  2. Русский
  3. ioBroker
  4. Ошибка
  5. ioBroker ошибки
  6. Разные ошибки
Разные ошибки
Geplant Angeheftet Gesperrt Verschoben ioBroker ошибки
192 Beiträge 27 Kommentatoren 82.2k Aufrufe
  • BluefoxB Offline
    BluefoxB Offline
    #155
    @spectrekr:
    Настройка let's encrypt.
    ! 2016-11-01 12:13:37.224 - error: uncaught exception: listen EACCES 0.0.0.0:80 2016-11-01 12:13:37.238 - error: Error: listen EACCES 0.0.0.0:80 at Object.exports._errnoException (util.js:874:11) at exports._exceptionWithHostPort (util.js:897:20) at Server._listen2 (net.js:1221:19) at listen (net.js:1270:10) at Server.listen (net.js:1366:5) at Object.createServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:69:21) at initWebServer (/opt/iobroker/node_modules/iobroker.admin/admin.js:523:28) at /opt/iobroker/node_modules/iobroker.admin/admin.js:255:25 at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:360:21) at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9) at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12) at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20) at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8) at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20) at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:246:12) at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:322:16) at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20) at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:444:14) at WS. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:261:10) at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20) at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:143:8) at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:135:8) at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/websocket.js:135:10) at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:442:14) at emitTwo (events.js:87:13) 2016-11-01 12:13:37.245 - info: admin.0 terminating https server on port 8081 2016-11-01 12:13:37.269 - info: admin.0 https server listening on port 8081 2016-11-01 12:13:37.271 - info: admin.0 Use link "https://localhost:8081" to configure. 2016-11-01 12:13:38.259 - info: admin.0 terminating https server on port 8081 2016-11-01 12:13:39.783 - error: host.Cubian instance system.adapter.admin.0 terminated with code 6 (uncaught exception) 2016-11-01 12:13:39.786 - info: host.Cubian Restart adapter system.adapter.admin.0 because enabled</anonymous></anonymous></anonymous></anonymous></anonymous> `
    Кто то висит на порту 80 и не даёт запустить web.
    Lets Encrypt работает только с 80. Хотя если на рутере перенаправить 80 на что либо другое, то тоже будет работать.
      spectrekr
      #156
      @Bluefox:
      @spectrekr:
      Lets Encrypt работает только с 80. Хотя если на рутере перенаправить 80 на что либо другое, то тоже будет работать. `
      Странно, висеть больше не чему. Ну в любом случае обновился.
      • F Offline
        ford7
        #157
        Подскажите, node-red ругается на node.js- как поправить?
        node-red.0 2017-03-09 10:48:45.449 error no connection to objects DB
        node-red.0 2017-03-09 10:48:45.451 warn 2017-03-09 10:48:45.451 - error: node-red.0 no connection to objects DB
        node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] ------------------------------------------------------
        node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] [mqtt] SyntaxError: Use of const in strict mode.
        node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] [rpi-gpio] Info : Ignoring Raspberry Pi specific node
        node-red.0 2017-03-09 10:48:09.753 warn ^^^^^
        node-red.0 2017-03-09 10:48:09.753 warn const isSecure = ['mqtts', 'wss'].indexOf(opts.protocol) !== -1
        node-red.0 2017-03-09 10:48:09.753 warn /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/mqtt/lib/connect/index.js:100
        web.0 2017-03-09 10:48:06.540 info 2017-03-09T06:48:06.540Z Connected system.user.admin
        web.0 2017-03-09 10:48:06.270 info 2017-03-09T06:48:06.270Z Connected system.user.admin
        web.0 2017-03-09 10:48:03.746 info 2017-03-09T06:48:03.746Z Connected system.user.admin
        node-red.0 2017-03-09 10:48:00.249 error 9 Mar 10:48:00 - [error] *****************************************************************
        node-red.0 2017-03-09 10:48:00.246 error 9 Mar 10:48:00 - [error] * Unsupported version of Node.js. Requires: >=4 Found: v0.10.25 *
        node-red.0 2017-03-09 10:48:00.242 error 9 Mar 10:48:00 - [error] *****************************************************************
        • H Offline
          Haus
          #158
          @ford7:
