  4. Test PV Forecast Adapter
forecastphotovoltaik
881 Beiträge 114 Kommentatoren 376.0k Aufrufe 108 Beobachtet
  • S Sputnik24
    @patrickwalther said in Test PV Forecast Adapter:
    @sputnik24 Da kommt bald ein Update.
    Gibt es bei deinem Fall Fehlermeldungen?
    Gestern wieder der Fall, summary hat 0 angezeigt, die beiden Anlagen hatten aber Werte. Hier die Logs. Die paarweise Meldung summary.power_kw: [0,0,0,0,0] und summary.power_kwh: [0,0,0,0,0] kommt fortlaufend jede Minute.
    2022-01-21 12:01:03.660 - debug: pvforecast.0 (27391) pvname: Sued,Nord,,,
    2022-01-21 12:01:03.660 - debug: pvforecast.0 (27391) ThisUrl https://api.forecast.solar/estimate/xxx/xxx/24/0/5.625
    2022-01-21 12:01:35.169 - error: pvforecast.0 (27391) Axios Error Error: Request failed with status code 502
    2022-01-21 12:01:35.171 - debug: pvforecast.0 (27391) ThisUrl https://api.forecast.solar/estimate/xxx/xxx/24/180/5.25
    2022-01-21 12:02:00.033 - debug: pvforecast.0 (27391) summary.power_kw: [0,0,0,0,0]
    2022-01-21 12:02:00.034 - debug: pvforecast.0 (27391) summary.power_kwh : [0,0,0,0,0]
    2022-01-21 12:02:06.649 - error: pvforecast.0 (27391) Axios Error Error: Request failed with status code 502
    2022-01-21 12:02:06.649 - debug: pvforecast.0 (27391) ThisUrl
    2022-01-21 12:02:06.650 - debug: pvforecast.0 (27391) ThisUrl
    2022-01-21 12:02:06.651 - debug: pvforecast.0 (27391) watts_tag_plants[0]0
    2022-01-21 12:02:06.651 - debug: pvforecast.0 (27391) watts_tag_plants[1]0
    2022-01-21 12:02:06.651 - debug: pvforecast.0 (27391) watts_tag_plants[2]0
    2022-01-21 12:02:06.652 - debug: pvforecast.0 (27391) watts_tag_plants[3]0
    2022-01-21 12:02:06.652 - debug: pvforecast.0 (27391) watts_tag_plants[4]0
    2022-01-21 12:02:06.652 - debug: pvforecast.0 (27391) watts_tomorrow_plants[0]0
    2022-01-21 12:02:06.653 - debug: pvforecast.0 (27391) watts_tomorrow_plants[1]0
    2022-01-21 12:02:06.653 - debug: pvforecast.0 (27391) watts_tomorrow_plants[2]0
    2022-01-21 12:02:06.653 - debug: pvforecast.0 (27391) watts_tomorrow_plants[3]0
    2022-01-21 12:02:06.654 - debug: pvforecast.0 (27391) watts_tomorrow_plants[4]0
    2022-01-21 12:02:06.654 - debug: pvforecast.0 (27391) summary.power_day_kWh:0 summary.power_day_tomorrow_kWh: 0
    2022-01-21 12:02:06.660 - debug: pvforecast.0 (27391) 1.transfer: success
    2022-01-21 12:02:06.660 - debug: pvforecast.0 (27391) 1.place: xxx, xxx, Baden-Württemberg, DE
    2022-01-21 12:02:06.672 - debug: pvforecast.0 (27391) 2.transfer: success
    2022-01-21 12:02:06.673 - debug: pvforecast.0 (27391) 2.place: xxx, xxx, Baden-Württemberg, DE
    2022-01-21 12:02:06.675 - debug: pvforecast.0 (27391) vorübergabe_power_kw[0]: 0
    2022-01-21 12:02:06.675 - debug: pvforecast.0 (27391) vorübergabe_power_kw[1]: {"2022-01-21 07:59:00":0,"2022-01-21 08:30:00":180,"2022-01-21 09:00:00":891,"2022-01-21 10:00:00":2265,"2022-01-21 11:00:00":2512,"2022-01-21 12:00:00":2458,"2022-01-21 13:00:00":2489,"2022-01-21 14:00:00":1883,"2022-01-21 15:00:00":1188,"2022-01-21 16:00:00":546,"2022-01-21 17:00:00":145,"2022-01-21 17:05:00":28,"2022-01-21 17:10:00":0,"2022-01-22 07:58:00":0,"2022-01-22 08:29:00":90,"2022-01-22 09:00:00":444,"2022-01-22 10:00:00":679,"2022-01-22 11:00:00":819,"2022-01-22 12:00:00":881,"2022-01-22 13:00:00":828,"2022-01-22 14:00:00":766,"2022-01-22 15:00:00":616,"2022-01-22 16:00:00":389,"2022-01-22 17:00:00":99,"2022-01-22 17:06:00":23,"2022-01-22 17:11:00":0}
