  2. Русский
  3. ioBroker
  4. Ошибка
  5. ioBroker ошибки
  6. Разные ошибки
Разные ошибки
Geplant Angeheftet Gesperrt Verschoben ioBroker ошибки
192 Beiträge 27 Kommentatoren 82.2k Aufrufe
    spectrekr
    #156
    @Bluefox:
    @spectrekr:
    Настройка let's encrypt.
    ! 2016-11-01 12:13:37.224 - error: uncaught exception: listen EACCES 0.0.0.0:80 2016-11-01 12:13:37.238 - error: Error: listen EACCES 0.0.0.0:80 at Object.exports._errnoException (util.js:874:11) at exports._exceptionWithHostPort (util.js:897:20) at Server._listen2 (net.js:1221:19) at listen (net.js:1270:10) at Server.listen (net.js:1366:5) at Object.createServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:69:21) at initWebServer (/opt/iobroker/node_modules/iobroker.admin/admin.js:523:28) at /opt/iobroker/node_modules/iobroker.admin/admin.js:255:25 at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:360:21) at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9) at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12) at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20) at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8) at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20) at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:246:12) at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:322:16) at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20) at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:444:14) at WS. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:261:10) at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20) at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:143:8) at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:135:8) at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/websocket.js:135:10) at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:442:14) at emitTwo (events.js:87:13) 2016-11-01 12:13:37.245 - info: admin.0 terminating https server on port 8081 2016-11-01 12:13:37.269 - info: admin.0 https server listening on port 8081 2016-11-01 12:13:37.271 - info: admin.0 Use link "https://localhost:8081" to configure. 2016-11-01 12:13:38.259 - info: admin.0 terminating https server on port 8081 2016-11-01 12:13:39.783 - error: host.Cubian instance system.adapter.admin.0 terminated with code 6 (uncaught exception) 2016-11-01 12:13:39.786 - info: host.Cubian Restart adapter system.adapter.admin.0 because enabled</anonymous></anonymous></anonymous></anonymous></anonymous> `
    Кто то висит на порту 80 и не даёт запустить web.
    Lets Encrypt работает только с 80. Хотя если на рутере перенаправить 80 на что либо другое, то тоже будет работать. `
    Странно, висеть больше не чему. Ну в любом случае обновился.
    • F Offline
      ford7
      #157
      Подскажите, node-red ругается на node.js- как поправить?
      node-red.0 2017-03-09 10:48:45.449 error no connection to objects DB
      node-red.0 2017-03-09 10:48:45.451 warn 2017-03-09 10:48:45.451 - error: node-red.0 no connection to objects DB
      node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] ------------------------------------------------------
      node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] [mqtt] SyntaxError: Use of const in strict mode.
      node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] [rpi-gpio] Info : Ignoring Raspberry Pi specific node
      node-red.0 2017-03-09 10:48:09.753 warn ^^^^^
      node-red.0 2017-03-09 10:48:09.753 warn const isSecure = ['mqtts', 'wss'].indexOf(opts.protocol) !== -1
      node-red.0 2017-03-09 10:48:09.753 warn /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/mqtt/lib/connect/index.js:100
      web.0 2017-03-09 10:48:06.540 info 2017-03-09T06:48:06.540Z Connected system.user.admin
      web.0 2017-03-09 10:48:06.270 info 2017-03-09T06:48:06.270Z Connected system.user.admin
      web.0 2017-03-09 10:48:03.746 info 2017-03-09T06:48:03.746Z Connected system.user.admin
      node-red.0 2017-03-09 10:48:00.249 error 9 Mar 10:48:00 - [error] *****************************************************************
      node-red.0 2017-03-09 10:48:00.246 error 9 Mar 10:48:00 - [error] * Unsupported version of Node.js. Requires: >=4 Found: v0.10.25 *
      node-red.0 2017-03-09 10:48:00.242 error 9 Mar 10:48:00 - [error] *****************************************************************
      • H Offline
        Haus
        #158
        @ford7:
