  4. Alpha Testing: OCPP Wallbox Adapter
    6.3k
ocppwallboxadapter
448 Beiträge 49 Kommentatoren 152.4k Aufrufe 47 Beobachtet
  • S schwimbi
    @foxriver76
    root@r01iobroker:/opt/iobroker# ps -aux | grep ocpp
    ps -aux | grep ocpp
    iobroker 16668  0.2  0.6 174764 55172 ?        Sl   19:58   0:06 io.ocpp.0
    root     18667  0.0  0.0   4900  1604 pts/1    R+   20:37   0:00 grep ocpp
    root@r01iobroker:/opt/iobroker# iobroker debug ocpp.0
    Debugger listening on ws://127.0.0.1:9229/cf2ab54a-5cc5-46e5-9b01-23eb14959444
    For help, see: https://nodejs.org/en/docs/inspector
    2022-01-08 20:37:59.256  - debug: ocpp.0 (18685) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2022-01-08 20:37:59.298  - debug: ocpp.0 (18685) Objects client ready ... initialize now
    2022-01-08 20:37:59.301  - debug: ocpp.0 (18685) Objects create System PubSub Client
    2022-01-08 20:37:59.303  - debug: ocpp.0 (18685) Objects create User PubSub Client
    2022-01-08 20:37:59.305  - debug: ocpp.0 (18685) Objects client initialize lua scripts
    2022-01-08 20:37:59.327  - debug: ocpp.0 (18685) Objects connected to redis: 127.0.0.1:9001
    2022-01-08 20:37:59.337  - debug: ocpp.0 (18685) objectDB connected
    2022-01-08 20:37:59.340  - debug: ocpp.0 (18685) Redis States: Use Redis connection: 127.0.0.1:9000
    2022-01-08 20:37:59.350  - debug: ocpp.0 (18685) States create System PubSub Client
    2022-01-08 20:37:59.351  - debug: ocpp.0 (18685) States create User PubSub Client
    2022-01-08 20:37:59.360  - debug: ocpp.0 (18685) States connected to redis: 127.0.0.1:9000
    2022-01-08 20:37:59.361  - debug: ocpp.0 (18685) statesDB connected
    2022-01-08 20:37:59.603  - info: ocpp.0 (18685) starting. Version 0.0.10 in /opt/iobroker/node_modules/iobroker.ocpp, node: v14.16.1, js-controller: 3.3.22
    2022-01-08 20:37:59.669  - info: ocpp.0 (18685) Starting OCPP Server
    2022-01-08 20:37:59.830  - info: ocpp.0 (18685) Server listening on port 9221
    schwimbi
    @foxriver76 Auch nach löschen selbes Bild
    root@r01iobroker:/opt/iobroker# iobroker delete ocpp
    Delete adapter "ocpp"
    host.r01iobroker Counted 1 instances of ocpp
    host.r01iobroker Counted 1 meta of ocpp
    host.r01iobroker Counted 1 adapter for ocpp
    host.r01iobroker Counted 2 devices of ocpp
    host.r01iobroker Counted 1 channels of ocpp
    host.r01iobroker Counted 15 states of ocpp
    host.r01iobroker Counted 14 states of system.adapter.ocpp
    host.r01iobroker Counted 10 states (io.ocpp.*) from states
    host.r01iobroker Counted 14 states (system.adapter.ocpp.*) from states
    host.r01iobroker file ocpp.admin deleted
    host.r01iobroker object ocpp deleted
    host.r01iobroker object ocpp.admin deleted
    host.r01iobroker Deleting 35 object(s).
    host.r01iobroker Deleting 24 state(s).
    npm uninstall iobroker.ocpp --loglevel error --prefix "/opt/iobroker" (System call)
    host.r01iobroker Counted 2 states (system.adapter.ocpp.*) from states
    host.r01iobroker Deleting 2 state(s).
    Error deleting adapter ocpp from disk: Error: Cannot find module 'iobroker.ocpp/io-package.json'
    Require stack:
    - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js
    - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
    - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
    You might have to delete it yourself!
