  2. Русский
  3. ioBroker
  4. Ошибка
  5. ioBroker ошибки
  6. Разные ошибки
Разные ошибки
Geplant Angeheftet Gesperrt Verschoben ioBroker ошибки
192 Beiträge 27 Kommentatoren 82.2k Aufrufe
  • F Offline
    ford7
    #157
    Подскажите, node-red ругается на node.js- как поправить?
    node-red.0 2017-03-09 10:48:45.449 error no connection to objects DB
    node-red.0 2017-03-09 10:48:45.451 warn 2017-03-09 10:48:45.451 - error: node-red.0 no connection to objects DB
    node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] ------------------------------------------------------
    node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] [mqtt] SyntaxError: Use of const in strict mode.
    node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] [rpi-gpio] Info : Ignoring Raspberry Pi specific node
    node-red.0 2017-03-09 10:48:09.753 warn ^^^^^
    node-red.0 2017-03-09 10:48:09.753 warn const isSecure = ['mqtts', 'wss'].indexOf(opts.protocol) !== -1
    node-red.0 2017-03-09 10:48:09.753 warn /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/mqtt/lib/connect/index.js:100
    web.0 2017-03-09 10:48:06.540 info 2017-03-09T06:48:06.540Z Connected system.user.admin
    web.0 2017-03-09 10:48:06.270 info 2017-03-09T06:48:06.270Z Connected system.user.admin
    web.0 2017-03-09 10:48:03.746 info 2017-03-09T06:48:03.746Z Connected system.user.admin
    node-red.0 2017-03-09 10:48:00.249 error 9 Mar 10:48:00 - [error] *****************************************************************
    node-red.0 2017-03-09 10:48:00.246 error 9 Mar 10:48:00 - [error] * Unsupported version of Node.js. Requires: >=4 Found: v0.10.25 *
    node-red.0 2017-03-09 10:48:00.242 error 9 Mar 10:48:00 - [error] *****************************************************************
    • H Offline
      Haus
      #158
      @ford7:
      ! node-red.0 2017-03-09 10:48:45.449 error no connection to objects DB node-red.0 2017-03-09 10:48:45.451 warn 2017-03-09 10:48:45.451 - error: node-red.0 no connection to objects DB node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] ------------------------------------------------------ node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] [mqtt] SyntaxError: Use of const in strict mode. node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] [rpi-gpio] Info : Ignoring Raspberry Pi specific node node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] ------------------------------------------------------ node-red.0 2017-03-09 10:48:09.753 warn ^^^^^ node-red.0 2017-03-09 10:48:09.753 warn const isSecure = ['mqtts', 'wss'].indexOf(opts.protocol) !== -1 node-red.0 2017-03-09 10:48:09.753 warn /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/mqtt/lib/connect/index.js:100 node-red.0 2017-03-09 10:48:09.753 warn web.0 2017-03-09 10:48:06.540 info 2017-03-09T06:48:06.540Z Connected system.user.admin web.0 2017-03-09 10:48:06.270 info 2017-03-09T06:48:06.270Z Connected system.user.admin web.0 2017-03-09 10:48:03.746 info 2017-03-09T06:48:03.746Z Connected system.user.admin node-red.0 2017-03-09 10:48:00.249 error 9 Mar 10:48:00 - [error] ***************************************************************** node-red.0 2017-03-09 10:48:00.246 error 9 Mar 10:48:00 - [error] * Unsupported version of Node.js. Requires: >=4 Found: v0.10.25 * node-red.0 2017-03-09 10:48:00.242 error 9 Mar 10:48:00 - [error] ***************************************************************** `
      Сменить nodejs нужна версия v4.x и выше.
      js-controller: 1.5.7 / node.js: v8.15.1/ npm: 6.4.1
      admin: 3.6.0
      javascript: 4.1.10
      web: 2.4.1 vis: 1.1.10
      cloud: 2.6.2
      Server: DELL FX170 / linux: Debian 9.5 Stretch
      Adapter: MegaD-2561, Mega-ES…
      • I Offline
        I Offline
        Izzm
        #159
        Обновился до крайней версии. MQTT сервер стал заваливать сообщениями в лог.
