  4. node-red-contrib-virtual-smart-home mit Loxone
32 Beiträge 3 Kommentatoren 5.0k Aufrufe 3 Beobachtet
  • H Heinloth
    mickymM Offline
    mickymM Offline
    mickym
    @heinloth Lösche mal den ganzen Flow hier raus - zumindest ohne die Alexa Node - weil da ist Dein Alexa Zugang drin - also ohne Alexa Node exportieren.
    Ansonsten schaut der Flow nun so aus:
    hier zum Import:
    [{"id":"a00cd64c3cdb4aae","type":"switch","z":"34a03c31fc3710a3","name":"Analysiere Directive","property":"payload.directive","propertyType":"msg","rules":[{"t":"eq","v":"TurnOn","vt":"str"},{"t":"eq","v":"TurnOff","vt":"str"},{"t":"eq","v":"SetBrightness","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":1140,"y":2380,"wires":[["bd4ab7e2e461457d"],["8b0f168e745ae4fd"],["04ab779f2aabecc5"]]},{"id":"bd4ab7e2e461457d","type":"change","z":"34a03c31fc3710a3","name":"auf 100","rules":[{"t":"set","p":"payload","pt":"msg","to":"100","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1420,"y":2340,"wires":[["b5821dba10da4c79"]]},{"id":"04ab779f2aabecc5","type":"change","z":"34a03c31fc3710a3","name":"auf payload.brightness","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.brightness","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1380,"y":2420,"wires":[["b5821dba10da4c79"]]},{"id":"8b0f168e745ae4fd","type":"change","z":"34a03c31fc3710a3","name":"auf 0","rules":[{"t":"set","p":"payload","pt":"msg","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1430,"y":2380,"wires":[["b5821dba10da4c79"]]},{"id":"b5821dba10da4c79","type":"debug","z":"34a03c31fc3710a3","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1660,"y":2380,"wires":[]}]
    Der Ansatz sieht also wie folgt aus:
    Am Anfang werten wir über die Switch Node aus, was für eine Directive Alexa ausgibt:
    Diese stand in der msg.payload.directive
    Nun wird an den ersten beiden Ausgängen 0 oder 100 gesetzt, beim letzten Ausgang auf die payload.brightness
    • H Offline
      Heinloth
      Herzlichen Dank, du warst mir wirklich eine sehr große Hilfe. Gibt es hier eine Funktion Daumen hoch? 👍
      • H Heinloth
        mickymM Offline
        mickymM Offline
        mickym
        @heinloth sagte in node-red-contrib-virtual-smart-home mit Loxone:
        Ja 😁
        • H Offline
          Heinloth
          Hallo, jetzt hänge ich gerade ein wenig an der Raffstoresteuerung.
          Mit Beschattung Küche fährt er immer ganz runter und stellt dann die Lamellen gerade, das funktioniert.
          Mit Raffstore Küche möchte ich den Raffstore steuern. Mit Sprachbefehl schließen macht er zu, mit Sprachbefehl auf öffnet er. Wenn ich sage 0% schließt er, wenn ich sage 100% öffnet er.
          Jetzt möchte ich :
          Raffstore definieren mit Prozentangabe ( z.B. 30%)
          Sprachbefehl ändern zusätzlich zu Befehl auf z.B. Befehl hoch
          Wie kann ich das noch umsetzen und wie kann ich meine Programmierung optimieren!