    Require stack:
    root@r01iobroker:/opt/iobroker# iobroker --help
    iobroker [command]
    Commands:
      iobroker setup                                               Setup ioBroker
      iobroker start                                               Starts the js-controller
      iobroker stop                                                stops the js-controller
      iobroker restart                                             Restarts js-controller
      iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
      iobroker info                                                Shows the host info
      iobroker logs [<adapter>]                                    Monitor log
      iobroker add <adapter> [desiredNumber]                       Add instance of adapter
      iobroker install <adapter>                                   Installs a specified adapter
      iobroker rebuild <adapter>|self                              Rebuilds a specified adapter
      iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
      iobroker del <adapter>                                       Remove adapter from system
      iobroker del <adapter>.<instance>                            Remove adapter instance
      iobroker update [<repositoryUrl>]                            Update repository and list adapters
      iobroker upgrade                                             Upgrade management
      iobroker upload                                              Upload management
      iobroker object                                              Object management
      iobroker state                                               State management
      iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
      iobroker list <type> [<filter>]                              List all entries, like objects
      iobroker chmod <mode> <file>                                 Change file rights
      iobroker chown <user> <group> <file>                         Change file ownership
      iobroker touch <file>                                        Touch file
      iobroker rm <file>                                           Remove file
      iobroker file                                                File management
      iobroker user                                                User commands
      iobroker group                                               group management
      iobroker host <hostname>                                     Set host to given hostname
      iobroker set <adapter>.<instance>                            Change settings of adapter config
      iobroker license <license.file or license.text>              Update license by given file
      iobroker cert                                                Certificate management
      iobroker clean <yes>                                         Clears all objects and states
      iobroker backup                                              Create backup
      iobroker restore <backup name or path>                       Restore a specified backup
      iobroker validate <backup name or path>                      Validate a specified backup
      iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance
      iobroker repo [<name>]                                       Show repo information
      iobroker uuid                                                Show uuid of the installation
      iobroker unsetup                                             Reset license, installation secret and language
      iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
      iobroker multihost                                           Multihost management
      iobroker compact                                             compact group management
      iobroker plugin                                              Plugin management
      iobroker version [<adapter>]                                 Show version of js-controller or specified adapter
    Options:
          --help     Show help  [boolean]
      -v, --version  Show version  [boolean]
    root@r01iobroker:/opt/iobroker# iobroker url https://github.com/foxriver76/ioBroker.ocpp.git
    install foxriver76/ioBroker.ocpp#4289b3596edcaf652fc73ac30e578e8b2d642046
    NPM version: 6.14.12
    npm install foxriver76/ioBroker.ocpp#4289b3596edcaf652fc73ac30e578e8b2d642046 --loglevel error --prefix "/opt/iobroker" (System call)
    upload [1] ocpp.admin /opt/iobroker/node_modules/iobroker.ocpp/admin/ocpp.png ocpp.png image/png
    upload [0] ocpp.admin /opt/iobroker/node_modules/iobroker.ocpp/admin/jsonConfig.json jsonConfig.json application/json
    root@r01iobroker:/opt/iobroker# iobroker add ocpp 0
    host.r01iobroker create instance ocpp
    host.r01iobroker object ocpp.0.info.connection created
    host.r01iobroker object ocpp.0.info created
    host.r01iobroker object system.adapter.ocpp.0.logLevel created
    host.r01iobroker object system.adapter.ocpp.0.sigKill created
    host.r01iobroker object system.adapter.ocpp.0.eventLoopLag created
    host.r01iobroker object system.adapter.ocpp.0.outputCount created
    host.r01iobroker object system.adapter.ocpp.0.inputCount created
    host.r01iobroker object system.adapter.ocpp.0.uptime created
    host.r01iobroker object system.adapter.ocpp.0.memRss created
    host.r01iobroker object system.adapter.ocpp.0.memHeapTotal created
    host.r01iobroker object system.adapter.ocpp.0.memHeapUsed created
    host.r01iobroker object system.adapter.ocpp.0.cputime created
    host.r01iobroker object system.adapter.ocpp.0.cpu created
    host.r01iobroker object system.adapter.ocpp.0.compactMode created
    host.r01iobroker object system.adapter.ocpp.0.connected created
    host.r01iobroker object system.adapter.ocpp.0.alive created
    host.r01iobroker Set default value of ocpp.0.info.connection: false
    host.r01iobroker object system.adapter.ocpp.0 created
    Debugger listening on ws://127.0.0.1:9229/ee93151f-d543-4b2a-90fd-467048a45342
    2022-01-08 20:42:47.300  - debug: ocpp.0 (19156) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2022-01-08 20:42:47.341  - debug: ocpp.0 (19156) Objects client ready ... initialize now
    2022-01-08 20:42:47.344  - debug: ocpp.0 (19156) Objects create System PubSub Client
    2022-01-08 20:42:47.346  - debug: ocpp.0 (19156) Objects create User PubSub Client
    2022-01-08 20:42:47.348  - debug: ocpp.0 (19156) Objects client initialize lua scripts
