  4. Test Adapter HeatingControl v3.xx
heating
3.3k Beiträge 241 Kommentatoren 2.9m Aufrufe 203 Beobachtet
  • S SchuetzeSchulz
    @rene_hm sagte in Test Adapter HeatingControl v2.8.x:
    @schuetzeschulz dann musst du mir ein debug log vom Vorgang "Fenster öffnen" zukommen lassen...
    Na klar, bitte sehr, direkt nach Adapterneustart Fenster geöffnet, ca. 10 Sekunden auf gelassen und wieder geschlossen:
    2021-12-21 10:26:35.201 - debug: heatingcontrol.0 (621912) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2021-12-21 10:26:35.223 - debug: heatingcontrol.0 (621912) Objects client ready ... initialize now
    2021-12-21 10:26:35.224 - debug: heatingcontrol.0 (621912) Objects create System PubSub Client
    2021-12-21 10:26:35.225 - debug: heatingcontrol.0 (621912) Objects create User PubSub Client
    2021-12-21 10:26:35.225 - debug: heatingcontrol.0 (621912) Objects client initialize lua scripts
    2021-12-21 10:26:35.237 - debug: heatingcontrol.0 (621912) Objects connected to redis: 127.0.0.1:9001
    2021-12-21 10:26:35.240 - debug: heatingcontrol.0 (621912) objectDB connected
    2021-12-21 10:26:35.241 - debug: heatingcontrol.0 (621912) Redis States: Use Redis connection: 127.0.0.1:6379
    2021-12-21 10:26:35.243 - debug: heatingcontrol.0 (621912) States create System PubSub Client
    2021-12-21 10:26:35.244 - debug: heatingcontrol.0 (621912) States create User PubSub Client
    2021-12-21 10:26:35.246 - debug: heatingcontrol.0 (621912) States connected to redis: 127.0.0.1:6379
    2021-12-21 10:26:35.246 - debug: heatingcontrol.0 (621912) statesDB connected
    2021-12-21 10:26:35.418 - debug: heatingcontrol.0 (621912) Plugin sentry Initialize Plugin (enabled=true)
    2021-12-21 10:26:35.480 - info: heatingcontrol.0 (621912) starting. Version 2.8.0 in /opt/iobroker/node_modules/iobroker.heatingcontrol, node: v12.22.7, js-controller: 3.3.21
    2021-12-21 10:26:35.488 - debug: heatingcontrol.0 (621912) devices [{"id":1,"name":"Heizung Esszimmer EG","OID_Current":"hm-rpc.0.LEQ1520465.4.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.LEQ1520465.4.SET_TEMPERATURE","isActive":true,"type":1,"room":"Esszimmer"},{"id":2,"name":"Fenstersensor links Esszimmer EG","OID_Current":"hm-rpc.0.MEQ0028801.1.STATE","isActive":true,"type":3,"room":"Esszimmer"},{"id":3,"name":"Fenstersensor rechts Esszimmer EG","OID_Current":"hm-rpc.0.MEQ0029513.1.STATE","isActive":true,"type":3,"room":"Esszimmer"},{"id":4,"name":"Heizung Kinderzimmer OG","OID_Current":"hm-rpc.0.LEQ1520877.4.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.LEQ1520877.4.SET_TEMPERATURE","isActive":true,"type":1,"room":"Kinderzimmer"},{"id":5,"name":"Fenstersensor Kinderzimmer OG","OID_Current":"hm-rpc.0.MEQ0030875.1.STATE","isActive":true,"type":3,"room":"Kinderzimmer"},{"id":6,"name":"Heizung Badezimmer OG 4.SET_TEMPERATURE","OID_Current":"hm-rpc.0.KEQ0574582.4.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.KEQ0574582.4.SET_TEMPERATURE","isActive":true,"type":1,"room":"Badezimmer oben"},{"id":7,"name":"Fenstersensor links Badezimmer OG","OID_Current":"hm-rpc.0.MEQ0029521.1.STATE","isActive":true,"type":3,"room":"Badezimmer oben","DataType":"boolean","valueOpen":true,"valueClosed":false},{"id":8,"name":"Fenstersensor rechts Badezimmer OG","OID_Current":"hm-rpc.0.MEQ0029487.1.STATE","isActive":true,"type":3,"room":"Badezimmer oben","DataType":"boolean","valueOpen":true,"valueClosed":false},{"id":9,"name":"Heizung Badezimmer EG","OID_Current":"hm-rpc.0.LEQ1520473.4.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.LEQ1520473.4.SET_TEMPERATURE","isActive":true,"type":1,"room":"Badezimmer unten"},{"id":10,"name":"Fenstersensor Badezimmer EG","OID_Current":"hm-rpc.0.MEQ0029496.1.STATE","isActive":true,"type":3,"room":"Badezimmer unten"},{"id":11,"name":"Heizung Vorflur EG","OID_Current":"hm-rpc.0.OEQ0242950.4.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.OEQ0242950.4.SET_TEMPERATURE","isActive":true,"type":1,"room":"Flur unten"},{"id":12,"name":"Heizung Gästezimmer OG","OID_Current":"hm-rpc.0.MEQ0007312.4.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.MEQ0007312.4.SET_TEMPERATURE","isActive":true,"type":1,"room":"Gästezimmer"},{"id":13,"name":"Fenstersensor Gästezimmer OG","OID_Current":"hm-rpc.0.MEQ0030860.1.STATE","isActive":true,"type":3,"room":"Gästezimmer"},{"id":14,"name":"Heizung Schlafzimmer OG 4.SET_TEMPERATURE","OID_Current":"hm-rpc.0.KEQ0574680.4.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.KEQ0574680.4.SET_TEMPERATURE","isActive":true,"type":1,"room":"Schlafzimmer"},{"id":15,"name":"Fenstersensor Kleiderschrank Schlafzimmer","OID_Current":"hm-rpc.0.MEQ0029506.1.STATE","isActive":true,"type":3,"room":"Schlafzimmer"},{"id":16,"name":"Fenstersensor links Schlafzimmer","OID_Current":"hm-rpc.0.MEQ0029515.1.STATE","isActive":true,"type":3,"room":"Schlafzimmer"},{"id":17,"name":"Fenstersensor rechts Schlafzimmer","OID_Current":"hm-rpc.0.MEQ0029522.1.STATE","isActive":true,"type":3,"room":"Schlafzimmer"},{"id":18,"name":"Wandthermostat Fussbodenheizung Wohnzimmer","OID_Current":"hm-rpc.0.OEQ1667353.2.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.OEQ1667353.2.SET_TEMPERATURE","isActive":true,"type":1,"room":"Wohnzimmer"}]
    2021-12-21 10:26:35.498 - debug: heatingcontrol.0 (621912) got system language de
    2021-12-21 10:26:35.498 - info: heatingcontrol.0 (621912) start CreateDatabase
    2021-12-21 10:26:35.499 - warn: heatingcontrol.0 (621912) window sensor has no datatyp in Badezimmer unten (Fenstersensor Badezimmer EG), boolean used. Please check and save configuration
    2021-12-21 10:26:35.499 - warn: heatingcontrol.0 (621912) window sensor has no datatyp in Esszimmer (Fenstersensor links Esszimmer EG), boolean used. Please check and save configuration
    2021-12-21 10:26:35.499 - warn: heatingcontrol.0 (621912) window sensor has no datatyp in Esszimmer (Fenstersensor rechts Esszimmer EG), boolean used. Please check and save configuration
    2021-12-21 10:26:35.500 - warn: heatingcontrol.0 (621912) window sensor has no datatyp in Gästezimmer (Fenstersensor Gästezimmer OG), boolean used. Please check and save configuration
    2021-12-21 10:26:35.500 - warn: heatingcontrol.0 (621912) window sensor has no datatyp in Kinderzimmer (Fenstersensor Kinderzimmer OG), boolean used. Please check and save configuration
    2021-12-21 10:26:35.500 - warn: heatingcontrol.0 (621912) window sensor has no datatyp in Schlafzimmer (Fenstersensor Kleiderschrank Schlafzimmer), boolean used. Please check and save configuration
    2021-12-21 10:26:35.500 - warn: heatingcontrol.0 (621912) window sensor has no datatyp in Schlafzimmer (Fenstersensor links Schlafzimmer), boolean used. Please check and save configuration
    2021-12-21 10:26:35.500 - warn: heatingcontrol.0 (621912) window sensor has no datatyp in Schlafzimmer (Fenstersensor rechts Schlafzimmer), boolean used. Please check and save configuration
    2021-12-21 10:26:35.500 - debug: heatingcontrol.0 (621912) CreateDatabase: 7 active rooms found [{"ID":0,"Name":"Badezimmer oben","isActive":true,"WindowIsOpen":false,"WindowIsOpenChanged":"never","TemperaturOverrideTime":"00:00","TemperaturOverride":0,"State":"starting","PreviousState":"none","CurrentTimePeriodTime":"00:00","CurrentTimePeriodFull":"","CurrentTimePeriod":-1,"CurrentTarget":-99,"CurrentReduced":0,"ActiveTimeSlot":-1,"MinimumTemperature":-99,"CurrentProfileTarget":-99,"LastAutoTarget":-99,"IsInOverride":false,"IsInReduced":false,"CurrentReducedMode":"none","IsInManual":false,"TemperatureManualMode":-99,"CurrentTemperature":-99,"ReducedState":"","HasActorsWithoutThermostat":false,"WindowCloseTimerId":null,"WindowOpenTimerId":null,"ActorOnTimerId":null,"ActorOffTimerId":null,"Present":true,"VacationAbsent":false,"MaintenanceActive":false,"FireplaceModeActive":false,"HolidayPresent":false,"GuestsPresent":false,"PartyNow":false,"PublicHolidyToday":false,"OverrideTimerId":null,"HeatingPeriod":true,"StatusLog":[],"hasWindowSensors":true,"ActorState":false,"NextTemperaturFromThermostatIsWindowOpen":false,"WindowOpenUntilTemperaturTimerId":null,"sensors":[{"name":"Fenstersensor links Badezimmer OG","id":0,"OID":"hm-rpc.0.MEQ0029521.1.STATE","DataType":"boolean","valueOpen":true,"valueClosed":false,"state":-1},{"name":"Fenstersensor rechts Badezimmer OG","id":1,"OID":"hm-rpc.0.MEQ0029487.1.STATE","DataType":"boolean","valueOpen":true,"valueClosed":false,"state":-1}],"TempOffset":0,"hasAddTempSensors":false,"TempOffsetData":[],"RemainingOverrideTime":0,"RemainingOverrideTimerId":null},{"ID":1,"Name":"Badezimmer unten","isActive":true,"WindowIsOpen":false,"WindowIsOpenChanged":"never","TemperaturOverrideTime":"00:00","TemperaturOverride":0,"State":"starting","PreviousState":"none","CurrentTimePeriodTime":"00:00","CurrentTimePeriodFull":"","CurrentTimePeriod":-1,"CurrentTarget":-99,"CurrentReduced":0,"ActiveTimeSlot":-1,"MinimumTemperature":-99,"CurrentProfileTarget":-99,"LastAutoTarget":-99,"IsInOverride":false,"IsInReduced":false,"CurrentReducedMode":"none","IsInManual":false,"TemperatureManualMode":-99,"CurrentTemperature":-99,"ReducedState":"","HasActorsWithoutThermostat":false,"WindowCloseTimerId":null,"WindowOpenTimerId":null,"ActorOnTimerId":null,"ActorOffTimerId":null,"Present":true,"VacationAbsent":false,"MaintenanceActive":false,"FireplaceModeActive":false,"HolidayPresent":false,"GuestsPresent":false,"PartyNow":false,"PublicHolidyToday":false,"OverrideTimerId":null,"HeatingPeriod":true,"StatusLog":[],"hasWindowSensors":true,"ActorState":false,"NextTemperaturFromThermostatIsWindowOpen":false,"WindowOpenUntilTemperaturTimerId":null,"sensors":[{"name":"Fenstersensor Badezimmer EG","id":2,"OID":"hm-rpc.0.MEQ0029496.1.STATE","DataType":"boolean","valueOpen":true,"valueClosed":false,"state":-1}],"TempOffset":0,"hasAddTempSensors":false,"TempOffsetData":[],"RemainingOverrideTime":0,"RemainingOverrideTimerId":null},{"ID":2,"Name":"Esszimmer","isActive":true,"WindowIsOpen":false,"WindowIsOpenChanged":"never","TemperaturOverrideTime":"00:00","TemperaturOverride":0,"State":"starting","PreviousState":"none","CurrentTimePeriodTime":"00:00","CurrentTimePeriodFull":"","CurrentTimePeriod":-1,"CurrentTarget":-99,"CurrentReduced":0,"ActiveTimeSlot":-1,"MinimumTemperature":-99,"CurrentProfileTarget":-99,"LastAutoTarget":-99,"IsInOverride":false,"IsInReduced":false,"CurrentReducedMode":"none","IsInManual":false,"TemperatureManualMode":-99,"CurrentTemperature":-99,"ReducedState":"","HasActorsWithoutThermostat":false,"WindowCloseTimerId":null,"WindowOpenTimerId":null,"ActorOnTimerId":null,"ActorOffTimerId":null,"Present":true,"VacationAbsent":false,"MaintenanceActive":false,"FireplaceModeActive":false,"HolidayPresent":false,"GuestsPresent":false,"PartyNow":false,"PublicHolidyToday":false,"OverrideTimerId":null,"HeatingPeriod":true,"StatusLog":[],"hasWindowSensors":true,"ActorState":false,"NextTemperaturFromThermostatIsWindowOpen":false,"WindowOpenUntilTemperaturTimerId":null,"sensors":[{"name":"Fenstersensor links Esszimmer