  5. Blocky script
Blocky script
86 Beiträge 6 Kommentatoren 12.0k Aufrufe 5 Beobachtet
  • I ingenii
    @Cinimod
    Schalfzimmer:
      <variables>
        <variable id="SIGD6q1KUTGFjp#3gO^{">offene Fenster</variable>
      </variables>
      <block type="comment" id="/0CV^O!1aoUk:BM=JQvY" x="-62" y="-1062">
        <field name="COMMENT">Schlafzimmer</field>
        <next>
          <block type="on_ext" id="K,WN,pgM_?_@X4vx9kNn">
            <mutation xmlns="http://www.w3.org/1999/xhtml" items="5"></mutation>
            <value name="OID0">
              <shadow type="field_oid" id="g^#UD(O)#46O[YL/yhiu">
                <field name="oid">sonoff.0.ZigBee_Bridge1.ZbReceived_0x1123_Contact</field>
              </shadow>
            </value>
            <value name="OID1">
              <shadow type="field_oid" id="GR{OtJXvaxmJ/8frKVV5">
                <field name="oid">sonoff.0.ZigBee_Bridge1.ZbReceived_0x5982_Contact</field>
              </shadow>
            </value>
            <value name="OID2">
              <shadow type="field_oid" id="AaDu2IdLTc;_8Y^(=#1u">
                <field name="oid">sonoff.0.ZigBee_Bridge1.ZbReceived_0x600E_Contact</field>
              </shadow>
            </value>
            <value name="OID3">
              <shadow type="field_oid" id="gz?y}5:(-k]7M;_c)L@c">
                <field name="oid">sonoff.0.ZigBee_Bridge1.ZbReceived_0x20A3_Contact</field>
              </shadow>
            </value>
            <value name="OID4">
              <shadow type="field_oid" id="f,#bPavRADQa!^9vgT;r">
                <field name="oid">sonoff.0.ZigBee_Bridge1.ZbReceived_0xD449_Contact</field>
              </shadow>
            </value>
            <statement name="STATEMENT">
              <block type="controls_if" id="zr))xYp5q6uk7gWR:FLp">
                <value name="IF0">
                  <block type="logic_compare" id="(%ip:yl;!KUbNeYJO=Q.">
                    <field name="OP">EQ</field>
                    <value name="A">
                      <block type="on_source" id="IQvqF`Ea*52V%WOo$(BG">
                      </block>
                    </value>
                    <value name="B">
                      <block type="math_number" id="YaM59`_}h-7w]wlp%rz]">
                        <field name="NUM">1</field>
                      </block>
                    </value>
                  </block>
                </value>
                <statement name="DO0">
                  <block type="control" id="hS]=O?t$f/y`yv?xV.9v">
                    <field name="OID">0_userdata.0.Testordner.Schalfzimmer_temp_Heizung</field>
                    <value name="VALUE">
                      <block type="logic_boolean" id="@WvR96o@/GT_W,v[-k@;">
                      </block>
                    </value>
                    <next>
                      <block type="variables_set" id="]qW3c_5Vo7}]mwMJaX]u">
                        <field name="VAR" id="SIGD6q1KUTGFjp#3gO^{">offene Fenster</field>
                          <block type="logic_boolean" id="%|=KaL92,D:1}t?+_kh@">
                          </block>
                        </value>
                      </block>
                    </next>
                  </block>
                </statement>
                <value name="IF1">
                  <block type="logic_operation" id="NI74tl{Cv%y2nnZ2mq(_" inline="false">
                    <field name="OP">AND</field>
                    <value name="A">
                      <block type="logic_operation" id="nBhW:|6IjFd#]:==r9MT" inline="false">
                        <value name="A">
                          <block type="logic_operation" id="TzDrBAgL)l{6h%e)Nbix" inline="false">
                            <value name="A">
                              <block type="logic_compare" id="H-by~#=i7qLd];I!ss,u">
                                <value name="A">
                                  <block type="get_value" id="G{e*#Ck_W4)[t!9NfppK">
                                    <field name="OID">sonoff.0.ZigBee_Bridge1.ZbReceived_0x1123_Contact</field>
                                  </block>
                                </value>
                                <value name="B">
                                  <block type="math_number" id="tV{:u[3b2[XI5;6o#uwv">
                                    <field name="NUM">0</field>
                                  </block>
                                </value>
                              </block>
                            </value>
                            <value name="B">
                              <block type="logic_compare" id="(Bj)7ZJ(0pgXXEA`sjl4">
                                <value name="A">
                                  <block type="get_value" id="CN}w9(9wU2-hnR|}zN~M">
                                    <field name="OID">sonoff.0.ZigBee_Bridge1.ZbReceived_0x5982_Contact</field>
                                  </block>
                                </value>
                                <value name="B">
                                  <block type="math_number" id="qxF?+P?(5WT4+Zh~VDzH">
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                        <value name="B">
                          <block type="logic_operation" id="iAW5jBZ|80_MVv0zs#04" inline="false">
                            <value name="A">
                              <block type="logic_compare" id="=FJ$#)NF)p%K+ci}.G+{">
                                <value name="A">
                                  <block type="get_value" id="b0E:[G*)^Jkwfko9)-UG">
                                    <field name="OID">sonoff.0.ZigBee_Bridge1.ZbReceived_0x600E_Contact</field>
                                  </block>
                                </value>
                                <value name="B">
                                  <block type="math_number" id="y@6zGn;xb0N/DCub4E+j">
                                  </block>
                                </value>
                              </block>
                            </value>
                            <value name="B">
                              <block type="logic_compare" id="7uPMqgWG]Q790FDLTidp">
                                <value name="A">
                                  <block type="get_value" id="5o;cwewhu(gE!B3`kDDT">
                                    <field name="OID">sonoff.0.ZigBee_Bridge1.ZbReceived_0x20A3_Contact</field>
                                  </block>
                                </value>
                                <value name="B">
                                  <block type="math_number" id="]T=$eX#l;JqAc9b,Y}+*">
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </value>
                    <value name="B">
                      <block type="logic_compare" id="(OQ76rw~]R]9Q_P/kA`V">
                        <value name="A">
                          <block type="get_value" id="R-*;=g!1Qh_#Zl_G0VM4">
                            <field name="OID">sonoff.0.ZigBee_Bridge1.ZbReceived_0xD449_Contact</field>
                          </block>
                        </value>
                        <value name="B">
                          <block type="math_number" id="aeH:*7-Gn3!c~HF5au^!">
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
                <statement name="DO1">
                  <block type="variables_set" id="ceR.;izW_r3Ty20RG_EX">
                      <block type="logic_boolean" id="D=!E,]q}FEHKUapa+q=2">
                      </block>
                    </value>
                  </block>
                </statement>
              </block>
            </statement>
            <next>
              <block type="on_ext" id="PbE+r6ibR_B!K.FQ}Fa$">
                <mutation xmlns="http://www.w3.org/1999/xhtml" items="2"></mutation>
                <value name="OID0">
                  <shadow type="field_oid" id="R*u+`^~1q(-5RFx%o(wQ">
                    <field name="oid">sonoff.0.Temparature_Schlafzimmer(TH16).SI7021_Temperature</field>
                  </shadow>
                </value>
                <value name="OID1">
                  <shadow type="field_oid" id="%,@ga-xK38tS$Zg=d_y0">
                    <field name="oid">hm-rpc.1.000A1D89983B40.1.SET_POINT_TEMPERATURE</field>
