  4. Test Adapter Mihome-vacuum v3.1.6 Next Generarition
    6.6k
1.2k Beiträge 100 Kommentatoren 503.3k Aufrufe 82 Beobachtet
  • MeistertrM Meistertr
    Maxim-777
    #583
    @meistertr
    hier ein debug, wenn S7 läuft, startet Adapter jede 5. Sekunde neu.
    Time difference between Mihome Vacuum and ioBroker: -1642491070 sec
    mihome-vacuum.1
    	28085	2022-01-18 21:37:04.960	debug	Receive <<< Helo <<< 213100200000000018cffd080000b832ffffffffffffffffffffffffffffffff
    mihome-vacuum.1
    	28085	2022-01-18 21:37:04.455	debug	MIIO RECIVE: {"id":31,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":101}
    mihome-vacuum.1
    	28085	2022-01-18 21:37:04.156	debug	Message= {"id":31,"method":"get_carpet_mode"}
    mihome-vacuum.1
    	28085	2022-01-18 21:37:04.155	info	create state for carpet_mode
    mihome-vacuum.1
    	28085	2022-01-18 21:37:04.153	debug	MIIO RECIVE: {"id":30,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"exe_time":100}
    mihome-vacuum.1
    	28085	2022-01-18 21:37:03.954	debug	Message= {"id":30,"method":"get_carpet_mode"}
    mihome-vacuum.1
    	28085	2022-01-18 21:37:03.953	debug	Startup: Delete setGetConsumable
    mihome-vacuum.1
    	28085	2022-01-18 21:37:03.953	debug	Startup: setGetConsumable Answer: true
    mihome-vacuum.1
    	28085	2022-01-18 21:37:03.952	debug	MIIO RECIVE: {"id":29,"result":[{"main_brush_work_time":672256,"side_brush_work_time":672256,"filter_work_time":294646,"filter_element_work_time":0,"sensor_dirty_time":85020,"dust_collection_work_times":0}],"exe_time":101}
    mihome-vacuum.1
    	28085	2022-01-18 21:37:03.754	debug	Message= {"id":29,"method":"get_consumable"}
    mihome-vacuum.1
    	28085	2022-01-18 21:37:03.753	debug	Startup: Delete setGetCleanSummary
    mihome-vacuum.1
    	28085	2022-01-18 21:37:03.753	debug	Startup: setGetCleanSummary Answer: true
    mihome-vacuum.1
    	28085	2022-01-18 21:37:03.751	debug	finish logs all [{"Datum":"18.1","Start":"21:22","Saugzeit":"1 min","Fläche":"2.27 m²","Error":0,"Ende":false},{"Datum":"18.1","Start":"20:51","Saugzeit":"0 min","Fläche":"0.3 m²","Error":0,"Ende":false},{"Datum":"18.1","Start":"20:40","Saugzeit":"1 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"18.1","Start":"11:16","Saugzeit":"29 min","Fläche":"33.44 m²","Error":0,"Ende":true},{"Datum":"18.1","Start":"10:38","Saugzeit":"37 min","Fläche":"39.28 m²","Error":0,"Ende":true},{"Datum":"16.1","Start":"20:18","Saugzeit":"35 min","Fläche":"34.85 m²","Error":0,"Ende":true},{"Datum":"16.1","Start":"12:25","Saugzeit":"31 min","Fläche":"38.02 m²","Error":0,"Ende":true},{"Datum":"16.1","Start":"11:36","Saugzeit":"40 min","Fläche":"40.06 m²","Error":0,"Ende":true},{"Datum":"14.1","Start":"11:57","Saugzeit":"42 min","Fläche":"38.09 m²","Error":0,"Ende":true},{"Datum":"14.1","Start":"10:20","Saugzeit":"42 min","Fläche":"39.27 m²","Error":0,"Ende":true},{"Datum":"13.1","Start":"11:37","Saugzeit":"38 min","Fläche":"38.98 m²","Error":0,"Ende":true},{"Datum":"11.1","Start":"19:53","Saugzeit":"60 min","Fläche":"38.96 m²","Error":0,"Ende":true},{"Datum":"11.1","Start":"10:01","Saugzeit":"17 min","Fläche":"5.73 m²","Error":0,"Ende":true},{"Datum":"11.1","Start":"09:08","Saugzeit":"11 min","Fläche":"8.65 m²","Error":0,"Ende":true},{"Datum":"10.1","Start":"23:59","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"10.1","Start":"22:33","Saugzeit":"32 min","Fläche":"25.72 m²","Error":0,"Ende":true},{"Datum":"10.1","Start":"20:20","Saugzeit":"33 min","Fläche":"26.4 m²","Error":0,"Ende":true},{"Datum":"10.1","Start":"19:59","Saugzeit":"19 min","Fläche":"25.92 m²","Error":0,"Ende":true},{"Datum":"9.1","Start":"21:12","Saugzeit":"30 min","Fläche":"32.92 m²","Error":0,"Ende":true},{"Datum":"8.1","Start":"14:44","Saugzeit":"36 min","Fläche":"40.24 m²","Error":0,"Ende":true}]
    mihome-vacuum.1
    	28085	2022-01-18 21:37:03.750	debug	MIIO RECIVE: {"id":28,"result":[{"begin":1641649453,"end":1641651611,"duration":2158,"area":40237500,"error":0,"complete":1,"start_type":2,"clean_type":1,"finish_reason":52,"dust_collection_status":0}],"exe_time":101}
    mihome-vacuum.1
    	28085	2022-01-18 21:37:03.550	debug	Message= {"id":28,"method":"get_clean_record","params":[1641649453]}
    mihome-vacuum.1
    	28085	2022-01-18 21:37:03.549	debug	MIIO RECIVE: {"id":27,"result":[{"begin":1641759125,"end":1641760941,"duration":1816,"area":32915000,"error":0,"complete":1,"start_type":1,"clean_type":1,"finish_reason":52,"dust_collection_status":0}],"exe_time":101}
    mihome-vacuum.1
    	28085	2022-01-18 21:37:03.248	debug	Message= {"id":27,"method":"get_clean_record","params":[1641759125]}
    mihome-vacuum.1
    	28085	2022-01-18 21:37:03.247	debug	MIIO RECIVE: {"id":26,"result":[{"begin":1641841190,"end":1641842317,"duration":1127,"area":25917500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}],"exe_time":100}
    mihome-vacuum.1
    	28085	2022-01-18 21:37:02.947	debug	Message= {"id":26,"method":"get_clean_record","params":[1641841190]}
    mihome-vacuum.1
    	28085	2022-01-18 21:37:02.946	debug	MIIO RECIVE: {"id":25,"result":[{"begin":1641842401,"end":1641844390,"duration":1989,"area":26402500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}],"exe_time":101}
    mihome-vacuum.1
    	28085	2022-01-18 21:37:02.645	debug	Message= {"id":25,"method":"get_clean_record","params":[1641842401]}
    mihome-vacuum.1
    	28085	2022-01-18 21:37:02.644	debug	MIIO RECIVE: {"id":24,"result":[{"begin":1641850432,"end":1641852357,"duration":1925,"area":25717500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}],"exe_time":100}
    mihome-vacuum.1
    	28085	2022-01-18 21:37:02.343	debug	Message= {"id":24,"method":"get_clean_record","params":[1641850432]}
    mihome-vacuum.1
    	28085	2022-01-18 21:37:02.342	debug	MIIO RECIVE: {"id":23,"result":[{"begin":1641855549,"end":1641856417,"duration":1,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":1,"finish_reason":60,"dust_collection_status":0}],"exe_time":101}
    mihome-vacuum.1
    	28085	2022-01-18 21:37:02.141	debug	Message= {"id":23,"method":"get_clean_record","params":[1641855549]}
    mihome-vacuum.1
    	28085	2022-01-18 21:37:02.140	debug	MIIO RECIVE: {"id":22,"result":[{"begin":1641888503,"end":1641889159,"duration":656,"area":8645000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}],"exe_time":101}
    mihome-vacuum.1
    	28085	2022-01-18 21:37:01.940	debug	Message= {"id":22,"method":"get_clean_record","params":[1641888503]}
    mihome-vacuum.1
    	28085	2022-01-18 21:37:01.939	debug	MIIO RECIVE: {"id":21,"result":[{"begin":1641891670,"end":1641892661,"duration":991,"area":5732500,"error":0,"complete":1,"start_type":1,"clean_type":1,"finish_reason":52,"dust_collection_status":0}],"exe_time":100}
    mihome-vacuum.1
    	28085	2022-01-18 21:37:01.644	debug	Message= {"id":21,"method":"get_clean_record","params":[1641891670]}
    mihome-vacuum.1
    	28085	2022-01-18 21:37:01.643	debug	MIIO RECIVE: {"id":20,"result":[{"begin":1641927202,"end":1641931502,"duration":3622,"area":38957500,"error":0,"complete":1,"start_type":1,"clean_type":1,"finish_reason":52,"dust_collection_status":0}],"exe_time":101}
    mihome-vacuum.1
    	28085	2022-01-18 21:37:01.346	debug	Message= {"id":20,"method":"get_clean_record","params":[1641927202]}
    mihome-vacuum.1
    	28085	2022-01-18 21:37:01.336	debug	MIIO RECIVE: {"id":19,"result":[{"begin":1642070229,"end":1642072485,"duration":2256,"area":38982500,"error":0,"complete":1,"start_type":1,"clean_type":1,"finish_reason":52,"dust_collection_status":0}],"exe_time":100}
    mihome-vacuum.1
    	28085	2022-01-18 21:37:01.034	debug	Message= {"id":19,"method":"get_clean_record","params":[1642070229]}
    mihome-vacuum.1
    	28085	2022-01-18 21:37:01.033	debug	MIIO RECIVE: {"id":18,"result":[{"begin":1642152056,"end":1642154633,"duration":2512,"area":39267500,"error":0,"complete":1,"start_type":1,"clean_type":1,"finish_reason":52,"dust_collection_status":0}],"exe_time":101}
    mihome-vacuum.1
    	28085	2022-01-18 21:37:00.832	debug	Message= {"id":18,"method":"get_clean_record","params":[1642152056]}
    mihome-vacuum.1
    	28085	2022-01-18 21:37:00.832	debug	MIIO RECIVE: {"id":17,"result":[{"begin":1642157827,"end":1642160363,"duration":2514,"area":38092500,"error":0,"complete":1,"start_type":1,"clean_type":1,"finish_reason":52,"dust_collection_status":0}],"exe_time":101}
    mihome-vacuum.1
    	28085	2022-01-18 21:37:00.640	debug	Message= {"id":17,"method":"get_clean_record","params":[1642157827]}
    mihome-vacuum.1
    	28085	2022-01-18 21:37:00.630	debug	MIIO RECIVE: {"id":16,"result":[{"begin":1642329408,"end":1642331817,"duration":2409,"area":40062500,"error":0,"complete":1,"start_type":2,"clean_type":1,"finish_reason":52,"dust_collection_status":0}],"exe_time":101}
    mihome-vacuum.1
    	28085	2022-01-18 21:37:00.330	debug	Message= {"id":16,"method":"get_clean_record","params":[1642329408]}
    mihome-vacuum.1
    	28085	2022-01-18 21:37:00.329	debug	MIIO RECIVE: {"id":15,"result":[{"begin":1642332305,"end":1642334161,"duration":1856,"area":38020000,"error":0,"complete":1,"start_type":2,"clean_type":1,"finish_reason":52,"dust_collection_status":0}],"exe_time":101}
    mihome-vacuum.1
    	28085	2022-01-18 21:37:00.037	debug	Message= {"id":15,"method":"get_clean_record","params":[1642332305]}
    mihome-vacuum.1
    	28085	2022-01-18 21:37:00.028	debug	MIIO RECIVE: {"id":14,"result":[{"begin":1642360687,"end":1642362770,"duration":2083,"area":34847500,"error":0,"complete":1,"start_type":1,"clean_type":1,"finish_reason":52,"dust_collection_status":0}],"exe_time":101}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:59.728	debug	Message= {"id":14,"method":"get_clean_record","params":[1642360687]}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:59.727	debug	MIIO RECIVE: {"id":13,"result":[{"begin":1642498729,"end":1642500970,"duration":2241,"area":39280000,"error":0,"complete":1,"start_type":1,"clean_type":1,"finish_reason":52,"dust_collection_status":0}],"exe_time":100}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:59.425	debug	Message= {"id":13,"method":"get_clean_record","params":[1642498729]}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:59.424	debug	MIIO RECIVE: {"id":12,"result":[{"begin":1642501018,"end":1642502752,"duration":1734,"area":33437500,"error":0,"complete":1,"start_type":1,"clean_type":1,"finish_reason":52,"dust_collection_status":0}],"exe_time":101}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:59.124	debug	Message= {"id":12,"method":"get_clean_record","params":[1642501018]}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:59.122	debug	MIIO RECIVE: {"id":11,"result":[{"begin":1642534851,"end":1642534894,"duration":37,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":1,"finish_reason":60,"dust_collection_status":0}],"exe_time":100}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:58.922	debug	Message= {"id":11,"method":"get_clean_record","params":[1642534851]}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:58.921	debug	MIIO RECIVE: {"id":10,"result":[{"begin":1642535502,"end":1642535529,"duration":22,"area":302500,"error":0,"complete":0,"start_type":2,"clean_type":1,"finish_reason":60,"dust_collection_status":0}],"exe_time":100}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:58.753	debug	Message= {"id":10,"method":"get_clean_record","params":[1642535502]}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:58.751	debug	MIIO RECIVE: {"id":9,"result":[{"begin":1642537339,"end":1642537539,"duration":87,"area":2265000,"error":0,"complete":0,"start_type":2,"clean_type":1,"finish_reason":60,"dust_collection_status":0}],"exe_time":101}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:58.521	debug	Message= {"id":9,"method":"get_clean_record","params":[1642537339]}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:58.519	debug	MIIO RECIVE: {"id":8,"result":{"clean_time":671991,"clean_area":11339822500,"clean_count":529,"dust_collection_count":0,"records":[1642537339,1642535502,1642534851,1642501018,1642498729,1642360687,1642332305,1642329408,1642157827,1642152056,1642070229,1641927202,1641891670,1641888503,1641855549,1641850432,1641842401,1641841190,1641759125,1641649453]},"exe_time":101}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:58.223	debug	Message= {"id":8,"method":"get_clean_summary"}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:58.222	debug	Startup: Delete getMultiMapsList