EG","id":3,"OID":"hm-rpc.0.MEQ0028801.1.STATE","DataType":"boolean","valueOpen":true,"valueClosed":false,"state":-1},{"name":"Fenstersensor rechts Esszimmer EG","id":4,"OID":"hm-rpc.0.MEQ0029513.1.STATE","DataType":"boolean","valueOpen":true,"valueClosed":false,"state":-1}],"TempOffset":0,"hasAddTempSensors":false,"TempOffsetData":[],"RemainingOverrideTime":0,"RemainingOverrideTimerId":null},{"ID":3,"Name":"Flur unten","isActive":true,"WindowIsOpen":false,"WindowIsOpenChanged":"never","TemperaturOverrideTime":"00:00","TemperaturOverride":0,"State":"starting","PreviousState":"none","CurrentTimePeriodTime":"00:00","CurrentTimePeriodFull":"","CurrentTimePeriod":-1,"CurrentTarget":-99,"CurrentReduced":0,"ActiveTimeSlot":-1,"MinimumTemperature":-99,"CurrentProfileTarget":-99,"LastAutoTarget":-99,"IsInOverride":false,"IsInReduced":false,"CurrentReducedMode":"none","IsInManual":false,"TemperatureManualMode":-99,"CurrentTemperature":-99,"ReducedState":"","HasActorsWithoutThermostat":false,"WindowCloseTimerId":null,"WindowOpenTimerId":null,"ActorOnTimerId":null,"ActorOffTimerId":null,"Present":true,"VacationAbsent":false,"MaintenanceActive":false,"FireplaceModeActive":false,"HolidayPresent":false,"GuestsPresent":false,"PartyNow":false,"PublicHolidyToday":false,"OverrideTimerId":null,"HeatingPeriod":true,"StatusLog":[],"hasWindowSensors":false,"ActorState":false,"NextTemperaturFromThermostatIsWindowOpen":false,"WindowOpenUntilTemperaturTimerId":null,"sensors":[],"TempOffset":0,"hasAddTempSensors":false,"TempOffsetData":[],"RemainingOverrideTime":0,"RemainingOverrideTimerId":null},{"ID":4,"Name":"Gästezimmer","isActive":true,"WindowIsOpen":false,"WindowIsOpenChanged":"never","TemperaturOverrideTime":"00:00","TemperaturOverride":0,"State":"starting","PreviousState":"none","CurrentTimePeriodTime":"00:00","CurrentTimePeriodFull":"","CurrentTimePeriod":-1,"CurrentTarget":-99,"CurrentReduced":0,"ActiveTimeSlot":-1,"MinimumTemperature":-99,"CurrentProfileTarget":-99,"LastAutoTarget":-99,"IsInOverride":false,"IsInReduced":false,"CurrentReducedMode":"none","IsInManual":false,"TemperatureManualMode":-99,"CurrentTemperature":-99,"ReducedState":"","HasActorsWithoutThermostat":false,"WindowCloseTimerId":null,"WindowOpenTimerId":null,"ActorOnTimerId":null,"ActorOffTimerId":null,"Present":true,"VacationAbsent":false,"MaintenanceActive":false,"FireplaceModeActive":false,"HolidayPresent":false,"GuestsPresent":false,"PartyNow":false,"PublicHolidyToday":false,"OverrideTimerId":null,"HeatingPeriod":true,"StatusLog":[],"hasWindowSensors":true,"ActorState":false,"NextTemperaturFromThermostatIsWindowOpen":false,"WindowOpenUntilTemperaturTimerId":null,"sensors":[{"name":"Fenstersensor Gästezimmer OG","id":5,"OID":"hm-rpc.0.MEQ0030860.1.STATE","DataType":"boolean","valueOpen":true,"valueClosed":false,"state":-1}],"TempOffset":0,"hasAddTempSensors":false,"TempOffsetData":[],"RemainingOverrideTime":0,"RemainingOverrideTimerId":null},{"ID":5,"Name":"Kinderzimmer","isActive":true,"WindowIsOpen":false,"WindowIsOpenChanged":"never","TemperaturOverrideTime":"00:00","TemperaturOverride":0,"State":"starting","PreviousState":"none","CurrentTimePeriodTime":"00:00","CurrentTimePeriodFull":"","CurrentTimePeriod":-1,"CurrentTarget":-99,"CurrentReduced":0,"ActiveTimeSlot":-1,"MinimumTemperature":-99,"CurrentProfileTarget":-99,"LastAutoTarget":-99,"IsInOverride":false,"IsInReduced":false,"CurrentReducedMode":"none","IsInManual":false,"TemperatureManualMode":-99,"CurrentTemperature":-99,"ReducedState":"","HasActorsWithoutThermostat":false,"WindowCloseTimerId":null,"WindowOpenTimerId":null,"ActorOnTimerId":null,"ActorOffTimerId":null,"Present":true,"VacationAbsent":false,"MaintenanceActive":false,"FireplaceModeActive":false,"HolidayPresent":false,"GuestsPresent":false,"PartyNow":false,"PublicHolidyToday":false,"OverrideTimerId":null,"HeatingPeriod":true,"StatusLog":[],"hasWindowSensors":true,"ActorState":false,"NextTemperaturFromThermostatIsWindowOpen":false,"WindowOpenUntilTemperaturTimerId":null,"sensors":[{"name":"Fenstersensor Kinderzimmer OG","id":6,"OID":"hm-rpc.0.MEQ0030875.1.STATE","DataType":"boolean","valueOpen":true,"valueClosed":false,"state":-1}],"TempOffset":0,"hasAddTempSensors":false,"TempOffsetData":[],"RemainingOverrideTime":0,"RemainingOverrideTimerId":null},{"ID":6,"Name":"Schlafzimmer","isActive":true,"WindowIsOpen":false,"WindowIsOpenChanged":"never","TemperaturOverrideTime":"00:00","TemperaturOverride":0,"State":"starting","PreviousState":"none","CurrentTimePeriodTime":"00:00","CurrentTimePeriodFull":"","CurrentTimePeriod":-1,"CurrentTarget":-99,"CurrentReduced":0,"ActiveTimeSlot":-1,"MinimumTemperature":-99,"CurrentProfileTarget":-99,"LastAutoTarget":-99,"IsInOverride":false,"IsInReduced":false,"CurrentReducedMode":"none","IsInManual":false,"TemperatureManualMode":-99,"CurrentTemperature":-99,"ReducedState":"","HasActorsWithoutThermostat":false,"WindowCloseTimerId":null,"WindowOpenTimerId":null,"ActorOnTimerId":null,"ActorOffTimerId":null,"Present":true,"VacationAbsent":false,"MaintenanceActive":false,"FireplaceModeActive":false,"HolidayPresent":false,"GuestsPresent":false,"PartyNow":false,"PublicHolidyToday":false,"OverrideTimerId":null,"HeatingPeriod":true,"StatusLog":[],"hasWindowSensors":true,"ActorState":false,"NextTemperaturFromThermostatIsWindowOpen":false,"WindowOpenUntilTemperaturTimerId":null,"sensors":[{"name":"Fenstersensor Kleiderschrank Schlafzimmer","id":7,"OID":"hm-rpc.0.MEQ0029506.1.STATE","DataType":"boolean","valueOpen":true,"valueClosed":false,"state":-1},{"name":"Fenstersensor links Schlafzimmer","id":8,"OID":"hm-rpc.0.MEQ0029515.1.STATE","DataType":"boolean","valueOpen":true,"valueClosed":false,"state":-1},{"name":"Fenstersensor rechts Schlafzimmer","id":9,"OID":"hm-rpc.0.MEQ0029522.1.STATE","DataType":"boolean","valueOpen":true,"valueClosed":false,"state":-1}],"TempOffset":0,"hasAddTempSensors":false,"TempOffsetData":[],"RemainingOverrideTime":0,"RemainingOverrideTimerId":null}]
    2021-12-21 10:26:35.500 - debug: heatingcontrol.0 (621912) CreateDatabase: 10 active sensors found [{"name":"Fenstersensor links Badezimmer OG","room":"Badezimmer oben","OID":"hm-rpc.0.MEQ0029521.1.STATE","lastState":false,"lastChange":"","DataType":"boolean","valueOpen":true,"valueClosed":false},{"name":"Fenstersensor rechts Badezimmer OG","room":"Badezimmer oben","OID":"hm-rpc.0.MEQ0029487.1.STATE","lastState":false,"lastChange":"","DataType":"boolean","valueOpen":true,"valueClosed":false},{"name":"Fenstersensor Badezimmer EG","room":"Badezimmer unten","OID":"hm-rpc.0.MEQ0029496.1.STATE","lastState":false,"lastChange":"","DataType":"boolean","valueOpen":true,"valueClosed":false},{"name":"Fenstersensor links Esszimmer EG","room":"Esszimmer","OID":"hm-rpc.0.MEQ0028801.1.STATE","lastState":false,"lastChange":"","DataType":"boolean","valueOpen":true,"valueClosed":false},{"name":"Fenstersensor rechts Esszimmer EG","room":"Esszimmer","OID":"hm-rpc.0.MEQ0029513.1.STATE","lastState":false,"lastChange":"","DataType":"boolean","valueOpen":true,"valueClosed":false},{"name":"Fenstersensor Gästezimmer OG","room":"Gästezimmer","OID":"hm-rpc.0.MEQ0030860.1.STATE","lastState":false,"lastChange":"","DataType":"boolean","valueOpen":true,"valueClosed":false},{"name":"Fenstersensor Kinderzimmer OG","room":"Kinderzimmer","OID":"hm-rpc.0.MEQ0030875.1.STATE","lastState":false,"lastChange":"","DataType":"boolean","valueOpen":true,"valueClosed":false},{"name":"Fenstersensor Kleiderschrank Schlafzimmer","room":"Schlafzimmer","OID":"hm-rpc.0.MEQ0029506.1.STATE","lastState":false,"lastChange":"","DataType":"boolean","valueOpen":true,"valueClosed":false},{"name":"Fenstersensor links Schlafzimmer","room":"Schlafzimmer","OID":"hm-rpc.0.MEQ0029515.1.STATE","lastState":false,"lastChange":"","DataType":"boolean","valueOpen":true,"valueClosed":false},{"name":"Fenstersensor rechts Schlafzimmer","room":"Schlafzimmer","OID":"hm-rpc.0.MEQ0029522.1.STATE","lastState":false,"lastChange":"","DataType":"boolean","valueOpen":true,"valueClosed":false}]
    2021-12-21 10:26:35.500 - debug: heatingcontrol.0 (621912) CreateDatabase: 0 active actors found []
    2021-12-21 10:26:35.500 - debug: heatingcontrol.0 (621912) CreateDatabase: 7 active thermostats found [{"name":"Heizung Badezimmer OG 4.SET_TEMPERATURE","room":"Badezimmer oben","OID_Target":"hm-rpc.0.KEQ0574582.4.SET_TEMPERATURE","OID_Current":"hm-rpc.0.KEQ0574582.4.ACTUAL_TEMPERATURE","lastTarget":-99,"currentTarget":-99,"lastTargetFromDevice":-99,"lastChange":""},{"name":"Heizung Badezimmer EG","room":"Badezimmer unten","OID_Target":"hm-rpc.0.LEQ1520473.4.SET_TEMPERATURE","OID_Current":"hm-rpc.0.LEQ1520473.4.ACTUAL_TEMPERATURE","lastTarget":-99,"currentTarget":-99,"lastTargetFromDevice":-99,"lastChange":""},{"name":"Heizung Esszimmer EG","room":"Esszimmer","OID_Target":"hm-rpc.0.LEQ1520465.4.SET_TEMPERATURE","OID_Current":"hm-rpc.0.LEQ1520465.4.ACTUAL_TEMPERATURE","lastTarget":-99,"currentTarget":-99,"lastTargetFromDevice":-99,"lastChange":""},{"name":"Heizung Vorflur EG","room":"Flur unten","OID_Target":"hm-rpc.0.OEQ0242950.4.SET_TEMPERATURE","OID_Current":"hm-rpc.0.OEQ0242950.4.ACTUAL_TEMPERATURE","lastTarget":-99,"currentTarget":-99,"lastTargetFromDevice":-99,"lastChange":""},{"name":"Heizung Gästezimmer OG","room":"Gästezimmer","OID_Target":"hm-rpc.0.MEQ0007312.4.SET_TEMPERATURE","OID_Current":"hm-rpc.0.MEQ0007312.4.ACTUAL_TEMPERATURE","lastTarget":-99,"currentTarget":-99,"lastTargetFromDevice":-99,"lastChange":""},{"name":"Heizung Kinderzimmer OG","room":"Kinderzimmer","OID_Target":"hm-rpc.0.LEQ1520877.4.SET_TEMPERATURE","OID_Current":"hm-rpc.0.LEQ1520877.4.ACTUAL_TEMPERATURE","lastTarget":-99,"currentTarget":-99,"lastTargetFromDevice":-99,"lastChange":""},{"name":"Heizung Schlafzimmer OG 4.SET_TEMPERATURE","room":"Schlafzimmer","OID_Target":"hm-rpc.0.KEQ0574680.4.SET_TEMPERATURE","OID_Current":"hm-rpc.0.KEQ0574680.4.ACTUAL_TEMPERATURE","lastTarget":-99,"currentTarget":-99,"lastTargetFromDevice":-99,"lastChange":""}]
    2021-12-21 10:26:35.501 - debug: heatingcontrol.0 (621912) CreateDatabase: 0 active additional Temp sensors found []
    2021-12-21 10:26:35.501 - info: heatingcontrol.0 (621912) CreateDatabase done with 7 rooms
    2021-12-21 10:26:35.502 - info: heatingcontrol.0 (621912) start CreateDatapoints
    2021-12-21 10:26:35.629 - info: heatingcontrol.0 (621912) CreateDatapoints done
    2021-12-21 10:26:35.630 - debug: heatingcontrol.0 (621912) start SetDefaults
    2021-12-21 10:26:35.653 - debug: heatingcontrol.0 (621912) SetDefaults done
    2021-12-21 10:26:35.654 - info: heatingcontrol.0 (621912) start SetInfo
    2021-12-21 10:26:35.665 - info: heatingcontrol.0 (621912) SetInfo done
    2021-12-21 10:26:35.665 - info: heatingcontrol.0 (621912) start SetCurrent
    2021-12-21 10:26:35.681 - info: heatingcontrol.0 (621912) SetCurrent done
    2021-12-21 10:26:35.688 - debug: heatingcontrol.0 (621912) no subscribe Path2FeiertagAdapter
    2021-12-21 10:26:35.688 - debug: heatingcontrol.0 (621912) no subscribe Path2PresentDP