    2022-01-08 20:42:47.369  - debug: ocpp.0 (19156) Objects connected to redis: 127.0.0.1:9001
    2022-01-08 20:42:47.379  - debug: ocpp.0 (19156) objectDB connected
    2022-01-08 20:42:47.382  - debug: ocpp.0 (19156) Redis States: Use Redis connection: 127.0.0.1:9000
    2022-01-08 20:42:47.391  - debug: ocpp.0 (19156) States create System PubSub Client
    2022-01-08 20:42:47.392  - debug: ocpp.0 (19156) States create User PubSub Client
    2022-01-08 20:42:47.401  - debug: ocpp.0 (19156) States connected to redis: 127.0.0.1:9000
    2022-01-08 20:42:47.402  - debug: ocpp.0 (19156) statesDB connected
    2022-01-08 20:42:47.635  - info: ocpp.0 (19156) starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.ocpp, node: v14.16.1, js-controller: 3.3.22
    2022-01-08 20:42:47.716  - info: ocpp.0 (19156) Starting OCPP Server
    2022-01-08 20:42:47.932  - info: ocpp.0 (19156) Server listening on port 9221
    ^C2022-01-08 20:43:12.378  - info: ocpp.0 (19156) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    root@r01iobroker:/opt/iobroker# netstat -tulpen
    netstat -tulpen
    Aktive Internetverbindungen (Nur Server)
    Proto Recv-Q Send-Q Local Address           Foreign Address         State       Benutzer   Inode      PID/Program name
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       98523589   6879/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       98525495   6879/iobroker.js-co
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       98529908   7790/io.jarvis.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17020      569/sshd
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       98525781   6989/node-red
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      109        18850      551/influxd
    tcp6       0      0 :::9220                 :::*                    LISTEN      1001       101512715  19128/io.ocpp.0
    tcp6       0      0 :::3493                 :::*                    LISTEN      0          18577      570/upsd
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       98524130   7199/io.harmony.0
    tcp6       0      0 :::80                   :::*                    LISTEN      0          88171095   22017/apache2
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       98526271   6900/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       98530587   7760/io.web.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       98528674   7724/io.socketio.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      109        19556      551/influxd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          17022      569/sshd
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       98530472   7681/io.simple-api.
    tcp6       0      0 :::7070                 :::*                    LISTEN      0          89507854   24843/./evcc
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       98524131   7199/io.harmony.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          17580      545/dhcpcd
    udp        0      0 169.254.82.229:123      0.0.0.0:*                           110        46523      563/ntpd
    udp        0      0 192.168.9.66:123        0.0.0.0:*                           110        46498      563/ntpd
    udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          18556      563/ntpd
    udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          18552      563/ntpd
    udp        0      0 192.168.9.66:56973      0.0.0.0:*                           1001       98528776   7775/io.knx.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15744      377/avahi-daemon: r
    udp        0      0 0.0.0.0:34726           0.0.0.0:*                           1001       100990480  6989/node-red
    udp        0      0 0.0.0.0:59876           0.0.0.0:*                           108        15746      377/avahi-daemon: r
    udp6       0      0 :::35402                :::*                                108        15747      377/avahi-daemon: r
    udp6       0      0 fe80::aefd:1a34:1b8:123 :::*                                0          18562      563/ntpd
    udp6       0      0 ::1:123                 :::*                                0          18560      563/ntpd
    udp6       0      0 :::123                  :::*                                0          18549      563/ntpd
    udp6       0      0 :::5353                 :::*                                108        15745      377/avahi-daemon: r
    root@r01iobroker:/opt/iobroker# netstat -tulpen | grep 9220
    root@r01iobroker:/opt/iobroker# netstat -tulpen | grep 9221
    Debugger listening on ws://127.0.0.1:9229/7761b669-a80d-405d-af76-81bc3231996e
    2022-01-08 20:43:30.046  - debug: ocpp.0 (19233) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2022-01-08 20:43:30.086  - debug: ocpp.0 (19233) Objects client ready ... initialize now
    2022-01-08 20:43:30.090  - debug: ocpp.0 (19233) Objects create System PubSub Client
    2022-01-08 20:43:30.092  - debug: ocpp.0 (19233) Objects create User PubSub Client
    2022-01-08 20:43:30.094  - debug: ocpp.0 (19233) Objects client initialize lua scripts
    2022-01-08 20:43:30.117  - debug: ocpp.0 (19233) Objects connected to redis: 127.0.0.1:9001
    2022-01-08 20:43:30.127  - debug: ocpp.0 (19233) objectDB connected
    2022-01-08 20:43:30.130  - debug: ocpp.0 (19233) Redis States: Use Redis connection: 127.0.0.1:9000
    2022-01-08 20:43:30.139  - debug: ocpp.0 (19233) States create System PubSub Client
    2022-01-08 20:43:30.140  - debug: ocpp.0 (19233) States create User PubSub Client
    2022-01-08 20:43:30.149  - debug: ocpp.0 (19233) States connected to redis: 127.0.0.1:9000
    2022-01-08 20:43:30.150  - debug: ocpp.0 (19233) statesDB connected
    2022-01-08 20:43:30.369  - info: ocpp.0 (19233) starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.ocpp, node: v14.16.1, js-controller: 3.3.22
    2022-01-08 20:43:30.435  - info: ocpp.0 (19233) Starting OCPP Server
    2022-01-08 20:43:30.672  - info: ocpp.0 (19233) Server listening on port 9221
    • S schwimbi
      @foxriver76
      ps -aux | grep ocpp
      foxriver76F Offline
      foxriver76F Offline
      foxriver76
      schrieb am zuletzt editiert von foxriver76
      @schwimbi Ja genau, kann ich bei mir auch beobachten, sobald du den debug Prozess startest, startet ein separater Prozess, der laufende Adapter wird nicht beendet.
