  4. [gelöst] Fehler in Adapterinstallation
    6.3k
33 Beiträge 4 Kommentatoren 3.3k Aufrufe 3 Beobachtet
  • S sanda
    @thomas-braun said in Fehler in Adapterinstallation:
    iobroker fix
    Das hat nun etwas länger mit der Ausgabe gedauert.
    Zu viele Errormeldunge 😠
    sudo -H -u iobroker npm install iobroker.js-controller
    npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
    The authenticity of host 'github.com (140.82.121.4)' can't be established.me/iobroker/.npm/_locks/staging-66d2468782e8ffc7
    ECDSA key fingerprint is SHA256:p2QAMXNIC1TJYWeIOttrVc98/R1BUFWu3/LiyKgUfQM.
    Are you sure you want to continue connecting (yes/no)? [       ...........] | extract:iobroker.js-controller: verb lock usi[            ......] \ extract:npm: sill extract npm@7.11.1 extracted to /opt/iobroker/node_modules/.staging/npm-fc55516d
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/common@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
    npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/core@>= 5.0.0 but none is installed. You must install peer dependencies yourself.
    npm WARN typedoc@0.20.28 requires a peer of typescript@3.9.x || 4.0.x || 4.1.x but none is installed. You must install peer dependencies yourself.
    npm ERR! Error while executing:
    npm ERR! /usr/bin/git ls-remote -h -t ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git
    npm ERR!
    npm ERR! Host key verification failed.
    npm ERR! fatal: Could not read from remote repository.
    npm ERR!
    npm ERR! Please make sure you have the correct access rights
    npm ERR! and the repository exists.
    npm ERR!
    npm ERR! exited with error code: 128
    npm ERR!     /home/iobroker/.npm/_logs/2021-11-30T13_48_08_408Z-debug.log
    @sanda sagte in Fehler in Adapterinstallation:
    Da hast du aber mal mit einer npm>6 herumhantiert...
    Kannst du mal bitte die ungekürzte Ausgabe von
    cd /opt/iobroker
    npm ls
    geben?
    HomoranH S 2 Antworten Letzte Antwort
      cd /opt/iobroker
      npm ls
      geben?
      @thomas-braun sagte in Fehler in Adapterinstallation:
      also /opt/iobroker/package-lock.json löschen
        cd /opt/iobroker
        npm ls
        geben?
        sanda
        Hier die Ausgabe, passt nicht mal ins Terminal
        │ │ ├── cookie@0.4.1
        │ │ ├── cookie-signature@1.0.6 deduped
        │ │ ├── debug@2.6.9 deduped
        │ │ ├── depd@2.0.0
        │ │ ├── on-headers@1.0.2 deduped
        │ │ ├── parseurl@1.3.3 deduped
        │ │ ├── safe-buffer@5.2.1
        │ │ └── uid-safe@2.1.5 deduped
        │ ├── iobroker.simple-api@2.6.1 deduped
        │ ├── iobroker.socketio@3.1.4 deduped
        │ ├─┬ mime-types@2.1.32
        │ │ └── mime-db@1.49.0
        │ ├── passport@0.4.1 deduped
        │ ├── passport-local@1.0.0 deduped
        │ ├── passport.socketio@3.7.0 deduped
        │ ├── request@2.88.2 deduped
        │ ├─┬ socket.io-client@2.3.0
        │ │ ├── backo2@1.0.2
        │ │ ├── base64-arraybuffer@0.1.5
        │ │ ├── component-bind@1.0.0
        │ │ ├── component-emitter@1.2.1
        │ │ ├─┬ debug@4.1.1
        │ │ │ └── ms@2.1.2
        │ │ ├─┬ engine.io-client@3.4.3
        │ │ │ ├── component-emitter@1.3.0
        │ │ │ ├── component-inherit@0.0.3
        │ │ │ ├─┬ debug@4.1.1
        │ │ │ │ └── ms@2.1.2
        │ │ │ ├── engine.io-parser@2.2.0 deduped
        │ │ │ ├── has-cors@1.1.0 deduped
        │ │ │ ├── indexof@0.0.1 deduped
        │ │ │ ├── parseqs@0.0.5 deduped
        │ │ │ ├── parseuri@0.0.5 deduped
        │ │ │ ├─┬ ws@6.1.4
        │ │ │ │ └── async-limiter@1.0.1 deduped
        │ │ │ ├── xmlhttprequest-ssl@1.5.5
        │ │ │ └── yeast@0.1.2
        │ │ ├── has-binary2@1.0.3 deduped
        │ │ ├── object-component@0.0.3
        │ │ ├─┬ parseqs@0.0.5
        │ │ │ └─┬ better-assert@1.0.2
        │ │ │   └── callsite@1.0.0 deduped
        │ │ ├─┬ parseuri@0.0.5
        │ │ │ └── better-assert@1.0.2 deduped
        │ │ ├─┬ socket.io-parser@3.3.0
        │ │ │ ├── component-emitter@1.2.1 deduped
        │ │ │ ├─┬ debug@3.1.0
        │ │ │ │ └── ms@2.0.0
        │ │ │ └── isarray@2.0.1 deduped
        │ │ └── to-array@0.1.4
        │ └── xtend@4.0.2
        ├─┬ iobroker.zigbee@1.5.6
        │ ├── @iobroker/adapter-core@2.5.1 deduped
        │ ├─┬ tar@6.1.0
        │ │ ├── chownr@2.0.0
        │ │ ├── fs-minipass@2.1.0 deduped
        │ │ ├── minipass@3.1.3 deduped
        │ │ ├─┬ minizlib@2.1.2
        │ │ │ ├── minipass@3.1.3 deduped
        │ │ │ └── yallist@4.0.0 deduped
        │ │ ├── mkdirp@1.0.4
        │ ├── typescript@4.4.4 deduped
        │ ├─┬ zigbee-herdsman@0.13.110
        │ │ ├── @babel/cli@7.13.0 extraneous
        │ │ ├── @babel/preset-env@7.13.9 extraneous
        │ │ ├── @babel/preset-typescript@7.13.0 extraneous
        │ │ ├─┬ @serialport/bindings@9.0.4
        │ │ │ ├─┬ @serialport/binding-abstract@9.0.7
        │ │ │ │ └── debug@4.3.1 deduped
        │ │ │ ├─┬ @serialport/parser-readline@9.0.7
        │ │ │ │ └── @serialport/parser-delimiter@9.0.7 deduped
        │ │ │ ├─┬ bindings@1.5.0
        │ │ │ │ └── file-uri-to-path@1.0.0
        │ │ │ ├── debug@4.3.1 deduped
        │ │ │ ├── nan@2.14.2
        │ │ │ └─┬ prebuild-install@6.0.1
        │ │ │   ├── detect-libc@1.0.3
        │ │ │   ├── expand-template@2.0.3
        │ │ │   ├── github-from-package@0.0.0
        │ │ │   ├── minimist@1.2.5
        │ │ │   ├── mkdirp-classic@0.5.3
        │ │ │   ├── napi-build-utils@1.0.2
        │ │ │   ├─┬ node-abi@2.20.0
        │ │ │   │ └── semver@5.7.1
        │ │ │   ├── noop-logger@0.1.1
        │ │ │   ├─┬ npmlog@4.1.2
        │ │ │   │ ├─┬ are-we-there-yet@1.1.5
        │ │ │   │ │ ├── delegates@1.0.0
        │ │ │   │ │ └─┬ readable-stream@2.3.7
        │ │ │   │ │   ├── core-util-is@1.0.2
        │ │ │   │ │   ├── inherits@2.0.4 deduped
        │ │ │   │ │   ├── isarray@1.0.0
        │ │ │   │ │   ├── process-nextick-args@2.0.1
        │ │ │   │ │   ├── safe-buffer@5.1.2 deduped
        │ │ │   │ │   ├─┬ string_decoder@1.1.1
        │ │ │   │ │   │ └── safe-buffer@5.1.2 deduped
        │ │ │   │ │   └── util-deprecate@1.0.2
        │ │ │   │ ├── console-control-strings@1.1.0
        │ │ │   │ ├─┬ gauge@2.7.4
        │ │ │   │ │ ├── aproba@1.2.0
        │ │ │   │ │ ├── console-control-strings@1.1.0 deduped
        │ │ │   │ │ ├── has-unicode@2.0.1
        │ │ │   │ │ ├── object-assign@4.1.1 deduped
        │ │ │   │ │ ├── signal-exit@3.0.3
        │ │ │   │ │ ├─┬ string-width@1.0.2
        │ │ │   │ │ │ ├── code-point-at@1.1.0
        │ │ │   │ │ │ ├─┬ is-fullwidth-code-point@1.0.0
        │ │ │   │ │ │ │ └── number-is-nan@1.0.1
        │ │ │   │ │ │ └── strip-ansi@3.0.1 deduped
        │ │ │   │ │ ├─┬ strip-ansi@3.0.1
        │ │ │   │ │ │ └── ansi-regex@2.1.1
        │ │ │   │ │ └─┬ wide-align@1.1.3
        │ │ │   │ │   └── string-width@1.0.2 deduped
        │ │ │   │ └── set-blocking@2.0.0
        │ │ │   ├─┬ pump@3.0.0
        │ │ │   │ ├─┬ end-of-stream@1.4.4
        │ │ │   │ │ └── once@1.4.0 deduped
        │ │ │   │ └─┬ once@1.4.0
        │ │ │   │   └── wrappy@1.0.2
        │ │ │   ├─┬ rc@1.2.8
        │ │ │   │ ├── deep-extend@0.6.0
        │ │ │   │ ├── ini@1.3.8
        │ │ │   │ ├── minimist@1.2.5 deduped
        │ │ │   │ └── strip-json-comments@2.0.1
        │ │ │   ├─┬ simple-get@3.1.0
        │ │ │   │ ├─┬ decompress-response@4.2.1
        │ │ │   │ │ └── mimic-response@2.1.0
        │ │ │   │ ├── once@1.4.0 deduped
        │ │ │   │ └── simple-concat@1.0.1
        │ │ │   ├─┬ tar-fs@2.1.1
        │ │ │   │ ├── chownr@1.1.4
        │ │ │   │ ├── mkdirp-classic@0.5.3 deduped
        │ │ │   │ ├── pump@3.0.0 deduped
        │ │ │   │ └─┬ tar-stream@2.2.0
        │ │ │   │   ├─┬ bl@4.1.0
        │ │ │   │   │ ├─┬ buffer@5.7.1
        │ │ │   │   │ │ ├── base64-js@1.5.1
        │ │ │   │   │ │ └── ieee754@1.2.1
        │ │ │   │   │ └─┬ readable-stream@3.6.0
        │ │ │   │   │   ├── string_decoder@1.1.1 deduped
        │ │ │   │   │   └── util-deprecate@1.0.2 deduped
        │ │ │   │   ├── end-of-stream@1.4.4 deduped
        │ │ │   │   ├── fs-constants@1.0.0
        │ │ │   ├─┬ tunnel-agent@0.6.0
        │ │ │   └── which-pm-runs@1.0.0
        │ │ ├── @types/debounce@1.2.0 extraneous
        │ │ ├── @types/debug@4.1.5 extraneous
        │ │ ├── @types/jest@26.0.20 extraneous
        │ │ ├── @types/mz@2.7.3 extraneous
        │ │ ├── @types/nedb@1.8.11 extraneous
        │ │ ├── @types/serialport@8.0.1 extraneous
        │ │ ├── @typescript-eslint/eslint-plugin@4.16.1 extraneous
        │ │ ├── @typescript-eslint/parser@4.16.1 extraneous
        │ │ ├── debounce@1.2.0
        │ │ ├─┬ debug@4.3.1
        │ │ │ └── ms@2.1.2
        │ │ ├── eslint@7.21.0 extraneous
        │ │ ├── fast-deep-equal@3.1.3
        │ │ ├── jest@26.6.3 extraneous
        │ │ ├── mixin-deep@2.0.1
        │ │ ├─┬ mz@2.7.0
        │ │ │ ├── any-promise@1.3.0
        │ │ │ └─┬ thenify-all@1.6.0
        │ │ │   └─┬ thenify@3.3.1
        │ │ │     └── any-promise@1.3.0 deduped
        │ │ ├─┬ serialport@9.0.6
        │ │ │ ├─┬ @serialport/binding-mock@9.0.7
        │ │ │ │ ├── @serialport/binding-abstract@9.0.7 deduped
        │ │ │ ├── @serialport/bindings@9.0.4 deduped
        │ │ │ ├── @serialport/parser-byte-length@9.0.7
        │ │ │ ├── @serialport/parser-cctalk@9.0.7
        │ │ │ ├── @serialport/parser-delimiter@9.0.7
        │ │ │ ├── @serialport/parser-inter-byte-timeout@9.0.7
        │ │ │ ├── @serialport/parser-readline@9.0.7 deduped
        │ │ │ ├── @serialport/parser-ready@9.0.7
        │ │ │ ├── @serialport/parser-regex@9.0.7
        │ │ │ ├─┬ @serialport/stream@9.0.7
        │ │ ├── slip@1.0.2
        │ │ ├── typedoc@0.20.28 extraneous
        │ │ ├── typedoc-plugin-markdown@3.6.0 extraneous
        │ │ ├── typedoc-plugin-no-inherit@1.2.0 extraneous
        │ │ ├── typedoc-plugin-sourcefile-url@1.0.6 extraneous
        │ │ └── UNMET PEER DEPENDENCY typescript@4.2.2 extraneous
        │ └─┬ zigbee-herdsman-converters@14.0.162
        │   ├─┬ axios@0.21.1
        │   │ └── follow-redirects@1.14.1
        │   ├── buffer-crc32@0.2.13
        │   ├── eslint@7.27.0 extraneous
        │   ├── eslint-config-google@0.14.0 extraneous
        │   ├── eslint-plugin-jest@24.3.6 extraneous
        │   ├─┬ https-proxy-agent@5.0.0
        │   │ ├─┬ agent-base@6.0.2
        │   │ └─┬ debug@4.3.1
        │   │   └── ms@2.1.2
        │   ├─┬ tar-stream@2.2.0
        │   │ ├─┬ bl@4.1.0
        │   │ │ └── readable-stream@3.6.0 deduped
        │   │   ├─┬ string_decoder@1.3.0
        │   │   │ └── safe-buffer@5.2.1
        │   └─┬ zigbee-herdsman@0.13.107
        │     │ ├── nan@2.14.2
        │     │   ├─┬ pump@3.0.0
        │     │   ├─┬ rc@1.2.8
        │     │   │ ├── ini@1.3.8
        │     │   │   ├─┬ bl@4.1.0
        │     ├─┬ debug@4.3.1
        │     │ └── ms@2.1.2
        │     ├─┬ mz@2.7.0
        │     ├── slip@1.0.2
        ├── semver@5.7.1
        └─┬ yargs@7.1.1
          ├── camelcase@3.0.0
          ├─┬ cliui@3.2.0
          │ ├── string-width@1.0.2 deduped
          │ └─┬ wrap-ansi@2.1.0
          ├── decamelize@1.2.0
          ├── get-caller-file@1.0.3
          ├─┬ os-locale@1.4.0
          │ └─┬ lcid@1.0.0
          │   └── invert-kv@1.0.0
          ├─┬ read-pkg-up@1.0.1
          │ ├─┬ find-up@1.1.2
          │ │ ├─┬ path-exists@2.1.0
          │ │ │ └── pinkie-promise@2.0.1 deduped
          │ │ └─┬ pinkie-promise@2.0.1
          │ │   └── pinkie@2.0.4
          │ └─┬ read-pkg@1.1.0
          │   ├─┬ load-json-file@1.1.0
          │   │ ├── graceful-fs@4.2.4 deduped
          │   │ ├─┬ parse-json@2.2.0
          │   │ │ └── error-ex@1.3.2 deduped
          │   │ ├── pify@2.3.0
          │   │ ├── pinkie-promise@2.0.1 deduped
          │   │ └─┬ strip-bom@2.0.0
          │   │   └── is-utf8@0.2.1
          │   ├─┬ normalize-package-data@2.5.0
          │   │ ├── hosted-git-info@2.8.8
          │   │ ├─┬ resolve@1.17.0
          │   │ │ └── path-parse@1.0.6 deduped
          │   │ ├── semver@5.7.1 deduped
          │   │ └── validate-npm-package-license@3.0.4 deduped
          │   └─┬ path-type@1.1.0
          │     ├── pify@2.3.0 deduped
          ├── require-directory@2.1.1
          ├── require-main-filename@1.0.1
          ├── set-blocking@2.0.0
          ├── which-module@1.0.0
          ├── y18n@3.2.1
          └─┬ yargs-parser@5.0.0-security.0
            ├── camelcase@3.0.0 deduped
            └─┬ object.assign@4.1.0
              ├── define-properties@1.1.3 deduped
              ├── function-bind@1.1.1 deduped
              ├── has-symbols@1.0.1
              └── object-keys@1.1.1
        npm ERR! missing: iobroker.sourceanalytix@git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#f64a6083778ce5b12274eadb73e78cf28568fccc, required by iobroker.inst@2.0.3
        npm ERR! peer dep missing: @angular/common@>= 5.0.0, required by xmlhttprequest-ts@1.0.1
        npm ERR! peer dep missing: @angular/core@>= 5.0.0, required by xmlhttprequest-ts@1.0.1
        npm ERR! missing: xmlhttprequest@^1.8.0, required by iobroker.javascript@5.2.13
        npm ERR! missing: cron@1.8.2, required by iobroker.sourceanalytix@git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#f64a6083778ce5b12274eadb73e78cf28568fccc
        npm ERR! missing: iobroker-adapter-helpers@0.0.8, required by iobroker.sourceanalytix@git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#f64a6083778ce5b12274eadb73e78cf28568fccc
        npm ERR! missing: @sentry/node@5.30.0, required by iobroker.sourceanalytix@git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#f64a6083778ce5b12274eadb73e78cf28568fccc
        npm ERR! missing: npm@7.11.1, required by iobroker.sourceanalytix@git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#f64a6083778ce5b12274eadb73e78cf28568fccc
        npm ERR! missing: node-schedule@1.3.2, required by iobroker.sourceanalytix@git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#f64a6083778ce5b12274eadb73e78cf28568fccc
        npm ERR! missing: @sentry/core@5.30.0, required by @sentry/node@5.30.0
        npm ERR! missing: @sentry/hub@5.30.0, required by @sentry/node@5.30.0
        npm ERR! missing: @sentry/tracing@5.30.0, required by @sentry/node@5.30.0
        npm ERR! missing: @sentry/types@5.30.0, required by @sentry/node@5.30.0
        npm ERR! missing: @sentry/utils@5.30.0, required by @sentry/node@5.30.0