    mihome-vacuum.1
    	28085	2022-01-18 21:36:58.222	debug	Startup: getMultiMapsList Answer: true
    mihome-vacuum.1
    	28085	2022-01-18 21:36:58.219	debug	States for Map: {"0":"K%FCche%20%26%20co","1":"Wohnzimmer%20","2":"Schlafzimmer%20und%20Bad"}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:58.218	debug	States for 3 Map: [{"mapFlag":0,"add_time":1642500997,"length":18,"name":"K%FCche%20%26%20co","bak_maps":[]},{"mapFlag":1,"add_time":1641041412,"length":13,"name":"Wohnzimmer%20","bak_maps":[]},{"mapFlag":2,"add_time":1624711206,"length":24,"name":"Schlafzimmer%20und%20Bad","bak_maps":[]}]
    mihome-vacuum.1
    	28085	2022-01-18 21:36:58.217	debug	MIIO RECIVE: {"id":7,"result":[{"max_multi_map":4,"max_bak_map":0,"multi_map_count":3,"map_info":[{"mapFlag":0,"add_time":1642500997,"length":18,"name":"K%FCche%20%26%20co","bak_maps":[]},{"mapFlag":1,"add_time":1641041412,"length":13,"name":"Wohnzimmer%20","bak_maps":[]},{"mapFlag":2,"add_time":1624711206,"length":24,"name":"Schlafzimmer%20und%20Bad","bak_maps":[]}]}],"exe_time":101}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:57.918	debug	Message= {"id":7,"method":"get_multi_maps_list"}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:57.915	debug	MIIO RECIVE: {"id":6,"result":[100],"exe_time":101}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:57.710	debug	Message= {"id":6,"method":"get_sound_volume"}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:57.623	debug	MIIO RECIVE: {"id":5,"result":{"ssid":"SERVER-ZENTRALE","ip":"172.16.0.80","mac":"b0:4a:39:16:2e:3d","bssid":"78:45:58:d4:67:fa","rssi":-68},"exe_time":100}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:57.116	debug	27536
    mihome-vacuum.1
    	28085	2022-01-18 21:36:56.714	debug	Message= {"id":5,"method":"get_network_info"}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:56.710	debug	MIIO RECIVE: {"id":4,"result":[[16,"212001026818"],[18,"212001026816"],[19,"212001026817"]],"exe_time":100}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:56.633	debug	update_Map got new time:1642538216
    mihome-vacuum.1
    	28085	2022-01-18 21:36:56.632	debug	update_Map got new expires:1642540016
    mihome-vacuum.1
    	28085	2022-01-18 21:36:56.631	debug	update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/roboroommap/416283912/1?Expires=1642540016000&GalaxyAccessKeyId=5271733786445&Signature=jUtE22hB5JwInsjqtTfgl76xFb4=
    mihome-vacuum.1
    	28085	2022-01-18 21:36:56.524	debug	Message= {"id":4,"method":"get_room_mapping"}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:56.513	debug	update_Map need new mapurl
    mihome-vacuum.1
    	28085	2022-01-18 21:36:56.512	debug	update_Map Mimap enabled
    mihome-vacuum.1
    	28085	2022-01-18 21:36:56.510	debug	Mappointer_updated
    mihome-vacuum.1
    	28085	2022-01-18 21:36:56.509	debug	MIIO RECIVE: {"id":3,"result":["roboroommap%2F416283912%2F1"],"exe_time":101}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:56.377	debug	Message= {"id":3,"method":"get_map_v1"}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:56.250	info	create states for mop
    mihome-vacuum.1
    	28085	2022-01-18 21:36:56.244	info	create states for water box mode
    mihome-vacuum.1
    	28085	2022-01-18 21:36:56.239	info	create states for water box
    mihome-vacuum.1
    	28085	2022-01-18 21:36:56.209	info	change states from State control.fan_power
    mihome-vacuum.1
    	28085	2022-01-18 21:36:56.208	debug	setGetStatus {"msg_ver":2,"msg_seq":3867,"state":10,"battery":70,"clean_time":0,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":3,"water_box_status":1,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":201,"water_box_carriage_status":0,"mop_forbidden_enable":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":0,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"error_text":"No error"}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:56.207	debug	MIIO RECIVE: {"id":2,"result":[{"msg_ver":2,"msg_seq":3867,"state":10,"battery":70,"clean_time":0,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":3,"water_box_status":1,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":201,"water_box_carriage_status":0,"mop_forbidden_enable":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":0,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0}],"exe_time":101}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.984	debug	Message= {"id":2,"method":"get_status"}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.983	debug	get params for stock Vacuum
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.982	debug	Create State done!
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.981	debug	Create State for map: loadMap
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.980	debug	Create State for map: mapURL
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.979	debug	Create State for map: mapStatus
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.978	debug	Create State for map: actualMap
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.976	debug	Create State for map: map64
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.974	debug	Create State for map:
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.968	info	Map selected create states...
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.966	debug	Create State for enableResumeZoneundefined
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.964	debug	Create State for enableResumeZoneundefined
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.958	debug	Create State for Queue: clearQueue
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.956	debug	Create State for Queue: queue
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.949	debug	Create State for stockHistoryundefined
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.940	debug	Create State for stockHistoryundefined
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.939	debug	Create State for stockHistoryundefined
    mihome-vacuum.1
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.938	debug	Create State for stockHistoryundefined
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.937	debug	Create State for stockHistoryundefined
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.928	debug	Create State for stockConsumableundefined
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.917	debug	Create State for stockConsumableundefined
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.916	debug	Create State for stockConsumableundefined
    mihome-vacuum.1
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.915	debug	Create State for stockConsumableundefined
    mihome-vacuum.1
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.914	debug	Create State for stockConsumableundefined
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.913	debug	Create State for stockConsumableundefined
    mihome-vacuum.1
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.904	debug	Create State for stockInfoundefined
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.895	debug	Create State for stockInfoundefined
    mihome-vacuum.1
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.894	debug	Create State for stockInfoundefined
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.893	debug	Create State for stockInfoundefined
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.892	debug	Create State for stockInfoundefined
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.885	debug	Create State for control{"id":"mihome-vacuum.1.control"}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.858	debug	Create State for controlundefined
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.857	debug	Create State for controlundefined
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.856	debug	Create State for controlundefined
    mihome-vacuum.1
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.855	debug	Create State for controlundefined
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.854	debug	Create State for controlundefined
    mihome-vacuum.1
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.853	debug	Create State for controlundefined
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.852	debug	Create State for controlundefined
    mihome-vacuum.1
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.851	debug	Create State for controlundefined
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.850	debug	Create State for controlundefined
    mihome-vacuum.1
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.849	debug	Create State for controlundefined
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.823	debug	Xiaomi Cloud: Login successful
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.822	debug	Login step3: [{"key":"userId","value":"6285111871","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-01-18T20:36:55.789Z","lastAccessed":"2022-01-18T20:36:55.821Z"},{"key":"cUserId","value":"g5O994QI2YKKWhdn9WHsfj9CdPo","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-01-18T20:36:55.809Z","lastAccessed":"2022-01-18T20:36:55.821Z"},{"key":"serviceToken","value":"olA3r/aZrsjVdp6WJf2rhhHHiCC0clHvfsULs9ybQUxHaaK1U9gdK4P2r5W3DyoB4UZE9TBMnhb0UbvRUYjM/EaqBCcaz1460uoi8mjIZqHzN7uHh2FYYf7TEWiYwZZ2RtXc0SWcobH3U8AoU2rRcEvk+Fmxo4R8BWAclkbd+Yc=","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-01-18T20:36:55.813Z","lastAccessed":"2022-01-18T20:36:55.821Z"}]
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.722	info	settest next timer: not available
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.503	debug	Login step2: &&&START&&&{"qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","ssecurity":"Zflzk+T+0d4E+13Vcs1Yog==","code":0,"passToken":"V1:DXmurwq2/R1BHTELu6obCTsR5njfVJUXgycsxQlr8lHfVz1x8NRL+i+QYihgiWhiMjnn1a9ehaP2mFjK5DYgOzBoVjDZr4Jya/5tTiXKzE0uHUszv3hXL/64ltIBrTzRC3Z4HeP7lvV8kYD0FeUyhnoicpv+v4Ww3cg2HMxxc29h2kgGXI2LZHfn7mRokaPF2MGB49OMBc87YZOPdmX81jCy7ziMxk3J4BBytjxgxxbSzMsIzu6CoKZPX4g72LrzkebM1N4EVPJovn83NsEyP1oRlmHhQNj33oU/GxBcYAU=","description":"成功","securityStatus":0,"nonce":1839856727383672832,"userId":6285111871,"cUserId":"g5O994QI2YKKWhdn9WHsfj9CdPo","result":"ok","psecurity":"bd9idScxEteVRpBT8zekHA==","captchaUrl":null,"location":"https://sts.api.io.mi.com/sts?d=bjyxgx&ticket=0&pwd=1&p_ts=1642538215000&fid=0&p_lm=1&auth=tYQtn7yyRXYz4HHzWGzNdMtGXkXuy1JTjiYjJK8e0v8b7AGngSN2bRvtxWQasBaTTb7z6zvaTYwylVWBhnQ2LXEww972eb1Q%2FK1AA%2BXa9qDrdv0VDhvbNX94KP%2BbfwwTcAa77R51w5dTnyMAJFpbXPJwPVn9XctZVNn%2BuG1e1d0%3D&m=1&tsl=0&nonce=lFPTuBQ1twcBobgU&_ssign=KmqtYPj%2FjcW41IPGnO8FosIaMRo%3D","pwd":1,"desc":"成功"}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.337	debug	Login step1: &&&START&&&{"serviceParam":"{\"checkSafePhone\":false,\"checkSafeAddress\":false,\"lsrp_score\":0.0}","qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","code":70016,"description":"登录验证失败","securityStatus":0,"_sign":"0psXfr43eNI0IX6q9Suk3qWbRqU=","sid":"xiaomiio","result":"error","captchaUrl":null,"callback":"https://sts.api.io.mi.com/sts","location":"https://account.xiaomi.com/fe/service/login?_json=true&sid=xiaomiio&qs=%253Fsid%253Dxiaomiio%2526_json%253Dtrue&callback=https%3A%2F%2Fsts.api.io.mi.com%2Fsts&_sign=0psXfr43eNI0IX6q9Suk3qWbRqU%3D&serviceParam=%7B%22checkSafePhone%22%3Afalse%2C%22checkSafeAddress%22%3Afalse%2C%22lsrp_score%22%3A0.0%7D&showActiveX=false&theme=&needTheme=false&bizDeviceType=","pwd":0,"desc":"登录验证失败"}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.166	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.084	debug	Xiaomi Cloud: Logging in
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.077	info	select standard vacuum protocol....
