  4. jarvis v3.0.0 - just another remarkable vis
    6.5k
4.5k Beiträge 254 Kommentatoren 3.1m Aufrufe 209 Beobachtet
  • sigi234S sigi234
    @zefau
    Seit Version 18 kommt das:
    jarvis.0
    2021-12-21 15:39:20.445	warn	alias.0.Geschirrspüler.BSH_Common_Command_PauseProgram is not a valid state
    jarvis.0
    2021-12-21 15:39:20.344	warn	alias.0.Geschirrspüler.BSH_Common_Command_ResumeProgram is not a valid state
    jarvis.0
    2021-12-21 15:39:20.276	warn	alias.0.Geschirrspüler.BSH_Common_Command_StopProgram is not a valid state
    jarvis.0
    2021-12-21 15:39:19.974	warn	http://192.168.178.20:8082/vis.0/yamaha-rx-v481.png is not a valid state
    jarvis.0
    2021-12-21 15:39:19.902	warn	tr-064.0.phonebook.number is not a valid state
    jarvis.0
    2021-12-21 15:39:19.814	warn	tr-064.0.phonebook.name is not a valid state
    jarvis.0
    2021-12-21 15:39:19.709	warn	tr-064.0.phonebook.image is not a valid state
    jarvis.0
    2021-12-21 15:39:19.703	warn	.ACTUAL is not a valid state
    jarvis.0
    2021-12-21 15:39:19.702	warn	.ACTUAL is not a valid state
    jarvis.0
    jarvis.0
    jarvis.0
    jarvis.0
    2021-12-21 15:39:19.701	warn	.ACTUAL is not a valid state
    jarvis.0
    2021-12-21 15:39:19.353	warn	.ACTUAL is not a valid state
    jarvis.0
    2021-12-21 15:39:19.298	warn	hue.0.Philips_hue.Alle.scene_nachtlicht is not a valid state
    jarvis.0
    2021-12-21 15:39:19.245	warn	hue.0.Philips_hue.Alle.scene_gedimmt is not a valid state
    jarvis.0
    2021-12-21 15:39:19.167	warn	hue.0.Philips_hue.Alle.scene_hell is not a valid state
    jarvis.0
    2021-12-21 15:39:19.086	warn	hue.0.Philips_hue.Alle.scene_frühlingsblüten is not a valid state
    jarvis.0
    2021-12-21 15:39:19.000	warn	hue.0.Philips_hue.Alle.scene_nordlichter is not a valid state
    jarvis.0
    2021-12-21 15:39:18.893	warn	hue.0.Philips_hue.Alle.scene_tropendämmerung is not a valid state
    jarvis.0
    2021-12-21 15:39:18.788	warn	hue.0.Philips_hue.Alle.scene_sonnenuntergang_savanne is not a valid state
    jarvis.0
    2021-12-21 15:39:18.706	warn	hue.0.Philips_hue.Alle.scene_energie_tanken is not a valid state
    jarvis.0
    2021-12-21 15:39:18.609	warn	hue.0.Philips_hue.Alle.scene_konzentrieren is not a valid state
    jarvis.0
    2021-12-21 15:39:18.438	warn	hue.0.Philips_hue.Alle.scene_lesen is not a valid state
    jarvis.0
    2021-12-21 15:39:18.308	warn	hue.0.Philips_hue.Alle.scene_entspannen is not a valid state
    jarvis.0
    2021-12-21 15:39:18.223	warn	hue.0.Philips_hue.Büro.scene_nachtlicht is not a valid state
    jarvis.0
    2021-12-21 15:39:18.142	warn	hue.0.Philips_hue.Büro.scene_frühlingsblüten is not a valid state
    jarvis.0
    2021-12-21 15:39:18.036	warn	hue.0.Philips_hue.Büro.scene_nordlichter is not a valid state
    jarvis.0
    2021-12-21 15:39:17.878	warn	hue.0.Philips_hue.Büro.scene_tropendämmerung is not a valid state
    jarvis.0
    2021-12-21 15:39:17.669	warn	hue.0.Philips_hue.Büro.scene_sonnenuntergang_savanne is not a valid state
    jarvis.0
    2021-12-21 15:39:17.541	warn	hue.0.Philips_hue.Büro.scene_energie_tanken is not a valid state
    jarvis.0
    2021-12-21 15:39:17.401	warn	hue.0.Philips_hue.Büro.scene_konzentrieren is not a valid state
    jarvis.0
    2021-12-21 15:39:17.302	warn	hue.0.Philips_hue.Büro.scene_lesen is not a valid state
    jarvis.0
    2021-12-21 15:39:17.175	warn	hue.0.Philips_hue.Büro.scene_entspannen is not a valid state
    jarvis.0
    2021-12-21 15:39:17.127	warn	hue.0.Philips_hue.Küche.scene_scene_storagescene_ is not a valid state
    jarvis.0
    2021-12-21 15:39:17.073	warn	hue.0.Philips_hue.Küche.scene_bewegung is not a valid state
    jarvis.0