        npm ERR! missing: cookie@0.4.1, required by @sentry/node@5.30.0
        npm ERR! missing: @sentry/hub@5.30.0, required by @sentry/core@5.30.0
        npm ERR! missing: @sentry/minimal@5.30.0, required by @sentry/core@5.30.0
        npm ERR! missing: @sentry/types@5.30.0, required by @sentry/core@5.30.0
        npm ERR! missing: @sentry/utils@5.30.0, required by @sentry/core@5.30.0
        npm ERR! missing: @sentry/hub@5.30.0, required by @sentry/minimal@5.30.0
        npm ERR! missing: @sentry/types@5.30.0, required by @sentry/minimal@5.30.0
        npm ERR! missing: @sentry/types@5.30.0, required by @sentry/hub@5.30.0
        npm ERR! missing: @sentry/utils@5.30.0, required by @sentry/hub@5.30.0
        npm ERR! missing: @sentry/hub@5.30.0, required by @sentry/tracing@5.30.0
        npm ERR! missing: @sentry/minimal@5.30.0, required by @sentry/tracing@5.30.0
        npm ERR! missing: @sentry/types@5.30.0, required by @sentry/tracing@5.30.0
        npm ERR! missing: @sentry/utils@5.30.0, required by @sentry/tracing@5.30.0
        npm ERR! missing: @sentry/types@5.30.0, required by @sentry/utils@5.30.0
        npm ERR! missing: @npmcli/arborist@2.4.0, required by npm@7.11.1
        npm ERR! missing: @npmcli/ci-detect@1.3.0, required by npm@7.11.1
        npm ERR! missing: @npmcli/config@2.2.0, required by npm@7.11.1
        npm ERR! missing: @npmcli/run-script@1.8.5, required by npm@7.11.1
        npm ERR! missing: abbrev@1.1.1, required by npm@7.11.1
        npm ERR! missing: ansicolors@0.3.2, required by npm@7.11.1
        npm ERR! missing: ansistyles@0.1.3, required by npm@7.11.1
        npm ERR! missing: archy@1.0.0, required by npm@7.11.1
        npm ERR! missing: byte-size@7.0.1, required by npm@7.11.1
        npm ERR! missing: cacache@15.0.6, required by npm@7.11.1
        npm ERR! missing: chalk@4.1.1, required by npm@7.11.1
        npm ERR! missing: chownr@2.0.0, required by npm@7.11.1
        npm ERR! missing: cli-columns@3.1.2, required by npm@7.11.1
        npm ERR! missing: cli-table3@0.6.0, required by npm@7.11.1
        npm ERR! missing: columnify@1.5.4, required by npm@7.11.1
        npm ERR! missing: glob@7.1.6, required by npm@7.11.1
        npm ERR! missing: graceful-fs@4.2.6, required by npm@7.11.1
        npm ERR! missing: hosted-git-info@4.0.2, required by npm@7.11.1
        npm ERR! missing: ini@2.0.0, required by npm@7.11.1
        npm ERR! missing: init-package-json@2.0.3, required by npm@7.11.1
        npm ERR! missing: is-cidr@4.0.2, required by npm@7.11.1
        npm ERR! missing: json-parse-even-better-errors@2.3.1, required by npm@7.11.1
        npm ERR! missing: leven@3.1.0, required by npm@7.11.1
        npm ERR! missing: libnpmaccess@4.0.2, required by npm@7.11.1
        npm ERR! missing: libnpmdiff@2.0.4, required by npm@7.11.1
        npm ERR! missing: libnpmexec@1.0.1, required by npm@7.11.1
        npm ERR! missing: libnpmfund@1.0.2, required by npm@7.11.1
        npm ERR! missing: libnpmhook@6.0.2, required by npm@7.11.1
        npm ERR! missing: libnpmorg@2.0.2, required by npm@7.11.1
        npm ERR! missing: libnpmpack@2.0.1, required by npm@7.11.1
        npm ERR! missing: libnpmpublish@4.0.1, required by npm@7.11.1
        npm ERR! missing: libnpmsearch@3.1.1, required by npm@7.11.1
        npm ERR! missing: libnpmteam@2.0.3, required by npm@7.11.1
        npm ERR! missing: libnpmversion@1.2.0, required by npm@7.11.1
        npm ERR! missing: make-fetch-happen@8.0.14, required by npm@7.11.1
        npm ERR! missing: minipass@3.1.3, required by npm@7.11.1
        npm ERR! missing: minipass-pipeline@1.2.4, required by npm@7.11.1
        npm ERR! missing: mkdirp@1.0.4, required by npm@7.11.1
        npm ERR! missing: mkdirp-infer-owner@2.0.0, required by npm@7.11.1
        npm ERR! missing: ms@2.1.3, required by npm@7.11.1
        npm ERR! missing: node-gyp@7.1.2, required by npm@7.11.1
        npm ERR! missing: nopt@5.0.0, required by npm@7.11.1
        npm ERR! missing: npm-audit-report@2.1.4, required by npm@7.11.1
        npm ERR! missing: npm-package-arg@8.1.2, required by npm@7.11.1
        npm ERR! missing: npm-pick-manifest@6.1.1, required by npm@7.11.1
        npm ERR! missing: npm-profile@5.0.3, required by npm@7.11.1
        npm ERR! missing: npm-registry-fetch@10.1.1, required by npm@7.11.1
        npm ERR! missing: npm-user-validate@1.0.1, required by npm@7.11.1
        npm ERR! missing: npmlog@4.1.2, required by npm@7.11.1
        npm ERR! missing: opener@1.5.2, required by npm@7.11.1
        npm ERR! missing: pacote@11.3.3, required by npm@7.11.1
        npm ERR! missing: parse-conflict-json@1.1.1, required by npm@7.11.1
        npm ERR! missing: qrcode-terminal@0.12.0, required by npm@7.11.1
        npm ERR! missing: read@1.0.7, required by npm@7.11.1
        npm ERR! missing: read-package-json@3.0.1, required by npm@7.11.1
        npm ERR! missing: read-package-json-fast@2.0.2, required by npm@7.11.1
        npm ERR! missing: readdir-scoped-modules@1.1.0, required by npm@7.11.1
        npm ERR! missing: rimraf@3.0.2, required by npm@7.11.1
        npm ERR! missing: semver@7.3.5, required by npm@7.11.1
        npm ERR! missing: ssri@8.0.1, required by npm@7.11.1
        npm ERR! missing: tar@6.1.0, required by npm@7.11.1
        npm ERR! missing: text-table@0.2.0, required by npm@7.11.1
        npm ERR! missing: tiny-relative-date@1.3.0, required by npm@7.11.1
        npm ERR! missing: treeverse@1.0.4, required by npm@7.11.1
        npm ERR! missing: validate-npm-package-name@3.0.0, required by npm@7.11.1
        npm ERR! missing: which@2.0.2, required by npm@7.11.1
        npm ERR! missing: write-file-atomic@3.0.3, required by npm@7.11.1
        npm ERR! missing: @npmcli/installed-package-contents@1.0.7, required by @npmcli/arborist@2.4.0
        npm ERR! missing: @npmcli/map-workspaces@1.0.3, required by @npmcli/arborist@2.4.0
        npm ERR! missing: @npmcli/metavuln-calculator@1.1.1, required by @npmcli/arborist@2.4.0
        npm ERR! missing: @npmcli/move-file@1.1.2, required by @npmcli/arborist@2.4.0
        npm ERR! missing: @npmcli/name-from-folder@1.0.1, required by @npmcli/arborist@2.4.0
        npm ERR! missing: @npmcli/node-gyp@1.0.2, required by @npmcli/arborist@2.4.0
        npm ERR! missing: @npmcli/run-script@1.8.5, required by @npmcli/arborist@2.4.0
        npm ERR! missing: bin-links@2.2.1, required by @npmcli/arborist@2.4.0
        npm ERR! missing: cacache@15.0.6, required by @npmcli/arborist@2.4.0
        npm ERR! missing: common-ancestor-path@1.0.1, required by @npmcli/arborist@2.4.0
        npm ERR! missing: json-parse-even-better-errors@2.3.1, required by @npmcli/arborist@2.4.0
        npm ERR! missing: json-stringify-nice@1.1.3, required by @npmcli/arborist@2.4.0
        npm ERR! missing: mkdirp-infer-owner@2.0.0, required by @npmcli/arborist@2.4.0
        npm ERR! missing: npm-install-checks@4.0.0, required by @npmcli/arborist@2.4.0
        npm ERR! missing: npm-package-arg@8.1.2, required by @npmcli/arborist@2.4.0
        npm ERR! missing: npm-pick-manifest@6.1.1, required by @npmcli/arborist@2.4.0
        npm ERR! missing: npm-registry-fetch@10.1.1, required by @npmcli/arborist@2.4.0
        npm ERR! missing: pacote@11.3.3, required by @npmcli/arborist@2.4.0
        npm ERR! missing: parse-conflict-json@1.1.1, required by @npmcli/arborist@2.4.0
        npm ERR! missing: promise-all-reject-late@1.0.1, required by @npmcli/arborist@2.4.0
        npm ERR! missing: promise-call-limit@1.0.1, required by @npmcli/arborist@2.4.0
        npm ERR! missing: read-package-json-fast@2.0.2, required by @npmcli/arborist@2.4.0
        npm ERR! missing: readdir-scoped-modules@1.1.0, required by @npmcli/arborist@2.4.0
        npm ERR! missing: semver@7.3.5, required by @npmcli/arborist@2.4.0
        npm ERR! missing: tar@6.1.0, required by @npmcli/arborist@2.4.0
        npm ERR! missing: treeverse@1.0.4, required by @npmcli/arborist@2.4.0
        npm ERR! missing: walk-up-path@1.0.0, required by @npmcli/arborist@2.4.0
        npm ERR! missing: npm-bundled@1.1.2, required by @npmcli/installed-package-contents@1.0.7
        npm ERR! missing: npm-normalize-package-bin@1.0.1, required by @npmcli/installed-package-contents@1.0.7
        npm ERR! missing: npm-normalize-package-bin@1.0.1, required by npm-bundled@1.1.2
        npm ERR! missing: @npmcli/name-from-folder@1.0.1, required by @npmcli/map-workspaces@1.0.3
        npm ERR! missing: glob@7.1.6, required by @npmcli/map-workspaces@1.0.3
        npm ERR! missing: minimatch@3.0.4, required by @npmcli/map-workspaces@1.0.3
        npm ERR! missing: read-package-json-fast@2.0.2, required by @npmcli/map-workspaces@1.0.3
        npm ERR! missing: cacache@15.0.6, required by @npmcli/metavuln-calculator@1.1.1
        npm ERR! missing: pacote@11.3.3, required by @npmcli/metavuln-calculator@1.1.1
        npm ERR! missing: semver@7.3.5, required by @npmcli/metavuln-calculator@1.1.1
        npm ERR! missing: mkdirp@1.0.4, required by @npmcli/move-file@1.1.2
        npm ERR! missing: rimraf@3.0.2, required by @npmcli/move-file@1.1.2
        npm ERR! missing: cmd-shim@4.1.0, required by bin-links@2.2.1
        npm ERR! missing: mkdirp@1.0.4, required by bin-links@2.2.1
        npm ERR! missing: npm-normalize-package-bin@1.0.1, required by bin-links@2.2.1
        npm ERR! missing: read-cmd-shim@2.0.0, required by bin-links@2.2.1
        npm ERR! missing: rimraf@3.0.2, required by bin-links@2.2.1
        npm ERR! missing: write-file-atomic@3.0.3, required by bin-links@2.2.1
        npm ERR! missing: mkdirp-infer-owner@2.0.0, required by cmd-shim@4.1.0
        npm ERR! missing: semver@7.3.5, required by npm-install-checks@4.0.0
        npm ERR! missing: ini@2.0.0, required by @npmcli/config@2.2.0
        npm ERR! missing: mkdirp-infer-owner@2.0.0, required by @npmcli/config@2.2.0
        npm ERR! missing: nopt@5.0.0, required by @npmcli/config@2.2.0
        npm ERR! missing: semver@7.3.5, required by @npmcli/config@2.2.0
        npm ERR! missing: walk-up-path@1.0.0, required by @npmcli/config@2.2.0
        npm ERR! missing: @npmcli/node-gyp@1.0.2, required by @npmcli/run-script@1.8.5
        npm ERR! missing: @npmcli/promise-spawn@1.3.2, required by @npmcli/run-script@1.8.5
        npm ERR! missing: infer-owner@1.0.4, required by @npmcli/run-script@1.8.5
        npm ERR! missing: node-gyp@7.1.2, required by @npmcli/run-script@1.8.5
        npm ERR! missing: read-package-json-fast@2.0.2, required by @npmcli/run-script@1.8.5
        npm ERR! missing: infer-owner@1.0.4, required by @npmcli/promise-spawn@1.3.2
        npm ERR! missing: @npmcli/move-file@1.1.2, required by cacache@15.0.6
        npm ERR! missing: chownr@2.0.0, required by cacache@15.0.6
        npm ERR! missing: fs-minipass@2.1.0, required by cacache@15.0.6
        npm ERR! missing: glob@7.1.6, required by cacache@15.0.6
        npm ERR! missing: infer-owner@1.0.4, required by cacache@15.0.6
        npm ERR! missing: lru-cache@6.0.0, required by cacache@15.0.6
        npm ERR! missing: minipass@3.1.3, required by cacache@15.0.6
        npm ERR! missing: minipass-collect@1.0.2, required by cacache@15.0.6
        npm ERR! missing: minipass-flush@1.0.5, required by cacache@15.0.6
        npm ERR! missing: minipass-pipeline@1.2.4, required by cacache@15.0.6
        npm ERR! missing: mkdirp@1.0.4, required by cacache@15.0.6
        npm ERR! missing: p-map@4.0.0, required by cacache@15.0.6
        npm ERR! missing: promise-inflight@1.0.1, required by cacache@15.0.6
        npm ERR! missing: rimraf@3.0.2, required by cacache@15.0.6
        npm ERR! missing: ssri@8.0.1, required by cacache@15.0.6
        npm ERR! missing: tar@6.1.0, required by cacache@15.0.6
        npm ERR! missing: unique-filename@1.1.1, required by cacache@15.0.6
        npm ERR! missing: minipass@3.1.3, required by fs-minipass@2.1.0
        npm ERR! missing: yallist@4.0.0, required by lru-cache@6.0.0
        npm ERR! missing: minipass@3.1.3, required by minipass-collect@1.0.2
        npm ERR! missing: minipass@3.1.3, required by minipass-flush@1.0.5
        npm ERR! missing: aggregate-error@3.1.0, required by p-map@4.0.0
        npm ERR! missing: clean-stack@2.2.0, required by aggregate-error@3.1.0
        npm ERR! missing: indent-string@4.0.0, required by aggregate-error@3.1.0
        npm ERR! missing: unique-slug@2.0.2, required by unique-filename@1.1.1
        npm ERR! missing: imurmurhash@0.1.4, required by unique-slug@2.0.2
        npm ERR! missing: ansi-styles@4.3.0, required by chalk@4.1.1
        npm ERR! missing: supports-color@7.2.0, required by chalk@4.1.1
        npm ERR! missing: color-convert@2.0.1, required by ansi-styles@4.3.0
        npm ERR! missing: color-name@1.1.4, required by color-convert@2.0.1
        npm ERR! missing: has-flag@4.0.0, required by supports-color@7.2.0
        npm ERR! missing: string-width@2.1.1, required by cli-columns@3.1.2
        npm ERR! missing: strip-ansi@3.0.1, required by cli-columns@3.1.2
        npm ERR! missing: is-fullwidth-code-point@2.0.0, required by string-width@2.1.1
        npm ERR! missing: strip-ansi@4.0.0, required by string-width@2.1.1
        npm ERR! missing: ansi-regex@3.0.0, required by strip-ansi@4.0.0
        npm ERR! missing: ansi-regex@2.1.1, required by strip-ansi@3.0.1
        npm ERR! missing: string-width@4.2.2, required by cli-table3@0.6.0
        npm ERR! missing: object-assign@4.1.1, required by cli-table3@0.6.0
        npm ERR! missing: is-fullwidth-code-point@3.0.0, required by string-width@4.2.2
        npm ERR! missing: strip-ansi@6.0.0, required by string-width@4.2.2
        npm ERR! missing: emoji-regex@8.0.0, required by string-width@4.2.2
        npm ERR! missing: ansi-regex@5.0.0, required by strip-ansi@6.0.0
        npm ERR! missing: strip-ansi@3.0.1, required by columnify@1.5.4
        npm ERR! missing: wcwidth@1.0.1, required by columnify@1.5.4
        npm ERR! missing: defaults@1.0.3, required by wcwidth@1.0.1
        npm ERR! missing: clone@1.0.4, required by defaults@1.0.3
        npm ERR! missing: fs.realpath@1.0.0, required by glob@7.1.6
        npm ERR! missing: inflight@1.0.6, required by glob@7.1.6
        npm ERR! missing: inherits@2.0.4, required by glob@7.1.6
        npm ERR! missing: minimatch@3.0.4, required by glob@7.1.6
        npm ERR! missing: once@1.4.0, required by glob@7.1.6