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.075	debug	DeviceModel selected to: roborock.vacuum.a15
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.005	debug	Get Device data from robot..
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.005	debug	Get Device data..0
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.004	debug	GETMODELFROMAPI:Data: {"id":1,"result":{"life":47144,"uid":6285111871,"model":"roborock.vacuum.a15","token":"5755304d335457683137676b5a667852","ipflag":1,"miio_ver":"0.0.9","mac":"B0:4A:39:16:2E:3D","fw_ver":"4.1.5_1398","hw_ver":"Linux","miio_client_ver":"4.1.5","VmPeak":10944,"VmRSS":1628,"MemFree":35952,"ap":{"ssid":"SERVER-ZENTRALE","bssid":"68:d7:9a:d7:1d:f3","rssi":"","freq":0},"netif":{"localIp":"172.16.0.80","mask":"255.255.0.0","gw":"172.16.0.1"},"miio_times":[47143,14,0,47128]},"exe_time":1}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:55.003	debug	MIIO RECIVE: {"id":1,"result":{"life":47144,"uid":6285111871,"model":"roborock.vacuum.a15","token":"5755304d335457683137676b5a667852","ipflag":1,"miio_ver":"0.0.9","mac":"B0:4A:39:16:2E:3D","fw_ver":"4.1.5_1398","hw_ver":"Linux","miio_client_ver":"4.1.5","VmPeak":10944,"VmRSS":1628,"MemFree":35952,"ap":{"ssid":"SERVER-ZENTRALE","bssid":"68:d7:9a:d7:1d:f3","rssi":"","freq":0},"netif":{"localIp":"172.16.0.80","mask":"255.255.0.0","gw":"172.16.0.1"},"miio_times":[47143,14,0,47128]},"exe_time":1}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:54.942	debug	Message= {"id":1,"method":"miIO.info"}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:54.940	debug	GETMODELFROMAPI: objModel: {"val":"roborock.vacuum.a15","ack":true,"ts":1642537772654,"q":0,"from":"system.adapter.mihome-vacuum.1","user":"system.user.admin","lc":1642534204932}
    mihome-vacuum.1
    	28085	2022-01-18 21:36:54.893	debug	Time difference between Mihome Vacuum and ioBroker: -1642491070 sec
    mihome-vacuum.1
    	28085	2022-01-18 21:36:54.890	debug	MAIN: Connected to device, try to get model..
    mihome-vacuum.1
    	28085	2022-01-18 21:36:54.889	debug	Receive <<< Helo <<< 213100200000000018cffd080000b828ffffffffffffffffffffffffffffffff
    MeistertrM 1 Antwort Letzte Antwort
    • da_WoodyD da_Woody
      @meistertr log gelöscht, adapter auf debug gestellt, nach neustart:
      mihome-vacuum.0
      2022-01-18 20:55:15.179	debug	Receive <<< Helo <<< 21310020000000001329b53561e71b23ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-01-18 20:55:05.162	debug	Receive <<< Helo <<< 21310020000000001329b53561e71b19ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-01-18 20:55:00.297	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":53}
      mihome-vacuum.0
      2022-01-18 20:55:00.283	debug	Message= {"id":53,"method":"get_carpet_mode"}
      mihome-vacuum.0
      2022-01-18 20:55:00.282	debug	MIIO RECIVE: {"result":[90],"id":52}
      mihome-vacuum.0
      2022-01-18 20:55:00.277	debug	Message= {"id":52,"method":"get_sound_volume"}
      mihome-vacuum.0
      2022-01-18 20:55:00.169	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-51},"id":51}
      mihome-vacuum.0
      2022-01-18 20:55:00.147	debug	Message= {"id":51,"method":"get_network_info"}
      mihome-vacuum.0
      2022-01-18 20:55:00.147	debug	setGetStatus {"msg_ver":2,"msg_seq":2657,"state":8,"battery":91,"clean_time":1625,"clean_area":24167500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
      mihome-vacuum.0
      2022-01-18 20:55:00.146	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":2657,"state":8,"battery":91,"clean_time":1625,"clean_area":24167500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":50}
      mihome-vacuum.0
      2022-01-18 20:55:00.133	debug	Message= {"id":50,"method":"get_status"}
      mihome-vacuum.0
      2022-01-18 20:55:00.132	debug	get params for stock Vacuum
      mihome-vacuum.0
      2022-01-18 20:54:55.156	debug	Receive <<< Helo <<< 21310020000000001329b53561e71b0fffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-01-18 20:54:45.153	debug	Receive <<< Helo <<< 21310020000000001329b53561e71b05ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-01-18 20:54:40.132	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":49}
      mihome-vacuum.0
      2022-01-18 20:54:40.122	debug	Message= {"id":49,"method":"get_carpet_mode"}
      mihome-vacuum.0
      2022-01-18 20:54:40.121	debug	MIIO RECIVE: {"result":[90],"id":48}
      mihome-vacuum.0
      2022-01-18 20:54:40.114	debug	Message= {"id":48,"method":"get_sound_volume"}
      mihome-vacuum.0
      2022-01-18 20:54:40.027	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-51},"id":47}
      mihome-vacuum.0
      2022-01-18 20:54:40.005	debug	Message= {"id":47,"method":"get_network_info"}
      mihome-vacuum.0
      2022-01-18 20:54:40.005	debug	setGetStatus {"msg_ver":2,"msg_seq":2656,"state":8,"battery":91,"clean_time":1625,"clean_area":24167500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
      mihome-vacuum.0
      2022-01-18 20:54:40.004	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":2656,"state":8,"battery":91,"clean_time":1625,"clean_area":24167500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":46}
      mihome-vacuum.0
      2022-01-18 20:54:39.998	debug	Message= {"id":46,"method":"get_status"}
      mihome-vacuum.0
      2022-01-18 20:54:39.998	debug	get params for stock Vacuum
      mihome-vacuum.0
      2022-01-18 20:54:35.149	debug	Receive <<< Helo <<< 21310020000000001329b53561e71afbffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-01-18 20:54:25.141	debug	Receive <<< Helo <<< 21310020000000001329b53561e71af1ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-01-18 20:54:19.997	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":45}
      mihome-vacuum.0
      2022-01-18 20:54:19.985	debug	Message= {"id":45,"method":"get_carpet_mode"}
      mihome-vacuum.0
      2022-01-18 20:54:19.985	debug	MIIO RECIVE: {"result":[90],"id":44}
      mihome-vacuum.0
      2022-01-18 20:54:19.945	debug	Message= {"id":44,"method":"get_sound_volume"}
      mihome-vacuum.0
      2022-01-18 20:54:19.813	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-51},"id":43}
      mihome-vacuum.0
      2022-01-18 20:54:19.790	debug	Message= {"id":43,"method":"get_network_info"}
      mihome-vacuum.0
      2022-01-18 20:54:19.790	debug	setGetStatus {"msg_ver":2,"msg_seq":2653,"state":8,"battery":90,"clean_time":1625,"clean_area":24167500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
      mihome-vacuum.0
      2022-01-18 20:54:19.789	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":2653,"state":8,"battery":90,"clean_time":1625,"clean_area":24167500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":42}
      mihome-vacuum.0
      2022-01-18 20:54:19.770	debug	Message= {"id":42,"method":"get_status"}
      mihome-vacuum.0
      2022-01-18 20:54:19.770	debug	get params for stock Vacuum
      mihome-vacuum.0
      2022-01-18 20:54:15.139	debug	Receive <<< Helo <<< 21310020000000001329b53561e71ae7ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-01-18 20:54:05.136	debug	Receive <<< Helo <<< 21310020000000001329b53561e71addffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-01-18 20:53:59.768	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":41}
      mihome-vacuum.0
      2022-01-18 20:53:59.763	debug	Message= {"id":41,"method":"get_carpet_mode"}
      mihome-vacuum.0
      2022-01-18 20:53:59.763	debug	MIIO RECIVE: {"result":[90],"id":40}
      mihome-vacuum.0
      2022-01-18 20:53:59.731	debug	Message= {"id":40,"method":"get_sound_volume"}
      mihome-vacuum.0
      2022-01-18 20:53:59.731	debug	Error at getSetNetwork: MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-01-18 20:53:59.730	debug	MIIO Receive Timeout for "get_network_info" <<<
      mihome-vacuum.0
      2022-01-18 20:53:57.729	debug	Message= {"id":39,"method":"get_network_info"}
      mihome-vacuum.0
      2022-01-18 20:53:57.729	debug	ERROR at setGetStatus: MESSAGE TIMEOUT
      mihome-vacuum.0
      2022-01-18 20:53:57.728	debug	MIIO Receive Timeout for "get_status" <<<
      mihome-vacuum.0
      2022-01-18 20:53:55.726	debug	Message= {"id":38,"method":"get_status"}
      mihome-vacuum.0
      2022-01-18 20:53:55.725	debug	get params for stock Vacuum
      mihome-vacuum.0
      2022-01-18 20:53:55.133	debug	Helo message Timeout
      mihome-vacuum.0
      2022-01-18 20:53:43.122	debug	Receive <<< Helo <<< 21310020000000001329b53561e71ac7ffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-01-18 20:53:36.205	debug	25610
      mihome-vacuum.0
      2022-01-18 20:53:35.860	debug	25610
      mihome-vacuum.0
      2022-01-18 20:53:35.783	debug	update_Map got new time:1642535615
      mihome-vacuum.0
      2022-01-18 20:53:35.783	debug	update_Map got new expires:1642537415
      mihome-vacuum.0
      2022-01-18 20:53:35.783	debug	update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubysc1/321500469/1?Expires=1642537415000&GalaxyAccessKeyId=5271733786445&Signature=aizvj45L7iC8kdVJyEAK1E0fSiI=
      mihome-vacuum.0
      2022-01-18 20:53:35.725	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":37}
      mihome-vacuum.0
      2022-01-18 20:53:35.718	debug	Message= {"id":37,"method":"get_carpet_mode"}
      mihome-vacuum.0
      2022-01-18 20:53:35.718	info	create state for carpet_mode
      mihome-vacuum.0
      2022-01-18 20:53:35.717	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":36}
      mihome-vacuum.0
      2022-01-18 20:53:35.717	debug	finish logs all [{"Datum":"18.1","Start":"20:20","Saugzeit":"27 min","Fläche":"24.17 m²","Error":0,"Ende":true},{"Datum":"6.1","Start":"19:10","Saugzeit":"12 min","Fläche":"14.82 m²","Error":0,"Ende":false},{"Datum":"6.1","Start":"15:36","Saugzeit":"32 min","Fläche":"24.57 m²","Error":0,"Ende":true},{"Datum":"4.1","Start":"17:10","Saugzeit":"29 min","Fläche":"23.87 m²","Error":0,"Ende":true},{"Datum":"26.12","Start":"08:04","Saugzeit":"28 min","Fläche":"24.78 m²","Error":0,"Ende":true},{"Datum":"22.12","Start":"20:13","Saugzeit":"1 min","Fläche":"0.92 m²","Error":0,"Ende":false},{"Datum":"19.12","Start":"12:44","Saugzeit":"25 min","Fläche":"24.53 m²","Error":0,"Ende":true},{"Datum":"18.12","Start":"19:29","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"18.12","Start":"14:36","Saugzeit":"27 min","Fläche":"24.74 m²","Error":0,"Ende":true},{"Datum":"18.12","Start":"14:17","Saugzeit":"2 min","Fläche":"2.24 m²","Error":0,"Ende":false},{"Datum":"18.12","Start":"14:07","Saugzeit":"10 min","Fläche":"11.18 m²","Error":0,"Ende":false},{"Datum":"17.12","Start":"20:36","Saugzeit":"24 min","Fläche":"24.41 m²","Error":0,"Ende":true},{"Datum":"17.12","Start":"19:47","Saugzeit":"25 min","Fläche":"24.06 m²","Error":0,"Ende":true},{"Datum":"17.12","Start":"19:37","Saugzeit":"2 min","Fläche":"2.79 m²","Error":0,"Ende":false},{"Datum":"17.12","Start":"19:35","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"8.12","Start":"08:57","Saugzeit":"29 min","Fläche":"24.65 m²","Error":0,"Ende":true},{"Datum":"30.11","Start":"19:48","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"30.11","Start":"19:48","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"25.11","Start":"14:42","Saugzeit":"28 min","Fläche":"24.72 m²","Error":0,"Ende":true},{"Datum":"23.8","Start":"20:35","Saugzeit":"36 min","Fläche":"24.67 m²","Error":0,"Ende":true}]
      mihome-vacuum.0
      2022-01-18 20:53:35.713	debug	MIIO RECIVE: {"result":[[1629743709,1629745916,2183,24672500,0,1,2,1,52]],"id":35}
      mihome-vacuum.0