        Перезапускал отдельно драйвер, перезагружал сервер целиком. Эффекта нет.
        js-controller 0.16.2
        Admin 1.7.0
        JS 3.2.6
        • BluefoxB Offline
          BluefoxB Offline
          #160
          @Izzm:
          Admin 1.7.0
          JS 3.2.6 `
          А на самом деле эти переменные существуют?
          • F Offline
            ford7
            #161
            @Haus:
            Сменить nodejs нужна версия v4.x и выше. `
            Как это сделать, подскажите.
            • H Offline
              Haus
              #162
              @ford7:
              @Haus:
              Сменить nodejs нужна версия v4.x и выше. Как это сделать, подскажите.
              apt-get --purge remove node
              apt-get --purge remove nodejs
              apt-get autoremove
              reboot
              apt-get update
              apt-get upgrade
              apt-get install curl build-essential
              curl -sL https://deb.nodesource.com/setup_4.x | bash -
              apt-get install -y nodejs
              admin: 3.6.0
              javascript: 4.1.10
              cloud: 2.6.2
              • F Offline
                ford7
                #163
                @Haus:
                apt-get autoremove
                reboot
                apt-get update
                apt-get upgrade
                Обновил, сейчас сыплются ошибки с sql и s7
                host.zvmubn 2017-03-10 12:25:46.641 error instance system.adapter.s7.0 terminated with code 0 (OK)
                s7.0 2017-03-10 12:25:46.627 info terminating
                s7.0 2017-03-10 12:25:46.206 info starting. Version 0.2.5 in /opt/iobroker/node_modules/iobroker.s7, node: v4.8.0
                s7.0 2017-03-10 12:25:46.116 error at Object.Module._extensions..js (module.js:416:10)
                s7.0 2017-03-10 12:25:46.116 error at Module._compile (module.js:409:26)
                s7.0 2017-03-10 12:25:46.116 error at Object. (/opt/iobroker/node_modules/iobroker.s7/node_modules/node-snap7/lib/node-snap7.js:6:45)
                s7.0 2017-03-10 12:25:46.116 error at bindings (/opt/iobroker/node_modules/iobroker.s7/node_modules/node-snap7/node_modules/bindings/bindings.js:76:44)
                s7.0 2017-03-10 12:25:46.116 error at require (internal/module.js:12:17)
                s7.0 2017-03-10 12:25:46.116 error at Module.require (module.js:353:17)
                s7.0 2017-03-10 12:25:46.116 error at Function.Module._load (module.js:300:12)
                s7.0 2017-03-10 12:25:46.116 error at Module.load (module.js:343:32)
                s7.0 2017-03-10 12:25:46.116 error at Object.Module._extensions..node (module.js:434:18)
                s7.0 2017-03-10 12:25:46.116 error at Error (native)
                s7.0 2017-03-10 12:25:46.116 error Error: Module did not self-register.
                s7.0 2017-03-10 12:25:46.108 error uncaught exception: Module did not self-register.
