  2. Русский
  3. ioBroker
  4. Ошибка
  5. ioBroker ошибки
  6. Разные ошибки
Разные ошибки
Geplant Angeheftet Gesperrt Verschoben ioBroker ошибки
192 Beiträge 27 Kommentatoren 80.2k Aufrufe
  • H Offline
    Haus
    #164
    @ford7:
    @Haus:
    apt-get --purge remove node
    apt-get --purge remove nodejs
    apt-get autoremove
    reboot
    apt-get update
    apt-get upgrade
    apt-get install curl build-essential
    curl -sL https://deb.nodesource.com/setup_4.x | bash -
    apt-get install -y nodejs
    Обновил, сейчас сыплются ошибки с sql и s7
    ! host.zvmubn 2017-03-10 12:25:46.641 error instance system.adapter.s7.0 terminated with code 0 (OK) s7.0 2017-03-10 12:25:46.627 info terminating s7.0 2017-03-10 12:25:46.206 info starting. Version 0.2.5 in /opt/iobroker/node_modules/iobroker.s7, node: v4.8.0 s7.0 2017-03-10 12:25:46.116 error at Object.Module._extensions..js (module.js:416:10) s7.0 2017-03-10 12:25:46.116 error at Module._compile (module.js:409:26) s7.0 2017-03-10 12:25:46.116 error at Object. (/opt/iobroker/node_modules/iobroker.s7/node_modules/node-snap7/lib/node-snap7.js:6:45) s7.0 2017-03-10 12:25:46.116 error at bindings (/opt/iobroker/node_modules/iobroker.s7/node_modules/node-snap7/node_modules/bindings/bindings.js:76:44) s7.0 2017-03-10 12:25:46.116 error at require (internal/module.js:12:17) s7.0 2017-03-10 12:25:46.116 error at Module.require (module.js:353:17) s7.0 2017-03-10 12:25:46.116 error at Function.Module._load (module.js:300:12) s7.0 2017-03-10 12:25:46.116 error at Module.load (module.js:343:32) s7.0 2017-03-10 12:25:46.116 error at Object.Module._extensions..node (module.js:434:18) s7.0 2017-03-10 12:25:46.116 error at Error (native) s7.0 2017-03-10 12:25:46.116 error Error: Module did not self-register. s7.0 2017-03-10 12:25:46.108 error uncaught exception: Module did not self-register. host.zvmubn 2017-03-10 12:25:45.677 info instance system.adapter.s7.0 started with pid 7860 sql.0 2017-03-10 12:25:31.347 error TypeError: Cannot read property 'borrow' of undefined sql.0 2017-03-10 12:25:31.347 error Selected SQL DB was not installed properly: "sqlite". SQLite requires build tools on system. See README.md host.zvmubn 2017-03-10 12:25:15.668 info Restart adapter system.adapter.s7.0 because enabled host.zvmubn 2017-03-10 12:25:15.668 error instance system.adapter.s7.0 terminated with code 0 (OK) `
    node.js Version? npm Version?
    node -v
    npm -v
    Если команда node -v выдаёт ошибку, то выполнить:
    ln -s /usr/bin/nodejs /usr/bin/node
    js-controller: 1.5.7 / node.js: v8.15.1/ npm: 6.4.1
    admin: 3.6.0
    javascript: 4.1.10
    web: 2.4.1 vis: 1.1.10
    cloud: 2.6.2
    Server: DELL FX170 / linux: Debian 9.5 Stretch
    Adapter: MegaD-2561, Mega-ES…
    • F Offline
      ford7
      #165
      @Haus:
      node -v
      npm -v
      root@zvmubn:/opt/iobroker# node -v
      v4.8.0
      root@zvmubn:/opt/iobroker# npm -v
      2.15.11
      • BluefoxB Offline
        BluefoxB Offline
        #166
        @ford7:
        @Haus:
        node -v
        npm -v
        v4.8.0
        2.15.11
        При смене ноды нужно все бинарные пакеты перекомпилировать.
        Попробуй
        cd /opt/iobroker
        iobroker stop
        npm i node-gyp -g --force
        npm i iobroker.s7 --force
        npm i iobroker.sql --force
        iobroker start
        Может быть нужно выполнить как sudo. Зависит от того какая у тебя система
        • I Offline
          I Offline
          Izzm
          #167
          @Bluefox:
          @Izzm:
          Обновился до крайней версии. MQTT сервер стал заваливать сообщениями в лог.