          Herzlichen Dank
          mickymM F 2 Antworten Letzte Antwort
          • H Offline
            Heinloth
            • H Offline
              Heinloth
                      "id": "e34db2b2.a93fc",
                      "type": "debug",
                      "z": "7d95d556.9cdadc",
                      "name": "",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": true,
                      "complete": "payload",
                      "targetType": "msg",
                      "statusVal": "payload",
                      "statusType": "auto",
                      "x": 370,
                      "y": 400,
                      "wires": []
                      "id": "3ba04a95.88a9a6",
                      "type": "debug",
                      "name": "",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": true,
                      "x": 930,
                      "y": 260,
                      "wires": []
                      "id": "5eafccaa.672334",
                      "type": "switch",
                      "name": "Analysiere Directive",
                      "property": "payload.percentage",
                      "propertyType": "msg",
                      "rules": [
                              "t": "eq",
                              "v": "0",
                              "vt": "str"
                              "t": "eq",
                              "v": "100",
                              "vt": "str"
                              "t": "btwn",
                              "v": "1",
                              "vt": "num",
                              "v2": "99",
                              "v2t": "num"
                      "checkall": "true",
                      "repair": false,
                      "outputs": 3,
                      "x": 420,
                      "y": 340,
                      "wires": [
                              "2b5ff971.9facd6",
                              "6e3cf6b8.251598"
                              "7bfe0352.318f1c",
                              "c343f71d.636c38"
                              "46980042.d750c",
                              "b6b591a7.d3c9c"
                      "id": "2b5ff971.9facd6",
                      "type": "change",
                      "name": "auf 0",
                      "rules": [
                              "t": "set",
                              "p": "payload",
                              "pt": "msg",
                              "to": "0",
                              "tot": "num"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 700,
                      "y": 340,
                      "wires": [
                              "1d2c69c6.9bd3d6",
                              "a23d546d.30cc58"
                      "id": "7bfe0352.318f1c",
                      "type": "change",
                      "name": "auf 100",
                      "rules": [
                              "t": "set",
                              "p": "payload",
                              "pt": "msg",
                              "to": "100",
                              "tot": "num"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 730,
                      "y": 380,
                      "wires": [
                              "1d2c69c6.9bd3d6",
                              "3ba04a95.88a9a6"
                      "id": "a23d546d.30cc58",
                      "type": "debug",
                      "name": "",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": true,
                      "x": 930,
                      "y": 200,
                      "wires": []
                      "id": "d683d5a9.696698",
                      "type": "debug",
                      "name": "",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": true,
                      "x": 930,
                      "y": 140,
                      "wires": []
                      "id": "6e3cf6b8.251598",
                      "type": "debug",
                      "name": "",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": true,
                      "x": 610,
                      "y": 500,
                      "wires": []
                      "id": "c343f71d.636c38",
                      "type": "debug",
                      "name": "",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": true,
                      "x": 610,
                      "y": 560,
                      "wires": []
                      "id": "3462d884.5cf738",
                      "type": "change",
                      "name": "Payloadänderung",
                      "rules": [
                              "t": "set",
                              "p": "payload",
                              "pt": "msg",
                              "to": "payload.mode",
                              "tot": "msg"
                              "t": "change",
                              "p": "payload",
                              "pt": "msg",
                              "from": "Position.Down",
                              "fromt": "str",
                              "to": "down",
                              "tot": "str"
                              "t": "change",
                              "p": "payload",
                              "pt": "msg",
                              "from": "Position.Up",
                              "fromt": "str",
                              "to": "up",
                              "tot": "str"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 690,
                      "y": 280,
                      "wires": [
                              "d683d5a9.696698",
                              "1d2c69c6.9bd3d6"
                      "id": "ed7b05a3.e24f58",
                      "type": "ioBroker out",
                      "name": "Küche Liegefenster: shade",
                      "topic": "loxone.0.0e6abcb9-033a-68b6-ffff1382f11b2d79.shade",
                      "ack": "false",
                      "autoCreate": "false",
                      "stateName": "",
                      "role": "",
                      "payloadType": "",
                      "readonly": "",
                      "stateUnit": "",
                      "stateMin": "",
                      "stateMax": "",
                      "x": 480,
                      "y": 100,
                      "wires": []
                      "id": "46980042.d750c",
                      "type": "debug",
                      "name": "",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": true,
                      "x": 610,
                      "y": 620,
                      "wires": []
                      "id": "b6b591a7.d3c9c",
                      "type": "change",
                      "name": "auf 100",
                      "rules": [
                              "t": "change",
                              "p": "payload",
                              "pt": "msg",
                              "from": "20",
                              "fromt": "num",
                              "to": "80",
                              "tot": "num"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 740,
                      "y": 420,
                      "wires": [
                              "1d2c69c6.9bd3d6",
                              "85644c84.026fa"
                      "id": "85644c84.026fa",
                      "type": "debug",
                      "name": "",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": true,
                      "x": 930,
                      "y": 560,
                      "wires": []
              • H Heinloth
                Jetzt möchte ich :
                Herzlichen Dank
                mickymM Offline
                mickymM Offline
                mickym
                @heinloth
                Jetzt möchte ich :
                das macht keinen Sinn wichtig sind für den Switch Node für verschiedene Befehle die Szenarien. Also Du sprichst die Befehle und untersuchst - welche Directiven die Alexa Node ausspukt und auf die reagierst Du - d.h. ich kann nur untersützen, wenn Du mir sagst bei welchem Befehl welche Directive ausgespukt wird.