      2022-01-18 20:53:35.697	debug	Message= {"id":36,"method":"get_carpet_mode"}
      mihome-vacuum.0
      2022-01-18 20:53:35.697	debug	update_Map need new mapurl
      mihome-vacuum.0
      2022-01-18 20:53:35.697	debug	update_Map Mimap enabled
      mihome-vacuum.0
      2022-01-18 20:53:35.696	debug	Mappointer_updated
      mihome-vacuum.0
      2022-01-18 20:53:35.696	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F1"],"id":34}
      mihome-vacuum.0
      2022-01-18 20:53:35.694	debug	Message= {"id":35,"method":"get_clean_record","params":[1629743709]}
      mihome-vacuum.0
      2022-01-18 20:53:35.693	debug	MIIO RECIVE: {"result":[[1637847746,1637849423,1677,24720000,0,1,2,1,52]],"id":33}
      mihome-vacuum.0
      2022-01-18 20:53:35.691	debug	Message= {"id":34,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-01-18 20:53:35.691	debug	Startup: Delete setGetConsumable
      mihome-vacuum.0
      2022-01-18 20:53:35.691	debug	Startup: setGetConsumable Answer: true
      mihome-vacuum.0
      2022-01-18 20:53:35.691	debug	MIIO RECIVE: {"result":[{"main_brush_work_time":22277,"side_brush_work_time":22277,"filter_work_time":22277,"filter_element_work_time":0,"sensor_dirty_time":51477}],"id":32}
      mihome-vacuum.0
      2022-01-18 20:53:35.683	debug	Message= {"id":33,"method":"get_clean_record","params":[1637847746]}
      mihome-vacuum.0
      2022-01-18 20:53:35.682	debug	MIIO RECIVE: {"result":[[1638298090,1638298093,3,0,0,0,5,1,37]],"id":31}
      mihome-vacuum.0
      2022-01-18 20:53:35.678	debug	Message= {"id":32,"method":"get_consumable"}
      mihome-vacuum.0
      2022-01-18 20:53:35.678	debug	Startup: Delete setGetCleanSummary
      mihome-vacuum.0
      2022-01-18 20:53:35.678	debug	Startup: setGetCleanSummary Answer: true
      mihome-vacuum.0
      2022-01-18 20:53:35.677	debug	MIIO RECIVE: {"result":[57137,727445000,59,[1642533653,1641492626,1641479793,1641312600,1640502268,1640200420,1639914272,1639852176,1639834584,1639833471,1639832823,1639769767,1639766834,1639766221,1639766120,1638950257,1638298120,1638298090,1637847746,1629743709]],"id":30}
      mihome-vacuum.0
      2022-01-18 20:53:35.673	debug	Message= {"id":31,"method":"get_clean_record","params":[1638298090]}
      mihome-vacuum.0
      2022-01-18 20:53:35.672	debug	MIIO RECIVE: {"result":[[1638298120,1638298130,10,0,0,0,2,1,60]],"id":29}
      mihome-vacuum.0
      2022-01-18 20:53:35.669	debug	Message= {"id":30,"method":"get_clean_summary"}
      mihome-vacuum.0
      2022-01-18 20:53:35.669	debug	Startup: Delete getMultiMapsList
      mihome-vacuum.0
      2022-01-18 20:53:35.669	debug	Startup: getMultiMapsList Answer: true
      mihome-vacuum.0
      2022-01-18 20:53:35.668	debug	States for Map: {"0":"0"}
      mihome-vacuum.0
      2022-01-18 20:53:35.664	debug	States for 1 Map: [{"mapFlag":0,"add_time":1642535320,"length":0,"name":"","bak_maps":[]}]
      mihome-vacuum.0
      2022-01-18 20:53:35.664	debug	MIIO RECIVE: {"result":[{"max_multi_map":1,"max_bak_map":0,"multi_map_count":1,"map_info":[{"mapFlag":0,"add_time":1642535320,"length":0,"name":"","bak_maps":[]}]}],"id":28}
      mihome-vacuum.0
      2022-01-18 20:53:35.642	debug	Message= {"id":29,"method":"get_clean_record","params":[1638298120]}
      mihome-vacuum.0
      2022-01-18 20:53:35.641	debug	MIIO RECIVE: {"result":[[1638950257,1638952005,1748,24650000,0,1,2,1,52]],"id":27}
      mihome-vacuum.0
      2022-01-18 20:53:35.641	debug	Message= {"id":28,"method":"get_multi_maps_list"}
      mihome-vacuum.0
      2022-01-18 20:53:35.637	debug	MIIO RECIVE: {"result":[90],"id":26}
      mihome-vacuum.0
      2022-01-18 20:53:35.631	debug	Message= {"id":27,"method":"get_clean_record","params":[1638950257]}
      mihome-vacuum.0
      2022-01-18 20:53:35.631	debug	MIIO RECIVE: {"result":[[1639766120,1639766127,7,0,0,0,2,1,60]],"id":25}
      mihome-vacuum.0
      2022-01-18 20:53:35.625	debug	Message= {"id":26,"method":"get_sound_volume"}
      mihome-vacuum.0
      2022-01-18 20:53:35.621	debug	Message= {"id":25,"method":"get_clean_record","params":[1639766120]}
      mihome-vacuum.0
      2022-01-18 20:53:35.609	debug	MIIO RECIVE: {"result":[[1639766221,1639766320,99,2787500,0,0,2,1,60]],"id":24}
      mihome-vacuum.0
      2022-01-18 20:53:35.603	debug	Message= {"id":24,"method":"get_clean_record","params":[1639766221]}
      mihome-vacuum.0
      2022-01-18 20:53:35.602	debug	MIIO RECIVE: {"result":[[1639766834,1639768334,1500,24057500,0,1,2,1,52]],"id":23}
      mihome-vacuum.0
      2022-01-18 20:53:35.597	debug	Message= {"id":23,"method":"get_clean_record","params":[1639766834]}
      mihome-vacuum.0
      2022-01-18 20:53:35.596	debug	MIIO RECIVE: {"result":[[1639769767,1639771238,1430,24405000,0,1,2,1,52]],"id":22}
      mihome-vacuum.0
      2022-01-18 20:53:35.591	debug	Message= {"id":22,"method":"get_clean_record","params":[1639769767]}
      mihome-vacuum.0
      2022-01-18 20:53:35.589	debug	MIIO RECIVE: {"result":[[1639832823,1639833407,584,11182500,0,0,2,1,43]],"id":21}
      mihome-vacuum.0
      2022-01-18 20:53:35.583	debug	update_Map got new time:1642535615
      mihome-vacuum.0
      2022-01-18 20:53:35.582	debug	update_Map got new expires:1642537415
      mihome-vacuum.0
      2022-01-18 20:53:35.582	debug	update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/rubysc1/321500469/0?Expires=1642537415000&GalaxyAccessKeyId=5271733786445&Signature=zGB9dgKKZAwTGfc9tG0r0iZ/3fs=
      mihome-vacuum.0
      2022-01-18 20:53:35.581	debug	Message= {"id":21,"method":"get_clean_record","params":[1639832823]}
      mihome-vacuum.0
      2022-01-18 20:53:35.580	debug	MIIO RECIVE: {"result":[[1639833471,1639833582,111,2242500,0,0,2,1,60]],"id":20}
      mihome-vacuum.0
      2022-01-18 20:53:35.576	debug	Message= {"id":20,"method":"get_clean_record","params":[1639833471]}
      mihome-vacuum.0
      2022-01-18 20:53:35.575	debug	MIIO RECIVE: {"result":[[1639834584,1639836197,1613,24735000,0,1,2,1,52]],"id":19}
      mihome-vacuum.0
      2022-01-18 20:53:35.571	debug	Message= {"id":19,"method":"get_clean_record","params":[1639834584]}
      mihome-vacuum.0
      2022-01-18 20:53:35.570	debug	MIIO RECIVE: {"result":[[1639852176,1639852181,4,0,0,0,5,1,37]],"id":18}
      mihome-vacuum.0
      2022-01-18 20:53:35.566	debug	Message= {"id":18,"method":"get_clean_record","params":[1639852176]}
      mihome-vacuum.0
      2022-01-18 20:53:35.566	debug	MIIO RECIVE: {"result":[[1639914272,1639915754,1482,24525000,0,1,2,1,52]],"id":17}
      mihome-vacuum.0
      2022-01-18 20:53:35.561	debug	Message= {"id":17,"method":"get_clean_record","params":[1639914272]}
      mihome-vacuum.0
      2022-01-18 20:53:35.561	debug	MIIO RECIVE: {"result":[[1640200420,1640200460,40,920000,0,0,2,1,60]],"id":16}
      mihome-vacuum.0
      2022-01-18 20:53:35.553	debug	Message= {"id":16,"method":"get_clean_record","params":[1640200420]}
      mihome-vacuum.0
      2022-01-18 20:53:35.547	debug	MIIO RECIVE: {"result":[[1640502268,1640503927,1659,24777500,0,1,2,1,52]],"id":15}
      mihome-vacuum.0
      2022-01-18 20:53:35.529	debug	Message= {"id":15,"method":"get_clean_record","params":[1640502268]}
      mihome-vacuum.0
      2022-01-18 20:53:35.529	debug	MIIO RECIVE: {"result":[[1641312600,1641318865,1738,23870000,0,1,2,1,52]],"id":14}
      mihome-vacuum.0
      2022-01-18 20:53:35.521	debug	Message= {"id":14,"method":"get_clean_record","params":[1641312600]}
      mihome-vacuum.0
      2022-01-18 20:53:35.521	debug	MIIO RECIVE: {"result":[[1641479793,1641486963,1910,24567500,0,1,2,1,52]],"id":13}
      mihome-vacuum.0
      2022-01-18 20:53:35.499	debug	Message= {"id":13,"method":"get_clean_record","params":[1641479793]}
      mihome-vacuum.0
      2022-01-18 20:53:35.497	debug	MIIO RECIVE: {"result":[[1641492626,1641493350,696,14817500,0,0,2,1,60]],"id":12}
      mihome-vacuum.0
      2022-01-18 20:53:35.480	debug	Message= {"id":12,"method":"get_clean_record","params":[1641492626]}
      mihome-vacuum.0
      2022-01-18 20:53:35.479	debug	MIIO RECIVE: {"result":[[1642533653,1642535288,1625,24167500,0,1,2,1,52]],"id":11}
      mihome-vacuum.0
      2022-01-18 20:53:35.454	debug	Message= {"id":11,"method":"get_clean_record","params":[1642533653]}
      mihome-vacuum.0
      2022-01-18 20:53:35.452	debug	MIIO RECIVE: {"result":[57137,727445000,59,[1642533653,1641492626,1641479793,1641312600,1640502268,1640200420,1639914272,1639852176,1639834584,1639833471,1639832823,1639769767,1639766834,1639766221,1639766120,1638950257,1638298120,1638298090,1637847746,1629743709]],"id":10}
      mihome-vacuum.0
      2022-01-18 20:53:35.449	debug	MIIO RECIVE: {"result":{"ssid":"Headquarter","ip":"192.168.1.15","mac":"64:90:c1:13:b1:18","bssid":"80:3f:5d:ae:a7:13","rssi":-51},"id":9}
      mihome-vacuum.0
      2022-01-18 20:53:35.434	debug	Message= {"id":10,"method":"get_clean_summary"}
      mihome-vacuum.0
      2022-01-18 20:53:35.433	debug	MIIO RECIVE: {"result":[{"main_brush_work_time":22277,"side_brush_work_time":22277,"filter_work_time":22277,"filter_element_work_time":0,"sensor_dirty_time":51477}],"id":8}
      mihome-vacuum.0
      2022-01-18 20:53:35.422	debug	Message= {"id":9,"method":"get_network_info"}
      mihome-vacuum.0
      2022-01-18 20:53:35.411	debug	Message= {"id":8,"method":"get_consumable"}
      mihome-vacuum.0
      2022-01-18 20:53:35.408	debug	MIIO RECIVE: {"result":[],"id":7}
      mihome-vacuum.0
      2022-01-18 20:53:35.400	debug	Message= {"id":7,"method":"get_room_mapping"}
      mihome-vacuum.0
      2022-01-18 20:53:35.398	debug	update_Map need new mapurl
      mihome-vacuum.0
      2022-01-18 20:53:35.398	debug	update_Map Mimap enabled
      mihome-vacuum.0
      2022-01-18 20:53:35.397	debug	Mappointer_updated
      mihome-vacuum.0
      2022-01-18 20:53:35.397	debug	MIIO RECIVE: {"result":["rubysc1%2F321500469%2F0"],"id":6}
      mihome-vacuum.0
      2022-01-18 20:53:35.390	debug	Message= {"id":6,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-01-18 20:53:35.090	debug	MIIO RECIVE: {"result":["retry"],"id":5}
      mihome-vacuum.0
      2022-01-18 20:53:35.084	debug	Message= {"id":5,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-01-18 20:53:34.782	debug	MIIO RECIVE: {"result":["retry"],"id":4}
      mihome-vacuum.0
      2022-01-18 20:53:34.777	debug	Message= {"id":4,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-01-18 20:53:34.476	debug	MIIO RECIVE: {"result":["retry"],"id":3}
      mihome-vacuum.0
      2022-01-18 20:53:34.415	debug	Message= {"id":3,"method":"get_map_v1"}
      mihome-vacuum.0
      2022-01-18 20:53:34.206	info	create states for water box
      mihome-vacuum.0
      2022-01-18 20:53:34.201	info	change states from State control.fan_power
      mihome-vacuum.0
      2022-01-18 20:53:34.200	debug	setGetStatus {"msg_ver":2,"msg_seq":2652,"state":8,"battery":90,"clean_time":1625,"clean_area":24167500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"is_locating":0,"lock_status":0,"error_text":"No error"}
      mihome-vacuum.0
      2022-01-18 20:53:34.200	debug	MIIO RECIVE: {"result":[{"msg_ver":2,"msg_seq":2652,"state":8,"battery":90,"clean_time":1625,"clean_area":24167500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0}],"id":2}
      mihome-vacuum.0
      2022-01-18 20:53:34.175	debug	Message= {"id":2,"method":"get_status"}
      mihome-vacuum.0
      2022-01-18 20:53:34.174	debug	get params for stock Vacuum
      mihome-vacuum.0
      2022-01-18 20:53:34.174	debug	Create State done!