    2022-01-21 12:02:06.676 - debug: pvforecast.0 (27391) vorübergabe_power_kw[2]: {"2022-01-21 07:59:00":0,"2022-01-21 08:30:00":68,"2022-01-21 09:00:00":352,"2022-01-21 10:00:00":589,"2022-01-21 11:00:00":716,"2022-01-21 12:00:00":752,"2022-01-21 13:00:00":688,"2022-01-21 14:00:00":591,"2022-01-21 15:00:00":496,"2022-01-21 16:00:00":311,"2022-01-21 17:00:00":102,"2022-01-21 17:05:00":21,"2022-01-21 17:10:00":0,"2022-01-22 07:58:00":0,"2022-01-22 08:29:00":68,"2022-01-22 09:00:00":331,"2022-01-22 10:00:00":512,"2022-01-22 11:00:00":618,"2022-01-22 12:00:00":665,"2022-01-22 13:00:00":608,"2022-01-22 14:00:00":575,"2022-01-22 15:00:00":472,"2022-01-22 16:00:00":300,"2022-01-22 17:00:00":79,"2022-01-22 17:06:00":16,"2022-01-22 17:11:00":0}
    2022-01-21 12:02:06.676 - debug: pvforecast.0 (27391) vorübergabe_power_kw[3]: 0
    2022-01-21 12:02:06.676 - debug: pvforecast.0 (27391) vorübergabe_power_kw[4]: 0
    2022-01-21 12:02:06.678 - debug: pvforecast.0 (27391) write zero to everyhour
    2022-01-21 12:02:06.679 - debug: pvforecast.0 (27391) plant_d_everyhourfalse,false,false,false,false
    2022-01-21 12:03:00.104 - debug: pvforecast.0 (27391) summary.power_kw: [0,0,0,0,0]
    2022-01-21 12:03:00.105 - debug: pvforecast.0 (27391) summary.power_kwh : [0,0,0,0,0]
    2022-01-21 12:04:00.041 - debug: pvforecast.0 (27391) summary.power_kw: [0,0,0,0,0]
    2022-01-21 12:04:00.042 - debug: pvforecast.0 (27391) summary.power_kwh : [0,0,0,0,0]
    2022-01-21 12:05:00.035 - debug: pvforecast.0 (27391) summary.power_kw: [0,0,0,0,0]
    2022-01-21 12:05:00.036 - debug: pvforecast.0 (27391) summary.power_kwh : [0,0,0,0,0]
    Mal abgesehen davon: Frage an alle API Nutzer: Seit guter einer Woche sind die Werte faktisch nicht zu gebrauchen und liegen im Schnitt um den Faktor 2-3 daneben. Ist das bei euch auch so?
    JoergH
    #168
    @sputnik24 Ich tracke ja noch nicht so lange, aber bei mir sieht es ähnlich aus:
    • J JoergH
      Tudo
      #169
      Mal eine praktische Frage zur Verwendung der gelieferten stündlichen Werte:
      Ich möchte mittels Blockly herausfinden, zu welcher Zeit die höchste Erzeugung prognostiziert wird.
      Es müssen also alle Datenpunkte miteinander verglichen werden und als Ergebnis eine Uhrzeit ausgeworfen werden.
      Kann mir jemand einen Tipp geben, wie ich das machen kann?
      • T Tudo
        DiginixD Offline
        DiginixD Offline
        Diginix
        #170
        @tudo Du erstellst 2 Listen. Eine mit allen Uhrzeiten und eine mit allen Leistungswerten. Mit den Blockly Listenfunktionen suchst du dann den Maxwert in der Liste der Leistungswerte bzw. die Position des höchsten Wertes. Mit der Position bekommst du dann in der Liste mit den Zeiten den passenden Zeitpunkt.
        Als Quelle für die 2 Listen würde ich pvforecast.0.1.JSONTable nutzen. Vllt geht es auch noch eleganter mit Schleifen. Hab ich aber selbst noch nicht gemacht.
