  4. Adapter werden neu gestartet
    6.3k
88 Beiträge 9 Kommentatoren 12.4k Aufrufe 6 Beobachtet
    Das ist die Ausgabe auf die (falsche) Vorgabe
    iobroker update - i
    Mit
    iobroker update -i
    wirds vermutlich passen.
    GlasfaserG Offline
    GlasfaserG Offline
    @thomas-braun sagte in Adapter werden neu gestartet:
    Ja gerade geseh ... habe ein Leerzeichen bei meiner Vorlage .
    • GlasfaserG Glasfaser
      matrose65
      @glasfaser So jetzt aber
      uwe@iobroker:~$ iobroker update -i
      [sudo] Passwort für uwe:
      Used repository: Beta (latest)
      hash unchanged, use cached sources
      update done
      Adapter    "admin"         : 5.2.3    , installed 5.2.3
      Adapter    "backitup"      : 2.2.2    , installed 2.2.2
      Adapter    "daswetter"     : 3.0.9    , installed 3.0.9
      Adapter    "discovery"     : 2.7.5    , installed 2.7.5
      Adapter    "dwd"           : 2.7.7    , installed 2.7.7
      Adapter    "feiertage"     : 1.1.0    , installed 1.1.0
      Adapter    "fullybrowser"  : 2.0.12   , installed 2.0.12
      Adapter    "hm-rega"       : 3.0.33   , installed 3.0.33
      Adapter    "hm-rpc"        : 1.15.0   , installed 1.15.0
      Adapter    "ical"          : 1.11.6   , installed 1.11.6
      Adapter    "icons-mfd-png" : 1.0.2    , installed 1.0.2
      Adapter    "info"          : 1.9.16   , installed 1.9.16
      Adapter    "javascript"    : 5.2.18   , installed 5.2.18
      Controller "js-controller" : 3.3.22   , installed 3.3.22
      Adapter    "netatmo"       : 1.4.4    , installed 1.4.4
      Adapter    "netatmo-crawler": 0.6.0   , installed 0.6.0
      Adapter    "paw"           : 0.3.2    , installed 0.3.2
      Adapter    "scenes"        : 2.3.8    , installed 2.3.8
      Adapter    "shelly"        : 5.0.0    , installed 5.0.0
      Adapter    "simple-api"    : 2.6.2    , installed 2.6.2
      Adapter    "socketio"      : 3.1.5    , installed 3.1.5
      Adapter    "sonoff"        : 2.4.7    , installed 2.4.7
      Adapter    "sonos"         : 2.1.7    , installed 2.1.7
      Adapter    "tankerkoenig"  : 2.1.1    , installed 2.1.1
      Adapter    "tr-064"        : 4.2.15   , installed 4.2.15
      Adapter    "vis"           : 1.4.7    , installed 1.4.7
      Adapter    "vis-hqwidgets" : 1.1.9    , installed 1.1.9
      Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
      Adapter    "vis-players"   : 0.1.6    , installed 0.1.6
      Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
      Adapter    "web"           : 3.4.16   , installed 3.4.16
      Adapter    "windows-control": 0.1.5   , installed 0.1.5
      Adapter    "wled"          : 0.6.3    , installed 0.6.3
      Adapter    "zigbee"        : 1.6.8    , installed 1.6.8
      uwe@iobroker:~$
        @matrose65 sagte in Adapter werden neu gestartet:
        Used repository: -
        was ist das denn für ein Repo?
        guergen
        Jetzt hat es mich grade schon wieder erwischt, habe grade nur auf "Instanz" geklickt:
        	In file included from ../src/binding.cc:6:/home/iobroker/.cache/node-gyp/14.18.2/include/node/node.h:787:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] 787 | (node::addon_register_func) (regfunc), \ | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/14.18.2/include/node/node.h:821:3: note: in expansion of macro ‘NODE_MODULE_X’ 821 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) | ^~~~~~~~~~~~~../src/binding.cc:2003:1: note: in expansion of macro ‘NODE_MODULE’ 2003 | NODE_MODULE(sshcrypto, init) | ^~~~~~~~~~~
        HomoranH GlasfaserG 2 Antworten Letzte Antwort
        • G guergen
          @guergen ich muss ehrlich sagen: davon verstehe ich nichts.
          Allerdings sehe ich etwas, was mich stutzig macht. Kann sein, dass ich da auf dem falschen Dampfer unterwegs bin, aber ich weiß nicht ob da was in:
          @guergen sagte in Adapter werden neu gestartet:
          laufen soll/darf
          • G guergen
            GlasfaserG Offline
            GlasfaserG Offline
            Wäre es nicht besser einen eigenen Thread .... sonst kommen wir hier durcheinander .
            Alle vorliegenden Info´s hier im Thread sind von @matrose65
            • crunchipC Abwesend
              crunchipC Abwesend
              @matrose65 nur reine Vermutung meinerseits, aber wenn ich die verschiedenen Logs betrachte, fällt mir immer zu Beginn hm-rpc auf, Zufall?
              allerdings besitze ich kein hm...
              hm-rpc.0 (147734) xmlrpc -> 192.168.178.93:2001/ init ["http://192.168.178.92:2001",""]
              hm-rpc.0 (147734) Disconnected
                matrose65
                @crunchip
                Guten Morgen
                Ok. Danke, das kann ich auch noch beobachten.
                Der hm-rpc läuft auf Raspberrymatic in einer eigenen VM.
                Der hat aber eigentlich noch nie Probleme gemacht
                  system.adapter.netatmo-crawler.0 terminated due to SIGSEGV]
                  Kannst du diesen Adapter längere Zeit mal ausschalten und das verhalten dann weiter beobachten !?
                  matrose65
                  @glasfaser said in Adapter werden neu gestartet:
                  Hallo
                  Jetzt ist der netatmo-crawler 2 Tage aus.
                  Ich weiß zwar nicht mehr wie kalt es draußen ist, aber der Fehler ist noch nicht wieder aufgetreten.
                    Ich habe schon den Proxmox server und auch den IOB neugestartet.
                    Proxmox Server neu gestartet ohne iobroker zuvor zu beenden?
                    logisch das dann Code 7 (already running) entstehen
                    Meister MopperM Online
                    Meister Mopper
                    @crunchip sagte in Adapter werden neu gestartet:
                    Muss mal hier zu meinem Verständnis nachhaken.
                    Wenn ich auf einem Proxmox node ein reboot anstoße, werden alle LXC und VM dieses node heruntergefahren bevor ein reboot gestartet wird.
                    Ich hatte bisher im Anschluss daran noch nie Probleme.
                    Ist es ratsam, alle LXC und VM vor einem reboot manuell runterzufahren? Und wenn ja, warum?
                    Proxmox und HA ...
                    W 1 Antwort Letzte Antwort
                      W Online
                      W Online
                      Wildbill
                      schrieb am zuletzt editiert von Wildbill
                      @meister-mopper Nein, man muss da manuell gar nix machen. Wenn iobroker in einer VM oder einem LXC installiert ist, so wird iobroker (und die anderen Dienste) sauber beendet, bervor der Neustart erfolgt. Gleiches gilt für LXC und VM generell unter iobroker. Wird der Host heruntergefahren, so fährt Proxmox vorher alle laufenden VM und LXC runter und meldet sich erst dann ab, wenn alles steht und das System fährt dann vollständig runter.
                      Voraussetzung ist aber natürlich jeweils, dass der Anwender sauber herunterfährt. Wenn man eine VM oder einen LXC unter Proxmox per "STOP" anstatt Shutdown abschiesst, so wird ein darin laufender iobroker (oder auch alles andere) natürlich nicht gestoppt. Probleme sind dann vorprogrammiert, ist quasi wie das Steckerziehen bei einem Rechner ohne Herunterfahren. Gleiches gilt für den Host. Zieht man da den Stecker ohne vorher einen shutdown zu machen, so sind alle LXC und VM natürlich auch nicht sauber runtergefahren und nehmen das unter Umständen übel.
                      Wenn alles sauber konfiguriert ist und läuft, so kann man mit einem "sudo reboot" oder "sudo shutdown" , egal ob innerhalb einer VM/LXC oder direkt beim Host, auch wenn noch VM/LXC laufen, eigentlich nichts falsch machen, es sollte alles sauber beenden und gegebenenfalls neu starten.
                      Gruss, Jürgen
                        crunchipC Abwesend
                        @meister-mopper sagte in Adapter werden neu gestartet:
                        nein das erledigt ja eigentlich Proxmox,
                        jedoch kommt es vor, zumindest bei mir
                        wenn die VM einfach nur neugestartet wird, iobroker nicht korrekt beendet wurde und dadurch noch Prozesse liefen, folglich erscheint dann bei dem ein oder anderen Adapter ein code7.
                        Daher die Anmerkung
                        Ich habe mir es deshalb angewöhnt, vor einem Neustart der VM, iobroker zu stoppen
                        • W Wildbill
                          Gruss, Jürgen
                          crunchipC Abwesend
                          crunchipC Abwesend
                          @wildbill sagte in Adapter werden neu gestartet:
                          das ist bei mir hin und wieder das Problem,
                          ein "Herunterfahren" bleibt hin und wieder hängen und die VM beendet sich dann nicht mehr
                          dann hilft nur ein
                          qm stop <vmid>
                            dann hilft nur ein
                            qm stop <vmid>
                            W Online
                            W Online
                            Wildbill
                            @crunchip Hast Du in der VM den Qemu guest agent installiert und aktiviert? Wenn nicht, könnte es sein, dass es da Probleme geben könnte, wenn Befehle zum Neustart oder Herunterfahren von "aussen" vom Host zum Guest geschickt werden. Hast Du das Problem auch, wenn Du per SSH in die VM direkt gehst und dort den Shutdown auslöst?
