  4. Adapter werden neu gestartet
    6.3k
88 Beiträge 9 Kommentatoren 12.4k Aufrufe 6 Beobachtet
  • M matrose65
    uwe@iobroker:~$ iobroker update - i
    [sudo] Passwort für uwe:
    Used repository: -
    failed to download new sources, use cached sources
    update done
    Adapter    "admin"         : 5.2.3    , installed 5.2.3
    Adapter    "backitup"      : 2.2.2    , installed 2.2.2
    Adapter    "daswetter"     : 3.0.9    , installed 3.0.9
    Adapter    "discovery"     : 2.7.5    , installed 2.7.5
    Adapter    "dwd"           : 2.7.7    , installed 2.7.7
    Adapter    "feiertage"     : 1.1.0    , installed 1.1.0
    Adapter    "fullybrowser"  : 2.0.12   , installed 2.0.12
    Adapter    "hm-rega"       : 3.0.33   , installed 3.0.33
    Adapter    "hm-rpc"        : 1.15.0   , installed 1.15.0
    Adapter    "ical"          : 1.11.6   , installed 1.11.6
    Adapter    "icons-mfd-png" : 1.0.2    , installed 1.0.2
    Adapter    "info"          : 1.9.16   , installed 1.9.16
    Adapter    "javascript"    : 5.2.18   , installed 5.2.18
    Controller "js-controller" : 3.3.22   , installed 3.3.22
    Adapter    "netatmo"       : 1.4.4    , installed 1.4.4
    Adapter    "netatmo-crawler": 0.6.0   , installed 0.6.0
    Adapter    "paw"           : 0.3.2    , installed 0.3.2
    Adapter    "scenes"        : 2.3.8    , installed 2.3.8
    Adapter    "shelly"        : 5.0.0    , installed 5.0.0
    Adapter    "simple-api"    : 2.6.2    , installed 2.6.2
    Adapter    "socketio"      : 3.1.5    , installed 3.1.5
    Adapter    "sonoff"        : 2.4.7    , installed 2.4.7
    Adapter    "sonos"         : 2.1.7    , installed 2.1.7
    Adapter    "tankerkoenig"  : 2.1.1    , installed 2.1.1
    Adapter    "tr-064"        : 4.2.15   , installed 4.2.15
    Adapter    "vis"           : 1.4.7    , installed 1.4.7
    Adapter    "vis-hqwidgets" : 1.1.9    , installed 1.1.9
    Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
    Adapter    "vis-players"   : 0.1.6    , installed 0.1.6
    Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
    Adapter    "web"           : 3.4.16   , installed 3.4.16
    Adapter    "windows-control": 0.1.5   , installed 0.1.5
    Adapter    "wled"          : 0.6.3    , installed 0.6.3
    Adapter    "zigbee"        : 1.6.8    , installed 1.6.8
    GlasfaserG Offline
    GlasfaserG Offline
    @matrose65 sagte in Adapter werden neu gestartet:
    Used repository: -
    da stimmt was nicht
    deine Repro Einstellungsausgabe fehlt
    und das müßte da stehen :
    hash changed or no sources cached => force download of new sources
    nochmal:
    iobroker update -i
    • M matrose65
      Used repository: -
      update done
      Used repository: -
      was ist das denn für ein Repo?
      Thomas BraunT G 2 Antworten Letzte Antwort
        Used repository: -
        Das ist die Ausgabe auf die (falsche) Vorgabe
        iobroker update - i
        Mit
        iobroker update -i
        wirds vermutlich passen.
          iobroker update - i
          Mit
          iobroker update -i
          GlasfaserG Offline
          GlasfaserG Offline
          @thomas-braun sagte in Adapter werden neu gestartet:
          Ja gerade geseh ... habe ein Leerzeichen bei meiner Vorlage .
          • GlasfaserG Glasfaser
            matrose65
            @glasfaser So jetzt aber
            uwe@iobroker:~$ iobroker update -i
            Used repository: Beta (latest)
            hash unchanged, use cached sources
            update done
            uwe@iobroker:~$
              Used repository: -
              G Online
              G Online
              guergen
              Jetzt hat es mich grade schon wieder erwischt, habe grade nur auf "Instanz" geklickt:
              	In file included from ../src/binding.cc:6:/home/iobroker/.cache/node-gyp/14.18.2/include/node/node.h:787:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] 787 | (node::addon_register_func) (regfunc), \ | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/14.18.2/include/node/node.h:821:3: note: in expansion of macro ‘NODE_MODULE_X’ 821 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) | ^~~~~~~~~~~~~../src/binding.cc:2003:1: note: in expansion of macro ‘NODE_MODULE’ 2003 | NODE_MODULE(sshcrypto, init) | ^~~~~~~~~~~
              HomoranH GlasfaserG 2 Antworten Letzte Antwort
              • G guergen
                @guergen ich muss ehrlich sagen: davon verstehe ich nichts.
                Allerdings sehe ich etwas, was mich stutzig macht. Kann sein, dass ich da auf dem falschen Dampfer unterwegs bin, aber ich weiß nicht ob da was in:
                @guergen sagte in Adapter werden neu gestartet:
                laufen soll/darf
                • G guergen
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Wäre es nicht besser einen eigenen Thread .... sonst kommen wir hier durcheinander .
                  Alle vorliegenden Info´s hier im Thread sind von @matrose65
                  • crunchipC Abwesend
                    crunchipC Abwesend
                    @matrose65 nur reine Vermutung meinerseits, aber wenn ich die verschiedenen Logs betrachte, fällt mir immer zu Beginn hm-rpc auf, Zufall?
                    allerdings besitze ich kein hm...
                    hm-rpc.0 (147734) xmlrpc -> 192.168.178.93:2001/ init ["http://192.168.178.92:2001",""]
                    hm-rpc.0 (147734) Disconnected
                      matrose65
                      @crunchip
                      Guten Morgen
                      Ok. Danke, das kann ich auch noch beobachten.