        ! node-red.0 2017-03-09 10:48:45.449 error no connection to objects DB node-red.0 2017-03-09 10:48:45.451 warn 2017-03-09 10:48:45.451 - error: node-red.0 no connection to objects DB node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] ------------------------------------------------------ node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] [mqtt] SyntaxError: Use of const in strict mode. node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] [rpi-gpio] Info : Ignoring Raspberry Pi specific node node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] ------------------------------------------------------ node-red.0 2017-03-09 10:48:09.753 warn ^^^^^ node-red.0 2017-03-09 10:48:09.753 warn const isSecure = ['mqtts', 'wss'].indexOf(opts.protocol) !== -1 node-red.0 2017-03-09 10:48:09.753 warn /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/mqtt/lib/connect/index.js:100 node-red.0 2017-03-09 10:48:09.753 warn web.0 2017-03-09 10:48:06.540 info 2017-03-09T06:48:06.540Z Connected system.user.admin web.0 2017-03-09 10:48:06.270 info 2017-03-09T06:48:06.270Z Connected system.user.admin web.0 2017-03-09 10:48:03.746 info 2017-03-09T06:48:03.746Z Connected system.user.admin node-red.0 2017-03-09 10:48:00.249 error 9 Mar 10:48:00 - [error] ***************************************************************** node-red.0 2017-03-09 10:48:00.246 error 9 Mar 10:48:00 - [error] * Unsupported version of Node.js. Requires: >=4 Found: v0.10.25 * node-red.0 2017-03-09 10:48:00.242 error 9 Mar 10:48:00 - [error] ***************************************************************** `
        Сменить nodejs нужна версия v4.x и выше.
        js-controller: 1.5.7 / node.js: v8.15.1/ npm: 6.4.1
        admin: 3.6.0
        javascript: 4.1.10
        web: 2.4.1 vis: 1.1.10
        cloud: 2.6.2
        Server: DELL FX170 / linux: Debian 9.5 Stretch
        Adapter: MegaD-2561, Mega-ES…
        • I Offline
          I Offline
          Izzm
          #159
          Обновился до крайней версии. MQTT сервер стал заваливать сообщениями в лог.
          Перезапускал отдельно драйвер, перезагружал сервер целиком. Эффекта нет.
          js-controller 0.16.2
          Admin 1.7.0
          JS 3.2.6
          • BluefoxB Offline
            BluefoxB Offline
            #160
            @Izzm:
            Admin 1.7.0
            JS 3.2.6 `
            А на самом деле эти переменные существуют?
            • F Offline
              ford7
              #161
              @Haus:
              Сменить nodejs нужна версия v4.x и выше. `
              Как это сделать, подскажите.
              • H Offline
                Haus
                #162
                @ford7:
                @Haus:
                Сменить nodejs нужна версия v4.x и выше. Как это сделать, подскажите.
                apt-get --purge remove node
                apt-get --purge remove nodejs
                apt-get autoremove
                reboot
                apt-get update
                apt-get upgrade
                apt-get install curl build-essential
                curl -sL https://deb.nodesource.com/setup_4.x | bash -
                apt-get install -y nodejs
                admin: 3.6.0
                javascript: 4.1.10
                cloud: 2.6.2
                • F Offline
                  ford7
                  #163
                  @Haus:
                  apt-get autoremove
                  reboot
                  apt-get update
                  apt-get upgrade
                  Обновил, сейчас сыплются ошибки с sql и s7
                  host.zvmubn 2017-03-10 12:25:46.641 error instance system.adapter.s7.0 terminated with code 0 (OK)
                  s7.0 2017-03-10 12:25:46.627 info terminating
                  s7.0 2017-03-10 12:25:46.206 info starting. Version 0.2.5 in /opt/iobroker/node_modules/iobroker.s7, node: v4.8.0
                  s7.0 2017-03-10 12:25:46.116 error at Object.Module._extensions..js (module.js:416:10)
                  s7.0 2017-03-10 12:25:46.116 error at Module._compile (module.js:409:26)
                  s7.0 2017-03-10 12:25:46.116 error at Object. (/opt/iobroker/node_modules/iobroker.s7/node_modules/node-snap7/lib/node-snap7.js:6:45)
                  s7.0 2017-03-10 12:25:46.116 error at bindings (/opt/iobroker/node_modules/iobroker.s7/node_modules/node-snap7/node_modules/bindings/bindings.js:76:44)
                  s7.0 2017-03-10 12:25:46.116 error at require (internal/module.js:12:17)
                  s7.0 2017-03-10 12:25:46.116 error at Module.require (module.js:353:17)
                  s7.0 2017-03-10 12:25:46.116 error at Function.Module._load (module.js:300:12)
                  s7.0 2017-03-10 12:25:46.116 error at Module.load (module.js:343:32)
                  s7.0 2017-03-10 12:25:46.116 error at Object.Module._extensions..node (module.js:434:18)
                  s7.0 2017-03-10 12:25:46.116 error at Error (native)
                  s7.0 2017-03-10 12:25:46.116 error Error: Module did not self-register.