                  </shadow>
                </value>
                  <block type="controls_if" id="r*B?@=L`.guY]MLJ.H@.">
                    <value name="IF0">
                      <block type="logic_operation" id="}2~Ew~gv@IZK*(xct$ew" inline="false">
                        <value name="A">
                          <block type="logic_compare" id="r//HYzBmYjm~s0OP1M`z">
                            <field name="OP">LT</field>
                            <value name="A">
                              <block type="get_value" id="X%j!o4/4cvnH?_-=y8W-">
                                <field name="OID">sonoff.0.Temparature_Schlafzimmer(TH16).SI7021_Temperature</field>
                              </block>
                            </value>
                            <value name="B">
                              <block type="get_value" id="JTFkdm].gf$UMbo%^75a">
                                <field name="OID">hm-rpc.1.000A1D89983B40.1.SET_POINT_TEMPERATURE</field>
                              </block>
                            </value>
                          </block>
                        </value>
                        <value name="B">
                          <block type="logic_negate" id="uy%HA(W4G:,?!bqWeHm%">
                            <value name="BOOL">
                              <block type="variables_get" id="d.x;V!*lz-mDZx7[Wa;a">
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </value>
                      <block type="control" id="#5GKyB|4=F4zr^[k^cQk">
                          <block type="logic_boolean" id="wjLU9dHN#h7Y?!IU[;}G">
                          </block>
                        </value>
                      </block>
                    </statement>
                    <value name="IF1">
                      <block type="logic_compare" id="9ky*iEK/IP-4$]#(bfJ3">
                        <field name="OP">GT</field>
                        <value name="A">
                          <block type="get_value" id="bGYSrX7HR^lxGJ)+x_#p">
                          </block>
                        </value>
                        <value name="B">
                          <block type="get_value" id="4h}L8%1PBaP2pIb3+y=z">
                          </block>
                        </value>
                      </block>
                    </value>
                      <block type="control" id="i@!4wAn+FGd4.YpiNN-=">
                          <block type="logic_boolean" id="ft~;-EU^W[TB:.[I(TFD">
                          </block>
                        </value>
                      </block>
                    </statement>
                  </block>
                </statement>
              </block>
            </next>
          </block>
        </next>
      </block>
    </xml>
    I Offline
    I Offline
    ingenii
    schrieb am zuletzt editiert von ingenii
    @Cinimod
    Datenpunkt:
      <block type="on_ext" id="PbE+r6ibR_B!K.FQ}Fa$" x="-20" y="-547">
        <mutation xmlns="http://www.w3.org/1999/xhtml" items="4"></mutation>
        <value name="OID0">
            <field name="oid">0_userdata.0.Testordner.Kinderzimmer_temp_Heizung</field>
          </shadow>
        </value>
        <value name="OID1">
          <shadow type="field_oid" id="d(7kaO!c#|rUIt#UbB={">
            <field name="oid">0_userdata.0.Testordner.Schalfzimmer_temp_Heizung</field>
          </shadow>
        </value>
        <value name="OID2">
          <shadow type="field_oid" id="DC]}pm|WdYkqYH*s(U9Y">
            <field name="oid">0_userdata.0.Testordner.Gastezimmer_temp_Heizung</field>
          </shadow>
        </value>
        <value name="OID3">
            <field name="oid">0_userdata.0.Testordner.Bad_1og_temp_Heizung</field>
          </shadow>
        </value>
            <value name="IF0">
              <block type="logic_operation" id="HX[~7p30kaYu$)lN#N?|" inline="false">
                <field name="OP">OR</field>
                <value name="A">
                  <block type="logic_operation" id="(1lKe/~%[/ym5C0WEI+)" inline="false">
                    <value name="A">
                      <block type="logic_compare" id="hJ?OQP@wN3Qj7(`eg2RC">
                        <value name="A">
                          <block type="get_value" id="=a~[{q/wL_8NvB0GYBKy">
                            <field name="OID">0_userdata.0.Testordner.Kinderzimmer_temp_Heizung</field>
                          </block>
                        </value>
                        <value name="B">
                          <block type="logic_boolean" id="~)rU]Uf|RxwC*L;6:-ob">
                          </block>
                        </value>
                      </block>
                    </value>
                    <value name="B">
                      <block type="logic_compare" id=":Sq$w}$5=)O`pmo=2yf;">
                        <value name="A">
                          <block type="get_value" id="AkjL]g},C{TRi-.EI~bP">
                          </block>
                        </value>
                        <value name="B">
                          <block type="logic_boolean" id=";Dgi8Kou1OA5*{Kno*:B">
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
                <value name="B">
                  <block type="logic_operation" id="+JV5hbNlN?udb*8%+_wB" inline="false">
                    <value name="A">
                      <block type="logic_compare" id="(d7~t,DzVnE%Uw?Vdt1D">
                        <value name="A">
                          <block type="get_value" id="lCutf)+r1!K)FN7WmI![">
                            <field name="OID">0_userdata.0.Testordner.Bad_1og_temp_Heizung</field>
                          </block>
                        </value>
                        <value name="B">
                          <block type="logic_boolean" id="8?~ty)5jrT/G=W1G0Y,7">
                          </block>
                        </value>
                      </block>
                    </value>
                    <value name="B">
                      <block type="logic_compare" id="#~vQ_5RX|_OzdP,gvbXs">
                        <value name="A">
                          <block type="get_value" id="NN^Pp*t0!]Ex-q:um~.H">
                            <field name="OID">0_userdata.0.Testordner.Gastezimmer_temp_Heizung</field>
                          </block>
                        </value>
                        <value name="B">
                          <block type="logic_boolean" id="12ipKo{9_9HGRQa*E_N1">
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
              </block>
            </value>
              <block type="control" id="B=1I|N7S`4~26PlSAQ-%">
                <field name="OID">sonoff.0.Heizung_R08.POWER8</field>
                  <block type="logic_boolean" id="y3;43=:xLQ(0wRm`(^`}">
                  </block>
                </value>
                <next>
                  <block type="control" id="~P;l$0_#%wUL.ixiKHxX">
                    <field name="OID">sonoff.0.Heizung_R08.POWER7</field>
                      <block type="logic_boolean" id="E^)mfO(7;lQ@6`d3r$5d">
                      </block>
                    </value>
                  </block>
                </next>
              </block>
            </statement>
            <value name="IF1">
                <value name="A">
                  <block type="logic_operation" id="x0;06[4!-J-wM?6Xg-O:" inline="false">
                    <value name="A">
                      <block type="logic_operation" id=",`JZOgL5aBSu8HVPZ0NW" inline="false">
                        <value name="A">
                            <value name="A">
                              </block>
                            </value>
                            <value name="B">
                              <block type="logic_boolean" id="O=x2`^..rQlbo?6Ng!xs">
                              </block>
                            </value>
                          </block>
                        </value>
                        <value name="B">
                          <block type="logic_compare" id="BV^sU|2@;Fh{+tPIUP6*">
                            <value name="A">
                              <block type="get_value" id="+=iCY2C6oN%.dQ/^kxe{">
                              </block>
                            </value>