    2021-12-21 15:39:17.023	warn	hue.0.Philips_hue.Küche.scene_scene_recoveryscene_ is not a valid state
    jarvis.0
    2021-12-21 15:39:16.946	warn	hue.0.Philips_hue.Küche.scene_nachtlicht is not a valid state
    jarvis.0
    2021-12-21 15:39:16.881	warn	hue.0.Philips_hue.Küche.scene_energie_tanken is not a valid state
    jarvis.0
    2021-12-21 15:39:16.830	warn	hue.0.Philips_hue.Küche.scene_hell is not a valid state
    jarvis.0
    2021-12-21 15:39:16.771	warn	hue.0.Philips_hue.Küche.scene_lesen is not a valid state
    jarvis.0
    2021-12-21 15:39:16.715	warn	hue.0.Philips_hue.Küche.scene_gedimmt_küche is not a valid state
    jarvis.0
    2021-12-21 15:39:16.622	warn	hue.0.Philips_hue.Küche.scene_entspannen is not a valid state
    jarvis.0
    2021-12-21 15:39:16.544	warn	hue.0.Philips_hue.Küche.scene_konzentrieren_küche is not a valid state
    jarvis.0
    2021-12-21 15:39:16.488	warn	hue.0.Philips_hue.Küche.scene_frühlingsblüten is not a valid state
    jarvis.0
    2021-12-21 15:39:16.440	warn	hue.0.Philips_hue.Küche.scene_sonnenuntergang_savanne is not a valid state
    jarvis.0
    2021-12-21 15:39:16.392	warn	hue.0.Philips_hue.Küche.scene_tropendämmerung is not a valid state
    jarvis.0
    2021-12-21 15:39:16.340	warn	hue.0.Philips_hue.Bad_Room.scene_gedimmt_bad is not a valid state
    jarvis.0
    2021-12-21 15:39:16.293	warn	hue.0.Philips_hue.Bad_Room.scene_hell_bad is not a valid state
    jarvis.0
    2021-12-21 15:39:16.237	warn	hue.0.Philips_hue.Bad_Room.scene_nachtlicht_bad is not a valid state
    jarvis.0
    2021-12-21 15:39:16.166	warn	http://192.168.178.20:8082/vis.0/VU_analog.gif is not a valid state
    Ebenso kommt bei den Bar Charts das : (bei mouseover in den Balken)
    M Online
    M Online
    MCU
    #280
    @sigi234 Welches Hintergrundbild nutzt du?
    • M MCU
      sigi234S Online
      sigi234S Online
      #281
      @mcu sagte in jarvis v3.0.0 (beta) - just another remarkable vis:
      background-image: url("https://images.hdqwalls.com/download/black-gradient-b9-1920x1080.jpg");
      • M MCU
        @j1s2e3
        Da muss ein boolean rein, da der Datenpunkt Anzeige ja ein boolean ist:
        {"false":"aus","true":"an"}
        Wie sind die Einstellungen zur SwitchAction?
        j1s2e3
        #282
        @mcu said in jarvis v3.0.0 (beta) - just another remarkable vis:
        @j1s2e3
        Sorry, habe den falschen Screenshot erwischt. Das hatte ich auch schon angepasst. Habe vorher schon alles mögliche ausprobiert. D.h. die Booleanvariante unter Anzeigevariante ist so drin, und geht trotzdem nicht.
        Default. Habe nix dran geändert.
        • J j1s2e3
          @j1s2e3
          M Online
          M Online
          MCU
          #283
          @j1s2e3 Das sollte so aussehen:
          Mach mal bitte ein Upload von jarvis:
          iobroker upload jarvis
          aus der console
          Welche Version? v3.0.0-beta.18
          J 2 Antworten Letzte Antwort
          • M MCU
            @j1s2e3 Web-Adapter neugestartet?
            j1s2e3
            #284
            Nee hatte ich nicht. Eben probiert, nach F5 in Jarvis dauert es jetzt ca. 10 Sekunden bis Sonnenauf- und Sonnenuntergang angezeigt werden. Kalendarwoche ist sofort da.
            • M MCU
              aus der console
              j1s2e3
              #285
              aus der console
              v3.0.0-beta.18
              iobroker upload habe ich gemacht. Dann iobroker neu gestartet. Alles beim alten. Geht nicht.
              Dann habe ich den DP on_on gelöscht und neu angelegt. SwitchAction->Einstellungen sieht jetzt so aus:
              Immerhin habe ich jetzt 2 Auswahlmöglichkeiten für den Datenpunktwert im Dropdownmenu.