          Перезапускал отдельно драйвер, перезагружал сервер целиком. Эффекта нет.
          js-controller 0.16.2
          Admin 1.7.0
          JS 3.2.6 А на самом деле эти переменные существуют?
          Нет, их не существует.Существует только в system.host.Server-Izzm.outputCount и system.host.Server-Izzm.inputCount.
          • F Offline
            ford7
            #168
            @Bluefox:
            Попробуй
            cd /opt/iobroker
            iobroker stop
            iobroker start
            Может быть нужно выполнить как sudo. Зависит от того какая у тебя система `
            Все получилось, спасибо!
              spectrekr
              #169
              при обновлении rflink драйвера, есть ошибки:
              npm install iobroker.rflink@1.1.2 --production --prefix "/opt/iobroker" (System call)
              node-pre-gyp
              ERR! Tried to download: https://github.com/voodootikigod/node-serialport/releases/download/3.1.2/serialport-v3.1.2-node-v46-linux-arm.tar.gz
              node-pre-gyp ERR! Pre-built binaries not found for serialport@3.1.2 and node@4.2.1 (node-v46 ABI) (falling back to source compile with node-gyp)
              node-pre-gyp
              ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v46-linux-arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@4.2.1 (node-v46 ABI) (falling back to source compile with node-gyp)
              Ошибки не критические, все ставится и работает, но мало ли.
              • BluefoxB Offline
                BluefoxB Offline
                #170
                @spectrekr:
                node-pre-gyp
                node-pre-gyp
                Ошибки не критические, все ставится и работает, но мало ли. `
                Это нормально. Просто нет для твоей системы готового бинарника и он переходит на компиляцию.
                • F Offline
                  ford7
                  #171
                  Не замечал ранее, что я делаю не так?
                  ! vis.0 2017-08-19 19:03:06.033 error No license found for vis. Please get one on https://iobroker.net !
                  • BluefoxB Offline
                    BluefoxB Offline
                    #172
                    @ford7:
                    ! vis.0 2017-08-19 19:03:06.033 error No license found for vis. Please get one on https://iobroker.net ! `
                    Пойди на https://iobroker.net и получи лицензию
                      maxmen
                      #173
                      После попытки переставить частоту обновления iobroker на "1раз в месяц" не могу зайти в веб-интерфейс (нажал "сохранить", после чего минут 15 ждал пока "перестанет крутиться шестерня").
                      Рестарт Iobroker не помогает, ребут системы тоже. Страница в браузере открывается бесконечно…
                      # iobroker -v
                      1.1.3
                      # node -v
                      v6.11.3
                      # npm -v
                      3.10.10
                      Нетстат показывает что iobroker слушает порт.
                      # netstat -tunlp
                      Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
                      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      29555/node-red
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1311/iobroker.js-co
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1311/iobroker.js-co
                      tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      1236/mysqld
                      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      799/nginx -g daemon
                      tcp        0      0 0.0.0.0:8881            0.0.0.0:*               LISTEN      915/motion
                      tcp        0      0 0.0.0.0:8882            0.0.0.0:*               LISTEN      915/motion
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      642/sshd
                      tcp6       0      0 :::5880                 :::*                    LISTEN      25028/apache2
                      tcp6       0      0 :::80                   :::*                    LISTEN      799/nginx -g daemon
                      tcp6       0      0 :::8081                 :::*                    LISTEN      31399/io.admin.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      29530/io.web.0
                      tcp6       0      0 :::8085                 :::*                    LISTEN      29513/io.megadd.0
                      tcp6       0      0 :::8086                 :::*                    LISTEN      29529/io.megadd.1
                      Куда копать? Опять переустанавливать iobroker?
                      • BluefoxB Offline
                        BluefoxB Offline
                        #174
                        @maxmen:
                        # iobroker -v
                        1.1.3
                        # node -v
                        v6.11.3
                        # npm -v
                        3.10.10
                        # netstat -tunlp
                        Куда копать? Опять переустанавливать iobroker? `
                        Что говорит "iobroker list instances" ?