          ! node-red.0 2017-03-09 10:48:45.449 error no connection to objects DB node-red.0 2017-03-09 10:48:45.451 warn 2017-03-09 10:48:45.451 - error: node-red.0 no connection to objects DB node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] ------------------------------------------------------ node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] [mqtt] SyntaxError: Use of const in strict mode. node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] [rpi-gpio] Info : Ignoring Raspberry Pi specific node node-red.0 2017-03-09 10:48:45.438 warn 9 Mar 10:48:45 - [warn] ------------------------------------------------------ node-red.0 2017-03-09 10:48:09.753 warn ^^^^^ node-red.0 2017-03-09 10:48:09.753 warn const isSecure = ['mqtts', 'wss'].indexOf(opts.protocol) !== -1 node-red.0 2017-03-09 10:48:09.753 warn /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/mqtt/lib/connect/index.js:100 node-red.0 2017-03-09 10:48:09.753 warn web.0 2017-03-09 10:48:06.540 info 2017-03-09T06:48:06.540Z Connected system.user.admin web.0 2017-03-09 10:48:06.270 info 2017-03-09T06:48:06.270Z Connected system.user.admin web.0 2017-03-09 10:48:03.746 info 2017-03-09T06:48:03.746Z Connected system.user.admin node-red.0 2017-03-09 10:48:00.249 error 9 Mar 10:48:00 - [error] ***************************************************************** node-red.0 2017-03-09 10:48:00.246 error 9 Mar 10:48:00 - [error] * Unsupported version of Node.js. Requires: >=4 Found: v0.10.25 * node-red.0 2017-03-09 10:48:00.242 error 9 Mar 10:48:00 - [error] ***************************************************************** `
          Сменить nodejs нужна версия v4.x и выше.
          js-controller: 1.5.7 / node.js: v8.15.1/ npm: 6.4.1
          admin: 3.6.0
          javascript: 4.1.10
          web: 2.4.1 vis: 1.1.10
          cloud: 2.6.2
          Server: DELL FX170 / linux: Debian 9.5 Stretch
          Adapter: MegaD-2561, Mega-ES…
          • I Offline
            I Offline
            Izzm
            #159
            Обновился до крайней версии. MQTT сервер стал заваливать сообщениями в лог.
            Перезапускал отдельно драйвер, перезагружал сервер целиком. Эффекта нет.
            js-controller 0.16.2
            Admin 1.7.0
            JS 3.2.6
            • BluefoxB Offline
              BluefoxB Offline
              #160
              @Izzm:
              Admin 1.7.0
              JS 3.2.6 `
              А на самом деле эти переменные существуют?
              • F Offline
                ford7
                #161
                @Haus:
                Сменить nodejs нужна версия v4.x и выше. `
                Как это сделать, подскажите.
                • H Offline
                  Haus
                  #162
                  @ford7:
                  @Haus:
                  Сменить nodejs нужна версия v4.x и выше. Как это сделать, подскажите.
                  apt-get --purge remove node
                  apt-get --purge remove nodejs
                  apt-get autoremove
                  reboot
                  apt-get update
                  apt-get upgrade
                  apt-get install curl build-essential
                  curl -sL https://deb.nodesource.com/setup_4.x | bash -
                  apt-get install -y nodejs
                  admin: 3.6.0
                  javascript: 4.1.10
                  cloud: 2.6.2
                  • F Offline
                    ford7
                    #163
                    @Haus:
                    apt-get autoremove
                    reboot
                    apt-get update
                    apt-get upgrade
                    Обновил, сейчас сыплются ошибки с sql и s7
                    host.zvmubn 2017-03-10 12:25:46.641 error instance system.adapter.s7.0 terminated with code 0 (OK)
                    s7.0 2017-03-10 12:25:46.627 info terminating
                    s7.0 2017-03-10 12:25:46.206 info starting. Version 0.2.5 in /opt/iobroker/node_modules/iobroker.s7, node: v4.8.0
                    s7.0 2017-03-10 12:25:46.116 error at Object.Module._extensions..js (module.js:416:10)
                    s7.0 2017-03-10 12:25:46.116 error at Module._compile (module.js:409:26)
                    s7.0 2017-03-10 12:25:46.116 error at Object. (/opt/iobroker/node_modules/iobroker.s7/node_modules/node-snap7/lib/node-snap7.js:6:45)
                    s7.0 2017-03-10 12:25:46.116 error at bindings (/opt/iobroker/node_modules/iobroker.s7/node_modules/node-snap7/node_modules/bindings/bindings.js:76:44)
                    s7.0 2017-03-10 12:25:46.116 error at require (internal/module.js:12:17)
                    s7.0 2017-03-10 12:25:46.116 error at Module.require (module.js:353:17)
                    s7.0 2017-03-10 12:25:46.116 error at Function.Module._load (module.js:300:12)
                    s7.0 2017-03-10 12:25:46.116 error at Module.load (module.js:343:32)
                    s7.0 2017-03-10 12:25:46.116 error at Object.Module._extensions..node (module.js:434:18)
                    s7.0 2017-03-10 12:25:46.116 error at Error (native)
                    s7.0 2017-03-10 12:25:46.116 error Error: Module did not self-register.