      mihome-vacuum.0
      2022-01-18 20:53:34.174	debug	Create State for map: loadMap
      mihome-vacuum.0
      2022-01-18 20:53:34.174	debug	Create State for map: mapURL
      mihome-vacuum.0
      2022-01-18 20:53:34.174	debug	Create State for map: mapStatus
      mihome-vacuum.0
      2022-01-18 20:53:34.173	debug	Create State for map: actualMap
      mihome-vacuum.0
      2022-01-18 20:53:34.173	debug	Create State for map: map64
      mihome-vacuum.0
      2022-01-18 20:53:34.126	debug	Create State for map:
      mihome-vacuum.0
      2022-01-18 20:53:34.121	info	Map selected create states...
      mihome-vacuum.0
      2022-01-18 20:53:34.121	debug	Create State for enableResumeZoneundefined
      mihome-vacuum.0
      2022-01-18 20:53:34.074	debug	Create State for enableResumeZoneundefined
      mihome-vacuum.0
      2022-01-18 20:53:34.069	debug	Create State for Queue: clearQueue
      mihome-vacuum.0
      2022-01-18 20:53:34.025	debug	Create State for Queue: queue
      mihome-vacuum.0
      2022-01-18 20:53:34.022	debug	Create State for stockHistoryundefined
      mihome-vacuum.0
      2022-01-18 20:53:34.021	debug	Create State for stockHistoryundefined
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      2022-01-18 20:53:33.978	debug	Create State for stockHistoryundefined
      mihome-vacuum.0
      2022-01-18 20:53:33.974	debug	Create State for stockConsumableundefined
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      2022-01-18 20:53:33.973	debug	Create State for stockConsumableundefined
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      2022-01-18 20:53:33.929	debug	Create State for stockConsumableundefined
      mihome-vacuum.0
      2022-01-18 20:53:33.926	debug	Create State for stockInfoundefined
      mihome-vacuum.0
      mihome-vacuum.0
      2022-01-18 20:53:33.925	debug	Create State for stockInfoundefined
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      2022-01-18 20:53:33.885	debug	Create State for stockInfoundefined
      mihome-vacuum.0
      2022-01-18 20:53:33.851	debug	Create State for controlundefined
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      2022-01-18 20:53:33.850	debug	Create State for controlundefined
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      2022-01-18 20:53:33.849	debug	Create State for controlundefined
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      mihome-vacuum.0
      2022-01-18 20:53:33.807	debug	Create State for controlundefined
      mihome-vacuum.0
      2022-01-18 20:53:33.779	debug	Xiaomi Cloud: Login successful
      mihome-vacuum.0
      2022-01-18 20:53:33.779	debug	Login step3: [{"key":"userId","value":"6363339872","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-01-18T19:53:33.764Z","lastAccessed":"2022-01-18T19:53:33.779Z"},{"key":"cUserId","value":"Wk6OEyZydMH9GynK--l9q0BrBCg","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-01-18T19:53:33.772Z","lastAccessed":"2022-01-18T19:53:33.779Z"},{"key":"serviceToken","value":"UnDyv/dlwFiM4cPD3MZLveeHBxrjjTznu38flVyupxxr59fUXMWIDtgEe6tuIwW0JC9I6T/0fk/TL2JxvUS8Z9qHTRpP4iHVqe4Cex9BeoaI4Lzgqk/nEvZR8pjnu9V45zp4ePLlsHzRA9GU5fpJ+yu0WXrLcyQCzdZzko9h3c8=","domain":"sts.api.io.mi.com","path":"/","hostOnly":false,"creation":"2022-01-18T19:53:33.774Z","lastAccessed":"2022-01-18T19:53:33.779Z"}]
      mihome-vacuum.0
      2022-01-18 20:53:33.747	info	settest next timer: not available
      mihome-vacuum.0
      2022-01-18 20:53:33.569	debug	Login step2: &&&START&&&{"qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","ssecurity":"avnzpRrwXf2R9JzYYHK/uQ==","code":0,"passToken":"V1:DXmurwq2/R1BHTELu6obCcnqZ86cOqqyLWgf0wJSc6VCYWHfPGJ8o1jbCf+0vyUR72hdG6YfAS/2504qNlAMEgUe5tAVBbjgFtdgSAe9cuevr/CQxEbh18awdJsRsctbfJJ3fZaoC9qvqLSAvxmAkiPea9bF/rb+GHuMluvr1YzkkofjK1O5oDuss/Nqn0VfX6qLGBMwoIEbwdJOK5f8n4GChIJpAZ4vdps9rmbSOGqw88rFED7z/hulcTA3jqqOugbqLgapLTbOIxNs217CLmGYR3MlruzGFjEp8+e15Ug=","description":"成功","securityStatus":0,"nonce":6141130534114247680,"userId":6363339872,"cUserId":"Wk6OEyZydMH9GynK--l9q0BrBCg","result":"ok","psecurity":"BQDcHjbWqxX9KQbnEfSjGw==","captchaUrl":null,"location":"https://sts.api.io.mi.com/sts?d=lnfvzw&ticket=0&pwd=1&p_ts=1642535613000&fid=0&p_lm=1&auth=XuBVqit%2BQ%2BPf9Tj2NitR%2BkIW3nb%2FSB4cMo4sWtUHmsFofVCwLdcgv89C5UkhKDIeUAQTLLUc%2BMwYjo%2FuED0JpicgEicN2SKPhRT5O1dcLAoTkjtW0bnXPlk%2FROBa163%2FcEQMC1IMS8H%2BpJnCXKOkJSzL%2BRYTS0hds8pfz%2FdB%2BPY%3D&m=1&tsl=0&nonce=OJ43Mfw9If8Bobfp&_ssign=6LLh1z3KIncgieLF%2B%2B4dWL041GE%3D","pwd":1,"desc":"成功"}
      mihome-vacuum.0
      2022-01-18 20:53:33.410	debug	Login step1: &&&START&&&{"serviceParam":"{\"checkSafePhone\":false,\"checkSafeAddress\":false,\"lsrp_score\":0.0}","qs":"%3Fsid%3Dxiaomiio%26_json%3Dtrue","code":70016,"description":"登录验证失败","securityStatus":0,"_sign":"0psXfr43eNI0IX6q9Suk3qWbRqU=","sid":"xiaomiio","result":"error","captchaUrl":null,"callback":"https://sts.api.io.mi.com/sts","location":"https://account.xiaomi.com/fe/service/login?_json=true&sid=xiaomiio&qs=%253Fsid%253Dxiaomiio%2526_json%253Dtrue&callback=https%3A%2F%2Fsts.api.io.mi.com%2Fsts&_sign=0psXfr43eNI0IX6q9Suk3qWbRqU%3D&serviceParam=%7B%22checkSafePhone%22%3Afalse%2C%22checkSafeAddress%22%3Afalse%2C%22lsrp_score%22%3A0.0%7D&showActiveX=false&theme=&needTheme=false&bizDeviceType=","pwd":0,"desc":"登录验证失败"}
      mihome-vacuum.0
      2022-01-18 20:53:33.262	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
      mihome-vacuum.0
      2022-01-18 20:53:33.234	debug	Xiaomi Cloud: Logging in
      mihome-vacuum.0
      2022-01-18 20:53:33.231	info	select standard vacuum protocol....
      mihome-vacuum.0
      2022-01-18 20:53:33.231	warn	Model roborock.vacuum.a08 not supported! Please open issue on git: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues
      mihome-vacuum.0
      2022-01-18 20:53:33.231	debug	DeviceModel selected to: roborock.vacuum.a08
      mihome-vacuum.0
      2022-01-18 20:53:33.127	debug	Get Device data from robot..
      mihome-vacuum.0
      2022-01-18 20:53:33.127	debug	Get Device data..0
      mihome-vacuum.0
      2022-01-18 20:53:33.127	debug	GETMODELFROMAPI:Data: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_1368","ap":{"ssid":"Headquarter","bssid":"80:3f:5d:ae:a7:13","rssi":-63},"netif":{"localIp":"192.168.1.15","mask":"255.255.248.0","gw":"192.168.0.1"},"miio_ver":"miio-client 3.5.8","model":"roborock.vacuum.a08","mac":"64:90:C1:13:B1:18","token":"544f6b574e4e5868504d335933373635","life":60941}}
      mihome-vacuum.0
      2022-01-18 20:53:33.127	debug	MIIO RECIVE: {"partner_id":"","id":1,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_1368","ap":{"ssid":"Headquarter","bssid":"80:3f:5d:ae:a7:13","rssi":-63},"netif":{"localIp":"192.168.1.15","mask":"255.255.248.0","gw":"192.168.0.1"},"miio_ver":"miio-client 3.5.8","model":"roborock.vacuum.a08","mac":"64:90:C1:13:B1:18","token":"544f6b574e4e5868504d335933373635","life":60941}}
      mihome-vacuum.0
      2022-01-18 20:53:33.121	debug	Message= {"id":1,"method":"miIO.info"}
      mihome-vacuum.0
      2022-01-18 20:53:33.121	debug	GETMODELFROMAPI: objModel: {"val":"roborock.vacuum.a08","ack":true,"ts":1642533525002,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1640205614333}
      mihome-vacuum.0
      2022-01-18 20:53:33.115	debug	MAIN: Connected to device, try to get model..
      mihome-vacuum.0
      2022-01-18 20:53:33.115	debug	Receive <<< Helo <<< 21310020000000001329b53561e71abdffffffffffffffffffffffffffffffff
      mihome-vacuum.0
      2022-01-18 20:53:33.110	debug	server started on 0.0.0.0:53421
      mihome-vacuum.0
      2022-01-18 20:53:33.108	info	IOT enabled, create state
      mihome-vacuum.0
      2022-01-18 20:53:33.105	debug	MIIO: Config: ip:192.168.1.15 token: 544f6b574e4e5868504d335933373635
      mihome-vacuum.0
      2022-01-18 20:53:33.104	debug	Create State for deviceInfowifi_signal
      mihome-vacuum.0
      2022-01-18 20:53:33.104	debug	Create State for deviceInfofw_ver
      mihome-vacuum.0
      2022-01-18 20:53:33.104	debug	Create State for deviceInfomodel
      mihome-vacuum.0
      2022-01-18 20:53:33.104	debug	Create State for deviceInfomac
      mihome-vacuum.0
      2022-01-18 20:53:33.103	debug	Create State for deviceInfo
      mihome-vacuum.0
      2022-01-18 20:53:33.073	debug	load Map creator... true
      mihome-vacuum.0
      2022-01-18 20:53:33.043	info	starting. Version 3.3.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v14.18.2, js-controller: 3.3.22
      mihome-vacuum.0
      2022-01-18 20:53:32.950	debug	Plugin sentry Initialize Plugin (enabled=true)
      karte wird in der APP aktualisiert, in der iQontrol visu nicht. war früher definitiv der fall.
      hilft das?
      sorry, jetzt wirklich debug log...
