  5. [Gelöst] Mal wieder IDs vom Selektor
    6.6k
33 Beiträge 5 Kommentatoren 4.0k Aufrufe 4 Beobachtet
  • O oFbEQnpoLKKl6mbY5e13
    Muss ich noch was anpassen?
    javascript.0	2021-03-11 21:04:13.491	error	(343) at processImmediate (internal/timers.js:458:21)
    javascript.0	2021-03-11 21:04:13.491	error	(343) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1238:17)
    javascript.0	2021-03-11 21:04:13.491	error	(343) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1722:17
    javascript.0	2021-03-11 21:04:13.491	error	(343) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1621:37)
    javascript.0	2021-03-11 21:04:13.490	error	(343) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1383:28)
    javascript.0	2021-03-11 21:04:13.490	error	(343) at Object.createScript (vm.js:263:10)
    javascript.0	2021-03-11 21:04:13.490	error	(343) at new Script (vm.js:88:7)
    javascript.0	2021-03-11 21:04:13.489	error	(343) SyntaxError: missing ) after argument list
    javascript.0	2021-03-11 21:04:13.489	error	(343) ^
    javascript.0	2021-03-11 21:04:13.489	error	(343) id = id.substring(0, id.lastIndexOf('.');
    javascript.0	2021-03-11 21:04:13.488	error	(343) script.js.common.Tests.Test_3 compile failed: at script.js.common.Tests.Test_3:5
    @ofbeqnpolkkl6mby5e13 sagte: missing ) after argument list
    Sorry, habe schließende Klammern vergessen: Ist oben korrigiert.
    O 1 Antwort Letzte Antwort
      O Abwesend
      O Abwesend
      Das hatte ich auch schon versucht, aber dann kommt:
      javascript.0	2021-03-11 21:19:49.768	error	(343) at Script.runInContext (vm.js:131:20)
      javascript.0	2021-03-11 21:19:49.767	error	(343) at script.js.common.Tests.Test_3:34:3
      javascript.0	2021-03-11 21:19:49.767	error	(343) at script.js.common.Tests.Test_3:31:2
      javascript.0	2021-03-11 21:19:49.767	error	(343) script.js.common.Tests.Test_3: ReferenceError: obj is not defined
        @ofbeqnpolkkl6mby5e13 sagte: ReferenceError: obj is not defined
        Wo wird die Variable obj verwendet?
        Erzeugter Javascript-Code?
        O 2 Antworten Letzte Antwort
          O Abwesend
          O Abwesend
          Ach Mist, ein freischwebendes "Objekt ID" vergessen zu deaktivieren. :man-facepalming:
            O Abwesend
            O Abwesend
            javascript.0	2021-03-11 21:25:14.031	info	(343) script.js.common.Tests.Test_3: Fenster Rechts
            Ganz herzlichen Dank! 👍
            • O Abwesend
              O Abwesend
              Ich habe noch mal eine Frage, die nur indirekt mit IDs vom Selektor zusammenhängt. Wenn ich alle Mitglieder (members) einer Aufzählung mit der id "enum.functions.Button" ausgeben will, dann kann ich das problemlos im Selektor mit (functions=Button) machen.
              Aber wie adressiert man eine verschachtelte Aufzählung wie "enum.functions.house.light"?
                @ofbeqnpolkkl6mby5e13 sagte: wie adressiert man eine verschachtelte Aufzählung wie "enum.functions.house.light"?
                Ich habe zwar keine "verschachtelten" Aufzählungen, aber funktioniert es nicht mit (functions=house.light)?
                Ich würde auch nicht verschachteln, sondern "enum.rooms.house" zuweisen.
                  O Abwesend
                  O Abwesend
                  Nein, das funktioniert leider nicht.
                  Ich muss ein Zweifamilienhaus mit 3 Wohnungen abdecken. Ohne eine strukturierte Aufzählung bin ich "verloren".
                    @ofbeqnpolkkl6mby5e13 sagte: Ohne eine strukturierte Aufzählung bin ich "verloren".
                    Die Aufzählungen sind nicht für "Verschachtelung" ausgelegt. Man kann höchstens über die Namen strukturieren, z.B. mittels Unterstrich im Namen "house_light".
                      O Abwesend
                      O Abwesend
                      Okay, danke!
                      Allerdings stellt sich dann schon die Frage, weshalb man die dann überhaupt verschachteln kann...
                        Okay, danke!