                          maxmen
                          #175
                          @Bluefox:
                          Что говорит "iobroker list instances" ? `
                          root@cubietruck:~# iobroker list instances
                          events.js:160
                          throw er; // Unhandled 'error' event
                          Error: listen EADDRINUSE 127.0.0.1:9001
                          at Object.exports._errnoException (util.js:1020:11)
                          at exports._exceptionWithHostPort (util.js:1043:20)
                          at Server._listen2 (net.js:1258:14)
                          at listen (net.js:1294:10)
                          at net.js:1404:9
                          at _combinedTickCallback (internal/process/next_tick.js:83:11)
                          at process._tickCallback (internal/process/next_tick.js:104:9)
                          root@cubietruck:~#
                          error говорит. Как лечить?
                          Вроде бы это"Error: listen EADDRINUSE 127.0.0.1:9001" говорит о том что этот порт уже используется. Это странно, потому что я никаких изменений, которые могли привести к появлению еще каких-то служб, слушающих порты, не делал.
                          root@cubietruck:~# netstat -tunlp
                          ! Active Internet connections (only servers)
                          ! Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
                          ! tcp 0 0 0.0.0.0:1880 0.0.0.0:* LISTEN 19221/node-red
                          ! tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 31520/iobroker.js-c
                          ! tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 31520/iobroker.js-c
                          root@cubietruck:~# netstat -a -o | grep 9001
                          ! tcp 0 0 localhost:9001 : LISTEN off (0.00/0/0)
                          ! tcp 0 0 localhost:9001 localhost:36746 TIME_WAIT timewait (46.55/0/0)
                          ! tcp 0 0 localhost:50000 localhost:9001 ESTABLISHED off (0.00/0/0)
                          ! tcp 294 341548 localhost:9001 localhost:36938 ESTABLISHED unkn-4 (0.21/0/0)
                          ! tcp 0 0 localhost:54468 localhost:9001 ESTABLISHED off (0.00/0/0)
                          ! tcp 0 0 localhost:49990 localhost:9001 ESTABLISHED off (0.00/0/0)
                          ! tcp 0 0 localhost:9001 localhost:36866 TIME_WAIT timewait (46.66/0/0)
                          ! tcp 0 0 localhost:49930 localhost:9001 ESTABLISHED off (0.00/0/0)
                          ! tcp 0 0 localhost:50074 localhost:9001 ESTABLISHED off (0.00/0/0)
                          ! tcp 788238 49 localhost:36938 localhost:9001 ESTABLISHED on (0.24/0/0)
                          ! tcp 0 0 localhost:9001 localhost:50006 ESTABLISHED off (0.00/0/0)
                          ! tcp 0 0 localhost:9001 localhost:50074 ESTABLISHED off (0.00/0/0)
                          ! tcp 0 0 localhost:9001 localhost:54468 ESTABLISHED off (0.00/0/0)
                          ! tcp 0 0 localhost:9001 localhost:50000 ESTABLISHED off (0.00/0/0)
                          ! tcp 0 0 localhost:9001 localhost:36936 TIME_WAIT timewait (49.51/0/0)
                          ! tcp 0 0 localhost:9001 localhost:49930 ESTABLISHED off (0.00/0/0)
                          ! tcp 0 0 localhost:50006 localhost:9001 ESTABLISHED off (0.00/0/0)
                          ! tcp 0 0 localhost:9001 localhost:36940 TIME_WAIT timewait (49.66/0/0)
                          ! tcp 0 0 localhost:9001 localhost:49990 ESTABLISHED off (0.00/0/0)
                          ! root@cubietruck:~#
                          root@cubietruck:~# lsof -i tcp:9001
                          ! COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
                          ! io.megadd 2507 root 12u IPv4 3675984 0t0 TCP localhost:49990->localhost:9001 (ESTABLISHED)
                          ! io.node-r 2513 root 12u IPv4 3675998 0t0 TCP localhost:50000->localhost:9001 (ESTABLISHED)
                          ! io.web.0 9540 root 11u IPv4 3676213 0t0 TCP localhost:50074->localhost:9001 (ESTABLISHED)
                          ! io.admin. 12873 root 11u IPv4 3882172 0t0 TCP localhost:37720->localhost:9001 (ESTABLISHED)
                          ! node-red 19221 root 13u IPv4 3693851 0t0 TCP localhost:54468->localhost:9001 (ESTABLISHED)
                          ! io.megadd 20337 root 11u IPv4 3675902 0t0 TCP localhost:49930->localhost:9001 (ESTABLISHED)
