  4. Jeelink Adapter startet nicht mehr
    apollon77A
53 Beiträge 14 Kommentatoren 10.8k Aufrufe 13 Beobachtet
  • Chris76eC Chris76e
    @berchemer
    mit 14.x funktioniert es bei mir nicht
    > @serialport/bindings@2.0.8 install /opt/iobroker/node_modules/iobroker.jeelink        /node_modules/@serialport/bindings
    > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
    prebuild-install WARN install No prebuilt binaries found (target=14.18.1 runtime        =node arch=x64 libc= platform=linux)
    make: Verzeichnis „/opt/iobroker/node_modules/iobroker.jeelink/node_modules/@ser        ialport/bindings/build“ wird betreten
      CXX(target) Release/obj.target/bindings/src/serialport.o
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_ME        THOD_ARGS_TYPE)’:
    ../src/serialport.cpp:78:69: warning: cast between incompatible function types f        rom ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {a        ka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOp        en);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_        METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:135:71: warning: cast between incompatible function types        from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {        aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
     uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUp        date);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_M        ETHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:175:70: warning: cast between incompatible function types        from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {        aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterCl        ose);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_M        ETHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:215:70: warning: cast between incompatible function types        from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {        aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFl        ush);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_MET        HOD_ARGS_TYPE)’:
    ../src/serialport.cpp:270:68: warning: cast between incompatible function types        from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {        aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet        );
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_MET        HOD_ARGS_TYPE)’:
    ../src/serialport.cpp:314:68: warning: cast between incompatible function types        from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {        aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet        );
    ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
    ../src/serialport.cpp:329:96: error: no matching function for call to ‘v8::Objec        t::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
     an::New<v8::String>("cts").ToLocalChecked(), Nan::New<v8::Boolean>(data->cts));
    In file included from /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h        :67,
                     from ../node_modules/nan/nan.h:58,
                     from ../src/./serialport.h:6,
                     from ../src/serialport.cpp:1:
    /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3670:37: note: candidat        e: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>        , v8::Local<v8::Value>)’
       V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context,
    /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3670:37: note:   candid        ate expects 3 arguments, 2 provided
    /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3673:37: note: candidat        e: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, uint32_t, v8::Local<        v8::Value>)’
       V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index,
    /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3673:37: note:   candid        ate expects 3 arguments, 2 provided
    ../src/serialport.cpp:330:96: error: no matching function for call to ‘v8::Objec        t::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
     an::New<v8::String>("dsr").ToLocalChecked(), Nan::New<v8::Boolean>(data->dsr));
    ../src/serialport.cpp:331:96: error: no matching function for call to ‘v8::Objec        t::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
     an::New<v8::String>("dcd").ToLocalChecked(), Nan::New<v8::Boolean>(data->dcd));
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan:        :NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:363:76: warning: cast between incompatible function types        from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {        aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
     eue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGe        tBaudRate);
    ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
    ../src/serialport.cpp:378:106: error: no matching function for call to ‘v8::Obje        ct::Set(v8::Local<v8::String>, Nan::imp::IntegerFactory<v8::Integer>::return_t)’
     ::String>("baudRate").ToLocalChecked(), Nan::New<v8::Integer>(data->baudRate));
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_M        ETHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:409:70: warning: cast between incompatible function types        from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {        aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDr        ain);
    ../src/serialport.cpp: At global scope:
    ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of        ‘ToParityEnum’ [-Wparentheses]
     SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
    ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of        ‘ToStopBitEnum’ [-Wparentheses]
     SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
    In file included from ../node_modules/nan/nan.h:58,
    /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:787:43: warning: cast        between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION        _ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_fu        nc’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast        -function-type]
           (node::addon_register_func) (regfunc),                          \
    /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:821:3: note: in expan        sion of macro ‘NODE_MODULE_X’
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(serialport, init);
    make: *** [bindings.target.mk:114: Release/obj.target/bindings/src/serialport.o]        Fehler 1
    make: Verzeichnis „/opt/iobroker/node_modules/iobroker.jeelink/node_modules/@ser        ialport/bindings/build“ wird verlassen
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_module        s/node-gyp/lib/build.js:194:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_proces        s.js:282:12)
    gyp ERR! System Linux 4.19.0-18-amd64
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gy        p/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/iobroker.jeelink/node_modules/@serialpor        t/bindings
    gyp ERR! node -v v14.18.1
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! @serialport/bindings@2.0.8 install: `prebuild-install --tag-prefix @ser        ialport/bindings@ || node-gyp rebuild`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the @serialport/bindings@2.0.8 install script.
    npm ERR! This is probably not a problem with npm. There is likely additional log        ging output above.
    IdleBitI
    IdleBitI
    IdleBit
    schrieb am zuletzt editiert von IdleBit
    Kann mal Jemand den Adapter von meinen Git aus Testen?
    Habe keine Hardware dafür da..
    https://github.com/o0shojo0o/ioBroker.jeelink
    #Edit
    Ich habe mir mal einen JeeLink Gateway gelötet und es tut wieder mit einer neuen Version des Serial Paketes und Node v14.
    Habe mal einen Pull requests im Git erstellt!
