  4. [Frage] Xiaomi Vacuum cleaner
    6.3k
2.2k Beiträge 204 Kommentatoren 1.2m Aufrufe 39 Beobachtet
    skorpil
    #288
    Gerhard,
    Update gerade durchgeführt. Im log steht jetzt:
    mihome-vacuum.0	2017-03-10 16:01:22.861	info	Empfangen <<< Helo <<< 2131002000000000034c8a8258c2bfc2ffffffffffffffffffffffffffffffff
    mihome-vacuum.0	2017-03-10 16:01:02.788	info	Empfangen <<< Helo <<< 2131002000000000034c8a8258c2bfaeffffffffffffffffffffffffffffffff
    mihome-vacuum.0	2017-03-10 16:00:42.822	info	Empfangen <<< Helo <<< 2131002000000000034c8a8258c2bf9affffffffffffffffffffffffffffffff
    mihome-vacuum.0	2017-03-10 16:00:22.744	info	Empfangen <<< Helo <<< 2131002000000000034c8a8258c2bf86ffffffffffffffffffffffffffffffff
    mihome-vacuum.0	2017-03-10 16:00:02.779	info	Empfangen <<< Helo <<< 2131002000000000034c8a8258c2bf72ffffffffffffffffffffffffffffffff
    mihome-vacuum.0	2017-03-10 15:59:42.812	info	Empfangen <<< Helo <<< 2131002000000000034c8a8258c2bf5effffffffffffffffffffffffffffffff
    Und im Gegensatz zu gestern sehe ich jetzt Werte find und Pause vacuum
    mihome-vacuum.upload	0	false	 	2017-03-09 19:48:19.214	2017-02-06 15:57:47.347
    mihome-vacuum.0.level	Power level 1-3	Power level 1-3
    mihome-vacuum.0.state	Start/pause	Start/pause
    mihome-vacuum.0.find	Find	Find	false	true	mihome-vacuum.0	2017-03-09 23:55:50.578	2017-03-09 23:55:50.578
    mihome-vacuum.0.home	Go home	Go home
    mihome-vacuum.0.pause	Pause vacuum	Pause vacuum	false	true	mihome-vacuum.0	2017-03-09 23:58:04.802	2017-03-09 23:58:04.802
    mihome-vacuum.0.start	Start vacuum	Start vacuum
    mihome-vacuum.0.info.connection	If connected to CUL	If connected to CUL	true	true	mihome-vacuum.0	2017-03-10 15:57:22.888	2017-03-10 15:57:22.888
    system.adapter.mihome-vacuum.0.uptime	mihome-vacuum.0	mihome-vacuum.0.uptime	362	true	mihome-vacuum.0	2017-03-10 16:03:22.872	2017-03-10 16:03:22.872
    system.adapter.mihome-vacuum.0.memRss	mihome-vacuum.0	mihome-vacuum.0.memRss	27.7	true	mihome-vacuum.0	2017-03-10 16:03:22.871	2017-03-10 16:02:52.860
    system.adapter.mihome-vacuum.0.memHeapTotal	mihome-vacuum.0	mihome-vacuum.0.memHeapTotal	17.26	true	mihome-vacuum.0	2017-03-10 16:03:22.872	2017-03-10 15:57:22.749
    system.adapter.mihome-vacuum.0.memHeapUsed	mihome-vacuum.0	mihome-vacuum.0.memHeapUsed	10.58	true	mihome-vacuum.0	2017-03-10 16:03:22.872	2017-03-10 16:03:22.872
    system.adapter.mihome-vacuum.0.connected	mihome-vacuum.0	mihome-vacuum.0.connected	true	true	mihome-vacuum.0	2017-03-10 16:03:22.871	2017-03-10 15:57:22.748
    system.adapter.mihome-vacuum.0.alive	mihome-vacuum.0
    Ich steuere mit der Mihome App vom iPad aus. Habe noch kein State via iobroker versucht.
    Hilft Dir das?
    Liebe Grüße
    Bernd
    • G Offline
      gst666
      #289
      Hallo Bernd,
      das Log sagt eigentlich nur aus, dass Du keine Befehle an den Robo schickst. Die Meldungen, die Du im Log hast, stammen von dem zyklischen Ping. Da ich kein Sendehinweis eingebaut habe, kann man sehen, dass sie vom Ping stammen.
      Wie steuerst Du denn den Robo aus dem ioBroker? Über das Widget?
      Gruß Gerhard
        skorpil
        #290
        @gst666:
        Hallo Bernd,
        Gruß Gerhard `
        Gerhard,
        Noch steuere ich gar nicht über iobroker. Ich wollte morgen eine kleine Java Skript schreiben und dann Steuern. Widgets nutze ich bisher gar nicht.