        npm ERR! missing: path-is-absolute@1.0.1, required by glob@7.1.6
        npm ERR! missing: once@1.4.0, required by inflight@1.0.6
        npm ERR! missing: wrappy@1.0.2, required by inflight@1.0.6
        npm ERR! missing: brace-expansion@1.1.11, required by minimatch@3.0.4
        npm ERR! missing: balanced-match@1.0.2, required by brace-expansion@1.1.11
        npm ERR! missing: concat-map@0.0.1, required by brace-expansion@1.1.11
        npm ERR! missing: wrappy@1.0.2, required by once@1.4.0
        npm ERR! missing: lru-cache@6.0.0, required by hosted-git-info@4.0.2
        npm ERR! missing: glob@7.1.6, required by init-package-json@2.0.3
        npm ERR! missing: npm-package-arg@8.1.2, required by init-package-json@2.0.3
        npm ERR! missing: promzard@0.3.0, required by init-package-json@2.0.3
        npm ERR! missing: read@1.0.7, required by init-package-json@2.0.3
        npm ERR! missing: read-package-json@3.0.1, required by init-package-json@2.0.3
        npm ERR! missing: semver@7.3.5, required by init-package-json@2.0.3
        npm ERR! missing: validate-npm-package-license@3.0.4, required by init-package-json@2.0.3
        npm ERR! missing: validate-npm-package-name@3.0.0, required by init-package-json@2.0.3
        npm ERR! missing: read@1.0.7, required by promzard@0.3.0
        npm ERR! missing: spdx-correct@3.1.1, required by validate-npm-package-license@3.0.4
        npm ERR! missing: spdx-expression-parse@3.0.1, required by validate-npm-package-license@3.0.4
        npm ERR! missing: spdx-expression-parse@3.0.1, required by spdx-correct@3.1.1
        npm ERR! missing: spdx-license-ids@3.0.7, required by spdx-correct@3.1.1
        npm ERR! missing: spdx-exceptions@2.3.0, required by spdx-expression-parse@3.0.1
        npm ERR! missing: spdx-license-ids@3.0.7, required by spdx-expression-parse@3.0.1
        npm ERR! missing: cidr-regex@3.1.1, required by is-cidr@4.0.2
        npm ERR! missing: ip-regex@4.3.0, required by cidr-regex@3.1.1
        npm ERR! missing: aproba@2.0.0, required by libnpmaccess@4.0.2
        npm ERR! missing: minipass@3.1.3, required by libnpmaccess@4.0.2
        npm ERR! missing: npm-package-arg@8.1.2, required by libnpmaccess@4.0.2
        npm ERR! missing: npm-registry-fetch@10.1.1, required by libnpmaccess@4.0.2
        npm ERR! missing: @npmcli/disparity-colors@1.0.1, required by libnpmdiff@2.0.4
        npm ERR! missing: @npmcli/installed-package-contents@1.0.7, required by libnpmdiff@2.0.4
        npm ERR! missing: binary-extensions@2.2.0, required by libnpmdiff@2.0.4
        npm ERR! missing: diff@5.0.0, required by libnpmdiff@2.0.4
        npm ERR! missing: minimatch@3.0.4, required by libnpmdiff@2.0.4
        npm ERR! missing: npm-package-arg@8.1.2, required by libnpmdiff@2.0.4
        npm ERR! missing: pacote@11.3.3, required by libnpmdiff@2.0.4
        npm ERR! missing: tar@6.1.0, required by libnpmdiff@2.0.4
        npm ERR! missing: ansi-styles@4.3.0, required by @npmcli/disparity-colors@1.0.1
        npm ERR! missing: @npmcli/arborist@2.4.0, required by libnpmexec@1.0.1
        npm ERR! missing: @npmcli/ci-detect@1.3.0, required by libnpmexec@1.0.1
        npm ERR! missing: @npmcli/run-script@1.8.5, required by libnpmexec@1.0.1
        npm ERR! missing: chalk@4.1.1, required by libnpmexec@1.0.1
        npm ERR! missing: mkdirp-infer-owner@2.0.0, required by libnpmexec@1.0.1
        npm ERR! missing: npm-package-arg@8.1.2, required by libnpmexec@1.0.1
        npm ERR! missing: pacote@11.3.3, required by libnpmexec@1.0.1
        npm ERR! missing: proc-log@1.0.0, required by libnpmexec@1.0.1
        npm ERR! missing: read@1.0.7, required by libnpmexec@1.0.1
        npm ERR! missing: read-package-json-fast@2.0.2, required by libnpmexec@1.0.1
        npm ERR! missing: @npmcli/arborist@2.4.0, required by libnpmfund@1.0.2
        npm ERR! missing: aproba@2.0.0, required by libnpmhook@6.0.2
        npm ERR! missing: npm-registry-fetch@10.1.1, required by libnpmhook@6.0.2
        npm ERR! missing: aproba@2.0.0, required by libnpmorg@2.0.2
        npm ERR! missing: npm-registry-fetch@10.1.1, required by libnpmorg@2.0.2
        npm ERR! missing: @npmcli/run-script@1.8.5, required by libnpmpack@2.0.1
        npm ERR! missing: npm-package-arg@8.1.2, required by libnpmpack@2.0.1
        npm ERR! missing: pacote@11.3.3, required by libnpmpack@2.0.1
        npm ERR! missing: normalize-package-data@3.0.2, required by libnpmpublish@4.0.1
        npm ERR! missing: npm-package-arg@8.1.2, required by libnpmpublish@4.0.1
        npm ERR! missing: npm-registry-fetch@10.1.1, required by libnpmpublish@4.0.1
        npm ERR! missing: semver@7.3.5, required by libnpmpublish@4.0.1
        npm ERR! missing: ssri@8.0.1, required by libnpmpublish@4.0.1
        npm ERR! missing: hosted-git-info@4.0.2, required by normalize-package-data@3.0.2
        npm ERR! missing: resolve@1.20.0, required by normalize-package-data@3.0.2
        npm ERR! missing: semver@7.3.5, required by normalize-package-data@3.0.2
        npm ERR! missing: validate-npm-package-license@3.0.4, required by normalize-package-data@3.0.2
        npm ERR! missing: is-core-module@2.2.0, required by resolve@1.20.0
        npm ERR! missing: path-parse@1.0.6, required by resolve@1.20.0
        npm ERR! missing: has@1.0.3, required by is-core-module@2.2.0
        npm ERR! missing: function-bind@1.1.1, required by has@1.0.3
        npm ERR! missing: npm-registry-fetch@10.1.1, required by libnpmsearch@3.1.1
        npm ERR! missing: aproba@2.0.0, required by libnpmteam@2.0.3
        npm ERR! missing: npm-registry-fetch@10.1.1, required by libnpmteam@2.0.3
        npm ERR! missing: @npmcli/git@2.0.8, required by libnpmversion@1.2.0
        npm ERR! missing: @npmcli/run-script@1.8.5, required by libnpmversion@1.2.0
        npm ERR! missing: json-parse-even-better-errors@2.3.1, required by libnpmversion@1.2.0
        npm ERR! missing: semver@7.3.5, required by libnpmversion@1.2.0
        npm ERR! missing: stringify-package@1.0.1, required by libnpmversion@1.2.0
        npm ERR! missing: @npmcli/promise-spawn@1.3.2, required by @npmcli/git@2.0.8
        npm ERR! missing: lru-cache@6.0.0, required by @npmcli/git@2.0.8
        npm ERR! missing: mkdirp@1.0.4, required by @npmcli/git@2.0.8
        npm ERR! missing: npm-pick-manifest@6.1.1, required by @npmcli/git@2.0.8
        npm ERR! missing: promise-inflight@1.0.1, required by @npmcli/git@2.0.8
        npm ERR! missing: promise-retry@2.0.1, required by @npmcli/git@2.0.8
        npm ERR! missing: semver@7.3.5, required by @npmcli/git@2.0.8
        npm ERR! missing: which@2.0.2, required by @npmcli/git@2.0.8
        npm ERR! missing: agentkeepalive@4.1.4, required by make-fetch-happen@8.0.14
        npm ERR! missing: cacache@15.0.6, required by make-fetch-happen@8.0.14
        npm ERR! missing: http-cache-semantics@4.1.0, required by make-fetch-happen@8.0.14
        npm ERR! missing: http-proxy-agent@4.0.1, required by make-fetch-happen@8.0.14
        npm ERR! missing: https-proxy-agent@5.0.0, required by make-fetch-happen@8.0.14
        npm ERR! missing: is-lambda@1.0.1, required by make-fetch-happen@8.0.14
        npm ERR! missing: lru-cache@6.0.0, required by make-fetch-happen@8.0.14
        npm ERR! missing: minipass@3.1.3, required by make-fetch-happen@8.0.14
        npm ERR! missing: minipass-collect@1.0.2, required by make-fetch-happen@8.0.14
        npm ERR! missing: minipass-fetch@1.3.3, required by make-fetch-happen@8.0.14
        npm ERR! missing: minipass-flush@1.0.5, required by make-fetch-happen@8.0.14
        npm ERR! missing: minipass-pipeline@1.2.4, required by make-fetch-happen@8.0.14
        npm ERR! missing: promise-retry@2.0.1, required by make-fetch-happen@8.0.14
        npm ERR! missing: socks-proxy-agent@5.0.0, required by make-fetch-happen@8.0.14
        npm ERR! missing: ssri@8.0.1, required by make-fetch-happen@8.0.14
        npm ERR! missing: debug@4.3.1, required by agentkeepalive@4.1.4
        npm ERR! missing: depd@1.1.2, required by agentkeepalive@4.1.4
        npm ERR! missing: humanize-ms@1.2.1, required by agentkeepalive@4.1.4
        npm ERR! missing: ms@2.1.2, required by debug@4.3.1
        npm ERR! missing: ms@2.1.3, required by humanize-ms@1.2.1
        npm ERR! missing: @tootallnate/once@1.1.2, required by http-proxy-agent@4.0.1
        npm ERR! missing: agent-base@6.0.2, required by http-proxy-agent@4.0.1
        npm ERR! missing: debug@4.3.1, required by http-proxy-agent@4.0.1
        npm ERR! missing: debug@4.3.1, required by agent-base@6.0.2
        npm ERR! missing: agent-base@6.0.2, required by https-proxy-agent@5.0.0
        npm ERR! missing: debug@4.3.1, required by https-proxy-agent@5.0.0
        npm ERR! missing: minipass@3.1.3, required by minipass-fetch@1.3.3
        npm ERR! missing: minipass-sized@1.0.3, required by minipass-fetch@1.3.3
        npm ERR! missing: minizlib@2.1.2, required by minipass-fetch@1.3.3
        npm ERR! missing: safer-buffer@2.1.2, required by iconv-lite@0.6.2
        npm ERR! missing: minipass@3.1.3, required by minipass-sized@1.0.3
        npm ERR! missing: err-code@2.0.3, required by promise-retry@2.0.1
        npm ERR! missing: retry@0.12.0, required by promise-retry@2.0.1
        npm ERR! missing: agent-base@6.0.2, required by socks-proxy-agent@5.0.0
        npm ERR! missing: debug@4.3.1, required by socks-proxy-agent@5.0.0
        npm ERR! missing: socks@2.6.1, required by socks-proxy-agent@5.0.0
        npm ERR! missing: ip@1.1.5, required by socks@2.6.1
        npm ERR! missing: smart-buffer@4.1.0, required by socks@2.6.1
        npm ERR! missing: yallist@4.0.0, required by minipass@3.1.3
        npm ERR! missing: minipass@3.1.3, required by minipass-pipeline@1.2.4
        npm ERR! missing: chownr@2.0.0, required by mkdirp-infer-owner@2.0.0
        npm ERR! missing: infer-owner@1.0.4, required by mkdirp-infer-owner@2.0.0
        npm ERR! missing: mkdirp@1.0.4, required by mkdirp-infer-owner@2.0.0
        npm ERR! missing: env-paths@2.2.1, required by node-gyp@7.1.2
        npm ERR! missing: glob@7.1.6, required by node-gyp@7.1.2
        npm ERR! missing: graceful-fs@4.2.6, required by node-gyp@7.1.2
        npm ERR! missing: nopt@5.0.0, required by node-gyp@7.1.2
        npm ERR! missing: npmlog@4.1.2, required by node-gyp@7.1.2
        npm ERR! missing: request@2.88.2, required by node-gyp@7.1.2
        npm ERR! missing: rimraf@3.0.2, required by node-gyp@7.1.2
        npm ERR! missing: semver@7.3.5, required by node-gyp@7.1.2
        npm ERR! missing: tar@6.1.0, required by node-gyp@7.1.2
        npm ERR! missing: which@2.0.2, required by node-gyp@7.1.2
        npm ERR! missing: aws-sign2@0.7.0, required by request@2.88.2
        npm ERR! missing: aws4@1.11.0, required by request@2.88.2
        npm ERR! missing: caseless@0.12.0, required by request@2.88.2
        npm ERR! missing: combined-stream@1.0.8, required by request@2.88.2
        npm ERR! missing: extend@3.0.2, required by request@2.88.2
        npm ERR! missing: forever-agent@0.6.1, required by request@2.88.2
        npm ERR! missing: form-data@2.3.3, required by request@2.88.2
        npm ERR! missing: har-validator@5.1.5, required by request@2.88.2
        npm ERR! missing: http-signature@1.2.0, required by request@2.88.2
        npm ERR! missing: is-typedarray@1.0.0, required by request@2.88.2
        npm ERR! missing: isstream@0.1.2, required by request@2.88.2
        npm ERR! missing: json-stringify-safe@5.0.1, required by request@2.88.2
        npm ERR! missing: mime-types@2.1.30, required by request@2.88.2
        npm ERR! missing: oauth-sign@0.9.0, required by request@2.88.2
        npm ERR! missing: performance-now@2.1.0, required by request@2.88.2
        npm ERR! missing: qs@6.5.2, required by request@2.88.2
        npm ERR! missing: tough-cookie@2.5.0, required by request@2.88.2
        npm ERR! missing: safe-buffer@5.1.2, required by request@2.88.2
        npm ERR! missing: tunnel-agent@0.6.0, required by request@2.88.2
        npm ERR! missing: uuid@3.4.0, required by request@2.88.2
        npm ERR! missing: delayed-stream@1.0.0, required by combined-stream@1.0.8
        npm ERR! missing: asynckit@0.4.0, required by form-data@2.3.3
        npm ERR! missing: combined-stream@1.0.8, required by form-data@2.3.3
        npm ERR! missing: mime-types@2.1.30, required by form-data@2.3.3
        npm ERR! missing: ajv@6.12.6, required by har-validator@5.1.5
        npm ERR! missing: har-schema@2.0.0, required by har-validator@5.1.5
        npm ERR! missing: fast-deep-equal@3.1.3, required by ajv@6.12.6
        npm ERR! missing: fast-json-stable-stringify@2.1.0, required by ajv@6.12.6
        npm ERR! missing: json-schema-traverse@0.4.1, required by ajv@6.12.6
        npm ERR! missing: uri-js@4.4.1, required by ajv@6.12.6
        npm ERR! missing: punycode@2.1.1, required by uri-js@4.4.1
        npm ERR! missing: assert-plus@1.0.0, required by http-signature@1.2.0
        npm ERR! missing: jsprim@1.4.1, required by http-signature@1.2.0
        npm ERR! missing: sshpk@1.16.1, required by http-signature@1.2.0
        npm ERR! missing: assert-plus@1.0.0, required by jsprim@1.4.1
        npm ERR! missing: extsprintf@1.3.0, required by jsprim@1.4.1
        npm ERR! missing: json-schema@0.2.3, required by jsprim@1.4.1
        npm ERR! missing: verror@1.10.0, required by jsprim@1.4.1
        npm ERR! missing: assert-plus@1.0.0, required by verror@1.10.0
        npm ERR! missing: core-util-is@1.0.2, required by verror@1.10.0
        npm ERR! missing: extsprintf@1.3.0, required by verror@1.10.0
        npm ERR! missing: asn1@0.2.4, required by sshpk@1.16.1
        npm ERR! missing: assert-plus@1.0.0, required by sshpk@1.16.1
        npm ERR! missing: bcrypt-pbkdf@1.0.2, required by sshpk@1.16.1
        npm ERR! missing: dashdash@1.14.1, required by sshpk@1.16.1
        npm ERR! missing: ecc-jsbn@0.1.2, required by sshpk@1.16.1
        npm ERR! missing: getpass@0.1.7, required by sshpk@1.16.1
        npm ERR! missing: jsbn@0.1.1, required by sshpk@1.16.1
        npm ERR! missing: safer-buffer@2.1.2, required by sshpk@1.16.1
        npm ERR! missing: tweetnacl@0.14.5, required by sshpk@1.16.1
        npm ERR! missing: safer-buffer@2.1.2, required by asn1@0.2.4
        npm ERR! missing: tweetnacl@0.14.5, required by bcrypt-pbkdf@1.0.2
        npm ERR! missing: assert-plus@1.0.0, required by dashdash@1.14.1