    S Chris76eC Ingo 0I B E 7 Antworten Letzte Antwort
    • IdleBitI IdleBit
      #Edit
      S
      S
      stefande
      @idlebit
      Ich hab deine Version unter V12 installiert, danach auf die V14 umgestellt.
      Das Rebuild funktionierte automatisch.
      Daumen hoch. Deine Version läuft.
      Vielen Dank
      • IdleBitI IdleBit
        #Edit
        Chris76eC
        Chris76eC
        Chris76e
        @idlebit
        Funktioniert, vielen Dank 👍 👍 👍
        • IdleBitI IdleBit
          #Edit
          Ingo 0I
          Ingo 0I
          Ingo 0
          @idlebit
          Funktioniert auch bei mir wieder.
          Hatte meine 7 LaCrosse DTH Sensoren schon fast abgeschrieben.
          Kommen noch aus meiner FHEM Zeit und funktionieren sehr zuverlässig.
          Vielen Dank. 👍
          IdleBitI 1 Antwort Letzte Antwort
          • Ingo 0I Ingo 0
            @idlebit
            Vielen Dank. 👍
            IdleBitI
            IdleBitI
            IdleBit
            @ingo-0 Ja im FEHM hatte ich sie auch in Nutzung, und seit gestern wieder einen Testweise :D
            • IdleBitI IdleBit
              #Edit
              B
              B
              Berchemer
              @idlebit sagte in Jeelink Adapter startet nicht mehr:
              #Edit
              Danke für die Arbeit 👍
              Werde es die Tage, auch versuchen zu installieren, gehe aber mal davon aus, dass es wie bei den Anderen auch bei mir funktionieren wird.
              Zumindest kann man jetzt sicher sein, dass ggf. noch etwas kurzfristig angepasst werden kann, sollte @foxthefox nicht so schnell reagieren können. Hoffentlich wird es dann aber auch in den Originalcode eingepflegt, damit man nicht zwischen mehreren Versionen hin und her springen muss 😊
              • IdleBitI IdleBit
                #Edit
                B
                B
                Berchemer
                #Edit
                @idlebit
                Recht herzlichen Dank.
                Habe nodejs auf 14 upgedatet, den bearbeiteten Adapter von Dir installiert und nun startet auch der Jeelink-Adapter (immer noch als v0.1.3) wieder.
                Auch die Werte werden in Empfang genommen und den Geräten ordentlich zugewiesen :-)
                Jetzt müsste man die geänderte Version nur noch offizeill übernehmen und ggf. die Versionsnummer anpassen.
                • B Berchemer
                  #Edit
                  @idlebit
                  IdleBitI
                  IdleBitI
                  IdleBit
                  @berchemer sagte in Jeelink Adapter startet nicht mehr:
                  Das liegt leider nicht in meiner Hand, ein Pull requests ist erstellt, der Rest liegt bei dem Maintainer.
                  • IdleBitI IdleBit
                    B
                    B
                    Berchemer
                    schrieb am zuletzt editiert von Berchemer
                    @Homoran : Meinst Du, Du könntest das vielleicht bitte irgendwie arrangieren? 🙏 😻 ;-)
                    • B Berchemer
                      nöö, das kann nur der Maintainer
                      und der scheint seit Monaten verschollen zu sein.
                      Da kann man nur hoffen, dass es ihm gut geht
                        B
                        B
                        Berchemer
                        @homoran sagte in Jeelink Adapter startet nicht mehr:
                        und der scheint seit Minaten verschollen zu sein.
                        Schade 😢
                        • IdleBitI IdleBit
                          #Edit
                          E
                          E
                          ErRi
                          @idlebit
                          👍 Super, bei mir funktioniert es auch wieder. Vielen Dank
                          MfG Erhard
                          Win11 Notebook, Lenovo MiniPC mit Proxmox, iobroker, Raspberrymatic, Maria DB, OMV
                          Fritzbox 7490, 1 Jeelink, 12 HM Rolladenschalter, 1 HM Energiezähler, VU UNO SE :)
                          P 1 Antwort Letzte Antwort
                          • E ErRi
                            @idlebit
                            P
                            P
                            photographix
                            @IdleBit
                            ich bedanke mich auch das es nach dem Upgrade auf Node 14 eine Lösung gibt. 👍
                            ioBroker in Docker auf Raspberry PI 4 / 4GB
                            CCU2 mit Strommessung, JeeLink v3c für TX29DHT-ITs, Maxtox's RF-Link 868 Mhz Arduino, Tradfri Lampen, Shellys
                            • IdleBitI IdleBit
                              #Edit
                              D
                              D
                              Dan_Ce
                              @idlebit
                              Sorry für meine vermeintliche Anfängerfrage: Wie kann ich denn die bestehende Version auf deine updaten?
                              Und werde ich zukünftig wieder über die update-Funktion des Adapters in io-Broker auf den "Original"-Adapter wechseln können, sobald dieser den Fix ebenfalls beinhaltet?
                              Danke!
                              • D Dan_Ce
                                @idlebit
                                Danke!