                            Gruss, Jürgen
                            • W Wildbill
                              Gruss, Jürgen
                              crunchipC Abwesend
                              crunchipC Abwesend
                              ja
                              hab ich nicht probiert, es kommt ja auch nur ab und an mal vor
                                ja
                                W Online
                                W Online
                                Wildbill
                                #66
                                @crunchip Irgendwelche Meldungen in Proxmox unten in der Leiste? Normal taucht ja dann dort was auf, wenn es irgendwo zu einem Fehler kommt.
                                Gruss, Jürgen
                                  crunchipC Abwesend
                                  #67
                                  @wildbill ja logisch kommt dann ne Meldung, Wortlaut hab ich allerdings nicht im Kopf. Hatte ja schon länger nimmer den Fall.
                                  Wenn ich morgen dazu komme, werde ich mal paar Maschine testen
                                  • W Wildbill
                                    Gruss, Jürgen
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    #68
                                    @wildbill heute mal ne VM rebootet
                                    TASK ERROR: VM quit/powerdown failed - got timeout
                                      W Online
                                      W Online
                                      Wildbill
                                      #69
                                      Ich nehme an, das war ein Reboot über die Proxmox-Konsole und nicht aus der VM heraus?
                                      Die Meldung taucht wohl immer wieder mal auf bei Proxmox. Öfters anscheinend in Verbindung mit Debian innerhalb der VM (welches Betriebssystem läuft da bei Dir?). Zudem gab es kürzlich wohl einen Bug in Proxmox selbst, deshalb sollte die aktuellste Version installiert werden, entweder die aktuellste 6.4 oder gleich der 7er-Zweig. HIER steht das auch nochmal so. Aber auch keine wirkliche Lösung.
                                      Gruss, Jürgen
                                      crunchipC Meister MopperM 2 Antworten Letzte Antwort
                                        matrose65
                                        #70
                                        @glasfaser
                                        Guten Morgen
                                        Nach dem seit dem Ausschalten am 04.01.22 17 Uhr keine Fehler mehr waren, war es heute wieder um 08.09 Uhr soweit.
                                        Vorher waren keine Fehler zu sehen. Bis 07.53 Uhr waren nur Abfragen im Zeitplan. Um 07.58 Uhr hat meine Frau den Sonos gestartet. Das auch ohne Probleme.
                                        Und um 08.09.07 ging es los. Beim letzten Eintrag habe ich meine VIS auf dem Tablet aufgerufen. Da war wieder alles in Ordnung
                                        Komische Sache das.
                                        2022-01-08 07:53:00.016 - info: host.iobroker instance system.adapter.dwd.0 started with pid 174216
                                        2022-01-08 07:53:00.504 - info: dwd.0 (174216) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.18.2, js-controller: 3.3.22
                                        2022-01-08 07:53:00.986 - info: dwd.0 (174216) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2022-01-08 07:53:01.505 - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2022-01-08 07:58:26.455 - info: sonos.0 (173891) try to control id sonos.0.root.192_168_178_31.play with {"val":true,"ack":false,"ts":1641625106453,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1640019319143}
                                        2022-01-08 08:09:07.855 - info: sonos.0 (173891) terminating
                                        2022-01-08 08:09:07.855 - info: fullybrowser.0 (149136) cleaned everything up...
                                        2022-01-08 08:09:07.860 - info: web.0 (149597) terminated http server on port 8082
                                        2022-01-08 08:09:07.853 - info: admin.0 (173066) terminating http server on port 8081
                                        2022-01-08 08:09:07.856 - info: netatmo.0 (148927) cleaned everything up...
                                        2022-01-08 08:09:07.859 - info: info.0 (149166) cleaned everything up...
                                        2022-01-08 08:09:07.858 - info: backitup.0 (149084) cleaned everything up...
                                        2022-01-08 08:09:07.862 - info: hm-rpc.0 (148860) xmlrpc -> 192.168.178.93:2001/ init ["http://192.168.178.92:2001",""]
                                        2022-01-08 08:09:07.855 - info: shelly.0 (148957) Closing Adapter
                                        2022-01-08 08:09:07.893 - info: hm-rpc.0 (148860) Disconnected
                                        2022-01-08 08:09:07.869 - info: javascript.0 (148782) Stop script script.js.Automaten.Küche-Tablet_Screen
                                        2022-01-08 08:09:07.887 - info: javascript.0 (148782) Stop script script.js.Bad.Bad-Nachtlicht
                                        2022-01-08 08:09:07.888 - info: javascript.0 (148782) Stop script script.js.Heizung.Heizung_Arbeitszimmer
                                        2022-01-08 08:09:07.888 - info: javascript.0 (148782) Stop script script.js.Heizung.Heizung_Arbeitszimmer_Kontrolle
                                        2022-01-08 08:09:07.888 - info: javascript.0 (148782) Stop script script.js.Heizung.Heizung_Bad
                                        2022-01-08 08:09:07.889 - info: javascript.0 (148782) Stop script script.js.Heizung.Heizung_Bad_Kontrolle
                                        2022-01-08 08:09:07.889 - info: javascript.0 (148782) Stop script script.js.Heizung.Heizung_Esszimmer
                                        2022-01-08 08:09:07.889 - info: javascript.0 (148782) Stop script script.js.Heizung.Heizung_Esszimmer_Kontrolle
                                        2022-01-08 08:09:07.890 - info: javascript.0 (148782) Stop script script.js.Heizung.Heizung_Küche
                                        2022-01-08 08:09:07.890 - info: javascript.0 (148782) Stop script script.js.Heizung.Heizung_Küche_Kontrolle
                                        2022-01-08 08:09:07.890 - info: javascript.0 (148782) Stop script script.js.Heizung.Heizung_Wohnzimmer
                                        2022-01-08 08:09:07.890 - info: javascript.0 (148782) Stop script script.js.Heizung.Heizung_Wohnzimmer_Kontrolle
                                        2022-01-08 08:09:07.891 - info: javascript.0 (148782) Stop script script.js.Ikea-Licht.Esszimmer-Lampe
                                        2022-01-08 08:09:07.892 - info: javascript.0 (148782) Stop script script.js.Ikea-Licht.Esszimmer-Lampe-Dimmer
                                        2022-01-08 08:09:07.892 - info: javascript.0 (148782) Stop script script.js.Ikea-Licht.Esszimmer-Lampe-Radio
                                        2022-01-08 08:09:07.893 - info: javascript.0 (148782) Stop script script.js.Ikea-Licht.Lampe-Wohnzimmer-Dimmer
                                        2022-01-08 08:09:07.893 - info: javascript.0 (148782) Stop script script.js.Ikea-Licht.Wohnzimmer-Lampe
                                        2022-01-08 08:09:07.893 - info: javascript.0 (148782) Stop script script.js.Sonos.Gruppenbildung
                                        2022-01-08 08:09:07.893 - info: javascript.0 (148782) Stop script script.js.Sonos.Gruppenbildung2
                                        2022-01-08 08:09:07.893 - info: javascript.0 (148782) Stop script script.js.Sonos.Sonos_Favoriten_Ess
                                        2022-01-08 08:09:07.893 - info: javascript.0 (148782) Stop script script.js.Sonos.Sonos_Favoriten_Küche
                                        2022-01-08 08:09:07.894 - info: javascript.0 (148782) Stop script script.js.Sonos.Sonos_Favoriten_WZ
                                        2022-01-08 08:09:07.859 - info: zigbee.0 (149043) cleaned everything up...
                                        2022-01-08 08:09:07.870 - info: zigbee.0 (149043) Zigbee: disabling joining new devices.
                                        2022-01-08 08:09:09.355 - info: sonoff.0 (149151) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                        2022-01-08 08:09:09.358 - info: fullybrowser.0 (149136) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                        2022-01-08 08:09:09.359 - info: web.0 (149597) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                        2022-01-08 08:09:09.358 - info: tankerkoenig.0 (149582) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                        2022-01-08 08:09:09.368 - info: sonos.0 (173891) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                        2022-01-08 08:09:09.371 - info: zigbee.0 (149043) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                        2022-01-08 08:09:09.372 - info: javascript.0 (148782) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                        2022-01-08 08:09:09.374 - info: admin.0 (173066) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                        2022-01-08 08:09:09.365 - info: tr-064.0 (157163) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                        2022-01-08 08:09:09.363 - info: hm-rega.0 (148834) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                        2022-01-08 08:09:09.364 - info: scenes.0 (148808) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                        2022-01-08 08:09:09.378 - info: backitup.0 (149084) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                        2022-01-08 08:09:09.380 - info: netatmo.0 (148927) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                        2022-01-08 08:09:09.382 - info: info.0 (149166) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                        2022-01-08 08:09:09.384 - info: shelly.0 (148957) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                        2022-01-08 08:09:09.887 - info: hm-rpc.0 (148860) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                        2022-01-08 08:09:12.845 - error: tankerkoenig.0 (149582) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                        2022-01-08 08:09:12.853 - error: netatmo.0 (148927) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                        2022-01-08 08:09:12.850 - warn: hm-rpc.0 (148860) get state error: DB closed
                                        2022-01-08 08:09:12.853 - error: fullybrowser.0 (149136) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                        2022-01-08 08:09:12.851 - error: web.0 (149597) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                        2022-01-08 08:09:12.853 - warn: web.0 (149597) get state error: Connection is closed.