              • J j1s2e3
                aus der console
                v3.0.0-beta.18
                j1s2e3
                #286
                @MCU
                Jarvis-Update mache ich immer so ^^^
                Und noch eine Info. Ich hatte vorher Jarvis V2 am laufen. Evtl. ist beim Update/Konvertieren irgendwas schief gelaufen???
                • J j1s2e3
                  @MCU
                  M Online
                  M Online
                  MCU
                  #287
                  @j1s2e3 Das Update passt schon so. Upload auf der console hast du auch gemacht?
                  Hat mit der Umsetzung v2-> v3 nichts zu tun.
                  • M MCU
                    j1s2e3
                    schrieb am zuletzt editiert von j1s2e3
                    #288
                    Ja, habe das upload gemacht:
                    root@pi:/opt/iobroker# iobroker upload jarvis
                    upload [15] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/zefau.jpg zefau.jpg image/jpeg
                    upload [14] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/words.js words.js application/javascript
                    upload [13] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/jarvis.png jarvis.png image/png
                    upload [12] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/index_m.html index_m.html text/html
                    upload [11] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                    upload [10] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                    upload [9] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                    upload [8] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                    upload [7] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                    upload [6] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/it/translations.json i18n/it/translations.json application/json
                    upload [5] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                    upload [4] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/es/translations.json i18n/es/translations.json application/json
                    upload [3] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/en/translations.json i18n/en/translations.json application/json
                    upload [2] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/de/translations.json i18n/de/translations.json application/json
                    upload [1] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/admin.js admin.js application/javascript
                    upload [0] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/admin.css admin.css text/css
                    upload [100] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/img/moon_24.3f480ec5.png img/moon_24.3f480ec5.png image/png
                    upload [90] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/img/moon_15.a88798db.png img/moon_15.a88798db.png image/png
                    upload [80] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/icons/web/icon-512-maskable.png icons/web/icon-512-maskable.png image/png
                    upload [70] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/icons/ios/AppIcon@2x.png icons/ios/AppIcon@2x.png image/png
                    upload [60] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/icons/ios/AppIcon-29@2x~ipad.png icons/ios/AppIcon-29@2x~ipad.png image/png
                    upload [50] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/icons/icon-192x192.png icons/icon-192x192.png image/png
                    upload [40] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/icons/android/res/mipmap-xxhdpi/ic_launcher.png icons/android/res/mipmap-xxhdpi/ic_launcher.png image/png
                    upload [30] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/icons/android/res/mipmap-anydpi-v26/ic_launcher.xml icons/android/res/mipmap-anydpi-v26/ic_launcher.xml application/xml
                    upload [20] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/icon-128x128.png icon-128x128.png image/png
                    upload [19] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/icon-1024x1024.png icon-1024x1024.png image/png
                    upload [18] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/fonts/materialdesignicons-webfont.606b1642.woff2 fonts/materialdesignicons-webfont.606b1642.woff2 font/woff2
                    upload [17] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/fonts/materialdesignicons-webfont.5dff34d5.woff fonts/materialdesignicons-webfont.5dff34d5.woff font/woff
                    upload [16] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/fonts/flUhRq6tzZclQEJ-Vdg-IuiaDsNcIhQ8tQ.cf9862e8.woff2 fonts/flUhRq6tzZclQEJ-Vdg-IuiaDsNcIhQ8tQ.cf9862e8.woff2 font/woff2
                    upload [15] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/fonts/flUhRq6tzZclQEJ-Vdg-IuiaDsNa.40fa1be9.woff fonts/flUhRq6tzZclQEJ-Vdg-IuiaDsNa.40fa1be9.woff font/woff
                    upload [14] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/fonts/KFOmCnqEu92Fr1Mu4mxM.9b78ea3b.woff fonts/KFOmCnqEu92Fr1Mu4mxM.9b78ea3b.woff font/woff
                    upload [13] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/fonts/KFOlCnqEu92Fr1MmYUtfBBc-.b555d228.woff fonts/KFOlCnqEu92Fr1MmYUtfBBc-.b555d228.woff font/woff
                    upload [12] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/fonts/KFOlCnqEu92Fr1MmWUlfBBc-.0344cc3c.woff fonts/KFOlCnqEu92Fr1MmWUlfBBc-.0344cc3c.woff font/woff
                    upload [11] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/fonts/KFOlCnqEu92Fr1MmSU5fBBc-.877b9231.woff fonts/KFOlCnqEu92Fr1MmSU5fBBc-.877b9231.woff font/woff
                    upload [10] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/fonts/KFOlCnqEu92Fr1MmEU9fBBc-.ddd11dab.woff fonts/KFOlCnqEu92Fr1MmEU9fBBc-.ddd11dab.woff font/woff
                    upload [9] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/fonts/KFOkCnqEu92Fr1MmgVxIIzQ.9391e6e2.woff fonts/KFOkCnqEu92Fr1MmgVxIIzQ.9391e6e2.woff font/woff
                    upload [8] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/favicon.ico favicon.ico image/vnd.microsoft.icon
                    upload [7] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/css/vendor.2d4cce86.css css/vendor.2d4cce86.css text/css
                    upload [6] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/css/app.b35c1dd2.css css/app.b35c1dd2.css text/css
                    upload [5] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/css/5.b4273620.css css/5.b4273620.css text/css
                    upload [4] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/css/4.16536d15.css css/4.16536d15.css text/css
                    upload [3] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/css/3.1d9edfe1.css css/3.1d9edfe1.css text/css
                    upload [2] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/css/1.2364fbbf.css css/1.2364fbbf.css text/css
                    upload [1] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/apple-touch-icon.png apple-touch-icon.png image/png
                    upload [0] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/apple-icon-120x120.png apple-icon-120x120.png image/png
                    ... das kaum raus.