                            <value name="B">
                              <block type="logic_boolean" id="Hsk~I1ACC%z$h!rX)wHd">
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </value>
                    <value name="B">
                      <block type="logic_compare" id="Yu*GN1tHPn|]JAtxBnAd">
                        <value name="A">
                          <block type="get_value" id="N;ZrYsp838;u5R=`Lh`H">
                          </block>
                        </value>
                        <value name="B">
                          <block type="logic_boolean" id="0h4:VOw~9d0+03^9HqNd">
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
                <value name="B">
                  <block type="logic_compare" id="/l,p+tv-nab=p0o3q=#]">
                    <value name="A">
                      <block type="get_value" id="T|(8__(z0vg?@DK,})PM">
                      </block>
                    </value>
                    <value name="B">
                      <block type="logic_boolean" id="b[}@z,E%pfC_t+azaXqk">
                      </block>
                    </value>
                  </block>
                </value>
              </block>
            </value>
              <block type="control" id="WLLdD.vKC!_^=OYxX*Rp">
                  <block type="logic_boolean" id="ldc#N@{RI=c{~~U$;#vk">
                  </block>
                </value>
                <next>
                  <block type="control" id="M;TncfhU?kR;[#Dn_Z)_">
                      <block type="logic_boolean" id="o@IGbqby.SrxA-ZhATy#">
                      </block>
                    </value>
                  </block>
                </next>
              </block>
            </statement>
          </block>
        </statement>
      </block>
    </xml>
    • I ingenii
      @cinimod
      Mein Konfig:
      Kinderzimmer:
        <variables>
        </variables>
        <block type="comment" id="_9LVB+mDFTm*bn-vUbQ{" x="-88" y="-1062">
          <field name="COMMENT">Kinderzimmer</field>
          <next>
              <value name="OID0">
                </shadow>
              </value>
              <value name="OID1">
                </shadow>
              </value>
              <value name="OID2">
                </shadow>
              </value>
              <value name="OID3">
                </shadow>
              </value>
              <value name="OID4">
                </shadow>
              </value>
                  <value name="IF0">
                      <value name="A">
                        </block>
                      </value>
                      <value name="B">
                        </block>
                      </value>
                    </block>
                  </value>
                        </block>
                      </value>
                      <next>
                            </block>
                          </value>
                        </block>
                      </next>
                    </block>
                  </statement>
                  <value name="IF1">
                      <value name="A">
                          <value name="A">
                              <value name="A">
                                  <value name="A">
                                    </block>
                                  </value>
                                  <value name="B">
                                    </block>
                                  </value>
                                </block>
                              </value>
                              <value name="B">
                                  <value name="A">
                                    </block>
                                  </value>
                                  <value name="B">
                                    </block>
                                  </value>
                                </block>
                              </value>
                            </block>
                          </value>
                          <value name="B">
                              <value name="A">
                                  <value name="A">
                                    </block>
                                  </value>
                                  <value name="B">
                                    </block>
                                  </value>
                                </block>
                              </value>
                              <value name="B">
                                  <value name="A">
                                    </block>
                                  </value>
                                  <value name="B">
                                    </block>
                                  </value>
                                </block>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                      <value name="B">
                          <value name="A">
                            </block>
                          </value>
                          <value name="B">
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </value>
                        </block>
                      </value>
                    </block>
                  </statement>
                </block>
              </statement>
              <next>
                  <value name="OID0">
                      <field name="oid">sonoff.0.Temparature_kinderzimmer(TH10).AM2301_Temperature</field>
                    </shadow>
                  </value>
                  <value name="OID1">
                      <field name="oid">hm-rpc.1.000A1D8998382C.1.SET_POINT_TEMPERATURE</field>
                    </shadow>
                  </value>
                      <value name="IF0">
                          <value name="A">
                              <value name="A">
                                  <field name="OID">sonoff.0.Temparature_kinderzimmer(TH10).AM2301_Temperature</field>
                                </block>
                              </value>
                              <value name="B">
                                  <field name="OID">hm-rpc.1.000A1D8998382C.1.SET_POINT_TEMPERATURE</field>
                                </block>
                              </value>
                            </block>
                          </value>
                          <value name="B">
                              <value name="BOOL">
                                </block>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                            </block>
                          </value>
                        </block>
                      </statement>
                      <value name="IF1">
                          <value name="A">
                            </block>
                          </value>
                          <value name="B">
                            </block>
                          </value>
                        </block>
                      </value>
                            </block>
                          </value>
                        </block>
                      </statement>
                    </block>
                  </statement>
                </block>
              </next>
            </block>
          </next>
        </block>
      </xml>
      I Offline
      I Offline
      ingenii
      @Cinimod
      Was gehört hier ?
      Switch oder State ?
      • I ingenii
        @Cinimod
        Was gehört hier ?
        Switch oder State ?
        CinimodC Offline
        CinimodC Offline
        Cinimod
        @ingenii sagte in Blocky script:
        @Cinimod
        Was gehört hier ?
        Switch oder State ?
        State
        Was genau ist denn jetzt dein Problem ?
        I 2 Antworten Letzte Antwort
        • CinimodC Cinimod
          @Cinimod
          Was gehört hier ?
          Switch oder State ?
          State
          I Offline
          I Offline
          ingenii
          @cinimod
          es hat immer was Heizung für 1 bis 2 Minuten eingeschaltet auch wen Temperatur zu hoch wahr.Problem wahr das ich immer zu spät gesehen hab und nicht nachvollziehen kann von wo das kommt.