    2021-12-21 10:26:35.688 - debug: heatingcontrol.0 (621912) no subscribe Path2VacationDP
    2021-12-21 10:26:35.688 - debug: heatingcontrol.0 (621912) no subscribe Path2HolidayPresentDP
    2021-12-21 10:26:35.688 - debug: heatingcontrol.0 (621912) no subscribe Path2GuestsPresentDP
    2021-12-21 10:26:35.689 - debug: heatingcontrol.0 (621912) no subscribe Path2PartyNowDP
    2021-12-21 10:26:35.689 - info: heatingcontrol.0 (621912) subscribe devices start
    2021-12-21 10:26:35.689 - info: heatingcontrol.0 (621912) subscribe thermostats current 7
    2021-12-21 10:26:35.689 - info: heatingcontrol.0 (621912) subscribe thermostat current Heizung Badezimmer OG 4.SET_TEMPERATURE hm-rpc.0.KEQ0574582.4.ACTUAL_TEMPERATURE
    2021-12-21 10:26:35.689 - info: heatingcontrol.0 (621912) subscribe thermostat current Heizung Badezimmer EG hm-rpc.0.LEQ1520473.4.ACTUAL_TEMPERATURE
    2021-12-21 10:26:35.690 - info: heatingcontrol.0 (621912) subscribe thermostat current Heizung Esszimmer EG hm-rpc.0.LEQ1520465.4.ACTUAL_TEMPERATURE
    2021-12-21 10:26:35.690 - info: heatingcontrol.0 (621912) subscribe thermostat current Heizung Vorflur EG hm-rpc.0.OEQ0242950.4.ACTUAL_TEMPERATURE
    2021-12-21 10:26:35.690 - info: heatingcontrol.0 (621912) subscribe thermostat current Heizung Gästezimmer OG hm-rpc.0.MEQ0007312.4.ACTUAL_TEMPERATURE
    2021-12-21 10:26:35.690 - info: heatingcontrol.0 (621912) subscribe thermostat current Heizung Kinderzimmer OG hm-rpc.0.LEQ1520877.4.ACTUAL_TEMPERATURE
    2021-12-21 10:26:35.690 - info: heatingcontrol.0 (621912) subscribe thermostat current Heizung Schlafzimmer OG 4.SET_TEMPERATURE hm-rpc.0.KEQ0574680.4.ACTUAL_TEMPERATURE
    2021-12-21 10:26:35.690 - info: heatingcontrol.0 (621912) subscribe thermostats target 7
    2021-12-21 10:26:35.690 - info: heatingcontrol.0 (621912) subscribe thermostat target Heizung Badezimmer OG 4.SET_TEMPERATURE hm-rpc.0.KEQ0574582.4.SET_TEMPERATURE
    2021-12-21 10:26:35.690 - info: heatingcontrol.0 (621912) subscribe thermostat target Heizung Badezimmer EG hm-rpc.0.LEQ1520473.4.SET_TEMPERATURE
    2021-12-21 10:26:35.690 - info: heatingcontrol.0 (621912) subscribe thermostat target Heizung Esszimmer EG hm-rpc.0.LEQ1520465.4.SET_TEMPERATURE
    2021-12-21 10:26:35.690 - info: heatingcontrol.0 (621912) subscribe thermostat target Heizung Vorflur EG hm-rpc.0.OEQ0242950.4.SET_TEMPERATURE
    2021-12-21 10:26:35.691 - info: heatingcontrol.0 (621912) subscribe thermostat target Heizung Gästezimmer OG hm-rpc.0.MEQ0007312.4.SET_TEMPERATURE
    2021-12-21 10:26:35.691 - info: heatingcontrol.0 (621912) subscribe thermostat target Heizung Kinderzimmer OG hm-rpc.0.LEQ1520877.4.SET_TEMPERATURE
    2021-12-21 10:26:35.691 - info: heatingcontrol.0 (621912) subscribe thermostat target Heizung Schlafzimmer OG 4.SET_TEMPERATURE hm-rpc.0.KEQ0574680.4.SET_TEMPERATURE
    2021-12-21 10:26:35.691 - info: heatingcontrol.0 (621912) subscribe sensor Fenstersensor links Badezimmer OG hm-rpc.0.MEQ0029521.1.STATE
    2021-12-21 10:26:35.691 - info: heatingcontrol.0 (621912) subscribe sensor Fenstersensor rechts Badezimmer OG hm-rpc.0.MEQ0029487.1.STATE
    2021-12-21 10:26:35.691 - info: heatingcontrol.0 (621912) subscribe sensor Fenstersensor Badezimmer EG hm-rpc.0.MEQ0029496.1.STATE
    2021-12-21 10:26:35.691 - info: heatingcontrol.0 (621912) subscribe sensor Fenstersensor links Esszimmer EG hm-rpc.0.MEQ0028801.1.STATE
    2021-12-21 10:26:35.691 - info: heatingcontrol.0 (621912) subscribe sensor Fenstersensor rechts Esszimmer EG hm-rpc.0.MEQ0029513.1.STATE
    2021-12-21 10:26:35.691 - info: heatingcontrol.0 (621912) subscribe sensor Fenstersensor Gästezimmer OG hm-rpc.0.MEQ0030860.1.STATE
    2021-12-21 10:26:35.691 - info: heatingcontrol.0 (621912) subscribe sensor Fenstersensor Kinderzimmer OG hm-rpc.0.MEQ0030875.1.STATE
    2021-12-21 10:26:35.691 - info: heatingcontrol.0 (621912) subscribe sensor Fenstersensor Kleiderschrank Schlafzimmer hm-rpc.0.MEQ0029506.1.STATE
    2021-12-21 10:26:35.692 - info: heatingcontrol.0 (621912) subscribe sensor Fenstersensor links Schlafzimmer hm-rpc.0.MEQ0029515.1.STATE
    2021-12-21 10:26:35.692 - info: heatingcontrol.0 (621912) subscribe sensor Fenstersensor rechts Schlafzimmer hm-rpc.0.MEQ0029522.1.STATE
    2021-12-21 10:26:35.695 - info: heatingcontrol.0 (621912) subscribe devices done
    2021-12-21 10:26:35.695 - debug: heatingcontrol.0 (621912) get current profile
    2021-12-21 10:26:35.727 - debug: heatingcontrol.0 (621912) profile 1
    2021-12-21 10:26:35.727 - debug: heatingcontrol.0 (621912) start CreateCronJobs
    2021-12-21 10:26:35.728 - info: heatingcontrol.0 (621912) start create cron jobs for profile type 1 (Mo - Su)
    2021-12-21 10:26:35.788 - debug: heatingcontrol.0 (621912) cron jobs created [{"hour":5,"minute":0,"day":0,"Values2Set":[{"room":"Badezimmer oben","target":4.5,"currentTimePeriod":1,"ActiveTimeSlot":1,"CurrentTimePeriodTime":"05:00","CurrentTimePeriodFull":"Period 1 05:00"},{"room":"Badezimmer unten","target":4.5,"currentTimePeriod":1,"ActiveTimeSlot":1,"CurrentTimePeriodTime":"05:00","CurrentTimePeriodFull":"Period 1 05:00"},{"room":"Esszimmer","target":21,"currentTimePeriod":1,"ActiveTimeSlot":1,"CurrentTimePeriodTime":"05:00","CurrentTimePeriodFull":"Period 1 05:00"},{"room":"Flur unten","target":23,"currentTimePeriod":1,"ActiveTimeSlot":1,"CurrentTimePeriodTime":"05:00","CurrentTimePeriodFull":"Period 1 05:00"},{"room":"Gästezimmer","target":"17.0","currentTimePeriod":1,"ActiveTimeSlot":1,"CurrentTimePeriodTime":"05:00","CurrentTimePeriodFull":"Period 1 05:00"}]},{"hour":20,"minute":0,"day":0,"Values2Set":[{"room":"Badezimmer oben","target":4.5,"currentTimePeriod":2,"ActiveTimeSlot":2,"CurrentTimePeriodTime":"20:00","CurrentTimePeriodFull":"Period 2 20:00"},{"room":"Badezimmer unten","target":4.5,"currentTimePeriod":2,"ActiveTimeSlot":2,"CurrentTimePeriodTime":"20:00","CurrentTimePeriodFull":"Period 2 20:00"},{"room":"Esszimmer","target":17,"currentTimePeriod":2,"ActiveTimeSlot":2,"CurrentTimePeriodTime":"20:00","CurrentTimePeriodFull":"Period 2 20:00"},{"room":"Gästezimmer","target":17,"currentTimePeriod":2,"ActiveTimeSlot":2,"CurrentTimePeriodTime":"20:00","CurrentTimePeriodFull":"Period 2 20:00"}]},{"hour":22,"minute":0,"day":0,"Values2Set":[{"room":"Flur unten","target":20,"currentTimePeriod":2,"ActiveTimeSlot":2,"CurrentTimePeriodTime":"22:00","CurrentTimePeriodFull":"Period 2 22:00"}]},{"hour":7,"minute":0,"day":0,"Values2Set":[{"room":"Kinderzimmer","target":21,"currentTimePeriod":1,"ActiveTimeSlot":1,"CurrentTimePeriodTime":"07:00","CurrentTimePeriodFull":"Period 1 07:00"},{"room":"Schlafzimmer","target":21,"currentTimePeriod":1,"ActiveTimeSlot":1,"CurrentTimePeriodTime":"07:00","CurrentTimePeriodFull":"Period 1 07:00"}]},{"hour":19,"minute":0,"day":0,"Values2Set":[{"room":"Kinderzimmer","target":21,"currentTimePeriod":2,"ActiveTimeSlot":2,"CurrentTimePeriodTime":"19:00","CurrentTimePeriodFull":"Period 2 19:00"},{"room":"Schlafzimmer","target":21,"currentTimePeriod":2,"ActiveTimeSlot":2,"CurrentTimePeriodTime":"19:00","CurrentTimePeriodFull":"Period 2 19:00"}]}]
    2021-12-21 10:26:35.788 - debug: heatingcontrol.0 (621912) create cron job #0 at 5:0 string: 0 0 5 * * * Europe/Berlin
    2021-12-21 10:26:35.792 - debug: heatingcontrol.0 (621912) create cron job #1 at 20:0 string: 0 0 20 * * * Europe/Berlin
    2021-12-21 10:26:35.835 - debug: heatingcontrol.0 (621912) create cron job #2 at 22:0 string: 0 0 22 * * * Europe/Berlin
    2021-12-21 10:26:35.836 - debug: heatingcontrol.0 (621912) create cron job #3 at 7:0 string: 0 0 7 * * * Europe/Berlin
    2021-12-21 10:26:35.837 - debug: heatingcontrol.0 (621912) create cron job #4 at 19:0 string: 0 0 19 * * * Europe/Berlin
    2021-12-21 10:26:35.838 - debug: heatingcontrol.0 (621912) CreateCronJobs done
    2021-12-21 10:26:35.839 - debug: heatingcontrol.0 (621912) cron status = true next event: 22 Dec 2021 05:00:00
    2021-12-21 10:26:35.839 - debug: heatingcontrol.0 (621912) cron status = true next event: 21 Dec 2021 20:00:00
    2021-12-21 10:26:35.859 - debug: heatingcontrol.0 (621912) cron status = true next event: 21 Dec 2021 22:00:00
    2021-12-21 10:26:35.860 - debug: heatingcontrol.0 (621912) cron status = true next event: 22 Dec 2021 07:00:00
    2021-12-21 10:26:35.860 - debug: heatingcontrol.0 (621912) cron status = true next event: 21 Dec 2021 19:00:00
    2021-12-21 10:26:35.861 - info: heatingcontrol.0 (621912) 5 cron job(s) created
    2021-12-21 10:26:35.861 - info: heatingcontrol.0 (621912) start statemachine
    2021-12-21 10:26:35.861 - debug: heatingcontrol.0 (621912) Badezimmer oben ### ChangeStatus ProfilPoint to -99 in starting
    2021-12-21 10:26:35.861 - debug: heatingcontrol.0 (621912) ChangeStatus Profilepoint in Badezimmer oben just recalc
    2021-12-21 10:26:35.862 - debug: heatingcontrol.0 (621912) UpdateDPs for Badezimmer oben starting
    2021-12-21 10:26:36.482 - debug: heatingcontrol.0 (621912) Badezimmer unten ### ChangeStatus ProfilPoint to -99 in starting
    2021-12-21 10:26:36.482 - debug: heatingcontrol.0 (621912) ChangeStatus Profilepoint in Badezimmer unten just recalc
    2021-12-21 10:26:36.482 - debug: heatingcontrol.0 (621912) UpdateDPs for Badezimmer unten starting
    2021-12-21 10:26:36.493 - debug: heatingcontrol.0 (621912) Esszimmer ### ChangeStatus ProfilPoint to -99 in starting
    2021-12-21 10:26:36.493 - debug: heatingcontrol.0 (621912) ChangeStatus Profilepoint in Esszimmer just recalc
    2021-12-21 10:26:36.493 - debug: heatingcontrol.0 (621912) UpdateDPs for Esszimmer starting
    2021-12-21 10:26:36.503 - debug: heatingcontrol.0 (621912) Flur unten ### ChangeStatus ProfilPoint to -99 in starting
    2021-12-21 10:26:36.503 - debug: heatingcontrol.0 (621912) ChangeStatus Profilepoint in Flur unten just recalc
    2021-12-21 10:26:36.503 - debug: heatingcontrol.0 (621912) UpdateDPs for Flur unten starting
    2021-12-21 10:26:36.518 - debug: heatingcontrol.0 (621912) Gästezimmer ### ChangeStatus ProfilPoint to -99 in starting
    2021-12-21 10:26:36.519 - debug: heatingcontrol.0 (621912) ChangeStatus Profilepoint in Gästezimmer just recalc
    2021-12-21 10:26:36.519 - debug: heatingcontrol.0 (621912) UpdateDPs for Gästezimmer starting
    2021-12-21 10:26:36.533 - debug: heatingcontrol.0 (621912) Kinderzimmer ### ChangeStatus ProfilPoint to -99 in starting
    2021-12-21 10:26:36.533 - debug: heatingcontrol.0 (621912) ChangeStatus Profilepoint in Kinderzimmer just recalc
    2021-12-21 10:26:36.533 - debug: heatingcontrol.0 (621912) UpdateDPs for Kinderzimmer starting
    2021-12-21 10:26:36.551 - debug: heatingcontrol.0 (621912) Schlafzimmer ### ChangeStatus ProfilPoint to -99 in starting
    2021-12-21 10:26:36.551 - debug: heatingcontrol.0 (621912) ChangeStatus Profilepoint in Schlafzimmer just recalc
    2021-12-21 10:26:36.551 - debug: heatingcontrol.0 (621912) UpdateDPs for Schlafzimmer starting
    2021-12-21 10:26:36.561 - debug: heatingcontrol.0 (621912) check all active thermostats
    2021-12-21 10:26:36.564 - debug: heatingcontrol.0 (621912) reset temp offsets because not used