        @PatrickWalther
        Gerade fällt mir auf, dass bei mir alle states unterhalb pvforecast.0.1.everyhour_kw und pvforecast.0.summary.everyhour_kw 0 zeigen. In pvforecast.0.1.JSONTable sind aber Leistungswerte. Die komplette Tagesprognose selbst ist 5,8 kWh.
        ..:: So long! Tom ::..
        • P Offline
          PatrickWalther
          #171
          Test PV Forecast Adapter 0.1.6
          Veröffentlichungsdatum 23.01.2021
          Github Link https://github.com/Patrick-Walther/ioBroker.pvforecast
          Guten Abend,
          anbei die Version 0.1.6. diese Version beseitig die bisherigen Fehler einträge.
          Neu:
          Der Adapter aktualisert alle x Minuten(nach Adapter start) , einstellbar in den Settings, die Daten. Bitte diesen Wert eingeben.
          Viel Spaß beim Testen.
          Patrick
          • P PatrickWalther
            Guten Abend,
            Neu:
            Patrick
            DiginixD Offline
            DiginixD Offline
            Diginix
            #172
            @patrickwalther 0.1.6 hat mein System gerade komplett vor den Baum gefahren. 100% CPU und 3 MB Log in 1 Minute.
            Musste ihn hart abschießen um die VM nicht ganz killen zu müssen. Hatte zeitweise nicht mal ein Prompt.
            Hier mal ein Auszug aus dem Log. Alle 20.000 Zeilen sprengen hier den Rahmen.
            1080 mal im Log:
            pvforecast.0 (2065410) Axios Error Error: Request failed with status code 429
            2022-01-23 20:33:27.838  - error: pvforecast.0 (2065410) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-01-23 20:33:27.838  - error: pvforecast.0 (2065410) unhandled promise rejection: DB closed
            2022-01-23 20:33:27.838  - error: pvforecast.0 (2065410) Error: DB closed
                at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:183:25)
                at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:150:20)
                at Object.onceWrapper (events.js:520:26)
                at Socket.emit (events.js:400:28)
                at TCP.<anonymous> (net.js:686:12)
            2022-01-23 20:33:27.839  - error: pvforecast.0 (2065410) DB closed
            Für alle Uhrzeiten und Knoten jeweils:
            pvforecast.0 (2065410) Cannot check object existence of "pvforecast.0.summary.everyhour_kw.10:00:00": Connection is closed.
            2022-01-23 20:33:33.780  - error: pvforecast.0 (2065410) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2022-01-23 20:33:33.780  - error: pvforecast.0 (2065410) unhandled promise rejection: Could not check object existence of pvforecast.0.summary.everyhour_kw.10:00:00: Cannot check object existence of "pvforecast.0.summary.everyhour_kw.10:00:00": Connection is closed.
            2022-01-23 20:33:33.780  - error: pvforecast.0 (2065410) Error: Could not check object existence of pvforecast.0.summary.everyhour_kw.10:00:00: Cannot check object existence of "pvforecast.0.summary.everyhour_kw.10:00:00": Connection is closed.
                at Object.maybeCallbackWithError (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:2335:17)
                at Adapter.setObjectNotExists (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3403:30)
                at runMicrotasks (<anonymous>)
                at processTicksAndRejections (internal/process/task_queues.js:95:5)
            2022-01-23 20:33:33.780  - error: pvforecast.0 (2065410) Could not check object existence of pvforecast.0.summary.everyhour_kw.10:00:00: Cannot check object existence of "pvforecast.0.summary.everyhour_kw.10:00:00": Connection is closed.
