[gelöst] Fehler in Adapterinstallation
@thomas-braun said in Fehler in Adapterinstallation:
iobroker fix
Das hat nun etwas länger mit der Ausgabe gedauert.
Zu viele Errormeldunge
sudo -H -u iobroker npm install iobroker.js-controller npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it! The authenticity of host 'github.com (140.82.121.4)' can't be established.me/iobroker/.npm/_locks/staging-66d2468782e8ffc7 ECDSA key fingerprint is SHA256:p2QAMXNIC1TJYWeIOttrVc98/R1BUFWu3/LiyKgUfQM. Are you sure you want to continue connecting (yes/no)? [ ...........] | extract:iobroker.js-controller: verb lock usi[ ......] \ extract:npm: sill extract npm@7.11.1 extracted to /opt/iobroker/node_modules/.staging/npm-fc55516d npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}) npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/common@>= 5.0.0 but none is installed. You must install peer dependencies yourself. npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/core@>= 5.0.0 but none is installed. You must install peer dependencies yourself. npm WARN typedoc@0.20.28 requires a peer of typescript@3.9.x || 4.0.x || 4.1.x but none is installed. You must install peer dependencies yourself. npm WARN typedoc@0.20.28 requires a peer of typescript@3.9.x || 4.0.x || 4.1.x but none is installed. You must install peer dependencies yourself. npm ERR! Error while executing: npm ERR! /usr/bin/git ls-remote -h -t ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git npm ERR! npm ERR! Host key verification failed. npm ERR! fatal: Could not read from remote repository. npm ERR! npm ERR! Please make sure you have the correct access rights npm ERR! and the repository exists. npm ERR! npm ERR! exited with error code: 128 npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2021-11-30T13_48_08_408Z-debug.log@sanda sagte in Fehler in Adapterinstallation:
da isser wieder :-(
iobroker fix
Da hast du aber mal mit einer npm>6 herumhantiert...
Kannst du mal bitte die ungekürzte Ausgabe von
cd /opt/iobroker npm lsgeben?
@thomas-braun sagte in Fehler in Adapterinstallation:
also /opt/iobroker/package-lock.json löschen
Hier die Ausgabe, passt nicht mal ins Terminal
│ │ ├── cookie@0.4.1 │ │ ├── cookie-signature@1.0.6 deduped │ │ ├── debug@2.6.9 deduped │ │ ├── depd@2.0.0 │ │ ├── on-headers@1.0.2 deduped │ │ ├── parseurl@1.3.3 deduped │ │ ├── safe-buffer@5.2.1 │ │ └── uid-safe@2.1.5 deduped │ ├── iobroker.simple-api@2.6.1 deduped │ ├── iobroker.socketio@3.1.4 deduped │ ├─┬ mime-types@2.1.32 │ │ └── mime-db@1.49.0 │ ├── passport@0.4.1 deduped │ ├── passport-local@1.0.0 deduped │ ├── passport.socketio@3.7.0 deduped │ ├── request@2.88.2 deduped │ ├─┬ socket.io-client@2.3.0 │ │ ├── backo2@1.0.2 │ │ ├── base64-arraybuffer@0.1.5 │ │ ├── component-bind@1.0.0 │ │ ├── component-emitter@1.2.1 │ │ ├─┬ debug@4.1.1 │ │ │ └── ms@2.1.2 │ │ ├─┬ engine.io-client@3.4.3 │ │ │ ├── component-emitter@1.3.0 │ │ │ ├── component-inherit@0.0.3 │ │ │ ├─┬ debug@4.1.1 │ │ │ │ └── ms@2.1.2 │ │ │ ├── engine.io-parser@2.2.0 deduped │ │ │ ├── has-cors@1.1.0 deduped │ │ │ ├── indexof@0.0.1 deduped │ │ │ ├── parseqs@0.0.5 deduped │ │ │ ├── parseuri@0.0.5 deduped │ │ │ ├─┬ ws@6.1.4 │ │ │ │ └── async-limiter@1.0.1 deduped │ │ │ ├── xmlhttprequest-ssl@1.5.5 │ │ │ └── yeast@0.1.2 │ │ ├── has-binary2@1.0.3 deduped │ │ ├── has-cors@1.1.0 │ │ ├── indexof@0.0.1 │ │ ├── object-component@0.0.3 │ │ ├─┬ parseqs@0.0.5 │ │ │ └─┬ better-assert@1.0.2 │ │ │ └── callsite@1.0.0 deduped │ │ ├─┬ parseuri@0.0.5 │ │ │ └── better-assert@1.0.2 deduped │ │ ├─┬ socket.io-parser@3.3.0 │ │ │ ├── component-emitter@1.2.1 deduped │ │ │ ├─┬ debug@3.1.0 │ │ │ │ └── ms@2.0.0 │ │ │ └── isarray@2.0.1 deduped │ │ └── to-array@0.1.4 │ └── xtend@4.0.2 ├─┬ iobroker.zigbee@1.5.6 │ ├── @iobroker/adapter-core@2.5.1 deduped │ ├─┬ tar@6.1.0 │ │ ├── chownr@2.0.0 │ │ ├── fs-minipass@2.1.0 deduped │ │ ├── minipass@3.1.3 deduped │ │ ├─┬ minizlib@2.1.2 │ │ │ ├── minipass@3.1.3 deduped │ │ │ └── yallist@4.0.0 deduped │ │ ├── mkdirp@1.0.4 │ │ └── yallist@4.0.0 deduped │ ├── typescript@4.4.4 deduped │ ├─┬ zigbee-herdsman@0.13.110 │ │ ├── @babel/cli@7.13.0 extraneous │ │ ├── @babel/preset-env@7.13.9 extraneous │ │ ├── @babel/preset-typescript@7.13.0 extraneous │ │ ├─┬ @serialport/bindings@9.0.4 │ │ │ ├─┬ @serialport/binding-abstract@9.0.7 │ │ │ │ └── debug@4.3.1 deduped │ │ │ ├─┬ @serialport/parser-readline@9.0.7 │ │ │ │ └── @serialport/parser-delimiter@9.0.7 deduped │ │ │ ├─┬ bindings@1.5.0 │ │ │ │ └── file-uri-to-path@1.0.0 │ │ │ ├── debug@4.3.1 deduped │ │ │ ├── nan@2.14.2 │ │ │ └─┬ prebuild-install@6.0.1 │ │ │ ├── detect-libc@1.0.3 │ │ │ ├── expand-template@2.0.3 │ │ │ ├── github-from-package@0.0.0 │ │ │ ├── minimist@1.2.5 │ │ │ ├── mkdirp-classic@0.5.3 │ │ │ ├── napi-build-utils@1.0.2 │ │ │ ├─┬ node-abi@2.20.0 │ │ │ │ └── semver@5.7.1 │ │ │ ├── noop-logger@0.1.1 │ │ │ ├─┬ npmlog@4.1.2 │ │ │ │ ├─┬ are-we-there-yet@1.1.5 │ │ │ │ │ ├── delegates@1.0.0 │ │ │ │ │ └─┬ readable-stream@2.3.7 │ │ │ │ │ ├── core-util-is@1.0.2 │ │ │ │ │ ├── inherits@2.0.4 deduped │ │ │ │ │ ├── isarray@1.0.0 │ │ │ │ │ ├── process-nextick-args@2.0.1 │ │ │ │ │ ├── safe-buffer@5.1.2 deduped │ │ │ │ │ ├─┬ string_decoder@1.1.1 │ │ │ │ │ │ └── safe-buffer@5.1.2 deduped │ │ │ │ │ └── util-deprecate@1.0.2 │ │ │ │ ├── console-control-strings@1.1.0 │ │ │ │ ├─┬ gauge@2.7.4 │ │ │ │ │ ├── aproba@1.2.0 │ │ │ │ │ ├── console-control-strings@1.1.0 deduped │ │ │ │ │ ├── has-unicode@2.0.1 │ │ │ │ │ ├── object-assign@4.1.1 deduped │ │ │ │ │ ├── signal-exit@3.0.3 │ │ │ │ │ ├─┬ string-width@1.0.2 │ │ │ │ │ │ ├── code-point-at@1.1.0 │ │ │ │ │ │ ├─┬ is-fullwidth-code-point@1.0.0 │ │ │ │ │ │ │ └── number-is-nan@1.0.1 │ │ │ │ │ │ └── strip-ansi@3.0.1 deduped │ │ │ │ │ ├─┬ strip-ansi@3.0.1 │ │ │ │ │ │ └── ansi-regex@2.1.1 │ │ │ │ │ └─┬ wide-align@1.1.3 │ │ │ │ │ └── string-width@1.0.2 deduped │ │ │ │ └── set-blocking@2.0.0 │ │ │ ├─┬ pump@3.0.0 │ │ │ │ ├─┬ end-of-stream@1.4.4 │ │ │ │ │ └── once@1.4.0 deduped │ │ │ │ └─┬ once@1.4.0 │ │ │ │ └── wrappy@1.0.2 │ │ │ ├─┬ rc@1.2.8 │ │ │ │ ├── deep-extend@0.6.0 │ │ │ │ ├── ini@1.3.8 │ │ │ │ ├── minimist@1.2.5 deduped │ │ │ │ └── strip-json-comments@2.0.1 │ │ │ ├─┬ simple-get@3.1.0 │ │ │ │ ├─┬ decompress-response@4.2.1 │ │ │ │ │ └── mimic-response@2.1.0 │ │ │ │ ├── once@1.4.0 deduped │ │ │ │ └── simple-concat@1.0.1 │ │ │ ├─┬ tar-fs@2.1.1 │ │ │ │ ├── chownr@1.1.4 │ │ │ │ ├── mkdirp-classic@0.5.3 deduped │ │ │ │ ├── pump@3.0.0 deduped │ │ │ │ └─┬ tar-stream@2.2.0 │ │ │ │ ├─┬ bl@4.1.0 │ │ │ │ │ ├─┬ buffer@5.7.1 │ │ │ │ │ │ ├── base64-js@1.5.1 │ │ │ │ │ │ └── ieee754@1.2.1 │ │ │ │ │ ├── inherits@2.0.4 deduped │ │ │ │ │ └─┬ readable-stream@3.6.0 │ │ │ │ │ ├── inherits@2.0.4 deduped │ │ │ │ │ ├── string_decoder@1.1.1 deduped │ │ │ │ │ └── util-deprecate@1.0.2 deduped │ │ │ │ ├── end-of-stream@1.4.4 deduped │ │ │ │ ├── fs-constants@1.0.0 │ │ │ │ ├── inherits@2.0.4 │ │ │ │ └─┬ readable-stream@3.6.0 │ │ │ │ ├── inherits@2.0.4 deduped │ │ │ │ ├── string_decoder@1.1.1 deduped │ │ │ │ └── util-deprecate@1.0.2 deduped │ │ │ ├─┬ tunnel-agent@0.6.0 │ │ │ │ └── safe-buffer@5.1.2 │ │ │ └── which-pm-runs@1.0.0 │ │ ├── @types/debounce@1.2.0 extraneous │ │ ├── @types/debug@4.1.5 extraneous │ │ ├── @types/jest@26.0.20 extraneous │ │ ├── @types/mz@2.7.3 extraneous │ │ ├── @types/nedb@1.8.11 extraneous │ │ ├── @types/serialport@8.0.1 extraneous │ │ ├── @typescript-eslint/eslint-plugin@4.16.1 extraneous │ │ ├── @typescript-eslint/parser@4.16.1 extraneous │ │ ├── debounce@1.2.0 │ │ ├─┬ debug@4.3.1 │ │ │ └── ms@2.1.2 │ │ ├── eslint@7.21.0 extraneous │ │ ├── fast-deep-equal@3.1.3 │ │ ├── jest@26.6.3 extraneous │ │ ├── mixin-deep@2.0.1 │ │ ├─┬ mz@2.7.0 │ │ │ ├── any-promise@1.3.0 │ │ │ ├── object-assign@4.1.1 │ │ │ └─┬ thenify-all@1.6.0 │ │ │ └─┬ thenify@3.3.1 │ │ │ └── any-promise@1.3.0 deduped │ │ ├─┬ serialport@9.0.6 │ │ │ ├─┬ @serialport/binding-mock@9.0.7 │ │ │ │ ├── @serialport/binding-abstract@9.0.7 deduped │ │ │ │ └── debug@4.3.1 deduped │ │ │ ├── @serialport/bindings@9.0.4 deduped │ │ │ ├── @serialport/parser-byte-length@9.0.7 │ │ │ ├── @serialport/parser-cctalk@9.0.7 │ │ │ ├── @serialport/parser-delimiter@9.0.7 │ │ │ ├── @serialport/parser-inter-byte-timeout@9.0.7 │ │ │ ├── @serialport/parser-readline@9.0.7 deduped │ │ │ ├── @serialport/parser-ready@9.0.7 │ │ │ ├── @serialport/parser-regex@9.0.7 │ │ │ ├─┬ @serialport/stream@9.0.7 │ │ │ │ └── debug@4.3.1 deduped │ │ │ └── debug@4.3.1 deduped │ │ ├── slip@1.0.2 │ │ ├── typedoc@0.20.28 extraneous │ │ ├── typedoc-plugin-markdown@3.6.0 extraneous │ │ ├── typedoc-plugin-no-inherit@1.2.0 extraneous │ │ ├── typedoc-plugin-sourcefile-url@1.0.6 extraneous │ │ └── UNMET PEER DEPENDENCY typescript@4.2.2 extraneous │ └─┬ zigbee-herdsman-converters@14.0.162 │ ├─┬ axios@0.21.1 │ │ └── follow-redirects@1.14.1 │ ├── buffer-crc32@0.2.13 │ ├── eslint@7.27.0 extraneous │ ├── eslint-config-google@0.14.0 extraneous │ ├── eslint-plugin-jest@24.3.6 extraneous │ ├─┬ https-proxy-agent@5.0.0 │ │ ├─┬ agent-base@6.0.2 │ │ │ └── debug@4.3.1 deduped │ │ └─┬ debug@4.3.1 │ │ └── ms@2.1.2 │ ├── jest@26.6.3 extraneous │ ├─┬ tar-stream@2.2.0 │ │ ├─┬ bl@4.1.0 │ │ │ ├─┬ buffer@5.7.1 │ │ │ │ ├── base64-js@1.5.1 │ │ │ │ └── ieee754@1.2.1 │ │ │ ├── inherits@2.0.4 deduped │ │ │ └── readable-stream@3.6.0 deduped │ │ ├─┬ end-of-stream@1.4.4 │ │ │ └─┬ once@1.4.0 │ │ │ └── wrappy@1.0.2 │ │ ├── fs-constants@1.0.0 │ │ ├── inherits@2.0.4 │ │ └─┬ readable-stream@3.6.0 │ │ ├── inherits@2.0.4 deduped │ │ ├─┬ string_decoder@1.3.0 │ │ │ └── safe-buffer@5.2.1 │ │ └── util-deprecate@1.0.2 │ └─┬ zigbee-herdsman@0.13.107 │ ├── @babel/cli@7.13.0 extraneous │ ├── @babel/preset-env@7.13.9 extraneous │ ├── @babel/preset-typescript@7.13.0 extraneous │ ├─┬ @serialport/bindings@9.0.4 │ │ ├─┬ @serialport/binding-abstract@9.0.7 │ │ │ └── debug@4.3.1 deduped │ │ ├─┬ @serialport/parser-readline@9.0.7 │ │ │ └── @serialport/parser-delimiter@9.0.7 deduped │ │ ├─┬ bindings@1.5.0 │ │ │ └── file-uri-to-path@1.0.0 │ │ ├── debug@4.3.1 deduped │ │ ├── nan@2.14.2 │ │ └─┬ prebuild-install@6.0.1 │ │ ├── detect-libc@1.0.3 │ │ ├── expand-template@2.0.3 │ │ ├── github-from-package@0.0.0 │ │ ├── minimist@1.2.5 │ │ ├── mkdirp-classic@0.5.3 │ │ ├── napi-build-utils@1.0.2 │ │ ├─┬ node-abi@2.20.0 │ │ │ └── semver@5.7.1 │ │ ├── noop-logger@0.1.1 │ │ ├─┬ npmlog@4.1.2 │ │ │ ├─┬ are-we-there-yet@1.1.5 │ │ │ │ ├── delegates@1.0.0 │ │ │ │ └─┬ readable-stream@2.3.7 │ │ │ │ ├── core-util-is@1.0.2 │ │ │ │ ├── inherits@2.0.4 deduped │ │ │ │ ├── isarray@1.0.0 │ │ │ │ ├── process-nextick-args@2.0.1 │ │ │ │ ├── safe-buffer@5.1.2 deduped │ │ │ │ ├─┬ string_decoder@1.1.1 │ │ │ │ │ └── safe-buffer@5.1.2 deduped │ │ │ │ └── util-deprecate@1.0.2 │ │ │ ├── console-control-strings@1.1.0 │ │ │ ├─┬ gauge@2.7.4 │ │ │ │ ├── aproba@1.2.0 │ │ │ │ ├── console-control-strings@1.1.0 deduped │ │ │ │ ├── has-unicode@2.0.1 │ │ │ │ ├── object-assign@4.1.1 deduped │ │ │ │ ├── signal-exit@3.0.3 │ │ │ │ ├─┬ string-width@1.0.2 │ │ │ │ │ ├── code-point-at@1.1.0 │ │ │ │ │ ├─┬ is-fullwidth-code-point@1.0.0 │ │ │ │ │ │ └── number-is-nan@1.0.1 │ │ │ │ │ └── strip-ansi@3.0.1 deduped │ │ │ │ ├─┬ strip-ansi@3.0.1 │ │ │ │ │ └── ansi-regex@2.1.1 │ │ │ │ └─┬ wide-align@1.1.3 │ │ │ │ └── string-width@1.0.2 deduped │ │ │ └── set-blocking@2.0.0 │ │ ├─┬ pump@3.0.0 │ │ │ ├─┬ end-of-stream@1.4.4 │ │ │ │ └── once@1.4.0 deduped │ │ │ └─┬ once@1.4.0 │ │ │ └── wrappy@1.0.2 │ │ ├─┬ rc@1.2.8 │ │ │ ├── deep-extend@0.6.0 │ │ │ ├── ini@1.3.8 │ │ │ ├── minimist@1.2.5 deduped │ │ │ └── strip-json-comments@2.0.1 │ │ ├─┬ simple-get@3.1.0 │ │ │ ├─┬ decompress-response@4.2.1 │ │ │ │ └── mimic-response@2.1.0 │ │ │ ├── once@1.4.0 deduped │ │ │ └── simple-concat@1.0.1 │ │ ├─┬ tar-fs@2.1.1 │ │ │ ├── chownr@1.1.4 │ │ │ ├── mkdirp-classic@0.5.3 deduped │ │ │ ├── pump@3.0.0 deduped │ │ │ └─┬ tar-stream@2.2.0 │ │ │ ├─┬ bl@4.1.0 │ │ │ │ ├─┬ buffer@5.7.1 │ │ │ │ │ ├── base64-js@1.5.1 │ │ │ │ │ └── ieee754@1.2.1 │ │ │ │ ├── inherits@2.0.4 deduped │ │ │ │ └─┬ readable-stream@3.6.0 │ │ │ │ ├── inherits@2.0.4 deduped │ │ │ │ ├── string_decoder@1.1.1 deduped │ │ │ │ └── util-deprecate@1.0.2 deduped │ │ │ ├── end-of-stream@1.4.4 deduped │ │ │ ├── fs-constants@1.0.0 │ │ │ ├── inherits@2.0.4 │ │ │ └─┬ readable-stream@3.6.0 │ │ │ ├── inherits@2.0.4 deduped │ │ │ ├── string_decoder@1.1.1 deduped │ │ │ └── util-deprecate@1.0.2 deduped │ │ ├─┬ tunnel-agent@0.6.0 │ │ │ └── safe-buffer@5.1.2 │ │ └── which-pm-runs@1.0.0 │ ├── @types/debounce@1.2.0 extraneous │ ├── @types/debug@4.1.5 extraneous │ ├── @types/jest@26.0.20 extraneous │ ├── @types/mz@2.7.3 extraneous │ ├── @types/nedb@1.8.11 extraneous │ ├── @types/serialport@8.0.1 extraneous │ ├── @typescript-eslint/eslint-plugin@4.16.1 extraneous │ ├── @typescript-eslint/parser@4.16.1 extraneous │ ├── debounce@1.2.0 │ ├─┬ debug@4.3.1 │ │ └── ms@2.1.2 │ ├── eslint@7.21.0 extraneous │ ├── fast-deep-equal@3.1.3 │ ├── jest@26.6.3 extraneous │ ├── mixin-deep@2.0.1 │ ├─┬ mz@2.7.0 │ │ ├── any-promise@1.3.0 │ │ ├── object-assign@4.1.1 │ │ └─┬ thenify-all@1.6.0 │ │ └─┬ thenify@3.3.1 │ │ └── any-promise@1.3.0 deduped │ ├─┬ serialport@9.0.6 │ │ ├─┬ @serialport/binding-mock@9.0.7 │ │ │ ├── @serialport/binding-abstract@9.0.7 deduped │ │ │ └── debug@4.3.1 deduped │ │ ├── @serialport/bindings@9.0.4 deduped │ │ ├── @serialport/parser-byte-length@9.0.7 │ │ ├── @serialport/parser-cctalk@9.0.7 │ │ ├── @serialport/parser-delimiter@9.0.7 │ │ ├── @serialport/parser-inter-byte-timeout@9.0.7 │ │ ├── @serialport/parser-readline@9.0.7 deduped │ │ ├── @serialport/parser-ready@9.0.7 │ │ ├── @serialport/parser-regex@9.0.7 │ │ ├─┬ @serialport/stream@9.0.7 │ │ │ └── debug@4.3.1 deduped │ │ └── debug@4.3.1 deduped │ ├── slip@1.0.2 │ ├── typedoc@0.20.28 extraneous │ ├── typedoc-plugin-markdown@3.6.0 extraneous │ ├── typedoc-plugin-no-inherit@1.2.0 extraneous │ ├── typedoc-plugin-sourcefile-url@1.0.6 extraneous │ └── UNMET PEER DEPENDENCY typescript@4.2.2 extraneous ├── semver@5.7.1 └─┬ yargs@7.1.1 ├── camelcase@3.0.0 ├─┬ cliui@3.2.0 │ ├── string-width@1.0.2 deduped │ ├─┬ strip-ansi@3.0.1 │ │ └── ansi-regex@2.1.1 │ └─┬ wrap-ansi@2.1.0 │ ├── string-width@1.0.2 deduped │ └── strip-ansi@3.0.1 deduped ├── decamelize@1.2.0 ├── get-caller-file@1.0.3 ├─┬ os-locale@1.4.0 │ └─┬ lcid@1.0.0 │ └── invert-kv@1.0.0 ├─┬ read-pkg-up@1.0.1 │ ├─┬ find-up@1.1.2 │ │ ├─┬ path-exists@2.1.0 │ │ │ └── pinkie-promise@2.0.1 deduped │ │ └─┬ pinkie-promise@2.0.1 │ │ └── pinkie@2.0.4 │ └─┬ read-pkg@1.1.0 │ ├─┬ load-json-file@1.1.0 │ │ ├── graceful-fs@4.2.4 deduped │ │ ├─┬ parse-json@2.2.0 │ │ │ └── error-ex@1.3.2 deduped │ │ ├── pify@2.3.0 │ │ ├── pinkie-promise@2.0.1 deduped │ │ └─┬ strip-bom@2.0.0 │ │ └── is-utf8@0.2.1 │ ├─┬ normalize-package-data@2.5.0 │ │ ├── hosted-git-info@2.8.8 │ │ ├─┬ resolve@1.17.0 │ │ │ └── path-parse@1.0.6 deduped │ │ ├── semver@5.7.1 deduped │ │ └── validate-npm-package-license@3.0.4 deduped │ └─┬ path-type@1.1.0 │ ├── graceful-fs@4.2.4 deduped │ ├── pify@2.3.0 deduped │ └── pinkie-promise@2.0.1 deduped ├── require-directory@2.1.1 ├── require-main-filename@1.0.1 ├── set-blocking@2.0.0 ├─┬ string-width@1.0.2 │ ├── code-point-at@1.1.0 │ ├─┬ is-fullwidth-code-point@1.0.0 │ │ └── number-is-nan@1.0.1 │ └── strip-ansi@3.0.1 deduped ├── which-module@1.0.0 ├── y18n@3.2.1 └─┬ yargs-parser@5.0.0-security.0 ├── camelcase@3.0.0 deduped └─┬ object.assign@4.1.0 ├── define-properties@1.1.3 deduped ├── function-bind@1.1.1 deduped ├── has-symbols@1.0.1 └── object-keys@1.1.1 npm ERR! missing: iobroker.sourceanalytix@git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#f64a6083778ce5b12274eadb73e78cf28568fccc, required by iobroker.inst@2.0.3 npm ERR! peer dep missing: @angular/common@>= 5.0.0, required by xmlhttprequest-ts@1.0.1 npm ERR! peer dep missing: @angular/core@>= 5.0.0, required by xmlhttprequest-ts@1.0.1 npm ERR! missing: xmlhttprequest@^1.8.0, required by iobroker.javascript@5.2.13 npm ERR! missing: cron@1.8.2, required by iobroker.sourceanalytix@git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#f64a6083778ce5b12274eadb73e78cf28568fccc npm ERR! missing: iobroker-adapter-helpers@0.0.8, required by iobroker.sourceanalytix@git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#f64a6083778ce5b12274eadb73e78cf28568fccc npm ERR! missing: @sentry/node@5.30.0, required by iobroker.sourceanalytix@git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#f64a6083778ce5b12274eadb73e78cf28568fccc npm ERR! missing: npm@7.11.1, required by iobroker.sourceanalytix@git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#f64a6083778ce5b12274eadb73e78cf28568fccc npm ERR! missing: node-schedule@1.3.2, required by iobroker.sourceanalytix@git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#f64a6083778ce5b12274eadb73e78cf28568fccc npm ERR! missing: @sentry/core@5.30.0, required by @sentry/node@5.30.0 npm ERR! missing: @sentry/hub@5.30.0, required by @sentry/node@5.30.0 npm ERR! missing: @sentry/tracing@5.30.0, required by @sentry/node@5.30.0 npm ERR! missing: @sentry/types@5.30.0, required by @sentry/node@5.30.0 npm ERR! missing: @sentry/utils@5.30.0, required by @sentry/node@5.30.0 npm ERR! missing: cookie@0.4.1, required by @sentry/node@5.30.0 npm ERR! missing: @sentry/hub@5.30.0, required by @sentry/core@5.30.0 npm ERR! missing: @sentry/minimal@5.30.0, required by @sentry/core@5.30.0 npm ERR! missing: @sentry/types@5.30.0, required by @sentry/core@5.30.0 npm ERR! missing: @sentry/utils@5.30.0, required by @sentry/core@5.30.0 npm ERR! missing: @sentry/hub@5.30.0, required by @sentry/minimal@5.30.0 npm ERR! missing: @sentry/types@5.30.0, required by @sentry/minimal@5.30.0 npm ERR! missing: @sentry/types@5.30.0, required by @sentry/hub@5.30.0 npm ERR! missing: @sentry/utils@5.30.0, required by @sentry/hub@5.30.0 npm ERR! missing: @sentry/hub@5.30.0, required by @sentry/tracing@5.30.0 npm ERR! missing: @sentry/minimal@5.30.0, required by @sentry/tracing@5.30.0 npm ERR! missing: @sentry/types@5.30.0, required by @sentry/tracing@5.30.0 npm ERR! missing: @sentry/utils@5.30.0, required by @sentry/tracing@5.30.0 npm ERR! missing: @sentry/types@5.30.0, required by @sentry/utils@5.30.0 npm ERR! missing: @npmcli/arborist@2.4.0, required by npm@7.11.1 npm ERR! missing: @npmcli/ci-detect@1.3.0, required by npm@7.11.1 npm ERR! missing: @npmcli/config@2.2.0, required by npm@7.11.1 npm ERR! missing: @npmcli/run-script@1.8.5, required by npm@7.11.1 npm ERR! missing: abbrev@1.1.1, required by npm@7.11.1 npm ERR! missing: ansicolors@0.3.2, required by npm@7.11.1 npm ERR! missing: ansistyles@0.1.3, required by npm@7.11.1 npm ERR! missing: archy@1.0.0, required by npm@7.11.1 npm ERR! missing: byte-size@7.0.1, required by npm@7.11.1 npm ERR! missing: cacache@15.0.6, required by npm@7.11.1 npm ERR! missing: chalk@4.1.1, required by npm@7.11.1 npm ERR! missing: chownr@2.0.0, required by npm@7.11.1 npm ERR! missing: cli-columns@3.1.2, required by npm@7.11.1 npm ERR! missing: cli-table3@0.6.0, required by npm@7.11.1 npm ERR! missing: columnify@1.5.4, required by npm@7.11.1 npm ERR! missing: glob@7.1.6, required by npm@7.11.1 npm ERR! missing: graceful-fs@4.2.6, required by npm@7.11.1 npm ERR! missing: hosted-git-info@4.0.2, required by npm@7.11.1 npm ERR! missing: ini@2.0.0, required by npm@7.11.1 npm ERR! missing: init-package-json@2.0.3, required by npm@7.11.1 npm ERR! missing: is-cidr@4.0.2, required by npm@7.11.1 npm ERR! missing: json-parse-even-better-errors@2.3.1, required by npm@7.11.1 npm ERR! missing: leven@3.1.0, required by npm@7.11.1 npm ERR! missing: libnpmaccess@4.0.2, required by npm@7.11.1 npm ERR! missing: libnpmdiff@2.0.4, required by npm@7.11.1 npm ERR! missing: libnpmexec@1.0.1, required by npm@7.11.1 npm ERR! missing: libnpmfund@1.0.2, required by npm@7.11.1 npm ERR! missing: libnpmhook@6.0.2, required by npm@7.11.1 npm ERR! missing: libnpmorg@2.0.2, required by npm@7.11.1 npm ERR! missing: libnpmpack@2.0.1, required by npm@7.11.1 npm ERR! missing: libnpmpublish@4.0.1, required by npm@7.11.1 npm ERR! missing: libnpmsearch@3.1.1, required by npm@7.11.1 npm ERR! missing: libnpmteam@2.0.3, required by npm@7.11.1 npm ERR! missing: libnpmversion@1.2.0, required by npm@7.11.1 npm ERR! missing: make-fetch-happen@8.0.14, required by npm@7.11.1 npm ERR! missing: minipass@3.1.3, required by npm@7.11.1 npm ERR! missing: minipass-pipeline@1.2.4, required by npm@7.11.1 npm ERR! missing: mkdirp@1.0.4, required by npm@7.11.1 npm ERR! missing: mkdirp-infer-owner@2.0.0, required by npm@7.11.1 npm ERR! missing: ms@2.1.3, required by npm@7.11.1 npm ERR! missing: node-gyp@7.1.2, required by npm@7.11.1 npm ERR! missing: nopt@5.0.0, required by npm@7.11.1 npm ERR! missing: npm-audit-report@2.1.4, required by npm@7.11.1 npm ERR! missing: npm-package-arg@8.1.2, required by npm@7.11.1 npm ERR! missing: npm-pick-manifest@6.1.1, required by npm@7.11.1 npm ERR! missing: npm-profile@5.0.3, required by npm@7.11.1 npm ERR! missing: npm-registry-fetch@10.1.1, required by npm@7.11.1 npm ERR! missing: npm-user-validate@1.0.1, required by npm@7.11.1 npm ERR! missing: npmlog@4.1.2, required by npm@7.11.1 npm ERR! missing: opener@1.5.2, required by npm@7.11.1 npm ERR! missing: pacote@11.3.3, required by npm@7.11.1 npm ERR! missing: parse-conflict-json@1.1.1, required by npm@7.11.1 npm ERR! missing: qrcode-terminal@0.12.0, required by npm@7.11.1 npm ERR! missing: read@1.0.7, required by npm@7.11.1 npm ERR! missing: read-package-json@3.0.1, required by npm@7.11.1 npm ERR! missing: read-package-json-fast@2.0.2, required by npm@7.11.1 npm ERR! missing: readdir-scoped-modules@1.1.0, required by npm@7.11.1 npm ERR! missing: rimraf@3.0.2, required by npm@7.11.1 npm ERR! missing: semver@7.3.5, required by npm@7.11.1 npm ERR! missing: ssri@8.0.1, required by npm@7.11.1 npm ERR! missing: tar@6.1.0, required by npm@7.11.1 npm ERR! missing: text-table@0.2.0, required by npm@7.11.1 npm ERR! missing: tiny-relative-date@1.3.0, required by npm@7.11.1 npm ERR! missing: treeverse@1.0.4, required by npm@7.11.1 npm ERR! missing: validate-npm-package-name@3.0.0, required by npm@7.11.1 npm ERR! missing: which@2.0.2, required by npm@7.11.1 npm ERR! missing: write-file-atomic@3.0.3, required by npm@7.11.1 npm ERR! missing: @npmcli/installed-package-contents@1.0.7, required by @npmcli/arborist@2.4.0 npm ERR! missing: @npmcli/map-workspaces@1.0.3, required by @npmcli/arborist@2.4.0 npm ERR! missing: @npmcli/metavuln-calculator@1.1.1, required by @npmcli/arborist@2.4.0 npm ERR! missing: @npmcli/move-file@1.1.2, required by @npmcli/arborist@2.4.0 npm ERR! missing: @npmcli/name-from-folder@1.0.1, required by @npmcli/arborist@2.4.0 npm ERR! missing: @npmcli/node-gyp@1.0.2, required by @npmcli/arborist@2.4.0 npm ERR! missing: @npmcli/run-script@1.8.5, required by @npmcli/arborist@2.4.0 npm ERR! missing: bin-links@2.2.1, required by @npmcli/arborist@2.4.0 npm ERR! missing: cacache@15.0.6, required by @npmcli/arborist@2.4.0 npm ERR! missing: common-ancestor-path@1.0.1, required by @npmcli/arborist@2.4.0 npm ERR! missing: json-parse-even-better-errors@2.3.1, required by @npmcli/arborist@2.4.0 npm ERR! missing: json-stringify-nice@1.1.3, required by @npmcli/arborist@2.4.0 npm ERR! missing: mkdirp-infer-owner@2.0.0, required by @npmcli/arborist@2.4.0 npm ERR! missing: npm-install-checks@4.0.0, required by @npmcli/arborist@2.4.0 npm ERR! missing: npm-package-arg@8.1.2, required by @npmcli/arborist@2.4.0 npm ERR! missing: npm-pick-manifest@6.1.1, required by @npmcli/arborist@2.4.0 npm ERR! missing: npm-registry-fetch@10.1.1, required by @npmcli/arborist@2.4.0 npm ERR! missing: pacote@11.3.3, required by @npmcli/arborist@2.4.0 npm ERR! missing: parse-conflict-json@1.1.1, required by @npmcli/arborist@2.4.0 npm ERR! missing: promise-all-reject-late@1.0.1, required by @npmcli/arborist@2.4.0 npm ERR! missing: promise-call-limit@1.0.1, required by @npmcli/arborist@2.4.0 npm ERR! missing: read-package-json-fast@2.0.2, required by @npmcli/arborist@2.4.0 npm ERR! missing: readdir-scoped-modules@1.1.0, required by @npmcli/arborist@2.4.0 npm ERR! missing: semver@7.3.5, required by @npmcli/arborist@2.4.0 npm ERR! missing: tar@6.1.0, required by @npmcli/arborist@2.4.0 npm ERR! missing: treeverse@1.0.4, required by @npmcli/arborist@2.4.0 npm ERR! missing: walk-up-path@1.0.0, required by @npmcli/arborist@2.4.0 npm ERR! missing: npm-bundled@1.1.2, required by @npmcli/installed-package-contents@1.0.7 npm ERR! missing: npm-normalize-package-bin@1.0.1, required by @npmcli/installed-package-contents@1.0.7 npm ERR! missing: npm-normalize-package-bin@1.0.1, required by npm-bundled@1.1.2 npm ERR! missing: @npmcli/name-from-folder@1.0.1, required by @npmcli/map-workspaces@1.0.3 npm ERR! missing: glob@7.1.6, required by @npmcli/map-workspaces@1.0.3 npm ERR! missing: minimatch@3.0.4, required by @npmcli/map-workspaces@1.0.3 npm ERR! missing: read-package-json-fast@2.0.2, required by @npmcli/map-workspaces@1.0.3 npm ERR! missing: cacache@15.0.6, required by @npmcli/metavuln-calculator@1.1.1 npm ERR! missing: pacote@11.3.3, required by @npmcli/metavuln-calculator@1.1.1 npm ERR! missing: semver@7.3.5, required by @npmcli/metavuln-calculator@1.1.1 npm ERR! missing: mkdirp@1.0.4, required by @npmcli/move-file@1.1.2 npm ERR! missing: rimraf@3.0.2, required by @npmcli/move-file@1.1.2 npm ERR! missing: cmd-shim@4.1.0, required by bin-links@2.2.1 npm ERR! missing: mkdirp@1.0.4, required by bin-links@2.2.1 npm ERR! missing: npm-normalize-package-bin@1.0.1, required by bin-links@2.2.1 npm ERR! missing: read-cmd-shim@2.0.0, required by bin-links@2.2.1 npm ERR! missing: rimraf@3.0.2, required by bin-links@2.2.1 npm ERR! missing: write-file-atomic@3.0.3, required by bin-links@2.2.1 npm ERR! missing: mkdirp-infer-owner@2.0.0, required by cmd-shim@4.1.0 npm ERR! missing: semver@7.3.5, required by npm-install-checks@4.0.0 npm ERR! missing: ini@2.0.0, required by @npmcli/config@2.2.0 npm ERR! missing: mkdirp-infer-owner@2.0.0, required by @npmcli/config@2.2.0 npm ERR! missing: nopt@5.0.0, required by @npmcli/config@2.2.0 npm ERR! missing: semver@7.3.5, required by @npmcli/config@2.2.0 npm ERR! missing: walk-up-path@1.0.0, required by @npmcli/config@2.2.0 npm ERR! missing: @npmcli/node-gyp@1.0.2, required by @npmcli/run-script@1.8.5 npm ERR! missing: @npmcli/promise-spawn@1.3.2, required by @npmcli/run-script@1.8.5 npm ERR! missing: infer-owner@1.0.4, required by @npmcli/run-script@1.8.5 npm ERR! missing: node-gyp@7.1.2, required by @npmcli/run-script@1.8.5 npm ERR! missing: read-package-json-fast@2.0.2, required by @npmcli/run-script@1.8.5 npm ERR! missing: infer-owner@1.0.4, required by @npmcli/promise-spawn@1.3.2 npm ERR! missing: @npmcli/move-file@1.1.2, required by cacache@15.0.6 npm ERR! missing: chownr@2.0.0, required by cacache@15.0.6 npm ERR! missing: fs-minipass@2.1.0, required by cacache@15.0.6 npm ERR! missing: glob@7.1.6, required by cacache@15.0.6 npm ERR! missing: infer-owner@1.0.4, required by cacache@15.0.6 npm ERR! missing: lru-cache@6.0.0, required by cacache@15.0.6 npm ERR! missing: minipass@3.1.3, required by cacache@15.0.6 npm ERR! missing: minipass-collect@1.0.2, required by cacache@15.0.6 npm ERR! missing: minipass-flush@1.0.5, required by cacache@15.0.6 npm ERR! missing: minipass-pipeline@1.2.4, required by cacache@15.0.6 npm ERR! missing: mkdirp@1.0.4, required by cacache@15.0.6 npm ERR! missing: p-map@4.0.0, required by cacache@15.0.6 npm ERR! missing: promise-inflight@1.0.1, required by cacache@15.0.6 npm ERR! missing: rimraf@3.0.2, required by cacache@15.0.6 npm ERR! missing: ssri@8.0.1, required by cacache@15.0.6 npm ERR! missing: tar@6.1.0, required by cacache@15.0.6 npm ERR! missing: unique-filename@1.1.1, required by cacache@15.0.6 npm ERR! missing: minipass@3.1.3, required by fs-minipass@2.1.0 npm ERR! missing: yallist@4.0.0, required by lru-cache@6.0.0 npm ERR! missing: minipass@3.1.3, required by minipass-collect@1.0.2 npm ERR! missing: minipass@3.1.3, required by minipass-flush@1.0.5 npm ERR! missing: aggregate-error@3.1.0, required by p-map@4.0.0 npm ERR! missing: clean-stack@2.2.0, required by aggregate-error@3.1.0 npm ERR! missing: indent-string@4.0.0, required by aggregate-error@3.1.0 npm ERR! missing: unique-slug@2.0.2, required by unique-filename@1.1.1 npm ERR! missing: imurmurhash@0.1.4, required by unique-slug@2.0.2 npm ERR! missing: ansi-styles@4.3.0, required by chalk@4.1.1 npm ERR! missing: supports-color@7.2.0, required by chalk@4.1.1 npm ERR! missing: color-convert@2.0.1, required by ansi-styles@4.3.0 npm ERR! missing: color-name@1.1.4, required by color-convert@2.0.1 npm ERR! missing: has-flag@4.0.0, required by supports-color@7.2.0 npm ERR! missing: string-width@2.1.1, required by cli-columns@3.1.2 npm ERR! missing: strip-ansi@3.0.1, required by cli-columns@3.1.2 npm ERR! missing: is-fullwidth-code-point@2.0.0, required by string-width@2.1.1 npm ERR! missing: strip-ansi@4.0.0, required by string-width@2.1.1 npm ERR! missing: ansi-regex@3.0.0, required by strip-ansi@4.0.0 npm ERR! missing: ansi-regex@2.1.1, required by strip-ansi@3.0.1 npm ERR! missing: string-width@4.2.2, required by cli-table3@0.6.0 npm ERR! missing: object-assign@4.1.1, required by cli-table3@0.6.0 npm ERR! missing: is-fullwidth-code-point@3.0.0, required by string-width@4.2.2 npm ERR! missing: strip-ansi@6.0.0, required by string-width@4.2.2 npm ERR! missing: emoji-regex@8.0.0, required by string-width@4.2.2 npm ERR! missing: ansi-regex@5.0.0, required by strip-ansi@6.0.0 npm ERR! missing: strip-ansi@3.0.1, required by columnify@1.5.4 npm ERR! missing: wcwidth@1.0.1, required by columnify@1.5.4 npm ERR! missing: defaults@1.0.3, required by wcwidth@1.0.1 npm ERR! missing: clone@1.0.4, required by defaults@1.0.3 npm ERR! missing: fs.realpath@1.0.0, required by glob@7.1.6 npm ERR! missing: inflight@1.0.6, required by glob@7.1.6 npm ERR! missing: inherits@2.0.4, required by glob@7.1.6 npm ERR! missing: minimatch@3.0.4, required by glob@7.1.6 npm ERR! missing: once@1.4.0, required by glob@7.1.6 npm ERR! missing: path-is-absolute@1.0.1, required by glob@7.1.6 npm ERR! missing: once@1.4.0, required by inflight@1.0.6 npm ERR! missing: wrappy@1.0.2, required by inflight@1.0.6 npm ERR! missing: brace-expansion@1.1.11, required by minimatch@3.0.4 npm ERR! missing: balanced-match@1.0.2, required by brace-expansion@1.1.11 npm ERR! missing: concat-map@0.0.1, required by brace-expansion@1.1.11 npm ERR! missing: wrappy@1.0.2, required by once@1.4.0 npm ERR! missing: lru-cache@6.0.0, required by hosted-git-info@4.0.2 npm ERR! missing: glob@7.1.6, required by init-package-json@2.0.3 npm ERR! missing: npm-package-arg@8.1.2, required by init-package-json@2.0.3 npm ERR! missing: promzard@0.3.0, required by init-package-json@2.0.3 npm ERR! missing: read@1.0.7, required by init-package-json@2.0.3 npm ERR! missing: read-package-json@3.0.1, required by init-package-json@2.0.3 npm ERR! missing: semver@7.3.5, required by init-package-json@2.0.3 npm ERR! missing: validate-npm-package-license@3.0.4, required by init-package-json@2.0.3 npm ERR! missing: validate-npm-package-name@3.0.0, required by init-package-json@2.0.3 npm ERR! missing: read@1.0.7, required by promzard@0.3.0 npm ERR! missing: spdx-correct@3.1.1, required by validate-npm-package-license@3.0.4 npm ERR! missing: spdx-expression-parse@3.0.1, required by validate-npm-package-license@3.0.4 npm ERR! missing: spdx-expression-parse@3.0.1, required by spdx-correct@3.1.1 npm ERR! missing: spdx-license-ids@3.0.7, required by spdx-correct@3.1.1 npm ERR! missing: spdx-exceptions@2.3.0, required by spdx-expression-parse@3.0.1 npm ERR! missing: spdx-license-ids@3.0.7, required by spdx-expression-parse@3.0.1 npm ERR! missing: cidr-regex@3.1.1, required by is-cidr@4.0.2 npm ERR! missing: ip-regex@4.3.0, required by cidr-regex@3.1.1 npm ERR! missing: aproba@2.0.0, required by libnpmaccess@4.0.2 npm ERR! missing: minipass@3.1.3, required by libnpmaccess@4.0.2 npm ERR! missing: npm-package-arg@8.1.2, required by libnpmaccess@4.0.2 npm ERR! missing: npm-registry-fetch@10.1.1, required by libnpmaccess@4.0.2 npm ERR! missing: @npmcli/disparity-colors@1.0.1, required by libnpmdiff@2.0.4 npm ERR! missing: @npmcli/installed-package-contents@1.0.7, required by libnpmdiff@2.0.4 npm ERR! missing: binary-extensions@2.2.0, required by libnpmdiff@2.0.4 npm ERR! missing: diff@5.0.0, required by libnpmdiff@2.0.4 npm ERR! missing: minimatch@3.0.4, required by libnpmdiff@2.0.4 npm ERR! missing: npm-package-arg@8.1.2, required by libnpmdiff@2.0.4 npm ERR! missing: pacote@11.3.3, required by libnpmdiff@2.0.4 npm ERR! missing: tar@6.1.0, required by libnpmdiff@2.0.4 npm ERR! missing: ansi-styles@4.3.0, required by @npmcli/disparity-colors@1.0.1 npm ERR! missing: @npmcli/arborist@2.4.0, required by libnpmexec@1.0.1 npm ERR! missing: @npmcli/ci-detect@1.3.0, required by libnpmexec@1.0.1 npm ERR! missing: @npmcli/run-script@1.8.5, required by libnpmexec@1.0.1 npm ERR! missing: chalk@4.1.1, required by libnpmexec@1.0.1 npm ERR! missing: mkdirp-infer-owner@2.0.0, required by libnpmexec@1.0.1 npm ERR! missing: npm-package-arg@8.1.2, required by libnpmexec@1.0.1 npm ERR! missing: pacote@11.3.3, required by libnpmexec@1.0.1 npm ERR! missing: proc-log@1.0.0, required by libnpmexec@1.0.1 npm ERR! missing: read@1.0.7, required by libnpmexec@1.0.1 npm ERR! missing: read-package-json-fast@2.0.2, required by libnpmexec@1.0.1 npm ERR! missing: @npmcli/arborist@2.4.0, required by libnpmfund@1.0.2 npm ERR! missing: aproba@2.0.0, required by libnpmhook@6.0.2 npm ERR! missing: npm-registry-fetch@10.1.1, required by libnpmhook@6.0.2 npm ERR! missing: aproba@2.0.0, required by libnpmorg@2.0.2 npm ERR! missing: npm-registry-fetch@10.1.1, required by libnpmorg@2.0.2 npm ERR! missing: @npmcli/run-script@1.8.5, required by libnpmpack@2.0.1 npm ERR! missing: npm-package-arg@8.1.2, required by libnpmpack@2.0.1 npm ERR! missing: pacote@11.3.3, required by libnpmpack@2.0.1 npm ERR! missing: normalize-package-data@3.0.2, required by libnpmpublish@4.0.1 npm ERR! missing: npm-package-arg@8.1.2, required by libnpmpublish@4.0.1 npm ERR! missing: npm-registry-fetch@10.1.1, required by libnpmpublish@4.0.1 npm ERR! missing: semver@7.3.5, required by libnpmpublish@4.0.1 npm ERR! missing: ssri@8.0.1, required by libnpmpublish@4.0.1 npm ERR! missing: hosted-git-info@4.0.2, required by normalize-package-data@3.0.2 npm ERR! missing: resolve@1.20.0, required by normalize-package-data@3.0.2 npm ERR! missing: semver@7.3.5, required by normalize-package-data@3.0.2 npm ERR! missing: validate-npm-package-license@3.0.4, required by normalize-package-data@3.0.2 npm ERR! missing: is-core-module@2.2.0, required by resolve@1.20.0 npm ERR! missing: path-parse@1.0.6, required by resolve@1.20.0 npm ERR! missing: has@1.0.3, required by is-core-module@2.2.0 npm ERR! missing: function-bind@1.1.1, required by has@1.0.3 npm ERR! missing: npm-registry-fetch@10.1.1, required by libnpmsearch@3.1.1 npm ERR! missing: aproba@2.0.0, required by libnpmteam@2.0.3 npm ERR! missing: npm-registry-fetch@10.1.1, required by libnpmteam@2.0.3 npm ERR! missing: @npmcli/git@2.0.8, required by libnpmversion@1.2.0 npm ERR! missing: @npmcli/run-script@1.8.5, required by libnpmversion@1.2.0 npm ERR! missing: json-parse-even-better-errors@2.3.1, required by libnpmversion@1.2.0 npm ERR! missing: semver@7.3.5, required by libnpmversion@1.2.0 npm ERR! missing: stringify-package@1.0.1, required by libnpmversion@1.2.0 npm ERR! missing: @npmcli/promise-spawn@1.3.2, required by @npmcli/git@2.0.8 npm ERR! missing: lru-cache@6.0.0, required by @npmcli/git@2.0.8 npm ERR! missing: mkdirp@1.0.4, required by @npmcli/git@2.0.8 npm ERR! missing: npm-pick-manifest@6.1.1, required by @npmcli/git@2.0.8 npm ERR! missing: promise-inflight@1.0.1, required by @npmcli/git@2.0.8 npm ERR! missing: promise-retry@2.0.1, required by @npmcli/git@2.0.8 npm ERR! missing: semver@7.3.5, required by @npmcli/git@2.0.8 npm ERR! missing: which@2.0.2, required by @npmcli/git@2.0.8 npm ERR! missing: agentkeepalive@4.1.4, required by make-fetch-happen@8.0.14 npm ERR! missing: cacache@15.0.6, required by make-fetch-happen@8.0.14 npm ERR! missing: http-cache-semantics@4.1.0, required by make-fetch-happen@8.0.14 npm ERR! missing: http-proxy-agent@4.0.1, required