                  s7.0 2017-03-10 12:25:46.108 error uncaught exception: Module did not self-register.
                  host.zvmubn 2017-03-10 12:25:45.677 info instance system.adapter.s7.0 started with pid 7860
                  sql.0 2017-03-10 12:25:31.347 error TypeError: Cannot read property 'borrow' of undefined
                  sql.0 2017-03-10 12:25:31.347 error Selected SQL DB was not installed properly: "sqlite". SQLite requires build tools on system. See README.md
                  host.zvmubn 2017-03-10 12:25:15.668 info Restart adapter system.adapter.s7.0 because enabled
                  host.zvmubn 2017-03-10 12:25:15.668 error instance system.adapter.s7.0 terminated with code 0 (OK)
                  • H Offline
                    Haus
                    #164
                    @ford7:
                    @Haus:
                    apt-get autoremove
                    reboot
                    apt-get update
                    apt-get upgrade
                    ! host.zvmubn 2017-03-10 12:25:46.641 error instance system.adapter.s7.0 terminated with code 0 (OK) s7.0 2017-03-10 12:25:46.627 info terminating s7.0 2017-03-10 12:25:46.206 info starting. Version 0.2.5 in /opt/iobroker/node_modules/iobroker.s7, node: v4.8.0 s7.0 2017-03-10 12:25:46.116 error at Object.Module._extensions..js (module.js:416:10) s7.0 2017-03-10 12:25:46.116 error at Module._compile (module.js:409:26) s7.0 2017-03-10 12:25:46.116 error at Object. (/opt/iobroker/node_modules/iobroker.s7/node_modules/node-snap7/lib/node-snap7.js:6:45) s7.0 2017-03-10 12:25:46.116 error at bindings (/opt/iobroker/node_modules/iobroker.s7/node_modules/node-snap7/node_modules/bindings/bindings.js:76:44) s7.0 2017-03-10 12:25:46.116 error at require (internal/module.js:12:17) s7.0 2017-03-10 12:25:46.116 error at Module.require (module.js:353:17) s7.0 2017-03-10 12:25:46.116 error at Function.Module._load (module.js:300:12) s7.0 2017-03-10 12:25:46.116 error at Module.load (module.js:343:32) s7.0 2017-03-10 12:25:46.116 error at Object.Module._extensions..node (module.js:434:18) s7.0 2017-03-10 12:25:46.116 error at Error (native) s7.0 2017-03-10 12:25:46.116 error Error: Module did not self-register. s7.0 2017-03-10 12:25:46.108 error uncaught exception: Module did not self-register. host.zvmubn 2017-03-10 12:25:45.677 info instance system.adapter.s7.0 started with pid 7860 sql.0 2017-03-10 12:25:31.347 error TypeError: Cannot read property 'borrow' of undefined sql.0 2017-03-10 12:25:31.347 error Selected SQL DB was not installed properly: "sqlite". SQLite requires build tools on system. See README.md host.zvmubn 2017-03-10 12:25:15.668 info Restart adapter system.adapter.s7.0 because enabled host.zvmubn 2017-03-10 12:25:15.668 error instance system.adapter.s7.0 terminated with code 0 (OK) `
                    node.js Version? npm Version?
                    node -v
                    npm -v
                    Если команда node -v выдаёт ошибку, то выполнить:
                    ln -s /usr/bin/nodejs /usr/bin/node
                    admin: 3.6.0
                    javascript: 4.1.10
                    cloud: 2.6.2
                    • F Offline
                      ford7
                      #165
                      @Haus:
                      node -v
                      npm -v
                      root@zvmubn:/opt/iobroker# node -v
                      v4.8.0
                      root@zvmubn:/opt/iobroker# npm -v
                      2.15.11
                      • BluefoxB Offline
                        BluefoxB Offline
                        #166
                        @ford7:
                        @Haus:
                        node -v
                        npm -v
                        v4.8.0
                        2.15.11
                        При смене ноды нужно все бинарные пакеты перекомпилировать.