    2021-12-21 10:26:36.564 - info: heatingcontrol.0 (621912) check all active sensors
    2021-12-21 10:26:36.573 - debug: heatingcontrol.0 (621912) Sensor state true ?= false
    2021-12-21 10:26:36.573 - debug: heatingcontrol.0 (621912) boolean: one window open in Badezimmer oben hm-rpc.0.MEQ0029521.1.STATE
    2021-12-21 10:26:36.573 - debug: heatingcontrol.0 (621912) Sensor state false ?= false
    2021-12-21 10:26:36.573 - debug: heatingcontrol.0 (621912) boolean: one window closed in Badezimmer oben hm-rpc.0.MEQ0029487.1.STATE
    2021-12-21 10:26:36.573 - debug: heatingcontrol.0 (621912) result for CheckSensors4Room in Badezimmer oben is true since 1640072770113 = never
    2021-12-21 10:26:36.576 - debug: heatingcontrol.0 (621912) Sensor state false ?= false
    2021-12-21 10:26:36.577 - debug: heatingcontrol.0 (621912) boolean: one window closed in Badezimmer unten hm-rpc.0.MEQ0029496.1.STATE
    2021-12-21 10:26:36.577 - debug: heatingcontrol.0 (621912) result for CheckSensors4Room in Badezimmer unten is false since 1639332648856 = never
    2021-12-21 10:26:36.579 - debug: heatingcontrol.0 (621912) Sensor state false ?= false
    2021-12-21 10:26:36.579 - debug: heatingcontrol.0 (621912) boolean: one window closed in Esszimmer hm-rpc.0.MEQ0028801.1.STATE
    2021-12-21 10:26:36.579 - debug: heatingcontrol.0 (621912) boolean: one window closed in Esszimmer hm-rpc.0.MEQ0029513.1.STATE
    2021-12-21 10:26:36.579 - debug: heatingcontrol.0 (621912) result for CheckSensors4Room in Esszimmer is false since 1639995464181 = never
    2021-12-21 10:26:36.579 - debug: heatingcontrol.0 (621912) result for CheckSensors4Room in Flur unten is false since 0 = never
    2021-12-21 10:26:36.582 - debug: heatingcontrol.0 (621912) Sensor state false ?= false
    2021-12-21 10:26:36.582 - debug: heatingcontrol.0 (621912) boolean: one window closed in Gästezimmer hm-rpc.0.MEQ0030860.1.STATE
    2021-12-21 10:26:36.582 - debug: heatingcontrol.0 (621912) result for CheckSensors4Room in Gästezimmer is false since 1639969545694 = never
    2021-12-21 10:26:36.584 - debug: heatingcontrol.0 (621912) Sensor state false ?= false
    2021-12-21 10:26:36.584 - debug: heatingcontrol.0 (621912) boolean: one window closed in Kinderzimmer hm-rpc.0.MEQ0030875.1.STATE
    2021-12-21 10:26:36.584 - debug: heatingcontrol.0 (621912) result for CheckSensors4Room in Kinderzimmer is false since 1639216434443 = never
    2021-12-21 10:26:36.586 - debug: heatingcontrol.0 (621912) Sensor state false ?= false
    2021-12-21 10:26:36.586 - debug: heatingcontrol.0 (621912) boolean: one window closed in Schlafzimmer hm-rpc.0.MEQ0029506.1.STATE
    2021-12-21 10:26:36.587 - debug: heatingcontrol.0 (621912) Sensor state false ?= false
    2021-12-21 10:26:36.587 - debug: heatingcontrol.0 (621912) boolean: one window closed in Schlafzimmer hm-rpc.0.MEQ0029515.1.STATE
    2021-12-21 10:26:36.587 - debug: heatingcontrol.0 (621912) boolean: one window closed in Schlafzimmer hm-rpc.0.MEQ0029522.1.STATE
    2021-12-21 10:26:36.587 - debug: heatingcontrol.0 (621912) result for CheckSensors4Room in Schlafzimmer is false since 1640061945717 = never
    2021-12-21 10:26:36.587 - info: heatingcontrol.0 (621912) checking external states
    2021-12-21 10:26:36.592 - debug: heatingcontrol.0 (621912) HeatingPeriodActive true
    2021-12-21 10:26:36.592 - debug: heatingcontrol.0 (621912) Present true
    2021-12-21 10:26:36.593 - debug: heatingcontrol.0 (621912) VacationAbsent false
    2021-12-21 10:26:36.594 - debug: heatingcontrol.0 (621912) HolidayPresent false
    2021-12-21 10:26:36.595 - debug: heatingcontrol.0 (621912) GuestsPresent false
    2021-12-21 10:26:36.595 - debug: heatingcontrol.0 (621912) PartyNow false
    2021-12-21 10:26:36.596 - debug: heatingcontrol.0 (621912) PublicHolidyToday false
    2021-12-21 10:26:36.597 - debug: heatingcontrol.0 (621912) MaintenanceActive false
    2021-12-21 10:26:36.597 - debug: heatingcontrol.0 (621912) Badezimmer oben ### ChangeStatus HeatingPeriodActive to true in starting
    2021-12-21 10:26:36.597 - debug: heatingcontrol.0 (621912) UpdateDPs for Badezimmer oben starting
    2021-12-21 10:26:36.608 - debug: heatingcontrol.0 (621912) Badezimmer unten ### ChangeStatus HeatingPeriodActive to true in starting
    2021-12-21 10:26:36.608 - debug: heatingcontrol.0 (621912) UpdateDPs for Badezimmer unten starting
    2021-12-21 10:26:36.618 - debug: heatingcontrol.0 (621912) Esszimmer ### ChangeStatus HeatingPeriodActive to true in starting
    2021-12-21 10:26:36.618 - debug: heatingcontrol.0 (621912) UpdateDPs for Esszimmer starting
    2021-12-21 10:26:36.634 - debug: heatingcontrol.0 (621912) Flur unten ### ChangeStatus HeatingPeriodActive to true in starting
    2021-12-21 10:26:36.634 - debug: heatingcontrol.0 (621912) UpdateDPs for Flur unten starting
    2021-12-21 10:26:36.649 - debug: heatingcontrol.0 (621912) Gästezimmer ### ChangeStatus HeatingPeriodActive to true in starting
    2021-12-21 10:26:36.649 - debug: heatingcontrol.0 (621912) UpdateDPs for Gästezimmer starting
    2021-12-21 10:26:36.662 - debug: heatingcontrol.0 (621912) Kinderzimmer ### ChangeStatus HeatingPeriodActive to true in starting
    2021-12-21 10:26:36.662 - debug: heatingcontrol.0 (621912) UpdateDPs for Kinderzimmer starting
    2021-12-21 10:26:36.675 - debug: heatingcontrol.0 (621912) Schlafzimmer ### ChangeStatus HeatingPeriodActive to true in starting
    2021-12-21 10:26:36.675 - debug: heatingcontrol.0 (621912) UpdateDPs for Schlafzimmer starting
    2021-12-21 10:26:36.685 - debug: heatingcontrol.0 (621912) Badezimmer oben ### ChangeStatus Present to true in starting
    2021-12-21 10:26:36.685 - debug: heatingcontrol.0 (621912) UpdateDPs for Badezimmer oben starting
    2021-12-21 10:26:36.692 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Badezimmer oben starting 4.5°C
    2021-12-21 10:26:36.695 - debug: heatingcontrol.0 (621912) Badezimmer unten ### ChangeStatus Present to true in starting
    2021-12-21 10:26:36.696 - debug: heatingcontrol.0 (621912) UpdateDPs for Badezimmer unten starting
    2021-12-21 10:26:36.702 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Badezimmer unten starting 4.5°C
    2021-12-21 10:26:36.705 - debug: heatingcontrol.0 (621912) Esszimmer ### ChangeStatus Present to true in starting
    2021-12-21 10:26:36.705 - debug: heatingcontrol.0 (621912) UpdateDPs for Esszimmer starting
    2021-12-21 10:26:36.712 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Esszimmer starting 21°C
    2021-12-21 10:26:36.717 - debug: heatingcontrol.0 (621912) Flur unten ### ChangeStatus Present to true in starting
    2021-12-21 10:26:36.717 - debug: heatingcontrol.0 (621912) UpdateDPs for Flur unten starting
    2021-12-21 10:26:36.723 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Flur unten starting 23°C
    2021-12-21 10:26:36.727 - debug: heatingcontrol.0 (621912) Gästezimmer ### ChangeStatus Present to true in starting
    2021-12-21 10:26:36.727 - debug: heatingcontrol.0 (621912) UpdateDPs for Gästezimmer starting
    2021-12-21 10:26:36.734 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Gästezimmer starting 17°C
    2021-12-21 10:26:36.738 - debug: heatingcontrol.0 (621912) Kinderzimmer ### ChangeStatus Present to true in starting
    2021-12-21 10:26:36.738 - debug: heatingcontrol.0 (621912) UpdateDPs for Kinderzimmer starting
    2021-12-21 10:26:36.745 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Kinderzimmer starting 21°C
    2021-12-21 10:26:36.748 - debug: heatingcontrol.0 (621912) Schlafzimmer ### ChangeStatus Present to true in starting
    2021-12-21 10:26:36.749 - debug: heatingcontrol.0 (621912) UpdateDPs for Schlafzimmer starting
    2021-12-21 10:26:36.755 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Schlafzimmer starting 21°C
    2021-12-21 10:26:36.760 - debug: heatingcontrol.0 (621912) Badezimmer oben ### ChangeStatus VacationAbsent to false in starting
    2021-12-21 10:26:36.760 - debug: heatingcontrol.0 (621912) UpdateDPs for Badezimmer oben starting
    2021-12-21 10:26:36.766 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Badezimmer oben starting 4.5°C
    2021-12-21 10:26:36.770 - debug: heatingcontrol.0 (621912) Badezimmer unten ### ChangeStatus VacationAbsent to false in starting
    2021-12-21 10:26:36.770 - debug: heatingcontrol.0 (621912) UpdateDPs for Badezimmer unten starting
    2021-12-21 10:26:36.777 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Badezimmer unten starting 4.5°C
    2021-12-21 10:26:36.785 - debug: heatingcontrol.0 (621912) Esszimmer ### ChangeStatus VacationAbsent to false in starting
    2021-12-21 10:26:36.785 - debug: heatingcontrol.0 (621912) UpdateDPs for Esszimmer starting
    2021-12-21 10:26:36.792 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Esszimmer starting 21°C
    2021-12-21 10:26:36.796 - debug: heatingcontrol.0 (621912) Flur unten ### ChangeStatus VacationAbsent to false in starting
    2021-12-21 10:26:36.796 - debug: heatingcontrol.0 (621912) UpdateDPs for Flur unten starting
    2021-12-21 10:26:36.802 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Flur unten starting 23°C
    2021-12-21 10:26:36.806 - debug: heatingcontrol.0 (621912) Gästezimmer ### ChangeStatus VacationAbsent to false in starting
    2021-12-21 10:26:36.807 - debug: heatingcontrol.0 (621912) UpdateDPs for Gästezimmer starting
    2021-12-21 10:26:36.815 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Gästezimmer starting 17°C
    2021-12-21 10:26:36.819 - debug: heatingcontrol.0 (621912) Kinderzimmer ### ChangeStatus VacationAbsent to false in starting
    2021-12-21 10:26:36.819 - debug: heatingcontrol.0 (621912) UpdateDPs for Kinderzimmer starting
    2021-12-21 10:26:36.825 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Kinderzimmer starting 21°C
    2021-12-21 10:26:36.829 - debug: heatingcontrol.0 (621912) Schlafzimmer ### ChangeStatus VacationAbsent to false in starting
    2021-12-21 10:26:36.829 - debug: heatingcontrol.0 (621912) UpdateDPs for Schlafzimmer starting
    2021-12-21 10:26:36.835 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Schlafzimmer starting 21°C
    2021-12-21 10:26:36.844 - debug: heatingcontrol.0 (621912) Badezimmer oben ### ChangeStatus HolidayPresent to false in starting
    2021-12-21 10:26:36.844 - debug: heatingcontrol.0 (621912) UpdateDPs for Badezimmer oben starting
    2021-12-21 10:26:36.850 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Badezimmer oben starting 4.5°C
    2021-12-21 10:26:36.854 - debug: heatingcontrol.0 (621912) Badezimmer unten ### ChangeStatus HolidayPresent to false in starting
    2021-12-21 10:26:36.854 - debug: heatingcontrol.0 (621912) UpdateDPs for Badezimmer unten starting
    2021-12-21 10:26:36.860 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Badezimmer unten starting 4.5°C
    2021-12-21 10:26:36.864 - debug: heatingcontrol.0 (621912) Esszimmer ### ChangeStatus HolidayPresent to false in starting