by make-fetch-happen@8.0.14 npm ERR! missing: https-proxy-agent@5.0.0, required by make-fetch-happen@8.0.14 npm ERR! missing: is-lambda@1.0.1, required by make-fetch-happen@8.0.14 npm ERR! missing: lru-cache@6.0.0, required by make-fetch-happen@8.0.14 npm ERR! missing: minipass@3.1.3, required by make-fetch-happen@8.0.14 npm ERR! missing: minipass-collect@1.0.2, required by make-fetch-happen@8.0.14 npm ERR! missing: minipass-fetch@1.3.3, required by make-fetch-happen@8.0.14 npm ERR! missing: minipass-flush@1.0.5, required by make-fetch-happen@8.0.14 npm ERR! missing: minipass-pipeline@1.2.4, required by make-fetch-happen@8.0.14 npm ERR! missing: promise-retry@2.0.1, required by make-fetch-happen@8.0.14 npm ERR! missing: socks-proxy-agent@5.0.0, required by make-fetch-happen@8.0.14 npm ERR! missing: ssri@8.0.1, required by make-fetch-happen@8.0.14 npm ERR! missing: debug@4.3.1, required by agentkeepalive@4.1.4 npm ERR! missing: depd@1.1.2, required by agentkeepalive@4.1.4 npm ERR! missing: humanize-ms@1.2.1, required by agentkeepalive@4.1.4 npm ERR! missing: ms@2.1.2, required by debug@4.3.1 npm ERR! missing: ms@2.1.3, required by humanize-ms@1.2.1 npm ERR! missing: @tootallnate/once@1.1.2, required by http-proxy-agent@4.0.1 npm ERR! missing: agent-base@6.0.2, required by http-proxy-agent@4.0.1 npm ERR! missing: debug@4.3.1, required by http-proxy-agent@4.0.1 npm ERR! missing: debug@4.3.1, required by agent-base@6.0.2 npm ERR! missing: agent-base@6.0.2, required by https-proxy-agent@5.0.0 npm ERR! missing: debug@4.3.1, required by https-proxy-agent@5.0.0 npm ERR! missing: minipass@3.1.3, required by minipass-fetch@1.3.3 npm ERR! missing: minipass-sized@1.0.3, required by minipass-fetch@1.3.3 npm ERR! missing: minizlib@2.1.2, required by minipass-fetch@1.3.3 npm ERR! missing: safer-buffer@2.1.2, required by iconv-lite@0.6.2 npm ERR! missing: minipass@3.1.3, required by minipass-sized@1.0.3 npm ERR! missing: err-code@2.0.3, required by promise-retry@2.0.1 npm ERR! missing: retry@0.12.0, required by promise-retry@2.0.1 npm ERR! missing: agent-base@6.0.2, required by socks-proxy-agent@5.0.0 npm ERR! missing: debug@4.3.1, required by socks-proxy-agent@5.0.0 npm ERR! missing: socks@2.6.1, required by socks-proxy-agent@5.0.0 npm ERR! missing: ip@1.1.5, required by socks@2.6.1 npm ERR! missing: smart-buffer@4.1.0, required by socks@2.6.1 npm ERR! missing: yallist@4.0.0, required by minipass@3.1.3 npm ERR! missing: minipass@3.1.3, required by minipass-pipeline@1.2.4 npm ERR! missing: chownr@2.0.0, required by mkdirp-infer-owner@2.0.0 npm ERR! missing: infer-owner@1.0.4, required by mkdirp-infer-owner@2.0.0 npm ERR! missing: mkdirp@1.0.4, required by mkdirp-infer-owner@2.0.0 npm ERR! missing: env-paths@2.2.1, required by node-gyp@7.1.2 npm ERR! missing: glob@7.1.6, required by node-gyp@7.1.2 npm ERR! missing: graceful-fs@4.2.6, required by node-gyp@7.1.2 npm ERR! missing: nopt@5.0.0, required by node-gyp@7.1.2 npm ERR! missing: npmlog@4.1.2, required by node-gyp@7.1.2 npm ERR! missing: request@2.88.2, required by node-gyp@7.1.2 npm ERR! missing: rimraf@3.0.2, required by node-gyp@7.1.2 npm ERR! missing: semver@7.3.5, required by node-gyp@7.1.2 npm ERR! missing: tar@6.1.0, required by node-gyp@7.1.2 npm ERR! missing: which@2.0.2, required by node-gyp@7.1.2 npm ERR! missing: aws-sign2@0.7.0, required by request@2.88.2 npm ERR! missing: aws4@1.11.0, required by request@2.88.2 npm ERR! missing: caseless@0.12.0, required by request@2.88.2 npm ERR! missing: combined-stream@1.0.8, required by request@2.88.2 npm ERR! missing: extend@3.0.2, required by request@2.88.2 npm ERR! missing: forever-agent@0.6.1, required by request@2.88.2 npm ERR! missing: form-data@2.3.3, required by request@2.88.2 npm ERR! missing: har-validator@5.1.5, required by request@2.88.2 npm ERR! missing: http-signature@1.2.0, required by request@2.88.2 npm ERR! missing: is-typedarray@1.0.0, required by request@2.88.2 npm ERR! missing: isstream@0.1.2, required by request@2.88.2 npm ERR! missing: json-stringify-safe@5.0.1, required by request@2.88.2 npm ERR! missing: mime-types@2.1.30, required by request@2.88.2 npm ERR! missing: oauth-sign@0.9.0, required by request@2.88.2 npm ERR! missing: performance-now@2.1.0, required by request@2.88.2 npm ERR! missing: qs@6.5.2, required by request@2.88.2 npm ERR! missing: tough-cookie@2.5.0, required by request@2.88.2 npm ERR! missing: safe-buffer@5.1.2, required by request@2.88.2 npm ERR! missing: tunnel-agent@0.6.0, required by request@2.88.2 npm ERR! missing: uuid@3.4.0, required by request@2.88.2 npm ERR! missing: delayed-stream@1.0.0, required by combined-stream@1.0.8 npm ERR! missing: asynckit@0.4.0, required by form-data@2.3.3 npm ERR! missing: combined-stream@1.0.8, required by form-data@2.3.3 npm ERR! missing: mime-types@2.1.30, required by form-data@2.3.3 npm ERR! missing: ajv@6.12.6, required by har-validator@5.1.5 npm ERR! missing: har-schema@2.0.0, required by har-validator@5.1.5 npm ERR! missing: fast-deep-equal@3.1.3, required by ajv@6.12.6 npm ERR! missing: fast-json-stable-stringify@2.1.0, required by ajv@6.12.6 npm ERR! missing: json-schema-traverse@0.4.1, required by ajv@6.12.6 npm ERR! missing: uri-js@4.4.1, required by ajv@6.12.6 npm ERR! missing: punycode@2.1.1, required by uri-js@4.4.1 npm ERR! missing: assert-plus@1.0.0, required by http-signature@1.2.0 npm ERR! missing: jsprim@1.4.1, required by http-signature@1.2.0 npm ERR! missing: sshpk@1.16.1, required by http-signature@1.2.0 npm ERR! missing: assert-plus@1.0.0, required by jsprim@1.4.1 npm ERR! missing: extsprintf@1.3.0, required by jsprim@1.4.1 npm ERR! missing: json-schema@0.2.3, required by jsprim@1.4.1 npm ERR! missing: verror@1.10.0, required by jsprim@1.4.1 npm ERR! missing: assert-plus@1.0.0, required by verror@1.10.0 npm ERR! missing: core-util-is@1.0.2, required by verror@1.10.0 npm ERR! missing: extsprintf@1.3.0, required by verror@1.10.0 npm ERR! missing: asn1@0.2.4, required by sshpk@1.16.1 npm ERR! missing: assert-plus@1.0.0, required by sshpk@1.16.1 npm ERR! missing: bcrypt-pbkdf@1.0.2, required by sshpk@1.16.1 npm ERR! missing: dashdash@1.14.1, required by sshpk@1.16.1 npm ERR! missing: ecc-jsbn@0.1.2, required by sshpk@1.16.1 npm ERR! missing: getpass@0.1.7, required by sshpk@1.16.1 npm ERR! missing: jsbn@0.1.1, required by sshpk@1.16.1 npm ERR! missing: safer-buffer@2.1.2, required by sshpk@1.16.1 npm ERR! missing: tweetnacl@0.14.5, required by sshpk@1.16.1 npm ERR! missing: safer-buffer@2.1.2, required by asn1@0.2.4 npm ERR! missing: tweetnacl@0.14.5, required by bcrypt-pbkdf@1.0.2 npm ERR! missing: assert-plus@1.0.0, required by dashdash@1.14.1 npm ERR! missing: jsbn@0.1.1, required by ecc-jsbn@0.1.2 npm ERR! missing: safer-buffer@2.1.2, required by ecc-jsbn@0.1.2 npm ERR! missing: assert-plus@1.0.0, required by getpass@0.1.7 npm ERR! missing: mime-db@1.47.0, required by mime-types@2.1.30 npm ERR! missing: psl@1.8.0, required by tough-cookie@2.5.0 npm ERR! missing: punycode@2.1.1, required by tough-cookie@2.5.0 npm ERR! missing: safe-buffer@5.1.2, required by tunnel-agent@0.6.0 npm ERR! missing: abbrev@1.1.1, required by nopt@5.0.0 npm ERR! missing: chalk@4.1.1, required by npm-audit-report@2.1.4 npm ERR! missing: hosted-git-info@4.0.2, required by npm-package-arg@8.1.2 npm ERR! missing: semver@7.3.5, required by npm-package-arg@8.1.2 npm ERR! missing: validate-npm-package-name@3.0.0, required by npm-package-arg@8.1.2 npm ERR! missing: npm-install-checks@4.0.0, required by npm-pick-manifest@6.1.1 npm ERR! missing: npm-normalize-package-bin@1.0.1, required by npm-pick-manifest@6.1.1 npm ERR! missing: npm-package-arg@8.1.2, required by npm-pick-manifest@6.1.1 npm ERR! missing: semver@7.3.5, required by npm-pick-manifest@6.1.1 npm ERR! missing: npm-registry-fetch@10.1.1, required by npm-profile@5.0.3 npm ERR! missing: lru-cache@6.0.0, required by npm-registry-fetch@10.1.1 npm ERR! missing: make-fetch-happen@8.0.14, required by npm-registry-fetch@10.1.1 npm ERR! missing: minipass@3.1.3, required by npm-registry-fetch@10.1.1 npm ERR! missing: minipass-fetch@1.3.3, required by npm-registry-fetch@10.1.1 npm ERR! missing: minipass-json-stream@1.0.1, required by npm-registry-fetch@10.1.1 npm ERR! missing: minizlib@2.1.2, required by npm-registry-fetch@10.1.1 npm ERR! missing: npm-package-arg@8.1.2, required by npm-registry-fetch@10.1.1 npm ERR! missing: jsonparse@1.3.1, required by minipass-json-stream@1.0.1 npm ERR! missing: minipass@3.1.3, required by minipass-json-stream@1.0.1 npm ERR! missing: minipass@3.1.3, required by minizlib@2.1.2 npm ERR! missing: yallist@4.0.0, required by minizlib@2.1.2 npm ERR! missing: are-we-there-yet@1.1.5, required by npmlog@4.1.2 npm ERR! missing: console-control-strings@1.1.0, required by npmlog@4.1.2 npm ERR! missing: gauge@2.7.4, required by npmlog@4.1.2 npm ERR! missing: set-blocking@2.0.0, required by npmlog@4.1.2 npm ERR! missing: delegates@1.0.0, required by are-we-there-yet@1.1.5 npm ERR! missing: readable-stream@2.3.7, required by are-we-there-yet@1.1.5 npm ERR! missing: core-util-is@1.0.2, required by readable-stream@2.3.7 npm ERR! missing: inherits@2.0.4, required by readable-stream@2.3.7 npm ERR! missing: isarray@1.0.0, required by readable-stream@2.3.7 npm ERR! missing: process-nextick-args@2.0.1, required by readable-stream@2.3.7 npm ERR! missing: safe-buffer@5.1.2, required by readable-stream@2.3.7 npm ERR! missing: string_decoder@1.1.1, required by readable-stream@2.3.7 npm ERR! missing: util-deprecate@1.0.2, required by readable-stream@2.3.7 npm ERR! missing: safe-buffer@5.1.2, required by string_decoder@1.1.1 npm ERR! missing: console-control-strings@1.1.0, required by gauge@2.7.4 npm ERR! missing: aproba@1.2.0, required by gauge@2.7.4 npm ERR! missing: string-width@1.0.2, required by gauge@2.7.4 npm ERR! missing: has-unicode@2.0.1, required by gauge@2.7.4 npm ERR! missing: object-assign@4.1.1, required by gauge@2.7.4 npm ERR! missing: signal-exit@3.0.3, required by gauge@2.7.4 npm ERR! missing: strip-ansi@3.0.1, required by gauge@2.7.4 npm ERR! missing: wide-align@1.1.3, required by gauge@2.7.4 npm ERR! missing: code-point-at@1.1.0, required by string-width@1.0.2 npm ERR! missing: is-fullwidth-code-point@1.0.0, required by string-width@1.0.2 npm ERR! missing: strip-ansi@3.0.1, required by string-width@1.0.2 npm ERR! missing: number-is-nan@1.0.1, required by is-fullwidth-code-point@1.0.0 npm ERR! missing: string-width@2.1.1, required by wide-align@1.1.3 npm ERR! missing: @npmcli/git@2.0.8, required by pacote@11.3.3 npm ERR! missing: @npmcli/installed-package-contents@1.0.7, required by pacote@11.3.3 npm ERR! missing: @npmcli/promise-spawn@1.3.2, required by pacote@11.3.3 npm ERR! missing: @npmcli/run-script@1.8.5, required by pacote@11.3.3 npm ERR! missing: cacache@15.0.6, required by pacote@11.3.3 npm ERR! missing: chownr@2.0.0, required by pacote@11.3.3 npm ERR! missing: fs-minipass@2.1.0, required by pacote@11.3.3 npm ERR! missing: infer-owner@1.0.4, required by pacote@11.3.3 npm ERR! missing: minipass@3.1.3, required by pacote@11.3.3 npm ERR! missing: mkdirp@1.0.4, required by pacote@11.3.3 npm ERR! missing: npm-package-arg@8.1.2, required by pacote@11.3.3 npm ERR! missing: npm-packlist@2.1.5, required by pacote@11.3.3 npm ERR! missing: npm-pick-manifest@6.1.1, required by pacote@11.3.3 npm ERR! missing: npm-registry-fetch@10.1.1, required by pacote@11.3.3 npm ERR! missing: promise-retry@2.0.1, required by pacote@11.3.3 npm ERR! missing: read-package-json-fast@2.0.2, required by pacote@11.3.3 npm ERR! missing: rimraf@3.0.2, required by pacote@11.3.3 npm ERR! missing: ssri@8.0.1, required by pacote@11.3.3 npm ERR! missing: tar@6.1.0, required by pacote@11.3.3 npm ERR! missing: glob@7.1.6, required by npm-packlist@2.1.5 npm ERR! missing: ignore-walk@3.0.3, required by npm-packlist@2.1.5 npm ERR! missing: npm-bundled@1.1.2, required by npm-packlist@2.1.5 npm ERR! missing: npm-normalize-package-bin@1.0.1, required by npm-packlist@2.1.5 npm ERR! missing: minimatch@3.0.4, required by ignore-walk@3.0.3 npm ERR! missing: json-parse-even-better-errors@2.3.1, required by parse-conflict-json@1.1.1 npm ERR! missing: just-diff@3.1.1, required by parse-conflict-json@1.1.1 npm ERR! missing: just-diff-apply@3.0.0, required by parse-conflict-json@1.1.1 npm ERR! missing: mute-stream@0.0.8, required by read@1.0.7 npm ERR! missing: glob@7.1.6, required by read-package-json@3.0.1 npm ERR! missing: json-parse-even-better-errors@2.3.1, required by read-package-json@3.0.1 npm ERR! missing: normalize-package-data@3.0.2, required by read-package-json@3.0.1 npm ERR! missing: npm-normalize-package-bin@1.0.1, required by read-package-json@3.0.1 npm ERR! missing: json-parse-even-better-errors@2.3.1, required by read-package-json-fast@2.0.2 npm ERR! missing: npm-normalize-package-bin@1.0.1, required by read-package-json-fast@2.0.2 npm ERR! missing: debuglog@1.0.1, required by readdir-scoped-modules@1.1.0 npm ERR! missing: dezalgo@1.0.3, required by readdir-scoped-modules@1.1.0 npm ERR! missing: graceful-fs@4.2.6, required by readdir-scoped-modules@1.1.0 npm ERR! missing: once@1.4.0, required by readdir-scoped-modules@1.1.0 npm ERR! missing: asap@2.0.6, required by dezalgo@1.0.3 npm ERR! missing: wrappy@1.0.2, required by dezalgo@1.0.3 npm ERR! missing: glob@7.1.6, required by rimraf@3.0.2 npm ERR! missing: lru-cache@6.0.0, required by semver@7.3.5 npm ERR! missing: minipass@3.1.3, required by ssri@8.0.1 npm ERR! missing: chownr@2.0.0, required by tar@6.1.0 npm ERR! missing: fs-minipass@2.1.0, required by tar@6.1.0 npm ERR! missing: minipass@3.1.3, required by tar@6.1.0 npm ERR! missing: minizlib@2.1.2, required by tar@6.1.0 npm ERR! missing: mkdirp@1.0.4, required by tar@6.1.0 npm ERR! missing: yallist@4.0.0, required by tar@6.1.0 npm ERR! missing: builtins@1.0.3, required by validate-npm-package-name@3.0.0 npm ERR! missing: isexe@2.0.0, required by which@2.0.2 npm ERR! missing: imurmurhash@0.1.4, required by write-file-atomic@3.0.3 npm ERR! missing: is-typedarray@1.0.0, required by write-file-atomic@3.0.3 npm ERR! missing: signal-exit@3.0.3, required by write-file-atomic@3.0.3 npm ERR! missing: typedarray-to-buffer@3.1.5, required by write-file-atomic@3.0.3 npm ERR! missing: is-typedarray@1.0.0, required by typedarray-to-buffer@3.1.5 npm ERR! missing: cron-parser@2.15.0, required by node-schedule@1.3.2 npm ERR! peer dep missing: typescript@3.9.x || 4.0.x || 4.1.x, required by typedoc@0.20.28 npm ERR! extraneous: @babel/cli@7.13.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/cli npm ERR! extraneous: @babel/preset-env@7.13.9 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/preset-env npm ERR! extraneous: @babel/preset-typescript@7.13.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/preset-typescript npm ERR! extraneous: @types/debounce@1.2.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/debounce npm ERR! extraneous: @types/debug@4.1.5 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/debug npm ERR! extraneous: @types/jest@26.0.20 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/jest npm ERR! extraneous: @types/mz@2.7.3 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/mz npm ERR! extraneous: @types/nedb@1.8.11 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/nedb npm ERR! extraneous: @types/serialport@8.0.1 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/serialport npm ERR! extraneous: @typescript-eslint/eslint-plugin@4.16.1 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/eslint-plugin npm ERR! extraneous: @typescript-eslint/parser@4.16.1 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/parser npm ERR! extraneous: eslint@7.21.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/eslint npm ERR! extraneous: jest@26.6.3 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/jest npm ERR! extraneous: typedoc@0.20.28 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc npm ERR! extraneous: typedoc-plugin-markdown@3.6.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-markdown npm ERR! extraneous: typedoc-plugin-no-inherit@1.2.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-no-inherit npm ERR! extraneous: typedoc-plugin-sourcefile-url@1.0.6 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-sourcefile-url npm ERR! extraneous: eslint@7.27.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint npm ERR! extraneous: eslint-config-google@0.14.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint-config-google npm ERR! extraneous: eslint-plugin-jest@24.3.6 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint-plugin-jest npm ERR! extraneous: jest@26.6.3 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/jest npm ERR! peer dep missing: typescript@3.9.x || 4.0.x || 4.1.x, required by typedoc@0.20.28 npm ERR! extraneous: @babel/cli@7.13.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/cli npm ERR! extraneous: @babel/preset-env@7.13.9 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/preset-env npm ERR! extraneous: @babel/preset-typescript@7.13.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/preset-typescript npm ERR! extraneous: @types/debounce@1.2.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/debounce npm ERR! extraneous: @types/debug@4.1.5 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/debug npm ERR! extraneous: @types/jest@26.0.20 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/jest npm ERR! extraneous: @types/mz@2.7.3 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/mz npm ERR! extraneous: @types/nedb@1.8.11 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/nedb npm ERR! extraneous: @types/serialport@8.0.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/serialport npm ERR! extraneous: @typescript-eslint/eslint-plugin@4.16.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/eslint-plugin npm ERR! extraneous: @typescript-eslint/parser@4.16.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/parser npm ERR! extraneous: eslint@7.21.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/eslint npm ERR! extraneous: jest@26.6.3 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/jest npm ERR! extraneous: typedoc@0.20.28 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc npm ERR! extraneous: typedoc-plugin-markdown@3.6.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-markdown npm ERR! extraneous: typedoc-plugin-no-inherit@1.2.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-no-inherit npm ERR! extraneous: typedoc-plugin-sourcefile-url@1.0.6 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-sourcefile-url -
