[Verkaufe] Zigbee LAN/USB/WLAN Gateway CC2652P
@dimaiv Die Lieferung war sagenhaft schnell! Super.
Leider bring ich den Adapter nicht zum Laufen.
Hab mal das Protokoll rauskopiert. Vielleicht siehst Du ja gleich, wo der Fehler ist.zigbee.1 2022-01-05 18:30:42.328 error Error herdsman start zigbee.1 2022-01-05 18:30:42.327 error Failed to start Zigbee zigbee.1 2022-01-05 18:30:42.326 error Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)" zigbee.1 2022-01-05 18:30:36.289 debug zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32] zigbee.1 2022-01-05 18:30:36.288 debug zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1} zigbee.1 2022-01-05 18:30:30.284 debug zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32] zigbee.1 2022-01-05 18:30:30.282 debug zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1} zigbee.1 2022-01-05 18:30:24.279 debug zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32] zigbee.1 2022-01-05 18:30:24.278 debug zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1} zigbee.1 2022-01-05 18:30:24.277 debug zigbee-herdsman:adapter:zStack:znp:log Skip bootloader for CC2652/CC1352 zigbee.1 2022-01-05 18:30:23.280 info Installed Version: iobroker.zigbee@1.6.6 zigbee.1 2022-01-05 18:30:23.279 debug zigbee-herdsman:adapter:zStack:znp:log Port closed zigbee.1 2022-01-05 18:30:23.275 debug zigbee-herdsman:adapter:zStack:unpi:writer --> buffer [239] zigbee.1 2022-01-05 18:30:23.274 debug zigbee-herdsman:adapter:zStack:znp:log Writing CC2530/CC2531 skip bootloader payload zigbee.1 2022-01-05 18:30:23.273 debug zigbee-herdsman:adapter:zStack:znp:log Socket ready zigbee.1 2022-01-05 18:30:23.272 debug zigbee-herdsman:adapter:zStack:znp:log Socket connected zigbee.1 2022-01-05 18:30:23.268 debug zigbee-herdsman:adapter:zStack:znp:log Opening TCP socket with 192.168.0.251:6638 zigbee.1 2022-01-05 18:30:23.267 debug zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"panID":6755,"extendedPanID":[0,18,75,0,37,143,31,182],"channelList":[12]},"serialPort":{"baudRate":115200,"rtscts":false,"path":"tcp://192.168.0.251:6638","adapter":"zstack"},"databasePath":"/opt/iobroker/iobroker-data/zigbee_1/shepherd.db","databaseBackupPath":null,"backupPath":"/opt/iobroker/iobroker-data/zigbee_1/nvbackup.json","adapter":{"disableLED":false,"forceStartWithInconsistentAdapterConfiguration":false},"acceptJoiningDeviceHandler":null}' zigbee.1 2022-01-05 18:30:23.265 debug Starting zigbee-herdsman... zigbee.1 2022-01-05 18:30:23.265 info Starting Zigbee npm ... zigbee.1 2022-01-05 18:30:23.264 info Try to reconnect.@gr , auch an die, die zu gleiche Situation kommen.
Hi. Ja, mittlerweile weiß ich zu 100% wie man zu deiner Situation kommt. Hier: während aller erstes Zigbee Adapter Start mit nagelneuem Zigbee Stick / Gateway hat man kein Geduld und zieht nach 15-30 Sekunden den Stick ab oder beim Gateway zieht man den Strom ab. Dann wird in dem Zigbee Modul NVRAM zerstört. Ohne es zu löschen startet das Modul nicht mehr. Dann wird es behauptet das der Stick/Gateway keine Firmware drauf hat.
Das schlimmste: es wird dann versucht das Modul mit irgendeinem Firmware zu flashen, und wenn es nicht die richtige erwischt wird, wird der Stick als defekt deklariert. -
Am besten immer mich direkt kontaktieren.Im zweiten Post von mir ist Multitool verlinkt, damit kann man vieles machen. In deinem Fall glaube ich, reicht nur NVRAM ERASE durchführen.
Dabei ist wichtig, Zigbee Adapter / Instanz muss gestoppt sein!!!Wenn du oder jemand andere damit nicht klar kommt, bitte mich direkt kontaktieren. 1 Post irgendwo im Forum kann ich nicht sofort merken/lesen.
@gr
@gr
@dimaiv Danke für die schnelle Lieferung, Freitag bestellt, Samstag bekommen. Super
Was noch besser ist, ich hatte ja vorher den USB CC2538+CC2592 PA Zigbee Stick und immer wieder mal Probleme mit dem finden des Sticks egal in welcher der verschiedenen Möglichkeiten der Adresseingabe. Jetzt per LAN wird er gefunden.