        npm ERR! missing: jsbn@0.1.1, required by ecc-jsbn@0.1.2
        npm ERR! missing: safer-buffer@2.1.2, required by ecc-jsbn@0.1.2
        npm ERR! missing: assert-plus@1.0.0, required by getpass@0.1.7
        npm ERR! missing: mime-db@1.47.0, required by mime-types@2.1.30
        npm ERR! missing: psl@1.8.0, required by tough-cookie@2.5.0
        npm ERR! missing: punycode@2.1.1, required by tough-cookie@2.5.0
        npm ERR! missing: safe-buffer@5.1.2, required by tunnel-agent@0.6.0
        npm ERR! missing: abbrev@1.1.1, required by nopt@5.0.0
        npm ERR! missing: chalk@4.1.1, required by npm-audit-report@2.1.4
        npm ERR! missing: hosted-git-info@4.0.2, required by npm-package-arg@8.1.2
        npm ERR! missing: semver@7.3.5, required by npm-package-arg@8.1.2
        npm ERR! missing: validate-npm-package-name@3.0.0, required by npm-package-arg@8.1.2
        npm ERR! missing: npm-install-checks@4.0.0, required by npm-pick-manifest@6.1.1
        npm ERR! missing: npm-normalize-package-bin@1.0.1, required by npm-pick-manifest@6.1.1
        npm ERR! missing: npm-package-arg@8.1.2, required by npm-pick-manifest@6.1.1
        npm ERR! missing: semver@7.3.5, required by npm-pick-manifest@6.1.1
        npm ERR! missing: npm-registry-fetch@10.1.1, required by npm-profile@5.0.3
        npm ERR! missing: lru-cache@6.0.0, required by npm-registry-fetch@10.1.1
        npm ERR! missing: make-fetch-happen@8.0.14, required by npm-registry-fetch@10.1.1
        npm ERR! missing: minipass@3.1.3, required by npm-registry-fetch@10.1.1
        npm ERR! missing: minipass-fetch@1.3.3, required by npm-registry-fetch@10.1.1
        npm ERR! missing: minipass-json-stream@1.0.1, required by npm-registry-fetch@10.1.1
        npm ERR! missing: minizlib@2.1.2, required by npm-registry-fetch@10.1.1
        npm ERR! missing: npm-package-arg@8.1.2, required by npm-registry-fetch@10.1.1
        npm ERR! missing: jsonparse@1.3.1, required by minipass-json-stream@1.0.1
        npm ERR! missing: minipass@3.1.3, required by minipass-json-stream@1.0.1
        npm ERR! missing: minipass@3.1.3, required by minizlib@2.1.2
        npm ERR! missing: yallist@4.0.0, required by minizlib@2.1.2
        npm ERR! missing: are-we-there-yet@1.1.5, required by npmlog@4.1.2
        npm ERR! missing: console-control-strings@1.1.0, required by npmlog@4.1.2
        npm ERR! missing: gauge@2.7.4, required by npmlog@4.1.2
        npm ERR! missing: set-blocking@2.0.0, required by npmlog@4.1.2
        npm ERR! missing: delegates@1.0.0, required by are-we-there-yet@1.1.5
        npm ERR! missing: readable-stream@2.3.7, required by are-we-there-yet@1.1.5
        npm ERR! missing: core-util-is@1.0.2, required by readable-stream@2.3.7
        npm ERR! missing: inherits@2.0.4, required by readable-stream@2.3.7
        npm ERR! missing: isarray@1.0.0, required by readable-stream@2.3.7
        npm ERR! missing: process-nextick-args@2.0.1, required by readable-stream@2.3.7
        npm ERR! missing: safe-buffer@5.1.2, required by readable-stream@2.3.7
        npm ERR! missing: string_decoder@1.1.1, required by readable-stream@2.3.7
        npm ERR! missing: util-deprecate@1.0.2, required by readable-stream@2.3.7
        npm ERR! missing: safe-buffer@5.1.2, required by string_decoder@1.1.1
        npm ERR! missing: console-control-strings@1.1.0, required by gauge@2.7.4
        npm ERR! missing: aproba@1.2.0, required by gauge@2.7.4
        npm ERR! missing: string-width@1.0.2, required by gauge@2.7.4
        npm ERR! missing: has-unicode@2.0.1, required by gauge@2.7.4
        npm ERR! missing: object-assign@4.1.1, required by gauge@2.7.4
        npm ERR! missing: signal-exit@3.0.3, required by gauge@2.7.4
        npm ERR! missing: strip-ansi@3.0.1, required by gauge@2.7.4
        npm ERR! missing: wide-align@1.1.3, required by gauge@2.7.4
        npm ERR! missing: code-point-at@1.1.0, required by string-width@1.0.2
        npm ERR! missing: is-fullwidth-code-point@1.0.0, required by string-width@1.0.2
        npm ERR! missing: strip-ansi@3.0.1, required by string-width@1.0.2
        npm ERR! missing: number-is-nan@1.0.1, required by is-fullwidth-code-point@1.0.0
        npm ERR! missing: string-width@2.1.1, required by wide-align@1.1.3
        npm ERR! missing: @npmcli/git@2.0.8, required by pacote@11.3.3
        npm ERR! missing: @npmcli/installed-package-contents@1.0.7, required by pacote@11.3.3
        npm ERR! missing: @npmcli/promise-spawn@1.3.2, required by pacote@11.3.3
        npm ERR! missing: @npmcli/run-script@1.8.5, required by pacote@11.3.3
        npm ERR! missing: cacache@15.0.6, required by pacote@11.3.3
        npm ERR! missing: chownr@2.0.0, required by pacote@11.3.3
        npm ERR! missing: fs-minipass@2.1.0, required by pacote@11.3.3
        npm ERR! missing: infer-owner@1.0.4, required by pacote@11.3.3
        npm ERR! missing: minipass@3.1.3, required by pacote@11.3.3
        npm ERR! missing: mkdirp@1.0.4, required by pacote@11.3.3
        npm ERR! missing: npm-package-arg@8.1.2, required by pacote@11.3.3
        npm ERR! missing: npm-packlist@2.1.5, required by pacote@11.3.3
        npm ERR! missing: npm-pick-manifest@6.1.1, required by pacote@11.3.3
        npm ERR! missing: npm-registry-fetch@10.1.1, required by pacote@11.3.3
        npm ERR! missing: promise-retry@2.0.1, required by pacote@11.3.3
        npm ERR! missing: read-package-json-fast@2.0.2, required by pacote@11.3.3
        npm ERR! missing: rimraf@3.0.2, required by pacote@11.3.3
        npm ERR! missing: ssri@8.0.1, required by pacote@11.3.3
        npm ERR! missing: tar@6.1.0, required by pacote@11.3.3
        npm ERR! missing: glob@7.1.6, required by npm-packlist@2.1.5
        npm ERR! missing: ignore-walk@3.0.3, required by npm-packlist@2.1.5
        npm ERR! missing: npm-bundled@1.1.2, required by npm-packlist@2.1.5
        npm ERR! missing: npm-normalize-package-bin@1.0.1, required by npm-packlist@2.1.5
        npm ERR! missing: minimatch@3.0.4, required by ignore-walk@3.0.3
        npm ERR! missing: json-parse-even-better-errors@2.3.1, required by parse-conflict-json@1.1.1
        npm ERR! missing: just-diff@3.1.1, required by parse-conflict-json@1.1.1
        npm ERR! missing: just-diff-apply@3.0.0, required by parse-conflict-json@1.1.1
        npm ERR! missing: mute-stream@0.0.8, required by read@1.0.7
        npm ERR! missing: glob@7.1.6, required by read-package-json@3.0.1
        npm ERR! missing: json-parse-even-better-errors@2.3.1, required by read-package-json@3.0.1
        npm ERR! missing: normalize-package-data@3.0.2, required by read-package-json@3.0.1
        npm ERR! missing: npm-normalize-package-bin@1.0.1, required by read-package-json@3.0.1
        npm ERR! missing: json-parse-even-better-errors@2.3.1, required by read-package-json-fast@2.0.2
        npm ERR! missing: npm-normalize-package-bin@1.0.1, required by read-package-json-fast@2.0.2
        npm ERR! missing: debuglog@1.0.1, required by readdir-scoped-modules@1.1.0
        npm ERR! missing: dezalgo@1.0.3, required by readdir-scoped-modules@1.1.0
        npm ERR! missing: graceful-fs@4.2.6, required by readdir-scoped-modules@1.1.0
        npm ERR! missing: once@1.4.0, required by readdir-scoped-modules@1.1.0
        npm ERR! missing: asap@2.0.6, required by dezalgo@1.0.3
        npm ERR! missing: wrappy@1.0.2, required by dezalgo@1.0.3
        npm ERR! missing: glob@7.1.6, required by rimraf@3.0.2
        npm ERR! missing: lru-cache@6.0.0, required by semver@7.3.5
        npm ERR! missing: minipass@3.1.3, required by ssri@8.0.1
        npm ERR! missing: chownr@2.0.0, required by tar@6.1.0
        npm ERR! missing: fs-minipass@2.1.0, required by tar@6.1.0
        npm ERR! missing: minipass@3.1.3, required by tar@6.1.0
        npm ERR! missing: minizlib@2.1.2, required by tar@6.1.0
        npm ERR! missing: mkdirp@1.0.4, required by tar@6.1.0
        npm ERR! missing: yallist@4.0.0, required by tar@6.1.0
        npm ERR! missing: builtins@1.0.3, required by validate-npm-package-name@3.0.0
        npm ERR! missing: isexe@2.0.0, required by which@2.0.2
        npm ERR! missing: imurmurhash@0.1.4, required by write-file-atomic@3.0.3
        npm ERR! missing: is-typedarray@1.0.0, required by write-file-atomic@3.0.3
        npm ERR! missing: signal-exit@3.0.3, required by write-file-atomic@3.0.3
        npm ERR! missing: typedarray-to-buffer@3.1.5, required by write-file-atomic@3.0.3
        npm ERR! missing: is-typedarray@1.0.0, required by typedarray-to-buffer@3.1.5
        npm ERR! missing: cron-parser@2.15.0, required by node-schedule@1.3.2
        npm ERR! peer dep missing: typescript@3.9.x || 4.0.x || 4.1.x, required by typedoc@0.20.28
        npm ERR! extraneous: @babel/cli@7.13.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/cli
        npm ERR! extraneous: @babel/preset-env@7.13.9 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/preset-env
        npm ERR! extraneous: @babel/preset-typescript@7.13.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/preset-typescript
        npm ERR! extraneous: @types/debounce@1.2.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/debounce
        npm ERR! extraneous: @types/debug@4.1.5 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/debug
        npm ERR! extraneous: @types/jest@26.0.20 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/jest
        npm ERR! extraneous: @types/mz@2.7.3 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/mz
        npm ERR! extraneous: @types/nedb@1.8.11 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/nedb
        npm ERR! extraneous: @types/serialport@8.0.1 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/serialport
        npm ERR! extraneous: @typescript-eslint/eslint-plugin@4.16.1 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/eslint-plugin
        npm ERR! extraneous: @typescript-eslint/parser@4.16.1 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/parser
        npm ERR! extraneous: eslint@7.21.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/eslint
        npm ERR! extraneous: jest@26.6.3 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/jest
        npm ERR! extraneous: typedoc@0.20.28 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc
        npm ERR! extraneous: typedoc-plugin-markdown@3.6.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-markdown
        npm ERR! extraneous: typedoc-plugin-no-inherit@1.2.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-no-inherit
        npm ERR! extraneous: typedoc-plugin-sourcefile-url@1.0.6 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-sourcefile-url
        npm ERR! extraneous: eslint@7.27.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint
        npm ERR! extraneous: eslint-config-google@0.14.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint-config-google
        npm ERR! extraneous: eslint-plugin-jest@24.3.6 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint-plugin-jest
        npm ERR! extraneous: jest@26.6.3 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/jest
        npm ERR! extraneous: @babel/cli@7.13.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/cli
        npm ERR! extraneous: @babel/preset-env@7.13.9 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/preset-env
        npm ERR! extraneous: @babel/preset-typescript@7.13.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/preset-typescript
        npm ERR! extraneous: @types/debounce@1.2.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/debounce
        npm ERR! extraneous: @types/debug@4.1.5 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/debug
        npm ERR! extraneous: @types/jest@26.0.20 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/jest
        npm ERR! extraneous: @types/mz@2.7.3 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/mz
        npm ERR! extraneous: @types/nedb@1.8.11 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/nedb
        npm ERR! extraneous: @types/serialport@8.0.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/serialport
        npm ERR! extraneous: @typescript-eslint/eslint-plugin@4.16.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/eslint-plugin
        npm ERR! extraneous: @typescript-eslint/parser@4.16.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/parser
        npm ERR! extraneous: eslint@7.21.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/eslint
        npm ERR! extraneous: jest@26.6.3 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/jest
        npm ERR! extraneous: typedoc@0.20.28 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc
        npm ERR! extraneous: typedoc-plugin-markdown@3.6.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-markdown
        npm ERR! extraneous: typedoc-plugin-no-inherit@1.2.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-no-inherit
        npm ERR! extraneous: typedoc-plugin-sourcefile-url@1.0.6 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-sourcefile-url
        • S sanda
          │ │ ├── depd@2.0.0
          │ │ ├─┬ debug@4.1.1
          │ │ │ └── ms@2.1.2
          │ │ │ ├─┬ ws@6.1.4
          │ └── xtend@4.0.2
          │ ├─┬ tar@6.1.0
          │ │ │   ├─┬ rc@1.2.8
          │ │ ├─┬ debug@4.3.1
          │ │ │ └── ms@2.1.2
          │ │ ├─┬ mz@2.7.0
          │ │ ├── slip@1.0.2
          │   ├─┬ axios@0.21.1
          │   │ └─┬ debug@4.3.1
          │   │   └── ms@2.1.2
          │   │ ├─┬ bl@4.1.0
          │     │ ├── nan@2.14.2
          │     │   ├─┬ pump@3.0.0
          │     │   ├─┬ rc@1.2.8
          │     │   │ ├── ini@1.3.8
          │     │   │   ├─┬ bl@4.1.0
          │     ├─┬ debug@4.3.1
          │     │ └── ms@2.1.2
          │     ├─┬ mz@2.7.0
          │     ├── slip@1.0.2
          ├── semver@5.7.1
          └─┬ yargs@7.1.1
            ├── camelcase@3.0.0
            ├─┬ cliui@3.2.0
            ├─┬ os-locale@1.4.0
            │ └─┬ lcid@1.0.0
            │ ├─┬ find-up@1.1.2
            │   │ ├── pify@2.3.0
            ├── y18n@3.2.1
          npm uninstall iobroker.sourceanalytix
          Siehste, hier kommt noch der Kram von npm@7 mit:
          Ich wäre ja fast geneigt, hier mal entgegen der sonstigen Empfehlung wirklich wieder npm@7 wieder zu installieren, damit die ganzen Depencies wieder bedient werden.