    2021-12-21 10:26:36.864 - debug: heatingcontrol.0 (621912) UpdateDPs for Esszimmer starting
    2021-12-21 10:26:36.872 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Esszimmer starting 21°C
    2021-12-21 10:26:36.875 - debug: heatingcontrol.0 (621912) Flur unten ### ChangeStatus HolidayPresent to false in starting
    2021-12-21 10:26:36.875 - debug: heatingcontrol.0 (621912) UpdateDPs for Flur unten starting
    2021-12-21 10:26:36.882 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Flur unten starting 23°C
    2021-12-21 10:26:36.885 - debug: heatingcontrol.0 (621912) Gästezimmer ### ChangeStatus HolidayPresent to false in starting
    2021-12-21 10:26:36.885 - debug: heatingcontrol.0 (621912) UpdateDPs for Gästezimmer starting
    2021-12-21 10:26:36.891 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Gästezimmer starting 17°C
    2021-12-21 10:26:36.895 - debug: heatingcontrol.0 (621912) Kinderzimmer ### ChangeStatus HolidayPresent to false in starting
    2021-12-21 10:26:36.895 - debug: heatingcontrol.0 (621912) UpdateDPs for Kinderzimmer starting
    2021-12-21 10:26:36.906 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Kinderzimmer starting 21°C
    2021-12-21 10:26:36.910 - debug: heatingcontrol.0 (621912) Schlafzimmer ### ChangeStatus HolidayPresent to false in starting
    2021-12-21 10:26:36.910 - debug: heatingcontrol.0 (621912) UpdateDPs for Schlafzimmer starting
    2021-12-21 10:26:36.928 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Schlafzimmer starting 21°C
    2021-12-21 10:26:36.932 - debug: heatingcontrol.0 (621912) Badezimmer oben ### ChangeStatus GuestsPresent to false in starting
    2021-12-21 10:26:36.932 - debug: heatingcontrol.0 (621912) UpdateDPs for Badezimmer oben starting
    2021-12-21 10:26:36.938 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Badezimmer oben starting 4.5°C
    2021-12-21 10:26:36.941 - debug: heatingcontrol.0 (621912) Badezimmer unten ### ChangeStatus GuestsPresent to false in starting
    2021-12-21 10:26:36.941 - debug: heatingcontrol.0 (621912) UpdateDPs for Badezimmer unten starting
    2021-12-21 10:26:36.947 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Badezimmer unten starting 4.5°C
    2021-12-21 10:26:36.951 - debug: heatingcontrol.0 (621912) Esszimmer ### ChangeStatus GuestsPresent to false in starting
    2021-12-21 10:26:36.951 - debug: heatingcontrol.0 (621912) UpdateDPs for Esszimmer starting
    2021-12-21 10:26:36.957 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Esszimmer starting 21°C
    2021-12-21 10:26:36.960 - debug: heatingcontrol.0 (621912) Flur unten ### ChangeStatus GuestsPresent to false in starting
    2021-12-21 10:26:36.961 - debug: heatingcontrol.0 (621912) UpdateDPs for Flur unten starting
    2021-12-21 10:26:36.966 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Flur unten starting 23°C
    2021-12-21 10:26:36.970 - debug: heatingcontrol.0 (621912) Gästezimmer ### ChangeStatus GuestsPresent to false in starting
    2021-12-21 10:26:36.970 - debug: heatingcontrol.0 (621912) UpdateDPs for Gästezimmer starting
    2021-12-21 10:26:36.977 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Gästezimmer starting 17°C
    2021-12-21 10:26:36.981 - debug: heatingcontrol.0 (621912) Kinderzimmer ### ChangeStatus GuestsPresent to false in starting
    2021-12-21 10:26:36.981 - debug: heatingcontrol.0 (621912) UpdateDPs for Kinderzimmer starting
    2021-12-21 10:26:36.987 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Kinderzimmer starting 21°C
    2021-12-21 10:26:36.990 - debug: heatingcontrol.0 (621912) Schlafzimmer ### ChangeStatus GuestsPresent to false in starting
    2021-12-21 10:26:36.990 - debug: heatingcontrol.0 (621912) UpdateDPs for Schlafzimmer starting
    2021-12-21 10:26:36.996 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Schlafzimmer starting 21°C
    2021-12-21 10:26:37.000 - debug: heatingcontrol.0 (621912) Badezimmer oben ### ChangeStatus PartyNow to false in starting
    2021-12-21 10:26:37.000 - debug: heatingcontrol.0 (621912) UpdateDPs for Badezimmer oben starting
    2021-12-21 10:26:37.007 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Badezimmer oben starting 4.5°C
    2021-12-21 10:26:37.011 - debug: heatingcontrol.0 (621912) Badezimmer unten ### ChangeStatus PartyNow to false in starting
    2021-12-21 10:26:37.011 - debug: heatingcontrol.0 (621912) UpdateDPs for Badezimmer unten starting
    2021-12-21 10:26:37.017 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Badezimmer unten starting 4.5°C
    2021-12-21 10:26:37.021 - debug: heatingcontrol.0 (621912) Esszimmer ### ChangeStatus PartyNow to false in starting
    2021-12-21 10:26:37.021 - debug: heatingcontrol.0 (621912) UpdateDPs for Esszimmer starting
    2021-12-21 10:26:37.027 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Esszimmer starting 21°C
    2021-12-21 10:26:37.030 - debug: heatingcontrol.0 (621912) Flur unten ### ChangeStatus PartyNow to false in starting
    2021-12-21 10:26:37.030 - debug: heatingcontrol.0 (621912) UpdateDPs for Flur unten starting
    2021-12-21 10:26:37.036 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Flur unten starting 23°C
    2021-12-21 10:26:37.040 - debug: heatingcontrol.0 (621912) Gästezimmer ### ChangeStatus PartyNow to false in starting
    2021-12-21 10:26:37.041 - debug: heatingcontrol.0 (621912) UpdateDPs for Gästezimmer starting
    2021-12-21 10:26:37.047 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Gästezimmer starting 17°C
    2021-12-21 10:26:37.050 - debug: heatingcontrol.0 (621912) Kinderzimmer ### ChangeStatus PartyNow to false in starting
    2021-12-21 10:26:37.050 - debug: heatingcontrol.0 (621912) UpdateDPs for Kinderzimmer starting
    2021-12-21 10:26:37.056 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Kinderzimmer starting 21°C
    2021-12-21 10:26:37.071 - debug: heatingcontrol.0 (621912) Schlafzimmer ### ChangeStatus PartyNow to false in starting
    2021-12-21 10:26:37.071 - debug: heatingcontrol.0 (621912) UpdateDPs for Schlafzimmer starting
    2021-12-21 10:26:37.077 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Schlafzimmer starting 21°C
    2021-12-21 10:26:37.080 - debug: heatingcontrol.0 (621912) Badezimmer oben ### ChangeStatus PublicHolidyToday to false in starting
    2021-12-21 10:26:37.080 - debug: heatingcontrol.0 (621912) UpdateDPs for Badezimmer oben starting
    2021-12-21 10:26:37.086 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Badezimmer oben starting 4.5°C
    2021-12-21 10:26:37.089 - debug: heatingcontrol.0 (621912) Badezimmer unten ### ChangeStatus PublicHolidyToday to false in starting
    2021-12-21 10:26:37.090 - debug: heatingcontrol.0 (621912) UpdateDPs for Badezimmer unten starting
    2021-12-21 10:26:37.097 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Badezimmer unten starting 4.5°C
    2021-12-21 10:26:37.101 - debug: heatingcontrol.0 (621912) Esszimmer ### ChangeStatus PublicHolidyToday to false in starting
    2021-12-21 10:26:37.101 - debug: heatingcontrol.0 (621912) UpdateDPs for Esszimmer starting
    2021-12-21 10:26:37.107 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Esszimmer starting 21°C
    2021-12-21 10:26:37.110 - debug: heatingcontrol.0 (621912) Flur unten ### ChangeStatus PublicHolidyToday to false in starting
    2021-12-21 10:26:37.110 - debug: heatingcontrol.0 (621912) UpdateDPs for Flur unten starting
    2021-12-21 10:26:37.116 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Flur unten starting 23°C
    2021-12-21 10:26:37.120 - debug: heatingcontrol.0 (621912) Gästezimmer ### ChangeStatus PublicHolidyToday to false in starting
    2021-12-21 10:26:37.120 - debug: heatingcontrol.0 (621912) UpdateDPs for Gästezimmer starting
    2021-12-21 10:26:37.125 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Gästezimmer starting 17°C
    2021-12-21 10:26:37.130 - debug: heatingcontrol.0 (621912) Kinderzimmer ### ChangeStatus PublicHolidyToday to false in starting
    2021-12-21 10:26:37.131 - debug: heatingcontrol.0 (621912) UpdateDPs for Kinderzimmer starting
    2021-12-21 10:26:37.136 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Kinderzimmer starting 21°C
    2021-12-21 10:26:37.140 - debug: heatingcontrol.0 (621912) Schlafzimmer ### ChangeStatus PublicHolidyToday to false in starting
    2021-12-21 10:26:37.141 - debug: heatingcontrol.0 (621912) UpdateDPs for Schlafzimmer starting
    2021-12-21 10:26:37.148 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Schlafzimmer starting 21°C
    2021-12-21 10:26:37.151 - debug: heatingcontrol.0 (621912) Badezimmer oben ### ChangeStatus MaintenanceActive to false in starting
    2021-12-21 10:26:37.151 - debug: heatingcontrol.0 (621912) UpdateDPs for Badezimmer oben starting
    2021-12-21 10:26:37.157 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Badezimmer oben starting 4.5°C
    2021-12-21 10:26:37.161 - debug: heatingcontrol.0 (621912) Badezimmer unten ### ChangeStatus MaintenanceActive to false in starting
    2021-12-21 10:26:37.161 - debug: heatingcontrol.0 (621912) UpdateDPs for Badezimmer unten starting
    2021-12-21 10:26:37.167 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Badezimmer unten starting 4.5°C
    2021-12-21 10:26:37.173 - debug: heatingcontrol.0 (621912) Esszimmer ### ChangeStatus MaintenanceActive to false in starting
    2021-12-21 10:26:37.173 - debug: heatingcontrol.0 (621912) UpdateDPs for Esszimmer starting
    2021-12-21 10:26:37.179 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Esszimmer starting 21°C
    2021-12-21 10:26:37.182 - debug: heatingcontrol.0 (621912) Flur unten ### ChangeStatus MaintenanceActive to false in starting
    2021-12-21 10:26:37.182 - debug: heatingcontrol.0 (621912) UpdateDPs for Flur unten starting
    2021-12-21 10:26:37.188 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Flur unten starting 23°C
    2021-12-21 10:26:37.193 - debug: heatingcontrol.0 (621912) Gästezimmer ### ChangeStatus MaintenanceActive to false in starting
    2021-12-21 10:26:37.194 - debug: heatingcontrol.0 (621912) UpdateDPs for Gästezimmer starting
    2021-12-21 10:26:37.204 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Gästezimmer starting 17°C
    2021-12-21 10:26:37.208 - debug: heatingcontrol.0 (621912) Kinderzimmer ### ChangeStatus MaintenanceActive to false in starting
    2021-12-21 10:26:37.208 - debug: heatingcontrol.0 (621912) UpdateDPs for Kinderzimmer starting
    2021-12-21 10:26:37.214 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Kinderzimmer starting 21°C
    2021-12-21 10:26:37.217 - debug: heatingcontrol.0 (621912) Schlafzimmer ### ChangeStatus MaintenanceActive to false in starting
    2021-12-21 10:26:37.217 - debug: heatingcontrol.0 (621912) UpdateDPs for Schlafzimmer starting
    2021-12-21 10:26:37.224 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Schlafzimmer starting 21°C
    2021-12-21 10:26:37.228 - info: heatingcontrol.0 (621912) checking external states done