War schon kurz davor Zigbee zu entfernen und komplett auf EnOcean oder HM umzuschwenken.Angeschlossen, Adresse eingegeben, ca. 1 Min. gewartet (WICHTIG! bis zu 3 Min.), dann wurden alle meine Geräte übernommen ohne das ich was machen musste.
Was soll ich sagen, bin begeistert Empfangswerte von über 100 hatte ich noch nie, meist bis max. 60, jetzt ist 60 bis auf einzelne Ausnahmen das untere Level.Schöne Grüße
Christian -
Christian[/OT]
@csr sagte in [Verkaufe] Zigbee LAN/USB/WLAN Gateway CC2652P:Was noch besser ist, ich hatte ja vorher den USB CC2538+CC2592 PA Zigbee Stick und immer wieder mal Probleme mit dem finden des Sticks egal in welcher der verschiedenen Möglichkeiten der Adresseingabe. Jetzt per LAN wird er gefunden.
War schon kurz davor Zigbee zu entfernen und komplett auf EnOcean oder HM umzuschwenken.Behaupte mal: Alles Linuxprobleme bzw. Durchreichen in VM, Container, Docker etc. Hat nichts mit dem Stick oder Zigbee zu tun. Bei mir unter Win liefen auch die anderen Sticks einwandfrei.
Ist aber gefühlt die Ursache 80% aller Beschwerden über Zigbee in diesem Forum und kann den Spass an Zigbee verderben - zu Unrecht.
Deshalb finde ich es so gut, daß @dimaiv diese Möglichkeit hier eröffnet hat. -
@klassisch sagte in [Verkaufe] Zigbee LAN/USB/WLAN Gateway CC2652P:
[/OT]
Deshalb finde ich es so gut, daß @dimaiv diese Möglichkeit hier eröffnet hat.Ich möchte hier keine große Diskussion anfangen und den Thread sprengen, nur bestätigen ;-) .
USB- Leseköpfe werden durchgereicht und ohne Probleme erkannt, nur beim Zigbee-Stick gabs Probleme. Irgendwo hier gabs mal einen Thread in dem das Problem mit dem "alten" Chip bei Neuverbindung nach reboot oder so beschrieben wurde, leider finde ich das nicht.
Und genau deshalb finde ich die Lösung wie du selber schreibst sehr gut. Auch im Hinblick auf die Platzierung, die jetzt übers Netzwerk noch flexibler ist. (meiner ist am gleichen fleck geblieben) -
Hersteller " Ich " Model "CC2652P + WT32-ETH01, Einsatzbereit" Anzahl 1, Sofort verfügbar *Preis pro Stück 60 €, Anfragen über Chat Nachricht oder Telegramm: https://t.me/Zigbee1 Versand "in DE inkl., mit Verfolgungsnummer" Beschreibung "Leistungsstarke ZigBee Stick / LAN Gateway mit Z-Stack 3.x.0, Update über LAN/USB, mit 3 dBi Antenne und Gehäuse"
Es gibt ab sofort Diskussion-Thread:
FAQ. Zigbee Gateway@dimaiv hab ihn erhalten, danke
gestern angelegt, nach ein paar Minuten wurde er im ioBroker erkannt
keiner meiner Sensoren war aktiv verbunden, dachte mir, nee das mach ich heute nicht mehr, geh lieber ein
trinken
heute sind bereits fast alle drin, welch wunderbare Art und Weise
den Türkonakt muss ich nur mal anstoßen was zu senden, denke dann ist auch der letzte drin. -
trinken
den Türkonakt muss ich nur mal anstoßen was zu senden, denke dann ist auch der letzte drin.@dimaiv Empfiehlt sich ein Update auf Firmware CC1352P2_CC2652P_launchpad_coordinator_20220103.zip ? Meiner hat derzeit die Ver 20210708 drauf.
@alexathome
Ich würde deine Firmware erst updaten, wenn man dazu gezwungen ist. Zum Beispiel, wenn man das ganze Zigbee Geschichte neu einrichtet, oder man holt die neuen Aqara Geräte Serie E1 (die brauchen unbedingt neuere Firmware ab version 20211217) -
@alexathome
Ich würde deine Firmware erst updaten, wenn man dazu gezwungen ist. Zum Beispiel, wenn man das ganze Zigbee Geschichte neu einrichtet, oder man holt die neuen Aqara Geräte Serie E1 (die brauchen unbedingt neuere Firmware ab version 20211217)@dimaiv Okidoki :-) Danke für Deine Antwort!
Mal ne Frage in die Runde. Bei mir schmiert das Gateway alle paar Tage ab. Ist erst nicht per WebInterface erreichbar (ping geht noch, Adapter läuft auch noch), aber dann bleibt auch der hängen.