          Dann Detail suche und bin drauf gekommen das ein Temp sensor bei Sonoff kaputt ist liefert ab und zu verschiedene Daten.
          Jetzt passt alles,
          • CinimodC Cinimod
            @Cinimod
            Was gehört hier ?
            Switch oder State ?
            State
            I Offline
            I Offline
            ingenii
            #66
            @cinimod
            hab ein kleines Problem, in Verwendung sind deine Scripts .In Wohnzimmer passiert das mir etwas Datenpunkt auf False steuert und ich weiß nicht was. Ich hab schon ein neuen Datenpunk erstellt das der nicht unabsichtlich irgendwo in anders drinnen ist und passiert wieder, ich stelle Set Point Temp um 2 Grad mehr das ich weiss das sicher Heizung ganze zeit lauf.
            Es ist ein Fußboden Heizung deswegen rennt Heizung nur cca 45 Minuten und Dann geht automatisch heizung auf OFF aber nicht Datenpunkt denn steuere ich mit einem Script der heist Restart Datenpunk aber bei dem hab ich 90Minuten also muss Heizung starten(Datenpunk) und Datenpunk wen Temp nicht erreicht Set Temp musst erst nach 90Minuten auf Datenpunkt False und dan soll wieder Staten, aber bei mir auch wen ich dieser Neustart Datenpunk deaktiviere geht jeden cca 10 Minuten Datenpunk auf False und gleich wieder auf True.
            Script :
              <block type="on_ext" id="xDq%i~$rGx~A.83cmM%;" x="-287" y="-787">
                <value name="OID0">
                  <shadow type="field_oid" id="S5Ja?RFgi-amy%b3nasc">
                    <field name="oid">hm-rpc.1.000A9D899F65CB.1.ACTUAL_TEMPERATURE</field>
                  </shadow>
                </value>
                <value name="OID1">
                  <shadow type="field_oid" id=",x^o!!V53@cT%;x8@hr]">
                    <field name="oid">hm-rpc.1.000A9D899F65CB.1.SET_POINT_TEMPERATURE</field>
                  </shadow>
                </value>
                  <block type="controls_if" id="^IQpxvAC2OFS~7?Wb54p">
                    <value name="IF0">
                      <block type="logic_compare" id="wv?fv3Sv#4)xrUA!h,;d">
                        <value name="A">
                          <block type="get_value" id="~FmMS%jS(50Pu}fG;xD(">
                            <field name="OID">hm-rpc.1.000A9D899F65CB.1.ACTUAL_TEMPERATURE</field>
                          </block>
                        </value>
                        <value name="B">
                          <block type="get_value" id="29K2ZhjmlM^.$R%?*O?r">
                            <field name="OID">hm-rpc.1.000A9D899F65CB.1.SET_POINT_TEMPERATURE</field>
                          </block>
                        </value>
                      </block>
                    </value>
                      <block type="control" id="BCFn=IlgKqu+C@xy)z`p">
                        <field name="OID">0_userdata.0.Testordner.Wohnzimmer_heizung</field>
                          <block type="logic_boolean" id="CjsW,Fb567aTJf@*m@?U">
                          </block>
                        </value>
                      </block>
                    </statement>
                    <value name="IF1">
                      <block type="logic_compare" id="r*KEn=z,[kyIxuL5}P;p">
                        <field name="OP">GTE</field>
                        <value name="A">
                          <block type="get_value" id="2T7[PNo`#A#Y.u(Q`c*H">
                          </block>
                        </value>
                        <value name="B">
                          <block type="get_value" id="E+-PcFA;?0rjyn;u~35W">
                          </block>
                        </value>
                      </block>
                    </value>
                      <block type="control" id="@*N1BGqFp,k14kZ$emx]">
                          <block type="logic_boolean" id="knxl8#k^UDaS0z/qJVoA">
                          </block>
                        </value>
                      </block>
                    </statement>
                  </block>
                </statement>
              </block>
            </xml>
            Restart Datenpunkt
              <block type="on" id="g^ts;K(Z?cyM6vDaU%4X" x="-162" y="-420">
                <field name="CONDITION">true</field>
                  <block type="control" id="J.Vb7Iz{qxWpi`hHY_:6">
                    <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="true"></mutation>
                    <field name="DELAY_MS">90</field>
                    <field name="UNIT">min</field>
                      <block type="logic_boolean" id="tw;W8Kimp?RG,kGR5}(e">
                      </block>
                    </value>
                  </block>
                </statement>
              </block>
            </xml>
            • I ingenii
              @cinimod
              Script :
                  <value name="OID0">
                    </shadow>
                  </value>
                  <value name="OID1">
                    </shadow>
                  </value>
                      <value name="IF0">
                          <value name="A">
                            </block>
                          </value>
                          <value name="B">
                            </block>
                          </value>
                        </block>
                      </value>
                            </block>
                          </value>
                        </block>
                      </statement>
                      <value name="IF1">
                          <value name="A">
                            </block>
                          </value>
                          <value name="B">
                            </block>
                          </value>
                        </block>
                      </value>
                            </block>
                          </value>
                        </block>
                      </statement>
                    </block>
                  </statement>
                </block>
              </xml>
              Restart Datenpunkt
                        </block>
                      </value>
                    </block>
                  </statement>
                </block>
              </xml>
              CinimodC Offline
              CinimodC Offline
              Cinimod
              #67
              @ingenii
              Dein Skript welches nach 90 min. automatisch die Heizung abschaltet ist das Problem. Jedesmal wenn die Heizung Wahr angesteuert wird, wir dein Abschalt-block neu angestoßen mit 90 minütiger Verzögerung.
              Dieser wird immer und immer wieder angestoßen, und lässt sich nicht stoppen.
