  4. help please - iobroker läuft nicht
    5.1k
78 Beiträge 5 Kommentatoren 11.7k Aufrufe 4 Beobachtet
    @pahan
    ps aux | grep io
    Statt dir besser
    ls -l
    verwenden.
    which iobroker
    liefert?
    Pahan
    @thomas-braun sagte in help please - iobroker läuft nicht:
    ps aux | grep io
    pi@raspberrypi:~ $ ps aux | grep io
    root        13  0.0  0.0      0     0 ?        S    21:44   0:00 [migration/0]
    root        16  0.0  0.0      0     0 ?        S    21:44   0:00 [migration/1]
    root        21  0.0  0.0      0     0 ?        S    21:44   0:00 [migration/2]
    root        26  0.0  0.0      0     0 ?        S    21:44   0:00 [migration/3]
    root        59  0.0  0.0      0     0 ?        I<   21:44   0:00 [blkcg_punt_bio]
    root        63  0.0  0.0      0     0 ?        I<   21:44   0:00 [rpciod]
    root        65  0.0  0.0      0     0 ?        I<   21:44   0:00 [xprtiod]
    root        67  0.0  0.0      0     0 ?        I<   21:44   0:00 [nfsiod]
    root        76  0.0  0.0      0     0 ?        I<   21:44   0:00 [DWC Notificatio]
    message+   373  0.0  0.0   6712  3424 ?        Ss   21:45   0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
    grafana    494  0.1  1.0 948740 43216 ?        Ssl  21:45   0:04 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --pidfile=/var/run/grafana/grafana-server.pid --packaging=deb cfg:default.paths.logs=/var/log/grafana cfg:default.paths.data=/var/lib/grafana cfg:default.paths.plugins=/var/lib/grafana/plugins cfg:default.paths.provisioning=/etc/grafana/provisioning
    pi         865  0.0  0.0   7348   516 pts/0    S+   22:31   0:00 grep --color=auto io
    pi@raspberrypi:~ $
    • P Pahan
      ps aux | grep io
      pi@raspberrypi:~ $
      @pahan
      Da läuft halt gar nix.
        @pahan
        ps aux | grep io
        Statt dir besser
        ls -l
        verwenden.
        which iobroker
        liefert?
        Pahan
        ls -l
        pi@raspberrypi:/opt/iobroker $ ls -l
        total 500
        drwxrwxr-x+   2 iobroker iobroker   4096 Jan 13 21:32 backups
        -rwxrwxrwx+   1 iobroker iobroker    861 Jan 26 21:29 INSTALLER_INFO.txt
        lrwxrwxrwx    1 iobroker iobroker     22 Jan 26 21:29 iob -> /opt/iobroker/iobro                      ker
        -rwxr-xr-x+   1 iobroker iobroker      0 Jan 26 21:29 iobroker
        drwxrwxr-x+   7 iobroker iobroker   4096 Jan 22 12:14 iobroker-data
        drwxrwxr-x+   2 iobroker iobroker   4096 Jan 26 21:25 log
        drwxrwxr-x+ 855 iobroker iobroker  32768 Jan 19 22:50 node_modules
        -rw-rwxr--+   1 iobroker iobroker   2181 Jan 19 22:50 package.json
        -rw-rwxr--+   1 iobroker iobroker 445073 Jan 19 22:50 package-lock.json
        -rw-rwxr--+   1 iobroker iobroker   5693 Jan 13 21:35 reinstall.js
        which iobroker
        liefert
        /usr/bin/iobroker
        • P Pahan
          ls -l
          total 500
          which iobroker
          liefert
          /usr/bin/iobroker
          @pahan
          cd /opt/iobroker
          sudo -H -u iobroker npm install iobroker.js-controller
          P 1 Antwort Letzte Antwort
            @pahan
            cd /opt/iobroker
            Pahan
            @pahan
            cd /opt/iobroker
            liefert:
            pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
            npm ERR! code ENOSPC
            npm ERR! syscall write
            npm ERR! errno -28
            npm ERR! nospc ENOSPC: no space left on device, write
            npm ERR! nospc There appears to be insufficient space on your system to finish.
            npm ERR! nospc Clear up some disk space and try again.