                          ! io.discov 20343 root 11u IPv4 3676001 0t0 TCP localhost:50006->localhost:9001 (ESTABLISHED)
                          ! iobroker. 31520 root 12u IPv4 399252 0t0 TCP localhost:9001 (LISTEN)
                          ! iobroker. 31520 root 13u IPv4 3675985 0t0 TCP localhost:9001->localhost:49990 (ESTABLISHED)
                          ! iobroker. 31520 root 15u IPv4 3674837 0t0 TCP localhost:9001->localhost:50000 (ESTABLISHED)
                          ! iobroker. 31520 root 19u IPv4 3674841 0t0 TCP localhost:9001->localhost:50006 (ESTABLISHED)
                          ! iobroker. 31520 root 23u IPv4 3694711 0t0 TCP localhost:9001->localhost:54468 (ESTABLISHED)
                          ! iobroker. 31520 root 26u IPv4 3882173 0t0 TCP localhost:9001->localhost:37720 (ESTABLISHED)
                          ! iobroker. 31520 root 28u IPv4 3674924 0t0 TCP localhost:9001->localhost:50074 (ESTABLISHED)
                          ! iobroker. 31520 root 30u IPv4 3675914 0t0 TCP localhost:9001->localhost:49930 (ESTABLISHED)
                          Останавливаю Iobroker и на порту 9001 сервисов не видно. Но запустить его не получается из-за вышеописанной ошибки.
                          root@cubietruck:~# iobroker stop
                          Stopping iobroker controller daemon…
                          iobroker controller daemon stopped.
                          Exit code for "killall.sh": 0
                          ! tcp 0 0 127.0.0.1:3306 0.0.0.0:* LISTEN 1236/mysqld
                          ! tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 799/nginx -g daemon
                          ! tcp 0 0 0.0.0.0:8881 0.0.0.0:* LISTEN 915/motion
                          ! tcp 0 0 0.0.0.0:8882 0.0.0.0:* LISTEN 915/motion
                          ! tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 642/sshd
                          ! tcp6 0 0 :::5880 :::* LISTEN 25028/apache2
                          ! tcp6 0 0 :::80 :::* LISTEN 799/nginx -g daemon
                          ! tcp6 0 0 :::22 :::* LISTEN 642/sshd
                          ! udp 0 0 0.0.0.0:20466 0.0.0.0:* 679/dhclient
                          ! udp 0 0 0.0.0.0:68 0.0.0.0:* 679/dhclient
                          ! udp 0 0 192.168.55.2:123 0.0.0.0:* 820/ntpd
                          ! udp 0 0 127.0.0.1:123 0.0.0.0:* 820/ntpd
                          ! udp 0 0 0.0.0.0:123 0.0.0.0:* 820/ntpd
                          ! udp6 0 0 ::1:123 :::* 820/ntpd
                          ! udp6 0 0 fe80::45:6ff:fe42:9:123 :::* 820/ntpd
                          ! udp6 0 0 :::123 :::* 820/ntpd
                          ! udp6 0 0 :::27484 :::* 679/dhclient
                            maxmen
                            #176
                            Кто-нибудь сталкивался с такой ошибкой? Как лечить? Как понять, что именно занимает порт раньше времени?
                            Решение из темы http://downloads.iobroker.com/forum/vie … =12&t=7202
                            ` > There are two possible reasons for that:
                            • the port is really occupied by other application, like monkey done server or torrent,
                            • your system is so slowly, that in 2 seconds the server still too busy to send the response.
                            You can change this parameter to 5000 or even to 10000
                            https://github.com/ioBroker/ioBroker.js … t.json#L24
                            But in iobroker-data/iobroker.json `
                            Не помогает.
                            Памяти в системе достаточно, остановка большинства сервисов тоже не помогает. И при том же самом наборе служб до этого все работало нормально до изменения времени обновления.
                            Такое ощущение, что iobroker или пытается себя дважды запустить или еще что-то непонятное.
                            Переустанавливать его в 10-й раз желания нет, т.к. после каждой установки приходится заново все настраивать и где гарантия, что эта проблема опять не проявит себя…
                            • V Offline
                              V Offline
                              Vadim
                              #177
                              С ioBroker.admin 2.0.11 возникают проблемы с интерфейсом. В т.ч. наблюдалось подвисание OS раз в несколько часов.
                              Откатился.
                              В 2.0.7 проблемы не наблюдаются.