              Probier mal das:
                <variables>
                  <variable type="timeout" id="timeout">timeout</variable>
                </variables>
                <block type="on_ext" id="xDq%i~$rGx~A.83cmM%;" x="-238" y="-787">
                  <value name="OID0">
                    </shadow>
                  </value>
                  <value name="OID1">
                    </shadow>
                  </value>
                      <value name="IF0">
                        <block type="logic_operation" id=".lsG$2HZt^DVJB*6ws~|" inline="false">
                          <value name="A">
                              <value name="A">
                                </block>
                              </value>
                              <value name="B">
                                </block>
                              </value>
                            </block>
                          </value>
                          <value name="B">
                            <block type="logic_negate" id="hBnvi-LmQ(j=.^{v)hq3">
                              <value name="BOOL">
                                <block type="get_value" id="1MBCiGjZW$VJF?c^n+R.">
                                  <field name="OID">ID auswählen</field>
                                </block>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                            </block>
                          </value>
                        </block>
                      </statement>
                      <value name="IF1">
                        <block type="logic_operation" id="8J!J=QuO[VRTAwL--$??" inline="false">
                          <value name="A">
                              <value name="A">
                                </block>
                              </value>
                              <value name="B">
                                </block>
                              </value>
                            </block>
                          </value>
                          <value name="B">
                            <block type="get_value" id="7(Ir`)[bFBmxYn!Eq^cZ">
                            </block>
                          </value>
                        </block>
                      </value>
                            </block>
                          </value>
                        </block>
                      </statement>
                    </block>
                  </statement>
                  <next>
                    <block type="on" id="g^ts;K(Z?cyM6vDaU%4X">
                        <block type="timeouts_cleartimeout" id="J0R;547HQ}}x15c(FKl:">
                          <next>
                            <block type="controls_if" id="BCO@@c0uweSQ/iFZ4i.6">
                              <value name="IF0">
                                <block type="on_source" id="X=x!S!Z(EN`|N_%s/rwU">
                                </block>
                              </value>
                                <block type="timeouts_settimeout" id="Vop9tK*z:cv$14_4.[B+">
                                  <field name="DELAY">90</field>
                                        </block>
                                      </value>
                                    </block>
                                  </statement>
                                </block>
                              </statement>
                            </block>
                          </next>
                        </block>
                      </statement>
                    </block>
                  </next>
                </block>
                <block type="comment" id="T+k|y}jvRS_RuIjyrW(j" x="338" y="-637">
                  <field name="COMMENT">&lt;- hier noch Wohnzimmer_Heizung eintragen</field>
                </block>
                <block type="comment" id="/tI;IUq6a#gMH4?[s|MR" x="237" y="-537">
                </block>
              </xml>
              I 1 Antwort Letzte Antwort
              • CinimodC Cinimod
                @ingenii
                Probier mal das:
                  <variables>
                  </variables>
                    <value name="OID0">
                      </shadow>
                    </value>
                    <value name="OID1">
                      </shadow>
                    </value>
                        <value name="IF0">
                            <value name="A">
                                <value name="A">
                                  </block>
                                </value>
                                <value name="B">
                                  </block>
                                </value>
                              </block>
                            </value>
                            <value name="B">
                                <value name="BOOL">
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                              </block>
                            </value>
                          </block>
                        </statement>
                        <value name="IF1">
                            <value name="A">
                                <value name="A">
                                  </block>
                                </value>
                                <value name="B">
                                  </block>
                                </value>
                              </block>
                            </value>
                            <value name="B">
                              </block>
                            </value>
                          </block>
                        </value>
                              </block>
                            </value>
                          </block>
                        </statement>
                      </block>
                    </statement>
                    <next>
                            <next>
                                <value name="IF0">
                                  </block>
                                </value>
                                          </block>
                                        </value>
                                      </block>
                                    </statement>
                                  </block>
                                </statement>
                              </block>
                            </next>
                          </block>
                        </statement>
                      </block>
                    </next>
                  </block>
                  </block>
                  </block>
                </xml>
                I Offline
                I Offline
                ingenii
                #68
                @cinimod
                Ja das Problem ist das fussboden Heizung eine Träge ist ich brauche das Heizung nur cca 45 lauft und dann gewisse zeit aus ist weil die warme Boden gibt gewisse zeit wärme ab erst nach gewisse zeit soll das wieder starten.
                • I ingenii
                  @cinimod
                  CinimodC Offline
                  CinimodC Offline
                  Cinimod
                  #69
                  @ingenii
                  Also nach 45 Minuten an, soll die Heizung auf jeden fall aus gehen, und wie lange soll sie mindestens aus bleiben, bis sie wieder an gehen darf ?
                  • CinimodC Cinimod
                    @ingenii
                    I Offline
                    I Offline
                    ingenii
                    #70
                    @cinimod
                    am Relle was Heizung einschaltet und abschaltet hab ich (Tasmota:Pulsetime cca 45 minuten) das geht nach einschalten automatisch auf AUS aber nicht Datenpunkt Wohnzimmer, aber das hab ich schon geschrieben, ja zeit 120 minuten.
                    • I ingenii
                      @cinimod
                      CinimodC Offline
                      CinimodC Offline
                      Cinimod
                      #71
                      @ingenii
                      Ich denke das entspricht etwa deiner Vorstellung :
                      Die Zeiten kannst du ja anpassen, und dein zweites Skript ganz weg lassen.
                        <variables>
                          <variable id="eXyCA~sNI-z]Gw*blb(Q">sperre</variable>
                          <variable type="timeout" id="timeout2">timeout2</variable>
                        </variables>
                        <block type="variables_set" id="2;(@A~;1iYQo@dys$@4E" x="-313" y="-812">
                          <field name="VAR" id="eXyCA~sNI-z]Gw*blb(Q">sperre</field>
                            <block type="logic_boolean" id="_*@_O2V@z)nbx}2a}ABw">
                            </block>
                          </value>
                          <next>
                            <block type="on_ext" id="xDq%i~$rGx~A.83cmM%;">
                              <value name="OID0">
                                </shadow>
                              </value>
                              <value name="OID1">
                                </shadow>
                              </value>
                                  <value name="IF0">
                                      <value name="A">
                                          <value name="A">
                                            </block>
                                          </value>
                                          <value name="B">
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                      <value name="B">
                                        <block type="logic_operation" id="eF6.mJ8)tZyOk]FLkTs/" inline="false">
                                          <value name="A">
                                              <value name="BOOL">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                          <value name="B">
                                            <block type="logic_negate" id="-/QD8C}5Tjf-sJ3C)yE-">
                                              <value name="BOOL">
                                                <block type="variables_get" id="_{`SnXEPu~xnz!QQ;HIg">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                        </block>
                                      </value>
                                      <next>
                                        <block type="variables_set" id="NpRPBz7Hf6OrB9tVI/7]">
                                            <block type="logic_boolean" id="HK7*w];WI5DxeR|H%([2">
                                            </block>
                                          </value>
                                          <next>
                                            <block type="timeouts_settimeout" id="}DJ},dg?Mi)VpfdMRY9{">
                                              <field name="DELAY">45</field>
                                                <block type="control" id="?sZli[f~Dg(yt|nc.o7.">
                                                    <block type="logic_boolean" id="}JIStyb]!4X!,7OnDcO@">