      Bevor du den Adapter mit debug startest, darf kein Adapter-Prozess laufen. Sprich vorher beenden. Mit ps -aux | grep ocpp checken, dass kein Prozess läuft, dann kannst du mit debug den Adapter starten.
      Ansonsten kannst du aber auch einfach über die GUI checken ohne den debug Prozess zu starten.
      Videotutorials & mehr
      • foxriver76F foxriver76
        schwimbi
        @foxriver76 ok verstehe,
        ocpp.0
        	19984	2022-01-08 20:59:21.219	info	Received Status Notification from "/Wallbox2": SuspendedEV
        ocpp.0
        	19984	2022-01-08 20:59:12.294	info	Received MeterValues from "/Wallbox2"
        ocpp.0
        	19984	2022-01-08 20:58:40.304	info	Received MeterValues from "/Wallbox2"
        ocpp.0
        	19984	2022-01-08 20:58:08.345	info	Received MeterValues from "/Wallbox2"
        ocpp.0
        	19984	2022-01-08 20:57:36.442	info	Received MeterValues from "/Wallbox2"
        ocpp.0
        	19984	2022-01-08 20:57:04.450	info	Received MeterValues from "/Wallbox2"
        ocpp.0
        	19984	2022-01-08 20:56:32.562	info	Received MeterValues from "/Wallbox2"
        ocpp.0
        	19984	2022-01-08 20:56:00.273	info	Received MeterValues from "/Wallbox2"
        ocpp.0
        	19984	2022-01-08 20:55:28.330	info	Received MeterValues from "/Wallbox2"
        ocpp.0
        	19984	2022-01-08 20:54:56.433	info	Received MeterValues from "/Wallbox2"
        ocpp.0
        	19984	2022-01-08 20:54:47.170	info	Received Status Notification from "/Wallbox2": Charging
        Der Befehl kommt an der Wallbox an, scheint Sie leider nicht zu interessieren.
        ....F[BA7.....L3.......AHA@......CXCF3..FMBA	......
        .CXCF"......J.......FMBA....F[BA%C.>.<.>..[3,"9847448",{}].~.z[3,"e0871be0-f9c2-43bc-af1d-9bae420299aa",{"connectorId":1,"csChargingProfiles":{"chargingProfileId":1,"stackLevel":1,"chargingProfilePurpose":"TxDefaultProfile","chargingProfileKind":"Recurring","recurrencyKind":"Daily","chargingSchedule":{"duration":86400,"startSchedule":"2013-01-01T00:00Z","chargingRateUnit":"W","chargingSchedulePeriod":[{"startPeriod":0,"limit":1234}]}}}].~.z[3,"375218b3-0dee-4fa6-8ca2-34d8f667c1a0",{"connectorId":1,"csChargingProfiles":{"chargingProfileId":1,"stackLevel":1,"chargingProfilePurpose":"TxDefaultProfile","chargingProfileKind":"Recurring","recurrencyKind":"Daily","chargingSchedule":{"duration":86400,"startSchedule":"2013-01-01T00:00Z","chargingRateUnit":"W","chargingSchedulePeriod":[{"startPeriod":0,"limit":1111}]}}}]....abcd:PODCURUTPVRCNCF,....4.....FMB.F.
        .....+.F[BRHA@........
        ..+.F[BRHA@.....2....CXC?.@.
        .......F[BAVQPQIQSNTY6R][W[^RZMTQR9FMBA.......5.
        ..F[B8.C.....A^A@QVTLZTCNCF.
        .CXCF7
        .....FMBA.	...CXCF-SN*CNCF..
        .CXCF7@.HA.A.....CXCFPWMVR@ODC..