    2021-12-21 10:26:37.229 - info: heatingcontrol.0 (621912) calculate current profile point for all rooms
    2021-12-21 10:26:37.229 - debug: heatingcontrol.0 (621912) get current profile
    2021-12-21 10:26:37.231 - debug: heatingcontrol.0 (621912) profile 1
    2021-12-21 10:26:37.231 - info: heatingcontrol.0 (621912) start calculate current profile point for profile type 1 (Mo - Su)
    2021-12-21 10:26:37.233 - debug: heatingcontrol.0 (621912) Badezimmer oben found profile point at Period 1 05:00 with 4.5
    2021-12-21 10:26:37.234 - debug: heatingcontrol.0 (621912) Badezimmer oben ### ChangeStatus ProfilPoint to -99 in starting
    2021-12-21 10:26:37.234 - debug: heatingcontrol.0 (621912) ChangeStatus Profilepoint in Badezimmer oben just recalc
    2021-12-21 10:26:37.234 - debug: heatingcontrol.0 (621912) UpdateDPs for Badezimmer oben starting
    2021-12-21 10:26:37.247 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Badezimmer oben starting 4.5°C
    2021-12-21 10:26:37.254 - info: heatingcontrol.0 (621912) start calculate current profile point for profile type 1 (Mo - Su)
    2021-12-21 10:26:37.255 - debug: heatingcontrol.0 (621912) Badezimmer unten found profile point at Period 1 05:00 with 4.5
    2021-12-21 10:26:37.255 - debug: heatingcontrol.0 (621912) Badezimmer unten ### ChangeStatus ProfilPoint to -99 in starting
    2021-12-21 10:26:37.256 - debug: heatingcontrol.0 (621912) ChangeStatus Profilepoint in Badezimmer unten just recalc
    2021-12-21 10:26:37.256 - debug: heatingcontrol.0 (621912) UpdateDPs for Badezimmer unten starting
    2021-12-21 10:26:37.263 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Badezimmer unten starting 4.5°C
    2021-12-21 10:26:37.266 - info: heatingcontrol.0 (621912) start calculate current profile point for profile type 1 (Mo - Su)
    2021-12-21 10:26:37.267 - debug: heatingcontrol.0 (621912) Esszimmer found profile point at Period 1 05:00 with 21
    2021-12-21 10:26:37.268 - debug: heatingcontrol.0 (621912) Esszimmer ### ChangeStatus ProfilPoint to -99 in starting
    2021-12-21 10:26:37.268 - debug: heatingcontrol.0 (621912) ChangeStatus Profilepoint in Esszimmer just recalc
    2021-12-21 10:26:37.268 - debug: heatingcontrol.0 (621912) UpdateDPs for Esszimmer starting
    2021-12-21 10:26:37.275 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Esszimmer starting 21°C
    2021-12-21 10:26:37.278 - info: heatingcontrol.0 (621912) start calculate current profile point for profile type 1 (Mo - Su)
    2021-12-21 10:26:37.279 - debug: heatingcontrol.0 (621912) Flur unten found profile point at Period 1 05:00 with 23
    2021-12-21 10:26:37.279 - debug: heatingcontrol.0 (621912) Flur unten ### ChangeStatus ProfilPoint to -99 in starting
    2021-12-21 10:26:37.279 - debug: heatingcontrol.0 (621912) ChangeStatus Profilepoint in Flur unten just recalc
    2021-12-21 10:26:37.279 - debug: heatingcontrol.0 (621912) UpdateDPs for Flur unten starting
    2021-12-21 10:26:37.286 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Flur unten starting 23°C
    2021-12-21 10:26:37.290 - info: heatingcontrol.0 (621912) start calculate current profile point for profile type 1 (Mo - Su)
    2021-12-21 10:26:37.291 - debug: heatingcontrol.0 (621912) try to convert 17.0 to a number
    2021-12-21 10:26:37.292 - debug: heatingcontrol.0 (621912) Gästezimmer found profile point at Period 1 05:00 with 17
    2021-12-21 10:26:37.292 - debug: heatingcontrol.0 (621912) Gästezimmer ### ChangeStatus ProfilPoint to -99 in starting
    2021-12-21 10:26:37.292 - debug: heatingcontrol.0 (621912) ChangeStatus Profilepoint in Gästezimmer just recalc
    2021-12-21 10:26:37.292 - debug: heatingcontrol.0 (621912) UpdateDPs for Gästezimmer starting
    2021-12-21 10:26:37.299 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Gästezimmer starting 17°C
    2021-12-21 10:26:37.302 - info: heatingcontrol.0 (621912) start calculate current profile point for profile type 1 (Mo - Su)
    2021-12-21 10:26:37.304 - debug: heatingcontrol.0 (621912) Kinderzimmer found profile point at Period 1 07:00 with 21
    2021-12-21 10:26:37.304 - debug: heatingcontrol.0 (621912) Kinderzimmer ### ChangeStatus ProfilPoint to -99 in starting
    2021-12-21 10:26:37.304 - debug: heatingcontrol.0 (621912) ChangeStatus Profilepoint in Kinderzimmer just recalc
    2021-12-21 10:26:37.304 - debug: heatingcontrol.0 (621912) UpdateDPs for Kinderzimmer starting
    2021-12-21 10:26:37.311 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Kinderzimmer starting 21°C
    2021-12-21 10:26:37.314 - info: heatingcontrol.0 (621912) start calculate current profile point for profile type 1 (Mo - Su)
    2021-12-21 10:26:37.315 - debug: heatingcontrol.0 (621912) Schlafzimmer found profile point at Period 1 07:00 with 21
    2021-12-21 10:26:37.315 - debug: heatingcontrol.0 (621912) Schlafzimmer ### ChangeStatus ProfilPoint to -99 in starting
    2021-12-21 10:26:37.315 - debug: heatingcontrol.0 (621912) ChangeStatus Profilepoint in Schlafzimmer just recalc
    2021-12-21 10:26:37.315 - debug: heatingcontrol.0 (621912) UpdateDPs for Schlafzimmer starting
    2021-12-21 10:26:37.332 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Schlafzimmer starting 21°C
    2021-12-21 10:26:37.335 - debug: heatingcontrol.0 (621912) Badezimmer oben: set new state auto
    2021-12-21 10:26:37.336 - debug: heatingcontrol.0 (621912) Badezimmer oben ### ChangeStatus ProfilPoint to -99 in auto
    2021-12-21 10:26:37.336 - debug: heatingcontrol.0 (621912) ChangeStatus Profilepoint in Badezimmer oben just recalc
    2021-12-21 10:26:37.336 - debug: heatingcontrol.0 (621912) CalculateRoomTemperature for Badezimmer oben auto
    2021-12-21 10:26:37.336 - debug: heatingcontrol.0 (621912) Badezimmer oben auto mode: target 4.5
    2021-12-21 10:26:37.336 - debug: heatingcontrol.0 (621912) Badezimmer oben auto mode (incl. reduced): target 4.5
    2021-12-21 10:26:37.337 - debug: heatingcontrol.0 (621912) SetRoomTemperature started for Badezimmer oben target 4.5 with offset 0
    2021-12-21 10:26:37.340 - debug: heatingcontrol.0 (621912) Badezimmer oben nothing to do to for hm-rpc.0.KEQ0574582.4.SET_TEMPERATURE , target 4.5 is already set 4.5
    2021-12-21 10:26:37.341 - debug: heatingcontrol.0 (621912) HandleActors for Badezimmer oben auto
    2021-12-21 10:26:37.341 - debug: heatingcontrol.0 (621912) UpdateDPs for Badezimmer oben auto
    2021-12-21 10:26:37.353 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Badezimmer oben auto 4.5°C
    2021-12-21 10:26:37.357 - debug: heatingcontrol.0 (621912) Badezimmer unten: set new state auto
    2021-12-21 10:26:37.357 - debug: heatingcontrol.0 (621912) Badezimmer unten ### ChangeStatus ProfilPoint to -99 in auto
    2021-12-21 10:26:37.357 - debug: heatingcontrol.0 (621912) ChangeStatus Profilepoint in Badezimmer unten just recalc
    2021-12-21 10:26:37.357 - debug: heatingcontrol.0 (621912) CalculateRoomTemperature for Badezimmer unten auto
    2021-12-21 10:26:37.357 - debug: heatingcontrol.0 (621912) Badezimmer unten auto mode: target 4.5
    2021-12-21 10:26:37.357 - debug: heatingcontrol.0 (621912) Badezimmer unten auto mode (incl. reduced): target 4.5
    2021-12-21 10:26:37.358 - debug: heatingcontrol.0 (621912) SetRoomTemperature started for Badezimmer unten target 4.5 with offset 0
    2021-12-21 10:26:37.361 - debug: heatingcontrol.0 (621912) Badezimmer unten nothing to do to for hm-rpc.0.LEQ1520473.4.SET_TEMPERATURE , target 4.5 is already set 4.5
    2021-12-21 10:26:37.362 - debug: heatingcontrol.0 (621912) HandleActors for Badezimmer unten auto
    2021-12-21 10:26:37.362 - debug: heatingcontrol.0 (621912) UpdateDPs for Badezimmer unten auto
    2021-12-21 10:26:37.370 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Badezimmer unten auto 4.5°C
    2021-12-21 10:26:37.373 - debug: heatingcontrol.0 (621912) Esszimmer: set new state auto
    2021-12-21 10:26:37.373 - debug: heatingcontrol.0 (621912) Esszimmer ### ChangeStatus ProfilPoint to -99 in auto
    2021-12-21 10:26:37.373 - debug: heatingcontrol.0 (621912) ChangeStatus Profilepoint in Esszimmer just recalc
    2021-12-21 10:26:37.374 - debug: heatingcontrol.0 (621912) CalculateRoomTemperature for Esszimmer auto
    2021-12-21 10:26:37.374 - debug: heatingcontrol.0 (621912) Esszimmer auto mode: target 21
    2021-12-21 10:26:37.374 - debug: heatingcontrol.0 (621912) Esszimmer auto mode (incl. reduced): target 21
    2021-12-21 10:26:37.377 - debug: heatingcontrol.0 (621912) SetRoomTemperature started for Esszimmer target 21 with offset 0
    2021-12-21 10:26:37.381 - debug: heatingcontrol.0 (621912) Esszimmer nothing to do to for hm-rpc.0.LEQ1520465.4.SET_TEMPERATURE , target 21 is already set 21
    2021-12-21 10:26:37.381 - debug: heatingcontrol.0 (621912) HandleActors for Esszimmer auto
    2021-12-21 10:26:37.381 - debug: heatingcontrol.0 (621912) UpdateDPs for Esszimmer auto
    2021-12-21 10:26:37.388 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Esszimmer auto 21°C
    2021-12-21 10:26:37.392 - debug: heatingcontrol.0 (621912) Flur unten: set new state auto
    2021-12-21 10:26:37.392 - debug: heatingcontrol.0 (621912) Flur unten ### ChangeStatus ProfilPoint to -99 in auto
    2021-12-21 10:26:37.392 - debug: heatingcontrol.0 (621912) ChangeStatus Profilepoint in Flur unten just recalc
    2021-12-21 10:26:37.392 - debug: heatingcontrol.0 (621912) CalculateRoomTemperature for Flur unten auto
    2021-12-21 10:26:37.392 - debug: heatingcontrol.0 (621912) Flur unten auto mode: target 23
    2021-12-21 10:26:37.392 - debug: heatingcontrol.0 (621912) Flur unten auto mode (incl. reduced): target 23
    2021-12-21 10:26:37.392 - debug: heatingcontrol.0 (621912) SetRoomTemperature started for Flur unten target 23 with offset 0
    2021-12-21 10:26:37.397 - debug: heatingcontrol.0 (621912) Flur unten nothing to do to for hm-rpc.0.OEQ0242950.4.SET_TEMPERATURE , target 23 is already set 23
    2021-12-21 10:26:37.397 - debug: heatingcontrol.0 (621912) HandleActors for Flur unten auto
    2021-12-21 10:26:37.397 - debug: heatingcontrol.0 (621912) UpdateDPs for Flur unten auto
    2021-12-21 10:26:37.404 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Flur unten auto 23°C
    2021-12-21 10:26:37.407 - debug: heatingcontrol.0 (621912) Gästezimmer: set new state auto
    2021-12-21 10:26:37.408 - debug: heatingcontrol.0 (621912) Gästezimmer ### ChangeStatus ProfilPoint to -99 in auto
    2021-12-21 10:26:37.408 - debug: heatingcontrol.0 (621912) ChangeStatus Profilepoint in Gästezimmer just recalc
    2021-12-21 10:26:37.408 - debug: heatingcontrol.0 (621912) CalculateRoomTemperature for Gästezimmer auto
    2021-12-21 10:26:37.408 - debug: heatingcontrol.0 (621912) Gästezimmer auto mode: target 17
    2021-12-21 10:26:37.408 - debug: heatingcontrol.0 (621912) Gästezimmer auto mode (incl. reduced): target 17
    2021-12-21 10:26:37.408 - debug: heatingcontrol.0 (621912) SetRoomTemperature started for Gästezimmer target 17 with offset 0