      MeistertrM Offline
      MeistertrM Offline
      Meistertr
      #584
      @da_woody was heißt früher? vor ca einem halben Jahrwurde das Format von dem map64 geändert. das Problem liegt auf jeden fall nicht am adapter. der eintrag '2022-01-18 20:53:35.860' 25610 ist die Position des Roboters die aus den Katendaten gelesen wurde, das bedeutet, dass die Karte generiert und gespeichert wurde.
      • M Maxim-777
        @meistertr
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        mihome-vacuum.1
        MeistertrM Offline
        MeistertrM Offline
        Meistertr
        #585
        @maxim-777 auch vom fehlerfall bitte einen log
          Maxim-777
          #586
          @meistertr
          host.SERVER
          		2022-01-18 21:57:56.024	error	Caught by controller[0]: -vacuum.1: ../../nan/nan_object_wrap.h:125: static void Nan::ObjectWrap::WeakCallback(const v8::WeakCallbackInfo<Nan::ObjectWrap>&): Assertion `wrap->refs_ == 0' failed.
          host.SERVER
          		2022-01-18 21:57:01.317	error	Caught by controller[0]: munmap_chunk(): invalid pointer
          host.SERVER
          		2022-01-18 21:56:23.973	error	Caught by controller[0]: #FailureMessage Object: 0xbe8b1348
          host.SERVER
          		2022-01-18 21:56:23.972	error	Caught by controller[0]: #
          host.SERVER
          host.SERVER
          host.SERVER
          		2022-01-18 21:56:23.971	error	Caught by controller[0]: # Check failed: !backing_store->is_wasm_memory().
          host.SERVER
          		2022-01-18 21:56:23.971	error	Caught by controller[0]: # Fatal error in , line 0
          host.SERVER
          		2022-01-18 21:56:23.969	error	Caught by controller[0]: #
          mihome-vacuum.1
          	29174	2022-01-18 21:56:12.736	error	Socket Close
          mihome-vacuum.1
          	28441	2022-01-18 21:51:55.429	error	Socket Close
          • M Maxim-777
            @meistertr
            host.SERVER
            host.SERVER
            host.SERVER
            host.SERVER
            host.SERVER
            host.SERVER
            host.SERVER
            host.SERVER
            host.SERVER
            mihome-vacuum.1
            mihome-vacuum.1
            MeistertrM Offline
            MeistertrM Offline
            Meistertr
            #587
            @maxim-777 das ist ein Fehler aus den tiefen des Systems nicht von Adapter oder iobroker. Kannst du mal ein bisschen mehr log posten dass ich sehe, wo genau das System kollabiert...
              Maxim-777
              #588
              @meistertr
              Kompletten fehlerlog? wenn mein S7 nicht läuft kommen überhaupt keine fehlerlog raus.
              • M Maxim-777
                @meistertr
                MeistertrM Offline
                MeistertrM Offline
                Meistertr
                #589
                @maxim-777 nein ich meineden ausschnitt den du geposet hast, der ist zu kurz nur der Error reicht nicht, ich muss wissen was kurz davor passiert ist. Also auch die logeinträge die vor dem Fehler sind
                  da_WoodyD Offline
                  da_WoodyD Offline
                  #590
                  @meistertr früher..., so um den jahreswechsel, wie die ersten erzählten, daß sie keine karte mehr angezeigt bekommen.
                  da wollte ich die farben für die anzeige ändern, plötzlich war nach neustart map64 und mapurl nicht mehr befüllt. dann kam die geschichte mit canvas, anscheinend wegen dem nodejs14 update. canvas repariert, seit dem bekomme ich zwar wieder die daten (siehe unten), aber in meiner visu wird die map, nicht wie vorher, während des saugens aktualisiert. wie geschrieben, in der APP wird akualisiert, in der visu nur nach reload der page. getestet mit chrome und firefox.
                  zwischendurch war dann auch das problem mit den mihome servern.
                    MeistertrM Offline
                    MeistertrM Offline
                    Meistertr
                    #591
                    @da_woody wenn es nur nach den reload der page aktualisiert wird, ist es dann aber eindeutig ein fehler von der visu und nicht vom adapter. wie gesagt die map wird eindeug erzeugt und gespeichert. kannst gerne nochmal einen logauszug vom saugvorgang schicken, dann check ich das auch nochmal. Aber wie gesagt am adapter liegt es nicht... hast du in der visu map64 oder das png bild?
                    • MeistertrM Meistertr
                      da_WoodyD Offline
                      da_WoodyD Offline
                      #592
                      @meistertr das .png, also mapURL. werd beim nächsten saugen mal ein log mitlaufen lassen...
                      ausschlussverfahren... kann mir schon vorstellen, das da die browser dran schuld sind. seit ein paar tagen kann ich meinen proxmox server mit chrome nicht mehr erreichen, mit firefox ohne probleme. aber das ist ein anderes thema.
                        MeistertrM Offline
                        MeistertrM Offline
                        Meistertr
                        #593
                        @da_woody zum Jahreswechsel hat chorme https zum Standard erklärt und http für unsicher. du musst in den Seiteneinstellungen expliziet unsicher eingebettete Inhalte erlauben 2022-01-19_08h42_23.png
                          da_WoodyD Offline
                          da_WoodyD Offline
                          #594
                          @meistertr wenns die einstellung auch gäbe... :)
                          egal, hab die seite explizit zugelassen...
                            bahnuhrB Online
                            bahnuhrB Online
                            bahnuhr
                            #595
                            @da_woody
                            Bei mir geht es noch.
                            Welche V hast du ?
                            Danke.
                            • bahnuhrB bahnuhr
                              @da_woody
                              Welche V hast du ?
                              da_WoodyD Offline
                              da_WoodyD Offline
                              #596
                              @bahnuhr die selbe. dürfte was an meinem rechner in der männerhöhle nicht stimmen. den müsste ich endlich wieder mal neu aufsetzen. am rechner im büro gerade getestet, da fluppts... 🤒
                              • BanditFGB Offline
                                BanditFGB Offline
                                BanditFG
                                #597
                                Hallo mir ist heute aufgefallen, das die Map von meinen beiden Xiaomi 1 Saugrobotern mal wieder nicht geladen wird.
                                Zumindest wird in der Vis nichts akualisiert. In der Flole App funktioniert es!!
                                mihome-vacuum.1
                                2022-01-19 13:57:32.377	debug	CanvasMap not loaded
                                mihome-vacuum.1
                                2022-01-19 13:57:32.377	debug	update_Map use old mapurl
                                mihome-vacuum.1
                                2022-01-19 13:57:32.377	debug	update_Map Mimap enabled
                                mihome-vacuum.1
                                2022-01-19 13:57:32.376	debug	Mappointer_updated
                                mihome-vacuum.1
                                2022-01-19 13:57:32.376	debug	MIIO RECIVE: {"result":["roboroommap%2F261467989%2F6"],"id":425}
                                mihome-vacuum.1
                                2022-01-19 13:57:32.372	debug	Message= {"id":425,"method":"get_map_v1"}
                                mihome-vacuum.1
                                2022-01-19 13:57:30.372	debug	CanvasMap not loaded
                                mihome-vacuum.1
                                2022-01-19 13:57:30.372	debug	update_Map use old mapurl
                                mihome-vacuum.1
                                2022-01-19 13:57:30.372	debug	update_Map Mimap enabled
                                mihome-vacuum.1
                                2022-01-19 13:57:30.372	debug	Mappointer_updated
                                mihome-vacuum.1
                                2022-01-19 13:57:30.371	debug	MIIO RECIVE: {"result":["roboroommap%2F261467989%2F5"],"id":424}
                                mihome-vacuum.1
                                2022-01-19 13:57:30.366	debug	Message= {"id":424,"method":"get_map_v1"}
                                mihome-vacuum.1
                                2022-01-19 13:57:28.366	debug	CanvasMap not loaded
                                mihome-vacuum.1
                                2022-01-19 13:57:28.366	debug	update_Map use old mapurl
                                mihome-vacuum.1
                                2022-01-19 13:57:28.365	debug	update_Map Mimap enabled
                                mihome-vacuum.1
                                2022-01-19 13:57:28.365	debug	Mappointer_updated
                                mihome-vacuum.1
                                2022-01-19 13:57:28.365	debug	MIIO RECIVE: {"result":["roboroommap%2F261467989%2F4"],"id":423}
                                mihome-vacuum.1
                                2022-01-19 13:57:28.359	debug	Message= {"id":423,"method":"get_map_v1"}
                                mihome-vacuum.1
                                2022-01-19 13:57:27.926	debug	Time difference between Mihome Vacuum and ioBroker: 1 sec
                                mihome-vacuum.1
                                2022-01-19 13:57:27.926	debug	Receive <<< Helo <<< 21310020000000000f95af5561e80ab8ffffffffffffffffffffffffffffffff
                                mihome-vacuum.1
                                2022-01-19 13:57:26.359	debug	CanvasMap not loaded
                                mihome-vacuum.1
                                2022-01-19 13:57:26.359	debug	update_Map use old mapurl
                                mihome-vacuum.1
                                2022-01-19 13:57:26.359	debug	update_Map Mimap enabled
                                mihome-vacuum.1
                                2022-01-19 13:57:26.358	debug	Mappointer_updated
                                mihome-vacuum.1
                                2022-01-19 13:57:26.358	debug	MIIO RECIVE: {"result":["roboroommap%2F261467989%2F3"],"id":422}
                                mihome-vacuum.1
                                2022-01-19 13:57:26.354	debug	Message= {"id":422,"method":"get_map_v1"}
                                mihome-vacuum.1
                                2022-01-19 13:57:24.354	debug	CanvasMap not loaded
                                mihome-vacuum.1
                                2022-01-19 13:57:24.353	debug	update_Map use old mapurl
                                mihome-vacuum.1
                                2022-01-19 13:57:24.353	debug	update_Map Mimap enabled
                                mihome-vacuum.1
                                2022-01-19 13:57:24.353	debug	Mappointer_updated
                                mihome-vacuum.1
                                2022-01-19 13:57:24.353	debug	MIIO RECIVE: {"result":["roboroommap%2F261467989%2F2"],"id":421}
                                mihome-vacuum.1
                                2022-01-19 13:57:24.345	debug	Message= {"id":421,"method":"get_map_v1"}
                                mihome-vacuum.1
                                2022-01-19 13:57:22.344	debug	CanvasMap not loaded
                                mihome-vacuum.1
                                2022-01-19 13:57:22.344	debug	update_Map use old mapurl
                                mihome-vacuum.1
                                2022-01-19 13:57:22.344	debug	update_Map Mimap enabled
                                mihome-vacuum.1
                                2022-01-19 13:57:22.344	debug	Mappointer_updated
                                mihome-vacuum.1
                                2022-01-19 13:57:22.343	debug	MIIO RECIVE: {"result":["roboroommap%2F261467989%2F1"],"id":420}
                                mihome-vacuum.1
                                2022-01-19 13:57:22.337	debug	Message= {"id":420,"method":"get_map_v1"}
                                mihome-vacuum.1
                                2022-01-19 13:57:21.778	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":419}
                                mihome-vacuum.1
                                2022-01-19 13:57:21.772	debug	Message= {"id":419,"method":"get_carpet_mode"}
                                mihome-vacuum.1
                                2022-01-19 13:57:21.771	debug	MIIO RECIVE: {"result":[30],"id":418}
                                mihome-vacuum.1