                    s7.0 2017-03-10 12:25:46.108 error uncaught exception: Module did not self-register.
                    host.zvmubn 2017-03-10 12:25:45.677 info instance system.adapter.s7.0 started with pid 7860
                    sql.0 2017-03-10 12:25:31.347 error TypeError: Cannot read property 'borrow' of undefined
                    sql.0 2017-03-10 12:25:31.347 error Selected SQL DB was not installed properly: "sqlite". SQLite requires build tools on system. See README.md
                    host.zvmubn 2017-03-10 12:25:15.668 info Restart adapter system.adapter.s7.0 because enabled
                    host.zvmubn 2017-03-10 12:25:15.668 error instance system.adapter.s7.0 terminated with code 0 (OK)
                    • H Offline
                      Haus
                      #164
                      @ford7:
                      @Haus:
                      apt-get autoremove
                      reboot
                      apt-get update
                      apt-get upgrade
                      ! host.zvmubn 2017-03-10 12:25:46.641 error instance system.adapter.s7.0 terminated with code 0 (OK) s7.0 2017-03-10 12:25:46.627 info terminating s7.0 2017-03-10 12:25:46.206 info starting. Version 0.2.5 in /opt/iobroker/node_modules/iobroker.s7, node: v4.8.0 s7.0 2017-03-10 12:25:46.116 error at Object.Module._extensions..js (module.js:416:10) s7.0 2017-03-10 12:25:46.116 error at Module._compile (module.js:409:26) s7.0 2017-03-10 12:25:46.116 error at Object. (/opt/iobroker/node_modules/iobroker.s7/node_modules/node-snap7/lib/node-snap7.js:6:45) s7.0 2017-03-10 12:25:46.116 error at bindings (/opt/iobroker/node_modules/iobroker.s7/node_modules/node-snap7/node_modules/bindings/bindings.js:76:44) s7.0 2017-03-10 12:25:46.116 error at require (internal/module.js:12:17) s7.0 2017-03-10 12:25:46.116 error at Module.require (module.js:353:17) s7.0 2017-03-10 12:25:46.116 error at Function.Module._load (module.js:300:12) s7.0 2017-03-10 12:25:46.116 error at Module.load (module.js:343:32) s7.0 2017-03-10 12:25:46.116 error at Object.Module._extensions..node (module.js:434:18) s7.0 2017-03-10 12:25:46.116 error at Error (native) s7.0 2017-03-10 12:25:46.116 error Error: Module did not self-register. s7.0 2017-03-10 12:25:46.108 error uncaught exception: Module did not self-register. host.zvmubn 2017-03-10 12:25:45.677 info instance system.adapter.s7.0 started with pid 7860 sql.0 2017-03-10 12:25:31.347 error TypeError: Cannot read property 'borrow' of undefined sql.0 2017-03-10 12:25:31.347 error Selected SQL DB was not installed properly: "sqlite". SQLite requires build tools on system. See README.md host.zvmubn 2017-03-10 12:25:15.668 info Restart adapter system.adapter.s7.0 because enabled host.zvmubn 2017-03-10 12:25:15.668 error instance system.adapter.s7.0 terminated with code 0 (OK) `
                      node.js Version? npm Version?
                      node -v
                      npm -v
                      Если команда node -v выдаёт ошибку, то выполнить:
                      ln -s /usr/bin/nodejs /usr/bin/node
                      admin: 3.6.0
                      javascript: 4.1.10
                      cloud: 2.6.2
                      • F Offline
                        ford7
                        #165
                        @Haus:
                        node -v
                        npm -v
                        root@zvmubn:/opt/iobroker# node -v
                        v4.8.0
                        root@zvmubn:/opt/iobroker# npm -v
                        2.15.11
                        • BluefoxB Offline
                          BluefoxB Offline
                          #166
                          @ford7:
                          @Haus:
                          node -v
                          npm -v
                          v4.8.0
                          2.15.11
                          При смене ноды нужно все бинарные пакеты перекомпилировать.
