Uhr erstellt, und unter //192.168.153.101/fritz.nas/iobroker_backup/backupDir gespeichert.
                :+1:
                Danke für die Unterstützung. Nach dem upgrade lief es dann.
                Franz
                  @franzosenfranz
                  Welches Upgrade?
                  Hast du cifs-utils nachinstalliert?
                    @franzosenfranz
                    Welches Upgrade?
                    Franzosenfranz
                    Ich habe Linux auf einen aktuellen Stand gebracht.
                    cifs-utils war schon installiert:
                    cifs-utils:
                    Installiert: 2:6.8-2
                    Installationskandidat: 2:6.8-2
                    Versionstabelle:
                    *** 2:6.8-2 500
                      @franzosenfranz
                      Ein System 'auf dem letzten Stand' setzte ich eigentlich voraus.
                      32.6k
                      82.1k