                                        2022-01-08 08:09:12.853 - warn: web.0 (149597) get state error: DB closed
                                        2022-01-08 08:09:12.849 - error: info.0 (149166) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                        2022-01-08 08:09:12.854 - warn: hm-rpc.0 (148860) get state error: DB closed
                                        2022-01-08 08:09:12.856 - error: hm-rega.0 (148834) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                        2022-01-08 08:09:12.863 - error: sonoff.0 (149151) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                        2022-01-08 08:09:12.856 - error: backitup.0 (149084) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                        2022-01-08 08:09:12.867 - error: tr-064.0 (157163) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                        2022-01-08 08:09:12.868 - error: shelly.0 (148957) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                        2022-01-08 08:09:12.871 - error: sonos.0 (173891) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                        2022-01-08 08:09:12.875 - warn: hm-rega.0 (148834) get state error: Connection is closed.
                                        2022-01-08 08:09:12.882 - error: admin.0 (173066) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                        2022-01-08 08:09:12.884 - error: zigbee.0 (149043) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                        2022-01-08 08:09:12.885 - error: javascript.0 (148782) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                        2022-01-08 08:09:12.896 - error: scenes.0 (148808) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                                        2022-01-08 08:09:12.893 - warn: javascript.0 (148782) get state error: DB closed
                                        2022-01-08 08:09:12.894 - warn: javascript.0 (148782) get state error: DB closed
                                        2022-01-08 08:09:18.384 - info: host.iobroker iobroker.js-controller version 3.3.22 js-controller starting
                                        2022-01-08 08:09:18.386 - info: host.iobroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                                        2022-01-08 08:09:18.387 - info: host.iobroker hostname: iobroker, node: v14.18.2
                                        2022-01-08 08:09:18.387 - info: host.iobroker ip addresses: 192.168.178.92 2a01:5241:24a:1600:d400:abff:fe33:1f59 fe80::d400:abff:fe33:1f59
                                        2022-01-08 08:09:18.391 - debug: host.iobroker-Server Data File: /opt/iobroker/iobroker-data/objects.json
                                        2022-01-08 08:09:18.500 - debug: host.iobroker-Server Redis inMem-objects listening on port 9001
                                        2022-01-08 08:09:18.501 - debug: host.iobroker Redis Objects: Use Redis connection: 127.0.0.1:9001
                                        2022-01-08 08:09:18.510 - debug: host.iobroker Objects client ready ... initialize now
                                        2022-01-08 08:09:18.511 - debug: host.iobroker Objects create System PubSub Client
                                        2022-01-08 08:09:18.512 - debug: host.iobroker Objects client initialize lua scripts
                                        2022-01-08 08:09:18.520 - debug: host.iobroker Objects connected to redis: 127.0.0.1:9001
                                        2022-01-08 08:09:18.521 - debug: host.iobroker-Server Data File: /opt/iobroker/iobroker-data/states.json
                                        2022-01-08 08:09:18.535 - debug: host.iobroker-Server Redis inMem-states listening on port 9000
                                        2022-01-08 08:09:18.536 - debug: host.iobroker Redis States: Use Redis connection: 127.0.0.1:9000
                                        2022-01-08 08:09:18.539 - debug: host.iobroker States create System PubSub Client
                                        2022-01-08 08:09:18.552 - debug: host.iobroker States connected to redis: 127.0.0.1:9000
                                        2022-01-08 08:09:18.576 - info: host.iobroker connected to Objects and States
                                        2022-01-08 08:09:18.602 - info: host.iobroker added notifications configuration of host
                                        2022-01-08 08:09:18.681 - debug: host.iobroker Plugin sentry Initialize Plugin (enabled=true)
                                        2022-01-08 08:09:18.781 - info: host.iobroker 29 instances found
                                        2022-01-08 08:09:18.781 - debug: host.iobroker check instance "system.adapter.admin.0" for host "iobroker"
                                        2022-01-08 08:09:18.783 - debug: host.iobroker check instance "system.adapter.javascript.0" for host "iobroker"
                                        2022-01-08 08:09:18.785 - debug: host.iobroker check instance "system.adapter.scenes.0" for host "iobroker"
                                        2022-01-08 08:09:18.786 - debug: host.iobroker check instance "system.adapter.hm-rega.0" for host "iobroker"
                                        2022-01-08 08:09:18.787 - debug: host.iobroker check instance "system.adapter.hm-rpc.0" for host "iobroker"
                                        2022-01-08 08:09:18.788 - debug: host.iobroker check instance "system.adapter.ical.0" for host "iobroker"
                                        2022-01-08 08:09:18.789 - debug: host.iobroker check instance "system.adapter.ical.2" for host "iobroker"
                                        2022-01-08 08:09:18.790 - debug: host.iobroker check instance "system.adapter.ical.3" for host "iobroker"
                                        2022-01-08 08:09:18.791 - debug: host.iobroker check instance "system.adapter.netatmo.0" for host "iobroker"
                                        2022-01-08 08:09:18.791 - debug: host.iobroker check instance "system.adapter.shelly.0" for host "iobroker"
                                        2022-01-08 08:09:18.792 - debug: host.iobroker check instance "system.adapter.sonoff.0" for host "iobroker"
                                        2022-01-08 08:09:18.792 - debug: host.iobroker check instance "system.adapter.tr-064.0" for host "iobroker"
                                        2022-01-08 08:09:18.792 - debug: host.iobroker check instance "system.adapter.zigbee.0" for host "iobroker"
                                        2022-01-08 08:09:18.793 - debug: host.iobroker check instance "system.adapter.backitup.0" for host "iobroker"
                                        2022-01-08 08:09:18.794 - debug: host.iobroker check instance "system.adapter.daswetter.0" for host "iobroker"
                                        2022-01-08 08:09:18.794 - debug: host.iobroker check instance "system.adapter.dwd.0" for host "iobroker"
                                        2022-01-08 08:09:18.795 - debug: host.iobroker check instance "system.adapter.feiertage.0" for host "iobroker"
                                        2022-01-08 08:09:18.795 - debug: host.iobroker check instance "system.adapter.fullybrowser.0" for host "iobroker"
                                        2022-01-08 08:09:18.796 - debug: host.iobroker check instance "system.adapter.info.0" for host "iobroker"
                                        2022-01-08 08:09:18.797 - debug: host.iobroker check instance "system.adapter.netatmo-crawler.0" for host "iobroker"
                                        2022-01-08 08:09:18.797 - debug: host.iobroker check instance "system.adapter.sonos.0" for host "iobroker"
                                        2022-01-08 08:09:18.798 - debug: host.iobroker check instance "system.adapter.tankerkoenig.0" for host "iobroker"
                                        2022-01-08 08:09:18.799 - debug: host.iobroker check instance "system.adapter.vis-hqwidgets.0" for host "iobroker"
                                        2022-01-08 08:09:18.800 - debug: host.iobroker check instance "system.adapter.vis-metro.0" for host "iobroker"
                                        2022-01-08 08:09:18.800 - debug: host.iobroker check instance "system.adapter.vis-players.0" for host "iobroker"
                                        2022-01-08 08:09:18.800 - debug: host.iobroker check instance "system.adapter.vis-timeandweather.0" for host "iobroker"
                                        2022-01-08 08:09:18.801 - debug: host.iobroker check instance "system.adapter.vis.0" for host "iobroker"
                                        2022-01-08 08:09:18.801 - debug: host.iobroker check instance "system.adapter.web.0" for host "iobroker"
                                        2022-01-08 08:09:18.802 - info: host.iobroker starting 23 instances
                                        2022-01-08 08:09:18.833 - debug: host.iobroker added notifications configuration of system.adapter.admin.0
                                        2022-01-08 08:09:18.833 - debug: host.iobroker startInstance admin.0 loglevel=info, compact=false
                                        2022-01-08 08:09:18.842 - info: host.iobroker instance system.adapter.admin.0 started with pid 174256
                                        2022-01-08 08:09:19.307 - error: admin.0 (174256) admin.0 already running
                                        2022-01-08 08:09:19.308 - warn: admin.0 (174256) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                        2022-01-08 08:09:19.841 - error: host.iobroker instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                        2022-01-08 08:09:19.841 - debug: host.iobroker Reset crash count of system.adapter.admin.0, because non-crash exit
                                        2022-01-08 08:09:19.841 - info: host.iobroker Restart adapter system.adapter.admin.0 because enabled
                                        2022-01-08 08:09:22.828 - debug: host.iobroker added notifications configuration of system.adapter.javascript.0
                                        2022-01-08 08:09:22.829 - debug: host.iobroker startInstance javascript.0 loglevel=info, compact=false
                                        2022-01-08 08:09:22.835 - info: host.iobroker instance system.adapter.javascript.0 started with pid 174267
                                        2022-01-08 08:09:23.516 - error: javascript.0 (174267) javascript.0 already running
                                        2022-01-08 08:09:23.518 - warn: javascript.0 (174267) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                        2022-01-08 08:09:24.048 - error: host.iobroker instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                        2022-01-08 08:09:24.048 - debug: host.iobroker Reset crash count of system.adapter.javascript.0, because non-crash exit
                                        2022-01-08 08:09:24.048 - info: host.iobroker Restart adapter system.adapter.javascript.0 because enabled
                                        2022-01-08 08:09:26.832 - debug: host.iobroker added notifications configuration of system.adapter.scenes.0
                                        2022-01-08 08:09:26.833 - debug: host.iobroker startInstance scenes.0 loglevel=info, compact=false
