  4. ESP Matrix Anzeige fully IoBroker steuerbar
esp8266matrix displaymax 7219
460 Beiträge 31 Kommentatoren 145.5k Aufrufe 45 Beobachtet
  • R Rushmed
    @liv-in-sky Gib dann mal Rückinfo obs läuft, wieviele Module du angeschlossen hast und ob die Initialisierung immer klappt.
    liv-in-skyL Offline
    liv-in-skyL Offline
    #257
    @rushmed wie erwähnt - dauert ein wenig - wo stelle ich eigentlich ein, wieviele module dranhängen - bei mir 8 - teste erstmal mit dem "kleinen" - die große matrix hat ja 16 einzelmodule (4mal4er)
    • R Rushmed
      liv-in-skyL Offline
      liv-in-skyL Offline
      #258
      @rushmed hast du den tm1637 aus deiner bin entfernt ?
      R 1 Antwort Letzte Antwort
      • liv-in-skyL liv-in-sky
        Rushmed
        #259
        @liv-in-sky Nein ich habe nichts entfernt.
        Hier die Anleitung:
          Assign the pins as follows from Tasmota's GUI:
          DIN hardware pin --> "MAX7219 DIN"
          CS hardware pin --> "MAX7219 CS"
          CLK hardware pin --> "MAX7219 CLK"
          Once the GPIO configuration is saved and the ESP8266/ESP32 module restarts,
          set the Display Model to 19 and Display Mode to 0
          Depending on order of the wired 8x8 matrix modules you have got a display of size pixel_width x pixel_height.
          The size has to be set with the commands "DisplayWidth <pixel_width>" and "DisplayHeight <pixel_height>"
          After the ESP8266/ESP32 module restarts again, turn ON the display with the command "Power 1"
          Now, the following "Display" commands can be used:
          DisplayText  text
            Sends the text to the display.
            If the text fits into the display, it is shown in the center.
            Otherwise it scrolls to the left and repeats as long it is cleared or new "DisplayText" overwrites it.
          DisplayDimmer [0..100]
            Sets the intensity of the display.
          DisplayBlinkrate [0..3]
            0: not blinking
            1: slow, 2: medium 3: fast blinking
          Power [ON|OFF]
            Sitches the display on or off. When "off", the display buffer is not cleared and will be shown again when after "Power ON".
            Other display commands are still active when off.
          DisplayClear
            Clears the display
          DisplayScrollDelay [0..15]   // default = 0
            Sets the speed of text scroll. Smaller delay = faster scrolling.
            The maximum scroll speed is 50ms per pixel on DisplayScrollDelay 0.
          DisplayWidth [8..256]
            Sets the pixel width of the display (8x number of modules in a row)
          DisplayHeight [8..256]
            Sets the pixel height of the display (8x number of module rows)
          DisplayRotate [0|2]
            0: normal orientation; devide 0 starts at top left
            2: upside down; device 0 starts at bottom right
          DisplayClock  [0|1|2]
            Displays a clock.
            Commands "DisplayClock 1"     // 12 hr format
                    "DisplayClock 2"     // 24 hr format
                    "DisplayClock 0"     // turn off clock; please use additional cammand: DisplayMode 0
          If you would like to use the UTF8 latin1 character set, it cam be added by copile option:
          #define USE_UTF8_LATIN1
        • R Rushmed
          Hier die Anleitung:
            DisplayText  text
              0: not blinking
            Power [ON|OFF]
            DisplayClear
              Clears the display
            DisplayRotate [0|2]
              Displays a clock.
          liv-in-skyL Offline
          liv-in-skyL Offline
          #260
          @rushmed könntest du bitte die tm1637 noch aktivieren in deiner bin
          Ich bekomme es irgendwie nicht hin
            Rushmed
            #261
            @liv-in-sky Wo hängts denn? Man muss doch nur die Zeilen einfügen.
            • R Rushmed
              liv-in-skyL Offline
              liv-in-skyL Offline
              #262
              @rushmed bei allem , was mit arduino zu tun hat :-(
                Rushmed
                #263
                @liv-in-sky Das geht mir auch so aber mit Gitpod isses in diesem Fall hier einfach.