                host.zvmubn 2017-03-10 12:25:45.677 info instance system.adapter.s7.0 started with pid 7860
                sql.0 2017-03-10 12:25:31.347 error TypeError: Cannot read property 'borrow' of undefined
                sql.0 2017-03-10 12:25:31.347 error Selected SQL DB was not installed properly: "sqlite". SQLite requires build tools on system. See README.md
                host.zvmubn 2017-03-10 12:25:15.668 info Restart adapter system.adapter.s7.0 because enabled
                host.zvmubn 2017-03-10 12:25:15.668 error instance system.adapter.s7.0 terminated with code 0 (OK)
                • H Offline
                  Haus
                  #164
                  @ford7:
                  @Haus:
                  apt-get autoremove
                  reboot
                  apt-get update
                  apt-get upgrade
                  ! host.zvmubn 2017-03-10 12:25:46.641 error instance system.adapter.s7.0 terminated with code 0 (OK) s7.0 2017-03-10 12:25:46.627 info terminating s7.0 2017-03-10 12:25:46.206 info starting. Version 0.2.5 in /opt/iobroker/node_modules/iobroker.s7, node: v4.8.0 s7.0 2017-03-10 12:25:46.116 error at Object.Module._extensions..js (module.js:416:10) s7.0 2017-03-10 12:25:46.116 error at Module._compile (module.js:409:26) s7.0 2017-03-10 12:25:46.116 error at Object. (/opt/iobroker/node_modules/iobroker.s7/node_modules/node-snap7/lib/node-snap7.js:6:45) s7.0 2017-03-10 12:25:46.116 error at bindings (/opt/iobroker/node_modules/iobroker.s7/node_modules/node-snap7/node_modules/bindings/bindings.js:76:44) s7.0 2017-03-10 12:25:46.116 error at require (internal/module.js:12:17) s7.0 2017-03-10 12:25:46.116 error at Module.require (module.js:353:17) s7.0 2017-03-10 12:25:46.116 error at Function.Module._load (module.js:300:12) s7.0 2017-03-10 12:25:46.116 error at Module.load (module.js:343:32) s7.0 2017-03-10 12:25:46.116 error at Object.Module._extensions..node (module.js:434:18) s7.0 2017-03-10 12:25:46.116 error at Error (native) s7.0 2017-03-10 12:25:46.116 error Error: Module did not self-register. s7.0 2017-03-10 12:25:46.108 error uncaught exception: Module did not self-register. host.zvmubn 2017-03-10 12:25:45.677 info instance system.adapter.s7.0 started with pid 7860 sql.0 2017-03-10 12:25:31.347 error TypeError: Cannot read property 'borrow' of undefined sql.0 2017-03-10 12:25:31.347 error Selected SQL DB was not installed properly: "sqlite". SQLite requires build tools on system. See README.md host.zvmubn 2017-03-10 12:25:15.668 info Restart adapter system.adapter.s7.0 because enabled host.zvmubn 2017-03-10 12:25:15.668 error instance system.adapter.s7.0 terminated with code 0 (OK) `
                  node.js Version? npm Version?
                  node -v
                  npm -v
                  Если команда node -v выдаёт ошибку, то выполнить:
                  ln -s /usr/bin/nodejs /usr/bin/node
                  admin: 3.6.0
                  javascript: 4.1.10
                  cloud: 2.6.2
                  • F Offline
                    ford7
                    #165
                    @Haus:
                    node -v
                    npm -v
                    root@zvmubn:/opt/iobroker# node -v
                    v4.8.0
                    root@zvmubn:/opt/iobroker# npm -v
                    2.15.11
                    • BluefoxB Offline
                      BluefoxB Offline
                      #166
                      @ford7:
                      @Haus:
                      node -v
                      npm -v
                      v4.8.0
                      2.15.11
                      При смене ноды нужно все бинарные пакеты перекомпилировать.
                      Попробуй
                      cd /opt/iobroker
                      iobroker stop
                      npm i node-gyp -g --force
                      npm i iobroker.s7 --force
                      npm i iobroker.sql --force
                      iobroker start
                      Может быть нужно выполнить как sudo. Зависит от того какая у тебя система
                      • I Offline
                        I Offline
                        Izzm
                        #167
                        @Bluefox:
                        @Izzm:
                        Admin 1.7.0
                        JS 3.2.6 А на самом деле эти переменные существуют?
                        Нет, их не существует.Существует только в system.host.Server-Izzm.outputCount и system.host.Server-Izzm.inputCount.
                        • F Offline
                          ford7
                          #168
                          @Bluefox:
                          Попробуй
                          cd /opt/iobroker
                          iobroker stop
                          iobroker start
                          Может быть нужно выполнить как sudo. Зависит от того какая у тебя система `
                          Все получилось, спасибо!