                                                    </block>
                                                  </value>
                                                </block>
                                              </statement>
                                              <next>
                                                <block type="timeouts_settimeout" id="m|w:|K(tQvZk+Ivqybk~">
                                                  <field name="NAME">timeout2</field>
                                                    <block type="variables_set" id="JY3sfC=._q~axwH|VG#!">
                                                        <block type="logic_boolean" id="f!j:dr|hTSbTHpM20JJ(">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </statement>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </next>
                                    </block>
                                  </statement>
                                  <value name="IF1">
                                      <value name="A">
                                          <value name="A">
                                            </block>
                                          </value>
                                          <value name="B">
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                      <value name="B">
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                        </block>
                                      </value>
                                      <next>
                                        <block type="timeouts_cleartimeout" id="I{OA]-{AEf|djZqwmIP#">
                                        </block>
                                      </next>
                                    </block>
                                  </statement>
                                </block>
                              </statement>
                            </block>
                          </next>
                        </block>
                        <block type="comment" id="T+k|y}jvRS_RuIjyrW(j" x="262" y="-638">
                        </block>
                        <block type="comment" id="/tI;IUq6a#gMH4?[s|MR" x="163" y="-337">
                        </block>
                      </xml>
                      • CinimodC Cinimod
                        @ingenii
                          <variables>
                          </variables>
                              </block>
                            </value>
                            <next>
                                <value name="OID0">
                                  </shadow>
                                </value>
                                <value name="OID1">
                                  </shadow>
                                </value>
                                    <value name="IF0">
                                        <value name="A">
                                            <value name="A">
                                              </block>
                                            </value>
                                            <value name="B">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                        <value name="B">
                                            <value name="A">
                                                <value name="BOOL">
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                            <value name="B">
                                                <value name="BOOL">
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                          </block>
                                        </value>
                                        <next>
                                              </block>
                                            </value>
                                            <next>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </statement>
                                                <next>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </statement>
                                                  </block>
                                                </next>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </statement>
                                    <value name="IF1">
                                        <value name="A">
                                            <value name="A">
                                              </block>
                                            </value>
                                            <value name="B">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                        <value name="B">
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                          </block>
                                        </value>
                                        <next>
                                          </block>
                                        </next>
                                      </block>
                                    </statement>
                                  </block>
                                </statement>
                              </block>
                            </next>
                          </block>
                          </block>
                          </block>
                        </xml>
                        I Offline
                        I Offline
                        ingenii
                        #72
                        @cinimod
                        Ich werde das jetzt laufen lassen und Bericht Morgen.
                        • I ingenii
                          @cinimod
                          CinimodC Offline
                          CinimodC Offline
                          Cinimod
                          #73
                          @ingenii
                          Gerne,
                          so richtig verstehe ich aber garnicht wieso du überhaupt Pulsetime benutzt, lass das Skript doch ein und ausschalten. Abgesehen davon muss das abschalten mit Pulsetime aber doch auch den Datenpunkt wieder auf false setzen 🤔 oder ist das Heizung-Relais nicht der Datenpunkt den wir hier ansteuern ?
                          • CinimodC Cinimod
                            @ingenii
                            Gerne,
                            I Offline
                            I Offline
                            ingenii
                            #74
                            @cinimod
                            es Funk.. super, nach Minuten hab ich das nicht kontrolliert aber schaut besser aus meine Lösung.
                            Sollte was mit Iobroker passieren brauche ich mir keine sorgen machen das Heizung ganze Tag rennt, Pulsetime ist Back Up.
                            • I ingenii
                              @cinimod
                              CinimodC Offline
                              CinimodC Offline
                              Cinimod
                              #75
                              @ingenii
                              Sehr schön das freut mich. 👍
                              • CinimodC Cinimod
                                @ingenii
                                I Offline
                                I Offline
                                ingenii
                                #76
                                @cinimod
                                heute ist das passiert, Datenpunkt hat sich nicht neu gestartet und seitdem hat Heizung nicht mehr gestartet, wahr leider nicht zu hause dann ich ich zu spät auf das gekommen.
                                ich hab auch Scheduller für Script instantz Neustarten aber das bringt nichts weil Datenpunk wahr schon auf True und er rechnet erst von False auf True die 90 Minuten.
                                Es gehört was anderes für Datenpunkt Restart.
                                Eine idee ?
                                • I ingenii
                                  @cinimod
                                  Eine idee ?
                                  I Offline
                                  I Offline
                                  ingenii
                                  #77
                                  @ingenii
                                  Kann das die Ursachen sein ? Was passiert wen dieser 90 Minuten zeit rennt und der Scheduller Startet die Ganze Script Instanz neu ?
                                  • CinimodC Cinimod
                                    @ingenii
                                    I Offline
                                    I Offline
                                    ingenii
                                    #78
                                    @cinimod
                                    Hilft das da :
                                    <block xmlns="https://developers.google.com/blockly/xml" type="on_ext" id="xDq%i~$rGx~A.83cmM%;" x="-227" y="-848">
                                      <value name="OID0">
                                          <field name="oid">sonoff.0.Heizung_R08.POWER6</field>
                                        </shadow>
                                      </value>
                                          <value name="IF0">
                                              <value name="A">
                                                  <field name="OID">sonoff.0.Heizung_R08.POWER6</field>
                                                </block>
                                              </value>
                                              <value name="B">
                                                <block type="logic_boolean" id="4AB~efGz{|usYULCq%,U">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                              <field name="OID">0_userdata.0.Testordner.Wohnzimmer_temp_Heizung</field>
                                                </block>
                                              </value>
                                            </block>
                                          </statement>
                                        </block>
                                      </statement>
                                    </block>
                                    • I ingenii
                                      @ingenii
                                      CinimodC Offline
                                      CinimodC Offline
                                      Cinimod
                                      #79
                                      @ingenii
                                      Ja das Neustarten des Script ist natürlich nicht all zu hilfreich. Wer oder was Startet denn bei mir die JS Instanz neu. Das sollte eigentlich nicht so sein.
                                      Man könnte um so ein Problem zu umgehen, einen Datenpunkt anlegen, welcher als CronTrigger benutzt werden kann. Und beim einschalten der Heizung kann man diesen Datenpunkt beschreiben, mit Aktueller Uhrzeit + 90 min.