            Und dann noch 1000de Zeilen:
            2022-01-23 20:35:11.975  - error: pvforecast.0 (2065621) Axios Error Error: Request failed with status code 429
            2022-01-23 20:35:11.976  - error: pvforecast.0 (2065621) Axios Error Error: Request failed with status code 429
            2022-01-23 20:35:11.982  - warn: pvforecast.0 (2065621) State "pvforecast.0.1.everyhour_kw.05:45:00" has no existing object, this might lead to an error in future versions
            2022-01-23 20:35:11.983  - warn: pvforecast.0 (2065621) State "pvforecast.0.1.everyhour_kw.05:45:00" has no existing object, this might lead to an error in future versions
            2022-01-23 20:35:11.983  - warn: pvforecast.0 (2065621) State "pvforecast.0.1.everyhour_kw.06:15:00" has no existing object, this might lead to an error in future versions
            2022-01-23 20:35:11.984  - warn: pvforecast.0 (2065621) State "pvforecast.0.1.everyhour_kw.06:15:00" has no existing object, this might lead to an error in future versions
            2022-01-23 20:35:11.984  - warn: pvforecast.0 (2065621) State "pvforecast.0.1.everyhour_kw.05:15:00" has no existing object, this might lead to an error in future versions
            2022-01-23 20:35:11.985  - warn: pvforecast.0 (2065621) State "pvforecast.0.1.everyhour_kw.05:15:00" has no existing object, this might lead to an error in future versions
            2022-01-23 20:35:11.986  - warn: pvforecast.0 (2065621) State "pvforecast.0.1.everyhour_kw.05:15:00" has no existing object, this might lead to an error in future versions
            2022-01-23 20:35:12.314  - warn: pvforecast.0 (2065621) State "pvforecast.0.summary.everyhour_kw.05:30:00" has no existing object, this might lead to an error in future versions
            2022-01-23 20:35:12.315  - warn: pvforecast.0 (2065621) State "pvforecast.0.summary.everyhour_kw.05:30:00" has no existing object, this might lead to an error in future versions
            2022-01-23 20:35:12.316  - warn: pvforecast.0 (2065621) State "pvforecast.0.summary.everyhour_kw.05:30:00" has no existing object, this might lead to an error in future versions
            2022-01-23 20:35:12.317  - warn: pvforecast.0 (2065621) State "pvforecast.0.summary.everyhour_kw.05:30:00" has no existing object, this might lead to an error in future versions
            2022-01-23 20:35:12.318  - warn: pvforecast.0 (2065621) State "pvforecast.0.summary.everyhour_kw.05:30:00" has no existing object, this might lead to an error in future versions
            2022-01-23 20:35:12.318  - warn: pvforecast.0 (2065621) State "pvforecast.0.summary.everyhour_kw.05:15:00" has no existing object, this might lead to an error in future versions
            2022-01-23 20:35:12.319  - warn: pvforecast.0 (2065621) State "pvforecast.0.summary.everyhour_kw.05:30:00" has no existing object, this might lead to an error in future versions
            2022-01-23 20:35:12.320  - warn: pvforecast.0 (2065621) State "pvforecast.0.summary.everyhour_kw.05:30:00" has no existing object, this might lead to an error in future versions
            2022-01-23 20:35:35.308  - warn: pvforecast.0 (2065621) State "pvforecast.0.1.everyhour_kw.05:15:00" has no existing object, this might lead to an error in future versions
            2022-01-23 20:35:35.517  - warn: pvforecast.0 (2065621) State "pvforecast.0.1.everyhour_kw.07:15:00" has no existing object, this might lead to an error in future versions
            2022-01-23 20:35:35.518  - warn: pvforecast.0 (2065621) State "pvforecast.0.1.everyhour_kw.07:15:00" has no existing object, this might lead to an error in future versions
            2022-01-23 20:35:35.518  - warn: pvforecast.0 (2065621) State "pvforecast.0.1.everyhour_kw.07:30:00" has no existing object, this might lead to an error in future versions
            2022-01-23 20:35:35.519  - warn: pvforecast.0 (2065621) State "pvforecast.0.1.everyhour_kw.06:15:00" has no existing object, this might lead to an error in future versions
            2022-01-23 20:35:35.523  - warn: pvforecast.0 (2065621) State "pvforecast.0.1.everyhour_kw.06:15:00" has no existing object, this might lead to an error in future versions
            P 1 Antwort Letzte Antwort
            • DiginixD Diginix
              1080 mal im Log:
              PatrickWalther
              #173
              @diginix sorry:-(
              Find ich komisch, hast du unter Config-> Settings die Zeitabfrage eingegeben?
              Sonstige Änderungen gemacht?
              Ich desinstalieren das auf meine zwei Pi nochmal und teste es.
              • P PatrickWalther
                @diginix sorry:-(
                DiginixD Offline
                DiginixD Offline
                Diginix
                #174
                @patrickwalther Da stand schon 60 min vorausgefüllt.
                Ich habe danach nur die Instanz von loglevel warn auf info gestellt, um mehr zu sehen. Der war ja warn damit mir das log durch die falschen Datentypen nicht vollgemüllt wird. Die kamen nun aber glaub auch wieder und auch für states alle 15 min, obwohl es doch nur noch volle Stunden geben sollte oder?