                Nun das hat mit NodeRed nichts zu tun - das musst Du irgendwo in der Alexa definieren. Vielleicht kann hier @frankyboy73 wieder mal aushelfen. Ich habe selbst keine Alexa.
                • H Offline
                  Heinloth
                  Ok kein Problem, werde mich damit noch ein wenig beschäftigen.
                  Kannst du mir evtl. noch ein paar grundlegende Tipps geben.
                  Backup IObroker mach ich über Backup funktion.
                  Nodes von NodeRed exportiere ich auf die Festplatte.
                  Muss ich sonst noch Sicherungen vornehmen?
                  Was muss ich machen, damit IObroker stabil läuft. Es gibt doch eine Funktion wenn eine Instanz gelb wird, dass diese dann neu gestartet wird. Ist das zu empfehlen?
                  Was muss ich noch beachten?
                  • H Heinloth
                    mickymM Offline
                    mickymM Offline
                    mickym
                    @heinloth Nun zu der Funktion, dass eine Instanz neu gestartet wird, wenn sie gelb ist, kann ich nichts zu sagen - ich kenn das gar nicht - wo stellst man das ein?
                    Ja das mache ich zwar auch so - habe damit aber noch nie ein System hergestellt. Ich hab das ganze auf einem Raspberry laufen und machen immer mal wieder Image-Backups - da halt noch manche andere Dinge auf der Maschine sind, die zusammengreifen. Ich glaube ich bräuchte ggf. lange bis das System wieder so läuft wie jetzt.
                    Teile des Backups - wie Zigbee habe ich schon mal benutzt.
                    Ja entweder als einzelne Flows - oder alle Flows zusammen.
                    Wie gesagt weiß nicht auf was für einem System Dein iobroker läuft - ich mach wie gesagt hin und wieder Images.
                    Ich nutze generell - Adapter nur sparsam - in erster Linie sind für mich Adapter das Interface zur Hardware oder Basisprotokollen. So Adapter die prüfen, ob Geräte noch eingeschaltet sind oder die mir nur Datenpunkte aus einem JSONString einzeln schreiben, darauf verzichte ich. Das mache ich entweder lieber mit Node Red - da weiß ich welche Logik dahinter steht und es sind keine Black Boxen. Die Adapter für Shellies oder Tasmota mag ich auch nicht - arbeite lieber mit originärem MQTT. Leider bieten diese Adapter auch keine Möglichkeit sich mit bestehendem MQTT-Brokern zu verbinden, sondern simulieren einen eigenen Broker. Das ist für mich auch ein K.O. - dann musst Du für jede Instanz einen eigenen Port verwenden.
                    Das wars mal mit so allgemeinen Hinweisen.
                    • H Heinloth
                      Jetzt möchte ich :
                      Herzlichen Dank
                      frankyboy73
                      schrieb am zuletzt editiert von frankyboy73
                      Hi, das könnte man eventuell über Routinen in der Alexa App umsetzen.
                      Wenn folgendes passiert, Stimme, da dann eingeben was man zur Ausführung sagen will, z.B.
                      "Raffstore hoch", man kann auch mehrere Sätze in einer Routine verwenden.
                      Dann bei Aktion das Gerät auswählen (unter dem Punkt Smarthome) und was passieren soll, (an,aus,auf,zu,10% oder 100%)
                      Habe das bei meinen Rollos auch so gemacht. Wenn ich sage"Rollo Schlafen hoch" oder "Rollo Schlafen auf" dann habe ich als Aktion, Rollo auf 0%. Runter dann das gleiche. Runter und zu und als Aktion dann 70% (70% weil ich die nicht ganz dicht haben will)
                      Man könnte auch nehmen Rollo Standart und dann z.B. Aktion auf 30%, usw.
                      Als Hinweis: Da muss man dann immer den gleichen Wortlaut sagen wie in der Routine eingegeben, also am besten nicht zu komplizierte Sachen verwenden.
                      Ich habe das auch schon so genutzt, das ich mir ein Vituelles Gerät erstellt habe und über verschieden Routinen stelle ich das Gerät dann auf verschiedene Prozentzahlen und werte das dann in Node Red aus um verschiedene Aktionen auszuführen. Ich lasse mir damit z.B. verschiedene Temperaturen ausgeben.
                      @mickym Nicht über die Funktion Nodes meckern, das ist noch ganz alt und habe ich noch nicht überarbeitet.
                      Schöne Grüße Frank
                      • H Offline
                        Heinloth
                        Danke, versuche ich mal.