                                      Das wird dann aber etwas komplexer, schau dir das mal an:
                                       <variables>
                                         <variable id="fg=~hsoRkJ/f1erCwxY_">zeit</variable>
                                         <variable type="cron" id="zeitplan1">zeitplan1</variable>
                                       </variables>
                                       <block type="variables_set" id="2;(@A~;1iYQo@dys$@4E" x="-663" y="-537">
                                           </block>
                                         </value>
                                         <next>
                                           <block type="on_ext" id="VphE2!M;LJJ=~uZvk/xi">
                                             <value name="OID0">
                                               <shadow type="field_oid" id="vUFdz09%BrFVW5w0eU77">
                                               </shadow>
                                             </value>
                                             <value name="OID1">
                                               </shadow>
                                             </value>
                                               <block type="controls_if" id="l/FriLrfo-]gnk$y7$Tw">
                                                 <value name="IF0">
                                                     <value name="A">
                                                       <block type="logic_compare" id=";AhA%((|o~s0b|*thGD6">
                                                         <value name="A">
                                                           <block type="get_value" id="gjq:kVVA[oP|2(Y7L844">
                                                           </block>
                                                         </value>
                                                         <value name="B">
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                     <value name="B">
                                                         <value name="BOOL">
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                       </block>
                                                     </value>
                                                     <next>
                                                       <block type="control" id="ZZFRY;*PxD?EZ)2O8iS~">
                                                           <block type="logic_boolean" id="AZ;;@J$SjYySbf|5:yvr">
                                                           </block>
                                                         </value>
                                                         <next>
                                                           <block type="control" id="i2+|k}fQJFZmiWvI:0Cw">
                                                             <field name="OID">0_userdata.0.testen.ende_sperrzeit_heizung</field>
                                                               <block type="convert_from_date" id="BRV!/gf]Za[d5Y(U`d0-">
        <field name="OPTION">hh:mm</field>
        <block type="math_arithmetic" id="tuB?8ijdf97ecwM8P`*w">
        <field name="OP">ADD</field>
        <value name="A">
        <shadow type="math_number" id="1[@ffvW*[Z0s+B1HE8Ly">
        </shadow>
        <block type="time_get" id="KTm,|(3-~.1%vh$ZOkK2">
        <field name="OPTION">object</field>
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="D.zbz$49YxC2c1azX=r~">
        </shadow>
        <block type="math_number" id="4O*(gsP.Zd2UY@m+r=ot">
        <field name="NUM">5400000</field>
        </block>
        </value>
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                             <next>
        </block>
        </value>
        </block>
        </statement>
                                                               </block>
                                                             </next>
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </statement>
                                                 <value name="IF1">
                                                     <value name="A">
                                                         <value name="A">
                                                           </block>
                                                         </value>
                                                         <value name="B">
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                     <value name="B">
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                       </block>
                                                     </value>
                                                     <next>
                                                       </block>
                                                     </next>
                                                   </block>
                                                 </statement>
                                               </block>
                                             </statement>
                                             <next>
                                               <block type="procedures_callnoreturn" id=";3^[{UoVAq5`gkRtpD?+">
                                                 <mutation name="Zeitsperre_bis"></mutation>
                                                 <next>
                                                   <block type="on_ext" id="=4vB/efwXf{;.80x]1y?">
                                                     <value name="OID0">
                                                       <shadow type="field_oid" id="dAFjD#$p%Lzu1jq3RS9]">
                                                       </shadow>
                                                       <block type="field_oid" id=",IESp[Ge{|7kYC1=gg=S">
                                                         <field name="oid">0_userdata.0.testen.testzeit</field>
                                                       </block>
                                                     </value>
                                                       <block type="schedule_clear" id="h,,l!_u[m(Ft2dtAt2T{">
                                                         <field name="NAME">zeitplan1</field>
                                                         <next>
                                                           <block type="procedures_callnoreturn" id="-Hznl}|3vix)`JPzQ/YB">
                                                           </block>
                                                         </next>
                                                       </block>
                                                     </statement>
                                                   </block>
                                                 </next>
                                               </block>
                                             </next>
                                           </block>
                                         </next>
                                       </block>
                                       <block type="comment" id="/tI;IUq6a#gMH4?[s|MR" x="-38" y="-112">
                                       </block>
                                       <block type="procedures_defnoreturn" id="|LCv6$f*g37VQ?B!V$ps" x="-62" y="-13">
                                         <field name="NAME">Zeitsperre_bis</field>
                                         <statement name="STACK">
                                           <block type="variables_set" id="x7f9J?+b7Qu=AF?$sI;4">
                                             <field name="VAR" id="fg=~hsoRkJ/f1erCwxY_">zeit</field>
                                               <block type="lists_split" id="kptth:MB]agxCGQ?-)qa">
                                                 <mutation mode="SPLIT"></mutation>
                                                 <field name="MODE">SPLIT</field>
                                                 <value name="INPUT">
                                                   <block type="get_value" id="QygiyzLaO=zz{Dp-G9RT">
                                                   </block>
                                                 </value>
                                                 <value name="DELIM">
                                                   <shadow type="text" id="C^2ndiGkG`#^BEOZ$bps">
                                                     <field name="TEXT">:</field>
                                                   </shadow>
                                                 </value>
                                               </block>
                                             </value>
                                             <next>
                                               <block type="schedule_create" id="eg*Lvnr-IRQStaiT4NY5">
                                                 <value name="SCHEDULE">
                                                   <shadow type="field_cron" id="onj(4EW)2d!N)oPKwA/S">
                                                     <field name="CRON">* * * * *</field>
                                                   </shadow>
                                                   <block type="cron_builder" id="Qy6NqfiE?grGs~5%-^C=">
                                                     <mutation xmlns="http://www.w3.org/1999/xhtml" seconds="false" as_line="false"></mutation>
                                                     <field name="LINE">FALSE</field>
                                                     <field name="WITH_SECONDS">FALSE</field>
                                                     <value name="DOW">
                                                       <shadow type="text" id="A6*h2v8D04+n#3t;9SV*">
                                                         <field name="TEXT">*</field>
                                                       </shadow>
                                                     </value>
                                                     <value name="MONTHS">
                                                       <shadow type="text" id="kkj[+iBB0jDS2z`Vj:qp">
                                                       </shadow>
                                                     </value>
                                                     <value name="DAYS">
                                                       <shadow type="text" id=":[o_I*K3u]iD[j^L{?jr">
                                                       </shadow>
                                                     </value>
                                                     <value name="HOURS">
                                                       <shadow type="text" id="Me,A#JM[54h`IlMna.SA">
                                                       </shadow>
                                                       <block type="lists_getIndex" id="@]7.cxTzhF%v1~,rn|U3">
                                                         <mutation statement="false" at="true"></mutation>
                                                         <field name="MODE">GET</field>
                                                         <field name="WHERE">FROM_START</field>
                                                           <block type="variables_get" id="]D6yb:QK;_}Y49Hp8VZ3">
                                                           </block>
                                                         </value>
                                                         <value name="AT">
                                                           <block type="math_number" id="/O{8z)AE/*DPUK8ShGl5">
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                     <value name="MINUTES">
                                                       <shadow type="text" id="!UEdIA.vdk8{5|gyYfw9">
                                                       </shadow>
                                                       <block type="lists_getIndex" id="o/Rh3*^06Se:p3a0a8Qb">
                                                           <block type="variables_get" id="Xu4l]4uWm}|BnWF,bwr+">
                                                           </block>
                                                         </value>
                                                         <value name="AT">
                                                           <block type="math_number" id="N#%1PD{UYraQF)o6l@ie">
                                                             <field name="NUM">2</field>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </statement>
                                               </block>
                                             </next>
                                           </block>
                                         </statement>
                                       </block>
                                      </xml>
                                      So richtig toll ist die Lösung aber auch nicht, wenn ich mir es recht überlege.