                            spectrekr
                            #169
                            при обновлении rflink драйвера, есть ошибки:
                            npm install iobroker.rflink@1.1.2 --production --prefix "/opt/iobroker" (System call)
                            node-pre-gyp
                            ERR! Tried to download: https://github.com/voodootikigod/node-serialport/releases/download/3.1.2/serialport-v3.1.2-node-v46-linux-arm.tar.gz
                            node-pre-gyp ERR! Pre-built binaries not found for serialport@3.1.2 and node@4.2.1 (node-v46 ABI) (falling back to source compile with node-gyp)
                            node-pre-gyp
                            ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v46-linux-arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@4.2.1 (node-v46 ABI) (falling back to source compile with node-gyp)
                            Ошибки не критические, все ставится и работает, но мало ли.
                            • BluefoxB Offline
                              BluefoxB Offline
                              #170
                              @spectrekr:
                              node-pre-gyp
                              node-pre-gyp
                              Ошибки не критические, все ставится и работает, но мало ли. `
                              Это нормально. Просто нет для твоей системы готового бинарника и он переходит на компиляцию.
                              • F Offline
                                ford7
                                #171
                                Не замечал ранее, что я делаю не так?
                                ! vis.0 2017-08-19 19:03:06.033 error No license found for vis. Please get one on https://iobroker.net !
                                • BluefoxB Offline
                                  BluefoxB Offline
                                  #172
                                  @ford7:
                                  ! vis.0 2017-08-19 19:03:06.033 error No license found for vis. Please get one on https://iobroker.net ! `
                                  Пойди на https://iobroker.net и получи лицензию
                                    maxmen
                                    #173
                                    После попытки переставить частоту обновления iobroker на "1раз в месяц" не могу зайти в веб-интерфейс (нажал "сохранить", после чего минут 15 ждал пока "перестанет крутиться шестерня").
                                    Рестарт Iobroker не помогает, ребут системы тоже. Страница в браузере открывается бесконечно…
                                    # iobroker -v
                                    1.1.3
                                    # node -v
                                    v6.11.3
                                    # npm -v
                                    3.10.10
                                    Нетстат показывает что iobroker слушает порт.
                                    # netstat -tunlp
                                    Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
                                    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      29555/node-red
                                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1311/iobroker.js-co
                                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1311/iobroker.js-co
                                    tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      1236/mysqld
                                    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      799/nginx -g daemon
                                    tcp        0      0 0.0.0.0:8881            0.0.0.0:*               LISTEN      915/motion
                                    tcp        0      0 0.0.0.0:8882            0.0.0.0:*               LISTEN      915/motion
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      642/sshd
                                    tcp6       0      0 :::5880                 :::*                    LISTEN      25028/apache2
                                    tcp6       0      0 :::80                   :::*                    LISTEN      799/nginx -g daemon
                                    tcp6       0      0 :::8081                 :::*                    LISTEN      31399/io.admin.0
                                    tcp6       0      0 :::8082                 :::*                    LISTEN      29530/io.web.0
                                    tcp6       0      0 :::8085                 :::*                    LISTEN      29513/io.megadd.0
                                    tcp6       0      0 :::8086                 :::*                    LISTEN      29529/io.megadd.1
                                    Куда копать? Опять переустанавливать iobroker?
                                    • BluefoxB Offline
                                      BluefoxB Offline
                                      #174
                                      @maxmen:
                                      # iobroker -v
                                      1.1.3
                                      # node -v
                                      v6.11.3
                                      # npm -v
                                      3.10.10
                                      # netstat -tunlp
                                      Куда копать? Опять переустанавливать iobroker? `
                                      Что говорит "iobroker list instances" ?
                                        maxmen
                                        #175
                                        @Bluefox:
                                        Что говорит "iobroker list instances" ? `
                                        root@cubietruck:~# iobroker list instances
                                        events.js:160
                                        throw er; // Unhandled 'error' event
                                        Error: listen EADDRINUSE 127.0.0.1:9001
                                        at Object.exports._errnoException (util.js:1020:11)
                                        at exports._exceptionWithHostPort (util.js:1043:20)
                                        at Server._listen2 (net.js:1258:14)
                                        at listen (net.js:1294:10)
                                        at net.js:1404:9
                                        at _combinedTickCallback (internal/process/next_tick.js:83:11)
                                        at process._tickCallback (internal/process/next_tick.js:104:9)
                                        root@cubietruck:~#
                                        error говорит. Как лечить?