            oder ganz einfach
            @homoran sagte in Fehler in Adapterinstallation:
            • S sanda
              │ │ ├── depd@2.0.0
              │ │ ├─┬ debug@4.1.1
              │ │ │ └── ms@2.1.2
              │ │ │ ├─┬ ws@6.1.4
              │ └── xtend@4.0.2
              │ ├─┬ tar@6.1.0
              │ │ │   ├─┬ rc@1.2.8
              │ │ ├─┬ debug@4.3.1
              │ │ │ └── ms@2.1.2
              │ │ ├─┬ mz@2.7.0
              │ │ ├── slip@1.0.2
              │   ├─┬ axios@0.21.1
              │   │ └─┬ debug@4.3.1
              │   │   └── ms@2.1.2
              │   │ ├─┬ bl@4.1.0
              │     │ ├── nan@2.14.2
              │     │   ├─┬ pump@3.0.0
              │     │   ├─┬ rc@1.2.8
              │     │   │ ├── ini@1.3.8
              │     │   │   ├─┬ bl@4.1.0
              │     ├─┬ debug@4.3.1
              │     │ └── ms@2.1.2
              │     ├─┬ mz@2.7.0
              │     ├── slip@1.0.2
              ├── semver@5.7.1
              └─┬ yargs@7.1.1
                ├── camelcase@3.0.0
                ├─┬ cliui@3.2.0
                ├─┬ os-locale@1.4.0
                │ └─┬ lcid@1.0.0
                │ ├─┬ find-up@1.1.2
                │   │ ├── pify@2.3.0
                ├── y18n@3.2.1
              Hast du eigentlich in den Einstellungen des javascript-Adapters noch zusätzliche Module reingeflickt?
              Wenn ja, welche?
                Wenn ja, welche?
                sanda
                @thomas-braun Jetzt wird es etwas sauberer nach sourceanalytics Deinstallation:
                pi@raspberrypi4-iob:/opt/iobroker $ npm ls
                iobroker.core@1.0.0 /opt/iobroker
                ├── iobroker@2.0.3 extraneous
                ├── iobroker.admin@5.1.25 extraneous
                ├── iobroker.backitup@2.2.2 extraneous
                ├── iobroker.discovery@2.7.3 extraneous
                ├── iobroker.dwd@2.7.7 extraneous
                ├── iobroker.fb-checkpresence@1.1.10 extraneous
                ├── iobroker.followthesun@0.3.5 extraneous
                ├── iobroker.growatt@1.1.1 extraneous
                ├── iobroker.gruenbeck@0.0.30 extraneous
                ├── iobroker.hm-rega@3.0.32 extraneous
                ├── iobroker.hm-rpc@1.14.45 extraneous
                ├── iobroker.homekit-controller@0.3.3 extraneous
                ├── iobroker.ical@1.11.4 extraneous
                ├── iobroker.icons-mfd-png@1.0.2 extraneous
                ├── iobroker.icons-ultimate-png@1.0.1 extraneous
                ├── iobroker.influxdb@1.9.5 extraneous
                ├── iobroker.info@1.9.8 extraneous
                ├── iobroker.javascript@5.2.13 extraneous
                ├── iobroker.js-controller@3.3.20 extraneous
                ├── iobroker.mihome-vacuum@3.3.1 extraneous
                ├── iobroker.mpd@1.0.6 extraneous
                ├── iobroker.odl@1.1.4 extraneous
                ├── iobroker.onvif@0.4.4 extraneous
                ├── iobroker.plenticore@2.2.0 extraneous
                ├── iobroker.samsung@0.2.9 extraneous
                ├── iobroker.schoolfree@1.0.0 extraneous
                ├── iobroker.shelly@4.0.7 extraneous
                ├── iobroker.synology@1.1.3 extraneous
                ├── iobroker.tankerkoenig@2.1.1 extraneous
                ├── iobroker.telegram@1.10.0 extraneous
                ├── iobroker.trashschedule@1.2.0 extraneous
                ├── iobroker.tuya@3.6.9 extraneous
                ├── iobroker.vis@1.4.5 extraneous
                ├── iobroker.vis-colorpicker@1.2.0 extraneous
                ├── iobroker.vis-hqwidgets@1.1.7 extraneous
                ├── iobroker.vis-inventwo@3.2.0 extraneous
                ├── iobroker.vis-jqui-mfd@1.0.12 extraneous
                ├── iobroker.vis-metro@1.1.2 extraneous
                ├── iobroker.vis-timeandweather@1.1.7 extraneous
                ├── iobroker.vis-weather@2.5.5 extraneous
                ├── iobroker.web@3.4.9 extraneous
                └── iobroker.zigbee@1.5.6 extraneous
                npm ERR! extraneous: iobroker@2.0.3 /opt/iobroker/node_modules/iobroker
                npm ERR! extraneous: iobroker.admin@5.1.25 /opt/iobroker/node_modules/iobroker.admin
                npm ERR! extraneous: iobroker.backitup@2.2.2 /opt/iobroker/node_modules/iobroker.backitup
                npm ERR! extraneous: iobroker.discovery@2.7.3 /opt/iobroker/node_modules/iobroker.discovery
                npm ERR! extraneous: iobroker.dwd@2.7.7 /opt/iobroker/node_modules/iobroker.dwd
                npm ERR! extraneous: iobroker.fb-checkpresence@1.1.10 /opt/iobroker/node_modules/iobroker.fb-checkpresence
                npm ERR! extraneous: iobroker.followthesun@0.3.5 /opt/iobroker/node_modules/iobroker.followthesun
                npm ERR! extraneous: iobroker.growatt@1.1.1 /opt/iobroker/node_modules/iobroker.growatt
                npm ERR! extraneous: iobroker.gruenbeck@0.0.30 /opt/iobroker/node_modules/iobroker.gruenbeck
                npm ERR! extraneous: iobroker.hm-rega@3.0.32 /opt/iobroker/node_modules/iobroker.hm-rega
                npm ERR! extraneous: iobroker.hm-rpc@1.14.45 /opt/iobroker/node_modules/iobroker.hm-rpc
                npm ERR! extraneous: iobroker.homekit-controller@0.3.3 /opt/iobroker/node_modules/iobroker.homekit-controller
                npm ERR! extraneous: iobroker.ical@1.11.4 /opt/iobroker/node_modules/iobroker.ical
                npm ERR! extraneous: iobroker.icons-mfd-png@1.0.2 /opt/iobroker/node_modules/iobroker.icons-mfd-png
                npm ERR! extraneous: iobroker.icons-ultimate-png@1.0.1 /opt/iobroker/node_modules/iobroker.icons-ultimate-png
                npm ERR! extraneous: iobroker.influxdb@1.9.5 /opt/iobroker/node_modules/iobroker.influxdb
                npm ERR! extraneous: iobroker.info@1.9.8 /opt/iobroker/node_modules/iobroker.info
                npm ERR! extraneous: iobroker.javascript@5.2.13 /opt/iobroker/node_modules/iobroker.javascript
                npm ERR! extraneous: iobroker.js-controller@3.3.20 /opt/iobroker/node_modules/iobroker.js-controller
                npm ERR! extraneous: iobroker.mihome-vacuum@3.3.1 /opt/iobroker/node_modules/iobroker.mihome-vacuum
                npm ERR! extraneous: iobroker.mpd@1.0.6 /opt/iobroker/node_modules/iobroker.mpd
                npm ERR! extraneous: iobroker.odl@1.1.4 /opt/iobroker/node_modules/iobroker.odl
                npm ERR! extraneous: iobroker.onvif@0.4.4 /opt/iobroker/node_modules/iobroker.onvif
                npm ERR! extraneous: iobroker.plenticore@2.2.0 /opt/iobroker/node_modules/iobroker.plenticore
                npm ERR! extraneous: iobroker.samsung@0.2.9 /opt/iobroker/node_modules/iobroker.samsung
                npm ERR! extraneous: iobroker.schoolfree@1.0.0 /opt/iobroker/node_modules/iobroker.schoolfree
                npm ERR! extraneous: iobroker.shelly@4.0.7 /opt/iobroker/node_modules/iobroker.shelly
                npm ERR! extraneous: iobroker.synology@1.1.3 /opt/iobroker/node_modules/iobroker.synology
                npm ERR! extraneous: iobroker.tankerkoenig@2.1.1 /opt/iobroker/node_modules/iobroker.tankerkoenig
                npm ERR! extraneous: iobroker.telegram@1.10.0 /opt/iobroker/node_modules/iobroker.telegram
                npm ERR! extraneous: iobroker.trashschedule@1.2.0 /opt/iobroker/node_modules/iobroker.trashschedule
                npm ERR! extraneous: iobroker.tuya@3.6.9 /opt/iobroker/node_modules/iobroker.tuya
                npm ERR! extraneous: iobroker.vis@1.4.5 /opt/iobroker/node_modules/iobroker.vis
                npm ERR! extraneous: iobroker.vis-colorpicker@1.2.0 /opt/iobroker/node_modules/iobroker.vis-colorpicker
                npm ERR! extraneous: iobroker.vis-hqwidgets@1.1.7 /opt/iobroker/node_modules/iobroker.vis-hqwidgets
                npm ERR! extraneous: iobroker.vis-inventwo@3.2.0 /opt/iobroker/node_modules/iobroker.vis-inventwo
                npm ERR! extraneous: iobroker.vis-jqui-mfd@1.0.12 /opt/iobroker/node_modules/iobroker.vis-jqui-mfd
                npm ERR! extraneous: iobroker.vis-metro@1.1.2 /opt/iobroker/node_modules/iobroker.vis-metro
                npm ERR! extraneous: iobroker.vis-timeandweather@1.1.7 /opt/iobroker/node_modules/iobroker.vis-timeandweather
                npm ERR! extraneous: iobroker.vis-weather@2.5.5 /opt/iobroker/node_modules/iobroker.vis-weather
                npm ERR! extraneous: iobroker.web@3.4.9 /opt/iobroker/node_modules/iobroker.web
                npm ERR! extraneous: iobroker.zigbee@1.5.6 /opt/iobroker/node_modules/iobroker.zigbee
                  oder ganz einfach
                  sanda
                  @homoran das hab ich auch erstmal umbenannt
                    Wenn ja, welche?
                    sanda
                    @thomas-braun Nein ich nutze keine zusätzlichen Module im javascript
                    • S sanda
                      @sanda
                      Okay, das sieht schon wesentlich anders aus.
                      Die Urinstallation ist aber auch schon etwas her, oder?
                      schaut ungewohnt aus. Die ganzen extraneous Einträge sind auch ungewöhnlich. Kann es sein, das da zwei Installationen ineinander verschachtelt wurden?
                      Mal z. B.
                      npm list iobroker.icons-mfd-png
                      anschauen.
                        @sanda
                        Mal z. B.
                        anschauen.
                        sanda
                        Das spuckt er mir aus und ja die Installation von IOB ist schon etwas her:
                        pi@raspberrypi4-iob:/opt/iobroker $ npm list iobroker.icons-mfd-png
                        └── iobroker.icons-mfd-png@1.0.2  extraneous
                        • S sanda
                          @sanda
                          Was mich irritiert ist, dass bei dir extraneous Module angezeigt werden, offenbar aber ohne das erste Modul.
                          Bei mir schaut das z. B. so aus:
                          echad@chet:/opt/iobroker $ npm ls jsonata
                          iobroker.inst@3.0.0 /opt/iobroker
                          ├─┬ iobroker.javascript@5.2.16
                          │ └── jsonata@1.8.5
                          └── jsonata@1.8.5 extraneous
                          Ich hab aber offengesagt keine Ahnung was ich dir da empfehlen soll. Mal über eine Neuinstallation nachgedacht?
                            @sanda
                            │ └── jsonata@1.8.5
                            sanda
                            @thomas-braun Alles neu zu installieren, da brauch ich ja wieder eine Woche, bis alles wieder läuft 😨
                            Ich habe jetzt js-controller Komplett neu installiert und jetzt nochmals das Kommando ausgeführt, was zuvor schon zu Error-Meldungen geführt hatte, aber jetzt nicht mehr.
                            pi@raspberrypi4-iob:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                            > iobroker.js-controller@3.3.21 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                            > node lib/preinstallCheck.js
                            NPM version: 6.14.15
                            > iobroker.js-controller@3.3.21 install /opt/iobroker/node_modules/iobroker.js-controller
                            > node iobroker.js setup first
                            object _design/custom updated
                            object _design/system updated
                            The following notifications happened during sync:
                            - Ignoring Directory "hm-rega" because officially not created as meta object. Please remove directory!