                                      • CinimodC Cinimod
                                        @ingenii
                                         <variables>
                                         </variables>
                                             </block>
                                           </value>
                                           <next>
                                               <value name="OID0">
                                                 </shadow>
                                               </value>
                                               <value name="OID1">
                                                 </shadow>
                                               </value>
                                                   <value name="IF0">
                                                       <value name="A">
                                                           <value name="A">
                                                             </block>
                                                           </value>
                                                           <value name="B">
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                       <value name="B">
                                                           <value name="BOOL">
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                         </block>
                                                       </value>
                                                       <next>
                                                             </block>
                                                           </value>
                                                           <next>
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        </block>
                                                               </value>
                                                               <next>
        </block>
        </value>
        </block>
        </statement>
        </block>
                                                               </next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </statement>
                                                   <value name="IF1">
                                                       <value name="A">
                                                           <value name="A">
                                                             </block>
                                                           </value>
                                                           <value name="B">
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                       <value name="B">
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                         </block>
                                                       </value>
                                                       <next>
                                                         </block>
                                                       </next>
                                                     </block>
                                                   </statement>
                                                 </block>
                                               </statement>
                                               <next>
                                                   <next>
                                                       <value name="OID0">
                                                         </shadow>
                                                         </block>
                                                       </value>
                                                           <next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </statement>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                         </block>
                                                     </block>
                                                   </value>
                                                     </shadow>
                                                   </value>
                                                 </block>
                                               </value>
                                               <next>
                                                     </shadow>
                                                       <value name="DOW">
                                                         </shadow>
                                                       </value>
                                                         </shadow>
                                                       </value>
                                                       <value name="DAYS">
                                                         </shadow>
                                                       </value>
                                                         </shadow>
                                                             </block>
                                                           </value>
                                                           <value name="AT">
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                         </shadow>
                                                             </block>
                                                           </value>
                                                           <value name="AT">
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </statement>
                                                 </block>
                                               </next>
                                             </block>
                                           </statement>
                                         </block>
                                        </xml>
                                        I Offline
                                        I Offline
                                        ingenii
                                        #80
                                        @cinimod
                                        Danke aber das ist mir zu kompliziert.
                                        • CinimodC Cinimod
                                          @cinimod
                                          Du bitte kein Stress.
                                          hab noch eine bitte wen du dann zeit hast.
                                          Hab wand Termostat Homematic, un ich will die ACTUAL_TEMPERATURE mit SET_POINT_TEMPERATURE abfragen und ein sonoff schalten.
                                          Meine Idee ist hier aber es funktioniert nicht:
                                          zu diesem brauch ich noch ein paar infos .... was soll passieren ? die Objekte oben sind alles tür/fenster kontakte ? die sollen bei jeder aktualisierung "Temperatur_Wohnzimmer" ausschalten ?
                                          I Offline
                                          I Offline
                                          ingenii
                                          #81
                                          @cinimod
                                          ich brauche wen Datenpunkten auf Wahr sind dann schalten ein Sonoff aber ausschalten erst wen alle auf False sind.
                                          ich hab mir so was geschrieben es funktioniert aber es kommt ein Fehler in Log.
                                          Kannst du mir bitte schreiben wieso ?
                                            <block type="comment" id="_9LVB+mDFTm*bn-vUbQ{" x="993" y="-2106">
                                              <field name="COMMENT">1.og</field>
                                              <next>
                                                  <value name="OID0">
                                                    <shadow type="field_oid" id="4WJh[A=5{zfL8JJaexmQ">
                                                    </shadow>
                                                  </value>
                                                  <value name="OID1">
                                                    <shadow type="field_oid" id="o1VmVTjNh.{faXSdtcf%">
                                                      <field name="oid">0_userdata.0.Testordner.Geastezimmer_temp_Heizung</field>
                                                    </shadow>
                                                  </value>
                                                      <value name="IF0">
                                                          <value name="A">
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            <block type="logic_boolean" id="I[ss_EoVs)Q`.9$2jDOM">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                          <field name="OID">0_userdata.0.Testordner.Heizung-1og-AN</field>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </statement>
                                                      <value name="IF1">
                                                          <value name="A">
                                                              <value name="A">
        </block>
                                                              </value>
                                                              <value name="B">
        <block type="logic_boolean" id="yVMjFYj};xch]pRb%O~O">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                              <value name="A">
        <field name="OID">0_userdata.0.Testordner.Geastezimmer_temp_Heizung</field>
        </block>
                                                              </value>
                                                              <value name="B">
        <block type="logic_boolean" id="a(@N2R~G23z9_{+2v:.H">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                        <block type="control" id="a010)~%,.3zP6z08$:dG">
                                                            <block type="logic_boolean" id="*Bs?pd`s{_^$#C6$ZaQ%">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </statement>
                                                    </block>
                                                  </statement>
                                                  <next>
                                                      <value name="OID0">
                                                          <field name="oid">0_userdata.0.Testordner.Heizung-1og-AN</field>
                                                        </shadow>
                                                      </value>
                                                          <value name="IF0">
                                                            <block type="logic_compare" id="yG^]{6_J#ybwkkR--1fQ">
                                                              <value name="A">
        <block type="get_value" id=",~*oG6T^1=4~o,45tX/h">
        </block>
                                                              </value>
                                                              <value name="B">
        <block type="logic_boolean" id="Ds_@mglbN-,}cDM*CoR3">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                              <field name="OID">sonoff.0.T2_WC_EG.POWER2</field>
        </block>
                                                              </value>
                                                            </block>
                                                          </statement>
                                                          <value name="IF1">
                                                            <block type="logic_compare" id="-3=In3^#!.98tjamQv=M">
                                                              <value name="A">
        <block type="get_value" id="IFmUuw4PVYZsI)!mwF{b">
        </block>
                                                              </value>
                                                              <value name="B">
        <block type="logic_boolean" id="X~3*IfnF7=:[xg@w.[9y">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                            <block type="control" id="ahb3Mq`:H=Unj~Jji#z:">
        <block type="logic_boolean" id="hZi.6P!TF_zeAvEvho]4">
        </block>
                                                              </value>
                                                            </block>
                                                          </statement>
                                                        </block>
                                                      </statement>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </xml>
                                          CinimodC 2 Antworten Letzte Antwort