                        Попробуй
                        cd /opt/iobroker
                        iobroker stop
                        npm i node-gyp -g --force
                        npm i iobroker.s7 --force
                        npm i iobroker.sql --force
                        iobroker start
                        Может быть нужно выполнить как sudo. Зависит от того какая у тебя система
                        • I Offline
                          I Offline
                          Izzm
                          #167
                          @Bluefox:
                          @Izzm:
                          Admin 1.7.0
                          JS 3.2.6 А на самом деле эти переменные существуют?
                          Нет, их не существует.Существует только в system.host.Server-Izzm.outputCount и system.host.Server-Izzm.inputCount.
                          • F Offline
                            ford7
                            #168
                            @Bluefox:
                            Попробуй
                            cd /opt/iobroker
                            iobroker stop
                            iobroker start
                            Может быть нужно выполнить как sudo. Зависит от того какая у тебя система `
                            Все получилось, спасибо!
                              spectrekr
                              #169
                              при обновлении rflink драйвера, есть ошибки:
                              npm install iobroker.rflink@1.1.2 --production --prefix "/opt/iobroker" (System call)
                              node-pre-gyp
                              ERR! Tried to download: https://github.com/voodootikigod/node-serialport/releases/download/3.1.2/serialport-v3.1.2-node-v46-linux-arm.tar.gz
                              node-pre-gyp ERR! Pre-built binaries not found for serialport@3.1.2 and node@4.2.1 (node-v46 ABI) (falling back to source compile with node-gyp)
                              node-pre-gyp
                              ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v46-linux-arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@4.2.1 (node-v46 ABI) (falling back to source compile with node-gyp)
                              Ошибки не критические, все ставится и работает, но мало ли.
                              • BluefoxB Offline
                                BluefoxB Offline
                                #170
                                @spectrekr:
                                node-pre-gyp
                                node-pre-gyp
                                Ошибки не критические, все ставится и работает, но мало ли. `
                                Это нормально. Просто нет для твоей системы готового бинарника и он переходит на компиляцию.
                                • F Offline
                                  ford7
                                  #171
                                  Не замечал ранее, что я делаю не так?
                                  ! vis.0 2017-08-19 19:03:06.033 error No license found for vis. Please get one on https://iobroker.net !
                                  • BluefoxB Offline
                                    BluefoxB Offline
                                    #172
                                    @ford7:
                                    ! vis.0 2017-08-19 19:03:06.033 error No license found for vis. Please get one on https://iobroker.net ! `
                                    Пойди на https://iobroker.net и получи лицензию
                                      maxmen
                                      #173
                                      После попытки переставить частоту обновления iobroker на "1раз в месяц" не могу зайти в веб-интерфейс (нажал "сохранить", после чего минут 15 ждал пока "перестанет крутиться шестерня").
                                      Рестарт Iobroker не помогает, ребут системы тоже. Страница в браузере открывается бесконечно…
                                      # iobroker -v
                                      1.1.3
                                      # node -v
                                      v6.11.3
                                      # npm -v
                                      3.10.10
                                      Нетстат показывает что iobroker слушает порт.
                                      # netstat -tunlp
                                      Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
                                      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      29555/node-red
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1311/iobroker.js-co
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1311/iobroker.js-co
                                      tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      1236/mysqld
                                      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      799/nginx -g daemon
                                      tcp        0      0 0.0.0.0:8881            0.0.0.0:*               LISTEN      915/motion
                                      tcp        0      0 0.0.0.0:8882            0.0.0.0:*               LISTEN      915/motion
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      642/sshd
                                      tcp6       0      0 :::5880                 :::*                    LISTEN      25028/apache2
                                      tcp6       0      0 :::80                   :::*                    LISTEN      799/nginx -g daemon
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      31399/io.admin.0
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      29530/io.web.0
                                      tcp6       0      0 :::8085                 :::*                    LISTEN      29513/io.megadd.0
                                      tcp6       0      0 :::8086                 :::*                    LISTEN      29529/io.megadd.1
                                      Куда копать? Опять переустанавливать iobroker?