│ │ ├── cookie@0.4.1 │ │ ├── cookie-signature@1.0.6 deduped │ │ ├── debug@2.6.9 deduped │ │ ├── depd@2.0.0 │ │ ├── on-headers@1.0.2 deduped │ │ ├── parseurl@1.3.3 deduped │ │ ├── safe-buffer@5.2.1 │ │ └── uid-safe@2.1.5 deduped │ ├── iobroker.simple-api@2.6.1 deduped │ ├── iobroker.socketio@3.1.4 deduped │ ├─┬ mime-types@2.1.32 │ │ └── mime-db@1.49.0 │ ├── passport@0.4.1 deduped │ ├── passport-local@1.0.0 deduped │ ├── passport.socketio@3.7.0 deduped │ ├── request@2.88.2 deduped │ ├─┬ socket.io-client@2.3.0 │ │ ├── backo2@1.0.2 │ │ ├── base64-arraybuffer@0.1.5 │ │ ├── component-bind@1.0.0 │ │ ├── component-emitter@1.2.1 │ │ ├─┬ debug@4.1.1 │ │ │ └── ms@2.1.2 │ │ ├─┬ engine.io-client@3.4.3 │ │ │ ├── component-emitter@1.3.0 │ │ │ ├── component-inherit@0.0.3 │ │ │ ├─┬ debug@4.1.1 │ │ │ │ └── ms@2.1.2 │ │ │ ├── engine.io-parser@2.2.0 deduped │ │ │ ├── has-cors@1.1.0 deduped │ │ │ ├── indexof@0.0.1 deduped │ │ │ ├── parseqs@0.0.5 deduped │ │ │ ├── parseuri@0.0.5 deduped │ │ │ ├─┬ ws@6.1.4 │ │ │ │ └── async-limiter@1.0.1 deduped │ │ │ ├── xmlhttprequest-ssl@1.5.5 │ │ │ └── yeast@0.1.2 │ │ ├── has-binary2@1.0.3 deduped │ │ ├── has-cors@1.1.0 │ │ ├── indexof@0.0.1 │ │ ├── object-component@0.0.3 │ │ ├─┬ parseqs@0.0.5 │ │ │ └─┬ better-assert@1.0.2 │ │ │ └── callsite@1.0.0 deduped │ │ ├─┬ parseuri@0.0.5 │ │ │ └── better-assert@1.0.2 deduped │ │ ├─┬ socket.io-parser@3.3.0 │ │ │ ├── component-emitter@1.2.1 deduped │ │ │ ├─┬ debug@3.1.0 │ │ │ │ └── ms@2.0.0 │ │ │ └── isarray@2.0.1 deduped │ │ └── to-array@0.1.4 │ └── xtend@4.0.2 ├─┬ iobroker.zigbee@1.5.6 │ ├── @iobroker/adapter-core@2.5.1 deduped │ ├─┬ tar@6.1.0 │ │ ├── chownr@2.0.0 │ │ ├── fs-minipass@2.1.0 deduped │ │ ├── minipass@3.1.3 deduped │ │ ├─┬ minizlib@2.1.2 │ │ │ ├── minipass@3.1.3 deduped │ │ │ └── yallist@4.0.0 deduped │ │ ├── mkdirp@1.0.4 │ │ └── yallist@4.0.0 deduped │ ├── typescript@4.4.4 deduped │ ├─┬ zigbee-herdsman@0.13.110 │ │ ├── @babel/cli@7.13.0 extraneous │ │ ├── @babel/preset-env@7.13.9 extraneous │ │ ├── @babel/preset-typescript@7.13.0 extraneous │ │ ├─┬ @serialport/bindings@9.0.4 │ │ │ ├─┬ @serialport/binding-abstract@9.0.7 │ │ │ │ └── debug@4.3.1 deduped │ │ │ ├─┬ @serialport/parser-readline@9.0.7 │ │ │ │ └── @serialport/parser-delimiter@9.0.7 deduped │ │ │ ├─┬ bindings@1.5.0 │ │ │ │ └── file-uri-to-path@1.0.0 │ │ │ ├── debug@4.3.1 deduped │ │ │ ├── nan@2.14.2 │ │ │ └─┬ prebuild-install@6.0.1 │ │ │ ├── detect-libc@1.0.3 │ │ │ ├── expand-template@2.0.3 │ │ │ ├── github-from-package@0.0.0 │ │ │ ├── minimist@1.2.5 │ │ │ ├── mkdirp-classic@0.5.3 │ │ │ ├── napi-build-utils@1.0.2 │ │ │ ├─┬ node-abi@2.20.0 │ │ │ │ └── semver@5.7.1 │ │ │ ├── noop-logger@0.1.1 │ │ │ ├─┬ npmlog@4.1.2 │ │ │ │ ├─┬ are-we-there-yet@1.1.5 │ │ │ │ │ ├── delegates@1.0.0 │ │ │ │ │ └─┬ readable-stream@2.3.7 │ │ │ │ │ ├── core-util-is@1.0.2 │ │ │ │ │ ├── inherits@2.0.4 deduped │ │ │ │ │ ├── isarray@1.0.0 │ │ │ │ │ ├── process-nextick-args@2.0.1 │ │ │ │ │ ├── safe-buffer@5.1.2 deduped │ │ │ │ │ ├─┬ string_decoder@1.1.1 │ │ │ │ │ │ └── safe-buffer@5.1.2 deduped │ │ │ │ │ └── util-deprecate@1.0.2 │ │ │ │ ├── console-control-strings@1.1.0 │ │ │ │ ├─┬ gauge@2.7.4 │ │ │ │ │ ├── aproba@1.2.0 │ │ │ │ │ ├── console-control-strings@1.1.0 deduped │ │ │ │ │ ├── has-unicode@2.0.1 │ │ │ │ │ ├── object-assign@4.1.1 deduped │ │ │ │ │ ├── signal-exit@3.0.3 │ │ │ │ │ ├─┬ string-width@1.0.2 │ │ │ │ │ │ ├── code-point-at@1.1.0 │ │ │ │ │ │ ├─┬ is-fullwidth-code-point@1.0.0 │ │ │ │ │ │ │ └── number-is-nan@1.0.1 │ │ │ │ │ │ └── strip-ansi@3.0.1 deduped │ │ │ │ │ ├─┬ strip-ansi@3.0.1 │ │ │ │ │ │ └── ansi-regex@2.1.1 │ │ │ │ │ └─┬ wide-align@1.1.3 │ │ │ │ │ └── string-width@1.0.2 deduped │ │ │ │ └── set-blocking@2.0.0 │ │ │ ├─┬ pump@3.0.0 │ │ │ │ ├─┬ end-of-stream@1.4.4 │ │ │ │ │ └── once@1.4.0 deduped │ │ │ │ └─┬ once@1.4.0 │ │ │ │ └── wrappy@1.0.2 │ │ │ ├─┬ rc@1.2.8 │ │ │ │ ├── deep-extend@0.6.0 │ │ │ │ ├── ini@1.3.8 │ │ │ │ ├── minimist@1.2.5 deduped │ │ │ │ └── strip-json-comments@2.0.1 │ │ │ ├─┬ simple-get@3.1.0 │ │ │ │ ├─┬ decompress-response@4.2.1 │ │ │ │ │ └── mimic-response@2.1.0 │ │ │ │ ├── once@1.4.0 deduped │ │ │ │ └── simple-concat@1.0.1 │ │ │ ├─┬ tar-fs@2.1.1 │ │ │ │ ├── chownr@1.1.4 │ │ │ │ ├── mkdirp-classic@0.5.3 deduped │ │ │ │ ├── pump@3.0.0 deduped │ │ │ │ └─┬ tar-stream@2.2.0 │ │ │ │ ├─┬ bl@4.1.0 │ │ │ │ │ ├─┬ buffer@5.7.1 │ │ │ │ │ │ ├── base64-js@1.5.1 │ │ │ │ │ │ └── ieee754@1.2.1 │ │ │ │ │ ├── inherits@2.0.4 deduped │ │ │ │ │ └─┬ readable-stream@3.6.0 │ │ │ │ │ ├── inherits@2.0.4 deduped │ │ │ │ │ ├── string_decoder@1.1.1 deduped │ │ │ │ │ └── util-deprecate@1.0.2 deduped │ │ │ │ ├── end-of-stream@1.4.4 deduped │ │ │ │ ├── fs-constants@1.0.0 │ │ │ │ ├── inherits@2.0.4 │ │ │ │ └─┬ readable-stream@3.6.0 │ │ │ │ ├── inherits@2.0.4 deduped │ │ │ │ ├── string_decoder@1.1.1 deduped │ │ │ │ └── util-deprecate@1.0.2 deduped │ │ │ ├─┬ tunnel-agent@0.6.0 │ │ │ │ └── safe-buffer@5.1.2 │ │ │ └── which-pm-runs@1.0.0 │ │ ├── @types/debounce@1.2.0 extraneous │ │ ├── @types/debug@4.1.5 extraneous │ │ ├── @types/jest@26.0.20 extraneous │ │ ├── @types/mz@2.7.3 extraneous │ │ ├── @types/nedb@1.8.11 extraneous │ │ ├── @types/serialport@8.0.1 extraneous │ │ ├── @typescript-eslint/eslint-plugin@4.16.1 extraneous │ │ ├── @typescript-eslint/parser@4.16.1 extraneous │ │ ├── debounce@1.2.0 │ │ ├─┬ debug@4.3.1 │ │ │ └── ms@2.1.2 │ │ ├── eslint@7.21.0 extraneous │ │ ├── fast-deep-equal@3.1.3 │ │ ├── jest@26.6.3 extraneous │ │ ├── mixin-deep@2.0.1 │ │ ├─┬ mz@2.7.0 │ │ │ ├── any-promise@1.3.0 │ │ │ ├── object-assign@4.1.1 │ │ │ └─┬ thenify-all@1.6.0 │ │ │ └─┬ thenify@3.3.1 │ │ │ └── any-promise@1.3.0 deduped │ │ ├─┬ serialport@9.0.6 │ │ │ ├─┬ @serialport/binding-mock@9.0.7 │ │ │ │ ├── @serialport/binding-abstract@9.0.7 deduped │ │ │ │ └── debug@4.3.1 deduped │ │ │ ├── @serialport/bindings@9.0.4 deduped │ │ │ ├── @serialport/parser-byte-length@9.0.7 │ │ │ ├── @serialport/parser-cctalk@9.0.7 │ │ │ ├── @serialport/parser-delimiter@9.0.7 │ │ │ ├── @serialport/parser-inter-byte-timeout@9.0.7 │ │ │ ├── @serialport/parser-readline@9.0.7 deduped │ │ │ ├── @serialport/parser-ready@9.0.7 │ │ │ ├── @serialport/parser-regex@9.0.7 │ │ │ ├─┬ @serialport/stream@9.0.7 │ │ │ │ └── debug@4.3.1 deduped │ │ │ └── debug@4.3.1 deduped │ │ ├── slip@1.0.2 │ │ ├── typedoc@0.20.28 extraneous │ │ ├── typedoc-plugin-markdown@3.6.0 extraneous │ │ ├── typedoc-plugin-no-inherit@1.2.0 extraneous │ │ ├── typedoc-plugin-sourcefile-url@1.0.6 extraneous │ │ └── UNMET PEER DEPENDENCY typescript@4.2.2 extraneous │ └─┬ zigbee-herdsman-converters@14.0.162 │ ├─┬ axios@0.21.1 │ │ └── follow-redirects@1.14.1 │ ├── buffer-crc32@0.2.13 │ ├── eslint@7.27.0 extraneous │ ├── eslint-config-google@0.14.0 extraneous │ ├── eslint-plugin-jest@24.3.6 extraneous │ ├─┬ https-proxy-agent@5.0.0 │ │ ├─┬ agent-base@6.0.2 │ │ │ └── debug@4.3.1 deduped │ │ └─┬ debug@4.3.1 │ │ └── ms@2.1.2 │ ├── jest@26.6.3 extraneous │ ├─┬ tar-stream@2.2.0 │ │ ├─┬ bl@4.1.0 │ │ │ ├─┬ buffer@5.7.1 │ │ │ │ ├── base64-js@1.5.1 │ │ │ │ └── ieee754@1.2.1 │ │ │ ├── inherits@2.0.4 deduped │ │ │ └── readable-stream@3.6.0 deduped │ │ ├─┬ end-of-stream@1.4.4 │ │ │ └─┬ once@1.4.0 │ │ │ └── wrappy@1.0.2 │ │ ├── fs-constants@1.0.0 │ │ ├── inherits@2.0.4 │ │ └─┬ readable-stream@3.6.0 │ │ ├── inherits@2.0.4 deduped │ │ ├─┬ string_decoder@1.3.0 │ │ │ └── safe-buffer@5.2.1 │ │ └── util-deprecate@1.0.2 │ └─┬ zigbee-herdsman@0.13.107 │ ├── @babel/cli@7.13.0 extraneous │ ├── @babel/preset-env@7.13.9 extraneous │ ├── @babel/preset-typescript@7.13.0 extraneous │ ├─┬ @serialport/bindings@9.0.4 │ │ ├─┬ @serialport/binding-abstract@9.0.7 │ │ │ └── debug@4.3.1 deduped │ │ ├─┬ @serialport/parser-readline@9.0.7 │ │ │ └── @serialport/parser-delimiter@9.0.7 deduped │ │ ├─┬ bindings@1.5.0 │ │ │ └── file-uri-to-path@1.0.0 │ │ ├── debug@4.3.1 deduped │ │ ├── nan@2.14.2 │ │ └─┬ prebuild-install@6.0.1 │ │ ├── detect-libc@1.0.3 │ │ ├── expand-template@2.0.3 │ │ ├── github-from-package@0.0.0 │ │ ├── minimist@1.2.5 │ │ ├── mkdirp-classic@0.5.3 │ │ ├── napi-build-utils@1.0.2 │ │ ├─┬ node-abi@2.20.0 │ │ │ └── semver@5.7.1 │ │ ├── noop-logger@0.1.1 │ │ ├─┬ npmlog@4.1.2 │ │ │ ├─┬ are-we-there-yet@1.1.5 │ │ │ │ ├── delegates@1.0.0 │ │ │ │ └─┬ readable-stream@2.3.7 │ │ │ │ ├── core-util-is@1.0.2 │ │ │ │ ├── inherits@2.0.4 deduped │ │ │ │ ├── isarray@1.0.0 │ │ │ │ ├── process-nextick-args@2.0.1 │ │ │ │ ├── safe-buffer@5.1.2 deduped │ │ │ │ ├─┬ string_decoder@1.1.1 │ │ │ │ │ └── safe-buffer@5.1.2 deduped │ │ │ │ └── util-deprecate@1.0.2 │ │ │ ├── console-control-strings@1.1.0 │ │ │ ├─┬ gauge@2.7.4 │ │ │ │ ├── aproba@1.2.0 │ │ │ │ ├── console-control-strings@1.1.0 deduped │ │ │ │ ├── has-unicode@2.0.1 │ │ │ │ ├── object-assign@4.1.1 deduped │ │ │ │ ├── signal-exit@3.0.3 │ │ │ │ ├─┬ string-width@1.0.2 │ │ │ │ │ ├── code-point-at@1.1.0 │ │ │ │ │ ├─┬ is-fullwidth-code-point@1.0.0 │ │ │ │ │ │ └── number-is-nan@1.0.1 │ │ │ │ │ └── strip-ansi@3.0.1 deduped │ │ │ │ ├─┬ strip-ansi@3.0.1 │ │ │ │ │ └── ansi-regex@2.1.1 │ │ │ │ └─┬ wide-align@1.1.3 │ │ │ │ └── string-width@1.0.2 deduped │ │ │ └── set-blocking@2.0.0 │ │ ├─┬ pump@3.0.0 │ │ │ ├─┬ end-of-stream@1.4.4 │ │ │ │ └── once@1.4.0 deduped │ │ │ └─┬ once@1.4.0 │ │ │ └── wrappy@1.0.2 │ │ ├─┬ rc@1.2.8 │ │ │ ├── deep-extend@0.6.0 │ │ │ ├── ini@1.3.8 │ │ │ ├── minimist@1.2.5 deduped │ │ │ └── strip-json-comments@2.0.1 │ │ ├─┬ simple-get@3.1.0 │ │ │ ├─┬ decompress-response@4.2.1 │ │ │ │ └── mimic-response@2.1.0 │ │ │ ├── once@1.4.0 deduped │ │ │ └── simple-concat@1.0.1 │ │ ├─┬ tar-fs@2.1.1 │ │ │ ├── chownr@1.1.4 │ │ │ ├── mkdirp-classic@0.5.3 deduped │ │ │ ├── pump@3.0.0 deduped │ │ │ └─┬ tar-stream@2.2.0 │ │ │ ├─┬ bl@4.1.0 │ │ │ │ ├─┬ buffer@5.7.1 │ │ │ │ │ ├── base64-js@1.5.1 │ │ │ │ │ └── ieee754@1.2.1 │ │ │ │ ├── inherits@2.0.4 deduped │ │ │ │ └─┬ readable-stream@3.6.0 │ │ │ │ ├── inherits@2.0.4 deduped │ │ │ │ ├── string_decoder@1.1.1 deduped │ │ │ │ └── util-deprecate@1.0.2 deduped │ │ │ ├── end-of-stream@1.4.4 deduped │ │ │ ├── fs-constants@1.0.0 │ │ │ ├── inherits@2.0.4 │ │ │ └─┬ readable-stream@3.6.0 │ │ │ ├── inherits@2.0.4 deduped │ │ │ ├── string_decoder@1.1.1 deduped │ │ │ └── util-deprecate@1.0.2 deduped │ │ ├─┬ tunnel-agent@0.6.0 │ │ │ └── safe-buffer@5.1.2 │ │ └── which-pm-runs@1.0.0 │ ├── @types/debounce@1.2.0 extraneous │ ├── @types/debug@4.1.5 extraneous │ ├── @types/jest@26.0.20 extraneous │ ├── @types/mz@2.7.3 extraneous │ ├── @types/nedb@1.8.11 extraneous │ ├── @types/serialport@8.0.1 extraneous │ ├── @typescript-eslint/eslint-plugin@4.16.1 extraneous │ ├── @typescript-eslint/parser@4.16.1 extraneous │ ├── debounce@1.2.0 │ ├─┬ debug@4.3.1 │ │ └── ms@2.1.2 │ ├── eslint@7.21.0 extraneous │ ├── fast-deep-equal@3.1.3 │ ├── jest@26.6.3 extraneous │ ├── mixin-deep@2.0.1 │ ├─┬ mz@2.7.0 │ │ ├── any-promise@1.3.0 │ │ ├── object-assign@4.1.1 │ │ └─┬ thenify-all@1.6.0 │ │ └─┬ thenify@3.3.1 │ │ └── any-promise@1.3.0 deduped │ ├─┬ serialport@9.0.6 │ │ ├─┬ @serialport/binding-mock@9.0.7 │ │ │ ├── @serialport/binding-abstract@9.0.7 deduped │ │ │ └── debug@4.3.1 deduped │ │ ├── @serialport/bindings@9.0.4 deduped │ │ ├── @serialport/parser-byte-length@9.0.7 │ │ ├── @serialport/parser-cctalk@9.0.7 │ │ ├── @serialport/parser-delimiter@9.0.7 │ │ ├── @serialport/parser-inter-byte-timeout@9.0.7 │ │ ├── @serialport/parser-readline@9.0.7 deduped │ │ ├── @serialport/parser-ready@9.0.7 │ │ ├── @serialport/parser-regex@9.0.7 │ │ ├─┬ @serialport/stream@9.0.7 │ │ │ └── debug@4.3.1 deduped │ │ └── debug@4.3.1 deduped │ ├── slip@1.0.2 │ ├── typedoc@0.20.28 extraneous │ ├── typedoc-plugin-markdown@3.6.0 extraneous │ ├── typedoc-plugin-no-inherit@1.2.0 extraneous │ ├── typedoc-plugin-sourcefile-url@1.0.6 extraneous │ └── UNMET PEER DEPENDENCY typescript@4.2.2 extraneous ├── semver@5.7.1 └─┬ yargs@7.1.1 ├── camelcase@3.0.0 ├─┬ cliui@3.2.0 │ ├── string-width@1.0.2 deduped │ ├─┬ strip-ansi@3.0.1 │ │ └── ansi-regex@2.1.1 │ └─┬ wrap-ansi@2.1.0 │ ├── string-width@1.0.2 deduped │ └── strip-ansi@3.0.1 deduped ├── decamelize@1.2.0 ├── get-caller-file@1.0.3 ├─┬ os-locale@1.4.0 │ └─┬ lcid@1.0.0 │ └── invert-kv@1.0.0 ├─┬ read-pkg-up@1.0.1 │ ├─┬ find-up@1.1.2 │ │ ├─┬ path-exists@2.1.0 │ │ │ └── pinkie-promise@2.0.1 deduped │ │ └─┬ pinkie-promise@2.0.1 │ │ └── pinkie@2.0.4 │ └─┬ read-pkg@1.1.0 │ ├─┬ load-json-file@1.1.0 │ │ ├── graceful-fs@4.2.4 deduped │ │ ├─┬ parse-json@2.2.0 │ │ │ └── error-ex@1.3.2 deduped │ │ ├── pify@2.3.0 │ │ ├── pinkie-promise@2.0.1 deduped │ │ └─┬ strip-bom@2.0.0 │ │ └── is-utf8@0.2.1 │ ├─┬ normalize-package-data@2.5.0 │ │ ├── hosted-git-info@2.8.8 │ │ ├─┬ resolve@1.17.0 │ │ │ └── path-parse@1.0.6 deduped │ │ ├── semver@5.7.1 deduped │ │ └── validate-npm-package-license@3.0.4 deduped │ └─┬ path-type@1.1.0 │ ├── graceful-fs@4.2.4 deduped │ ├── pify@2.3.0 deduped │ └── pinkie-promise@2.0.1 deduped ├── require-directory@2.1.1 ├── require-main-filename@1.0.1 ├── set-blocking@2.0.0 ├─┬ string-width@1.0.2 │ ├── code-point-at@1.1.0 │ ├─┬ is-fullwidth-code-point@1.0.0 │ │ └── number-is-nan@1.0.1 │ └── strip-ansi@3.0.1 deduped ├── which-module@1.0.0 ├── y18n@3.2.1 └─┬ yargs-parser@5.0.0-security.0 ├── camelcase@3.0.0 deduped └─┬ object.assign@4.1.0 ├── define-properties@1.1.3 deduped ├── function-bind@1.1.1 deduped ├── has-symbols@1.0.1 └── object-keys@1.1.1 npm ERR! missing: iobroker.sourceanalytix@git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#f64a6083778ce5b12274eadb73e78cf28568fccc, required by iobroker.inst@2.0.3 npm ERR! peer dep missing: @angular/common@>= 5.0.0, required by xmlhttprequest-ts@1.0.1 npm ERR! peer dep missing: @angular/core@>= 5.0.0, required by xmlhttprequest-ts@1.0.1 npm ERR! missing: xmlhttprequest@^1.8.0, required by iobroker.javascript@5.2.13 npm ERR! missing: cron@1.8.2, required by iobroker.sourceanalytix@git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#f64a6083778ce5b12274eadb73e78cf28568fccc npm ERR! missing: iobroker-adapter-helpers@0.0.8, required by iobroker.sourceanalytix@git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#f64a6083778ce5b12274eadb73e78cf28568fccc npm ERR! missing: @sentry/node@5.30.0, required by iobroker.sourceanalytix@git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#f64a6083778ce5b12274eadb73e78cf28568fccc npm ERR! missing: npm@7.11.1, required by iobroker.sourceanalytix@git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#f64a6083778ce5b12274eadb73e78cf28568fccc npm ERR! missing: node-schedule@1.3.2, required by iobroker.sourceanalytix@git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#f64a6083778ce5b12274eadb73e78cf28568fccc npm ERR! missing: @sentry/core@5.30.0, required by @sentry/node@5.30.0 npm ERR! missing: @sentry/hub@5.30.0, required by @sentry/node@5.30.0 npm ERR! missing: @sentry/tracing@5.30.0, required by @sentry/node@5.30.0 npm ERR! missing: @sentry/types@5.30.0, required by @sentry/node@5.30.0 npm ERR! missing: @sentry/utils@5.30.0, required by @sentry/node@5.30.0 npm ERR! missing: cookie@0.4.1, required by @sentry/node@5.30.0 npm ERR! missing: @sentry/hub@5.30.0, required by @sentry/core@5.30.0 npm ERR! missing: @sentry/minimal@5.30.0, required by @sentry/core@5.30.0 npm ERR! missing: @sentry/types@5.30.0, required by @sentry/core@5.30.0 npm ERR! missing: @sentry/utils@5.30.0, required by @sentry/core@5.30.0 npm ERR! missing: @sentry/hub@5.30.0, required by @sentry/minimal@5.30.0 npm ERR! missing: @sentry/types@5.30.0, required by @sentry/minimal@5.30.0 npm ERR! missing: @sentry/types@5.30.0, required by @sentry/hub@5.30.0 npm ERR! missing: @sentry/utils@5.30.0, required by @sentry/hub@5.30.0 npm ERR! missing: @sentry/hub@5.30.0, required by @sentry/tracing@5.30.0 npm ERR! missing: @sentry/minimal@5.30.0, required by @sentry/tracing@5.30.0 npm ERR! missing: @sentry/types@5.30.0, required by @sentry/tracing@5.30.0 npm ERR! missing: @sentry/utils@5.30.0, required by @sentry/tracing@5.30.0 npm ERR! missing: @sentry/types@5.30.0, required by @sentry/utils@5.30.0 npm ERR! missing: @npmcli/arborist@2.4.0, required by npm@7.11.1 npm ERR! missing: @npmcli/ci-detect@1.3.0, required by npm@7.11.1 npm ERR! missing: @npmcli/config@2.2.0, required by npm@7.11.1 npm ERR! missing: @npmcli/run-script@1.8.5, required by npm@7.11.1 npm ERR! missing: abbrev@1.1.1, required by npm@7.11.1 npm ERR! missing: ansicolors@0.3.2, required by npm@7.11.1 npm ERR! missing: ansistyles@0.1.3, required by npm@7.11.1 npm ERR! missing: archy@1.0.0, required by npm@7.11.1 npm ERR! missing: byte-size@7.0.1, required by npm@7.11.1 npm ERR! missing: cacache@15.0.6, required by npm@7.11.1 npm ERR! missing: chalk@4.1.1, required by npm@7.11.1 npm ERR! missing: chownr@2.0.0, required by npm@7.11.1 npm ERR! missing: cli-columns@3.1.2, required by npm@7.11.1 npm ERR! missing: cli-table3@0.6.0, required by npm@7.11.1 npm ERR! missing: columnify@1.5.4, required by npm@7.11.1 npm ERR! missing: glob@7.1.6, required by npm@7.11.1 npm ERR! missing: graceful-fs@4.2.6, required by npm@7.11.1 npm ERR! missing: hosted-git-info@4.0.2, required by npm@7.11.1 npm ERR! missing: ini@2.0.0, required by npm@7.11.1 npm ERR! missing: init-package-json@2.0.3, required by npm@7.11.1 npm ERR! missing: is-cidr@4.0.2, required by npm@7.11.1 npm ERR! missing: json-parse-even-better-errors@2.3.1, required by npm@7.11.1 npm ERR! missing: leven@3.1.0, required by npm@7.11.1 npm ERR! missing: libnpmaccess@4.0.2, required by npm@7.11.1 npm ERR! missing: libnpmdiff@2.0.4, required by npm@7.11.1 npm ERR! missing: libnpmexec@1.0.1, required by npm@7.11.1 npm ERR! missing: libnpmfund@1.0.2, required by npm@7.11.1 npm ERR! missing: libnpmhook@6.0.2, required by npm@7.11.1 