        Trace -> ocpp2.pcap
        foxriver76F S 2 Antworten Letzte Antwort
        • S schwimbi
          ocpp.0
          ocpp.0
          ocpp.0
          ocpp.0
          ocpp.0
          ocpp.0
          ocpp.0
          ocpp.0
          ocpp.0
          ocpp.0
          ocpp.0
          .CXCF7
          Trace -> ocpp2.pcap
          foxriver76F Offline
          foxriver76F Offline
          foxriver76
          @schwimbi Dann ist meine Befürchtung dass es bei dir auch nicht implementiert ist, so deute ich das zumindest bei meiner Pulsar:
          Einige der myWallbox-Funktionen sind weiterhin verfügbar, wenn OCPP aktiviert ist. Sie können vom
          Charge Point Operator (CPO) über die myWallbox-App oder das Portal durchgeführt werden:
          • Überwachung des Ladezustands
          • Anonyme Ladesitzungen
          • Power Sharing einstellen
          • Power Boost einstellen
          • MID-Messgerät einstellen
          • Die Stromgrenze einstellen
          • Die Ladesoftware aktualisieren
          • Neustart (Neustart des Ladegeräts)
          • Wiederherstellen (Werksbedingungen)
          • Zeitpläne für das Aufladen einstellen
          • TN/TT-Erdungssystem einstellen
          Heißt für mich, dass sich diese Dinge nicht über OCPP sondern nur über die herstellereigene App steuern lassen.
          Siehe https://support.wallbox.com/wp-content/uploads/2021/02/DE_OCPP_AKTIVIERUNGSANLEITUNG.pdf Seite 15.
          Für deine WB habe ich auf die schnelle keine OCPP Infos gefunden.
          Leider ist das eines der wichtigsten Funktionen und ich kann es nicht ganz nachvollziehen warum es nicht implementiert ist.
          Um mal nicht ganz auszuschließen, dass der Fehler auf Adapterseite liegt schaue ichnochmal in die Beschreibung für setChargePointProfile ob ich da etwas übersehen habe.
          • S schwimbi
            ocpp.0
            ocpp.0
            ocpp.0
            ocpp.0
            ocpp.0
            ocpp.0
            ocpp.0
            ocpp.0
            ocpp.0
            ocpp.0
            ocpp.0
            .CXCF7
            Trace -> ocpp2.pcap
            schwimbi
            @foxriver76 Gerade nochmal probiert wenn nur 1 Wallbox aktiv ist. Funktioniert leider auch nicht mit der ABB Terra AC :(
            • foxriver76F Offline
              foxriver76F Offline
              foxriver76
              Wobei laut https://www.ampcontrol.io/post/3-tricks-to-implement-smart-charging-with-ocpp-1-6 Trick 1 das Diagramm auf unsere setChargingProfile eine Antwort mit der Config kommen sollte, das passiert bei mir definitiv nicht.
              Vorgehensweise wäre dann aber Starten des Ladevorgangs -> dann setzen des Limits dann beobachten obs ne Auswirkung hatte.
                schwimbi
                @foxriver76 said in Alpha Testing: OCPP Wallbox Adapter:
                Hm, das wäre denkbar :( habe ABB dazu angeschrieben.
                Im Home Assistant Github haben Sie ähnliche Vermutungen : https://github.com/lbbrhzn/ocpp/discussions/217#discussioncomment-1738220
                • S schwimbi
                  schwimbi
                  @foxriver76 Lt. https://github.com/lbbrhzn/ocpp/files/7806205/Terra.AC.OCPP.1.6.Implementation.overview._v1.5.-.external.pdf scheint es aber doch möglich zu sein :/ hm
                  foxriver76F 2 Antworten Letzte Antwort
                  • S schwimbi
                    foxriver76F Offline
                    foxriver76F Offline
                    foxriver76
                    @schwimbi Ich habe jetzt mal noch versucht die Config anzufordern, meine WB ignoriert aber leider auch diese Anforderung. Villt. kommt da bei dir was zurück, wird dann als Warning geloggt wenn darauf eine Antwort kommt. In der Config steht eigentlich welche Profile unterstützt werden von der WB. Gerne mal die Version von GitHub probieren.