            ...wobei es ein Pi4 mit 4GB und 32GB Speicherkarte ist und es vorher reichlich Platz vorhanden war. Kann mir die Fehlermeldung nicht erklären
            • P Pahan
              @pahan
              cd /opt/iobroker
              liefert:
              npm ERR! errno -28
              @pahan
              df -h
                @pahan
                df -h
                Pahan
                @pahan
                df -h
                pi@raspberrypi:/opt/iobroker $ df -h
                Filesystem      Size  Used Avail Use% Mounted on
                /dev/root        15G   15G     0 100% /
                devtmpfs        1.8G     0  1.8G   0% /dev
                tmpfs           1.9G     0  1.9G   0% /dev/shm
                tmpfs           1.9G  8.5M  1.9G   1% /run
                tmpfs           5.0M  4.0K  5.0M   1% /run/lock
                tmpfs           1.9G     0  1.9G   0% /sys/fs/cgroup
                /dev/mmcblk0p1  253M   49M  204M  20% /boot
                tmpfs           384M     0  384M   0% /run/user/1000
                scheint eine 16GB zu sein, die zu 100% voll ist? Nicht schlecht... War vorher definitiv nicht
                • P Pahan
                  @pahan
                  df -h
                  @pahan sagte in help please - iobroker läuft nicht:
                  Nee, vorher war sie leerer...
                  Musst du Mal mit du oder ncdu schauen, was da aus dem Ruder gelaufen ist. Kameras am Start?
                    Pahan
                    Kameras laufen nicht auf dem Raspi. Es war grundsätzlich alles OK. Lief alles gut und schnell, bis eben auf den UPNP adapter. Der produzierte ständig Fehlermeldungen. Diesen habe ich deinstalliert und seitdem ging es los. Da wurde wohl viel Datenmüll generiert, oder? Soll ich daraufmal schauen und ggf. irgendwelche kryptischen Sachen über den Windows PC löschen ?
                    • P Pahan
                      Was würdest du denn als kryptisch bezeichnen?
                        Pahan
                        weiß ich noch nicht, aber ich vermute mal irgendeine übergroße Datei, die seit dem Ausfall erstellt wurde....nur so als Idee?
                        • P Pahan
                          @pahan
                          ncdu
                          ist installiert? Dann schau damit nach.
                            @pahan
                            ncdu
                            Pahan
                            @pahan
                            ncdu
                            --- /opt/iobroker ------------------------------------------------------------------------------------
                                6.6 GiB [##########] /log
                              755.2 MiB [#         ] /node_modules
                              346.8 MiB [          ] /iobroker-data
                               80.8 MiB [          ] /backups
                              436.0 KiB [          ]  package-lock.json
                                8.0 KiB [          ]  reinstall.js
                                4.0 KiB [          ]  package.json
                                4.0 KiB [          ]  INSTALLER_INFO.txt
                                4.0 KiB [          ]  .npmrc
                            @   0.0   B [          ]  iob
                                0.0   B [          ]  iobroker
                            • P Pahan
                              @pahan
                              ncdu
                                  4.0 KiB [          ]  .npmrc
                              @   0.0   B [          ]  iob
                                  0.0   B [          ]  iobroker
                              @pahan
                              Wie erwartet sind dir da die Log Files um die Ohren geflogen. Lösch die mal. Zumindest die ältesten. Und dann musst du mal reinschauen was dein System da so treibt.
                                @pahan
                                Pahan
                                @pahan
                                sieht so ja, ja...
                                wie lösche ich am besten eine bestimmte Datei und welche hiervon würde sich hierzu eignen?