                Ich setz mich dann mal ran.
                • R Rushmed
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  #264
                  @rushmed sagte in ESP Matrix Anzeige fully IoBroker steuerbar:
                  Gitpod isses
                  noch was neues ?
                  wäre echt nett von dir - ich bräuchte nur die max7219 und die tm1637 - und das alles in einer bin - dann bin ich schon happy
                    Gitpod isses
                    noch was neues ?
                    Rushmed
                    schrieb am zuletzt editiert von Rushmed
                    #265
                    @liv-in-sky Prego!
                    tasmota-display.bin
                    liv-in-skyL W 2 Antworten Letzte Antwort
                    • R Rushmed
                      @liv-in-sky Prego!
                      tasmota-display.bin
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      #266
                      @rushmed tausend dank - du rettest mir den tag
                      teste gleich
                        teste gleich
                        Rushmed
                        #267
                        @liv-in-sky Dann kannste dich hier noch über die Verwendung von Gitpod für Tasmota belesen.
                        • R Rushmed
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          #268
                          @rushmed
                          leider kein tm1637 - der 7219 ist da - evtl geht beides nicht gleichzeitig ?
                            @rushmed
                            Rushmed
                            #269
                            @liv-in-sky Findest du es in der vorkompilierten display bin?
                            • R Rushmed
                              liv-in-skyL Offline
                              liv-in-skyL Offline
                              #270
                              @rushmed ja - da ist es drin (aber die befehle in der console funktioniert nicht - erkennt command nicht)aber der 7219 ist nicht drin
                              habe deine letzte bin getestet mit 7219 - funktioniert nicht - alle leds leuchten - immer !
                              was bei deiner version auch nicht da ist, im gegensatz zu bin von tasmota download ist der datenpunkt command - der erscheint nicht
                                Rushmed
                                #271
                                @liv-in-sky alle LEDs leuchten immer ist das Symptom mit dem initialisierungsfehler die LEDs müssen vor dem ESP Strom haben
                                Der datenpunkt command erscheint bei mir wenn es das erste Kommando eingegeben habe
                                • R Rushmed
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  #272
                                  @rushmed
                                  aber lass gut sein - das ist mir zu viel zeitaufwand im moment - mach ich mal in ruhe, wenn ich mehr lust dazu habe
                                  • R Rushmed
                                    @liv-in-sky Prego!
                                    tasmota-display.bin
                                    W Offline
                                    W Offline
                                    Wolfi
                                    #273
                                    @rushmed
                                    Also dein tasmota-display.bin funktioniert.
                                    Super vielen Dank!
                                    Auch via iobroker bzw. MQTT.
                                    Muss mich jetzt endlich mal wieder mit der Entwicklung Umgebung beschäftigen bzw. installieren.
                                    Gibt es eine Gute Anleitung für die Installation bzw. wichtiger die richtige Integration von Tasmota in die Umgebung?
                                    Entweder für Visual Studio (PlatformIO) oder Arduino!
                                    liv-in-skyL R 2 Antworten Letzte Antwort
                                    • W Wolfi
                                      @rushmed
                                      Super vielen Dank!
                                      liv-in-skyL Offline
                                      liv-in-skyL Offline
                                      #274
                                      @wolfi
                                      du glücklicher - ich habe das mit den 7219ern nicht hinbekommen
                                      W 1 Antwort Letzte Antwort
                                      • W Wolfi
                                        @rushmed
                                        Super vielen Dank!
                                        Rushmed
                                        #275
                                        @wolfi wie gesagt tasmota kompiliere ich mit Gitpod, das ist einfach ein browser-add-on, den Link habe ich weiter oben mit tasmota Anleitung schon gepostet das ist echt einfach.
                                          @wolfi
                                          W Offline
                                          W Offline
                                          Wolfi
                                          #276
                                          @liv-in-sky
                                          Kann ich dir Helfen?
                                          Brauchst du Infos von mir?
                                          Gruss
                                          Wolfgang