npm ERR! missing: libnpmorg@2.0.2, required by npm@7.11.1 npm ERR! missing: libnpmpack@2.0.1, required by npm@7.11.1 npm ERR! missing: libnpmpublish@4.0.1, required by npm@7.11.1 npm ERR! missing: libnpmsearch@3.1.1, required by npm@7.11.1 npm ERR! missing: libnpmteam@2.0.3, required by npm@7.11.1 npm ERR! missing: libnpmversion@1.2.0, required by npm@7.11.1 npm ERR! missing: make-fetch-happen@8.0.14, required by npm@7.11.1 npm ERR! missing: minipass@3.1.3, required by npm@7.11.1 npm ERR! missing: minipass-pipeline@1.2.4, required by npm@7.11.1 npm ERR! missing: mkdirp@1.0.4, required by npm@7.11.1 npm ERR! missing: mkdirp-infer-owner@2.0.0, required by npm@7.11.1 npm ERR! missing: ms@2.1.3, required by npm@7.11.1 npm ERR! missing: node-gyp@7.1.2, required by npm@7.11.1 npm ERR! missing: nopt@5.0.0, required by npm@7.11.1 npm ERR! missing: npm-audit-report@2.1.4, required by npm@7.11.1 npm ERR! missing: npm-package-arg@8.1.2, required by npm@7.11.1 npm ERR! missing: npm-pick-manifest@6.1.1, required by npm@7.11.1 npm ERR! missing: npm-profile@5.0.3, required by npm@7.11.1 npm ERR! missing: npm-registry-fetch@10.1.1, required by npm@7.11.1 npm ERR! missing: npm-user-validate@1.0.1, required by npm@7.11.1 npm ERR! missing: npmlog@4.1.2, required by npm@7.11.1 npm ERR! missing: opener@1.5.2, required by npm@7.11.1 npm ERR! missing: pacote@11.3.3, required by npm@7.11.1 npm ERR! missing: parse-conflict-json@1.1.1, required by npm@7.11.1 npm ERR! missing: qrcode-terminal@0.12.0, required by npm@7.11.1 npm ERR! missing: read@1.0.7, required by npm@7.11.1 npm ERR! missing: read-package-json@3.0.1, required by npm@7.11.1 npm ERR! missing: read-package-json-fast@2.0.2, required by npm@7.11.1 npm ERR! missing: readdir-scoped-modules@1.1.0, required by npm@7.11.1 npm ERR! missing: rimraf@3.0.2, required by npm@7.11.1 npm ERR! missing: semver@7.3.5, required by npm@7.11.1 npm ERR! missing: ssri@8.0.1, required by npm@7.11.1 npm ERR! missing: tar@6.1.0, required by npm@7.11.1 npm ERR! missing: text-table@0.2.0, required by npm@7.11.1 npm ERR! missing: tiny-relative-date@1.3.0, required by npm@7.11.1 npm ERR! missing: treeverse@1.0.4, required by npm@7.11.1 npm ERR! missing: validate-npm-package-name@3.0.0, required by npm@7.11.1 npm ERR! missing: which@2.0.2, required by npm@7.11.1 npm ERR! missing: write-file-atomic@3.0.3, required by npm@7.11.1 npm ERR! missing: @npmcli/installed-package-contents@1.0.7, required by @npmcli/arborist@2.4.0 npm ERR! missing: @npmcli/map-workspaces@1.0.3, required by @npmcli/arborist@2.4.0 npm ERR! missing: @npmcli/metavuln-calculator@1.1.1, required by @npmcli/arborist@2.4.0 npm ERR! missing: @npmcli/move-file@1.1.2, required by @npmcli/arborist@2.4.0 npm ERR! missing: @npmcli/name-from-folder@1.0.1, required by @npmcli/arborist@2.4.0 npm ERR! missing: @npmcli/node-gyp@1.0.2, required by @npmcli/arborist@2.4.0 npm ERR! missing: @npmcli/run-script@1.8.5, required by @npmcli/arborist@2.4.0 npm ERR! missing: bin-links@2.2.1, required by @npmcli/arborist@2.4.0 npm ERR! missing: cacache@15.0.6, required by @npmcli/arborist@2.4.0 npm ERR! missing: common-ancestor-path@1.0.1, required by @npmcli/arborist@2.4.0 npm ERR! missing: json-parse-even-better-errors@2.3.1, required by @npmcli/arborist@2.4.0 npm ERR! missing: json-stringify-nice@1.1.3, required by @npmcli/arborist@2.4.0 npm ERR! missing: mkdirp-infer-owner@2.0.0, required by @npmcli/arborist@2.4.0 npm ERR! missing: npm-install-checks@4.0.0, required by @npmcli/arborist@2.4.0 npm ERR! missing: npm-package-arg@8.1.2, required by @npmcli/arborist@2.4.0 npm ERR! missing: npm-pick-manifest@6.1.1, required by @npmcli/arborist@2.4.0 npm ERR! missing: npm-registry-fetch@10.1.1, required by @npmcli/arborist@2.4.0 npm ERR! missing: pacote@11.3.3, required by @npmcli/arborist@2.4.0 npm ERR! missing: parse-conflict-json@1.1.1, required by @npmcli/arborist@2.4.0 npm ERR! missing: promise-all-reject-late@1.0.1, required by @npmcli/arborist@2.4.0 npm ERR! missing: promise-call-limit@1.0.1, required by @npmcli/arborist@2.4.0 npm ERR! missing: read-package-json-fast@2.0.2, required by @npmcli/arborist@2.4.0 npm ERR! missing: readdir-scoped-modules@1.1.0, required by @npmcli/arborist@2.4.0 npm ERR! missing: semver@7.3.5, required by @npmcli/arborist@2.4.0 npm ERR! missing: tar@6.1.0, required by @npmcli/arborist@2.4.0 npm ERR! missing: treeverse@1.0.4, required by @npmcli/arborist@2.4.0 npm ERR! missing: walk-up-path@1.0.0, required by @npmcli/arborist@2.4.0 npm ERR! missing: npm-bundled@1.1.2, required by @npmcli/installed-package-contents@1.0.7 npm ERR! missing: npm-normalize-package-bin@1.0.1, required by @npmcli/installed-package-contents@1.0.7 npm ERR! missing: npm-normalize-package-bin@1.0.1, required by npm-bundled@1.1.2 npm ERR! missing: @npmcli/name-from-folder@1.0.1, required by @npmcli/map-workspaces@1.0.3 npm ERR! missing: glob@7.1.6, required by @npmcli/map-workspaces@1.0.3 npm ERR! missing: minimatch@3.0.4, required by @npmcli/map-workspaces@1.0.3 npm ERR! missing: read-package-json-fast@2.0.2, required by @npmcli/map-workspaces@1.0.3 npm ERR! missing: cacache@15.0.6, required by @npmcli/metavuln-calculator@1.1.1 npm ERR! missing: pacote@11.3.3, required by @npmcli/metavuln-calculator@1.1.1 npm ERR! missing: semver@7.3.5, required by @npmcli/metavuln-calculator@1.1.1 npm ERR! missing: mkdirp@1.0.4, required by @npmcli/move-file@1.1.2 npm ERR! missing: rimraf@3.0.2, required by @npmcli/move-file@1.1.2 npm ERR! missing: cmd-shim@4.1.0, required by bin-links@2.2.1 npm ERR! missing: mkdirp@1.0.4, required by bin-links@2.2.1 npm ERR! missing: npm-normalize-package-bin@1.0.1, required by bin-links@2.2.1 npm ERR! missing: read-cmd-shim@2.0.0, required by bin-links@2.2.1 npm ERR! missing: rimraf@3.0.2, required by bin-links@2.2.1 npm ERR! missing: write-file-atomic@3.0.3, required by bin-links@2.2.1 npm ERR! missing: mkdirp-infer-owner@2.0.0, required by cmd-shim@4.1.0 npm ERR! missing: semver@7.3.5, required by npm-install-checks@4.0.0 npm ERR! missing: ini@2.0.0, required by @npmcli/config@2.2.0 npm ERR! missing: mkdirp-infer-owner@2.0.0, required by @npmcli/config@2.2.0 npm ERR! missing: nopt@5.0.0, required by @npmcli/config@2.2.0 npm ERR! missing: semver@7.3.5, required by @npmcli/config@2.2.0 npm ERR! missing: walk-up-path@1.0.0, required by @npmcli/config@2.2.0 npm ERR! missing: @npmcli/node-gyp@1.0.2, required by @npmcli/run-script@1.8.5 npm ERR! missing: @npmcli/promise-spawn@1.3.2, required by @npmcli/run-script@1.8.5 npm ERR! missing: infer-owner@1.0.4, required by @npmcli/run-script@1.8.5 npm ERR! missing: node-gyp@7.1.2, required by @npmcli/run-script@1.8.5 npm ERR! missing: read-package-json-fast@2.0.2, required by @npmcli/run-script@1.8.5 npm ERR! missing: infer-owner@1.0.4, required by @npmcli/promise-spawn@1.3.2 npm ERR! missing: @npmcli/move-file@1.1.2, required by cacache@15.0.6 npm ERR! missing: chownr@2.0.0, required by cacache@15.0.6 npm ERR! missing: fs-minipass@2.1.0, required by cacache@15.0.6 npm ERR! missing: glob@7.1.6, required by cacache@15.0.6 npm ERR! missing: infer-owner@1.0.4, required by cacache@15.0.6 npm ERR! missing: lru-cache@6.0.0, required by cacache@15.0.6 npm ERR! missing: minipass@3.1.3, required by cacache@15.0.6 npm ERR! missing: minipass-collect@1.0.2, required by cacache@15.0.6 npm ERR! missing: minipass-flush@1.0.5, required by cacache@15.0.6 npm ERR! missing: minipass-pipeline@1.2.4, required by cacache@15.0.6 npm ERR! missing: mkdirp@1.0.4, required by cacache@15.0.6 npm ERR! missing: p-map@4.0.0, required by cacache@15.0.6 npm ERR! missing: promise-inflight@1.0.1, required by cacache@15.0.6 npm ERR! missing: rimraf@3.0.2, required by cacache@15.0.6 npm ERR! missing: ssri@8.0.1, required by cacache@15.0.6 npm ERR! missing: tar@6.1.0, required by cacache@15.0.6 npm ERR! missing: unique-filename@1.1.1, required by cacache@15.0.6 npm ERR! missing: minipass@3.1.3, required by fs-minipass@2.1.0 npm ERR! missing: yallist@4.0.0, required by lru-cache@6.0.0 npm ERR! missing: minipass@3.1.3, required by minipass-collect@1.0.2 npm ERR! missing: minipass@3.1.3, required by minipass-flush@1.0.5 npm ERR! missing: aggregate-error@3.1.0, required by p-map@4.0.0 npm ERR! missing: clean-stack@2.2.0, required by aggregate-error@3.1.0 npm ERR! missing: indent-string@4.0.0, required by aggregate-error@3.1.0 npm ERR! missing: unique-slug@2.0.2, required by unique-filename@1.1.1 npm ERR! missing: imurmurhash@0.1.4, required by unique-slug@2.0.2 npm ERR! missing: ansi-styles@4.3.0, required by chalk@4.1.1 npm ERR! missing: supports-color@7.2.0, required by chalk@4.1.1 npm ERR! missing: color-convert@2.0.1, required by ansi-styles@4.3.0 npm ERR! missing: color-name@1.1.4, required by color-convert@2.0.1 npm ERR! missing: has-flag@4.0.0, required by supports-color@7.2.0 npm ERR! missing: string-width@2.1.1, required by cli-columns@3.1.2 npm ERR! missing: strip-ansi@3.0.1, required by cli-columns@3.1.2 npm ERR! missing: is-fullwidth-code-point@2.0.0, required by string-width@2.1.1 npm ERR! missing: strip-ansi@4.0.0, required by string-width@2.1.1 npm ERR! missing: ansi-regex@3.0.0, required by strip-ansi@4.0.0 npm ERR! missing: ansi-regex@2.1.1, required by strip-ansi@3.0.1 npm ERR! missing: string-width@4.2.2, required by cli-table3@0.6.0 npm ERR! missing: object-assign@4.1.1, required by cli-table3@0.6.0 npm ERR! missing: is-fullwidth-code-point@3.0.0, required by string-width@4.2.2 npm ERR! missing: strip-ansi@6.0.0, required by string-width@4.2.2 npm ERR! missing: emoji-regex@8.0.0, required by string-width@4.2.2 npm ERR! missing: ansi-regex@5.0.0, required by strip-ansi@6.0.0 npm ERR! missing: strip-ansi@3.0.1, required by columnify@1.5.4 npm ERR! missing: wcwidth@1.0.1, required by columnify@1.5.4 npm ERR! missing: defaults@1.0.3, required by wcwidth@1.0.1 npm ERR! missing: clone@1.0.4, required by defaults@1.0.3 npm ERR! missing: fs.realpath@1.0.0, required by glob@7.1.6 npm ERR! missing: inflight@1.0.6, required by glob@7.1.6 npm ERR! missing: inherits@2.0.4, required by glob@7.1.6 npm ERR! missing: minimatch@3.0.4, required by glob@7.1.6 npm ERR! missing: once@1.4.0, required by glob@7.1.6 npm ERR! missing: path-is-absolute@1.0.1, required by glob@7.1.6 npm ERR! missing: once@1.4.0, required by inflight@1.0.6 npm ERR! missing: wrappy@1.0.2, required by inflight@1.0.6 npm ERR! missing: brace-expansion@1.1.11, required by minimatch@3.0.4 npm ERR! missing: balanced-match@1.0.2, required by brace-expansion@1.1.11 npm ERR! missing: concat-map@0.0.1, required by brace-expansion@1.1.11 npm ERR! missing: wrappy@1.0.2, required by once@1.4.0 npm ERR! missing: lru-cache@6.0.0, required by hosted-git-info@4.0.2 npm ERR! missing: glob@7.1.6, required by init-package-json@2.0.3 npm ERR! missing: npm-package-arg@8.1.2, required by init-package-json@2.0.3 npm ERR! missing: promzard@0.3.0, required by init-package-json@2.0.3 npm ERR! missing: read@1.0.7, required by init-package-json@2.0.3 npm ERR! missing: read-package-json@3.0.1, required by init-package-json@2.0.3 npm ERR! missing: semver@7.3.5, required by init-package-json@2.0.3 npm ERR! missing: validate-npm-package-license@3.0.4, required by init-package-json@2.0.3 npm ERR! missing: validate-npm-package-name@3.0.0, required by init-package-json@2.0.3 npm ERR! missing: read@1.0.7, required by promzard@0.3.0 npm ERR! missing: spdx-correct@3.1.1, required by validate-npm-package-license@3.0.4 npm ERR! missing: spdx-expression-parse@3.0.1, required by validate-npm-package-license@3.0.4 npm ERR! missing: spdx-expression-parse@3.0.1, required by spdx-correct@3.1.1 npm ERR! missing: spdx-license-ids@3.0.7, required by spdx-correct@3.1.1 npm ERR! missing: spdx-exceptions@2.3.0, required by spdx-expression-parse@3.0.1 npm ERR! missing: spdx-license-ids@3.0.7, required by spdx-expression-parse@3.0.1 npm ERR! missing: cidr-regex@3.1.1, required by is-cidr@4.0.2 npm ERR! missing: ip-regex@4.3.0, required by cidr-regex@3.1.1 npm ERR! missing: aproba@2.0.0, required by libnpmaccess@4.0.2 npm ERR! missing: minipass@3.1.3, required by libnpmaccess@4.0.2 npm ERR! missing: npm-package-arg@8.1.2, required by libnpmaccess@4.0.2 npm ERR! missing: npm-registry-fetch@10.1.1, required by libnpmaccess@4.0.2 npm ERR! missing: @npmcli/disparity-colors@1.0.1, required by libnpmdiff@2.0.4 npm ERR! missing: @npmcli/installed-package-contents@1.0.7, required by libnpmdiff@2.0.4 npm ERR! missing: binary-extensions@2.2.0, required by libnpmdiff@2.0.4 npm ERR! missing: diff@5.0.0, required by libnpmdiff@2.0.4 npm ERR! missing: minimatch@3.0.4, required by libnpmdiff@2.0.4 npm ERR! missing: npm-package-arg@8.1.2, required by libnpmdiff@2.0.4 npm ERR! missing: pacote@11.3.3, required by libnpmdiff@2.0.4 npm ERR! missing: tar@6.1.0, required by libnpmdiff@2.0.4 npm ERR! missing: ansi-styles@4.3.0, required by @npmcli/disparity-colors@1.0.1 npm ERR! missing: @npmcli/arborist@2.4.0, required by libnpmexec@1.0.1 npm ERR! missing: @npmcli/ci-detect@1.3.0, required by libnpmexec@1.0.1 npm ERR! missing: @npmcli/run-script@1.8.5, required by libnpmexec@1.0.1 npm ERR! missing: chalk@4.1.1, required by libnpmexec@1.0.1 npm ERR! missing: mkdirp-infer-owner@2.0.0, required by libnpmexec@1.0.1 npm ERR! missing: npm-package-arg@8.1.2, required by libnpmexec@1.0.1 npm ERR! missing: pacote@11.3.3, required by libnpmexec@1.0.1 npm ERR! missing: proc-log@1.0.0, required by libnpmexec@1.0.1 npm ERR! missing: read@1.0.7, required by libnpmexec@1.0.1 npm ERR! missing: read-package-json-fast@2.0.2, required by libnpmexec@1.0.1 npm ERR! missing: @npmcli/arborist@2.4.0, required by libnpmfund@1.0.2 npm ERR! missing: aproba@2.0.0, required by libnpmhook@6.0.2 npm ERR! missing: npm-registry-fetch@10.1.1, required by libnpmhook@6.0.2 npm ERR! missing: aproba@2.0.0, required by libnpmorg@2.0.2 npm ERR! missing: npm-registry-fetch@10.1.1, required by libnpmorg@2.0.2 npm ERR! missing: @npmcli/run-script@1.8.5, required by libnpmpack@2.0.1 npm ERR! missing: npm-package-arg@8.1.2, required by libnpmpack@2.0.1 npm ERR! missing: pacote@11.3.3, required by libnpmpack@2.0.1 npm ERR! missing: normalize-package-data@3.0.2, required by libnpmpublish@4.0.1 npm ERR! missing: npm-package-arg@8.1.2, required by libnpmpublish@4.0.1 npm ERR! missing: npm-registry-fetch@10.1.1, required by libnpmpublish@4.0.1 npm ERR! missing: semver@7.3.5, required by libnpmpublish@4.0.1 npm ERR! missing: ssri@8.0.1, required by libnpmpublish@4.0.1 npm ERR! missing: hosted-git-info@4.0.2, required by normalize-package-data@3.0.2 npm ERR! missing: resolve@1.20.0, required by normalize-package-data@3.0.2 npm ERR! missing: semver@7.3.5, required by normalize-package-data@3.0.2 npm ERR! missing: validate-npm-package-license@3.0.4, required by normalize-package-data@3.0.2 npm ERR! missing: is-core-module@2.2.0, required by resolve@1.20.0 npm ERR! missing: path-parse@1.0.6, required by resolve@1.20.0 npm ERR! missing: has@1.0.3, required by is-core-module@2.2.0 npm ERR! missing: function-bind@1.1.1, required by has@1.0.3 npm ERR! missing: npm-registry-fetch@10.1.1, required by libnpmsearch@3.1.1 npm ERR! missing: aproba@2.0.0, required by libnpmteam@2.0.3 npm ERR! missing: npm-registry-fetch@10.1.1, required by libnpmteam@2.0.3 npm ERR! missing: @npmcli/git@2.0.8, required by libnpmversion@1.2.0 npm ERR! missing: @npmcli/run-script@1.8.5, required by libnpmversion@1.2.0 npm ERR! missing: json-parse-even-better-errors@2.3.1, required by libnpmversion@1.2.0 npm ERR! missing: semver@7.3.5, required by libnpmversion@1.2.0 npm ERR! missing: stringify-package@1.0.1, required by libnpmversion@1.2.0 npm ERR! missing: @npmcli/promise-spawn@1.3.2, required by @npmcli/git@2.0.8 npm ERR! missing: lru-cache@6.0.0, required by @npmcli/git@2.0.8 npm ERR! missing: mkdirp@1.0.4, required by @npmcli/git@2.0.8 npm ERR! missing: npm-pick-manifest@6.1.1, required by @npmcli/git@2.0.8 npm ERR! missing: promise-inflight@1.0.1, required by @npmcli/git@2.0.8 npm ERR! missing: promise-retry@2.0.1, required by @npmcli/git@2.0.8 npm ERR! missing: semver@7.3.5, required by @npmcli/git@2.0.8 npm ERR! missing: which@2.0.2, required by @npmcli/git@2.0.8 npm ERR! missing: agentkeepalive@4.1.4, required by make-fetch-happen@8.0.14 npm ERR! missing: cacache@15.0.6, required by make-fetch-happen@8.0.14 npm ERR! missing: http-cache-semantics@4.1.0, required by make-fetch-happen@8.0.14 npm ERR! missing: http-proxy-agent@4.0.1, required by make-fetch-happen@8.0.14 npm ERR! missing: https-proxy-agent@5.0.0, required by make-fetch-happen@8.0.14 npm ERR! missing: is-lambda@1.0.1, required by make-fetch-happen@8.0.14 npm ERR! missing: lru-cache@6.0.0, required by make-fetch-happen@8.0.14 npm ERR! missing: minipass@3.1.3, required by make-fetch-happen@8.0.14 npm ERR! missing: minipass-collect@1.0.2, required by make-fetch-happen@8.0.14 npm ERR! missing: minipass-fetch@1.3.3, required by make-fetch-happen@8.0.14 npm ERR! missing: minipass-flush@1.0.5, required by make-fetch-happen@8.0.14 npm ERR! missing: minipass-pipeline@1.2.4, required by make-fetch-happen@8.0.14 npm ERR! missing: promise-retry@2.0.1, required by make-fetch-happen@8.0.14 npm ERR! missing: socks-proxy-agent@5.0.0, required by make-fetch-happen@8.0.14 npm ERR! missing: ssri@8.0.1, required by make-fetch-happen@8.0.14 npm ERR! missing: debug@4.3.1, required by agentkeepalive@4.1.4 npm ERR! missing: depd@1.1.2, required by agentkeepalive@4.1.4 npm ERR! missing: humanize-ms@1.2.1, required by agentkeepalive@4.1.4 npm ERR! missing: ms@2.1.2, required by debug@4.3.1 npm ERR! missing: ms@2.1.3, required by humanize-ms@1.2.1 npm ERR! missing: @tootallnate/once@1.1.2, required by http-proxy-agent@4.0.1 npm ERR! missing: agent-base@6.0.2, required by http-proxy-agent@4.0.1 npm ERR! missing: debug@4.3.1, required by http-proxy-agent@4.0.1 npm ERR! missing: debug@4.3.1, required by agent-base@6.0.2 npm ERR! missing: agent-base@6.0.2, required by https-proxy-agent@5.0.0 npm ERR! missing: debug@4.3.1, required by https-proxy-agent@5.0.0 npm ERR! missing: minipass@3.1.3, required by