                              Orange pi plus2e
                              ARMBIAN 5.31 stable Debian GNU/Linux 8 (jessie) 3.4.113-sun8i
                              Memory usage: 14 % of 2014MB
                              • H Offline
                                Haus
                                #178
                                Версии с гит, устанавливаешь на свой страх и риск. Бывают исключения когда разработчик драйвера делает правки ошибок в релизе и советует поставить с гит. Стабильная версия 2.0.7
                                По первому скину
                                cd /opt/iobroker
                                iobroker upload admin
                                iobroker restart admin
                                admin: 3.6.0
                                javascript: 4.1.10
                                cloud: 2.6.2
                                  koh
                                  #179
                                  подскажите, люди добрые )
                                  перенес c горем пополам iobroker c win на linux
                                  все вроде завел, а вот с драйвером S7 проблема..
                                  в логе такие записи
                                  ! host.deb 2017-11-29 19:43:28.441 error instance system.adapter.s7.0 terminated with code 0 (OK)
                                  ! Caught 2017-11-29 19:43:28.440 error by controller[0]: at /opt/iobroker/node_modules/iobroker.s7/main.js:1158:33
                                  ! Caught 2017-11-29 19:43:28.440 error by controller[0]: at /opt/iobroker/node_modules/iobroker.s7/node_modules/async/lib/async.js:44:16
                                  ! Caught 2017-11-29 19:43:28.440 error by controller[0]: at done (/opt/iobroker/node_modules/iobroker.s7/node_modules/async/lib/async.js:246:17)
                                  ! Caught 2017-11-29 19:43:28.440 error by controller[0]: at /opt/iobroker/node_modules/iobroker.s7/node_modules/async/lib/async.js:52:16
                                  ! Caught 2017-11-29 19:43:28.440 error by controller[0]: at /opt/iobroker/node_modules/iobroker.s7/main.js:1187:74
                                  ! Caught 2017-11-29 19:43:28.440 error by controller[0]: TypeError: Cannot read property 'lsb' of undefined
                                  ! s7.0 2017-11-29 19:43:28.432 info terminating
                                  ! s7.0 2017-11-29 19:43:27.929 error at /opt/iobroker/node_modules/iobroker.s7/main.js:1158:33
                                  ! s7.0 2017-11-29 19:43:27.929 error at /opt/iobroker/node_modules/iobroker.s7/node_modules/async/lib/async.js:44:16
                                  ! s7.0 2017-11-29 19:43:27.929 error at done (/opt/iobroker/node_modules/iobroker.s7/node_modules/async/lib/async.js:246:17)
                                  ! s7.0 2017-11-29 19:43:27.929 error at /opt/iobroker/node_modules/iobroker.s7/node_modules/async/lib/async.js:52:16
                                  ! s7.0 2017-11-29 19:43:27.929 error at /opt/iobroker/node_modules/iobroker.s7/main.js:1187:74
                                  ! s7.0 2017-11-29 19:43:27.929 error TypeError: Cannot read property 'lsb' of undefined
                                  ! s7.0 2017-11-29 19:43:27.929 error uncaught exception: Cannot read property 'lsb' of undefined
                                  ! s7.0 2017-11-29 19:43:27.927 error Writing DB. Code #TypeError: Cannot read property 'lsb' of undefined
                                  js-controller: 1.2.3 / node.js: v6.12.0 / npm: 3.10.10
                                  admin: 2.0.9
                                  web: 2.1.9 vis: 1.0.4
                                  Server: Intel i5 / linux: Debian 9-amd64
                                  Adapter: Siemens LOGO!8.FS4 , Modbus TCP
                                    koh
                                    #180
                                    поставил версию 1.0.3 с гитхаба
                                    драйвер заработал, но теперь каждому номеру DB может соответствовать только один адрес
                                    т.е. раньше было так
                                    DB1 0
                                    DB1 2
                                    DB1 4
                                    DBx y
                                    а после обновления драйвер с такой адресацией не работает
                                    только так:
                                    DB1 0
                                    DB2 2
                                    DB3 4
                                    но значение читает только DB1
                                    Это баг? или придется всю адресацию как-то перенастраивать?