                                        Вроде бы это"Error: listen EADDRINUSE 127.0.0.1:9001" говорит о том что этот порт уже используется. Это странно, потому что я никаких изменений, которые могли привести к появлению еще каких-то служб, слушающих порты, не делал.
                                        root@cubietruck:~# netstat -tunlp
                                        ! Active Internet connections (only servers)
                                        ! Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
                                        ! tcp 0 0 0.0.0.0:1880 0.0.0.0:* LISTEN 19221/node-red
                                        ! tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 31520/iobroker.js-c
                                        ! tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 31520/iobroker.js-c
                                        root@cubietruck:~# netstat -a -o | grep 9001
                                        ! tcp 0 0 localhost:9001 : LISTEN off (0.00/0/0)
                                        ! tcp 0 0 localhost:9001 localhost:36746 TIME_WAIT timewait (46.55/0/0)
                                        ! tcp 0 0 localhost:50000 localhost:9001 ESTABLISHED off (0.00/0/0)
                                        ! tcp 294 341548 localhost:9001 localhost:36938 ESTABLISHED unkn-4 (0.21/0/0)
                                        ! tcp 0 0 localhost:54468 localhost:9001 ESTABLISHED off (0.00/0/0)
                                        ! tcp 0 0 localhost:49990 localhost:9001 ESTABLISHED off (0.00/0/0)
                                        ! tcp 0 0 localhost:9001 localhost:36866 TIME_WAIT timewait (46.66/0/0)
                                        ! tcp 0 0 localhost:49930 localhost:9001 ESTABLISHED off (0.00/0/0)
                                        ! tcp 0 0 localhost:50074 localhost:9001 ESTABLISHED off (0.00/0/0)
                                        ! tcp 788238 49 localhost:36938 localhost:9001 ESTABLISHED on (0.24/0/0)
                                        ! tcp 0 0 localhost:9001 localhost:50006 ESTABLISHED off (0.00/0/0)
                                        ! tcp 0 0 localhost:9001 localhost:50074 ESTABLISHED off (0.00/0/0)
                                        ! tcp 0 0 localhost:9001 localhost:54468 ESTABLISHED off (0.00/0/0)
                                        ! tcp 0 0 localhost:9001 localhost:50000 ESTABLISHED off (0.00/0/0)
                                        ! tcp 0 0 localhost:9001 localhost:36936 TIME_WAIT timewait (49.51/0/0)
                                        ! tcp 0 0 localhost:9001 localhost:49930 ESTABLISHED off (0.00/0/0)
                                        ! tcp 0 0 localhost:50006 localhost:9001 ESTABLISHED off (0.00/0/0)
                                        ! tcp 0 0 localhost:9001 localhost:36940 TIME_WAIT timewait (49.66/0/0)
                                        ! tcp 0 0 localhost:9001 localhost:49990 ESTABLISHED off (0.00/0/0)
                                        ! root@cubietruck:~#
                                        root@cubietruck:~# lsof -i tcp:9001
                                        ! COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
                                        ! io.megadd 2507 root 12u IPv4 3675984 0t0 TCP localhost:49990->localhost:9001 (ESTABLISHED)
                                        ! io.node-r 2513 root 12u IPv4 3675998 0t0 TCP localhost:50000->localhost:9001 (ESTABLISHED)
                                        ! io.web.0 9540 root 11u IPv4 3676213 0t0 TCP localhost:50074->localhost:9001 (ESTABLISHED)
                                        ! io.admin. 12873 root 11u IPv4 3882172 0t0 TCP localhost:37720->localhost:9001 (ESTABLISHED)
                                        ! node-red 19221 root 13u IPv4 3693851 0t0 TCP localhost:54468->localhost:9001 (ESTABLISHED)
                                        ! io.megadd 20337 root 11u IPv4 3675902 0t0 TCP localhost:49930->localhost:9001 (ESTABLISHED)
                                        ! io.discov 20343 root 11u IPv4 3676001 0t0 TCP localhost:50006->localhost:9001 (ESTABLISHED)
                                        ! iobroker. 31520 root 12u IPv4 399252 0t0 TCP localhost:9001 (LISTEN)
                                        ! iobroker. 31520 root 13u IPv4 3675985 0t0 TCP localhost:9001->localhost:49990 (ESTABLISHED)