                      schwimbi
                      @foxriver76
                      Hm, da kommt bei mir auch wenig :(
                      ocpp.0
                      	22864	2022-01-09 08:49:30.522	info	Requesting GetConfiguration from "/Wallbox2"
                      ocpp.0
                      	22864	2022-01-09 08:49:30.192	info	Requesting GetConfiguration from "/Wallbox1"
                      ocpp.0
                      	22864	2022-01-09 08:49:29.520	info	Requesting MeterValues from "/Wallbox2"
                      ocpp.0
                      	22864	2022-01-09 08:49:29.516	info	Received Status Notification from "/Wallbox2": Finishing
                      ocpp.0
                      	22864	2022-01-09 08:49:29.188	info	Requesting MeterValues from "/Wallbox1"
                      ocpp.0
                      	22864	2022-01-09 08:49:29.154	info	Received Status Notification from "/Wallbox1": Available
                      ocpp.0
                      	22864	2022-01-09 08:49:29.017	info	Received Status Notification from "/Wallbox2": Available
                      ocpp.0
                      	22864	2022-01-09 08:49:28.654	info	Received Status Notification from "/Wallbox1": Available
                      ocpp.0
                      	22864	2022-01-09 08:49:28.595	info	Received boot notification from "/Wallbox2"
                      ocpp.0
                      	22864	2022-01-09 08:49:28.517	info	Requesting StatusNotification from "/Wallbox2"
                      ocpp.0
                      	22864	2022-01-09 08:49:28.516	info	New device connected: "/Wallbox2"
                      ocpp.0
                      	22864	2022-01-09 08:49:28.310	info	Received boot notification from "/Wallbox1"
                      ocpp.0
                      	22864	2022-01-09 08:49:28.166	info	Requesting StatusNotification from "/Wallbox1"
                      ocpp.0
                      	22864	2022-01-09 08:49:28.164	info	New device connected: "/Wallbox1"
                      ocpp.0
                      	22864	2022-01-09 08:49:27.643	info	Connection from /Wallbox1 with credentials {"name":"Wallbox1","pass":"ocpp"} and protocol: http
                      ocpp.0
                      	22864	2022-01-09 08:49:27.563	info	Connection from /Wallbox2 with credentials {"name":"Wallbox2","pass":"ocpp"} and protocol: http
                      ocpp.0
                      	22864	2022-01-09 08:48:43.743	info	Server listening on port 9220
                      ocpp.0
                      	22864	2022-01-09 08:48:43.685	info	Starting OCPP Server
                      ocpp.0
                      	22864	2022-01-09 08:48:43.649	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.ocpp, node: v14.16.1, js-controller: 3.3.22
                      • S schwimbi
                        @foxriver76
                        ocpp.0
                        ocpp.0
                        ocpp.0
                        ocpp.0
                        ocpp.0
                        ocpp.0
                        ocpp.0
                        ocpp.0
                        ocpp.0
                        ocpp.0
                        ocpp.0
                        ocpp.0
                        ocpp.0
                        ocpp.0
                        ocpp.0
                        ocpp.0
                        ocpp.0
                        ocpp.0
                        ocpp.0
                        foxriver76F Offline
                        foxriver76F Offline
                        foxriver76
                        @schwimbi Kannst du mit der Version noch Transaktionen starten? Irgendwie mag meine WB nicht mehr so recht reagieren.
                        Habe noch nen Fehler gefunden dass das Limit bei Transaktionsstart nicht mitgegeben wurde.
                          schwimbi
                          @foxriver76 Kann ich nicht genau sagen.
                          Anbei der Output
                          ocpp.0
                          	22864	2022-01-09 12:35:36.531	info	Received MeterValues from "/Wallbox2"
                          ocpp.0
                          	22864	2022-01-09 12:35:04.578	info	Received MeterValues from "/Wallbox2"
                          ocpp.0
                          	22864	2022-01-09 12:34:32.645	info	Received MeterValues from "/Wallbox2"
                          ocpp.0
                          	22864	2022-01-09 12:34:00.742	info	Received MeterValues from "/Wallbox2"
                          ocpp.0
                          	22864	2022-01-09 12:33:51.352	info	Received Start transaction from "/Wallbox2"
                          ocpp.0
                          	22864	2022-01-09 12:33:50.852	info	Received Status Notification from "/Wallbox2": Charging
                          ocpp.0
                          	22864	2022-01-09 12:33:50.089	info	Received Status Notification from "/Wallbox2": SuspendedEV
                          S foxriver76F 2 Antworten Letzte Antwort
                          • S schwimbi
                            Anbei der Output
                            ocpp.0
                            ocpp.0
                            ocpp.0
                            ocpp.0
                            ocpp.0
                            ocpp.0
                            ocpp.0
                            schwimbi