                                        2022-01-08 08:09:26.841 - info: host.iobroker instance system.adapter.scenes.0 started with pid 174278
                                        2022-01-08 08:09:27.169 - error: scenes.0 (174278) scenes.0 already running
                                        2022-01-08 08:09:27.170 - warn: scenes.0 (174278) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                        2022-01-08 08:09:27.699 - error: host.iobroker instance system.adapter.scenes.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                        2022-01-08 08:09:27.699 - debug: host.iobroker Reset crash count of system.adapter.scenes.0, because non-crash exit
                                        2022-01-08 08:09:27.699 - info: host.iobroker Restart adapter system.adapter.scenes.0 because enabled
                                        2022-01-08 08:09:30.823 - debug: host.iobroker added notifications configuration of system.adapter.hm-rega.0
                                        2022-01-08 08:09:30.823 - debug: host.iobroker startInstance hm-rega.0 loglevel=info, compact=false
                                        2022-01-08 08:09:30.830 - info: host.iobroker instance system.adapter.hm-rega.0 started with pid 174290
                                        2022-01-08 08:09:31.253 - error: hm-rega.0 (174290) hm-rega.0 already running
                                        2022-01-08 08:09:31.254 - warn: hm-rega.0 (174290) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                        2022-01-08 08:09:31.783 - error: host.iobroker instance system.adapter.hm-rega.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                        2022-01-08 08:09:31.783 - debug: host.iobroker Reset crash count of system.adapter.hm-rega.0, because non-crash exit
                                        2022-01-08 08:09:31.783 - info: host.iobroker Restart adapter system.adapter.hm-rega.0 because enabled
                                        2022-01-08 08:09:34.821 - debug: host.iobroker added notifications configuration of system.adapter.hm-rpc.0
                                        2022-01-08 08:09:34.822 - debug: host.iobroker startInstance hm-rpc.0 loglevel=info, compact=false
                                        2022-01-08 08:09:34.828 - info: host.iobroker instance system.adapter.hm-rpc.0 started with pid 174301
                                        2022-01-08 08:09:35.162 - error: hm-rpc.0 (174301) hm-rpc.0 already running
                                        2022-01-08 08:09:35.163 - warn: hm-rpc.0 (174301) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                        2022-01-08 08:09:35.696 - error: host.iobroker instance system.adapter.hm-rpc.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                        2022-01-08 08:09:35.696 - debug: host.iobroker Reset crash count of system.adapter.hm-rpc.0, because non-crash exit
                                        2022-01-08 08:09:35.696 - info: host.iobroker Restart adapter system.adapter.hm-rpc.0 because enabled
                                        2022-01-08 08:09:38.838 - debug: host.iobroker added notifications configuration of system.adapter.ical.0
                                        2022-01-08 08:09:38.860 - info: host.iobroker instance scheduled system.adapter.ical.0 56 0,3,6,9,12,15,18,21 * * *
                                        2022-01-08 08:09:38.864 - info: host.iobroker instance system.adapter.ical.0 started with pid 174312
                                        2022-01-08 08:09:39.460 - info: ical.0 (174312) starting. Version 1.11.6 in /opt/iobroker/node_modules/iobroker.ical, node: v14.18.2, js-controller: 3.3.22
                                        2022-01-08 08:09:40.023 - info: ical.0 (174312) processing URL: Familie hier ist nix
                                        2022-01-08 08:09:42.822 - debug: host.iobroker added notifications configuration of system.adapter.ical.2
                                        2022-01-08 08:09:42.827 - info: host.iobroker instance scheduled system.adapter.ical.2 58 3 * * *
                                        2022-01-08 08:09:42.831 - info: host.iobroker instance system.adapter.ical.2 started with pid 174327
                                        2022-01-08 08:09:43.423 - info: ical.2 (174327) starting. Version 1.11.6 in /opt/iobroker/node_modules/iobroker.ical, node: v14.18.2, js-controller: 3.3.22
                                        2022-01-08 08:09:43.741 - info: ical.2 (174327) processing URL: Geburtstag auch das weg
                                        2022-01-08 08:09:45.143 - info: ical.0 (174312) Terminated (NO_ERROR): Without reason
                                        2022-01-08 08:09:45.670 - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                                        2022-01-08 08:09:46.821 - debug: host.iobroker added notifications configuration of system.adapter.ical.3
                                        2022-01-08 08:09:46.827 - info: host.iobroker instance scheduled system.adapter.ical.3 57 3 * * *
                                        2022-01-08 08:09:46.831 - info: host.iobroker instance system.adapter.ical.3 started with pid 174342
                                        2022-01-08 08:09:47.411 - info: ical.3 (174342) starting. Version 1.11.6 in /opt/iobroker/node_modules/iobroker.ical, node: v14.18.2, js-controller: 3.3.22
                                        2022-01-08 08:09:48.245 - info: ical.3 (174342) processing URL: Arbeit nix mehr
                                        2022-01-08 08:09:48.821 - info: ical.2 (174327) Terminated (NO_ERROR): Without reason
                                        2022-01-08 08:09:49.349 - info: host.iobroker instance system.adapter.ical.2 terminated with code 0 (NO_ERROR)
                                        2022-01-08 08:09:49.845 - debug: host.iobroker added notifications configuration of system.adapter.admin.0
                                        2022-01-08 08:09:49.845 - debug: host.iobroker startInstance admin.0 loglevel=info, compact=false
                                        2022-01-08 08:09:49.851 - info: host.iobroker instance system.adapter.admin.0 started with pid 174357
                                        2022-01-08 08:09:50.345 - info: admin.0 (174357) Plugin sentry Sentry Plugin disabled for this process because data reporting is disabled on instance
                                        2022-01-08 08:09:50.350 - info: admin.0 (174357) starting. Version 5.2.3 in /opt/iobroker/node_modules/iobroker.admin, node: v14.18.2, js-controller: 3.3.22
                                        2022-01-08 08:09:50.367 - info: admin.0 (174357) requesting all states
                                        2022-01-08 08:09:50.367 - info: admin.0 (174357) requesting all objects
                                        2022-01-08 08:09:50.694 - info: admin.0 (174357) received all objects
                                        2022-01-08 08:09:50.804 - debug: host.iobroker added notifications configuration of system.adapter.netatmo.0
                                        2022-01-08 08:09:50.814 - info: admin.0 (174357) http server listening on port 8081
                                        2022-01-08 08:09:50.804 - debug: host.iobroker startInstance netatmo.0 loglevel=info, compact=false
                                        2022-01-08 08:09:50.814 - info: host.iobroker instance system.adapter.netatmo.0 started with pid 174372
                                        2022-01-08 08:09:50.814 - info: admin.0 (174357) Use link "http://localhost:8081" to configure.
                                        2022-01-08 08:09:51.240 - error: netatmo.0 (174372) netatmo.0 already running
                                        2022-01-08 08:09:51.240 - warn: netatmo.0 (174372) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                        2022-01-08 08:09:51.771 - error: host.iobroker instance system.adapter.netatmo.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                        2022-01-08 08:09:51.771 - debug: host.iobroker Reset crash count of system.adapter.netatmo.0, because non-crash exit
                                        2022-01-08 08:09:51.771 - info: host.iobroker Restart adapter system.adapter.netatmo.0 because enabled
                                        2022-01-08 08:09:53.456 - info: ical.3 (174342) Terminated (NO_ERROR): Without reason
                                        2022-01-08 08:09:53.979 - info: host.iobroker instance system.adapter.ical.3 terminated with code 0 (NO_ERROR)
                                        2022-01-08 08:09:54.050 - debug: host.iobroker added notifications configuration of system.adapter.javascript.0
                                        2022-01-08 08:09:54.050 - debug: host.iobroker startInstance javascript.0 loglevel=info, compact=false
                                        2022-01-08 08:09:54.056 - info: host.iobroker instance system.adapter.javascript.0 started with pid 174383
                                        2022-01-08 08:09:54.830 - debug: host.iobroker added notifications configuration of system.adapter.shelly.0
                                        2022-01-08 08:09:54.831 - debug: host.iobroker startInstance shelly.0 loglevel=info, compact=false
                                        2022-01-08 08:09:54.838 - info: host.iobroker instance system.adapter.shelly.0 started with pid 174394
                                        2022-01-08 08:09:54.874 - info: javascript.0 (174383) starting. Version 5.2.18 in /opt/iobroker/node_modules/iobroker.javascript, node: v14.18.2, js-controller: 3.3.22
                                        2022-01-08 08:09:54.915 - info: javascript.0 (174383) requesting all states
                                        2022-01-08 08:09:54.916 - info: javascript.0 (174383) requesting all objects
                                        2022-01-08 08:09:55.241 - info: javascript.0 (174383) received all objects
                                        2022-01-08 08:09:55.316 - info: javascript.0 (174383) received all states
                                        2022-01-08 08:09:55.343 - info: javascript.0 (174383) Start javascript script.js.Automaten.Küche-Tablet_Screen
                                        2022-01-08 08:09:55.364 - info: javascript.0 (174383) script.js.Automaten.Küche-Tablet_Screen: registered 1 subscription and 0 schedules
                                        2022-01-08 08:09:55.364 - info: javascript.0 (174383) Start javascript script.js.Bad.Bad-Nachtlicht
                                        2022-01-08 08:09:55.366 - info: javascript.0 (174383) script.js.Bad.Bad-Nachtlicht: registered 1 subscription and 0 schedules
                                        2022-01-08 08:09:55.367 - info: javascript.0 (174383) Start javascript script.js.Heizung.Heizung_Arbeitszimmer
                                        2022-01-08 08:09:55.369 - info: javascript.0 (174383) script.js.Heizung.Heizung_Arbeitszimmer: registered 1 subscription and 0 schedules
                                        2022-01-08 08:09:55.370 - info: javascript.0 (174383) Start javascript script.js.Heizung.Heizung_Arbeitszimmer_Kontrolle