        Liebe Grüße
        Bernd
        • MeistertrM Offline
          MeistertrM Offline
          Meistertr
          #291
          so habe mal den log beobachtet:
          mihome-vacuum.0	2017-03-10 19:43:20.262	info	Sende >>> {"id":6,"method":"app_pause"} >>> 213100400000000002f20d8f58c301d7ccda4da2178777d10d8b0a1c6f6b6d46ca234bcde27115e6d3ffba48b703ac9d910b8e53c3baf8ed258bf437eaa0eaf1
          mihome-vacuum.0	2017-03-10 19:43:20.258	info	Empfangen <<< Helo <<< 213100200000000002f20d8f58c301d7ffffffffffffffffffffffffffffffff
          mihome-vacuum.0	2017-03-10 19:43:19.928	info	Sende >>> Helo >>> 21310020ffffffffffffffffffffffffffffffffffffffffffffffffffffffff
          mihome-vacuum.0	2017-03-10 19:43:18.808	info	Sende >>> {"id":5,"method":"app_start"} >>> 213100400000000002f20d8f58c301d6352ee03773c1eab4c26f29b008bfd857b9c3d398545323ef1dd05e98602816050a3ad59e81fdffb5a405e17aac5ad1c7
          mihome-vacuum.0	2017-03-10 19:43:18.805	info	Empfangen <<< Helo <<< 213100200000000002f20d8f58c301d6ffffffffffffffffffffffffffffffff
          mihome-vacuum.0	2017-03-10 19:43:18.770	info	Sende >>> Helo >>> 21310020ffffffffffffffffffffffffffffffffffffffffffffffffffffffff
          mihome-vacuum.0	2017-03-10 19:43:17.791	info	Sende >>> {"id":4,"method":"app_charge"} >>> 213100400000000002f20d8f58c301d5c20ea8582acb38933967c80b56390a1b3f04e54cb0ae7ddd7fa6ff873345029c6ffdb3b1405c9bc403225efeff6c837a
          mihome-vacuum.0	2017-03-10 19:43:17.789	info	Empfangen <<< Helo <<< 213100200000000002f20d8f58c301d5ffffffffffffffffffffffffffffffff
          mihome-vacuum.0	2017-03-10 19:43:17.472	info	Sende >>> Helo >>> 21310020ffffffffffffffffffffffffffffffffffffffffffffffffffffffff
          Die komandos sind alle richtig, erreichbar ist der robby auch er antwortet ja auf HELO. Habe versucht die Nachrichten mit dem script wieder zu entcrypten, leider keine chance.
          • G Offline
            gst666
            #292
            Danke @Meistertr
            Das hat mir schon etwas geholfen. Offensichtlich stimmt etwas nicht mit der Verschlüsselung. In einer früheren Version sah das Ergebnis anders aus. Ich muss mir mal die Verschlüsselungsroutine noch mal genauer anschauen.
            • G Offline
              gst666
              #293
              Gute und schlechte Nachrichten:
              Die Gute: Die Verschlüsselung ist zum Glück nicht das Problem.
              Die Schlechte: Ich weiß nicht, wo das Problem zur Zeit liegt.
              Die im Debug angezeigten Nachrichten konnten nicht decodier werden, da das Log die Nachricht abgeschnitten hat. Grrgh. Hat mich viel zeit gekostet.
              Habe jetzt die Nachrichten in zwei Zeilen aufgeteilt, so dass das Problem seltener auftreten dürfte.
              Nur wo liegt das Problem: Hier gibt es nur noch zwei denkbare Stellen:
              Timestamp und ID.
              Als Timestamp verwende ich den Timestamp aus dem Helo-Paket. Hatte bislang funktioniert. Warum denn jetzt nicht mehr.
              Also ist die wahrscheinlichste Ursache die ID. In den Nachrichten, die ich habe, beginnen sie mit 6000. Vielleicht muss sie bei dem Robot 4-stellig sein? Wer weiß. Habe das mal testweise geändert. Wenn sich jemand zum Testen opfern würde, wäre es prima.