                                pi@raspberrypi:/opt/iobroker/log $ ls -l
                                total 6893644
                                -rw-rwxr--+ 1 iobroker iobroker      90160 Jan 16 00:00 iobroker.2022-01-15.log.gz
                                -rw-rwxr--+ 1 iobroker iobroker      87270 Jan 17 00:00 iobroker.2022-01-16.log.gz
                                -rw-rwxr--+ 1 iobroker iobroker      96656 Jan 18 00:00 iobroker.2022-01-17.log.gz
                                -rw-rwxr--+ 1 iobroker iobroker      98687 Jan 19 00:00 iobroker.2022-01-18.log.gz
                                -rw-rwxr--+ 1 iobroker iobroker     143200 Jan 20 00:00 iobroker.2022-01-19.log.gz
                                -rw-rwxr--+ 1 iobroker iobroker     136465 Jan 21 00:00 iobroker.2022-01-20.log.gz
                                -rw-rwxr--+ 1 iobroker iobroker 3811752771 Jan 21 23:59 iobroker.2022-01-21.log
                                -rw-rwxr--+ 1 iobroker iobroker   73853799 Jan 22 00:06 iobroker.2022-01-21.log.gz
                                -rw-rwxr--+ 1 iobroker iobroker 3172790272 Jan 22 23:59 iobroker.2022-01-22.log
                                -rw-rwxr--+ 1 iobroker iobroker          0 Jan 23 23:59 iobroker.2022-01-23.log
                                -rw-rwxr--+ 1 iobroker iobroker          0 Jan 24 23:59 iobroker.2022-01-24.log
                                -rw-rwxr--+ 1 iobroker iobroker          0 Jan 25 23:59 iobroker.2022-01-25.log
                                -rw-rwxr--+ 1 iobroker iobroker          0 Jan 26 21:25 iobroker.2022-01-26.log
                                -rw-rwxr--+ 1 iobroker iobroker          0 Jan 23 00:00 iobroker-audit.json
                                lrwxrwxrwx  1 iobroker iobroker         23 Jan 26 21:25 iobroker.current.log -> iobroker.2022-01-26.log
                                wahrscheinlich die mit 3811752771 bytes?
                                Und was kann ich danach machen? Wieder wie damals "iobroker add admin" ?
                                • P Pahan
                                  @pahan
                                  sieht so ja, ja...
                                  total 6893644
                                  @pahan
                                  Lösch das dickste Ding.
                                  sudo -u iobroker rm /opt/iobroker/log/iobroker.2022-01-21.log
                                  An dem Tag ist dir da was um die Ohren geflogen.
                                  Schau dann in das iobroker.2022-01-21.log.gz rein. Da steht der Verlauf drin.
                                  Danach musste die Kiste auch wieder Luft zum Atmen haben. Mal neu starten.
                                    @pahan
                                    @Pahan
                                    ab dem 21. ist dein log explodiert. Hast fuvda ein paar Instanzen auf debug gestellt.
                                    stell sie wieder zurück. Ab dem 23. war wohl die Karte voll, dass die logs nicht mehr drauf passten
                                    • P Offline
                                      Pahan
                                      Hallo Leute,
                                      habe die größte log-Datei gelöscht, Pi rebootet,
                                      jedoch keine Änderung spürbar. Ich bin nach wie vor bei Schritt 1:
                                      Alle diese Eingaben :
                                      iobroker fix
                                      iobroker add admin
                                      iobroker restart
                                      iobroker list adapters
                                      iobroker list instances
                                      iobroker status
                                      liefern absolut keine Reaktion
                                      d.h. ich bin wohl noch weit entfernt, etwas von debug wegzustellen :(
                                      • P Pahan
                                        Hallo Leute,
                                        iobroker fix
                                        iobroker add admin
                                        iobroker restart
                                        iobroker status
                                        @pahan
                                        cd /opt/iobroker
                                          @pahan
                                          cd /opt/iobroker
                                          Pahan
                                          @pahan
                                          cd /opt/iobroker
                                          sorry, hatte ich vergessen. Klar, hattest du ja oben schon erwähnt.
                                          Diese Eingabe liefert folgendes:
                                          > iobroker.js-controller@3.3.22 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                                          > node lib/preinstallCheck.js
                                          NPM version: 6.14.15
                                          > iobroker.js-controller@3.3.22 install /opt/iobroker/node_modules/iobroker.js-controller
                                          > node iobroker.js setup first
                                          object _design/custom updated
                                          object _design/system updated
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
                                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                          + iobroker.js-controller@3.3.22
                                          updated 4 packages in 103.877s
                                          111 packages are looking for funding
                                            run `npm fund` for details