                Aktuell läuft die Instanz gar nicht bis noch jemand getestet hat oder du was findest. Brauche es ja nicht wirklich.
                • DiginixD Diginix
                  PatrickWalther
                  #175
                  @diginix ich guck morgen danach.
                  Hab meinen Pi jetzt auch ins Nirvana geschickt. Verstehe aber noch nicht wieso:-/
                  • P PatrickWalther
                    PatrickWalther
                    #176
                    @patrickwalther Habe noch zwei Änderungen vor gesehen, könnte das jemand Testen?
                    Habe nach mehrfacher Installation und Desinallation, den Fehler nicht mehr bekommen den diginix hatte.
                    Bitte den Adapter stoppen und eine zweite Instanz zum Testen installieren.
                    • DiginixD Offline
                      DiginixD Offline
                      Diginix
                      #177
                      @patrickwalther Die "neue" 0.1.6 sieht gut aus. Hab den gesamten Adapter inkl Instanz zuvor deinstalliert und dadurch eine komplett saubere Installation. Selbst auf Loglevel info kam tatsächlich bisher nur:
                      2022-01-24 15:46:48.031 - info: pvforecast.0 (2189705) starting. Version 0.1.6 in /opt/iobroker/node_modules/iobroker.pvforecast, node: v14.18.3, js-controller: 3.3.22
                      Also keinerlei Warnings oder Error beim Erzeugen der Objekte und der ersten Aktualisierung.
                      • DiginixD Diginix
                        PatrickWalther
                        #178
                        @diginix das freut, sorry das gestern dein System gegen die Wand gefahren ist.
                        • P PatrickWalther
                          DiginixD Offline
                          DiginixD Offline
                          Diginix
                          #179
                          @patrickwalther Ich konnte den Amoklauf ja noch rechtzeitig beenden. Vllt liefen auch durch den Wechsel des Loglevel 2 Instanzen. Das kann schon mal vorkommen. Aber das würde noch nicht erklären warum derart viel Alarm mit unterschiedlichen Meldungen kam. Spielt aber auch keine Rolle mehr, da es wahrs. wirklich ein individuelles lokales Problem war.
                          Bei mir sind allerdings weiterhin alle pvforecast.0.1.everyhour_kw.*** und pvforecast.0.summary.everyhour_kw.*** states 0 kW. Nur pvforecast.0.1.JSONTable enthält die stündlichen Werte.
                          Haken ist aber aktiv:
                          ioT4dbI 1 Antwort Letzte Antwort
                          • DiginixD Diginix
                            ioT4dbI Offline
                            ioT4dbI Offline
                            ioT4db
                            #180
                            Moin Zusammen,
                            ich teste den Adapter nun auch schon ein paar Tage, aber auch ich sehe, dass die Werte meistens, nicht immer, bis zu 10x zu groß angegeben werden.
                            Da ich auch die freie API-Abfrage verwende, frage ich mich, ob das tatsächlich Werte sind, die schon die Wettervorhersage mit berücksichtigen.
                            Auf der Webseite verstehe ich es jedenfalls so, dass die Wetterlage auch bei der freien Variante berücksichtigt wird. Ich hatte weiter oben irgendwo gelesen, dass jmd. genau das schonmal den Webseitenbetreiber gefragt hatte, aber noch auf Antwort wartet. Gibts da vlt. schon neue Infos?
                            @diginix
                            interessant. Bei mir ist es eher anders herum gewesen. Ich habe eben das Update auf die 0.1.6 gemacht und nun stehen auch Werte bei "everyhour" drin. In der Version vorher waren diese Werte bei mir immer 0, jedoch standen in der json, so wie bei Dir, Werten drin.
                            VG...
                            • P Offline
                              PatrickWalther
                              #181
                              @friesenjung Guten Morgen, das liegt daran, das ich gestern das Update hochgeladen habe;-). Allerdings hatte ich es hier noch nicht verkündet.
                              Das mit den zu hohen Werten stimmt, bisher gab es keine Antwort, soweit ich weiß.
                              • DiginixD Offline
                                DiginixD Offline
                                Diginix
                                #182
                                @patrickwalther Mit der neuen 0.1.6 habe ich nun auch Werte in pvforecast.0.*.everyhour_kw.