                MeistertrM Offline
                Meistertr
                #294
                Mach ich nachher. Habe gestern leider mein Testsystem zerschossen. Muss gleich noch neu aufsetzen. Aus welcher Funktion wird die decodierungsfunc. Aufgerufen? Konnte das nirgendwo finden…
                Gesendet von meinem E5823 mit Tapatalk
                • G Offline
                  gst666
                  #295
                  Such mal nach GetPlainData() in main.js
                    mayer
                    #296
                    Empfangen <<< Helo <<< 2131002000000000034cce9258c3dd52ffffffffffffffffffffffffffffffff
                    info	>>> 2131005000000000034cce9258c3dd50eb0c4d40cfa09c0b16e1f342d3643b83485ac6f0a9674e825a05e4d1e3161339d4bdb67d611407aaae26c0203468d948f5207261187e8442b0541a6cb42f8228
                    info	Sende >>> {"id":6431,"method":"find_me","params":[""]}
                    Habe mal getestet. Leider keine Reaktion vom Robot.
                    • G Offline
                      gst666
                      #297
                      Die verschlüsselten Daten scheinen richtig zu sein. Da ich mir ein solches Gerät immer noch nicht geleistet habe, benötige ich Eure Hilfe:
                      Bitte schickt mir per PM eine aktuelle Kommunikation zwischen Handy App und Robo nebst Token zu. Vielleicht komme ich dann dahinter, woran es hakt.
                      Danke, Gerhard
                      • bahnuhrB Online
                        bahnuhrB Online
                        bahnuhr
                        #298
                        cd /opt/iobroker
                        npm i https://github.com/ioBroker/ioBroker.mihome-vacuum/tarball/dev
                        Habe wie das von bluefox geschrieben wurde mal installiert.
                        Es kamen Fehlermeldungen.
                        filename="bild1.jpg" index="0">~~
                        Und dann die instanz erstellt.
                        Daten eingegeben und gespeichert. Die Instanz wird nicht grün, es bleibt bei gelb.
                        Liegt es an win7 ?
                        mfg
                        Danke.
                        • G Offline
                          gst666
                          #299
                          Gelb bedeutet, dass der Adapter zwar läuft, es aber keine Verbindung hergestellt werden konnte.
                          Das könnte drei Gründe haben:
                          1. falsche IP
                          2. DGRAM nicht richtig installiert
                          3. Firewall funkt dazwischen
                          Versuche mal einen ping von der Komandozeile aus. Wenn das nicht geht, ist es die IP
                          • bahnuhrB Online
                            bahnuhrB Online
                            bahnuhr
                            #300
                            falsche ip: glaub ich eigentlich nicht.
                            In der fritzbox hab ich feste ip vergeben.
                            Diese eingegeben bei instanz.
                            filename="bild2.jpg" index="0">~~
                            und ping funktioniert doch auch:
                            filename="bild1.jpg" index="1">~~
                            zu 2:
                            Was ist dgram ??
                            Was sagen die anderen Fehler, z.B.
                            python nicht installiert, etc…..
                            Danke.
                            • G Offline
                              gst666
                              #301
                              So wie es aussieht benötigt DGRAM Python bei der Installation unter Windows. DGRAM ist die Kommunikationsbibliothek. Versuche doch bitte mal Python zu installieren um dann noch mal den Adapter zu installieren. Eventuell fehlen aber noch weitere Build Tools.
                              • bahnuhrB Online
                                bahnuhrB Online
                                bahnuhr
                                #302
                                @gst66
                                ok, dann muss ich aussteigen.
                                Wenn ich nicht genau weiß, was ich wie wo eingeben soll, dann komm ich nicht weiter.
                                Bisher ist mihome auf der instanz gelb.
                                mfg
                                Danke.
                                • G Offline
                                  gst666
                                  #303
                                  Du musst Python von der Webseite python.org installieren und dann den Adapter löschen und neu installieren.
                                  • bahnuhrB Online
                                    bahnuhrB Online
                                    bahnuhr
                                    #304
                                    python hab ich doch drauf (dachte ich jedenfalls).
                                    Hab doch mit dem xpn.py rum experimentiert. Hat ja fast alles geklappt. (-h, -info, etc.). Nur der Robo ist nicht angesprungen.
                                    Die Installation des app "mihome" erkennt aber nun python nicht.
                                    Warum nicht ?
                                    Ich hab keine Ahnung.
                                    Fazit:
                                    python war installiert.
                                    npm i mihome….. erkennt python nicht ????
                                    mfg
                                    Danke.
                                      #305
                                      puthon 2.7 oder python 3.0???
                                      du benötigst 2.7!
                                        skorpil
                                        #306
                                        Ich bin leider heute Abend nicht zu hause u. kann mit meinem Raspi keine konstruktiven Beiträge leisten. [emoji42]
                                        • bahnuhrB Online
                                          bahnuhrB Online
                                          bahnuhr
                                          #307
                                          python27
                                          Danke.