                            @foxriver76 Nochmaliger log mit Version von 12:39
                            ocpp.0
                            	2059	2022-01-09 12:43:06.065	info	Received MeterValues from "/Wallbox2"
                            ocpp.0
                            	2059	2022-01-09 12:42:35.951	info	Sending GetConfiguration to "/Wallbox2"
                            ocpp.0
                            	2059	2022-01-09 12:42:35.484	info	Received MeterValues from "/Wallbox2"
                            ocpp.0
                            	2059	2022-01-09 12:42:34.946	info	Requesting MeterValues from "/Wallbox2"
                            ocpp.0
                            	2059	2022-01-09 12:42:34.941	info	Received Status Notification from "/Wallbox2": Charging
                            ocpp.0
                            	2059	2022-01-09 12:42:34.919	info	Sending GetConfiguration to "/Wallbox1"
                            ocpp.0
                            	2059	2022-01-09 12:42:34.440	info	Received Status Notification from "/Wallbox2": Unavailable
                            ocpp.0
                            	2059	2022-01-09 12:42:34.074	info	Received boot notification from "/Wallbox2"
                            ocpp.0
                            	2059	2022-01-09 12:42:33.942	info	Requesting StatusNotification from "/Wallbox2"
                            ocpp.0
                            	2059	2022-01-09 12:42:33.941	info	New device connected: "/Wallbox2"
                            ocpp.0
                            	2059	2022-01-09 12:42:33.914	info	Requesting MeterValues from "/Wallbox1"
                            ocpp.0
                            	2059	2022-01-09 12:42:33.889	info	Received Status Notification from "/Wallbox1": Available
                            ocpp.0
                            	2059	2022-01-09 12:42:33.388	info	Received Status Notification from "/Wallbox1": Available
                            ocpp.0
                            	2059	2022-01-09 12:42:33.010	info	Received boot notification from "/Wallbox1"
                            ocpp.0
                            	2059	2022-01-09 12:42:32.994	info	Connection from "/Wallbox2" with credentials "{"name":"Wallbox2","pass":"ocpp"}" and protocol: "http"
                            ocpp.0
                            	2059	2022-01-09 12:42:32.899	info	Requesting StatusNotification from "/Wallbox1"
                            ocpp.0
                            	2059	2022-01-09 12:42:32.897	info	New device connected: "/Wallbox1"
                            ocpp.0
                            	2059	2022-01-09 12:42:32.622	info	Connection from "/Wallbox1" with credentials "{"name":"Wallbox1","pass":"ocpp"}" and protocol: "http"
                            ocpp.0
                            	2059	2022-01-09 12:42:01.478	info	Server listening on port 9220
                            ocpp.0
                            	2059	2022-01-09 12:42:01.413	info	Starting OCPP Server
                            ocpp.0
                            	2059	2022-01-09 12:42:01.377	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.ocpp, node: v14.16.1, js-controller: 3.3.22
                            ocpp.0
                            	22864	2022-01-09 12:40:28.742	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            ocpp.0
                            	22864	2022-01-09 12:40:28.741	info	terminating
                            • S schwimbi
                              Anbei der Output
                              ocpp.0
                              ocpp.0
                              ocpp.0
                              ocpp.0
                              ocpp.0
                              ocpp.0
                              ocpp.0
                              foxriver76F Offline
                              foxriver76F Offline
                              foxriver76
                              @schwimbi Ja das schaut gut aus, dann lokales Problem bei mir. ;-)
                              Aber das Ladelimit wird wohl nach wie vor nicht angezogen?
                                schwimbi
                                @foxriver76 Leider nein :(
                                • S schwimbi
                                  foxriver76F Offline
                                  foxriver76F Offline
                                  foxriver76
                                  #66
                                  @schwimbi sagte in Alpha Testing: OCPP Wallbox Adapter:
                                  Ab Firmware 1.x, welche läuft denn bei dir?
                                    foxriver76F Offline
                                    foxriver76
                                    #67
                                    Ah holy.. ich habs..
                                    Das mit der Configuration klappt zwar immer noch nicht, wäre mir sehr wichtig dass das noch klappt, aber ich kann bei meinem Charger die Ladeleistung ändern. Denke bei dir wird es auch gehen @schwimbi
                                    Hatte den State damals default auf Watt programmiert, man kann W/A mitgeben, habe jetzt bei dir in der Beschreibung gesehen, dass nur Ampere gehen. Pushe gleich. den chargeLimit state ein mal löschen sonst bleibt der Name falsch, da die Einheit mit im Namen steht.