                                      • BluefoxB Offline
                                        BluefoxB Offline
                                        #174
                                        @maxmen:
                                        # iobroker -v
                                        1.1.3
                                        # node -v
                                        v6.11.3
                                        # npm -v
                                        3.10.10
                                        # netstat -tunlp
                                        Куда копать? Опять переустанавливать iobroker? `
                                        Что говорит "iobroker list instances" ?
                                          maxmen
                                          #175
                                          @Bluefox:
                                          Что говорит "iobroker list instances" ? `
                                          root@cubietruck:~# iobroker list instances
                                          events.js:160
                                          throw er; // Unhandled 'error' event
                                          Error: listen EADDRINUSE 127.0.0.1:9001
                                          at Object.exports._errnoException (util.js:1020:11)
                                          at exports._exceptionWithHostPort (util.js:1043:20)
                                          at Server._listen2 (net.js:1258:14)
                                          at listen (net.js:1294:10)
                                          at net.js:1404:9
                                          at _combinedTickCallback (internal/process/next_tick.js:83:11)
                                          at process._tickCallback (internal/process/next_tick.js:104:9)
                                          root@cubietruck:~#
                                          error говорит. Как лечить?
                                          Вроде бы это"Error: listen EADDRINUSE 127.0.0.1:9001" говорит о том что этот порт уже используется. Это странно, потому что я никаких изменений, которые могли привести к появлению еще каких-то служб, слушающих порты, не делал.
                                          root@cubietruck:~# netstat -tunlp
                                          ! Active Internet connections (only servers)
                                          ! Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
                                          ! tcp 0 0 0.0.0.0:1880 0.0.0.0:* LISTEN 19221/node-red
                                          ! tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 31520/iobroker.js-c
                                          ! tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 31520/iobroker.js-c
                                          root@cubietruck:~# netstat -a -o | grep 9001
                                          ! tcp 0 0 localhost:9001 : LISTEN off (0.00/0/0)
                                          ! tcp 0 0 localhost:9001 localhost:36746 TIME_WAIT timewait (46.55/0/0)
                                          ! tcp 0 0 localhost:50000 localhost:9001 ESTABLISHED off (0.00/0/0)
                                          ! tcp 294 341548 localhost:9001 localhost:36938 ESTABLISHED unkn-4 (0.21/0/0)
                                          ! tcp 0 0 localhost:54468 localhost:9001 ESTABLISHED off (0.00/0/0)
                                          ! tcp 0 0 localhost:49990 localhost:9001 ESTABLISHED off (0.00/0/0)
                                          ! tcp 0 0 localhost:9001 localhost:36866 TIME_WAIT timewait (46.66/0/0)
                                          ! tcp 0 0 localhost:49930 localhost:9001 ESTABLISHED off (0.00/0/0)
                                          ! tcp 0 0 localhost:50074 localhost:9001 ESTABLISHED off (0.00/0/0)
                                          ! tcp 788238 49 localhost:36938 localhost:9001 ESTABLISHED on (0.24/0/0)
                                          ! tcp 0 0 localhost:9001 localhost:50006 ESTABLISHED off (0.00/0/0)
                                          ! tcp 0 0 localhost:9001 localhost:50074 ESTABLISHED off (0.00/0/0)
                                          ! tcp 0 0 localhost:9001 localhost:54468 ESTABLISHED off (0.00/0/0)
                                          ! tcp 0 0 localhost:9001 localhost:50000 ESTABLISHED off (0.00/0/0)
                                          ! tcp 0 0 localhost:9001 localhost:36936 TIME_WAIT timewait (49.51/0/0)