                      Der hm-rpc läuft auf Raspberrymatic in einer eigenen VM.
                      Der hat aber eigentlich noch nie Probleme gemacht
                        system.adapter.netatmo-crawler.0 terminated due to SIGSEGV]
                        Kannst du diesen Adapter längere Zeit mal ausschalten und das verhalten dann weiter beobachten !?
                        matrose65
                        @glasfaser said in Adapter werden neu gestartet:
                        Hallo
                        Jetzt ist der netatmo-crawler 2 Tage aus.
                        Ich weiß zwar nicht mehr wie kalt es draußen ist, aber der Fehler ist noch nicht wieder aufgetreten.
                          Ich habe schon den Proxmox server und auch den IOB neugestartet.
                          Proxmox Server neu gestartet ohne iobroker zuvor zu beenden?
                          logisch das dann Code 7 (already running) entstehen
                          Meister MopperM Online
                          Meister Mopper
                          @crunchip sagte in Adapter werden neu gestartet:
                          Muss mal hier zu meinem Verständnis nachhaken.
                          Wenn ich auf einem Proxmox node ein reboot anstoße, werden alle LXC und VM dieses node heruntergefahren bevor ein reboot gestartet wird.
                          Ich hatte bisher im Anschluss daran noch nie Probleme.
                          Ist es ratsam, alle LXC und VM vor einem reboot manuell runterzufahren? Und wenn ja, warum?
                          Proxmox und HA ...
                          W 1 Antwort Letzte Antwort
                            W Online
                            W Online
                            Wildbill
                            schrieb am zuletzt editiert von Wildbill
                            @meister-mopper Nein, man muss da manuell gar nix machen. Wenn iobroker in einer VM oder einem LXC installiert ist, so wird iobroker (und die anderen Dienste) sauber beendet, bervor der Neustart erfolgt. Gleiches gilt für LXC und VM generell unter iobroker. Wird der Host heruntergefahren, so fährt Proxmox vorher alle laufenden VM und LXC runter und meldet sich erst dann ab, wenn alles steht und das System fährt dann vollständig runter.
                            Voraussetzung ist aber natürlich jeweils, dass der Anwender sauber herunterfährt. Wenn man eine VM oder einen LXC unter Proxmox per "STOP" anstatt Shutdown abschiesst, so wird ein darin laufender iobroker (oder auch alles andere) natürlich nicht gestoppt. Probleme sind dann vorprogrammiert, ist quasi wie das Steckerziehen bei einem Rechner ohne Herunterfahren. Gleiches gilt für den Host. Zieht man da den Stecker ohne vorher einen shutdown zu machen, so sind alle LXC und VM natürlich auch nicht sauber runtergefahren und nehmen das unter Umständen übel.
                            Wenn alles sauber konfiguriert ist und läuft, so kann man mit einem "sudo reboot" oder "sudo shutdown" , egal ob innerhalb einer VM/LXC oder direkt beim Host, auch wenn noch VM/LXC laufen, eigentlich nichts falsch machen, es sollte alles sauber beenden und gegebenenfalls neu starten.
                            Gruss, Jürgen
                              crunchipC Abwesend
                              @meister-mopper sagte in Adapter werden neu gestartet:
                              nein das erledigt ja eigentlich Proxmox,
                              jedoch kommt es vor, zumindest bei mir
                              wenn die VM einfach nur neugestartet wird, iobroker nicht korrekt beendet wurde und dadurch noch Prozesse liefen, folglich erscheint dann bei dem ein oder anderen Adapter ein code7.
                              Daher die Anmerkung
                              Ich habe mir es deshalb angewöhnt, vor einem Neustart der VM, iobroker zu stoppen
                              • W Wildbill
                                Gruss, Jürgen
                                crunchipC Abwesend
                                crunchipC Abwesend
                                @wildbill sagte in Adapter werden neu gestartet:
                                das ist bei mir hin und wieder das Problem,
                                ein "Herunterfahren" bleibt hin und wieder hängen und die VM beendet sich dann nicht mehr
                                dann hilft nur ein
                                qm stop <vmid>
                                  dann hilft nur ein
                                  qm stop <vmid>
                                  W Online
                                  W Online
                                  Wildbill
                                  @crunchip Hast Du in der VM den Qemu guest agent installiert und aktiviert? Wenn nicht, könnte es sein, dass es da Probleme geben könnte, wenn Befehle zum Neustart oder Herunterfahren von "aussen" vom Host zum Guest geschickt werden. Hast Du das Problem auch, wenn Du per SSH in die VM direkt gehst und dort den Shutdown auslöst?
                                  Gruss, Jürgen
                                  • W Wildbill
                                    Gruss, Jürgen
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    ja
                                    hab ich nicht probiert, es kommt ja auch nur ab und an mal vor
                                      ja
                                      W Online
                                      W Online
                                      Wildbill
                                      #66
                                      @crunchip Irgendwelche Meldungen in Proxmox unten in der Leiste? Normal taucht ja dann dort was auf, wenn es irgendwo zu einem Fehler kommt.
                                      Gruss, Jürgen
                                        crunchipC Abwesend
                                        #67
                                        @wildbill ja logisch kommt dann ne Meldung, Wortlaut hab ich allerdings nicht im Kopf. Hatte ja schon länger nimmer den Fall.
                                        Wenn ich morgen dazu komme, werde ich mal paar Maschine testen
                                        • W Wildbill
                                          Gruss, Jürgen
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          #68
                                          @wildbill heute mal ne VM rebootet
                                          TASK ERROR: VM quit/powerdown failed - got timeout