                                      schwimbi
                                      #68
                                      @foxriver76 Firmware ist v1.3
                                      Derzeit funktioniert das mit A(mpere) noch nicht :(
                                      Tesla lädt mit 11kW/16A, setzen auf niedrigeren Wert bleibt ohne Wirkung
                                      ocpp.0
                                      	10368	2022-01-09 15:35:27.944	info	Received MeterValues from "/Wallbox2"
                                      ocpp.0
                                      	10368	2022-01-09 15:34:56.001	info	Received MeterValues from "/Wallbox2"
                                      ocpp.0
                                      	10368	2022-01-09 15:34:24.049	info	Received MeterValues from "/Wallbox2"
                                      ocpp.0
                                      	10368	2022-01-09 15:33:51.810	info	Received MeterValues from "/Wallbox2"
                                      ocpp.0
                                      	10368	2022-01-09 15:33:19.877	info	Received MeterValues from "/Wallbox2"
                                      ocpp.0
                                      	10368	2022-01-09 15:32:47.936	info	Received MeterValues from "/Wallbox2"
                                      ocpp.0
                                      	10368	2022-01-09 15:32:28.525	info	Received Status Notification from "/Wallbox2": Charging
                                      ocpp.0
                                      	10368	2022-01-09 15:31:29.817	info	Received Status Notification from "/Wallbox2": SuspendedEV
                                      ocpp.0
                                      	10368	2022-01-09 15:31:12.086	info	Received MeterValues from "/Wallbox2"
                                      ocpp.0
                                      	10368	2022-01-09 15:30:44.061	info	Sending GetConfiguration to "/Wallbox2"
                                      ocpp.0
                                      	10368	2022-01-09 15:30:43.599	info	Sending GetConfiguration to "/Wallbox1"
                                      ocpp.0
                                      	10368	2022-01-09 15:30:42.560	info	Received MeterValues from "/Wallbox2"
                                      ocpp.0
                                      	10368	2022-01-09 15:30:42.099	info	Requesting MeterValues from "/Wallbox1"
                                      ocpp.0
                                      	10368	2022-01-09 15:30:42.098	info	Received Status Notification from "/Wallbox1": Available
                                      ocpp.0
                                      	10368	2022-01-09 15:30:42.058	info	Received Status Notification from "/Wallbox2": Charging
                                      ocpp.0
                                      	10368	2022-01-09 15:30:41.782	info	Requesting MeterValues from "/Wallbox2"
                                      ocpp.0
                                      	10368	2022-01-09 15:30:41.599	info	Received Status Notification from "/Wallbox1": Available
                                      ocpp.0
                                      	10368	2022-01-09 15:30:41.561	info	Received Status Notification from "/Wallbox2": Unavailable
                                      ocpp.0
                                      	10368	2022-01-09 15:30:40.746	info	Received boot notification from "/Wallbox1"
                                      ocpp.0
                                      	10368	2022-01-09 15:30:40.600	info	Requesting StatusNotification from "/Wallbox1"
                                      ocpp.0
                                      	10368	2022-01-09 15:30:40.599	info	New device connected: "/Wallbox1"
                                      ocpp.0
                                      	10368	2022-01-09 15:30:40.395	info	Received boot notification from "/Wallbox2"
                                      ocpp.0
                                      	10368	2022-01-09 15:30:40.286	info	Requesting StatusNotification from "/Wallbox2"
                                      ocpp.0
                                      	10368	2022-01-09 15:30:40.284	info	New device connected: "/Wallbox2"
                                      ocpp.0
                                      	10368	2022-01-09 15:30:40.069	info	Connection from "/Wallbox2" with credentials "{"name":"Wallbox2","pass":"ocpp"}" and protocol: "http"
                                      ocpp.0
                                      	10368	2022-01-09 15:30:40.060	info	Connection from "/Wallbox1" with credentials "{"name":"Wallbox1","pass":"ocpp"}" and protocol: "http"
                                      ocpp.0
                                      	10368	2022-01-09 15:30:12.495	info	Server listening on port 9220
                                      ocpp.0
                                      	10368	2022-01-09 15:30:12.418	info	Starting OCPP Server
                                      ocpp.0
                                      	10368	2022-01-09 15:30:12.361	info	starting. Version 0.2.0 in /opt/iobroker/node_modules/iobroker.ocpp, node: v14.16.1, js-controller: 3.3.22
                                      • S schwimbi
                                        ocpp.0
                                        ocpp.0
                                        ocpp.0
                                        ocpp.0
                                        ocpp.0
                                        ocpp.0
                                        ocpp.0
                                        ocpp.0
                                        ocpp.0
                                        ocpp.0
                                        ocpp.0
                                        ocpp.0
                                        ocpp.0
                                        ocpp.0
                                        ocpp.0
                                        ocpp.0
                                        ocpp.0
                                        ocpp.0
                                        ocpp.0
                                        ocpp.0
                                        ocpp.0
                                        ocpp.0
                                        ocpp.0
                                        ocpp.0
                                        ocpp.0
                                        ocpp.0
                                        ocpp.0
                                        ocpp.0
                                        ocpp.0
                                        schwimbi
                                        #69
                                        • S schwimbi
                                          foxriver76F Offline
                                          foxriver76F Offline
                                          foxriver76
                                          #70
                                          @schwimbi habe es bei mir nicht während einer Transaktion probiert, aber ohne sehe ich dass sich das Limit in der WB App entsprechend ändert.