                            - Ignoring Directory "synology.0" because officially not created as meta object. Please remove directory!
                            - Ignoring Directory "synology.1" because officially not created as meta object. Please remove directory!
                            + iobroker.js-controller@3.3.21
                            removed 75 packages and updated 1 package in 65.018s
                            167 packages are looking for funding
                              run `npm fund` for details
                            • S sanda
                              sanda
                              Anscheinend hab ich es nun hinbekommen. Die Lösung war, das ich anschließend den admin neu installiert habe 😊
                              Danke euch vielmals 👍
                              • S sanda
                                @sanda
                                Wie schaut denn jetzt ein
                                cd /opt/iobroker
                                npm list
                                aus?
                                  @sanda
                                  cd /opt/iobroker
                                  npm list
                                  aus?
                                  sanda
                                  schrieb am zuletzt editiert von sanda
                                  @thomas-braun da stehen immer noch einige Error-Punkte, aber alles läuft ohne Probleme und neue Adapter lassen sich nun auch installieren.
                                  │ │ │   ├─┬ get-symbol-description@1.0.0
                                  │ │ │   │ ├── call-bind@1.0.2 deduped
                                  │ │ │   │ └── get-intrinsic@1.1.1 deduped
                                  │ │ │   ├── has@1.0.3 deduped
                                  │ │ │   ├── has-symbols@1.0.2
                                  │ │ │   ├─┬ internal-slot@1.0.3
                                  │ │ │   │ ├── get-intrinsic@1.1.1 deduped
                                  │ │ │   │ ├── has@1.0.3 deduped
                                  │ │ │   │ └── side-channel@1.0.4 deduped
                                  │ │ │   ├── is-callable@1.2.4
                                  │ │ │   ├── is-negative-zero@2.0.1
                                  │ │ │   ├─┬ is-regex@1.1.4
                                  │ │ │   │ └─┬ has-tostringtag@1.0.0
                                  │ │ │   │   └── has-symbols@1.0.2 deduped
                                  │ │ │   ├── is-shared-array-buffer@1.0.1
                                  │ │ │   ├─┬ is-string@1.0.7
                                  │ │ │   │ └── has-tostringtag@1.0.0 deduped
                                  │ │ │   ├─┬ is-weakref@1.0.1
                                  │ │ │   │ └── call-bind@1.0.2 deduped
                                  │ │ │   ├── object-inspect@1.11.0
                                  │ │ │   ├── object-keys@1.1.1 deduped
                                  │ │ │   ├─┬ object.assign@4.1.2
                                  │ │ │   │ ├── define-properties@1.1.3 deduped
                                  │ │ │   │ ├── has-symbols@1.0.2 deduped
                                  │ │ │   │ └── object-keys@1.1.1 deduped
                                  │ │ │   ├─┬ string.prototype.trimend@1.0.4
                                  │ │ │   │ └── define-properties@1.1.3 deduped
                                  │ │ │   ├─┬ string.prototype.trimstart@1.0.4
                                  │ │ │   └─┬ unbox-primitive@1.0.1
                                  │ │ │     ├── function-bind@1.1.1 deduped
                                  │ │ │     ├── has-bigints@1.0.1
                                  │ │ │     └─┬ which-boxed-primitive@1.0.2
                                  │ │ │       ├─┬ is-bigint@1.0.4
                                  │ │ │       │ └── has-bigints@1.0.1 deduped
                                  │ │ │       ├─┬ is-boolean-object@1.1.2
                                  │ │ │       ├─┬ is-number-object@1.0.6
                                  │ │ │       ├── is-string@1.0.7 deduped
                                  │ │ │       └── is-symbol@1.0.4 deduped
                                  │ │ ├─┬ bl@1.2.3
                                  │ │ │ ├── readable-stream@2.3.7 deduped
                                  │ │ │ └── safe-buffer@5.2.1 deduped
                                  │ │ ├── bluebird@3.7.2 deduped
                                  │ │ ├── debug@3.2.7 deduped
                                  │ │ ├── depd@1.1.2 deduped
                                  │ │ ├── eventemitter3@3.1.2
                                  │ │ ├── file-type@3.9.0
                                  │ │ ├── mime@1.6.0
                                  │ │ ├─┬ pump@2.0.1
                                  │ │ ├── request@2.88.2 deduped
                                  │ │ └─┬ request-promise@4.2.6
                                  │ │   ├─┬ request-promise-core@1.1.4
                                  │ │   │ └── lodash@4.17.21 deduped
                                  │ │   ├── stealthy-require@1.1.1
                                  │ │   └── tough-cookie@2.5.0 deduped
                                  │ └─┬ socksv5@0.0.6
                                  │   └─┬ ipv6@3.1.1
                                  │     ├─┬ cli@0.4.5
                                  │     │ └── glob@7.2.0 deduped
                                  │     ├─┬ cliff@0.1.10
                                  │     │ ├── colors@1.0.3
                                  │     │ ├── eyes@0.1.8 deduped
                                  │     │ └─┬ winston@0.8.3
                                  │     │   ├── async@0.2.10
                                  │     │   ├── colors@0.6.2
                                  │     │   ├── cycle@1.0.3 deduped
                                  │     │   ├── isstream@0.1.2 deduped
                                  │     │   ├── pkginfo@0.3.1
                                  │     │   └── stack-trace@0.0.10 deduped
                                  │     └── sprintf@0.1.3
                                  ├─┬ iobroker.trashschedule@1.2.0
                                  │ └── @iobroker/adapter-core@2.5.1 deduped
                                  ├─┬ iobroker.vis@1.4.5
                                  │ └── jsonwebtoken@8.5.1 deduped
                                  ├─┬ iobroker.vis-colorpicker@1.2.0
                                  ├─┬ iobroker.vis-inventwo@3.2.0
                                  │ └─┬ np@7.6.0
                                  │   ├─┬ @samverschueren/stream-to-observable@0.3.1
                                  │   │ └── any-observable@0.3.0
                                  │   ├── any-observable@0.5.1
                                  │   ├── async-exit-hook@2.0.1
                                  │   ├─┬ chalk@4.1.2
                                  │   │ ├─┬ ansi-styles@4.3.0
                                  │   │ │ └─┬ color-convert@2.0.1
                                  │   │ │   └── color-name@1.1.4
                                  │   │ └─┬ supports-color@7.2.0
                                  │   │   └── has-flag@4.0.0
                                  │   ├─┬ cosmiconfig@7.0.1
                                  │   │ ├── @types/parse-json@4.0.0
                                  │   │ ├─┬ import-fresh@3.3.0
                                  │   │ │ ├─┬ parent-module@1.0.1
                                  │   │ │ │ └── callsites@3.1.0 deduped
                                  │   │ │ └── resolve-from@4.0.0
                                  │   │ ├─┬ parse-json@5.2.0
                                  │   │ │ ├─┬ @babel/code-frame@7.16.0
                                  │   │ │ │ └─┬ @babel/highlight@7.16.0
                                  │   │ │ │   ├── @babel/helper-validator-identifier@7.15.7
                                  │   │ │ │   ├─┬ chalk@2.4.2
                                  │   │ │ │   │ ├─┬ ansi-styles@3.2.1
                                  │   │ │ │   │ │ └── color-convert@1.9.3 deduped
                                  │   │ │ │   │ ├── escape-string-regexp@1.0.5
                                  │   │ │ │   │ └─┬ supports-color@5.5.0
                                  │   │ │ │   │   └── has-flag@3.0.0
                                  │   │ │ │   └── js-tokens@4.0.0
                                  │   │ │ ├─┬ error-ex@1.3.2
                                  │   │ │ │ └── is-arrayish@0.2.1
                                  │   │ │ ├── json-parse-even-better-errors@2.3.1
                                  │   │ │ └── lines-and-columns@1.2.4
                                  │   │ ├── path-type@4.0.0
                                  │   │ └── yaml@1.10.2
                                  │   ├─┬ del@6.0.0
                                  │   │ ├─┬ globby@11.0.4
                                  │   │ │ ├── array-union@2.1.0
                                  │   │ │ ├─┬ dir-glob@3.0.1
                                  │   │ │ │ └── path-type@4.0.0 deduped
                                  │   │ │ ├─┬ fast-glob@3.2.7
                                  │   │ │ │ ├── @nodelib/fs.stat@2.0.5
                                  │   │ │ │ ├─┬ @nodelib/fs.walk@1.2.8
                                  │   │ │ │ │ ├─┬ @nodelib/fs.scandir@2.1.5
                                  │   │ │ │ │ │ ├── @nodelib/fs.stat@2.0.5 deduped
                                  │   │ │ │ │ │ └─┬ run-parallel@1.2.0
                                  │   │ │ │ │ │   └── queue-microtask@1.2.3
                                  │   │ │ │ │ └─┬ fastq@1.13.0
                                  │   │ │ │ │   └── reusify@1.0.4
                                  │   │ │ │ ├── glob-parent@5.1.2 deduped
                                  │   │ │ │ ├── merge2@1.4.1 deduped
                                  │   │ │ │ └─┬ micromatch@4.0.4
                                  │   │ │ │   ├── braces@3.0.2 deduped
                                  │   │ │ │   └── picomatch@2.3.0 deduped
                                  │   │ │ ├── ignore@5.1.9
                                  │   │ │ └── slash@3.0.0 deduped
                                  │   │ ├── graceful-fs@4.2.8 deduped
                                  │   │ ├── is-glob@4.0.3 deduped
                                  │   │ ├── is-path-cwd@2.2.0
                                  │   │ ├── is-path-inside@3.0.3
                                  │   │ ├─┬ p-map@4.0.0
                                  │   │ │ └─┬ aggregate-error@3.1.0
                                  │   │ │   ├── clean-stack@2.2.0
                                  │   │ │   └── indent-string@4.0.0 deduped
                                  │   │ ├── rimraf@3.0.2 deduped
                                  │   │ └── slash@3.0.0
                                  │   ├── escape-goat@3.0.0
                                  │   ├── escape-string-regexp@4.0.0
                                  │   ├─┬ execa@5.1.1
                                  │   │ ├─┬ cross-spawn@7.0.3
                                  │   │ │ ├── path-key@3.1.1
                                  │   │ │ ├─┬ shebang-command@2.0.0
                                  │   │ │ │ └── shebang-regex@3.0.0
                                  │   │ │ └─┬ which@2.0.2
                                  │   │ │   └── isexe@2.0.0
                                  │   │ ├── get-stream@6.0.1
                                  │   │ ├── human-signals@2.1.0
                                  │   │ ├── is-stream@2.0.1 deduped
                                  │   │ ├── merge-stream@2.0.0
                                  │   │ ├─┬ npm-run-path@4.0.1
                                  │   │ │ └── path-key@3.1.1 deduped
                                  │   │ ├── onetime@5.1.2 deduped
                                  │   │ ├── signal-exit@3.0.6
                                  │   │ └── strip-final-newline@2.0.0
                                  │   ├── github-url-from-git@1.5.0
                                  │   ├── has-yarn@2.1.0
                                  │   ├─┬ hosted-git-info@3.0.8
                                  │   │ └── lru-cache@6.0.0 deduped
                                  │   ├─┬ ignore-walk@3.0.4
                                  │   │ └── minimatch@3.0.4 deduped
                                  │   ├─┬ import-local@3.0.3
                                  │   │ ├─┬ pkg-dir@4.2.0
                                  │   │ │ └── find-up@4.1.0 deduped
                                  │   │ └─┬ resolve-cwd@3.0.0
                                  │   │   └── resolve-from@5.0.0
                                  │   ├─┬ inquirer@7.3.3
                                  │   │ ├─┬ ansi-escapes@4.3.2
                                  │   │ │ └── type-fest@0.21.3
                                  │   │ ├── chalk@4.1.2 deduped
                                  │   │ ├─┬ cli-cursor@3.1.0
                                  │   │ │ └─┬ restore-cursor@3.1.0
                                  │   │ │   ├── onetime@5.1.2 deduped
                                  │   │ │   └── signal-exit@3.0.6 deduped
                                  │   │ ├── cli-width@3.0.0
                                  │   │ ├─┬ external-editor@3.1.0
                                  │   │ │ ├── chardet@0.7.0
                                  │   │ │ ├─┬ iconv-lite@0.4.24
                                  │   │ │ │ └── safer-buffer@2.1.2 deduped
                                  │   │ │ └─┬ tmp@0.0.33
                                  │   │ │   └── os-tmpdir@1.0.2
                                  │   │ ├─┬ figures@3.2.0
                                  │   │ │ └── escape-string-regexp@1.0.5
                                  │   │ ├── lodash@4.17.21 deduped
                                  │   │ ├── mute-stream@0.0.8 deduped
                                  │   │ ├── run-async@2.4.1
                                  │   │ ├── rxjs@6.6.7 deduped
                                  │   │ ├── string-width@4.2.3 deduped
                                  │   │ ├── strip-ansi@6.0.1 deduped
                                  │   │ └── through@2.3.8 deduped
                                  │   ├─┬ is-installed-globally@0.3.2
                                  │   │ ├─┬ global-dirs@2.1.0
                                  │   │ │ └── ini@1.3.7
                                  │   │ └── is-path-inside@3.0.3 deduped
                                  │   ├── is-interactive@1.0.0
                                  │   ├─┬ is-scoped@2.1.0
                                  │   │ └── scoped-regex@2.1.0
                                  │   ├── issue-regex@3.1.0
                                  │   ├─┬ listr@0.14.3
                                  │   │ ├── @samverschueren/stream-to-observable@0.3.1 deduped
                                  │   │ ├─┬ is-observable@1.1.0
                                  │   │ │ └── symbol-observable@1.2.0
                                  │   │ ├── is-promise@2.2.2
                                  │   │ ├── is-stream@1.1.0
                                  │   │ ├── listr-silent-renderer@1.1.1
                                  │   │ ├─┬ listr-update-renderer@0.5.0
                                  │   │ │ ├─┬ chalk@1.1.3
                                  │   │ │ │ ├── ansi-styles@2.2.1
                                  │   │ │ │ ├─┬ has-ansi@2.0.0
                                  │   │ │ │ │ └── ansi-regex@2.1.1
                                  │   │ │ │ ├── strip-ansi@3.0.1 deduped
                                  │   │ │ │ └── supports-color@2.0.0
                                  │   │ │ ├─┬ cli-truncate@0.2.1
                                  │   │ │ │ ├── slice-ansi@0.0.4
                                  │   │ │ │ └─┬ string-width@1.0.2
                                  │   │ │ │   ├── code-point-at@1.1.0 deduped
                                  │   │ │ │   ├─┬ is-fullwidth-code-point@1.0.0
                                  │   │ │ │   │ └── number-is-nan@1.0.1 deduped
                                  │   │ │ │   └─┬ strip-ansi@3.0.1
                                  │   │ │ ├── elegant-spinner@1.0.1
                                  │   │ │ ├─┬ figures@1.7.0
                                  │   │ │ │ ├── escape-string-regexp@1.0.5 deduped
                                  │   │ │ │ └── object-assign@4.1.1
                                  │   │ │ ├── indent-string@3.2.0
                                  │   │ │ ├─┬ log-symbols@1.0.2
                                  │   │ │ │ └── chalk@1.1.3 deduped
                                  │   │ │ ├─┬ log-update@2.3.0
                                  │   │ │ │ ├── ansi-escapes@3.2.0
                                  │   │ │ │ ├─┬ cli-cursor@2.1.0
                                  │   │ │ │ │ └─┬ restore-cursor@2.0.0
                                  │   │ │ │ │   ├─┬ onetime@2.0.1
                                  │   │ │ │ │   │ └── mimic-fn@1.2.0
                                  │   │ │ │ │   └── signal-exit@3.0.6 deduped
                                  │   │ │ │ └─┬ wrap-ansi@3.0.1
                                  │   │ │ │   ├─┬ string-width@2.1.1
                                  │   │ │ │   │ ├── is-fullwidth-code-point@2.0.0
                                  │   │ │ │   │ └── strip-ansi@4.0.0 deduped
                                  │   │ │ │   └─┬ strip-ansi@4.0.0
                                  │   │ │ │     └── ansi-regex@3.0.0
                                  │   │ ├─┬ listr-verbose-renderer@0.5.0