                                        ! iobroker. 31520 root 15u IPv4 3674837 0t0 TCP localhost:9001->localhost:50000 (ESTABLISHED)
                                        ! iobroker. 31520 root 19u IPv4 3674841 0t0 TCP localhost:9001->localhost:50006 (ESTABLISHED)
                                        ! iobroker. 31520 root 23u IPv4 3694711 0t0 TCP localhost:9001->localhost:54468 (ESTABLISHED)
                                        ! iobroker. 31520 root 26u IPv4 3882173 0t0 TCP localhost:9001->localhost:37720 (ESTABLISHED)
                                        ! iobroker. 31520 root 28u IPv4 3674924 0t0 TCP localhost:9001->localhost:50074 (ESTABLISHED)
                                        ! iobroker. 31520 root 30u IPv4 3675914 0t0 TCP localhost:9001->localhost:49930 (ESTABLISHED)
                                        Останавливаю Iobroker и на порту 9001 сервисов не видно. Но запустить его не получается из-за вышеописанной ошибки.
                                        root@cubietruck:~# iobroker stop
                                        Stopping iobroker controller daemon…
                                        iobroker controller daemon stopped.
                                        Exit code for "killall.sh": 0
                                        ! tcp 0 0 127.0.0.1:3306 0.0.0.0:* LISTEN 1236/mysqld
                                        ! tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 799/nginx -g daemon
                                        ! tcp 0 0 0.0.0.0:8881 0.0.0.0:* LISTEN 915/motion
                                        ! tcp 0 0 0.0.0.0:8882 0.0.0.0:* LISTEN 915/motion
                                        ! tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 642/sshd
                                        ! tcp6 0 0 :::5880 :::* LISTEN 25028/apache2
                                        ! tcp6 0 0 :::80 :::* LISTEN 799/nginx -g daemon
                                        ! tcp6 0 0 :::22 :::* LISTEN 642/sshd
                                        ! udp 0 0 0.0.0.0:20466 0.0.0.0:* 679/dhclient
                                        ! udp 0 0 0.0.0.0:68 0.0.0.0:* 679/dhclient
                                        ! udp 0 0 192.168.55.2:123 0.0.0.0:* 820/ntpd
                                        ! udp 0 0 127.0.0.1:123 0.0.0.0:* 820/ntpd
                                        ! udp 0 0 0.0.0.0:123 0.0.0.0:* 820/ntpd
                                        ! udp6 0 0 ::1:123 :::* 820/ntpd
                                        ! udp6 0 0 fe80::45:6ff:fe42:9:123 :::* 820/ntpd
                                        ! udp6 0 0 :::123 :::* 820/ntpd
                                        ! udp6 0 0 :::27484 :::* 679/dhclient
                                          maxmen
                                          #176
                                          Кто-нибудь сталкивался с такой ошибкой? Как лечить? Как понять, что именно занимает порт раньше времени?
                                          Решение из темы http://downloads.iobroker.com/forum/vie … =12&t=7202
                                          ` > There are two possible reasons for that:
                                          • the port is really occupied by other application, like monkey done server or torrent,
                                          • your system is so slowly, that in 2 seconds the server still too busy to send the response.
                                          You can change this parameter to 5000 or even to 10000
                                          https://github.com/ioBroker/ioBroker.js … t.json#L24
                                          But in iobroker-data/iobroker.json `
                                          Не помогает.
                                          Памяти в системе достаточно, остановка большинства сервисов тоже не помогает. И при том же самом наборе служб до этого все работало нормально до изменения времени обновления.
                                          Такое ощущение, что iobroker или пытается себя дважды запустить или еще что-то непонятное.
                                          Переустанавливать его в 10-й раз желания нет, т.к. после каждой установки приходится заново все настраивать и где гарантия, что эта проблема опять не проявит себя…