    2021-12-21 10:26:37.412 - debug: heatingcontrol.0 (621912) Gästezimmer nothing to do to for hm-rpc.0.MEQ0007312.4.SET_TEMPERATURE , target 17 is already set 17
    2021-12-21 10:26:37.412 - debug: heatingcontrol.0 (621912) HandleActors for Gästezimmer auto
    2021-12-21 10:26:37.412 - debug: heatingcontrol.0 (621912) UpdateDPs for Gästezimmer auto
    2021-12-21 10:26:37.418 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Gästezimmer auto 17°C
    2021-12-21 10:26:37.422 - debug: heatingcontrol.0 (621912) Kinderzimmer: set new state auto
    2021-12-21 10:26:37.422 - debug: heatingcontrol.0 (621912) Kinderzimmer ### ChangeStatus ProfilPoint to -99 in auto
    2021-12-21 10:26:37.422 - debug: heatingcontrol.0 (621912) ChangeStatus Profilepoint in Kinderzimmer just recalc
    2021-12-21 10:26:37.422 - debug: heatingcontrol.0 (621912) CalculateRoomTemperature for Kinderzimmer auto
    2021-12-21 10:26:37.422 - debug: heatingcontrol.0 (621912) Kinderzimmer auto mode: target 21
    2021-12-21 10:26:37.422 - debug: heatingcontrol.0 (621912) Kinderzimmer auto mode (incl. reduced): target 21
    2021-12-21 10:26:37.422 - debug: heatingcontrol.0 (621912) SetRoomTemperature started for Kinderzimmer target 21 with offset 0
    2021-12-21 10:26:37.430 - debug: heatingcontrol.0 (621912) Kinderzimmer nothing to do to for hm-rpc.0.LEQ1520877.4.SET_TEMPERATURE , target 21 is already set 21
    2021-12-21 10:26:37.430 - debug: heatingcontrol.0 (621912) HandleActors for Kinderzimmer auto
    2021-12-21 10:26:37.430 - debug: heatingcontrol.0 (621912) UpdateDPs for Kinderzimmer auto
    2021-12-21 10:26:37.446 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Kinderzimmer auto 21°C
    2021-12-21 10:26:37.449 - debug: heatingcontrol.0 (621912) Schlafzimmer: set new state auto
    2021-12-21 10:26:37.449 - debug: heatingcontrol.0 (621912) Schlafzimmer ### ChangeStatus ProfilPoint to -99 in auto
    2021-12-21 10:26:37.449 - debug: heatingcontrol.0 (621912) ChangeStatus Profilepoint in Schlafzimmer just recalc
    2021-12-21 10:26:37.449 - debug: heatingcontrol.0 (621912) CalculateRoomTemperature for Schlafzimmer auto
    2021-12-21 10:26:37.449 - debug: heatingcontrol.0 (621912) Schlafzimmer auto mode: target 21
    2021-12-21 10:26:37.450 - debug: heatingcontrol.0 (621912) Schlafzimmer auto mode (incl. reduced): target 21
    2021-12-21 10:26:37.450 - debug: heatingcontrol.0 (621912) SetRoomTemperature started for Schlafzimmer target 21 with offset 0
    2021-12-21 10:26:37.453 - debug: heatingcontrol.0 (621912) Schlafzimmer nothing to do to for hm-rpc.0.KEQ0574680.4.SET_TEMPERATURE , target 21 is already set 21
    2021-12-21 10:26:37.453 - debug: heatingcontrol.0 (621912) HandleActors for Schlafzimmer auto
    2021-12-21 10:26:37.454 - debug: heatingcontrol.0 (621912) UpdateDPs for Schlafzimmer auto
    2021-12-21 10:26:37.460 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Schlafzimmer auto 21°C
    2021-12-21 10:26:37.463 - info: heatingcontrol.0 (621912) statemachine started
    2021-12-21 10:26:47.981 - debug: heatingcontrol.0 (621912) ### handle state change acked hm-rpc.0.MEQ0029513.1.STATE {"val":true,"ack":true,"ts":1640078807979,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1640078807979}
    2021-12-21 10:26:47.981 - debug: heatingcontrol.0 (621912) HandleStateChangeDevices hm-rpc.0.MEQ0029513.1.STATE
    2021-12-21 10:26:47.981 - debug: heatingcontrol.0 (621912) CheckStateChangeDevice hm-rpc.0.MEQ0029513.1.STATE
    2021-12-21 10:26:47.981 - debug: heatingcontrol.0 (621912) handle sensor 0 hm-rpc.0.MEQ0029513.1.STATE, state auto, isOpen false, new state true, openDelay 0, closeDelay 0
    2021-12-21 10:26:47.981 - debug: heatingcontrol.0 (621912) Sensor state true ?= false
    2021-12-21 10:26:47.981 - debug: heatingcontrol.0 (621912) boolean: one window open in Esszimmer hm-rpc.0.MEQ0029513.1.STATE
    2021-12-21 10:26:47.982 - debug: heatingcontrol.0 (621912) Esszimmer ### ChangeStatus Sensor to {"OID":"hm-rpc.0.MEQ0029513.1.STATE","state":true} in auto
    2021-12-21 10:26:47.982 - debug: heatingcontrol.0 (621912) add new sensor state in Esszimmer hm-rpc.0.MEQ0029513.1.STATE true
    2021-12-21 10:26:47.982 - debug: heatingcontrol.0 (621912) Sensor state false ?= false
    2021-12-21 10:26:47.982 - debug: heatingcontrol.0 (621912) boolean: one window closed in Esszimmer hm-rpc.0.MEQ0028801.1.STATE
    2021-12-21 10:26:47.982 - debug: heatingcontrol.0 (621912) update state of hm-rpc.0.MEQ0029513.1.STATE to true
    2021-12-21 10:26:47.982 - debug: heatingcontrol.0 (621912) Sensor state true ?= false
    2021-12-21 10:26:47.982 - debug: heatingcontrol.0 (621912) boolean: one window open in Esszimmer hm-rpc.0.MEQ0029513.1.STATE
    2021-12-21 10:26:47.982 - debug: heatingcontrol.0 (621912) result for AddSensorState in Esszimmer is true
    2021-12-21 10:26:47.982 - debug: heatingcontrol.0 (621912) Change Status WindowOpen in Esszimmer to true
    2021-12-21 10:26:47.982 - debug: heatingcontrol.0 (621912) CalculateRoomTemperature for Esszimmer auto
    2021-12-21 10:26:47.982 - debug: heatingcontrol.0 (621912) Esszimmer auto mode: target 21
    2021-12-21 10:26:47.983 - debug: heatingcontrol.0 (621912) Esszimmer auto mode (incl. reduced): target 21
    2021-12-21 10:26:47.983 - debug: heatingcontrol.0 (621912) SetRoomTemperature started for Esszimmer target 21 with offset 0
    2021-12-21 10:26:47.987 - debug: heatingcontrol.0 (621912) Esszimmer nothing to do to for hm-rpc.0.LEQ1520465.4.SET_TEMPERATURE , target 21 is already set 21
    2021-12-21 10:26:47.987 - debug: heatingcontrol.0 (621912) HandleActors for Esszimmer auto
    2021-12-21 10:26:47.987 - debug: heatingcontrol.0 (621912) UpdateDPs for Esszimmer auto
    2021-12-21 10:26:47.999 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Esszimmer auto 21°C
    2021-12-21 10:26:58.157 - debug: heatingcontrol.0 (621912) ### handle state change acked hm-rpc.0.MEQ0029513.1.STATE {"val":false,"ack":true,"ts":1640078818156,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1640078818156}
    2021-12-21 10:26:58.157 - debug: heatingcontrol.0 (621912) HandleStateChangeDevices hm-rpc.0.MEQ0029513.1.STATE
    2021-12-21 10:26:58.158 - debug: heatingcontrol.0 (621912) CheckStateChangeDevice hm-rpc.0.MEQ0029513.1.STATE
    2021-12-21 10:26:58.158 - debug: heatingcontrol.0 (621912) handle sensor 0 hm-rpc.0.MEQ0029513.1.STATE, state auto, isOpen true, new state false, openDelay 0, closeDelay 0
    2021-12-21 10:26:58.158 - debug: heatingcontrol.0 (621912) Sensor state false ?= false
    2021-12-21 10:26:58.158 - debug: heatingcontrol.0 (621912) boolean: one window closed in Esszimmer hm-rpc.0.MEQ0029513.1.STATE
    2021-12-21 10:26:58.158 - debug: heatingcontrol.0 (621912) Esszimmer ### ChangeStatus Sensor to {"OID":"hm-rpc.0.MEQ0029513.1.STATE","state":false} in auto
    2021-12-21 10:26:58.158 - debug: heatingcontrol.0 (621912) add new sensor state in Esszimmer hm-rpc.0.MEQ0029513.1.STATE false
    2021-12-21 10:26:58.158 - debug: heatingcontrol.0 (621912) boolean: one window closed in Esszimmer hm-rpc.0.MEQ0028801.1.STATE
    2021-12-21 10:26:58.158 - debug: heatingcontrol.0 (621912) update state of hm-rpc.0.MEQ0029513.1.STATE to false
    2021-12-21 10:26:58.159 - debug: heatingcontrol.0 (621912) boolean: one window closed in Esszimmer hm-rpc.0.MEQ0029513.1.STATE
    2021-12-21 10:26:58.159 - debug: heatingcontrol.0 (621912) result for AddSensorState in Esszimmer is false
    2021-12-21 10:26:58.159 - debug: heatingcontrol.0 (621912) Change Status WindowOpen in Esszimmer to false
    2021-12-21 10:26:58.159 - debug: heatingcontrol.0 (621912) CalculateRoomTemperature for Esszimmer auto
    2021-12-21 10:26:58.159 - debug: heatingcontrol.0 (621912) Esszimmer auto mode: target 21
    2021-12-21 10:26:58.159 - debug: heatingcontrol.0 (621912) Esszimmer auto mode (incl. reduced): target 21
    2021-12-21 10:26:58.159 - debug: heatingcontrol.0 (621912) SetRoomTemperature started for Esszimmer target 21 with offset 0
    2021-12-21 10:26:58.164 - debug: heatingcontrol.0 (621912) Esszimmer nothing to do to for hm-rpc.0.LEQ1520465.4.SET_TEMPERATURE , target 21 is already set 21
    2021-12-21 10:26:58.164 - debug: heatingcontrol.0 (621912) HandleActors for Esszimmer auto
    2021-12-21 10:26:58.164 - debug: heatingcontrol.0 (621912) UpdateDPs for Esszimmer auto
    2021-12-21 10:26:58.177 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Esszimmer auto 21°C
    2021-12-21 10:27:08.833 - debug: heatingcontrol.0 (621912) ### handle state change acked hm-rpc.0.LEQ1520473.4.ACTUAL_TEMPERATURE {"val":22.9,"ack":true,"ts":1640078828831,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1640078669700}
    2021-12-21 10:27:08.833 - debug: heatingcontrol.0 (621912) HandleStateChangeDevices hm-rpc.0.LEQ1520473.4.ACTUAL_TEMPERATURE
    2021-12-21 10:27:08.833 - debug: heatingcontrol.0 (621912) CheckStateChangeDevice hm-rpc.0.LEQ1520473.4.ACTUAL_TEMPERATURE
    2021-12-21 10:27:08.833 - debug: heatingcontrol.0 (621912) Badezimmer unten ### ChangeStatus Thermostats_Current to {"val":22.9,"ack":true,"ts":1640078828831,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1640078669700} in auto
    2021-12-21 10:27:08.833 - debug: heatingcontrol.0 (621912) Change Status current temperature in Badezimmer unten to 22.9
    2021-12-21 10:27:08.833 - debug: heatingcontrol.0 (621912) HandleActors for Badezimmer unten auto
    2021-12-21 10:27:08.833 - debug: heatingcontrol.0 (621912) UpdateDPs for Badezimmer unten auto
    2021-12-21 10:27:08.842 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Badezimmer unten auto 4.5°C
    2021-12-21 10:27:08.861 - debug: heatingcontrol.0 (621912) ### handle state change acked hm-rpc.0.LEQ1520473.4.SET_TEMPERATURE {"val":4.5,"ack":true,"ts":1640078828860,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1640059200054}
    2021-12-21 10:27:08.861 - debug: heatingcontrol.0 (621912) HandleStateChangeDevices hm-rpc.0.LEQ1520473.4.SET_TEMPERATURE
    2021-12-21 10:27:08.861 - debug: heatingcontrol.0 (621912) CheckStateChangeDevice hm-rpc.0.LEQ1520473.4.SET_TEMPERATURE
    2021-12-21 10:27:08.861 - debug: heatingcontrol.0 (621912) Badezimmer unten ### ChangeStatus Thermostats_Target to {"val":4.5,"ack":true,"ts":1640078828860,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1640059200054} in auto
    2021-12-21 10:27:08.861 - debug: heatingcontrol.0 (621912) Change Status target temperature in Badezimmer unten to 4.5 (profile 4.5) in auto
    2021-12-21 10:27:08.861 - debug: heatingcontrol.0 (621912) CheckManualMode Badezimmer unten target 4.5 current manual target -99 state auto
    2021-12-21 10:27:08.862 - debug: heatingcontrol.0 (621912) CheckStartManualMode Badezimmer unten
    2021-12-21 10:27:08.862 - debug: heatingcontrol.0 (621912) UpdateDPs for Badezimmer unten auto
    2021-12-21 10:27:08.878 - debug: heatingcontrol.0 (621912) AddStatusToLog skip Badezimmer unten auto 4.5°C
    Rene_HMR
    Rene_HMR
    Rene_HM
    #2507
    @schuetzeschulz was steht hier?