                                        2022-01-08 08:09:55.371 - info: javascript.0 (174383) script.js.Heizung.Heizung_Arbeitszimmer_Kontrolle: registered 1 subscription and 0 schedules
                                        2022-01-08 08:09:55.421 - error: shelly.0 (174394) shelly.0 already running
                                        2022-01-08 08:09:55.423 - warn: shelly.0 (174394) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                        2022-01-08 08:09:55.373 - info: javascript.0 (174383) Start javascript script.js.Heizung.Heizung_Bad
                                        2022-01-08 08:09:55.376 - info: javascript.0 (174383) script.js.Heizung.Heizung_Bad: registered 1 subscription and 0 schedules
                                        2022-01-08 08:09:55.376 - info: javascript.0 (174383) Start javascript script.js.Heizung.Heizung_Bad_Kontrolle
                                        2022-01-08 08:09:55.379 - info: javascript.0 (174383) script.js.Heizung.Heizung_Bad_Kontrolle: registered 1 subscription and 0 schedules
                                        2022-01-08 08:09:55.379 - info: javascript.0 (174383) Start javascript script.js.Heizung.Heizung_Esszimmer
                                        2022-01-08 08:09:55.381 - info: javascript.0 (174383) script.js.Heizung.Heizung_Esszimmer: registered 1 subscription and 0 schedules
                                        2022-01-08 08:09:55.382 - info: javascript.0 (174383) Start javascript script.js.Heizung.Heizung_Esszimmer_Kontrolle
                                        2022-01-08 08:09:55.384 - info: javascript.0 (174383) script.js.Heizung.Heizung_Esszimmer_Kontrolle: registered 1 subscription and 0 schedules
                                        2022-01-08 08:09:55.384 - info: javascript.0 (174383) Start javascript script.js.Heizung.Heizung_Küche
                                        2022-01-08 08:09:55.387 - info: javascript.0 (174383) script.js.Heizung.Heizung_Küche: registered 1 subscription and 0 schedules
                                        2022-01-08 08:09:55.387 - info: javascript.0 (174383) Start javascript script.js.Heizung.Heizung_Küche_Kontrolle
                                        2022-01-08 08:09:55.389 - info: javascript.0 (174383) script.js.Heizung.Heizung_Küche_Kontrolle: registered 1 subscription and 0 schedules
                                        2022-01-08 08:09:55.390 - info: javascript.0 (174383) Start javascript script.js.Heizung.Heizung_Wohnzimmer
                                        2022-01-08 08:09:55.393 - info: javascript.0 (174383) script.js.Heizung.Heizung_Wohnzimmer: registered 1 subscription and 0 schedules
                                        2022-01-08 08:09:55.393 - info: javascript.0 (174383) Start javascript script.js.Heizung.Heizung_Wohnzimmer_Kontrolle
                                        2022-01-08 08:09:55.395 - info: javascript.0 (174383) script.js.Heizung.Heizung_Wohnzimmer_Kontrolle: registered 1 subscription and 0 schedules
                                        2022-01-08 08:09:55.396 - info: javascript.0 (174383) Start javascript script.js.Ikea-Licht.Esszimmer-Lampe
                                        2022-01-08 08:09:55.398 - info: javascript.0 (174383) script.js.Ikea-Licht.Esszimmer-Lampe: registered 2 subscriptions and 0 schedules
                                        2022-01-08 08:09:55.399 - info: javascript.0 (174383) Start javascript script.js.Ikea-Licht.Esszimmer-Lampe-Dimmer
                                        2022-01-08 08:09:55.401 - info: javascript.0 (174383) script.js.Ikea-Licht.Esszimmer-Lampe-Dimmer: registered 3 subscriptions and 0 schedules
                                        2022-01-08 08:09:55.401 - info: javascript.0 (174383) Start javascript script.js.Ikea-Licht.Esszimmer-Lampe-Radio
                                        2022-01-08 08:09:55.403 - info: javascript.0 (174383) script.js.Ikea-Licht.Esszimmer-Lampe-Radio: registered 2 subscriptions and 0 schedules
                                        2022-01-08 08:09:55.433 - info: javascript.0 (174383) Start javascript script.js.Ikea-Licht.Lampe-Wohnzimmer-Dimmer
                                        2022-01-08 08:09:55.435 - info: javascript.0 (174383) script.js.Ikea-Licht.Lampe-Wohnzimmer-Dimmer: registered 3 subscriptions and 0 schedules
                                        2022-01-08 08:09:55.435 - info: javascript.0 (174383) Start javascript script.js.Ikea-Licht.Wohnzimmer-Lampe
                                        2022-01-08 08:09:55.436 - info: javascript.0 (174383) script.js.Ikea-Licht.Wohnzimmer-Lampe: registered 2 subscriptions and 0 schedules
                                        2022-01-08 08:09:55.437 - info: javascript.0 (174383) Start javascript script.js.Sonos.Gruppenbildung
                                        2022-01-08 08:09:55.438 - info: javascript.0 (174383) script.js.Sonos.Gruppenbildung: registered 1 subscription and 0 schedules
                                        2022-01-08 08:09:55.438 - info: javascript.0 (174383) Start javascript script.js.Sonos.Gruppenbildung2
                                        2022-01-08 08:09:55.440 - info: javascript.0 (174383) script.js.Sonos.Gruppenbildung2: registered 1 subscription and 0 schedules
                                        2022-01-08 08:09:55.440 - info: javascript.0 (174383) Start javascript script.js.Sonos.Sonos_Favoriten_Ess
                                        2022-01-08 08:09:55.442 - info: javascript.0 (174383) script.js.Sonos.Sonos_Favoriten_Ess: registered 1 subscription and 0 schedules
                                        2022-01-08 08:09:55.442 - info: javascript.0 (174383) Start javascript script.js.Sonos.Sonos_Favoriten_Küche
                                        2022-01-08 08:09:55.444 - info: javascript.0 (174383) script.js.Sonos.Sonos_Favoriten_Küche: registered 1 subscription and 0 schedules
                                        2022-01-08 08:09:55.444 - info: javascript.0 (174383) Start javascript script.js.Sonos.Sonos_Favoriten_WZ
                                        2022-01-08 08:09:55.446 - info: javascript.0 (174383) script.js.Sonos.Sonos_Favoriten_WZ: registered 1 subscription and 0 schedules
                                        2022-01-08 08:09:55.951 - error: host.iobroker instance system.adapter.shelly.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                        2022-01-08 08:09:55.951 - debug: host.iobroker Reset crash count of system.adapter.shelly.0, because non-crash exit
                                        2022-01-08 08:09:55.951 - info: host.iobroker Restart adapter system.adapter.shelly.0 because enabled
                                        2022-01-08 08:09:57.701 - debug: host.iobroker added notifications configuration of system.adapter.scenes.0
                                        2022-01-08 08:09:57.701 - debug: host.iobroker startInstance scenes.0 loglevel=info, compact=false
                                        2022-01-08 08:09:57.708 - info: host.iobroker instance system.adapter.scenes.0 started with pid 174409
                                        2022-01-08 08:09:58.157 - info: scenes.0 (174409) starting. Version 2.3.8 in /opt/iobroker/node_modules/iobroker.scenes, node: v14.18.2, js-controller: 3.3.22
                                        2022-01-08 08:09:58.820 - debug: host.iobroker added notifications configuration of system.adapter.sonoff.0
                                        2022-01-08 08:09:58.820 - debug: host.iobroker startInstance sonoff.0 loglevel=info, compact=false
                                        2022-01-08 08:09:58.827 - info: host.iobroker instance system.adapter.sonoff.0 started with pid 174424
                                        2022-01-08 08:09:59.185 - error: sonoff.0 (174424) sonoff.0 already running
                                        2022-01-08 08:09:59.186 - warn: sonoff.0 (174424) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                        2022-01-08 08:09:59.715 - error: host.iobroker instance system.adapter.sonoff.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                        2022-01-08 08:09:59.715 - debug: host.iobroker Reset crash count of system.adapter.sonoff.0, because non-crash exit
                                        2022-01-08 08:09:59.715 - info: host.iobroker Restart adapter system.adapter.sonoff.0 because enabled
                                        2022-01-08 08:10:01.786 - debug: host.iobroker added notifications configuration of system.adapter.hm-rega.0
                                        2022-01-08 08:10:01.786 - debug: host.iobroker startInstance hm-rega.0 loglevel=info, compact=false
                                        2022-01-08 08:10:01.793 - info: host.iobroker instance system.adapter.hm-rega.0 started with pid 174435
                                        2022-01-08 08:10:02.371 - info: hm-rega.0 (174435) starting. Version 3.0.33 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v14.18.2, js-controller: 3.3.22
                                        2022-01-08 08:10:02.419 - info: hm-rega.0 (174435) subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
                                        2022-01-08 08:10:02.436 - info: hm-rega.0 (174435) ReGaHSS 192.168.178.93 up
                                        2022-01-08 08:10:02.503 - info: hm-rega.0 (174435) time difference local-ccu 1s
                                        2022-01-08 08:10:02.754 - info: hm-rega.0 (174435) request state values
                                        2022-01-08 08:10:02.820 - debug: host.iobroker added notifications configuration of system.adapter.tr-064.0
                                        2022-01-08 08:10:02.820 - debug: host.iobroker startInstance tr-064.0 loglevel=info, compact=false
                                        2022-01-08 08:10:02.828 - info: host.iobroker instance system.adapter.tr-064.0 started with pid 174450
                                        2022-01-08 08:10:02.975 - info: hm-rega.0 (174435) Updated all datapoints
                                        2022-01-08 08:10:02.979 - info: hm-rega.0 (174435) got 5 variables
                                        2022-01-08 08:10:03.015 - info: hm-rega.0 (174435) added/updated 5 variables
                                        2022-01-08 08:10:03.015 - info: hm-rega.0 (174435) deleted 0 variables
                                        2022-01-08 08:10:03.022 - info: hm-rega.0 (174435) got 0 programs
                                        2022-01-08 08:10:03.025 - info: hm-rega.0 (174435) update rooms to enum.rooms
                                        2022-01-08 08:10:03.029 - info: hm-rega.0 (174435) added/updated 0 programs
                                        2022-01-08 08:10:03.030 - info: hm-rega.0 (174435) deleted 0 programs
                                        2022-01-08 08:10:03.078 - info: hm-rega.0 (174435) update functions to enum.functions
                                        2022-01-08 08:10:03.093 - info: hm-rega.0 (174435) update favorites to enum.favorites
                                        2022-01-08 08:10:03.094 - error: hm-rega.0 (174435) Could not synchronize favorites of user "": Error: The id "enum.favorites." is invalid. Ids are not allowed to end in "."