                                Thomas BraunT
                                Thomas BraunT
                                @dan_ce sagte in Jeelink Adapter startet nicht mehr:
                                Ja, sobald die Versionsnummer in deinem Verwahrort höher als die jetzige im git ist. Dann wird automatisch die höhere Version bevorzugt
                                Chris76eC 1 Antwort Letzte Antwort
                                  Chris76eC
                                  Chris76eC
                                  Chris76e
                                  Es gibt ein update von foxthefox im Github.
                                  https://github.com/foxthefox/ioBroker.jeelink
                                  derAugeD 1 Antwort Letzte Antwort
                                    derAugeD
                                    derAugeD
                                    derAuge
                                    Habe heute auch meine Installation auf NODE.JS: V14.18.3 upgedatet.
                                    Und :-( Adapter funktioniert nicht mehr.
                                    Nach einigen vergeblichen Neu Installationen habe ich mich auf die Suche gemacht und den Beitrag hier gefunden.
                                    Es ist schade das nach solange Zeit man Adapter über die GIT-Install Funktion updaten muss da sie nicht im Stabil-Reposity erscheinen.
                                    Nun laufen meine 10 Sensoren wieder
                                    Jürgen
                                    E 1 Antwort Letzte Antwort
                                    • derAugeD derAuge
                                      Jürgen
                                      E
                                      E
                                      euro
                                      Hallo in die Runde
                                      bin aktuell im Umzug von FHEM auf ioBroker
                                      soweit läuft bisher alles, bis auf die jeelink Temperatursensoren
                                      hab zuerst die normale Installation am pi4 probiert und danach den Hinweis zu unsafe gefunden, was leider ebenfalls nicht funktioniert hat. Den Stick finde ich am pi und hab ihn erfolgreich in den Docker Container durchgereicht (analog dem enocean STick)
                                      hier mal ein Log Auszug
                                      jeelink.txt
                                      hat da noch jemand eine Idee zu ?
                                      mfg
                                      STefan
                                      • E euro
                                        Hallo in die Runde
                                        jeelink.txt
                                        mfg
                                        STefan
                                        Thomas BraunT
                                        Thomas BraunT
                                        @euro
                                        Eine Idee ist:
                                        root@iobroker:/opt/iobroker# sudo npm install
                                        Oberquark. Zunächst nie als root rumeimern. Dann nie npm mit sudo verwenden. (Warum eigentlich sudo? Willst du noch rootiger werden?)
                                        Installation geht in der Kommandozeile so:
                                        iobroker url https://github.com/foxthefox/ioBroker.jeelink
                                        Sollte dann so aussehen:
                                        $ iobroker url https://github.com/foxthefox/ioBroker.jeelink --host chet
                                        install foxthefox/ioBroker.jeelink#4b07255327a59be85c853ff6725e12617139c2d4
                                        NPM version: 8.3.1
                                        Installing foxthefox/ioBroker.jeelink#4b07255327a59be85c853ff6725e12617139c2d4... (System call)
                                        added 27 packages in 31s
                                        54 packages are looking for funding run `npm fund` for details
                                        upload [4] jeelink.admin /opt/iobroker/node_modules/iobroker.jeelink/admin/index_m.html index_m.html text/html
                                        upload [3] jeelink.admin /opt/iobroker/node_modules/iobroker.jeelink/admin/jeelab_logo.png jeelab_logo.png image/png
                                        upload [2] jeelink.admin /opt/iobroker/node_modules/iobroker.jeelink/admin/style.css style.css text/css
                                        upload [1] jeelink.admin /opt/iobroker/node_modules/iobroker.jeelink/admin/template.png template.png image/png
                                        upload [0] jeelink.admin /opt/iobroker/node_modules/iobroker.jeelink/admin/words.js words.js application/javascript
                                        Process exited with code 0
                                          @euro
                                          Eine Idee ist:
                                          NPM version: 8.3.1
                                          E
                                          E
                                          euro
                                          Danke Thomas, linux noob halt :man-gesturing-ok:
                                          aber kaum macht man es richtig .. gehts auch - zumindest teils
                                          root@iobroker:/opt/iobroker# iobroker url https://github.com/foxthefox/ioBroker.jeelink
                                          NPM version: 6.14.16
                                          npm install foxthefox/ioBroker.jeelink#4b07255327a59be85c853ff6725e12617139c2d4 --loglevel error --prefix "/opt/iobroker" (System call)
                                          upload [4] jeelink.admin /opt/iobroker/node_modules/iobroker.jeelink/admin/words.js words.js application/javascript
                                          upload [3] jeelink.admin /opt/iobroker/node_modules/iobroker.jeelink/admin/template.png template.png image/png
                                          upload [1] jeelink.admin /opt/iobroker/node_modules/iobroker.jeelink/admin/jeelab_logo.png jeelab_logo.png image/png
                                          upload [0] jeelink.admin /opt/iobroker/node_modules/iobroker.jeelink/admin/index_m.html index_m.html text/html
                                          Unter Objekte sehe ich jeelink (evtl auch aus einem vorigen Installationsversuch?), allerdings noch keine Instanz
                                          ich such mal noch dazu hier
                                          83.9k