                                Pro Aktualisierung bekomme ich aber nun diese Fehlermeldungen:
                                2022-01-26 10:18:14.783 - warn: pvforecast.0 (258795) State "pvforecast.0.1.everyhour_kw.07:53:00" has no existing object, this might lead to an error in future versions
                                2022-01-26 10:18:14.828 - warn: pvforecast.0 (258795) State "pvforecast.0.summary.everyhour_kw.07:53:00" has no existing object, this might lead to an error in future versions
                                2022-01-26 10:18:14.832 - warn: pvforecast.0 (258795) State "pvforecast.0.1.everyhour_kw.07:57:00" has no existing object, this might lead to an error in future versions
                                2022-01-26 10:18:14.837 - warn: pvforecast.0 (258795) State "pvforecast.0.summary.everyhour_kw.07:57:00" has no existing object, this might lead to an error in future versions
                                2022-01-26 10:18:15.028 - warn: pvforecast.0 (258795) State "pvforecast.0.1.everyhour_kw.16:32:00" has no existing object, this might lead to an error in future versions
                                2022-01-26 10:18:15.074 - warn: pvforecast.0 (258795) State "pvforecast.0.summary.everyhour_kw.16:32:00" has no existing object, this might lead to an error in future versions
                                2022-01-26 10:18:15.078 - warn: pvforecast.0 (258795) State "pvforecast.0.1.everyhour_kw.17:04:00" has no existing object, this might lead to an error in future versions
                                2022-01-26 10:18:15.083 - warn: pvforecast.0 (258795) State "pvforecast.0.summary.everyhour_kw.17:04:00" has no existing object, this might lead to an error in future versions
                                Das sind krumme Uhrzeiten, evtl. die vom Sonnenauf/untergang?
                                Wobei es ja 2 vom Morgen und 2 vom Abend sind.
                                • P Offline
                                  PatrickWalther
                                  schrieb am zuletzt editiert von PatrickWalther
                                  #183
                                  @diginix das liegt daran dass, das erstellen länger braucht als die Daten zu schreiben, habe eine Timeout function eingeführt dir ich noch am Testen bin. Werde diese in den Einstellungen Anlegen, das es jeder für sich einstellen kann.
                                  Allerdings sollte er nur 15,30,45 Minuten zu lassen.
                                  Kannst du mir die Json zu Verfügung stellen?
                                  Legt er Datenpunkte an?
                                  • P PatrickWalther
                                    DiginixD Offline
                                    DiginixD Offline
                                    Diginix
                                    #184
                                    @patrickwalther Nein, es gibt nur diese in .1 und .summary. Das macht die Fehlermeldung noch etwas merkwürdiger.
                                    • DiginixD Diginix
                                      PatrickWalther
                                      #185
                                      @diginix Hast du einen API Key gekauft?
                                      Ansonsten ist es stündlich, ich versuche bis zum Wochenende den Code hochzuladen.
                                      • P PatrickWalther
                                        DiginixD Offline
                                        DiginixD Offline
                                        Diginix
                                        #186
                                        @patrickwalther Habe keinen API Key.
                                        • sonnenscheinS Offline
                                          sonnenschein
                                          schrieb am zuletzt editiert von sonnenschein
                                          #187
                                          Hallo Zusammen!
                                          Ich habe mir nun auch mal den Adapter in der v0.1.6 installiert. Unter den Objekten wurden auch die Datenpunkte angelegt.
                                          Im VIS habe ich es hinbekommen die json tabelle darzustellen. Das mit dem json Graph funzt schon nicht.
                                          Lieber würde ich mit Grafana die Daten zusammen mit meinen Istdaten aus der sql abfrage darstellen. Irgend wie stehe ich auf dem Schlauch und weiss nicht wie ich das anstellen soll?
                                          Die Darstellung wie bei Sputnik24wäre mein Ziel.
                                          Das ist ein Time Series Panel Grafana.
                                          Datenquelle MySQL
                                          SELECT
                                          (n.ts/1000) as time_sec,
                                          n.val as value,
                                          '°C' as metric
                                          FROM ts_number n
                                          WHERE $__unixEpochFrom()*1000<n.ts and $__unixEpochTo()*1000>n.ts and n.id = 55
                                          ORDER BY n.ts desc
                                          PlatformBetriebssystem:linux Architektur:arm64 CPUs:4 Geschwindigkeit:1800 MHz Modell:Cortex-A72
                                          RAM:3.7 GB System-Betriebszeit:00:19:02 Node.js:v20.18.0
                                          _nodeCurrent:20.18.0
                                          _npmCurrent:10.8.2
                                          Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.6.57-v8+