                                        2022-01-08 08:10:03.317 - error: tr-064.0 (174450) tr-064.0 already running
                                        2022-01-08 08:10:03.318 - warn: tr-064.0 (174450) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                        2022-01-08 08:10:03.846 - error: host.iobroker instance system.adapter.tr-064.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                        2022-01-08 08:10:03.846 - debug: host.iobroker Reset crash count of system.adapter.tr-064.0, because non-crash exit
                                        2022-01-08 08:10:03.846 - info: host.iobroker Restart adapter system.adapter.tr-064.0 because enabled
                                        2022-01-08 08:10:05.698 - debug: host.iobroker added notifications configuration of system.adapter.hm-rpc.0
                                        2022-01-08 08:10:05.698 - debug: host.iobroker startInstance hm-rpc.0 loglevel=info, compact=false
                                        2022-01-08 08:10:05.705 - info: host.iobroker instance system.adapter.hm-rpc.0 started with pid 174461
                                        2022-01-08 08:10:06.190 - info: hm-rpc.0 (174461) starting. Version 1.15.0 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v14.18.2, js-controller: 3.3.22
                                        2022-01-08 08:10:06.236 - info: hm-rpc.0 (174461) xmlrpc server is trying to listen on 192.168.178.92:2001
                                        2022-01-08 08:10:06.237 - info: hm-rpc.0 (174461) xmlrpc client is trying to connect to 192.168.178.93:2001/ with ["http://192.168.178.92:2001","iobroker:hm-rpc.0"]
                                        2022-01-08 08:10:06.247 - info: hm-rpc.0 (174461) xmlrpc <- system.listMethods ["iobroker:hm-rpc.0"]
                                        2022-01-08 08:10:06.250 - info: hm-rpc.0 (174461) xmlrpc <- listDevices ["iobroker:hm-rpc.0"]
                                        2022-01-08 08:10:06.264 - info: hm-rpc.0 (174461) xmlrpc -> 92 devices
                                        2022-01-08 08:10:06.272 - info: hm-rpc.0 (174461) Connected
                                        2022-01-08 08:10:06.804 - debug: host.iobroker added notifications configuration of system.adapter.zigbee.0
                                        2022-01-08 08:10:06.804 - debug: host.iobroker startInstance zigbee.0 loglevel=info, compact=false
                                        2022-01-08 08:10:06.811 - info: host.iobroker instance system.adapter.zigbee.0 started with pid 174476
                                        2022-01-08 08:10:07.595 - error: zigbee.0 (174476) zigbee.0 already running
                                        2022-01-08 08:10:07.596 - warn: zigbee.0 (174476) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                        2022-01-08 08:10:08.123 - error: host.iobroker instance system.adapter.zigbee.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                        2022-01-08 08:10:08.123 - debug: host.iobroker Reset crash count of system.adapter.zigbee.0, because non-crash exit
                                        2022-01-08 08:10:08.123 - info: host.iobroker Restart adapter system.adapter.zigbee.0 because enabled
                                        2022-01-08 08:10:10.805 - debug: host.iobroker added notifications configuration of system.adapter.backitup.0
                                        2022-01-08 08:10:10.805 - debug: host.iobroker startInstance backitup.0 loglevel=info, compact=false
                                        2022-01-08 08:10:10.811 - info: host.iobroker instance system.adapter.backitup.0 started with pid 174487
                                        2022-01-08 08:10:11.160 - error: backitup.0 (174487) backitup.0 already running
                                        2022-01-08 08:10:11.161 - warn: backitup.0 (174487) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                        2022-01-08 08:10:11.692 - error: host.iobroker instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                        2022-01-08 08:10:11.692 - debug: host.iobroker Reset crash count of system.adapter.backitup.0, because non-crash exit
                                        2022-01-08 08:10:11.692 - info: host.iobroker Restart adapter system.adapter.backitup.0 because enabled
                                        2022-01-08 08:10:14.805 - debug: host.iobroker added notifications configuration of system.adapter.daswetter.0
                                        2022-01-08 08:10:14.815 - info: host.iobroker instance scheduled system.adapter.daswetter.0 55 0,3,6,9,12,15,18,21 * * *
                                        2022-01-08 08:10:14.819 - info: host.iobroker instance system.adapter.daswetter.0 started with pid 174498
                                        2022-01-08 08:10:15.291 - info: daswetter.0 (174498) starting. Version 3.0.9 in /opt/iobroker/node_modules/iobroker.daswetter, node: v14.18.2, js-controller: 3.3.22
                                        2022-01-08 08:10:17.567 - info: daswetter.0 (174498) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                                        2022-01-08 08:10:18.074 - info: daswetter.0 (174498) cleaned everything up...
                                        2022-01-08 08:10:18.095 - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2022-01-08 08:10:18.819 - debug: host.iobroker added notifications configuration of system.adapter.dwd.0
                                        2022-01-08 08:10:18.822 - info: host.iobroker instance scheduled system.adapter.dwd.0 53 * * * *
                                        2022-01-08 08:10:18.827 - info: host.iobroker instance system.adapter.dwd.0 started with pid 174513
                                        2022-01-08 08:10:19.332 - info: dwd.0 (174513) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.18.2, js-controller: 3.3.22
                                        2022-01-08 08:10:19.844 - info: dwd.0 (174513) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2022-01-08 08:10:20.367 - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2022-01-08 08:10:21.773 - debug: host.iobroker added notifications configuration of system.adapter.netatmo.0
                                        2022-01-08 08:10:21.773 - debug: host.iobroker startInstance netatmo.0 loglevel=info, compact=false
                                        2022-01-08 08:10:21.780 - info: host.iobroker instance system.adapter.netatmo.0 started with pid 174528
                                        2022-01-08 08:10:22.246 - info: netatmo.0 (174528) starting. Version 1.4.4 in /opt/iobroker/node_modules/iobroker.netatmo, node: v14.18.2, js-controller: 3.3.22
                                        2022-01-08 08:10:22.805 - debug: host.iobroker added notifications configuration of system.adapter.feiertage.0
                                        2022-01-08 08:10:22.810 - info: host.iobroker instance scheduled system.adapter.feiertage.0 36 3 * * *
                                        2022-01-08 08:10:22.814 - info: host.iobroker instance system.adapter.feiertage.0 started with pid 174543
                                        2022-01-08 08:10:23.264 - info: feiertage.0 (174543) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.feiertage, node: v14.18.2, js-controller: 3.3.22
                                        2022-01-08 08:10:23.397 - info: feiertage.0 (174543) Next holiday: Rosenmontag is in 51 days on 28.02.2022
                                        2022-01-08 08:10:23.403 - info: feiertage.0 (174543) adapter feiertage objects written
                                        2022-01-08 08:10:23.906 - info: feiertage.0 (174543) Terminated (NO_ERROR): Without reason
                                        2022-01-08 08:10:24.432 - info: host.iobroker instance system.adapter.feiertage.0 terminated with code 0 (NO_ERROR)
                                        2022-01-08 08:10:25.954 - debug: host.iobroker added notifications configuration of system.adapter.shelly.0
                                        2022-01-08 08:10:25.954 - debug: host.iobroker startInstance shelly.0 loglevel=info, compact=false
                                        2022-01-08 08:10:25.960 - info: host.iobroker instance system.adapter.shelly.0 started with pid 174558
                                        2022-01-08 08:10:26.625 - info: shelly.0 (174558) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v14.18.2, js-controller: 3.3.22
                                        2022-01-08 08:10:26.637 - info: shelly.0 (174558) Starting Adapter shelly.0 in version 5.0.0
                                        2022-01-08 08:10:26.712 - info: shelly.0 (174558) Starting in CoAP mode.