                                  │   │ │ ├── date-fns@1.30.1
                                  │   │ │ └─┬ figures@2.0.0
                                  │   │ │   └── escape-string-regexp@1.0.5 deduped
                                  │   │ ├── p-map@2.1.0
                                  │   │ └── rxjs@6.6.7 deduped
                                  │   ├─┬ listr-input@0.2.1
                                  │   │ ├── inquirer@7.3.3 deduped
                                  │   │ ├─┬ inquirer-autosubmit-prompt@0.2.0
                                  │   │ │ ├─┬ inquirer@6.5.2
                                  │   │ │ │ ├── chalk@2.4.2 deduped
                                  │   │ │ │ ├── cli-width@2.2.1
                                  │   │ │ │ ├── external-editor@3.1.0 deduped
                                  │   │ │ │ ├─┬ figures@2.0.0
                                  │   │ │ │ │ └── escape-string-regexp@1.0.5 deduped
                                  │   │ │ │ ├── lodash@4.17.21 deduped
                                  │   │ │ │ ├── mute-stream@0.0.7
                                  │   │ │ │ ├── run-async@2.4.1 deduped
                                  │   │ │ │ ├── rxjs@6.6.7 deduped
                                  │   │ │ │ │ └─┬ strip-ansi@4.0.0
                                  │   │ │ │ │   └── ansi-regex@3.0.0
                                  │   │ │ │ ├─┬ strip-ansi@5.2.0
                                  │   │ │ │ │ └── ansi-regex@4.1.0
                                  │   │ │ │ └── through@2.3.8 deduped
                                  │   │ │ └── rxjs@6.6.7 deduped
                                  │   ├─┬ log-symbols@4.1.0
                                  │   │ └── is-unicode-supported@0.1.0
                                  │   ├─┬ meow@8.1.2
                                  │   │ ├── @types/minimist@1.2.2
                                  │   │ ├─┬ camelcase-keys@6.2.2
                                  │   │ │ ├── camelcase@5.3.1
                                  │   │ │ ├── map-obj@4.3.0
                                  │   │ │ └── quick-lru@4.0.1
                                  │   │ ├─┬ decamelize-keys@1.1.0
                                  │   │ │ ├── decamelize@1.2.0 deduped
                                  │   │ │ └── map-obj@1.0.1
                                  │   │ ├── hard-rejection@2.1.0
                                  │   │ ├─┬ minimist-options@4.1.0
                                  │   │ │ ├── arrify@1.0.1
                                  │   │ │ ├── is-plain-obj@1.1.0
                                  │   │ │ └── kind-of@6.0.3
                                  │   │ ├─┬ normalize-package-data@3.0.3
                                  │   │ │ ├─┬ hosted-git-info@4.0.2
                                  │   │ │ │ └── lru-cache@6.0.0 deduped
                                  │   │ │ ├─┬ is-core-module@2.8.0
                                  │   │ │ │ └── has@1.0.3 deduped
                                  │   │ │ ├── semver@7.3.5 deduped
                                  │   │ │ └─┬ validate-npm-package-license@3.0.4
                                  │   │ │   ├─┬ spdx-correct@3.1.1
                                  │   │ │   │ ├── spdx-expression-parse@3.0.1 deduped
                                  │   │ │   │ └── spdx-license-ids@3.0.11
                                  │   │ │   └─┬ spdx-expression-parse@3.0.1
                                  │   │ │     ├── spdx-exceptions@2.3.0
                                  │   │ │     └── spdx-license-ids@3.0.11 deduped
                                  │   │ ├── read-pkg-up@7.0.1 deduped
                                  │   │ ├─┬ redent@3.0.0
                                  │   │ │ ├── indent-string@4.0.0
                                  │   │ │ └─┬ strip-indent@3.0.0
                                  │   │ │   └── min-indent@1.0.1
                                  │   │ ├── trim-newlines@3.0.1
                                  │   │ ├── type-fest@0.18.1
                                  │   │ └── yargs-parser@20.2.9 deduped
                                  │   ├── minimatch@3.0.4 deduped
                                  │   ├─┬ new-github-release-url@1.0.0
                                  │   │ └── type-fest@0.4.1
                                  │   ├─┬ npm-name@6.0.1
                                  │   │ ├─┬ got@10.7.0
                                  │   │ │ ├── @sindresorhus/is@2.1.1
                                  │   │ │ ├─┬ @szmarczak/http-timer@4.0.6
                                  │   │ │ │ └── defer-to-connect@2.0.1
                                  │   │ │ ├─┬ @types/cacheable-request@6.0.2
                                  │   │ │ │ ├── @types/http-cache-semantics@4.0.1
                                  │   │ │ │ ├─┬ @types/keyv@3.1.3
                                  │   │ │ │ │ └── @types/node@16.11.11 deduped
                                  │   │ │ │ ├── @types/node@16.11.11 deduped
                                  │   │ │ │ └─┬ @types/responselike@1.0.0
                                  │   │ │ ├─┬ cacheable-lookup@2.0.1
                                  │   │ │ │ ├── @types/keyv@3.1.3 deduped
                                  │   │ │ │ └─┬ keyv@4.0.4
                                  │   │ │ │   └── json-buffer@3.0.1
                                  │   │ │ ├─┬ cacheable-request@7.0.2
                                  │   │ │ │ ├─┬ clone-response@1.0.2
                                  │   │ │ │ │ └── mimic-response@1.0.1
                                  │   │ │ │ ├─┬ get-stream@5.2.0
                                  │   │ │ │ │ └─┬ pump@3.0.0
                                  │   │ │ │ │   ├── end-of-stream@1.4.4 deduped
                                  │   │ │ │ │   └── once@1.4.0 deduped
                                  │   │ │ │ ├── http-cache-semantics@4.1.0
                                  │   │ │ │ ├── keyv@4.0.4 deduped
                                  │   │ │ │ ├── lowercase-keys@2.0.0 deduped
                                  │   │ │ │ ├── normalize-url@6.1.0
                                  │   │ │ │ └── responselike@2.0.0 deduped
                                  │   │ │ ├─┬ decompress-response@5.0.0
                                  │   │ │ │ └── mimic-response@2.1.0 deduped
                                  │   │ │ ├── duplexer3@0.1.4
                                  │   │ │ ├── mimic-response@2.1.0 deduped
                                  │   │ │ ├── p-cancelable@2.1.1
                                  │   │ │ ├─┬ p-event@4.2.0
                                  │   │ │ │ └─┬ p-timeout@3.2.0
                                  │   │ │ │   └── p-finally@1.0.0
                                  │   │ │ ├─┬ responselike@2.0.0
                                  │   │ │ │ └── lowercase-keys@2.0.0 deduped
                                  │   │ │ ├── to-readable-stream@2.1.0
                                  │   │ │ └── type-fest@0.10.0
                                  │   │ ├── is-scoped@2.1.0 deduped
                                  │   │ ├── is-url-superb@4.0.0
                                  │   │ ├── lodash.zip@4.2.0
                                  │   │ ├── org-regex@1.0.0
                                  │   │ ├─┬ p-map@3.0.0
                                  │   │ │ └── aggregate-error@3.1.0 deduped
                                  │   │ ├─┬ registry-auth-token@4.2.1
                                  │   │ │ └── rc@1.2.8 deduped
                                  │   │ ├─┬ registry-url@5.1.0
                                  │   │ └─┬ validate-npm-package-name@3.0.0
                                  │   │   └── builtins@1.0.3
                                  │   ├─┬ onetime@5.1.2
                                  │   │ └── mimic-fn@2.1.0
                                  │   ├─┬ open@7.4.2
                                  │   │ ├── is-docker@2.2.1
                                  │   │ └─┬ is-wsl@2.2.0
                                  │   │   └── is-docker@2.2.1 deduped
                                  │   ├─┬ ow@0.21.0
                                  │   │ ├── @sindresorhus/is@4.2.0
                                  │   │ ├── callsites@3.1.0
                                  │   │ ├─┬ dot-prop@6.0.1
                                  │   │ │ └── is-obj@2.0.0
                                  │   │ ├── lodash.isequal@4.5.0
                                  │   │ ├── type-fest@0.20.2
                                  │   │ └── vali-date@1.0.0
                                  │   ├─┬ p-memoize@4.0.3
                                  │   │ ├─┬ map-age-cleaner@0.1.3
                                  │   │ │ └── p-defer@1.0.0
                                  │   │ ├── mimic-fn@3.1.0
                                  │   │ └─┬ p-settle@4.1.1
                                  │   │   ├─┬ p-limit@2.3.0
                                  │   │   │ └── p-try@2.2.0
                                  │   │   └── p-reflect@2.1.0
                                  │   ├── p-timeout@4.1.0
                                  │   ├─┬ pkg-dir@5.0.0
                                  │   │ └─┬ find-up@5.0.0
                                  │   │   ├─┬ locate-path@6.0.0
                                  │   │   │ └─┬ p-locate@5.0.0
                                  │   │   │   └─┬ p-limit@3.1.0
                                  │   │   │     └── yocto-queue@0.1.0
                                  │   │   └── path-exists@4.0.0
                                  │   ├─┬ read-pkg-up@7.0.1
                                  │   │ ├─┬ find-up@4.1.0
                                  │   │ │ ├─┬ locate-path@5.0.0
                                  │   │ │ │ └─┬ p-locate@4.1.0
                                  │   │ │ │   └── p-limit@2.3.0 deduped
                                  │   │ │ └── path-exists@4.0.0 deduped
                                  │   │ ├─┬ read-pkg@5.2.0
                                  │   │ │ ├── @types/normalize-package-data@2.4.1
                                  │   │ │ ├─┬ normalize-package-data@2.5.0
                                  │   │ │ │ ├── hosted-git-info@2.8.9
                                  │   │ │ │ ├─┬ resolve@1.20.0
                                  │   │ │ │ │ ├── is-core-module@2.8.0 deduped
                                  │   │ │ │ │ └── path-parse@1.0.7
                                  │   │ │ │ ├── semver@5.7.1
                                  │   │ │ │ └── validate-npm-package-license@3.0.4 deduped
                                  │   │ │ ├── parse-json@5.2.0 deduped
                                  │   │ │ └── type-fest@0.6.0
                                  │   │ └── type-fest@0.8.1
                                  │   ├─┬ rxjs@6.6.7
                                  │   │ └── tslib@1.14.1 deduped
                                  │   ├── split@1.0.1 deduped
                                  │   ├── symbol-observable@3.0.0
                                  │   ├─┬ terminal-link@2.1.1
                                  │   │ ├── ansi-escapes@4.3.2 deduped
                                  │   │ └─┬ supports-hyperlinks@2.2.0
                                  │   │   ├── has-flag@4.0.0 deduped
                                  │   │   └── supports-color@7.2.0 deduped
                                  │   └─┬ update-notifier@5.1.0
                                  │     ├─┬ boxen@5.1.2
                                  │     │ ├─┬ ansi-align@3.0.1
                                  │     │ │ └── string-width@4.2.3 deduped
                                  │     │ ├── camelcase@6.2.1
                                  │     │ ├── cli-boxes@2.2.1
                                  │     │ ├─┬ widest-line@3.1.0
                                  │     │ └─┬ wrap-ansi@7.0.0
                                  │     │   ├── ansi-styles@4.3.0 deduped
                                  │     │   └── strip-ansi@6.0.1 deduped
                                  │     ├─┬ configstore@5.0.1
                                  │     │ ├─┬ dot-prop@5.3.0
                                  │     │ │ └── is-obj@2.0.0 deduped
                                  │     │ ├── make-dir@3.1.0 deduped
                                  │     │ ├─┬ unique-string@2.0.0
                                  │     │ │ └── crypto-random-string@2.0.0
                                  │     │ ├─┬ write-file-atomic@3.0.3
                                  │     │ │ ├── imurmurhash@0.1.4
                                  │     │ │ ├── is-typedarray@1.0.0 deduped
                                  │     │ │ ├── signal-exit@3.0.6 deduped
                                  │     │ │ └─┬ typedarray-to-buffer@3.1.5
                                  │     │ │   └── is-typedarray@1.0.0 deduped
                                  │     │ └── xdg-basedir@4.0.0 deduped
                                  │     ├── has-yarn@2.1.0 deduped
                                  │     ├── import-lazy@2.1.0
                                  │     ├─┬ is-ci@2.0.0
                                  │     │ └── ci-info@2.0.0
                                  │     ├─┬ is-installed-globally@0.4.0
                                  │     │ ├─┬ global-dirs@3.0.0
                                  │     │ │ └── ini@2.0.0
                                  │     ├── is-npm@5.0.0
                                  │     ├── is-yarn-global@0.3.0
                                  │     ├─┬ latest-version@5.1.0
                                  │     │ └─┬ package-json@6.5.0
                                  │     │   ├─┬ got@9.6.0
                                  │     │   │ ├── @sindresorhus/is@0.14.0
                                  │     │   │ ├─┬ @szmarczak/http-timer@1.1.2
                                  │     │   │ │ └── defer-to-connect@1.1.3
                                  │     │   │ ├─┬ cacheable-request@6.1.0
                                  │     │   │ │ ├── clone-response@1.0.2 deduped
                                  │     │   │ │ │ └── pump@3.0.0 deduped
                                  │     │   │ │ ├── http-cache-semantics@4.1.0 deduped
                                  │     │   │ │ ├─┬ keyv@3.1.0
                                  │     │   │ │ │ └── json-buffer@3.0.0
                                  │     │   │ │ ├── normalize-url@4.5.1
                                  │     │   │ │ └─┬ responselike@1.0.2
                                  │     │   │ │   └── lowercase-keys@1.0.1 deduped
                                  │     │   │ ├─┬ decompress-response@3.3.0
                                  │     │   │ │ └── mimic-response@1.0.1 deduped
                                  │     │   │ ├── duplexer3@0.1.4 deduped
                                  │     │   │ ├─┬ get-stream@4.1.0
                                  │     │   │ ├── lowercase-keys@1.0.1
                                  │     │   │ ├── mimic-response@1.0.1
                                  │     │   │ ├── p-cancelable@1.1.0
                                  │     │   │ ├── to-readable-stream@1.0.0
                                  │     │   │ └─┬ url-parse-lax@3.0.0
                                  │     │   │   └── prepend-http@2.0.0
                                  │     │   ├── registry-auth-token@4.2.1 deduped
                                  │     │   ├── registry-url@5.1.0 deduped
                                  │     │   └── semver@6.3.0
                                  │     ├─┬ pupa@2.1.1
                                  │     │ └── escape-goat@2.1.1
                                  │     ├─┬ semver-diff@3.1.1
                                  ├─┬ iobroker.web@3.4.9
                                  │ ├── @iobroker/adapter-core@2.5.1 deduped
                                  │ ├── body-parser@1.19.0 deduped
                                  │ ├── connect-flash@0.1.1 deduped
                                  │ ├── cookie-parser@1.4.6 deduped
                                  │ ├── express@4.17.1 deduped
                                  │ ├── express-session@1.17.2 deduped
                                  │ ├─┬ iobroker.simple-api@2.6.2
                                  │ │ └── @iobroker/adapter-core@2.5.1 deduped
                                  │ ├─┬ iobroker.socketio@3.1.5
                                  │ │ ├── @iobroker/adapter-core@2.5.1 deduped
                                  │ │ ├─┬ axios@0.23.0
                                  │ │ │ └── follow-redirects@1.14.5 deduped
                                  │ │ ├── cookie-parser@1.4.6 deduped
                                  │ │ ├── express-session@1.17.2 deduped
                                  │ │ └─┬ socket.io@2.4.1
                                  │ │   ├─┬ debug@4.1.1
                                  │ │   │ └── ms@2.1.3 deduped
                                  │ │   ├─┬ engine.io@3.5.0
                                  │ │   │ ├── accepts@1.3.7 deduped
                                  │ │   │ ├── base64id@2.0.0
                                  │ │   │ ├── cookie@0.4.1
                                  │ │   │ ├─┬ debug@4.1.1
                                  │ │   │ │ └── ms@2.1.3 deduped
                                  │ │   │ ├── engine.io-parser@2.2.1 deduped
                                  │ │   │ └── ws@7.4.6
                                  │ │   ├── has-binary2@1.0.3 deduped
                                  │ │   ├── socket.io-adapter@1.1.2
                                  │ │   ├── socket.io-client@2.4.0 deduped
                                  │ │   └─┬ socket.io-parser@3.4.1