                                          ! tcp 0 0 localhost:9001 localhost:49930 ESTABLISHED off (0.00/0/0)
                                          ! tcp 0 0 localhost:50006 localhost:9001 ESTABLISHED off (0.00/0/0)
                                          ! tcp 0 0 localhost:9001 localhost:36940 TIME_WAIT timewait (49.66/0/0)
                                          ! tcp 0 0 localhost:9001 localhost:49990 ESTABLISHED off (0.00/0/0)
                                          ! root@cubietruck:~#
                                          root@cubietruck:~# lsof -i tcp:9001
                                          ! COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
                                          ! io.megadd 2507 root 12u IPv4 3675984 0t0 TCP localhost:49990->localhost:9001 (ESTABLISHED)
                                          ! io.node-r 2513 root 12u IPv4 3675998 0t0 TCP localhost:50000->localhost:9001 (ESTABLISHED)
                                          ! io.web.0 9540 root 11u IPv4 3676213 0t0 TCP localhost:50074->localhost:9001 (ESTABLISHED)
                                          ! io.admin. 12873 root 11u IPv4 3882172 0t0 TCP localhost:37720->localhost:9001 (ESTABLISHED)
                                          ! node-red 19221 root 13u IPv4 3693851 0t0 TCP localhost:54468->localhost:9001 (ESTABLISHED)
                                          ! io.megadd 20337 root 11u IPv4 3675902 0t0 TCP localhost:49930->localhost:9001 (ESTABLISHED)
                                          ! io.discov 20343 root 11u IPv4 3676001 0t0 TCP localhost:50006->localhost:9001 (ESTABLISHED)
                                          ! iobroker. 31520 root 12u IPv4 399252 0t0 TCP localhost:9001 (LISTEN)
                                          ! iobroker. 31520 root 13u IPv4 3675985 0t0 TCP localhost:9001->localhost:49990 (ESTABLISHED)
                                          ! iobroker. 31520 root 15u IPv4 3674837 0t0 TCP localhost:9001->localhost:50000 (ESTABLISHED)
                                          ! iobroker. 31520 root 19u IPv4 3674841 0t0 TCP localhost:9001->localhost:50006 (ESTABLISHED)
                                          ! iobroker. 31520 root 23u IPv4 3694711 0t0 TCP localhost:9001->localhost:54468 (ESTABLISHED)
                                          ! iobroker. 31520 root 26u IPv4 3882173 0t0 TCP localhost:9001->localhost:37720 (ESTABLISHED)
                                          ! iobroker. 31520 root 28u IPv4 3674924 0t0 TCP localhost:9001->localhost:50074 (ESTABLISHED)
                                          ! iobroker. 31520 root 30u IPv4 3675914 0t0 TCP localhost:9001->localhost:49930 (ESTABLISHED)
                                          Останавливаю Iobroker и на порту 9001 сервисов не видно. Но запустить его не получается из-за вышеописанной ошибки.
                                          root@cubietruck:~# iobroker stop
                                          Stopping iobroker controller daemon…
                                          iobroker controller daemon stopped.
                                          Exit code for "killall.sh": 0
                                          ! tcp 0 0 127.0.0.1:3306 0.0.0.0:* LISTEN 1236/mysqld
                                          ! tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 799/nginx -g daemon
                                          ! tcp 0 0 0.0.0.0:8881 0.0.0.0:* LISTEN 915/motion
                                          ! tcp 0 0 0.0.0.0:8882 0.0.0.0:* LISTEN 915/motion
                                          ! tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 642/sshd
                                          ! tcp6 0 0 :::5880 :::* LISTEN 25028/apache2
                                          ! tcp6 0 0 :::80 :::* LISTEN 799/nginx -g daemon
                                          ! tcp6 0 0 :::22 :::* LISTEN 642/sshd
                                          ! udp 0 0 0.0.0.0:20466 0.0.0.0:* 679/dhclient
                                          ! udp 0 0 0.0.0.0:68 0.0.0.0:* 679/dhclient
                                          ! udp 0 0 192.168.55.2:123 0.0.0.0:* 820/ntpd
                                          ! udp 0 0 127.0.0.1:123 0.0.0.0:* 820/ntpd
                                          ! udp 0 0 0.0.0.0:123 0.0.0.0:* 820/ntpd
                                          ! udp6 0 0 ::1:123 :::* 820/ntpd
                                          ! udp6 0 0 fe80::45:6ff:fe42:9:123 :::* 820/ntpd
                                          ! udp6 0 0 :::123 :::* 820/ntpd
                                          ! udp6 0 0 :::27484 :::* 679/dhclient