                                        2022-01-08 08:10:26.733 - info: shelly.0 (174558) Listening for Shelly packets in the network
                                        2022-01-08 08:10:26.821 - debug: host.iobroker added notifications configuration of system.adapter.fullybrowser.0
                                        2022-01-08 08:10:26.821 - debug: host.iobroker startInstance fullybrowser.0 loglevel=info, compact=false
                                        2022-01-08 08:10:26.827 - info: host.iobroker instance system.adapter.fullybrowser.0 started with pid 174573
                                        2022-01-08 08:10:27.156 - error: fullybrowser.0 (174573) fullybrowser.0 already running
                                        2022-01-08 08:10:27.157 - warn: fullybrowser.0 (174573) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                        2022-01-08 08:10:27.685 - error: host.iobroker instance system.adapter.fullybrowser.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                        2022-01-08 08:10:27.686 - debug: host.iobroker Reset crash count of system.adapter.fullybrowser.0, because non-crash exit
                                        2022-01-08 08:10:27.686 - info: host.iobroker Restart adapter system.adapter.fullybrowser.0 because enabled
                                        2022-01-08 08:10:29.307 - info: shelly.0 (174558) Shelly device 192.168.178.54 (shellydimmer / shellydimmer-CC50E3F3AB05 / SHDM-1#CC50E3F3AB05#1) with CoAP connected! Polltime set to 5 sec.
                                        2022-01-08 08:10:29.716 - debug: host.iobroker added notifications configuration of system.adapter.sonoff.0
                                        2022-01-08 08:10:29.716 - debug: host.iobroker startInstance sonoff.0 loglevel=info, compact=false
                                        2022-01-08 08:10:29.723 - info: host.iobroker instance system.adapter.sonoff.0 started with pid 174584
                                        2022-01-08 08:10:30.211 - info: sonoff.0 (174584) starting. Version 2.4.7 in /opt/iobroker/node_modules/iobroker.sonoff, node: v14.18.2, js-controller: 3.3.22
                                        2022-01-08 08:10:30.234 - info: sonoff.0 (174584) Starting MQTT server on port 1883
                                        2022-01-08 08:10:30.501 - info: sonoff.0 (174584) Client [Küche-Tisch] connected with secret 1641625830498_9529
                                        2022-01-08 08:10:30.717 - info: sonoff.0 (174584) Client [Bad2-Wanne] connected with secret 1641625830716_4062
                                        2022-01-08 08:10:30.729 - info: sonoff.0 (174584) Client [Kueche-Herd] connected with secret 1641625830729_1300
                                        2022-01-08 08:10:30.820 - debug: host.iobroker added notifications configuration of system.adapter.info.0
                                        2022-01-08 08:10:30.820 - debug: host.iobroker startInstance info.0 loglevel=info, compact=false
                                        2022-01-08 08:10:30.826 - info: host.iobroker instance system.adapter.info.0 started with pid 174599
                                        2022-01-08 08:10:31.344 - error: info.0 (174599) info.0 already running
                                        2022-01-08 08:10:31.345 - warn: info.0 (174599) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                        2022-01-08 08:10:31.878 - error: host.iobroker instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                        2022-01-08 08:10:31.878 - debug: host.iobroker Reset crash count of system.adapter.info.0, because non-crash exit
                                        2022-01-08 08:10:31.878 - info: host.iobroker Restart adapter system.adapter.info.0 because enabled
                                        2022-01-08 08:10:32.565 - info: shelly.0 (174558) Shelly device 192.168.178.53 (shellyplug-s / shellyplug-s-79F6A9 / SHPLG-S#79F6A9#1) with CoAP connected! Polltime set to 5 sec.
                                        2022-01-08 08:10:33.848 - debug: host.iobroker added notifications configuration of system.adapter.tr-064.0
                                        2022-01-08 08:10:33.848 - debug: host.iobroker startInstance tr-064.0 loglevel=info, compact=false
                                        2022-01-08 08:10:33.855 - info: host.iobroker instance system.adapter.tr-064.0 started with pid 174618
                                        2022-01-08 08:10:34.518 - info: tr-064.0 (174618) starting. Version 4.2.15 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.18.2, js-controller: 3.3.22
                                        2022-01-08 08:10:34.818 - debug: host.iobroker added notifications configuration of system.adapter.sonos.0
                                        2022-01-08 08:10:34.818 - debug: host.iobroker startInstance sonos.0 loglevel=info, compact=false
                                        2022-01-08 08:10:34.828 - info: host.iobroker instance system.adapter.sonos.0 started with pid 174633
                                        2022-01-08 08:10:35.226 - error: sonos.0 (174633) sonos.0 already running
                                        2022-01-08 08:10:35.227 - warn: sonos.0 (174633) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                        2022-01-08 08:10:35.758 - error: host.iobroker instance system.adapter.sonos.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                        2022-01-08 08:10:35.758 - debug: host.iobroker Reset crash count of system.adapter.sonos.0, because non-crash exit
                                        2022-01-08 08:10:35.758 - info: host.iobroker Restart adapter system.adapter.sonos.0 because enabled
                                        2022-01-08 08:10:36.118 - info: shelly.0 (174558) Shelly device 192.168.178.55 (shellycolorbulb / shellycolorbulb-E8DB84AA2596 / SHCB-1#E8DB84AA2596#1) with CoAP connected! Polltime set to 5 sec.
                                        2022-01-08 08:10:36.760 - debug: host.iobroker added notifications configuration of system.adapter.sonos.0
                                        2022-01-08 08:10:36.760 - debug: host.iobroker startInstance sonos.0 loglevel=info, compact=false
                                        2022-01-08 08:10:36.768 - info: host.iobroker instance system.adapter.sonos.0 started with pid 174644
                                        2022-01-08 08:10:37.180 - info: sonos.0 (174644) starting. Version 2.1.7 in /opt/iobroker/node_modules/iobroker.sonos, node: v14.18.2, js-controller: 3.3.22
                                        2022-01-08 08:10:38.125 - debug: host.iobroker added notifications configuration of system.adapter.zigbee.0
                                        2022-01-08 08:10:38.126 - debug: host.iobroker startInstance zigbee.0 loglevel=info, compact=false
                                        2022-01-08 08:10:38.132 - info: host.iobroker instance system.adapter.zigbee.0 started with pid 174659
                                        2022-01-08 08:10:38.805 - debug: host.iobroker added notifications configuration of system.adapter.tankerkoenig.0
                                        2022-01-08 08:10:38.805 - debug: host.iobroker startInstance tankerkoenig.0 loglevel=info, compact=false
                                        2022-01-08 08:10:38.812 - info: host.iobroker instance system.adapter.tankerkoenig.0 started with pid 174670
                                        2022-01-08 08:10:39.079 - info: zigbee.0 (174659) starting. Version 1.6.8 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.18.2, js-controller: 3.3.22
                                        2022-01-08 08:10:39.116 - info: zigbee.0 (174659) Starting Zigbee npm ...
                                        2022-01-08 08:10:39.254 - info: zigbee.0 (174659) Installed Version: iobroker.zigbee@1.6.8
                                        2022-01-08 08:10:39.304 - error: tankerkoenig.0 (174670) tankerkoenig.0 already running
                                        2022-01-08 08:10:39.304 - warn: tankerkoenig.0 (174670) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                        2022-01-08 08:10:39.837 - error: host.iobroker instance system.adapter.tankerkoenig.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                        2022-01-08 08:10:39.837 - debug: host.iobroker Reset crash count of system.adapter.tankerkoenig.0, because non-crash exit
                                        2022-01-08 08:10:39.837 - info: host.iobroker Restart adapter system.adapter.tankerkoenig.0 because enabled
                                        2022-01-08 08:10:40.755 - info: shelly.0 (174558) Shelly device 192.168.178.52 (shelly1 / shelly1-10DCB4 / SHSW-1#10DCB4#1) with CoAP connected! Polltime set to 5 sec.
                                        2022-01-08 08:10:40.766 - info: shelly.0 (174558) Shelly device 192.168.178.51 (shelly1 / shelly1-767A0F / SHSW-1#767A0F#1) with CoAP connected! Polltime set to 5 sec.
                                        2022-01-08 08:10:41.013 - info: zigbee.0 (174659) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
                                        2022-01-08 08:10:41.022 - info: zigbee.0 (174659) Unable to disable LED, unsupported function.