Jetzt ist mir aufgefallen, dass die Anzahl der Socket-Verbindungen hoch zählt. Solange der Adapter noch nicht läuft, steht der auf 0. Wenn ich den Adapter starte, kommt da ne 1. Heute morgen ist da aber schon wieder ne 2. Meine mich zu erinnern, da auch schonmal eine 6 gesehen zu haben.
Irgendne Idee? Gibt es eigentlich irgendne Art von Logfiles?
@holgerwolf
Netzteil wechseln. Kein Handy-Ladegerät benutzen! -
@holgerwolf
Netzteil wechseln. Kein Handy-Ladegerät benutzen!@dimaiv Wieviel Watt braucht das GW? Was zeichnet ein "nicht Handy-Ladegerät" aus?
@holgerwolf sagte in [Verkaufe] Zigbee LAN/USB/WLAN Gateway CC2652P:
<1 Watt
läuft dein iobroker zufällig in einer VM mit proxmox?
@saeft_2003 Ja. Jetzt wirds spannend ;-)
In der tat. Weil wenn es nicht das Netzteil sein sollte, könnte auch proxmox Schuld sein. War bei mir der Fall. Schau mal ob du im proxmox syslog sowas findest.
Detected Hardware Unit HangJun 14 12:43:13 pve-1 kernel: e1000e 0000:00:1f.6 eno1: Detected Hardware Unit Hang: TDH <2> TDT <45> next_to_use <45> next_to_clean <1> buffer_info[next_to_clean]: time_stamp <101dbc441> next_to_watch <2> jiffies <101dbc5a8> next_to_watch.status <0> MAC Status <40080083> PHY Status <796d> PHY 1000BASE-T Status <7800> PHY Extended Status <3000> PCI Status <10> Jun 14 12:43:15 pve-1 kernel: e1000e 0000:00:1f.6 eno1: Detected Hardware Unit Hang: TDH <2> TDT <45> next_to_use <45> next_to_clean <1> buffer_info[next_to_clean]: time_stamp <101dbc441> next_to_watch <2> jiffies <101dbc7a1> next_to_watch.status <0> MAC Status <40080083> PHY Status <796d> PHY 1000BASE-T Status <7800> PHY Extended Status <3000> PCI Status <10> -
Detected Hardware Unit HangJun 14 12:43:13 pve-1 kernel: e1000e 0000:00:1f.6 eno1: Detected Hardware Unit Hang: TDH <2> TDT <45> next_to_use <45> next_to_clean <1> buffer_info[next_to_clean]: time_stamp <101dbc441> next_to_watch <2> jiffies <101dbc5a8> next_to_watch.status <0> MAC Status <40080083> PHY Status <796d> PHY 1000BASE-T Status <7800> PHY Extended Status <3000> PCI Status <10> Jun 14 12:43:15 pve-1 kernel: e1000e 0000:00:1f.6 eno1: Detected Hardware Unit Hang: TDH <2> TDT <45> next_to_use <45> next_to_clean <1> buffer_info[next_to_clean]: time_stamp <101dbc441> next_to_watch <2> jiffies <101dbc7a1> next_to_watch.status <0> MAC Status <40080083> PHY Status <796d> PHY 1000BASE-T Status <7800> PHY Extended Status <3000> PCI Status <10>@saeft_2003 Treffer:
Jan 20 13:01:16 pve2 kernel: e1000e 0000:00:1f.6 eno1: Detected Hardware Unit Hang: TDH <81> TDT <b9> next_to_use <b9> next_to_clean <80> buffer_info[next_to_clean]: time_stamp <107e2fcf6> next_to_watch <81> jiffies <107e2fe18> next_to_watch.status <0> MAC Status <40080083> PHY Status <796d> PHY 1000BASE-T Status <3800> PHY Extended Status <3000> PCI Status <10>Was hast du gemacht? Aber warum hängt sich dann auch das GW auf? Ich komme da ja auch nicht mehr aufs Webinterface.
Bring erstmal proxmox in Ordnung.
https://forum.proxmox.com/threads/e1000-driver-hang.58284/page-8
Du musst das aber in deine interfaces packen sonst ist es nach einem Neustart wieder weg.
auto lo iface lo inet loopback iface eno1 inet manual offload-gso off offload-gro off offload-tso off offload-rx off offload-tx off offload-rxvlan off offload-txvlan off offload-sg off offload-ufo off offload-lro off auto vmbr0 iface vmbr0 inet static address 192.168.178.101/24 gateway 192.168.178.1 bridge_ports eno1 bridge_stp off bridge_fd 0