                                2022-01-19 13:57:21.766	debug	Message= {"id":418,"method":"get_sound_volume"}
                                mihome-vacuum.1
                                2022-01-19 13:57:21.766	debug	MIIO RECIVE: {"result":"unknown_method","id":417}
                                mihome-vacuum.1
                                2022-01-19 13:57:21.762	debug	Message= {"id":417,"method":"get_network_info"}
                                mihome-vacuum.1
                                2022-01-19 13:57:21.762	debug	setGetStatus {"msg_ver":8,"msg_seq":1789,"state":5,"battery":88,"clean_time":800,"clean_area":15802500,"error_code":0,"map_present":true,"in_cleaning":true,"fan_power":90,"dnd_enabled":false,"error_text":"No error"}
                                mihome-vacuum.1
                                2022-01-19 13:57:21.762	debug	MIIO RECIVE: {"result":[{"msg_ver":8,"msg_seq":1789,"state":5,"battery":88,"clean_time":800,"clean_area":15802500,"error_code":0,"map_present":1,"in_cleaning":1,"fan_power":90,"dnd_enabled":0}],"id":416}
                                mihome-vacuum.1
                                2022-01-19 13:57:21.756	debug	Message= {"id":416,"method":"get_status"}
                                mihome-vacuum.1
                                2022-01-19 13:57:21.756	debug	get params for stock Vacuum
                                mihome-vacuum.1
                                2022-01-19 13:57:20.337	debug	CanvasMap not loaded
                                mihome-vacuum.1
                                2022-01-19 13:57:20.337	debug	update_Map use old mapurl
                                mihome-vacuum.1
                                2022-01-19 13:57:20.336	debug	update_Map Mimap enabled
                                mihome-vacuum.1
                                2022-01-19 13:57:20.336	debug	Mappointer_updated
                                mihome-vacuum.1
                                2022-01-19 13:57:20.336	debug	MIIO RECIVE: {"result":["roboroommap%2F261467989%2F0"],"id":415}
                                mihome-vacuum.1
                                2022-01-19 13:57:20.332	debug	Message= {"id":415,"method":"get_map_v1"}
                                mihome-vacuum.1
                                2022-01-19 13:57:18.331	debug	CanvasMap not loaded
                                mihome-vacuum.1
                                2022-01-19 13:57:18.331	debug	update_Map use old mapurl
                                mihome-vacuum.1
                                2022-01-19 13:57:18.331	debug	update_Map Mimap enabled
                                mihome-vacuum.1
                                2022-01-19 13:57:18.331	debug	Mappointer_updated
                                mihome-vacuum.1
                                2022-01-19 13:57:18.331	debug	MIIO RECIVE: {"result":["roboroommap%2F261467989%2F19"],"id":414}
                                mihome-vacuum.1
                                2022-01-19 13:57:18.323	debug	Message= {"id":414,"method":"get_map_v1"}
                                mihome-vacuum.1
                                2022-01-19 13:57:17.920	debug	Time difference between Mihome Vacuum and ioBroker: 1 sec
                                mihome-vacuum.1
                                2022-01-19 13:57:17.919	debug	Receive <<< Helo <<< 21310020000000000f95af5561e80aaeffffffffffffffffffffffffffffffff
                                mihome-vacuum.1
                                2022-01-19 13:57:16.322	debug	CanvasMap not loaded
                                mihome-vacuum.1
                                2022-01-19 13:57:16.322	debug	update_Map use old mapurl
                                mihome-vacuum.1
                                2022-01-19 13:57:16.322	debug	update_Map Mimap enabled
                                mihome-vacuum.1
                                2022-01-19 13:57:16.321	debug	Mappointer_updated
                                mihome-vacuum.1
                                2022-01-19 13:57:16.321	debug	MIIO RECIVE: {"result":["roboroommap%2F261467989%2F18"],"id":413}
                                mihome-vacuum.1
                                2022-01-19 13:57:16.271	debug	Message= {"id":413,"method":"get_map_v1"}
                                mihome-vacuum.1
                                2022-01-19 13:57:14.271	debug	CanvasMap not loaded
                                mihome-vacuum.1
                                2022-01-19 13:57:14.271	debug	update_Map use old mapurl
                                mihome-vacuum.1
                                2022-01-19 13:57:14.271	debug	update_Map Mimap enabled
                                mihome-vacuum.1
                                2022-01-19 13:57:14.270	debug	Mappointer_updated
                                mihome-vacuum.1
                                2022-01-19 13:57:14.270	debug	MIIO RECIVE: {"result":["roboroommap%2F261467989%2F17"],"id":412}
                                mihome-vacuum.1
                                2022-01-19 13:57:14.261	debug	Message= {"id":412,"method":"get_map_v1"}
                                mihome-vacuum.1
                                2022-01-19 13:57:12.261	debug	CanvasMap not loaded
                                mihome-vacuum.1
                                2022-01-19 13:57:12.260	debug	update_Map use old mapurl
                                mihome-vacuum.1
                                2022-01-19 13:57:12.260	debug	update_Map Mimap enabled
                                mihome-vacuum.1
                                2022-01-19 13:57:12.260	debug	Mappointer_updated
                                mihome-vacuum.1
                                2022-01-19 13:57:12.260	debug	MIIO RECIVE: {"result":["roboroommap%2F261467989%2F16"],"id":411}
                                mihome-vacuum.1
                                2022-01-19 13:57:12.255	debug	Message= {"id":411,"method":"get_map_v1"}
                                mihome-vacuum.1
                                2022-01-19 13:57:10.254	debug	CanvasMap not loaded
                                mihome-vacuum.1
                                2022-01-19 13:57:10.254	debug	update_Map use old mapurl
                                mihome-vacuum.1
                                2022-01-19 13:57:10.254	debug	update_Map Mimap enabled
                                mihome-vacuum.1
                                2022-01-19 13:57:10.253	debug	Mappointer_updated
                                mihome-vacuum.1
                                2022-01-19 13:57:10.253	debug	MIIO RECIVE: {"result":["roboroommap%2F261467989%2F15"],"id":410}
                                mihome-vacuum.1
                                2022-01-19 13:57:10.244	debug	Message= {"id":410,"method":"get_map_v1"}
                                mihome-vacuum.1
                                2022-01-19 13:57:08.244	debug	CanvasMap not loaded
                                mihome-vacuum.1
                                2022-01-19 13:57:08.243	debug	update_Map use old mapurl
                                mihome-vacuum.1
                                2022-01-19 13:57:08.243	debug	update_Map Mimap enabled
                                mihome-vacuum.1
                                2022-01-19 13:57:08.243	debug	Mappointer_updated
                                mihome-vacuum.1
                                2022-01-19 13:57:08.243	debug	MIIO RECIVE: {"result":["roboroommap%2F261467989%2F14"],"id":409}
                                mihome-vacuum.1
                                2022-01-19 13:57:08.238	debug	Message= {"id":409,"method":"get_map_v1"}
                                mihome-vacuum.1
                                2022-01-19 13:57:07.916	debug	Time difference between Mihome Vacuum and ioBroker: 1 sec
                                mihome-vacuum.1
                                2022-01-19 13:57:07.916	debug	Receive <<< Helo <<< 21310020000000000f95af5561e80aa4ffffffffffffffffffffffffffffffff
                                mihome-vacuum.1
                                2022-01-19 13:57:06.237	debug	CanvasMap not loaded
                                mihome-vacuum.1
                                2022-01-19 13:57:06.237	debug	update_Map use old mapurl
                                mihome-vacuum.1
                                2022-01-19 13:57:06.236	debug	update_Map Mimap enabled
                                mihome-vacuum.1
                                2022-01-19 13:57:06.236	debug	Mappointer_updated
                                mihome-vacuum.1
                                2022-01-19 13:57:06.236	debug	MIIO RECIVE: {"result":["roboroommap%2F261467989%2F13"],"id":408}
                                mihome-vacuum.1
                                2022-01-19 13:57:06.231	debug	Message= {"id":408,"method":"get_map_v1"}
                                mihome-vacuum.1
                                2022-01-19 13:57:04.231	debug	CanvasMap not loaded
                                mihome-vacuum.1
                                2022-01-19 13:57:04.231	debug	update_Map use old mapurl
                                mihome-vacuum.1
                                2022-01-19 13:57:04.231	debug	update_Map Mimap enabled
                                mihome-vacuum.1
                                2022-01-19 13:57:04.231	debug	Mappointer_updated
                                mihome-vacuum.1
                                2022-01-19 13:57:04.230	debug	MIIO RECIVE: {"result":["roboroommap%2F261467989%2F12"],"id":407}
                                mihome-vacuum.1
                                2022-01-19 13:57:04.225	debug	Message= {"id":407,"method":"get_map_v1"}
                                mihome-vacuum.1
                                2022-01-19 13:57:02.225	debug	CanvasMap not loaded
                                mihome-vacuum.1
                                2022-01-19 13:57:02.225	debug	update_Map use old mapurl
                                mihome-vacuum.1
                                2022-01-19 13:57:02.224	debug	update_Map Mimap enabled
                                mihome-vacuum.1
                                2022-01-19 13:57:02.224	debug	Mappointer_updated
                                mihome-vacuum.1
                                2022-01-19 13:57:02.224	debug	MIIO RECIVE: {"result":["roboroommap%2F261467989%2F11"],"id":406}
                                mihome-vacuum.1
                                2022-01-19 13:57:02.219	debug	Message= {"id":406,"method":"get_map_v1"}
                                mihome-vacuum.1
                                2022-01-19 13:57:01.755	debug	MIIO RECIVE: {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":405}
                                mihome-vacuum.1
                                2022-01-19 13:57:01.743	debug	Message= {"id":405,"method":"get_carpet_mode"}
                                mihome-vacuum.1
                                2022-01-19 13:57:01.743	debug	MIIO RECIVE: {"result":[30],"id":404}
                                mihome-vacuum.1
                                2022-01-19 13:57:01.738	debug	Message= {"id":404,"method":"get_sound_volume"}
                                mihome-vacuum.1
                                2022-01-19 13:57:01.738	debug	MIIO RECIVE: {"result":"unknown_method","id":403}
                                mihome-vacuum.1
                                2022-01-19 13:57:01.732	debug	Message= {"id":403,"method":"get_network_info"}
                                mihome-vacuum.1
                                2022-01-19 13:57:01.732	debug	setGetStatus {"msg_ver":8,"msg_seq":1787,"state":5,"battery":89,"clean_time":780,"clean_area":14787500,"error_code":0,"map_present":true,"in_cleaning":true,"fan_power":90,"dnd_enabled":false,"error_text":"No error"}
                                mihome-vacuum.1
                                2022-01-19 13:57:01.731	debug	MIIO RECIVE: {"result":[{"msg_ver":8,"msg_seq":1787,"state":5,"battery":89,"cle
                                in der Vis wird es über actualMap_1.png dargesellt, das hat Anfang des Jahres so auch funktioniert..
                                Wurde irgendwas geändert?
                                Hat jemand ne Idee wo das Problem ist??
                                Danke im Voraus
                                • D3ltoroxpD Offline
                                  D3ltoroxpD Offline
                                  D3ltoroxp
                                  #598
                                  Also Adapter läuft ja soweit wieder und die Verbindung steht, aber die Map bleibt leider weg. Die DP's bleiben leer. Debug sagt folgendes...