                          Попробуй
                          cd /opt/iobroker
                          iobroker stop
                          npm i node-gyp -g --force
                          npm i iobroker.s7 --force
                          npm i iobroker.sql --force
                          iobroker start
                          Может быть нужно выполнить как sudo. Зависит от того какая у тебя система
                          • I Offline
                            I Offline
                            Izzm
                            #167
                            @Bluefox:
                            @Izzm:
                            Admin 1.7.0
                            JS 3.2.6 А на самом деле эти переменные существуют?
                            Нет, их не существует.Существует только в system.host.Server-Izzm.outputCount и system.host.Server-Izzm.inputCount.
                            • F Offline
                              ford7
                              #168
                              @Bluefox:
                              Попробуй
                              cd /opt/iobroker
                              iobroker stop
                              iobroker start
                              Может быть нужно выполнить как sudo. Зависит от того какая у тебя система `
                              Все получилось, спасибо!
                                spectrekr
                                #169
                                при обновлении rflink драйвера, есть ошибки:
                                npm install iobroker.rflink@1.1.2 --production --prefix "/opt/iobroker" (System call)
                                node-pre-gyp
                                ERR! Tried to download: https://github.com/voodootikigod/node-serialport/releases/download/3.1.2/serialport-v3.1.2-node-v46-linux-arm.tar.gz
                                node-pre-gyp ERR! Pre-built binaries not found for serialport@3.1.2 and node@4.2.1 (node-v46 ABI) (falling back to source compile with node-gyp)
                                node-pre-gyp
                                ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v46-linux-arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@4.2.1 (node-v46 ABI) (falling back to source compile with node-gyp)
                                Ошибки не критические, все ставится и работает, но мало ли.
                                • BluefoxB Offline
                                  BluefoxB Offline
                                  #170
                                  @spectrekr:
                                  node-pre-gyp
                                  node-pre-gyp
                                  Ошибки не критические, все ставится и работает, но мало ли. `
                                  Это нормально. Просто нет для твоей системы готового бинарника и он переходит на компиляцию.
                                  • F Offline
                                    ford7
                                    #171
                                    Не замечал ранее, что я делаю не так?
                                    ! vis.0 2017-08-19 19:03:06.033 error No license found for vis. Please get one on https://iobroker.net !
                                    • BluefoxB Offline
                                      BluefoxB Offline
                                      #172
                                      @ford7:
                                      ! vis.0 2017-08-19 19:03:06.033 error No license found for vis. Please get one on https://iobroker.net ! `
                                      Пойди на https://iobroker.net и получи лицензию
                                        maxmen
                                        #173
                                        После попытки переставить частоту обновления iobroker на "1раз в месяц" не могу зайти в веб-интерфейс (нажал "сохранить", после чего минут 15 ждал пока "перестанет крутиться шестерня").
                                        Рестарт Iobroker не помогает, ребут системы тоже. Страница в браузере открывается бесконечно…
                                        # iobroker -v
                                        1.1.3
                                        # node -v
                                        v6.11.3
                                        # npm -v
                                        3.10.10
                                        Нетстат показывает что iobroker слушает порт.
                                        # netstat -tunlp
                                        Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
                                        tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      29555/node-red
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1311/iobroker.js-co
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1311/iobroker.js-co
                                        tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      1236/mysqld
                                        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      799/nginx -g daemon
                                        tcp        0      0 0.0.0.0:8881            0.0.0.0:*               LISTEN      915/motion
                                        tcp        0      0 0.0.0.0:8882            0.0.0.0:*               LISTEN      915/motion
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      642/sshd
                                        tcp6       0      0 :::5880                 :::*                    LISTEN      25028/apache2
                                        tcp6       0      0 :::80                   :::*                    LISTEN      799/nginx -g daemon
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      31399/io.admin.0
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      29530/io.web.0
                                        tcp6       0      0 :::8085                 :::*                    LISTEN      29513/io.megadd.0
                                        tcp6       0      0 :::8086                 :::*                    LISTEN      29529/io.megadd.1
                                        Куда копать? Опять переустанавливать iobroker?
                                        • BluefoxB Offline
                                          BluefoxB Offline
                                          #174
                                          @maxmen:
                                          # iobroker -v
                                          1.1.3
                                          # node -v
                                          v6.11.3
                                          # npm -v
                                          3.10.10
                                          # netstat -tunlp
                                          Куда копать? Опять переустанавливать iobroker? `
                                          Что говорит "iobroker list instances" ?