                                  │ │     ├── component-emitter@1.2.1
                                  │ │     ├─┬ debug@4.1.1
                                  │ │     └── isarray@2.0.1
                                  │ ├─┬ mime-types@2.1.34
                                  │ │ └── mime-db@1.51.0
                                  │ ├─┬ passport@0.4.1
                                  │ │ ├── passport-strategy@1.0.0 deduped
                                  │ │ └── pause@0.0.1 deduped
                                  │ ├── passport-local@1.0.0 deduped
                                  │ ├── passport.socketio@3.7.0 deduped
                                  │ ├─┬ socket.io-client@2.4.0
                                  │ │ ├── backo2@1.0.2
                                  │ │ ├── component-bind@1.0.0
                                  │ │ ├── component-emitter@1.3.0
                                  │ │ ├─┬ debug@3.1.0
                                  │ │ │ └── ms@2.0.0
                                  │ │ ├─┬ engine.io-client@3.5.2
                                  │ │ │ ├── component-emitter@1.3.0 deduped
                                  │ │ │ ├── component-inherit@0.0.3
                                  │ │ │ ├─┬ debug@3.1.0
                                  │ │ │ │ └── ms@2.0.0
                                  │ │ │ ├─┬ engine.io-parser@2.2.1
                                  │ │ │ │ ├── after@0.8.2
                                  │ │ │ │ ├── arraybuffer.slice@0.0.7
                                  │ │ │ │ ├── base64-arraybuffer@0.1.4
                                  │ │ │ │ ├── blob@0.0.5
                                  │ │ │ │ └── has-binary2@1.0.3 deduped
                                  │ │ │ ├── has-cors@1.1.0
                                  │ │ │ ├── indexof@0.0.1 deduped
                                  │ │ │ ├── parseqs@0.0.6 deduped
                                  │ │ │ ├── parseuri@0.0.6 deduped
                                  │ │ │ ├── ws@7.4.6
                                  │ │ │ ├── xmlhttprequest-ssl@1.6.3
                                  │ │ │ └── yeast@0.1.2
                                  │ │ ├─┬ has-binary2@1.0.3
                                  │ │ │ └── isarray@2.0.1
                                  │ │ ├─┬ socket.io-parser@3.3.2
                                  │ │ │ ├── debug@3.1.0 deduped
                                  │ │ └── to-array@0.1.4
                                  │ └── xtend@4.0.2
                                  └─┬ iobroker.zigbee@1.5.6
                                    ├── tar@6.1.11 deduped
                                    ├── typescript@4.5.2 deduped
                                    ├─┬ zigbee-herdsman@0.13.110
                                    │ ├── @babel/cli@7.13.0 extraneous
                                    │ ├── @babel/preset-env@7.13.9 extraneous
                                    │ ├── @babel/preset-typescript@7.13.0 extraneous
                                    │ ├─┬ @serialport/bindings@9.0.4
                                    │ │ ├─┬ @serialport/binding-abstract@9.0.7
                                    │ │ │ └── debug@4.3.1 deduped
                                    │ │ ├─┬ @serialport/parser-readline@9.0.7
                                    │ │ │ └── @serialport/parser-delimiter@9.0.7 deduped
                                    │ │ ├─┬ bindings@1.5.0
                                    │ │ │ └── file-uri-to-path@1.0.0
                                    │ │ ├── debug@4.3.1 deduped
                                    │ │ ├── nan@2.14.2
                                    │ │ └─┬ prebuild-install@6.0.1
                                    │ │   ├── detect-libc@1.0.3
                                    │ │   ├── expand-template@2.0.3
                                    │ │   ├── github-from-package@0.0.0
                                    │ │   ├── minimist@1.2.5
                                    │ │   ├── mkdirp-classic@0.5.3
                                    │ │   ├── napi-build-utils@1.0.2
                                    │ │   ├─┬ node-abi@2.20.0
                                    │ │   │ └── semver@5.7.1
                                    │ │   ├── noop-logger@0.1.1
                                    │ │   ├─┬ npmlog@4.1.2
                                    │ │   │ ├─┬ are-we-there-yet@1.1.5
                                    │ │   │ │ ├── delegates@1.0.0
                                    │ │   │ │ └─┬ readable-stream@2.3.7
                                    │ │   │ │   ├── core-util-is@1.0.2
                                    │ │   │ │   ├── inherits@2.0.4 deduped
                                    │ │   │ │   ├── isarray@1.0.0
                                    │ │   │ │   ├── process-nextick-args@2.0.1
                                    │ │   │ │   ├── safe-buffer@5.1.2 deduped
                                    │ │   │ │   ├─┬ string_decoder@1.1.1
                                    │ │   │ │   │ └── safe-buffer@5.1.2 deduped
                                    │ │   │ │   └── util-deprecate@1.0.2
                                    │ │   │ ├── console-control-strings@1.1.0
                                    │ │   │ ├─┬ gauge@2.7.4
                                    │ │   │ │ ├── aproba@1.2.0
                                    │ │   │ │ ├── console-control-strings@1.1.0 deduped
                                    │ │   │ │ ├── has-unicode@2.0.1
                                    │ │   │ │ ├── object-assign@4.1.1 deduped
                                    │ │   │ │ ├── signal-exit@3.0.3
                                    │ │   │ │ ├─┬ string-width@1.0.2
                                    │ │   │ │ │ ├── code-point-at@1.1.0
                                    │ │   │ │ │ ├─┬ is-fullwidth-code-point@1.0.0
                                    │ │   │ │ │ │ └── number-is-nan@1.0.1
                                    │ │   │ │ │ └── strip-ansi@3.0.1 deduped
                                    │ │   │ │ ├─┬ strip-ansi@3.0.1
                                    │ │   │ │ └─┬ wide-align@1.1.3
                                    │ │   │ │   └── string-width@1.0.2 deduped
                                    │ │   │ └── set-blocking@2.0.0
                                    │ │   ├─┬ pump@3.0.0
                                    │ │   │ ├─┬ end-of-stream@1.4.4
                                    │ │   │ └─┬ once@1.4.0
                                    │ │   │   └── wrappy@1.0.2
                                    │ │   ├─┬ rc@1.2.8
                                    │ │   │ ├── deep-extend@0.6.0
                                    │ │   │ ├── ini@1.3.8
                                    │ │   │ ├── minimist@1.2.5 deduped
                                    │ │   │ └── strip-json-comments@2.0.1
                                    │ │   ├─┬ simple-get@3.1.0
                                    │ │   │ ├─┬ decompress-response@4.2.1
                                    │ │   │ ├── once@1.4.0 deduped
                                    │ │   │ └── simple-concat@1.0.1
                                    │ │   ├─┬ tar-fs@2.1.1
                                    │ │   │ ├── chownr@1.1.4
                                    │ │   │ ├── mkdirp-classic@0.5.3 deduped
                                    │ │   │ ├── pump@3.0.0 deduped
                                    │ │   │ └─┬ tar-stream@2.2.0
                                    │ │   │   ├─┬ bl@4.1.0
                                    │ │   │   │ ├─┬ buffer@5.7.1
                                    │ │   │   │ │ ├── base64-js@1.5.1
                                    │ │   │   │ │ └── ieee754@1.2.1
                                    │ │   │   │ └─┬ readable-stream@3.6.0
                                    │ │   │   │   ├── string_decoder@1.1.1 deduped
                                    │ │   │   │   └── util-deprecate@1.0.2 deduped
                                    │ │   │   ├── fs-constants@1.0.0
                                    │ │   ├─┬ tunnel-agent@0.6.0
                                    │ │   └── which-pm-runs@1.0.0
                                    │ ├── @types/debounce@1.2.0 extraneous
                                    │ ├── @types/debug@4.1.5 extraneous
                                    │ ├── @types/jest@26.0.20 extraneous
                                    │ ├── @types/mz@2.7.3 extraneous
                                    │ ├── @types/nedb@1.8.11 extraneous
                                    │ ├── @types/serialport@8.0.1 extraneous
                                    │ ├── @typescript-eslint/eslint-plugin@4.16.1 extraneous
                                    │ ├── @typescript-eslint/parser@4.16.1 extraneous
                                    │ ├── debounce@1.2.0
                                    │ ├─┬ debug@4.3.1
                                    │ │ └── ms@2.1.2
                                    │ ├── eslint@7.21.0 extraneous
                                    │ ├── fast-deep-equal@3.1.3
                                    │ ├── jest@26.6.3 extraneous
                                    │ ├── mixin-deep@2.0.1
                                    │ ├─┬ mz@2.7.0
                                    │ │ ├── any-promise@1.3.0
                                    │ │ └─┬ thenify-all@1.6.0
                                    │ │   └─┬ thenify@3.3.1
                                    │ │     └── any-promise@1.3.0 deduped
                                    │ ├─┬ serialport@9.0.6
                                    │ │ ├─┬ @serialport/binding-mock@9.0.7
                                    │ │ │ ├── @serialport/binding-abstract@9.0.7 deduped
                                    │ │ ├── @serialport/bindings@9.0.4 deduped
                                    │ │ ├── @serialport/parser-byte-length@9.0.7
                                    │ │ ├── @serialport/parser-cctalk@9.0.7
                                    │ │ ├── @serialport/parser-delimiter@9.0.7
                                    │ │ ├── @serialport/parser-inter-byte-timeout@9.0.7
                                    │ │ ├── @serialport/parser-readline@9.0.7 deduped
                                    │ │ ├── @serialport/parser-ready@9.0.7
                                    │ │ ├── @serialport/parser-regex@9.0.7
                                    │ │ ├─┬ @serialport/stream@9.0.7
                                    │ ├── slip@1.0.2
                                    │ ├── typedoc@0.20.28 extraneous
                                    │ ├── typedoc-plugin-markdown@3.6.0 extraneous
                                    │ ├── typedoc-plugin-no-inherit@1.2.0 extraneous
                                    │ ├── typedoc-plugin-sourcefile-url@1.0.6 extraneous
                                    │ └── UNMET PEER DEPENDENCY typescript@4.2.2 extraneous
                                    └─┬ zigbee-herdsman-converters@14.0.162
                                      ├─┬ axios@0.21.1
                                      │ └── follow-redirects@1.14.1
                                      ├── buffer-crc32@0.2.13
                                      ├── eslint@7.27.0 extraneous
                                      ├── eslint-config-google@0.14.0 extraneous
                                      ├── eslint-plugin-jest@24.3.6 extraneous
                                      ├─┬ https-proxy-agent@5.0.0
                                      │ ├─┬ agent-base@6.0.2
                                      │ └─┬ debug@4.3.1
                                      │   └── ms@2.1.2
                                      ├─┬ tar-stream@2.2.0
                                      │ ├─┬ bl@4.1.0
                                      │ │ └── readable-stream@3.6.0 deduped
                                      │ │ └─┬ once@1.4.0
                                      │   ├─┬ string_decoder@1.3.0
                                      └─┬ zigbee-herdsman@0.13.107
                                        │ ├── nan@2.14.2
                                        │   ├─┬ npmlog@4.1.2
                                        │   │ ├─┬ gauge@2.7.4
                                        │   ├─┬ pump@3.0.0
                                        │   │ └─┬ once@1.4.0
                                        │   ├─┬ rc@1.2.8
                                        │   │ ├── ini@1.3.8
                                        │   ├─┬ tar-fs@2.1.1
                                        │   │   ├─┬ bl@4.1.0
                                        ├── debounce@1.2.0
                                        ├─┬ debug@4.3.1
                                        │ └── ms@2.1.2
                                        ├─┬ mz@2.7.0
                                        │   └─┬ thenify@3.3.1
                                        ├── slip@1.0.2
                                  npm ERR! peer dep missing: @angular/common@>= 5.0.0, required by xmlhttprequest-ts@1.0.1
                                  npm ERR! peer dep missing: @angular/core@>= 5.0.0, required by xmlhttprequest-ts@1.0.1
                                  Haben die Error-Meldung irgendeine Auswirkung und müssen beseitigt werden?
                                  • S sanda
                                    │ │ ├─┬ bl@1.2.3
                                    │ │ ├── mime@1.6.0
                                    │ │ ├─┬ pump@2.0.1
                                    │ └─┬ socksv5@0.0.6
                                    │   └─┬ ipv6@3.1.1
                                    │     ├─┬ cli@0.4.5
                                    │     ├─┬ cliff@0.1.10
                                    │     └── sprintf@0.1.3
                                    │ └─┬ np@7.6.0
                                    │   ├─┬ chalk@4.1.2
                                    │   │ └── yaml@1.10.2
                                    │   ├─┬ del@6.0.0
                                    │   │ ├─┬ p-map@4.0.0
                                    │   │ └── slash@3.0.0
                                    │   ├─┬ execa@5.1.1
                                    │   │ │ └── ini@1.3.7
                                    │   ├─┬ listr@0.14.3
                                    │   │ ├── p-map@2.1.0
                                    │   ├─┬ meow@8.1.2
                                    │   │ ├─┬ got@10.7.0
                                    │   │ ├─┬ p-map@3.0.0
                                    │   ├─┬ onetime@5.1.2
                                    │   ├─┬ open@7.4.2
                                    │   ├─┬ ow@0.21.0
                                    │   ├─┬ pkg-dir@5.0.0
                                    │   ├─┬ rxjs@6.6.7
                                    │     ├─┬ boxen@5.1.2
                                    │     ├─┬ is-ci@2.0.0
                                    │     │ │ └── ini@2.0.0
                                    │     ├── is-npm@5.0.0
                                    │     │   ├─┬ got@9.6.0
                                    │     ├─┬ pupa@2.1.1
                                    │ │   ├─┬ debug@4.1.1
                                    │ │   │ └── ws@7.4.6
                                    │ │     ├─┬ debug@4.1.1
                                    │ │ ├─┬ debug@3.1.0
                                    │ │ │ └── ms@2.0.0
                                    │ │ │ ├── ws@7.4.6
                                    │ └── xtend@4.0.2
                                      │ │ ├── nan@2.14.2
                                      │ │   ├─┬ pump@3.0.0
                                      │ │   ├─┬ rc@1.2.8
                                      │ │   │ ├── ini@1.3.8
                                      │ │   │   ├─┬ bl@4.1.0
                                      │ ├─┬ debug@4.3.1
                                      │ │ └── ms@2.1.2
                                      │ ├─┬ mz@2.7.0
                                      │ ├── slip@1.0.2
                                        ├─┬ axios@0.21.1
                                        │ └─┬ debug@4.3.1
                                        │   └── ms@2.1.2
                                        │ ├─┬ bl@4.1.0
                                        │ │ └─┬ once@1.4.0
                                          │ ├── nan@2.14.2
                                          │   ├─┬ npmlog@4.1.2
                                          │   │ ├─┬ gauge@2.7.4
                                          │   ├─┬ pump@3.0.0
                                          │   │ └─┬ once@1.4.0
                                          │   ├─┬ rc@1.2.8
                                          │   │ ├── ini@1.3.8
                                          │   ├─┬ tar-fs@2.1.1
                                          │   │   ├─┬ bl@4.1.0
                                          ├── debounce@1.2.0
                                          ├─┬ debug@4.3.1
                                          │ └── ms@2.1.2
                                          ├─┬ mz@2.7.0
                                          │   └─┬ thenify@3.3.1
                                          ├── slip@1.0.2
                                    @sanda sagte in Fehler in Adapterinstallation:
                                    Eigentlicht ist mein Ansatz ja Meldungen soweit wie möglich auch zu adressieren.
                                    In dem Fall würde ich allerdings die Finger davon lassen. Das wird sich (vermutlich) mit künftigen Updates auswachsen.
                                      sanda
                                      @thomas-braun Hab ich mir auch gedacht und hoffe natürlich, dass es auch sein wird 👍