    • P passuff
      @rene_hm
      alles klar.
      Neue Baustelle:
      Problem Nr1:
      Ich habe mir heute mal die Regelung in einem Raum angesehen und verstehe es nicht.
      Es gibt einen externen Temperatursensor sowie ein Homematic Thermostat.
      Folgende Einstellungen im Profil:
      Aktuell ist es 22:43 Uhr und somit sollte Periode "5" mit "20°C" aktiv sein. Ist Sie aber nicht:
      Problem Nr. 2:
      Current Target = 22°C
      Die aktuelle Temperatur des externen Sensors beträgt 22.5°C.
      Die aktuelle Temperatur des internen Sensors beträgt 23.3°C.
      Das Delta beträgt daher eigentlich 0.8°C.
      An das HM Thermostat würde ich eine Zieltemperatur von 22.8°C senden. Aktuell ist aber 22°C gesetzt.
      Nicht dass mich 0.8°C tatsächlich stören, aber mir geht es darum die Funktion zu verstehen...
      Rene_HMR
      Rene_HMR
      Rene_HM
      #2508
      @passuff sagte in Test Adapter HeatingControl v2.8.x:
      Laut Bild ist Periode 5 aktiv, Zieltemperatur (current Target) ist 20°C+2°C (also inkl. offset).
      Aus meiner Sicht passt das.
      und der Offset ist ein Mittelwert über die letzten Messungen. Bei dir ist der Offset aktuell 2°C und das wird auch an das Thermostat gesendet (siehe oben).
      Du kannst dir die gesamte Berechnung anschauen, wenn du mal debug-log für den Adapter anschaltest, da logge ich den kompletten Berechnungsprozess...
      P 1 Antwort Letzte Antwort
      • Rene_HMR Rene_HM
        P
        P
        passuff
        schrieb am zuletzt editiert von passuff
        #2509
        @rene_hm sagte in Test Adapter HeatingControl v2.8.x:
        Das debug log schaue ich mir mal an- danke für den Tipp.
        aus meiner Sicht ist das aber Käse.
        Ist (extern): 22.5°C
        Ist (intern) 23.3°C
        Fehler = 0.8°C
        Real ist es 0.8°C kälter als das Thermostat denkt.
        Um die Zieltemperatur von 20°C einzuregeln sollte ich doch 20.8°C an das Thermostat senden, oder sehe ich das falsch?
        (Im oberen Post habe ich gestern Abend leider fälschlicherweise 22.8°C geschrieben..)
        Rene_HMR 1 Antwort Letzte Antwort
        • Rene_HMR Rene_HM
          S
          S
          SchuetzeSchulz
          #2510
          Da ist der Haken gesetzt.
          • S SchuetzeSchulz
            Rene_HMR
            Rene_HMR
            Rene_HM
            #2511
            @schuetzeschulz damit schaltest du das Handling bzgl. Fenster offen vom Adapter aus (weil es macht ja das Thermostat selbst). Also: wenn der Adapter reduzieren soll, muss der Haken weg...
            • P passuff
              Ist (intern) 23.3°C
              Fehler = 0.8°C
              Rene_HMR
              Rene_HMR
              Rene_HM
              #2512
              nochmal: der Offset wird als Mittelwert berechnet. In deinem Fall hat sich der Offset auf 2°C eingeregelt. Aktuell sind es zwar 0,8°C, wir sehen aber die history der Werte nicht... Also wird 2°C höher geregelt (und nicht nur die 0,8°C die wir aktuell sehen)
              Dominik F.D P 2 Antworten Letzte Antwort
              • Rene_HMR Rene_HM
                S
                S
                SchuetzeSchulz
                #2513
                Das scheint es gewesen zu sein. Ich teste das mal.
                • Rene_HMR Rene_HM
                  Dominik F.D
                  Dominik F.D
                  Dominik F.
                  #2514
                  @rene_hm
                  Hey,
                  ich nutze deinen Adapter schon sehr lange und seit neuestem bekomme ich Warnmeldungen:
                  heatingcontrol.0
                  2021-12-22 13:35:25.562	warn	window sensor has no datatyp in Wohnzimmer (EG_Wohnzimmer_Terrassentür Is open), boolean used. Please check and save configuration
                  heatingcontrol.0
                  2021-12-22 13:35:25.562	warn	window sensor has no datatyp in Wohnzimmer (EG_Kaminzimmer_Fenster_Links Is open), boolean used. Please check and save configuration
                  heatingcontrol.0
                  2021-12-22 13:35:25.562	warn	window sensor has no datatyp in Wohnzimmer (EG_Kaminzimmer_Fenster_Rechts Is open), boolean used. Please check and save configuration
                  heatingcontrol.0
                  2021-12-22 13:35:25.562	warn	window sensor has no datatyp in Küche (EG_Küche_FensterRechts_Links Is open), boolean used. Please check and save configuration
                  heatingcontrol.0
                  2021-12-22 13:35:25.561	warn	window sensor has no datatyp in Küche (EG_Küche_FensterRechts_Rechts Is open), boolean used. Please check and save configuration
                  heatingcontrol.0
                  2021-12-22 13:35:25.561	warn	window sensor has no datatyp in Küche (EG_Küche_FensterLinks_Links Is open), boolean used. Please check and save configuration
                  heatingcontrol.0
                  2021-12-22 13:35:25.561	warn	window sensor has no datatyp in Küche (EG_Küche_FensterLinks_Rechts Is open), boolean used. Please check and save configuration
                  Ich habe die Konfiguration etc. mit anderen funktionierenden Fenstersensoren verglichen und finde keinen Unterschied in der Konfiguration und auch nicht in den Datenpunkten.
                  Hier ein Datenpunkt der als Warnung angezeigt wird:
                  Hier die Konfiguarion:
                  Hast du eventuell eine Idee?
                  • Dominik F.D Dominik F.
                    @rene_hm
                    Hey,
                    heatingcontrol.0
                    heatingcontrol.0
                    heatingcontrol.0
                    heatingcontrol.0
                    heatingcontrol.0
                    heatingcontrol.0
                    heatingcontrol.0
                    Rene_HMR
                    Rene_HMR
                    Rene_HM
                    #2515
                    @dominik-f sagte in Test Adapter HeatingControl v2.8.x:
                    Die Meldung kommt, weil ich irgendwann für die Sensoren den support verschiedener Datentypen eingebaut habe und gleichzeitig die aktuelle Konfiguration kompatibel machen wollte. Eigentlich sollte es reichen, einmal im Admin die Konfiguration zu speichern...
                    Wenn das nicht hilft, müssen wir genauer schauen. Das letzte Bild mit der Konfiguration der Sensoren ist genau was wir brauchen. Dort kann man die Datentypen umschalten. Vielleicht muss man einfach den Datentyp kurz ändern, damit dort gespeichert wird... Ich hoffe, die Sensor-Namen sind eindeutig und nicht evtl. doppelt verwendet?
                    • Rene_HMR Rene_HM
                      Dominik F.D
                      Dominik F.D
                      Dominik F.
                      #2516
                      @rene_hm
                      Das ändern des Datenpunkten zu Number und wieder zurück zu Boolean hat geholfen, Fehlermeldungen sind weg. Musste das für jeden Sensor machen.
                      Ich danke dir
                      • Rene_HMR Rene_HM
                        P
                        P
                        passuff
                        #2517
                        @rene_hm
                        OK, verstehe. Wie wird der Wert gemittelt?
                        Neue Beobachtung:
                        Wenn ich die Temperatur bei geöffnetem Fenster auf 12°C setze, wird die Temperatur als Sollwert übernommen. Ich möchte lediglich manuelle Eingriffe am Thermostat in das Profil übernehmen. Gibt es eine Möglichkeit dies so zu konfigurieren?
                        • C
                          C
                          ChrisXY
                          #2518
                          ich versuche gerade in der VIS Vorlage einen Regler einzubauen um am Handy auch ganz einfach die Temperatur einzustellen. Also wenn es jetzt doch mal was wärmer sein soll.
                          Mit welchem Wert Steuer ich dies am besten?
                          Über den Adapter ? Oder direkt am Thermostat SetTemperature ?
                          Oder arbeitet man hier mit offsets ?
                          Nutze das HQwidget dafür.
                          • Rene_HMR
                            Rene_HMR
                            Rene_HM
                            #2519
                            Im github und NPM liegt die 2.8.1 zum Testen bereit.
                            siehe auch github
                            Es gibt folgende Änderungen:
                            • im Raumstatus (html) wird nun die Temperatur vom externen Sensor und der aktuelle Offset angezeigt (siehe issue)
                            • der override wird nur verlängert, wenn eine geänderte Temperatur erkannt wird. Die gleiche Temperatur führt nicht mehr zu einer Verlängerung des overrides
                            • die verbleibende Override-Zeit wird auf 0 gesetzt, wenn der override abgebrochen wird
                            • das ack-Flag für geänderte Datenpunkte wird erst nach zwei Sekunden gesetzt. Das sollte anderen Adaptern (hmip o.ä.) genügend Zeit geben, ebenfalls auf die Änderung zu reagieren.
                            Feedback ist wie immer willkommen...
                            Übrigens: ich suche support bei der Erstellung bzw. Update der Dokumentation. Bei Interesse bitte melden...
                            • C ChrisXY
                              Rene_HMR
                              Rene_HMR
                              Rene_HM
                              #2520
                              @chrisxy sagte in Test Adapter HeatingControl v2.8.x:
                              aus meiner Sicht sollte man den SetTemperature verwenden. Das funktioniert dann ähnlich wie eine direkte Änderung am Thermostat. Mit der 2.8.1 sollte das dann auch wieder funktionieren, da bis 2.8.0 der Adapter das ack-Flag direkt gesetzt hat, was dann dazu geführt hat, dass z.Bsp. der hmip-Adapter die geänderten Daten nicht ans Thermostat gesendet hat, weil das ack schon gesetzt war und hmip dann nicht mehr reagiert...
                              • P passuff
                                @rene_hm
                                Neue Beobachtung:
                                Rene_HMR
                                Rene_HMR
                                Rene_HM
                                #2521
                                Das verstehe ich nicht... Wo änderst du die Temperatur? und wie soll der Adapter "manuelle" Eingriffe erkennen?
                                • Rene_HMR Rene_HM
                                  P
                                  P
                                  passuff
                                  #2522
                                  Der Adapter stellt bei geöffnetem Fenster auf 12 Grad . Das wird als override erkannt. Sollte so nicht sein, denke ich.
                                  • P passuff
                                    Rene_HMR
                                    Rene_HMR
                                    Rene_HM
                                    #2523
                                    @passuff nein, das sollte so nicht sein...
                                    Kannst du von dem Vorgang ein debug log erstellen?
                                    • Rene_HMR Rene_HM
                                      P
                                      P
                                      passuff
                                      #2524
                                      @rene_hm
                                      Würde dir das gerne per PM senden. Wie geht das? Finde nur so einen dämlichen Chat. Ich habe keine Möglichkeit gefunden dort eine Datei zu senden.
                                      Rene_HMR 2 Antworten Letzte Antwort
                                      • P passuff
                                        @rene_hm
                                        Rene_HMR
                                        Rene_HMR
                                        Rene_HM
                                        #2525
                                        @passuff habe dir eine PM mit der email-Adresse geschickt...
                                        • P passuff
                                          @rene_hm
                                          Rene_HMR
                                          Rene_HMR
                                          Rene_HM
                                          #2526
                                          @passuff kannst du mal die 2.8.2 versuchen, ob das Problem behoben ist?
                                          M M 2 Antworten Letzte Antwort
                                          33.2k
                                          84.3k