                                    версия 1.0.1 работает нормально
                                    ! s7.0 2017-11-30 16:15:10.210 info terminating
                                    ! s7.0 2017-11-30 16:15:09.717 error Writing DB: {"dbID":"DBs.DB11.PI_Set_vlSP","db":"DB11","dbType":"WORD","dbOffsetByte":12,"dbOffsetBit":0,"dbLength":"","_dbLsb":0,"n":9,"bufLength":2}
                                    ! s7.0 2017-11-30 16:15:09.717 error Writing DB. Code #RangeError: Index out of range
                                    ! s7.0 2017-11-30 16:15:09.717 error Writing DB: {"dbID":"DBs.DB10.am2","db":"DB10","dbType":"WORD","dbOffsetByte":1120,"dbOffsetBit":0,"dbLength":"","_dbLsb":20,"n":8,"bufLength":2}
                                    ! s7.0 2017-11-30 16:15:09.716 error Writing DB: {"dbID":"DBs.DB9.NAI2","db":"DB9","dbType":"WORD","dbOffsetByte":1264,"dbOffsetBit":0,"dbLength":"","_dbLsb":4,"n":7,"bufLength":2}
                                    ! s7.0 2017-11-30 16:15:09.716 error Writing DB. Code #RangeError: Index out of range
                                    ! s7.0 2017-11-30 16:15:09.716 error Writing DB: {"dbID":"DBs.DB8.am1","db":"DB8","dbType":"WORD","dbOffsetByte":1118,"dbOffsetBit":0,"dbLength":"","_dbLsb":6,"n":6,"bufLength":2}
                                    ! s7.0 2017-11-30 16:15:09.716 error Writing DB: {"dbID":"DBs.DB7.OnRemaningTimeShower","db":"DB7","dbType":"WORD","dbOffsetByte":10,"dbOffsetBit":0,"dbLength":"","_dbLsb":8,"n":5,"bufLength":2}
                                    ! s7.0 2017-11-30 16:15:09.716 error Writing DB: {"dbID":"DBs.DB6.OnDelayShower","db":"DB6","dbType":"WORD","dbOffsetByte":8,"dbOffsetBit":0,"dbLength":"","_dbLsb":10,"n":4,"bufLength":2}
                                    ! s7.0 2017-11-30 16:15:09.716 error Writing DB: {"dbID":"DBs.DB4.OnRemaningTimeToilet","db":"DB4","dbType":"WORD","dbOffsetByte":6,"dbOffsetBit":0,"dbLength":"","_dbLsb":1118,"n":3,"bufLength":2}
                                    ! s7.0 2017-11-30 16:15:09.716 error Writing DB: {"dbID":"DBs.DB3.OnDelayToilet","db":"DB3","dbType":"WORD","dbOffsetByte":4,"dbOffsetBit":0,"dbLength":"","_dbLsb":1264,"n":2,"bufLength":2}
                                    ! s7.0 2017-11-30 16:15:09.716 error Writing DB: {"dbID":"DBs.DB2.OffRemaningTime","db":"DB2","dbType":"WORD","dbOffsetByte":20,"dbOffsetBit":0,"dbLength":"","_dbLsb":1120,"n":1,"bufLength":2}
                                    ! s7.0 2017-11-30 16:15:09.715 error Writing DB. Code #RangeError: Index out of range
                                    ! s7.0 2017-11-30 16:15:09.715 error Writing DB: {"dbID":"DBs.DB1.OffDelay","db":"DB1","dbType":"WORD","dbOffsetByte":0,"dbOffsetBit":0,"dbLength":"","_dbLsb":12,"n":0,"bufLength":2}
                                    admin: 2.0.9
                                      koh
                                      #181
                                      ` > 1.0.4 (2017.11.30)
                                      (bluefox) Fix read of DB (range error) `
                                      Спасибо :D
                                      IOBroker супер. Спасибо разработчикам. Снимаю шляпу. Давно искал решение для себя, перепробовал кучу разного софта, включая промышленные скады.
                                      admin: 2.0.9
                                      • N Offline
                                        N Offline
                                        nnprject
                                        #182
                                        Не вижу список драйверов, "Обработка.." висит бесконечно. Admin обновил, JS-controller тоже, не помогает. Что еще проверить ?
                                        • I Offline
                                          I Offline
                                          instalator
                                          #183
                                          @nnprject:
                                          Не вижу список драйверов, "Обработка.." висит бесконечно. Admin обновил, JS-controller тоже, не помогает. Что еще проверить ? `
                                          попробуй репозиторий сменить на latest
                                          Высокий уровень Децибел вреден для здоровья!
                                          http://blog.instalator.ru/