                        @ofbeqnpolkkl6mby5e13 sagte: weshalb man die dann überhaupt verschachteln kann...
                        Kann man das? Wenn ich eine ID mit Punkt eingebe, wird daraus automatisch ein Unterstrich. Bei Erstellung im Tab "Objekte" wird allerdings nicht geprüft.
                          O Abwesend
                          O Abwesend
                          Ja, man kann einfach entweder eine Aufzählung mit der Maus auf eine andere ziehen oder direkt eine Art "Unterkategorie" einer Aufzählung erstellen. Jeweils wird die ID vererbt.
                          Mein Gedanke war:
                          Haus - Licht
                                       - Obergeschoss
                                          - Küche
                                       - Erdgeschoss
                                          - Küche
                                       - Keller
                                          - Küche
                                  - Fenster
                                       - Obergeschoss
                                          - Küche
                                       - Erdgeschoss
                                         - Küche
                                       - Keller
                                         - Küche
                                  - Steckdose
                                       - Obergeschoss
                                          - Küche
                                       - Erdgeschoss
                                          - Küche
                                       - Keller
                                          - Küche
                          usw.
                            Mein Gedanke war:
                            Haus - Licht
                                         - Obergeschoss
                                            - Küche
                                         - Erdgeschoss
                                            - Küche
                                         - Keller
                                            - Küche
                                    - Fenster
                                         - Obergeschoss
                                            - Küche
                                         - Erdgeschoss
                                           - Küche
                                         - Keller
                                           - Küche
                                    - Steckdose
                                         - Obergeschoss
                                            - Küche
                                         - Erdgeschoss
                                            - Küche
                                         - Keller
                                            - Küche
                            usw.
                            @ofbeqnpolkkl6mby5e13 sagte: Mein Gedanke war:
                            Aus diesem Gedanken würde ich die Gewerke Licht, Fenster, Steckdosen und die Räume (Orte) Haus1_OG_Kueche, Haus1_EG_Kueche, Haus1_Keller_Kueche machen.
                            Wenn man mit Alias arbeitet, kann man auch die IDs entsprechend strukturieren, was den Vorteil hat, dass man im Selektor Wildcards (*) verwenden kann.
                              O Abwesend
                              O Abwesend
                              Okay, danke. Aliase habe ich in der Form natürlich bereits vorliegen.
                                O Abwesend
                                O Abwesend
                                Ob es sich lohnt, einen neuen Thread zu erstellen, um mal von einem Entwickler zu hören, weshalb man Aufzählungen mit der GUI verschachteln kann, diese dann aber nicht absolut adressieren kann?
                                Edit:
                                Oder ist das eher ein Problem des Blockly-Bausteins?
                                Gibt es dazu eine Javascript-Funktion?
                                Edit2:
                                Geht mit Javascript auch nicht:
                                var i;
                                var i_list = Array.prototype.slice.apply($("(functions=house.light)"));
                                for (var i_index in i_list) {
                                  i = i_list[i_index];
                                  console.log(i);
                                  Edit:
                                  Edit2:
                                  var i;
                                    console.log(i);
                                  @ofbeqnpolkkl6mby5e13 sagte: Geht mit Javascript auch nicht:
                                  Ich hatte es mit Javascript getestet.
                                    O Abwesend
                                    O Abwesend
                                    Ah, okay.
                                      Ah, okay.
                                      O Abwesend
                                      O Abwesend
                                      @Bluefox @foxriver76 @apollon77
                                      Man kann mit dem Admin eine solche Aufzählungshierarchie erstellen. Abfragen kann man sie allerdings nicht. Wieso nicht?
                                      Aufzählung
                                        Aufzählung
                                        foxriver76F Offline
                                        foxriver76F Offline
                                        foxriver76
                                        @ofbeqnpolkkl6mby5e13 Inwiefern nicht abfragen? Wie im Objekte Tab auch stellt jeder . eine neue Hierarchie dar. Oder meinst du es fehlt eine convinience Funktion im Script Adapter?
                                        Videotutorials & mehr
                                        • foxriver76F foxriver76
                                          O Abwesend
                                          O Abwesend
                                          @foxriver76
                                          Mit dem Blockly-Baustein "IDs vom Selektor" oder direkt mittels Javascript kann man solche Aufzählungen abfragen. Die Mitglieder der Aufzählung werden dann dadurch ermittelt. Das geht aber nur auf der ersten Ebene. In dem obigen Bild mit "enum.functions.house" schon "enum.functions.house.light" funktioniert leider nicht.