                                        2022-01-08 08:10:41.024 - info: zigbee.0 (174659) --> transmitPower : normal
                                        2022-01-08 08:10:41.046 - info: zigbee.0 (174659) Currently 17 devices are joined:
                                        2022-01-08 08:10:41.063 - info: zigbee.0 (174659) 0x086bd7fffe51dbd6 (addr 64726): LED1649C5 - IKEA TRADFRI LED bulb E12/E14/E17 400 lumen, dimmable warm white, chandelier opal (Router)
                                        2022-01-08 08:10:41.064 - info: zigbee.0 (174659) 0x00158d0003faf01b (addr 62232): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                        2022-01-08 08:10:41.065 - info: zigbee.0 (174659) 0x00158d000358c678 (addr 5513): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                                        2022-01-08 08:10:41.065 - info: zigbee.0 (174659) 0x14b457fffe732925 (addr 9173): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                                        2022-01-08 08:10:41.066 - info: zigbee.0 (174659) 0x842e14fffea1801a (addr 13524): LED1624G9 - IKEA TRADFRI LED bulb E14/E26/E27 600 lumen, dimmable, color, opal white (Router)
                                        2022-01-08 08:10:41.066 - info: zigbee.0 (174659) 0x00158d000358c57a (addr 24218): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                                        2022-01-08 08:10:41.067 - info: zigbee.0 (174659) 0x00158d00045140d3 (addr 24472): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                        2022-01-08 08:10:41.067 - info: zigbee.0 (174659) 0x00158d00045d46cc (addr 30298): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                        2022-01-08 08:10:41.068 - info: zigbee.0 (174659) 0x00158d00045c5d25 (addr 44319): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                        2022-01-08 08:10:41.068 - info: zigbee.0 (174659) 0xbc33acfffe158f61 (addr 45674): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                                        2022-01-08 08:10:41.068 - info: zigbee.0 (174659) 0x00158d00042d17a0 (addr 42890): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                        2022-01-08 08:10:41.069 - info: zigbee.0 (174659) 0x00158d0006f6ba34 (addr 22622): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                        2022-01-08 08:10:41.069 - info: zigbee.0 (174659) 0x5c0272fffe2c4ca3 (addr 30163): HG06337 - Lidl Silvercrest smart plug (EU, CH, FR, BS, DK) (Router)
                                        2022-01-08 08:10:41.070 - info: zigbee.0 (174659) 0x60a423fffe116b9c (addr 42734): HG06337 - Lidl Silvercrest smart plug (EU, CH, FR, BS, DK) (Router)
                                        2022-01-08 08:10:41.071 - info: zigbee.0 (174659) 0x60a423fffe03ce72 (addr 31923): HG06337 - Lidl Silvercrest smart plug (EU, CH, FR, BS, DK) (Router)
                                        2022-01-08 08:10:41.071 - info: zigbee.0 (174659) 0xbc33acfffe47e5ef (addr 19590): HG06337 - Lidl Silvercrest smart plug (EU, CH, FR, BS, DK) (Router)
                                        2022-01-08 08:10:41.072 - info: zigbee.0 (174659) 0x5c0272fffe28904b (addr 63315): HG06337 - Lidl Silvercrest smart plug (EU, CH, FR, BS, DK) (Router)
                                        2022-01-08 08:10:41.072 - info: zigbee.0 (174659) Zigbee started
                                        2022-01-08 08:10:41.177 - info: sonoff.0 (174584) Client [Bad1-Spiegel] connected with secret 1641625841176_4680
                                        2022-01-08 08:10:41.694 - debug: host.iobroker added notifications configuration of system.adapter.backitup.0
                                        2022-01-08 08:10:41.694 - debug: host.iobroker startInstance backitup.0 loglevel=info, compact=false
                                        2022-01-08 08:10:41.701 - info: host.iobroker instance system.adapter.backitup.0 started with pid 174685
                                        2022-01-08 08:10:42.239 - info: backitup.0 (174685) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.18.2, js-controller: 3.3.22
                                        2022-01-08 08:10:42.259 - info: backitup.0 (174685) [iobroker] backup was activated at 03:30 every 1 day(s)
                                        2022-01-08 08:10:42.283 - info: backitup.0 (174685) [ccu] backup was activated at 01:30 every 1 day(s)
                                        2022-01-08 08:10:42.820 - debug: host.iobroker added notifications configuration of system.adapter.vis.0
                                        2022-01-08 08:10:42.820 - debug: host.iobroker startInstance vis.0 loglevel=info, compact=false
                                        2022-01-08 08:10:43.229 - info: vis.0 (174700) starting. Version 1.4.7 in /opt/iobroker/node_modules/iobroker.vis, node: v14.18.2, js-controller: 3.3.22
                                        2022-01-08 08:10:43.507 - info: vis.0 (174700) vis license is OK.
                                        2022-01-08 08:10:44.121 - info: vis.0 (174700) Terminated (NO_ERROR): Without reason
                                        2022-01-08 08:10:44.650 - info: host.iobroker instance system.adapter.vis.0 terminated while should be started once
                                        2022-01-08 08:10:46.816 - debug: host.iobroker added notifications configuration of system.adapter.web.0
                                        2022-01-08 08:10:46.817 - debug: host.iobroker startInstance web.0 loglevel=info, compact=false
                                        2022-01-08 08:10:46.823 - info: host.iobroker instance system.adapter.web.0 started with pid 174715
                                        2022-01-08 08:10:47.192 - error: web.0 (174715) web.0 already running
                                        2022-01-08 08:10:47.193 - warn: web.0 (174715) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                        2022-01-08 08:10:47.720 - error: host.iobroker instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                        2022-01-08 08:10:47.721 - debug: host.iobroker Reset crash count of system.adapter.web.0, because non-crash exit
                                        2022-01-08 08:10:47.721 - info: host.iobroker Restart adapter system.adapter.web.0 because enabled
                                        2022-01-08 08:10:57.289 - info: sonoff.0 (174584) Client [Bad-Nachtlicht] connected with secret 1641625857288_2465
                                        2022-01-08 08:10:57.687 - debug: host.iobroker added notifications configuration of system.adapter.fullybrowser.0
                                        2022-01-08 08:10:57.688 - debug: host.iobroker startInstance fullybrowser.0 loglevel=info, compact=false
                                        2022-01-08 08:10:57.694 - info: host.iobroker instance system.adapter.fullybrowser.0 started with pid 174726
                                        2022-01-08 08:10:58.077 - info: fullybrowser.0 (174726) starting. Version 2.0.12 in /opt/iobroker/node_modules/iobroker.fullybrowser, node: v14.18.2, js-controller: 3.3.22
                                        2022-01-08 08:10:58.088 - info: fullybrowser.0 (174726) Start with IP : 192.168.178.44
                                        2022-01-08 08:11:01.881 - debug: host.iobroker added notifications configuration of system.adapter.info.0
                                        2022-01-08 08:11:01.881 - debug: host.iobroker startInstance info.0 loglevel=info, compact=false
                                        2022-01-08 08:11:01.888 - info: host.iobroker instance system.adapter.info.0 started with pid 174741
                                        2022-01-08 08:11:02.792 - info: info.0 (174741) starting. Version 1.9.16 in /opt/iobroker/node_modules/iobroker.info, node: v14.18.2, js-controller: 3.3.22
                                        2022-01-08 08:11:02.828 - info: info.0 (174741) Reading/updating systemdata.
                                        2022-01-08 08:11:03.251 - info: info.0 (174741) cpu Temp res = {"main":null,"cores":[],"max":null,"socket":[],"chipset":null}
                                        2022-01-08 08:11:09.839 - debug: host.iobroker added notifications configuration of system.adapter.tankerkoenig.0
                                        2022-01-08 08:11:09.840 - debug: host.iobroker startInstance tankerkoenig.0 loglevel=info, compact=false
                                        2022-01-08 08:11:09.847 - info: host.iobroker instance system.adapter.tankerkoenig.0 started with pid 175145
                                        2022-01-08 08:11:10.754 - info: tankerkoenig.0 (175145) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v14.18.2, js-controller: 3.3.22
                                        2022-01-08 08:11:10.764 - info: tankerkoenig.0 (175145) Sync time set to 12 minutes or 720000 ms
                                        2022-01-08 08:11:17.724 - debug: host.iobroker added notifications configuration of system.adapter.web.0
                                        2022-01-08 08:11:17.726 - debug: host.iobroker startInstance web.0 loglevel=info, compact=false
                                        2022-01-08 08:11:17.737 - info: host.iobroker instance system.adapter.web.0 started with pid 175160
                                        2022-01-08 08:11:18.261 - info: web.0 (175160) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v14.18.2, js-controller: 3.3.22
                                        2022-01-08 08:11:18.367 - debug: host.iobroker-Server States 127.0.0.1:38890 Redis Socket error: Error: read ECONNRESET
                                        2022-01-08 08:11:18.389 - warn: host.iobroker instance system.adapter.web.0 terminated due to SIGSEGV
                                        2022-01-08 08:11:18.389 - info: host.iobroker instance system.adapter.web.0 terminated with code NaN ()
                                        2022-01-08 08:11:18.390 - debug: host.iobroker Reset crash count of system.adapter.web.0, because non-crash exit
                                        2022-01-08 08:11:18.390 - info: host.iobroker Restart adapter system.adapter.web.0 because enabled
                                        2022-01-08 08:11:48.392 - debug: host.iobroker added notifications configuration of system.adapter.web.0
                                        2022-01-08 08:11:48.392 - debug: host.iobroker startInstance web.0 loglevel=info, compact=false
                                        2022-01-08 08:11:48.398 - info: host.iobroker instance system.adapter.web.0 started with pid 175175
                                        2022-01-08 08:11:48.905 - info: web.0 (175175) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v14.18.2, js-controller: 3.3.22
                                        2022-01-08 08:11:49.028 - info: web.0 (175175) socket.io server listening on port 8082
                                        2022-01-08 08:11:49.030 - info: web.0 (175175) simpleAPI server listening on port 8082
                                        2022-01-08 08:11:49.030 - info: web.0 (175175) Allow states only when user is owner: false
                                        2022-01-08 08:11:49.033 - info: web.0 (175175) http server listening on port 8082
                                        2022-01-08 08:12:07.264 - info: web.0 (175175) ==>Connected system.user.admin from 192.168.178.44code_text
                                        • M matrose65
                                          @glasfaser
                                          Guten Morgen
                                          Komische Sache das.
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          #71
                                          @matrose65
                                          processing URL: Arbeit https: .....
                                          und die anderen !!!!!!!!!!!!!
                                          Lösche deine Ical URL , im Log !
                                          Es kommt mir so vor als wäre es ein Speicherproblem .
                                          Ich kenne Proxmox nicht wie man das Prüfen kann , aber da gibt es andere hier im Thread , die eventuell damit helfen können !?
                                          @paul53 sagte in Adapter werden neu gestartet:
                                          @matrose65 sagte: Es wird um diese Zeit der ical.2 aktualisiert. Danach beginnen die Fehler.
                                          RAM voll? Der Start einer Instanz benötigt kurzzeitig viel RAM.
                                          Eventuell ein Script ... mit einer Schleife !?
                                          HomoranH M GlasfaserG 4 Antworten Letzte Antwort