                    Danach service iobroker restart.
                    • J j1s2e3
                      ... das kaum raus.
                      M Online
                      M Online
                      MCU
                      #289
                      @j1s2e3 Cache im Browser gelöscht? Und dann bin ich draussen.
                      Cache im Web-Adapter ist aus?
                      • M MCU
                        j1s2e3
                        #290
                        Cache gelöscht -> keine Änderung. Switch geht nicht und unter SwitchAction->Einstellung gibt es nur das config#componentOptions#_all#val#options#val
                        Anderen Browser probiert -> das gleiche
                        Nochmal neuen DP angelegt, SwitchAction ausgewählt, Einstellungen wie gehabt. Rohwert(val) sehe ich nicht.
                        Cache im Webadapter ist aus
                        • J j1s2e3
                          M Online
                          M Online
                          MCU
                          #291
                          @j1s2e3 Das muss sich @zefau selbst anschauen.
                          U 1 Antwort Letzte Antwort
                          • M MCU
                            U Offline
                            U Offline
                            uwe72
                            #292
                            @Zefau Bin grad dran am Pro-Abo abschließen. Der Pro Account ist verknüpft an eine Linux-ID. Werden in 2-3 Wochen den Server austauschen. Kriegen wir den Pro-Account dann umgebogen auf das neue System?
                            U ZefauZ 2 Antworten Letzte Antwort
                            • U uwe72
                              U Offline
                              U Offline
                              uwe72
                              schrieb am zuletzt editiert von uwe72
                              #293
                              Frage: Hab gerade meine VIS von V2 auf V3 migriert. Habe große HTML-Tabellen. In V2 wurde die sauber dargestellt.
                              In V3 habe ich den komischen Effekt, dass die Tabelle sehr klein wird wenn ich das Fenster groß ziehen. Kann mir jemand einen Tipp geben?
                              • U uwe72
                                M Online
                                M Online
                                MCU
                                #294
                                @uwe72 Nimm mal die Scale contents to fit widget raus:
                                ausschalten
                                Sind das eigene HTML-Tabellen, die selbst erstellt werden?
                                • M MCU
                                  ausschalten
                                  U Offline
                                  U Offline
                                  uwe72
                                  #295
                                  @mcu hat funktioniert. Danke!
                                  Ja, ist in Iobroker selber geschriebenes HTML in JavaScript
                                  • U uwe72
                                    ZefauZ Offline
                                    ZefauZ Offline
                                    Zefau
                                    #296
                                    @uwe72 sagte in jarvis v3.0.0 (beta) - just another remarkable vis:
                                    Wie kommst du darauf? Ist nicht verknüpft.
                                    M U 2 Antworten Letzte Antwort
                                    • ZefauZ Zefau
                                      M Online
                                      M Online
                                      MCU
                                      #297
                                      @zefau
                                      Der Pro-Account ist doch an die ioBrokerID geknüpft?
                                      Wenn das komplette ioBroker-System, durch ein Restore vom "alten" System auf ein neues Hardwaresystem gespielt wird, hat dann ioBroker noch die gleiche ioBrokerID?
                                      Und ist somit die Pro-Lizenz (jarvis) dann noch gültig?
                                      • ZefauZ Zefau
                                        U Offline
                                        U Offline
                                        uwe72
                                        #298
                                        @zefau ich meine dies hier:
                                        Siehe unten links in gelb.
                                        • M MCU
                                          @zefau
                                          U Offline
                                          U Offline
                                          uwe72
                                          #299
                                          @mcu
                                          Auf das wollte ich mich in meinem Fall sowieso nicht verlassen. Wird komplett neu aufgesetzt, dieses mal mit docker.
                                          R 1 Antwort Letzte Antwort