                                  Log-Größe: 2.4 MB
                                  Zeit
                                  Nachricht
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:50.647	debug	CanvasMap not loaded
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:50.647	debug	update_Map got new time:1642612370
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:50.647	debug	update_Map got new expires:1642614170
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:50.646	debug	update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/260658891/5?Expires=1642614170000&GalaxyAccessKeyId=5271733786445&Signature=VGjgf0R9u3SW+kyrLA8eqYX3zEw=
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:50.571	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":50}
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:50.557	debug	Message= {"id":50,"method":"get_carpet_mode"}
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:50.556	debug	update_Map need new mapurl
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:50.556	debug	update_Map Mimap enabled
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:50.556	debug	Mappointer_updated
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:50.555	debug	MIIO RECIVE: {"result":["robomap%2F260658891%2F5"],"id":49}
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:50.550	debug	Message= {"id":49,"method":"get_map_v1"}
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:50.549	debug	MIIO RECIVE: {"result":[90],"id":48}
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:50.544	debug	Message= {"id":48,"method":"get_sound_volume"}
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:50.453	debug	MIIO RECIVE: {"result":{"ssid":"HomeCinemaHD","ip":"192.168.178.31","mac":"50:ec:50:08:9b:a4","bssid":"44:4e:6d:d6:ed:b9","rssi":-55},"id":47}
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:50.432	debug	Message= {"id":47,"method":"get_network_info"}
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:50.431	debug	setGetStatus {"msg_ver":3,"msg_seq":2561,"state":8,"battery":100,"clean_time":2435,"clean_area":45957500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"lock_status":0,"error_text":"No error"}
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:50.431	debug	MIIO RECIVE: {"result":[{"msg_ver":3,"msg_seq":2561,"state":8,"battery":100,"clean_time":2435,"clean_area":45957500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":46}
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:50.424	debug	Message= {"id":46,"method":"get_status"}
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:50.423	debug	get params for stock Vacuum
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:48.412	debug	Receive <<< Helo <<< 21310020000000000f8956cb61e84690ffffffffffffffffffffffffffffffff
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:38.403	debug	Receive <<< Helo <<< 21310020000000000f8956cb61e84686ffffffffffffffffffffffffffffffff
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:30.544	debug	CanvasMap not loaded
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:30.544	debug	update_Map got new time:1642612350
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:30.544	debug	update_Map got new expires:1642614150
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:30.543	debug	update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/260658891/4?Expires=1642614150000&GalaxyAccessKeyId=5271733786445&Signature=8YIuHBxgtQVR1j7KJUnMivl8/GA=
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:30.422	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":45}
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:30.416	debug	Message= {"id":45,"method":"get_carpet_mode"}
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:30.415	debug	update_Map need new mapurl
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:30.415	debug	update_Map Mimap enabled
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:30.415	debug	Mappointer_updated
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:30.415	debug	MIIO RECIVE: {"result":["robomap%2F260658891%2F4"],"id":44}
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:30.408	debug	Message= {"id":44,"method":"get_map_v1"}
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:30.407	debug	MIIO RECIVE: {"result":[90],"id":43}
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:30.402	debug	Message= {"id":43,"method":"get_sound_volume"}
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:30.315	debug	MIIO RECIVE: {"result":{"ssid":"HomeCinemaHD","ip":"192.168.178.31","mac":"50:ec:50:08:9b:a4","bssid":"44:4e:6d:d6:ed:b9","rssi":-55},"id":42}
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:30.294	debug	Message= {"id":42,"method":"get_network_info"}
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:30.293	debug	setGetStatus {"msg_ver":3,"msg_seq":2560,"state":8,"battery":100,"clean_time":2435,"clean_area":45957500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"lock_status":0,"error_text":"No error"}
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:30.292	debug	MIIO RECIVE: {"result":[{"msg_ver":3,"msg_seq":2560,"state":8,"battery":100,"clean_time":2435,"clean_area":45957500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":41}
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:30.283	debug	Message= {"id":41,"method":"get_status"}
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:30.282	debug	get params for stock Vacuum
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:28.399	debug	Receive <<< Helo <<< 21310020000000000f8956cb61e8467cffffffffffffffffffffffffffffffff
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:18.393	debug	Receive <<< Helo <<< 21310020000000000f8956cb61e84672ffffffffffffffffffffffffffffffff
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:10.338	debug	CanvasMap not loaded
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:10.338	debug	update_Map got new time:1642612330
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:10.338	debug	update_Map got new expires:1642614130
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:10.337	debug	update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/260658891/3?Expires=1642614130000&GalaxyAccessKeyId=5271733786445&Signature=ggyWlvJatkolUOotv8mIyeSdqhY=
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:10.280	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":40}
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:10.265	debug	Message= {"id":40,"method":"get_carpet_mode"}
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:10.265	debug	update_Map need new mapurl
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:10.264	debug	update_Map Mimap enabled
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:10.264	debug	Mappointer_updated
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:10.264	debug	MIIO RECIVE: {"result":["robomap%2F260658891%2F3"],"id":39}
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:10.256	debug	Message= {"id":39,"method":"get_map_v1"}
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:10.255	debug	MIIO RECIVE: {"result":[90],"id":38}
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:10.244	debug	Message= {"id":38,"method":"get_sound_volume"}
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:10.154	debug	MIIO RECIVE: {"result":{"ssid":"HomeCinemaHD","ip":"192.168.178.31","mac":"50:ec:50:08:9b:a4","bssid":"44:4e:6d:d6:ed:b9","rssi":-55},"id":37}
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:10.126	debug	Message= {"id":37,"method":"get_network_info"}
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:10.125	debug	setGetStatus {"msg_ver":3,"msg_seq":2559,"state":8,"battery":100,"clean_time":2435,"clean_area":45957500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"lock_status":0,"error_text":"No error"}
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:10.124	debug	MIIO RECIVE: {"result":[{"msg_ver":3,"msg_seq":2559,"state":8,"battery":100,"clean_time":2435,"clean_area":45957500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":36}
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:10.116	debug	Message= {"id":36,"method":"get_status"}
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:10.115	debug	get params for stock Vacuum
                                  mihome-vacuum.0
                                  	2022-01-19 18:12:08.386	debug	Receive <<< Helo <<< 21310020000000000f8956cb61e84668ffffffffffffffffffffffffffffffff
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:58.380	debug	Receive <<< Helo <<< 21310020000000000f8956cb61e8465effffffffffffffffffffffffffffffff
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:50.223	debug	CanvasMap not loaded
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:50.223	debug	update_Map got new time:1642612310
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:50.223	debug	update_Map got new expires:1642614110
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:50.223	debug	update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/260658891/2?Expires=1642614110000&GalaxyAccessKeyId=5271733786445&Signature=NmK0GiGHwdNuut5JCDNez8UP85k=
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:50.113	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":35}
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:50.108	debug	Message= {"id":35,"method":"get_carpet_mode"}
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:50.107	debug	update_Map need new mapurl
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:50.107	debug	update_Map Mimap enabled
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:50.106	debug	Mappointer_updated
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:50.106	debug	MIIO RECIVE: {"result":["robomap%2F260658891%2F2"],"id":34}
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:50.100	debug	Message= {"id":34,"method":"get_map_v1"}
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:50.100	debug	MIIO RECIVE: {"result":[90],"id":33}
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:50.094	debug	Message= {"id":33,"method":"get_sound_volume"}
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:50.001	debug	MIIO RECIVE: {"result":{"ssid":"HomeCinemaHD","ip":"192.168.178.31","mac":"50:ec:50:08:9b:a4","bssid":"44:4e:6d:d6:ed:b9","rssi":-55},"id":32}
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:49.977	debug	Message= {"id":32,"method":"get_network_info"}
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:49.977	debug	setGetStatus {"msg_ver":3,"msg_seq":2558,"state":8,"battery":100,"clean_time":2435,"clean_area":45957500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"lock_status":0,"error_text":"No error"}
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:49.976	debug	MIIO RECIVE: {"result":[{"msg_ver":3,"msg_seq":2558,"state":8,"battery":100,"clean_time":2435,"clean_area":45957500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":31}
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:49.969	debug	Message= {"id":31,"method":"get_status"}
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:49.969	debug	get params for stock Vacuum
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:48.375	debug	Receive <<< Helo <<< 21310020000000000f8956cb61e84654ffffffffffffffffffffffffffffffff
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:38.368	debug	Receive <<< Helo <<< 21310020000000000f8956cb61e8464affffffffffffffffffffffffffffffff
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:36.925	debug	CanvasMap not loaded
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:36.924	debug	update_Map got new time:1642612296
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:36.924	debug	update_Map got new expires:1642614096
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:36.924	debug	update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/260658891/1?Expires=1642614096000&GalaxyAccessKeyId=5271733786445&Signature=KVaLIUbGDhanb4MwkCqUzCxeesM=
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:36.810	debug	update_Map need new mapurl
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:36.810	debug	update_Map Mimap enabled
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:36.809	debug	Mappointer_updated
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:36.809	debug	MIIO RECIVE: {"result":["robomap%2F260658891%2F1"],"id":30}
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:36.803	debug	Message= {"id":30,"method":"get_map_v1"}
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:36.803	debug	command: loadMap parent: cleanmap
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:33.222	debug	command: loadMap parent: cleanmap
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:30.093	debug	CanvasMap not loaded
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:30.093	debug	update_Map got new time:1642612289
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:30.093	debug	update_Map got new expires:1642614090
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:30.093	debug	update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/260658891/0?Expires=1642614090000&GalaxyAccessKeyId=5271733786445&Signature=MQqkblgwdvXvb7rNnWCf6LiF7ug=
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:29.967	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":29}
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:29.960	debug	Message= {"id":29,"method":"get_carpet_mode"}
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:29.959	debug	update_Map need new mapurl
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:29.959	debug	update_Map Mimap enabled
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:29.959	debug	Mappointer_updated
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:29.958	debug	MIIO RECIVE: {"result":["robomap%2F260658891%2F0"],"id":28}
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:29.952	debug	Message= {"id":28,"method":"get_map_v1"}
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:29.951	debug	MIIO RECIVE: {"result":[90],"id":27}
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:29.946	debug	Message= {"id":27,"method":"get_sound_volume"}
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:29.858	debug	MIIO RECIVE: {"result":{"ssid":"HomeCinemaHD","ip":"192.168.178.31","mac":"50:ec:50:08:9b:a4","bssid":"44:4e:6d:d6:ed:b9","rssi":-55},"id":26}
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:29.837	debug	Message= {"id":26,"method":"get_network_info"}
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:29.836	debug	setGetStatus {"msg_ver":3,"msg_seq":2557,"state":8,"battery":100,"clean_time":2435,"clean_area":45957500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":false,"map_status":3,"lock_status":0,"error_text":"No error"}
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:29.836	debug	MIIO RECIVE: {"result":[{"msg_ver":3,"msg_seq":2557,"state":8,"battery":100,"clean_time":2435,"clean_area":45957500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":25}
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:29.825	debug	Message= {"id":25,"method":"get_status"}
                                  mihome-vacuum.0
                                  	2022-01-19 18:11:29.825	debug	get params for stock Vacuum
                                  • D3ltoroxpD D3ltoroxp
                                    Log-Größe: 2.4 MB
                                    Zeit
                                    Nachricht
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    mihome-vacuum.0
                                    DarkDevil
                                    #599
                                    @d3ltoroxp so schaut’s bei mir auch aus
                                    • D Nicht stören
                                      D Nicht stören
                                      dirkhe
                                      #600
                                      @d3ltoroxp da steht doch, dass er canvas nicht laden konnte, also erstmal das zum laufen bringen, wie das geht gibt es zig Beiträge hier. Gibt halt unterschiedliche Ursachen dafür
                                      • MeistertrM Offline
                                        MeistertrM Offline
                                        Meistertr
                                        #601
                                        das Problem ist, dass cavas für arm nciht mehr unterstützt wird suche da gerade nach einer Lösung oder alternative... bin schon am überlegen die Map komplett raus zu nehmen bei arm Installationen...
                                        bahnuhrB Thomas BraunT D 3 Antworten Letzte Antwort
                                          bahnuhrB Online
                                          bahnuhrB Online
                                          bahnuhr
                                          #602
                                          @meistertr sagte in Test Adapter Mihome-vacuum v3.1.6 Next Generarition:
                                          arm Installation
                                          was ist eine "arm" Installation ?
                                          Wäre doch äußerst schade wenn die map nicht mehr funktionieren würde.
                                          Danke.