minipass-fetch@1.3.3 npm ERR! missing: minipass-sized@1.0.3, required by minipass-fetch@1.3.3 npm ERR! missing: minizlib@2.1.2, required by minipass-fetch@1.3.3 npm ERR! missing: safer-buffer@2.1.2, required by iconv-lite@0.6.2 npm ERR! missing: minipass@3.1.3, required by minipass-sized@1.0.3 npm ERR! missing: err-code@2.0.3, required by promise-retry@2.0.1 npm ERR! missing: retry@0.12.0, required by promise-retry@2.0.1 npm ERR! missing: agent-base@6.0.2, required by socks-proxy-agent@5.0.0 npm ERR! missing: debug@4.3.1, required by socks-proxy-agent@5.0.0 npm ERR! missing: socks@2.6.1, required by socks-proxy-agent@5.0.0 npm ERR! missing: ip@1.1.5, required by socks@2.6.1 npm ERR! missing: smart-buffer@4.1.0, required by socks@2.6.1 npm ERR! missing: yallist@4.0.0, required by minipass@3.1.3 npm ERR! missing: minipass@3.1.3, required by minipass-pipeline@1.2.4 npm ERR! missing: chownr@2.0.0, required by mkdirp-infer-owner@2.0.0 npm ERR! missing: infer-owner@1.0.4, required by mkdirp-infer-owner@2.0.0 npm ERR! missing: mkdirp@1.0.4, required by mkdirp-infer-owner@2.0.0 npm ERR! missing: env-paths@2.2.1, required by node-gyp@7.1.2 npm ERR! missing: glob@7.1.6, required by node-gyp@7.1.2 npm ERR! missing: graceful-fs@4.2.6, required by node-gyp@7.1.2 npm ERR! missing: nopt@5.0.0, required by node-gyp@7.1.2 npm ERR! missing: npmlog@4.1.2, required by node-gyp@7.1.2 npm ERR! missing: request@2.88.2, required by node-gyp@7.1.2 npm ERR! missing: rimraf@3.0.2, required by node-gyp@7.1.2 npm ERR! missing: semver@7.3.5, required by node-gyp@7.1.2 npm ERR! missing: tar@6.1.0, required by node-gyp@7.1.2 npm ERR! missing: which@2.0.2, required by node-gyp@7.1.2 npm ERR! missing: aws-sign2@0.7.0, required by request@2.88.2 npm ERR! missing: aws4@1.11.0, required by request@2.88.2 npm ERR! missing: caseless@0.12.0, required by request@2.88.2 npm ERR! missing: combined-stream@1.0.8, required by request@2.88.2 npm ERR! missing: extend@3.0.2, required by request@2.88.2 npm ERR! missing: forever-agent@0.6.1, required by request@2.88.2 npm ERR! missing: form-data@2.3.3, required by request@2.88.2 npm ERR! missing: har-validator@5.1.5, required by request@2.88.2 npm ERR! missing: http-signature@1.2.0, required by request@2.88.2 npm ERR! missing: is-typedarray@1.0.0, required by request@2.88.2 npm ERR! missing: isstream@0.1.2, required by request@2.88.2 npm ERR! missing: json-stringify-safe@5.0.1, required by request@2.88.2 npm ERR! missing: mime-types@2.1.30, required by request@2.88.2 npm ERR! missing: oauth-sign@0.9.0, required by request@2.88.2 npm ERR! missing: performance-now@2.1.0, required by request@2.88.2 npm ERR! missing: qs@6.5.2, required by request@2.88.2 npm ERR! missing: tough-cookie@2.5.0, required by request@2.88.2 npm ERR! missing: safe-buffer@5.1.2, required by request@2.88.2 npm ERR! missing: tunnel-agent@0.6.0, required by request@2.88.2 npm ERR! missing: uuid@3.4.0, required by request@2.88.2 npm ERR! missing: delayed-stream@1.0.0, required by combined-stream@1.0.8 npm ERR! missing: asynckit@0.4.0, required by form-data@2.3.3 npm ERR! missing: combined-stream@1.0.8, required by form-data@2.3.3 npm ERR! missing: mime-types@2.1.30, required by form-data@2.3.3 npm ERR! missing: ajv@6.12.6, required by har-validator@5.1.5 npm ERR! missing: har-schema@2.0.0, required by har-validator@5.1.5 npm ERR! missing: fast-deep-equal@3.1.3, required by ajv@6.12.6 npm ERR! missing: fast-json-stable-stringify@2.1.0, required by ajv@6.12.6 npm ERR! missing: json-schema-traverse@0.4.1, required by ajv@6.12.6 npm ERR! missing: uri-js@4.4.1, required by ajv@6.12.6 npm ERR! missing: punycode@2.1.1, required by uri-js@4.4.1 npm ERR! missing: assert-plus@1.0.0, required by http-signature@1.2.0 npm ERR! missing: jsprim@1.4.1, required by http-signature@1.2.0 npm ERR! missing: sshpk@1.16.1, required by http-signature@1.2.0 npm ERR! missing: assert-plus@1.0.0, required by jsprim@1.4.1 npm ERR! missing: extsprintf@1.3.0, required by jsprim@1.4.1 npm ERR! missing: json-schema@0.2.3, required by jsprim@1.4.1 npm ERR! missing: verror@1.10.0, required by jsprim@1.4.1 npm ERR! missing: assert-plus@1.0.0, required by verror@1.10.0 npm ERR! missing: core-util-is@1.0.2, required by verror@1.10.0 npm ERR! missing: extsprintf@1.3.0, required by verror@1.10.0 npm ERR! missing: asn1@0.2.4, required by sshpk@1.16.1 npm ERR! missing: assert-plus@1.0.0, required by sshpk@1.16.1 npm ERR! missing: bcrypt-pbkdf@1.0.2, required by sshpk@1.16.1 npm ERR! missing: dashdash@1.14.1, required by sshpk@1.16.1 npm ERR! missing: ecc-jsbn@0.1.2, required by sshpk@1.16.1 npm ERR! missing: getpass@0.1.7, required by sshpk@1.16.1 npm ERR! missing: jsbn@0.1.1, required by sshpk@1.16.1 npm ERR! missing: safer-buffer@2.1.2, required by sshpk@1.16.1 npm ERR! missing: tweetnacl@0.14.5, required by sshpk@1.16.1 npm ERR! missing: safer-buffer@2.1.2, required by asn1@0.2.4 npm ERR! missing: tweetnacl@0.14.5, required by bcrypt-pbkdf@1.0.2 npm ERR! missing: assert-plus@1.0.0, required by dashdash@1.14.1 npm ERR! missing: jsbn@0.1.1, required by ecc-jsbn@0.1.2 npm ERR! missing: safer-buffer@2.1.2, required by ecc-jsbn@0.1.2 npm ERR! missing: assert-plus@1.0.0, required by getpass@0.1.7 npm ERR! missing: mime-db@1.47.0, required by mime-types@2.1.30 npm ERR! missing: psl@1.8.0, required by tough-cookie@2.5.0 npm ERR! missing: punycode@2.1.1, required by tough-cookie@2.5.0 npm ERR! missing: safe-buffer@5.1.2, required by tunnel-agent@0.6.0 npm ERR! missing: abbrev@1.1.1, required by nopt@5.0.0 npm ERR! missing: chalk@4.1.1, required by npm-audit-report@2.1.4 npm ERR! missing: hosted-git-info@4.0.2, required by npm-package-arg@8.1.2 npm ERR! missing: semver@7.3.5, required by npm-package-arg@8.1.2 npm ERR! missing: validate-npm-package-name@3.0.0, required by npm-package-arg@8.1.2 npm ERR! missing: npm-install-checks@4.0.0, required by npm-pick-manifest@6.1.1 npm ERR! missing: npm-normalize-package-bin@1.0.1, required by npm-pick-manifest@6.1.1 npm ERR! missing: npm-package-arg@8.1.2, required by npm-pick-manifest@6.1.1 npm ERR! missing: semver@7.3.5, required by npm-pick-manifest@6.1.1 npm ERR! missing: npm-registry-fetch@10.1.1, required by npm-profile@5.0.3 npm ERR! missing: lru-cache@6.0.0, required by npm-registry-fetch@10.1.1 npm ERR! missing: make-fetch-happen@8.0.14, required by npm-registry-fetch@10.1.1 npm ERR! missing: minipass@3.1.3, required by npm-registry-fetch@10.1.1 npm ERR! missing: minipass-fetch@1.3.3, required by npm-registry-fetch@10.1.1 npm ERR! missing: minipass-json-stream@1.0.1, required by npm-registry-fetch@10.1.1 npm ERR! missing: minizlib@2.1.2, required by npm-registry-fetch@10.1.1 npm ERR! missing: npm-package-arg@8.1.2, required by npm-registry-fetch@10.1.1 npm ERR! missing: jsonparse@1.3.1, required by minipass-json-stream@1.0.1 npm ERR! missing: minipass@3.1.3, required by minipass-json-stream@1.0.1 npm ERR! missing: minipass@3.1.3, required by minizlib@2.1.2 npm ERR! missing: yallist@4.0.0, required by minizlib@2.1.2 npm ERR! missing: are-we-there-yet@1.1.5, required by npmlog@4.1.2 npm ERR! missing: console-control-strings@1.1.0, required by npmlog@4.1.2 npm ERR! missing: gauge@2.7.4, required by npmlog@4.1.2 npm ERR! missing: set-blocking@2.0.0, required by npmlog@4.1.2 npm ERR! missing: delegates@1.0.0, required by are-we-there-yet@1.1.5 npm ERR! missing: readable-stream@2.3.7, required by are-we-there-yet@1.1.5 npm ERR! missing: core-util-is@1.0.2, required by readable-stream@2.3.7 npm ERR! missing: inherits@2.0.4, required by readable-stream@2.3.7 npm ERR! missing: isarray@1.0.0, required by readable-stream@2.3.7 npm ERR! missing: process-nextick-args@2.0.1, required by readable-stream@2.3.7 npm ERR! missing: safe-buffer@5.1.2, required by readable-stream@2.3.7 npm ERR! missing: string_decoder@1.1.1, required by readable-stream@2.3.7 npm ERR! missing: util-deprecate@1.0.2, required by readable-stream@2.3.7 npm ERR! missing: safe-buffer@5.1.2, required by string_decoder@1.1.1 npm ERR! missing: console-control-strings@1.1.0, required by gauge@2.7.4 npm ERR! missing: aproba@1.2.0, required by gauge@2.7.4 npm ERR! missing: string-width@1.0.2, required by gauge@2.7.4 npm ERR! missing: has-unicode@2.0.1, required by gauge@2.7.4 npm ERR! missing: object-assign@4.1.1, required by gauge@2.7.4 npm ERR! missing: signal-exit@3.0.3, required by gauge@2.7.4 npm ERR! missing: strip-ansi@3.0.1, required by gauge@2.7.4 npm ERR! missing: wide-align@1.1.3, required by gauge@2.7.4 npm ERR! missing: code-point-at@1.1.0, required by string-width@1.0.2 npm ERR! missing: is-fullwidth-code-point@1.0.0, required by string-width@1.0.2 npm ERR! missing: strip-ansi@3.0.1, required by string-width@1.0.2 npm ERR! missing: number-is-nan@1.0.1, required by is-fullwidth-code-point@1.0.0 npm ERR! missing: string-width@2.1.1, required by wide-align@1.1.3 npm ERR! missing: @npmcli/git@2.0.8, required by pacote@11.3.3 npm ERR! missing: @npmcli/installed-package-contents@1.0.7, required by pacote@11.3.3 npm ERR! missing: @npmcli/promise-spawn@1.3.2, required by pacote@11.3.3 npm ERR! missing: @npmcli/run-script@1.8.5, required by pacote@11.3.3 npm ERR! missing: cacache@15.0.6, required by pacote@11.3.3 npm ERR! missing: chownr@2.0.0, required by pacote@11.3.3 npm ERR! missing: fs-minipass@2.1.0, required by pacote@11.3.3 npm ERR! missing: infer-owner@1.0.4, required by pacote@11.3.3 npm ERR! missing: minipass@3.1.3, required by pacote@11.3.3 npm ERR! missing: mkdirp@1.0.4, required by pacote@11.3.3 npm ERR! missing: npm-package-arg@8.1.2, required by pacote@11.3.3 npm ERR! missing: npm-packlist@2.1.5, required by pacote@11.3.3 npm ERR! missing: npm-pick-manifest@6.1.1, required by pacote@11.3.3 npm ERR! missing: npm-registry-fetch@10.1.1, required by pacote@11.3.3 npm ERR! missing: promise-retry@2.0.1, required by pacote@11.3.3 npm ERR! missing: read-package-json-fast@2.0.2, required by pacote@11.3.3 npm ERR! missing: rimraf@3.0.2, required by pacote@11.3.3 npm ERR! missing: ssri@8.0.1, required by pacote@11.3.3 npm ERR! missing: tar@6.1.0, required by pacote@11.3.3 npm ERR! missing: glob@7.1.6, required by npm-packlist@2.1.5 npm ERR! missing: ignore-walk@3.0.3, required by npm-packlist@2.1.5 npm ERR! missing: npm-bundled@1.1.2, required by npm-packlist@2.1.5 npm ERR! missing: npm-normalize-package-bin@1.0.1, required by npm-packlist@2.1.5 npm ERR! missing: minimatch@3.0.4, required by ignore-walk@3.0.3 npm ERR! missing: json-parse-even-better-errors@2.3.1, required by parse-conflict-json@1.1.1 npm ERR! missing: just-diff@3.1.1, required by parse-conflict-json@1.1.1 npm ERR! missing: just-diff-apply@3.0.0, required by parse-conflict-json@1.1.1 npm ERR! missing: mute-stream@0.0.8, required by read@1.0.7 npm ERR! missing: glob@7.1.6, required by read-package-json@3.0.1 npm ERR! missing: json-parse-even-better-errors@2.3.1, required by read-package-json@3.0.1 npm ERR! missing: normalize-package-data@3.0.2, required by read-package-json@3.0.1 npm ERR! missing: npm-normalize-package-bin@1.0.1, required by read-package-json@3.0.1 npm ERR! missing: json-parse-even-better-errors@2.3.1, required by read-package-json-fast@2.0.2 npm ERR! missing: npm-normalize-package-bin@1.0.1, required by read-package-json-fast@2.0.2 npm ERR! missing: debuglog@1.0.1, required by readdir-scoped-modules@1.1.0 npm ERR! missing: dezalgo@1.0.3, required by readdir-scoped-modules@1.1.0 npm ERR! missing: graceful-fs@4.2.6, required by readdir-scoped-modules@1.1.0 npm ERR! missing: once@1.4.0, required by readdir-scoped-modules@1.1.0 npm ERR! missing: asap@2.0.6, required by dezalgo@1.0.3 npm ERR! missing: wrappy@1.0.2, required by dezalgo@1.0.3 npm ERR! missing: glob@7.1.6, required by rimraf@3.0.2 npm ERR! missing: lru-cache@6.0.0, required by semver@7.3.5 npm ERR! missing: minipass@3.1.3, required by ssri@8.0.1 npm ERR! missing: chownr@2.0.0, required by tar@6.1.0 npm ERR! missing: fs-minipass@2.1.0, required by tar@6.1.0 npm ERR! missing: minipass@3.1.3, required by tar@6.1.0 npm ERR! missing: minizlib@2.1.2, required by tar@6.1.0 npm ERR! missing: mkdirp@1.0.4, required by tar@6.1.0 npm ERR! missing: yallist@4.0.0, required by tar@6.1.0 npm ERR! missing: builtins@1.0.3, required by validate-npm-package-name@3.0.0 npm ERR! missing: isexe@2.0.0, required by which@2.0.2 npm ERR! missing: imurmurhash@0.1.4, required by write-file-atomic@3.0.3 npm ERR! missing: is-typedarray@1.0.0, required by write-file-atomic@3.0.3 npm ERR! missing: signal-exit@3.0.3, required by write-file-atomic@3.0.3 npm ERR! missing: typedarray-to-buffer@3.1.5, required by write-file-atomic@3.0.3 npm ERR! missing: is-typedarray@1.0.0, required by typedarray-to-buffer@3.1.5 npm ERR! missing: cron-parser@2.15.0, required by node-schedule@1.3.2 npm ERR! peer dep missing: typescript@3.9.x || 4.0.x || 4.1.x, required by typedoc@0.20.28 npm ERR! extraneous: @babel/cli@7.13.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/cli npm ERR! extraneous: @babel/preset-env@7.13.9 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/preset-env npm ERR! extraneous: @babel/preset-typescript@7.13.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/preset-typescript npm ERR! extraneous: @types/debounce@1.2.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/debounce npm ERR! extraneous: @types/debug@4.1.5 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/debug npm ERR! extraneous: @types/jest@26.0.20 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/jest npm ERR! extraneous: @types/mz@2.7.3 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/mz npm ERR! extraneous: @types/nedb@1.8.11 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/nedb npm ERR! extraneous: @types/serialport@8.0.1 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/serialport npm ERR! extraneous: @typescript-eslint/eslint-plugin@4.16.1 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/eslint-plugin npm ERR! extraneous: @typescript-eslint/parser@4.16.1 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/parser npm ERR! extraneous: eslint@7.21.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/eslint npm ERR! extraneous: jest@26.6.3 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/jest npm ERR! extraneous: typedoc@0.20.28 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc npm ERR! extraneous: typedoc-plugin-markdown@3.6.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-markdown npm ERR! extraneous: typedoc-plugin-no-inherit@1.2.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-no-inherit npm ERR! extraneous: typedoc-plugin-sourcefile-url@1.0.6 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-sourcefile-url npm ERR! extraneous: eslint@7.27.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint npm ERR! extraneous: eslint-config-google@0.14.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint-config-google npm ERR! extraneous: eslint-plugin-jest@24.3.6 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint-plugin-jest npm ERR! extraneous: jest@26.6.3 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/jest npm ERR! peer dep missing: typescript@3.9.x || 4.0.x || 4.1.x, required by typedoc@0.20.28 npm ERR! extraneous: @babel/cli@7.13.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/cli npm ERR! extraneous: @babel/preset-env@7.13.9 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/preset-env npm ERR! extraneous: @babel/preset-typescript@7.13.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/preset-typescript npm ERR! extraneous: @types/debounce@1.2.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/debounce npm ERR! extraneous: @types/debug@4.1.5 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/debug npm ERR! extraneous: @types/jest@26.0.20 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/jest npm ERR! extraneous: @types/mz@2.7.3 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/mz npm ERR! extraneous: @types/nedb@1.8.11 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/nedb npm ERR! extraneous: @types/serialport@8.0.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/serialport npm ERR! extraneous: @typescript-eslint/eslint-plugin@4.16.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/eslint-plugin npm ERR! extraneous: @typescript-eslint/parser@4.16.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/parser npm ERR! extraneous: eslint@7.21.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/eslint npm ERR! extraneous: jest@26.6.3 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/jest npm ERR! extraneous: typedoc@0.20.28 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc npm ERR! extraneous: typedoc-plugin-markdown@3.6.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-markdown npm ERR! extraneous: typedoc-plugin-no-inherit@1.2.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-no-inherit npm ERR! extraneous: typedoc-plugin-sourcefile-url@1.0.6 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-sourcefile-url@sanda sagte in Fehler in Adapterinstallation:
npm uninstall iobroker.sourceanalytixSiehste, hier kommt noch der Kram von npm@7 mit:
required by npm@7.11.1Ich wäre ja fast geneigt, hier mal entgegen der sonstigen Empfehlung wirklich wieder npm@7 wieder zu installieren, damit die ganzen Depencies wieder bedient werden.
@thomas-braun sagte in Fehler in Adapterinstallation:
oder ganz einfach
@homoran sagte in Fehler in Adapterinstallation:
/opt/iobroker/package-lock.json löschen
Hier die Ausgabe, passt nicht mal ins Terminal
Hast du eigentlich in den Einstellungen des javascript-Adapters noch zusätzliche Module reingeflickt?
Wenn ja, welche? -
Wenn ja, welche?@thomas-braun Jetzt wird es etwas sauberer nach sourceanalytics Deinstallation:
pi@raspberrypi4-iob:/opt/iobroker $ npm ls iobroker.core@1.0.0 /opt/iobroker ├── iobroker@2.0.3 extraneous ├── iobroker.admin@5.1.25 extraneous ├── iobroker.backitup@2.2.2 extraneous ├── iobroker.discovery@2.7.3 extraneous ├── iobroker.dwd@2.7.7 extraneous ├── iobroker.fb-checkpresence@1.1.10 extraneous ├── iobroker.followthesun@0.3.5 extraneous ├── iobroker.growatt@1.1.1 extraneous ├── iobroker.gruenbeck@0.0.30 extraneous ├── iobroker.hm-rega@3.0.32 extraneous ├── iobroker.hm-rpc@1.14.45 extraneous ├── iobroker.homekit-controller@0.3.3 extraneous ├── iobroker.ical@1.11.4 extraneous ├── iobroker.icons-mfd-png@1.0.2 extraneous ├── iobroker.icons-ultimate-png@1.0.1 extraneous ├── iobroker.influxdb@1.9.5 extraneous ├── iobroker.info@1.9.8 extraneous ├── iobroker.javascript@5.2.13 extraneous ├── iobroker.js-controller@3.3.20 extraneous ├── iobroker.mihome-vacuum@3.3.1 extraneous ├── iobroker.mpd@1.0.6 extraneous ├── iobroker.odl@1.1.4 extraneous ├── iobroker.onvif@0.4.4 extraneous ├── iobroker.plenticore@2.2.0 extraneous ├── iobroker.samsung@0.2.9 extraneous ├── iobroker.schoolfree@1.0.0 extraneous ├── iobroker.shelly@4.0.7 extraneous ├── iobroker.synology@1.1.3 extraneous ├── iobroker.tankerkoenig@2.1.1 extraneous ├── iobroker.telegram@1.10.0 extraneous ├── iobroker.trashschedule@1.2.0 extraneous ├── iobroker.tuya@3.6.9 extraneous ├── iobroker.vis@1.4.5 extraneous ├── iobroker.vis-colorpicker@1.2.0 extraneous ├── iobroker.vis-hqwidgets@1.1.7 extraneous ├── iobroker.vis-inventwo@3.2.0 extraneous ├── iobroker.vis-jqui-mfd@1.0.12 extraneous ├── iobroker.vis-metro@1.1.2 extraneous ├── iobroker.vis-timeandweather@1.1.7 extraneous ├── iobroker.vis-weather@2.5.5 extraneous ├── iobroker.web@3.4.9 extraneous └── iobroker.zigbee@1.5.6 extraneous npm ERR! extraneous: iobroker@2.0.3 /opt/iobroker/node_modules/iobroker npm ERR! extraneous: iobroker.admin@5.1.25 /opt/iobroker/node_modules/iobroker.admin npm ERR! extraneous: iobroker.backitup@2.2.2 /opt/iobroker/node_modules/iobroker.backitup npm ERR! extraneous: iobroker.discovery@2.7.3 /opt/iobroker/node_modules/iobroker.discovery npm ERR! extraneous: iobroker.dwd@2.7.7 /opt/iobroker/node_modules/iobroker.dwd npm ERR! extraneous: iobroker.fb-checkpresence@1.1.10 /opt/iobroker/node_modules/iobroker.fb-checkpresence npm ERR! extraneous: iobroker.followthesun@0.3.5 /opt/iobroker/node_modules/iobroker.followthesun npm ERR! extraneous: iobroker.growatt@1.1.1 /opt/iobroker/node_modules/iobroker.growatt npm ERR! extraneous: iobroker.gruenbeck@0.0.30 /opt/iobroker/node_modules/iobroker.gruenbeck npm ERR! extraneous: iobroker.hm-rega@3.0.32 /opt/iobroker/node_modules/iobroker.hm-rega npm ERR! extraneous: iobroker.hm-rpc@1.14.45 /opt/iobroker/node_modules/iobroker.hm-rpc npm ERR! extraneous: iobroker.homekit-controller@0.3.3 /opt/iobroker/node_modules/iobroker.homekit-controller npm ERR! extraneous: iobroker.ical@1.11.4 /opt/iobroker/node_modules/iobroker.ical npm ERR! extraneous: iobroker.icons-mfd-png@1.0.2 /opt/iobroker/node_modules/iobroker.icons-mfd-png npm ERR! extraneous: iobroker.icons-ultimate-png@1.0.1 /opt/iobroker/node_modules/iobroker.icons-ultimate-png npm ERR! extraneous: iobroker.influxdb@1.9.5 /opt/iobroker/node_modules/iobroker.influxdb npm ERR! extraneous: iobroker.info@1.9.8 /opt/iobroker/node_modules/iobroker.info npm ERR! extraneous: iobroker.javascript@5.2.13 /opt/iobroker/node_modules/iobroker.javascript npm ERR! extraneous: iobroker.js-controller@3.3.20 /opt/iobroker/node_modules/iobroker.js-controller npm ERR! extraneous: iobroker.mihome-vacuum@3.3.1 /opt/iobroker/node_modules/iobroker.mihome-vacuum npm ERR! extraneous: iobroker.mpd@1.0.6 /opt/iobroker/node_modules/iobroker.mpd npm ERR! extraneous: iobroker.odl@1.1.4 /opt/iobroker/node_modules/iobroker.odl npm ERR! extraneous: iobroker.onvif@0.4.4 /opt/iobroker/node_modules/iobroker.onvif npm ERR! extraneous: iobroker.plenticore@2.2.0 /opt/iobroker/node_modules/iobroker.plenticore npm ERR! extraneous: iobroker.samsung@0.2.9 /opt/iobroker/node_modules/iobroker.samsung npm ERR! extraneous: iobroker.schoolfree@1.0.0 /opt/iobroker/node_modules/iobroker.schoolfree npm ERR! extraneous: iobroker.shelly@4.0.7 /opt/iobroker/node_modules/iobroker.shelly npm ERR! extraneous: iobroker.synology@1.1.3 /opt/iobroker/node_modules/iobroker.synology npm ERR! extraneous: iobroker.tankerkoenig@2.1.1 /opt/iobroker/node_modules/iobroker.tankerkoenig npm ERR! extraneous: iobroker.telegram@1.10.0 /opt/iobroker/node_modules/iobroker.telegram npm ERR! extraneous: iobroker.trashschedule@1.2.0 /opt/iobroker/node_modules/iobroker.trashschedule npm ERR! extraneous: iobroker.tuya@3.6.9 /opt/iobroker/node_modules/iobroker.tuya npm ERR! extraneous: iobroker.vis@1.4.5 /opt/iobroker/node_modules/iobroker.vis npm ERR! extraneous: iobroker.vis-colorpicker@1.2.0 /opt/iobroker/node_modules/iobroker.vis-colorpicker npm ERR! extraneous: iobroker.vis-hqwidgets@1.1.7 /opt/iobroker/node_modules/iobroker.vis-hqwidgets npm ERR! extraneous: iobroker.vis-inventwo@3.2.0 /opt/iobroker/node_modules/iobroker.vis-inventwo npm ERR! extraneous: iobroker.vis-jqui-mfd@1.0.12 /opt/iobroker/node_modules/iobroker.vis-jqui-mfd npm ERR! extraneous: iobroker.vis-metro@1.1.2 /opt/iobroker/node_modules/iobroker.vis-metro npm ERR! extraneous: iobroker.vis-timeandweather@1.1.7 /opt/iobroker/node_modules/iobroker.vis-timeandweather npm ERR! extraneous: iobroker.vis-weather@2.5.5 /opt/iobroker/node_modules/iobroker.vis-weather npm ERR! extraneous: iobroker.web@3.4.9 /opt/iobroker/node_modules/iobroker.web npm ERR! extraneous: iobroker.zigbee@1.5.6 /opt/iobroker/node_modules/iobroker.zigbee -
oder ganz einfach
Wenn ja, welche?@thomas-braun Nein ich nutze keine zusätzlichen Module im javascript
pi@raspberrypi4-iob:/opt/iobroker $ npm ls iobroker.core@1.0.0 /opt/iobroker ├── iobroker@2.0.3 extraneous ├── iobroker.admin@5.1.25 extraneous ├── iobroker.backitup@2.2.2 extraneous ├── iobroker.discovery@2.7.3 extraneous ├── iobroker.dwd@2.7.7 extraneous ├── iobroker.fb-checkpresence@1.1.10 extraneous ├── iobroker.followthesun@0.3.5 extraneous ├── iobroker.growatt@1.1.1 extraneous ├── iobroker.gruenbeck@0.0.30 extraneous ├── iobroker.hm-rega@3.0.32 extraneous ├── iobroker.hm-rpc@1.14.45 extraneous ├── iobroker.homekit-controller@0.3.3 extraneous ├── iobroker.ical@1.11.4 extraneous ├── iobroker.icons-mfd-png@1.0.2 extraneous ├── iobroker.icons-ultimate-png@1.0.1 extraneous ├── iobroker.influxdb@1.9.5 extraneous ├── iobroker.info@1.9.8 extraneous ├── iobroker.javascript@5.2.13 extraneous ├── iobroker.js-controller@3.3.20 extraneous ├── iobroker.mihome-vacuum@3.3.1 extraneous ├── iobroker.mpd@1.0.6 extraneous ├── iobroker.odl@1.1.4 extraneous ├── iobroker.onvif@0.4.4 extraneous ├── iobroker.plenticore@2.2.0 extraneous ├── iobroker.samsung@0.2.9 extraneous ├── iobroker.schoolfree@1.0.0 extraneous ├── iobroker.shelly@4.0.7 extraneous ├── iobroker.synology@1.1.3 extraneous ├── iobroker.tankerkoenig@2.1.1 extraneous ├── iobroker.telegram@1.10.0 extraneous ├── iobroker.trashschedule@1.2.0 extraneous ├── iobroker.tuya@3.6.9 extraneous ├── iobroker.vis@1.4.5 extraneous ├── iobroker.vis-colorpicker@1.2.0 extraneous ├── iobroker.vis-hqwidgets@1.1.7 extraneous ├── iobroker.vis-inventwo@3.2.0 extraneous ├── iobroker.vis-jqui-mfd@1.0.12 extraneous ├── iobroker.vis-metro@1.1.2 extraneous ├── iobroker.vis-timeandweather@1.1.7 extraneous ├── iobroker.vis-weather@2.5.5 extraneous ├── iobroker.web@3.4.9 extraneous └── iobroker.zigbee@1.5.6 extraneous npm ERR! extraneous: iobroker@2.0.3 /opt/iobroker/node_modules/iobroker npm ERR! extraneous: iobroker.admin@5.1.25 /opt/iobroker/node_modules/iobroker.admin npm ERR! extraneous: iobroker.backitup@2.2.2 /opt/iobroker/node_modules/iobroker.backitup npm ERR! extraneous: iobroker.discovery@2.7.3 /opt/iobroker/node_modules/iobroker.discovery npm ERR! extraneous: iobroker.dwd@2.7.7 /opt/iobroker/node_modules/iobroker.dwd npm ERR! extraneous: iobroker.fb-checkpresence@1.1.10 /opt/iobroker/node_modules/iobroker.fb-checkpresence npm ERR! extraneous: iobroker.followthesun@0.3.5 /opt/iobroker/node_modules/iobroker.followthesun npm ERR! extraneous: iobroker.growatt@1.1.1 /opt/iobroker/node_modules/iobroker.growatt npm ERR! extraneous: iobroker.gruenbeck@0.0.30 /opt/iobroker/node_modules/iobroker.gruenbeck npm ERR! extraneous: iobroker.hm-rega@3.0.32 /opt/iobroker/node_modules/iobroker.hm-rega npm ERR! extraneous: iobroker.hm-rpc@1.14.45 /opt/iobroker/node_modules/iobroker.hm-rpc npm ERR! extraneous: iobroker.homekit-controller@0.3.3 /opt/iobroker/node_modules/iobroker.homekit-controller npm ERR! extraneous: iobroker.ical@1.11.4 /opt/iobroker/node_modules/iobroker.ical npm ERR! extraneous: iobroker.icons-mfd-png@1.0.2 /opt/iobroker/node_modules/iobroker.icons-mfd-png npm ERR! extraneous: iobroker.icons-ultimate-png@1.0.1 /opt/iobroker/node_modules/iobroker.icons-ultimate-png npm ERR! extraneous: iobroker.influxdb@1.9.5 /opt/iobroker/node_modules/iobroker.influxdb npm ERR! extraneous: iobroker.info@1.9.8 /opt/iobroker/node_modules/iobroker.info npm ERR! extraneous: iobroker.javascript@5.2.13 /opt/iobroker/node_modules/iobroker.javascript npm ERR! extraneous: iobroker.js-controller@3.3.20 /opt/iobroker/node_modules/iobroker.js-controller npm ERR! extraneous: iobroker.mihome-vacuum@3.3.1 /opt/iobroker/node_modules/iobroker.mihome-vacuum npm ERR! extraneous: iobroker.mpd@1.0.6 /opt/iobroker/node_modules/iobroker.mpd npm ERR! extraneous: iobroker.odl@1.1.4 /opt/iobroker/node_modules/iobroker.odl npm ERR! extraneous: iobroker.onvif@0.4.4 /opt/iobroker/node_modules/iobroker.onvif npm ERR! extraneous: iobroker.plenticore@2.2.0 /opt/iobroker/node_modules/iobroker.plenticore npm ERR! extraneous: iobroker.samsung@0.2.9 /opt/iobroker/node_modules/iobroker.samsung npm ERR! extraneous: iobroker.schoolfree@1.0.0 /opt/iobroker/node_modules/iobroker.schoolfree npm ERR! extraneous: iobroker.shelly@4.0.7 /opt/iobroker/node_modules/iobroker.shelly npm ERR! extraneous: iobroker.synology@1.1.3 /opt/iobroker/node_modules/iobroker.synology npm ERR! extraneous: iobroker.tankerkoenig@2.1.1 /opt/iobroker/node_modules/iobroker.tankerkoenig npm ERR! extraneous: iobroker.telegram@1.10.0 /opt/iobroker/node_modules/iobroker.telegram npm ERR! extraneous: iobroker.trashschedule@1.2.0 /opt/iobroker/node_modules/iobroker.trashschedule npm ERR! extraneous: iobroker.tuya@3.6.9 /opt/iobroker/node_modules/iobroker.tuya npm ERR! extraneous: iobroker.vis@1.4.5 /opt/iobroker/node_modules/iobroker.vis npm ERR! extraneous: iobroker.vis-colorpicker@1.2.0 /opt/iobroker/node_modules/iobroker.vis-colorpicker npm ERR! extraneous: iobroker.vis-hqwidgets@1.1.7 /opt/iobroker/node_modules/iobroker.vis-hqwidgets npm ERR! extraneous: iobroker.vis-inventwo@3.2.0 /opt/iobroker/node_modules/iobroker.vis-inventwo npm ERR! extraneous: iobroker.vis-jqui-mfd@1.0.12 /opt/iobroker/node_modules/iobroker.vis-jqui-mfd npm ERR! extraneous: iobroker.vis-metro@1.1.2 /opt/iobroker/node_modules/iobroker.vis-metro npm ERR! extraneous: iobroker.vis-timeandweather@1.1.7 /opt/iobroker/node_modules/iobroker.vis-timeandweather npm ERR! extraneous: iobroker.vis-weather@2.5.5 /opt/iobroker/node_modules/iobroker.vis-weather npm ERR! extraneous: iobroker.web@3.4.9 /opt/iobroker/node_modules/iobroker.web npm ERR! extraneous: iobroker.zigbee@1.5.6 /opt/iobroker/node_modules/iobroker.zigbeeOkay, das sieht schon wesentlich anders aus.
Die Urinstallation ist aber auch schon etwas her, oder?
iobroker.core@1.0.0 /opt/iobroker ├── iobroker@2.0.3 extraneousschaut ungewohnt aus. Die ganzen extraneous Einträge sind auch ungewöhnlich. Kann es sein, das da zwei Installationen ineinander verschachtelt wurden?
Mal z. B.
npm list iobroker.icons-mfd-pnganschauen.
Mal z. B.
@thomas-braun said in Fehler in Adapterinstallation:
Das spuckt er mir aus und ja die Installation von IOB ist schon etwas her:
pi@raspberrypi4-iob:/opt/iobroker $ npm list iobroker.icons-mfd-png iobroker.core@1.0.0 /opt/iobroker └── iobroker.icons-mfd-png@1.0.2 extraneous npm ERR! extraneous: iobroker.icons-mfd-png@1.0.2 /opt/iobroker/node_modules/iobroker.icons-mfd-png -
pi@raspberrypi4-iob:/opt/iobroker $ npm list iobroker.icons-mfd-png iobroker.core@1.0.0 /opt/iobroker └── iobroker.icons-mfd-png@1.0.2 extraneous npm ERR! extraneous: iobroker.icons-mfd-png@1.0.2 /opt/iobroker/node_modules/iobroker.icons-mfd-png@sanda
Was mich irritiert ist, dass bei dir extraneous Module angezeigt werden, offenbar aber ohne das erste Modul.
Bei mir schaut das z. B. so aus:echad@chet:/opt/iobroker $ npm ls jsonata iobroker.inst@3.0.0 /opt/iobroker ├─┬ iobroker.javascript@5.2.16 │ └── jsonata@1.8.5 └── jsonata@1.8.5 extraneousIch hab aber offengesagt keine Ahnung was ich dir da empfehlen soll. Mal über eine Neuinstallation nachgedacht?
@sanda
@thomas-braun Alles neu zu installieren, da brauch ich ja wieder eine Woche, bis alles wieder läuft
Ich habe jetzt js-controller Komplett neu installiert und jetzt nochmals das Kommando ausgeführt, was zuvor schon zu Error-Meldungen geführt hatte, aber jetzt nicht mehr.
pi@raspberrypi4-iob:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller > iobroker.js-controller@3.3.21 preinstall /opt/iobroker/node_modules/iobroker.js-controller > node lib/preinstallCheck.js NPM version: 6.14.15 > iobroker.js-controller@3.3.21 install /opt/iobroker/node_modules/iobroker.js-controller > node iobroker.js setup first object _design/custom updated object _design/system updated The following notifications happened during sync: - Ignoring Directory "hm-rega" because officially not created as meta object. Please remove directory! - Ignoring Directory "synology.0" because officially not created as meta object. Please remove directory! - Ignoring Directory "synology.1" because officially not created as meta object. Please remove directory! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}) npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/common@>= 5.0.0 but none is installed. You must install peer dependencies yourself. npm WARN xmlhttprequest-ts@1.0.1 requires a peer of @angular/core@>= 5.0.0 but none is installed. You must install peer dependencies yourself. npm WARN typedoc@0.20.28 requires a peer of typescript@3.9.x || 4.0.x || 4.1.x but none is installed. You must install peer dependencies yourself. npm WARN typedoc@0.20.28 requires a peer of typescript@3.9.x || 4.0.x || 4.1.x but none is installed. You must install peer dependencies yourself. + iobroker.js-controller@3.3.21 removed 75 packages and updated 1 package in 65.018s 167 packages are looking for funding run `npm fund` for details -
Anscheinend hab ich es nun hinbekommen. Die Lösung war, das ich anschließend den admin neu installiert habe
Danke euch vielmals
@thomas-braun da stehen immer noch einige Error-Punkte, aber alles läuft ohne Probleme und neue Adapter lassen sich nun auch installieren.
│ │ │ ├─┬ get-symbol-description@1.0.0 │ │ │ │ ├── call-bind@1.0.2 deduped │ │ │ │ └── get-intrinsic@1.1.1 deduped │ │ │ ├── has@1.0.3 deduped │ │ │ ├── has-symbols@1.0.2 │ │ │ ├─┬ internal-slot@1.0.3 │ │ │ │ ├── get-intrinsic@1.1.1 deduped │ │ │ │ ├── has@1.0.3 deduped │ │ │ │ └── side-channel@1.0.4 deduped │ │ │ ├── is-callable@1.2.4 │ │ │ ├── is-negative-zero@2.0.1 │ │ │ ├─┬ is-regex@1.1.4 │ │ │ │ ├── call-bind@1.0.2 deduped │ │ │ │ └─┬ has-tostringtag@1.0.0 │ │ │ │ └── has-symbols@1.0.2 deduped │ │ │ ├── is-shared-array-buffer@1.0.1 │ │ │ ├─┬ is-string@1.0.7 │ │ │ │ └── has-tostringtag@1.0.0 deduped │ │ │ ├─┬ is-weakref@1.0.1 │ │ │ │ └── call-bind@1.0.2 deduped │ │ │ ├── object-inspect@1.11.0 │ │ │ ├── object-keys@1.1.1 deduped │ │ │ ├─┬ object.assign@4.1.2 │ │ │ │ ├── call-bind@1.0.2 deduped │ │ │ │ ├── define-properties@1.1.3 deduped │ │ │ │ ├── has-symbols@1.0.2 deduped │ │ │ │ └── object-keys@1.1.1 deduped │ │ │ ├─┬ string.prototype.trimend@1.0.4 │ │ │ │ ├── call-bind@1.0.2 deduped │ │ │ │ └── define-properties@1.1.3 deduped │ │ │ ├─┬ string.prototype.trimstart@1.0.4 │ │ │ │ ├── call-bind@1.0.2 deduped │ │ │ │ └── define-properties@1.1.3 deduped │ │ │ └─┬ unbox-primitive@1.0.1 │ │ │ ├── function-bind@1.1.1 deduped │ │ │ ├── has-bigints@1.0.1 │ │ │ ├── has-symbols@1.0.2 deduped │ │ │ └─┬ which-boxed-primitive@1.0.2 │ │ │ ├─┬ is-bigint@1.0.4 │ │ │ │ └── has-bigints@1.0.1 deduped │ │ │ ├─┬ is-boolean-object@1.1.2 │ │ │ │ ├── call-bind@1.0.2 deduped │ │ │ │ └── has-tostringtag@1.0.0 deduped │ │ │ ├─┬ is-number-object@1.0.6 │ │ │ │ └── has-tostringtag@1.0.0 deduped │ │ │ ├── is-string@1.0.7 deduped │ │ │ └── is-symbol@1.0.4 deduped │ │ ├─┬ bl@1.2.3 │ │ │ ├── readable-stream@2.3.7 deduped │ │ │ └── safe-buffer@5.2.1 deduped │ │ ├── bluebird@3.7.2 deduped │ │ ├── debug@3.2.7 deduped │ │ ├── depd@1.1.2 deduped │ │ ├── eventemitter3@3.1.2 │ │ ├── file-type@3.9.0 │ │ ├── mime@1.6.0 │ │ ├─┬ pump@2.0.1 │ │ │ ├── end-of-stream@1.4.4 deduped │ │ │ └── once@1.4.0 deduped │ │ ├── request@2.88.2 deduped │ │ └─┬ request-promise@4.2.6 │ │ ├── bluebird@3.7.2 deduped │ │ ├─┬ request-promise-core@1.1.4 │ │ │ └── lodash@4.17.21 deduped │ │ ├── stealthy-require@1.1.1 │ │ └── tough-cookie@2.5.0 deduped │ └─┬ socksv5@0.0.6 │ └─┬ ipv6@3.1.1 │ ├─┬ cli@0.4.5 │ │ └── glob@7.2.0 deduped │ ├─┬ cliff@0.1.10 │ │ ├── colors@1.0.3 │ │ ├── eyes@0.1.8 deduped │ │ └─┬ winston@0.8.3 │ │ ├── async@0.2.10 │ │ ├── colors@0.6.2 │ │ ├── cycle@1.0.3 deduped │ │ ├── eyes@0.1.8 deduped │ │ ├── isstream@0.1.2 deduped │ │ ├── pkginfo@0.3.1 │ │ └── stack-trace@0.0.10 deduped │ └── sprintf@0.1.3 ├─┬ iobroker.trashschedule@1.2.0 │ └── @iobroker/adapter-core@2.5.1 deduped ├─┬ iobroker.vis@1.4.5 │ ├── @iobroker/adapter-core@2.5.1 deduped │ └── jsonwebtoken@8.5.1 deduped ├─┬ iobroker.vis-colorpicker@1.2.0 │ └── @iobroker/adapter-core@2.5.1 deduped ├── iobroker.vis-hqwidgets@1.1.7 ├─┬ iobroker.vis-inventwo@3.2.0 │ ├── @iobroker/adapter-core@2.5.1 deduped │ ├── minimist@1.2.5 │ └─┬ np@7.6.0 │ ├─┬ @samverschueren/stream-to-observable@0.3.1 │ │ └── any-observable@0.3.0 │ ├── any-observable@0.5.1 │ ├── async-exit-hook@2.0.1 │ ├─┬ chalk@4.1.2 │ │ ├─┬ ansi-styles@4.3.0 │ │ │ └─┬ color-convert@2.0.1 │ │ │ └── color-name@1.1.4 │ │ └─┬ supports-color@7.2.0 │ │ └── has-flag@4.0.0 │ ├─┬ cosmiconfig@7.0.1 │ │ ├── @types/parse-json@4.0.0 │ │ ├─┬ import-fresh@3.3.0 │ │ │ ├─┬ parent-module@1.0.1 │ │ │ │ └── callsites@3.1.0 deduped │ │ │ └── resolve-from@4.0.0 │ │ ├─┬ parse-json@5.2.0 │ │ │ ├─┬ @babel/code-frame@7.16.0 │ │ │ │ └─┬ @babel/highlight@7.16.0 │ │ │ │ ├── @babel/helper-validator-identifier@7.15.7 │ │ │ │ ├─┬ chalk@2.4.2 │ │ │ │ │ ├─┬ ansi-styles@3.2.1 │ │ │ │ │ │ └── color-convert@1.9.3 deduped │ │ │ │ │ ├── escape-string-regexp@1.0.5 │ │ │ │ │ └─┬ supports-color@5.5.0 │ │ │ │ │ └── has-flag@3.0.0 │ │ │ │ └── js-tokens@4.0.0 │ │ │ ├─┬ error-ex@1.3.2 │ │ │ │ └── is-arrayish@0.2.1 │ │ │ ├── json-parse-even-better-errors@2.3.1 │ │ │ └── lines-and-columns@1.2.4 │ │ ├── path-type@4.0.0 │ │ └── yaml@1.10.2 │ ├─┬ del@6.0.0 │ │ ├─┬ globby@11.0.4 │ │ │ ├── array-union@2.1.0 │ │ │ ├─┬ dir-glob@3.0.1 │ │ │ │ └── path-type@4.0.0 deduped │ │ │ ├─┬ fast-glob@3.2.7 │ │ │ │ ├── @nodelib/fs.stat@2.0.5 │ │ │ │ ├─┬ @nodelib/fs.walk@1.2.8 │ │ │ │ │ ├─┬ @nodelib/fs.scandir@2.1.5 │ │ │ │ │ │ ├── @nodelib/fs.stat@2.0.5 deduped │ │ │ │ │ │ └─┬ run-parallel@1.2.0 │ │ │ │ │ │ └── queue-microtask@1.2.3 │ │ │ │ │ └─┬ fastq@1.13.0 │ │ │ │ │ └── reusify@1.0.4 │ │ │ │ ├── glob-parent@5.1.2 deduped │ │ │ │ ├── merge2@1.4.1 deduped │ │ │ │ └─┬ micromatch@4.0.4 │ │ │ │ ├── braces@3.0.2 deduped │ │ │ │ └── picomatch@2.3.0 deduped │ │ │ ├── ignore@5.1.9 │ │ │ ├── merge2@1.4.1 │ │ │ └── slash@3.0.0 deduped │ │ ├── graceful-fs@4.2.8 deduped │ │ ├── is-glob@4.0.3 deduped │ │ ├── is-path-cwd@2.2.0 │ │ ├── is-path-inside@3.0.3 │ │ ├─┬ p-map@4.0.0 │ │ │ └─┬ aggregate-error@3.1.0 │ │ │ ├── clean-stack@2.2.0 │ │ │ └── indent-string@4.0.0 deduped │ │ ├── rimraf@3.0.2 deduped │ │ └── slash@3.0.0 │ ├── escape-goat@3.0.0 │ ├── escape-string-regexp@4.0.0 │ ├─┬ execa@5.1.1 │ │ ├─┬ cross-spawn@7.0.3 │ │ │ ├── path-key@3.1.1 │ │ │ ├─┬ shebang-command@2.0.0 │ │ │ │ └── shebang-regex@3.0.0 │ │ │ └─┬ which@2.0.2 │ │ │ └── isexe@2.0.0 │ │ ├── get-stream@6.0.1 │ │ ├── human-signals@2.1.0 │ │ ├── is-stream@2.0.1 deduped │ │ ├── merge-stream@2.0.0 │ │ ├─┬ npm-run-path@4.0.1 │ │ │ └── path-key@3.1.1 deduped │ │ ├── onetime@5.1.2 deduped │ │ ├── signal-exit@3.0.6 │ │ └── strip-final-newline@2.0.0 │ ├── github-url-from-git@1.5.0 │ ├── has-yarn@2.1.0 │ ├─┬ hosted-git-info@3.0.8 │ │ └── lru-cache@6.0.0 deduped │ ├─┬ ignore-walk@3.0.4 │ │ └── minimatch@3.0.4 deduped │ ├─┬ import-local@3.0.3 │ │ ├─┬ pkg-dir@4.2.0 │ │ │ └── find-up@4.1.0 deduped │ │ └─┬ resolve-cwd@3.0.0 │ │ └── resolve-from@5.0.0 │ ├─┬ inquirer@7.3.3 │ │ ├─┬ ansi-escapes@4.3.2 │ │ │ └── type-fest@0.21.3 │ │ ├── chalk@4.1.2 deduped │ │ ├─┬ cli-cursor@3.1.0 │ │ │ └─┬ restore-cursor@3.1.0 │ │ │ ├── onetime@5.1.2 deduped │ │ │ └── signal-exit@3.0.6 deduped │ │ ├── cli-width@3.0.0 │ │ ├─┬ external-editor@3.1.0 │ │ │ ├── chardet@0.7.0 │ │ │ ├─┬ iconv-lite@0.4.24 │ │ │ │ └── safer-buffer@2.1.2 deduped │ │ │ └─┬ tmp@0.0.33 │ │ │ └── os-tmpdir@1.0.2 │ │ ├─┬ figures@3.2.0 │ │ │ └── escape-string-regexp@1.0.5 │ │ ├── lodash@4.17.21 deduped │ │ ├── mute-stream@0.0.8 deduped │ │ ├── run-async@2.4.1 │ │ ├── rxjs@6.6.7 deduped │ │ ├── string-width@4.2.3 deduped │ │ ├── strip-ansi@6.0.1 deduped │ │ └── through@2.3.8 deduped │ ├─┬ is-installed-globally@0.3.2 │ │ ├─┬ global-dirs@2.1.0 │ │ │ └── ini@1.3.7 │ │ └── is-path-inside@3.0.3 deduped │ ├── is-interactive@1.0.0 │ ├─┬ is-scoped@2.1.0 │ │ └── scoped-regex@2.1.0 │ ├── issue-regex@3.1.0 │ ├─┬ listr@0.14.3 │ │ ├── @samverschueren/stream-to-observable@0.3.1 deduped │ │ ├─┬ is-observable@1.1.0 │ │ │ └── symbol-observable@1.2.0 │ │ ├── is-promise@2.2.2 │ │ ├── is-stream@1.1.0 │ │ ├── listr-silent-renderer@1.1.1 │ │ ├─┬ listr-update-renderer@0.5.0 │ │ │ ├─┬ chalk@1.1.3 │ │ │ │ ├── ansi-styles@2.2.1 │ │ │ │ ├── escape-string-regexp@1.0.5 │ │ │ │ ├─┬ has-ansi@2.0.0 │ │ │ │ │ └── ansi-regex@2.1.1 │ │ │ │ ├── strip-ansi@3.0.1 deduped │ │ │ │ └── supports-color@2.0.0 │ │ │ ├─┬ cli-truncate@0.2.1 │ │ │ │ ├── slice-ansi@0.0.4 │ │ │ │ └─┬ string-width@1.0.2 │ │ │ │ ├── code-point-at@1.1.0 deduped │ │ │ │ ├─┬ is-fullwidth-code-point@1.0.0 │ │ │ │ │ └── number-is-nan@1.0.1 deduped │ │ │ │ └─┬ strip-ansi@3.0.1 │ │ │ │ └── ansi-regex@2.1.1 │ │ │ ├── elegant-spinner@1.0.1 │ │ │ ├─┬ figures@1.7.0 │ │ │ │ ├── escape-string-regexp@1.0.5 deduped │ │ │ │ └── object-assign@4.1.1 │ │ │ ├── indent-string@3.2.0 │ │ │ ├─┬ log-symbols@1.0.2 │ │ │ │ └── chalk@1.1.3 deduped │ │ │ ├─┬ log-update@2.3.0 │ │ │ │ ├── ansi-escapes@3.2.0 │ │ │ │ ├─┬ cli-cursor@2.1.0 │ │ │ │ │ └─┬ restore-cursor@2.0.0 │ │ │ │ │ ├─┬ onetime@2.0.1 │ │ │ │ │ │ └── mimic-fn@1.2.0 │ │ │ │ │ └── signal-exit@3.0.6 deduped │ │ │ │ └─┬ wrap-ansi@3.0.1 │ │ │ │ ├─┬ string-width@2.1.1 │ │ │ │ │ ├── is-fullwidth-code-point@2.0.0 │ │ │ │ │ └── strip-ansi@4.0.0 deduped │ │ │ │ └─┬ strip-ansi@4.0.0 │ │ │ │ └── ansi-regex@3.0.0 │ │ │ └─┬ strip-ansi@3.0.1 │ │ │ └── ansi-regex@2.1.1 │ │ ├─┬ listr-verbose-renderer@0.5.0 │ │ │ ├─┬ chalk@2.4.2 │ │ │ │ ├─┬ ansi-styles@3.2.1 │ │ │ │ │ └── color-convert@1.9.3 deduped │ │ │ │ ├── escape-string-regexp@1.0.5 │ │ │ │ └─┬ supports-color@5.5.0 │ │ │ │ └── has-flag@3.0.0 │ │ │ ├─┬ cli-cursor@2.1.0 │ │ │ │ └─┬ restore-cursor@2.0.0 │ │ │ │ ├─┬ onetime@2.0.1 │ │ │ │ │ └── mimic-fn@1.2.0 │ │ │ │ └── signal-exit@3.0.6 deduped │ │ │ ├── date-fns@1.30.1 │ │ │ └─┬ figures@2.0.0 │ │ │ └── escape-string-regexp@1.0.5 deduped │ │ ├── p-map@2.1.0 │ │ └── rxjs@6.6.7 deduped │ ├─┬ listr-input@0.2.1 │ │ ├── inquirer@7.3.3 deduped │ │ ├─┬ inquirer-autosubmit-prompt@0.2.0 │ │ │ ├─┬ chalk@2.4.2 │ │ │ │ ├─┬ ansi-styles@3.2.1 │ │ │ │ │ └── color-convert@1.9.3 deduped │ │ │ │ ├── escape-string-regexp@1.0.5 │ │ │ │ └─┬ supports-color@5.5.0 │ │ │ │ └── has-flag@3.0.0 │ │ │ ├─┬ inquirer@6.5.2 │ │ │ │ ├── ansi-escapes@3.2.0 │ │ │ │ ├── chalk@2.4.2 deduped │ │ │ │ ├─┬ cli-cursor@2.1.0 │ │ │ │ │ └─┬ restore-cursor@2.0.0 │ │ │ │ │ ├─┬ onetime@2.0.1 │ │ │ │ │ │ └── mimic-fn@1.2.0 │ │ │ │ │ └── signal-exit@3.0.6 deduped │ │ │ │ ├── cli-width@2.2.1 │ │ │ │ ├── external-editor@3.1.0 deduped │ │ │ │ ├─┬ figures@2.0.0 │ │ │ │ │ └── escape-string-regexp@1.0.5 deduped │ │ │ │ ├── lodash@4.17.21 deduped │ │ │ │ ├── mute-stream@0.0.7 │ │ │ │ ├── run-async@2.4.1 deduped │ │ │ │ ├── rxjs@6.6.7 deduped │ │ │ │ ├─┬ string-width@2.1.1 │ │ │ │ │ ├── is-fullwidth-code-point@2.0.0 │ │ │ │ │ └─┬ strip-ansi@4.0.0 │ │ │ │ │ └── ansi-regex@3.0.0 │ │ │ │ ├─┬ strip-ansi@5.2.0 │ │ │ │ │ └── ansi-regex@4.1.0 │ │ │ │ └── through@2.3.8 deduped │ │ │ └── rxjs@6.6.7 deduped │ │ ├── rxjs@6.6.7 deduped │ │ └── through@2.3.8 deduped │ ├─┬ log-symbols@4.1.0 │ │ ├── chalk@4.1.2 deduped │ │ └── is-unicode-supported@0.1.0 │ ├─┬ meow@8.1.2 │ │ ├── @types/minimist@1.2.2 │ │ ├─┬ camelcase-keys@6.2.2 │ │ │ ├── camelcase@5.3.1 │ │ │ ├── map-obj@4.3.0 │ │ │ └── quick-lru@4.0.1 │ │ ├─┬ decamelize-keys@1.1.0 │ │ │ ├── decamelize@1.2.0 deduped │ │ │ └── map-obj@1.0.1 │ │ ├── hard-rejection@2.1.0 │ │ ├─┬ minimist-options@4.1.0 │ │ │ ├── arrify@1.0.1 │ │ │ ├── is-plain-obj@1.1.0 │ │ │ └── kind-of@6.0.3 │ │ ├─┬ normalize-package-data@3.0.3 │ │ │ ├─┬ hosted-git-info@4.0.2 │ │ │ │ └── lru-cache@6.0.0 deduped │ │ │ ├─┬ is-core-module@2.8.0 │ │ │ │ └── has@1.0.3 deduped │ │ │ ├── semver@7.3.5 deduped │ │ │ └─┬ validate-npm-package-license@3.0.4 │ │ │ ├─┬ spdx-correct@3.1.1 │ │ │ │ ├── spdx-expression-parse@3.0.1 deduped │ │ │ │ └── spdx-license-ids@3.0.11 │ │ │ └─┬ spdx-expression-parse@3.0.1 │ │ │ ├── spdx-exceptions@2.3.0 │ │ │ └── spdx-license-ids@3.0.11 deduped │ │ ├── read-pkg-up@7.0.1 deduped │ │ ├─┬ redent@3.0.0 │ │ │ ├── indent-string@4.0.0 │ │ │ └─┬ strip-indent@3.0.0 │ │ │ └── min-indent@1.0.1 │ │ ├── trim-newlines@3.0.1 │ │ ├── type-fest@0.18.1 │ │ └── yargs-parser@20.2.9 deduped │ ├── minimatch@3.0.4 deduped │ ├─┬ new-github-release-url@1.0.0 │ │ └── type-fest@0.4.1 │ ├─┬ npm-name@6.0.1 │ │ ├─┬ got@10.7.0 │ │ │ ├── @sindresorhus/is@2.1.1 │ │ │ ├─┬ @szmarczak/http-timer@4.0.6 │ │ │ │ └── defer-to-connect@2.0.1 │ │ │ ├─┬ @types/cacheable-request@6.0.2 │ │ │ │ ├── @types/http-cache-semantics@4.0.1 │ │ │ │ ├─┬ @types/keyv@3.1.3 │ │ │ │ │ └── @types/node@16.11.11 deduped │ │ │ │ ├── @types/node@16.11.11 deduped │ │ │ │ └─┬ @types/responselike@1.0.0 │ │ │ │ └── @types/node@16.11.11 deduped │ │ │ ├─┬ cacheable-lookup@2.0.1 │ │ │ │ ├── @types/keyv@3.1.3 deduped │ │ │ │ └─┬ keyv@4.0.4 │ │ │ │ └── json-buffer@3.0.1 │ │ │ ├─┬ cacheable-request@7.0.2 │ │ │ │ ├─┬ clone-response@1.0.2 │ │ │ │ │ └── mimic-response@1.0.1 │ │ │ │ ├─┬ get-stream@5.2.0 │ │ │ │ │ └─┬ pump@3.0.0 │ │ │ │ │ ├── end-of-stream@1.4.4 deduped │ │ │ │ │ └── once@1.4.0 deduped │ │ │ │ ├── http-cache-semantics@4.1.0 │ │ │ │ ├── keyv@4.0.4 deduped │ │ │ │ ├── lowercase-keys@2.0.0 deduped │ │ │ │ ├── normalize-url@6.1.0 │ │ │ │ └── responselike@2.0.0 deduped │ │ │ ├─┬ decompress-response@5.0.0 │ │ │ │ └── mimic-response@2.1.0 deduped │ │ │ ├── duplexer3@0.1.4 │ │ │ ├─┬ get-stream@5.2.0 │ │ │ │ └─┬ pump@3.0.0 │ │ │ │ ├── end-of-stream@1.4.4 deduped │ │ │ │ └── once@1.4.0 deduped │ │ │ ├── lowercase-keys@2.0.0 │ │ │ ├── mimic-response@2.1.0 deduped │ │ │ ├── p-cancelable@2.1.1 │ │ │ ├─┬ p-event@4.2.0 │ │ │ │ └─┬ p-timeout@3.2.0 │ │ │ │ └── p-finally@1.0.0 │ │ │ ├─┬ responselike@2.0.0 │ │ │ │ └── lowercase-keys@2.0.0 deduped │ │ │ ├── to-readable-stream@2.1.0 │ │ │ └── type-fest@0.10.0 │ │ ├── is-scoped@2.1.0 deduped │ │ ├── is-url-superb@4.0.0 │ │ ├── lodash.zip@4.2.0 │ │ ├── org-regex@1.0.0 │ │ ├─┬ p-map@3.0.0 │ │ │ └── aggregate-error@3.1.0 deduped │ │ ├─┬ registry-auth-token@4.2.1 │ │ │ └── rc@1.2.8 deduped │ │ ├─┬ registry-url@5.1.0 │ │ │ └── rc@1.2.8 deduped │ │ └─┬ validate-npm-package-name@3.0.0 │ │ └── builtins@1.0.3 │ ├─┬ onetime@5.1.2 │ │ └── mimic-fn@2.1.0 │ ├─┬ open@7.4.2 │ │ ├── is-docker@2.2.1 │ │ └─┬ is-wsl@2.2.0 │ │ └── is-docker@2.2.1 deduped │ ├─┬ ow@0.21.0 │ │ ├── @sindresorhus/is@4.2.0 │ │ ├── callsites@3.1.0 │ │ ├─┬ dot-prop@6.0.1 │ │ │ └── is-obj@2.0.0 │ │ ├── lodash.isequal@4.5.0 │ │ ├── type-fest@0.20.2 │ │ └── vali-date@1.0.0 │ ├─┬ p-memoize@4.0.3 │ │ ├─┬ map-age-cleaner@0.1.3 │ │ │ └── p-defer@1.0.0 │ │ ├── mimic-fn@3.1.0 │ │ └─┬ p-settle@4.1.1 │ │ ├─┬ p-limit@2.3.0 │ │ │ └── p-try@2.2.0 │ │ └── p-reflect@2.1.0 │ ├── p-timeout@4.1.0 │ ├─┬ pkg-dir@5.0.0 │ │ └─┬ find-up@5.0.0 │ │ ├─┬ locate-path@6.0.0 │ │ │ └─┬ p-locate@5.0.0 │ │ │ └─┬ p-limit@3.1.0 │ │ │ └── yocto-queue@0.1.0 │ │ └── path-exists@4.0.0 │ ├─┬ read-pkg-up@7.0.1 │ │ ├─┬ find-up@4.1.0 │ │ │ ├─┬ locate-path@5.0.0 │ │ │ │ └─┬ p-locate@4.1.0 │ │ │ │ └── p-limit@2.3.0 deduped │ │ │ └── path-exists@4.0.0 deduped │ │ ├─┬ read-pkg@5.2.0 │ │ │ ├── @types/normalize-package-data@2.4.1 │ │ │ ├─┬ normalize-package-data@2.5.0 │ │ │ │ ├── hosted-git-info@2.8.9 │ │ │ │ ├─┬ resolve@1.20.0 │ │ │ │ │ ├── is-core-module@2.8.0 deduped │ │ │ │ │ └── path-parse@1.0.7 │ │ │ │ ├── semver@5.7.1 │ │ │ │ └── validate-npm-package-license@3.0.4 deduped │ │ │ ├── parse-json@5.2.0 deduped │ │ │ └── type-fest@0.6.0 │ │ └── type-fest@0.8.1 │ ├─┬ rxjs@6.6.7 │ │ └── tslib@1.14.1 deduped │ ├── semver@7.3.5 deduped │ ├── split@1.0.1 deduped │ ├── symbol-observable@3.0.0 │ ├─┬ terminal-link@2.1.1 │ │ ├── ansi-escapes@4.3.2 deduped │ │ └─┬ supports-hyperlinks@2.2.0 │ │ ├── has-flag@4.0.0 deduped │ │ └── supports-color@7.2.0 deduped │ └─┬ update-notifier@5.1.0 │ ├─┬ boxen@5.1.2 │ │ ├─┬ ansi-align@3.0.1 │ │ │ └── string-width@4.2.3 deduped │ │ ├── camelcase@6.2.1 │ │ ├── chalk@4.1.2 deduped │ │ ├── cli-boxes@2.2.1 │ │ ├── string-width@4.2.3 deduped │ │ ├── type-fest@0.20.2 │ │ ├─┬ widest-line@3.1.0 │ │ │ └── string-width@4.2.3 deduped │ │ └─┬ wrap-ansi@7.0.0 │ │ ├── ansi-styles@4.3.0 deduped │ │ ├── string-width@4.2.3 deduped │ │ └── strip-ansi@6.0.1 deduped │ ├── chalk@4.1.2 deduped │ ├─┬ configstore@5.0.1 │ │ ├─┬ dot-prop@5.3.0 │ │ │ └── is-obj@2.0.0 deduped │ │ ├── graceful-fs@4.2.8 deduped │ │ ├── make-dir@3.1.0 deduped │ │ ├─┬ unique-string@2.0.0 │ │ │ └── crypto-random-string@2.0.0 │ │ ├─┬ write-file-atomic@3.0.3 │ │ │ ├── imurmurhash@0.1.4 │ │ │ ├── is-typedarray@1.0.0 deduped │ │ │ ├── signal-exit@3.0.6 deduped │ │ │ └─┬ typedarray-to-buffer@3.1.5 │ │ │ └── is-typedarray@1.0.0 deduped │ │ └── xdg-basedir@4.0.0 deduped │ ├── has-yarn@2.1.0 deduped │ ├── import-lazy@2.1.0 │ ├─┬ is-ci@2.0.0 │ │ └── ci-info@2.0.0 │ ├─┬ is-installed-globally@0.4.0 │ │ ├─┬ global-dirs@3.0.0 │ │ │ └── ini@2.0.0 │ │ └── is-path-inside@3.0.3 deduped │ ├── is-npm@5.0.0 │ ├── is-yarn-global@0.3.0 │ ├─┬ latest-version@5.1.0 │ │ └─┬ package-json@6.5.0 │ │ ├─┬ got@9.6.0 │ │ │ ├── @sindresorhus/is@0.14.0 │ │ │ ├─┬ @szmarczak/http-timer@1.1.2 │ │ │ │ └── defer-to-connect@1.1.3 │ │ │ ├─┬ cacheable-request@6.1.0 │ │ │ │ ├── clone-response@1.0.2 deduped │ │ │ │ ├─┬ get-stream@5.2.0 │ │ │ │ │ └── pump@3.0.0 deduped │ │ │ │ ├── http-cache-semantics@4.1.0 deduped │ │ │ │ ├─┬ keyv@3.1.0 │ │ │ │ │ └── json-buffer@3.0.0 │ │ │ │ ├── lowercase-keys@2.0.0 │ │ │ │ ├── normalize-url@4.5.1 │ │ │ │ └─┬ responselike@1.0.2 │ │ │ │ └── lowercase-keys@1.0.1 deduped │ │ │ ├─┬ decompress-response@3.3.0 │ │ │ │ └── mimic-response@1.0.1 deduped │ │ │ ├── duplexer3@0.1.4 deduped │ │ │ ├─┬ get-stream@4.1.0 │ │ │ │ └─┬ pump@3.0.0 │ │ │ │ ├── end-of-stream@1.4.4 deduped │ │ │ │ └── once@1.4.0 deduped │ │ │ ├── lowercase-keys@1.0.1 │ │ │ ├── mimic-response@1.0.1 │ │ │ ├── p-cancelable@1.1.0 │ │ │ ├── to-readable-stream@1.0.0 │ │ │ └─┬ url-parse-lax@3.0.0 │ │ │ └── prepend-http@2.0.0 │ │ ├── registry-auth-token@4.2.1 deduped │ │ ├── registry-url@5.1.0 deduped │ │ └── semver@6.3.0 │ ├─┬ pupa@2.1.1 │ │ └── escape-goat@2.1.1 │ ├── semver@7.3.5 deduped │ ├─┬ semver-diff@3.1.1 │ │ └── semver@6.3.0 │ └── xdg-basedir@4.0.0 ├── iobroker.vis-metro@1.1.2 ├── iobroker.vis-weather@2.5.5 ├─┬ iobroker.web@3.4.9 │ ├── @iobroker/adapter-core@2.5.1 deduped │ ├── body-parser@1.19.0 deduped │ ├── connect-flash@0.1.1 deduped │ ├── cookie-parser@1.4.6 deduped │ ├── express@4.17.1 deduped │ ├── express-session@1.17.2 deduped │ ├─┬ iobroker.simple-api@2.6.2 │ │ └── @iobroker/adapter-core@2.5.1 deduped │ ├─┬ iobroker.socketio@3.1.5 │ │ ├── @iobroker/adapter-core@2.5.1 deduped │ │ ├─┬ axios@0.23.0 │ │ │ └── follow-redirects@1.14.5 deduped │ │ ├── cookie-parser@1.4.6 deduped │ │ ├── express-session@1.17.2 deduped │ │ └─┬ socket.io@2.4.1 │ │ ├─┬ debug@4.1.1 │ │ │ └── ms@2.1.3 deduped │ │ ├─┬ engine.io@3.5.0 │ │ │ ├── accepts@1.3.7 deduped │ │ │ ├── base64id@2.0.0 │ │ │ ├── cookie@0.4.1 │ │ │ ├─┬ debug@4.1.1 │ │ │ │ └── ms@2.1.3 deduped │ │ │ ├── engine.io-parser@2.2.1 deduped │ │ │ └── ws@7.4.6 │ │ ├── has-binary2@1.0.3 deduped │ │ ├── socket.io-adapter@1.1.2 │ │ ├── socket.io-client@2.4.0 deduped │ │ └─┬ socket.io-parser@3.4.1 │ │ ├── component-emitter@1.2.1 │ │ ├─┬ debug@4.1.1 │ │ │ └── ms@2.1.3 deduped │ │ └── isarray@2.0.1 │ ├─┬ mime-types@2.1.34 │ │ └── mime-db@1.51.0 │ ├─┬ passport@0.4.1 │ │ ├── passport-strategy@1.0.0 deduped │ │ └── pause@0.0.1 deduped │ ├── passport-local@1.0.0 deduped │ ├── passport.socketio@3.7.0 deduped │ ├── request@2.88.2 deduped │ ├─┬ socket.io-client@2.4.0 │ │ ├── backo2@1.0.2 │ │ ├── component-bind@1.0.0 │ │ ├── component-emitter@1.3.0 │ │ ├─┬ debug@3.1.0 │ │ │ └── ms@2.0.0 │ │ ├─┬ engine.io-client@3.5.2 │ │ │ ├── component-emitter@1.3.0 deduped │ │ │ ├── component-inherit@0.0.3 │ │ │ ├─┬ debug@3.1.0 │ │ │ │ └── ms@2.0.0 │ │ │ ├─┬ engine.io-parser@2.2.1 │ │ │ │ ├── after@0.8.2 │ │ │ │ ├── arraybuffer.slice@0.0.7 │ │ │ │ ├── base64-arraybuffer@0.1.4 │ │ │ │ ├── blob@0.0.5 │ │ │ │ └── has-binary2@1.0.3 deduped │ │ │ ├── has-cors@1.1.0 │ │ │ ├── indexof@0.0.1 deduped │ │ │ ├── parseqs@0.0.6 deduped │ │ │ ├── parseuri@0.0.6 deduped │ │ │ ├── ws@7.4.6 │ │ │ ├── xmlhttprequest-ssl@1.6.3 │ │ │ └── yeast@0.1.2 │ │ ├─┬ has-binary2@1.0.3 │ │ │ └── isarray@2.0.1 │ │ ├── indexof@0.0.1 │ │ ├── parseqs@0.0.6 │ │ ├── parseuri@0.0.6 │ │ ├─┬ socket.io-parser@3.3.2 │ │ │ ├── component-emitter@1.3.0 deduped │ │ │ ├── debug@3.1.0 deduped │ │ │ └── isarray@2.0.1 │ │ └── to-array@0.1.4 │ └── xtend@4.0.2 └─┬ iobroker.zigbee@1.5.6 ├── @iobroker/adapter-core@2.5.1 deduped ├── tar@6.1.11 deduped ├── typescript@4.5.2 deduped ├─┬ zigbee-herdsman@0.13.110 │ ├── @babel/cli@7.13.0 extraneous │ ├── @babel/preset-env@7.13.9 extraneous │ ├── @babel/preset-typescript@7.13.0 extraneous │ ├─┬ @serialport/bindings@9.0.4 │ │ ├─┬ @serialport/binding-abstract@9.0.7 │ │ │ └── debug@4.3.1 deduped │ │ ├─┬ @serialport/parser-readline@9.0.7 │ │ │ └── @serialport/parser-delimiter@9.0.7 deduped │ │ ├─┬ bindings@1.5.0 │ │ │ └── file-uri-to-path@1.0.0 │ │ ├── debug@4.3.1 deduped │ │ ├── nan@2.14.2 │ │ └─┬ prebuild-install@6.0.1 │ │ ├── detect-libc@1.0.3 │ │ ├── expand-template@2.0.3 │ │ ├── github-from-package@0.0.0 │ │ ├── minimist@1.2.5 │ │ ├── mkdirp-classic@0.5.3 │ │ ├── napi-build-utils@1.0.2 │ │ ├─┬ node-abi@2.20.0 │ │ │ └── semver@5.7.1 │ │ ├── noop-logger@0.1.1 │ │ ├─┬ npmlog@4.1.2 │ │ │ ├─┬ are-we-there-yet@1.1.5 │ │ │ │ ├── delegates@1.0.0 │ │ │ │ └─┬ readable-stream@2.3.7 │ │ │ │ ├── core-util-is@1.0.2 │ │ │ │ ├── inherits@2.0.4 deduped │ │ │ │ ├── isarray@1.0.0 │ │ │ │ ├── process-nextick-args@2.0.1 │ │ │ │ ├── safe-buffer@5.1.2 deduped │ │ │ │ ├─┬ string_decoder@1.1.1 │ │ │ │ │ └── safe-buffer@5.1.2 deduped │ │ │ │ └── util-deprecate@1.0.2 │ │ │ ├── console-control-strings@1.1.0 │ │ │ ├─┬ gauge@2.7.4 │ │ │ │ ├── aproba@1.2.0 │ │ │ │ ├── console-control-strings@1.1.0 deduped │ │ │ │ ├── has-unicode@2.0.1 │ │ │ │ ├── object-assign@4.1.1 deduped │ │ │ │ ├── signal-exit@3.0.3 │ │ │ │ ├─┬ string-width@1.0.2 │ │ │ │ │ ├── code-point-at@1.1.0 │ │ │ │ │ ├─┬ is-fullwidth-code-point@1.0.0 │ │ │ │ │ │ └── number-is-nan@1.0.1 │ │ │ │ │ └── strip-ansi@3.0.1 deduped │ │ │ │ ├─┬ strip-ansi@3.0.1 │ │ │ │ │ └── ansi-regex@2.1.1 │ │ │ │ └─┬ wide-align@1.1.3 │ │ │ │ └── string-width@1.0.2 deduped │ │ │ └── set-blocking@2.0.0 │ │ ├─┬ pump@3.0.0 │ │ │ ├─┬ end-of-stream@1.4.4 │ │ │ │ └── once@1.4.0 deduped │ │ │ └─┬ once@1.4.0 │ │ │ └── wrappy@1.0.2 │ │ ├─┬ rc@1.2.8 │ │ │ ├── deep-extend@0.6.0 │ │ │ ├── ini@1.3.8 │ │ │ ├── minimist@1.2.5 deduped │ │ │ └── strip-json-comments@2.0.1 │ │ ├─┬ simple-get@3.1.0 │ │ │ ├─┬ decompress-response@4.2.1 │ │ │ │ └── mimic-response@2.1.0 │ │ │ ├── once@1.4.0 deduped │ │ │ └── simple-concat@1.0.1 │ │ ├─┬ tar-fs@2.1.1 │ │ │ ├── chownr@1.1.4 │ │ │ ├── mkdirp-classic@0.5.3 deduped │ │ │ ├── pump@3.0.0 deduped │ │ │ └─┬ tar-stream@2.2.0 │ │ │ ├─┬ bl@4.1.0 │ │ │ │ ├─┬ buffer@5.7.1 │ │ │ │ │ ├── base64-js@1.5.1 │ │ │ │ │ └── ieee754@1.2.1 │ │ │ │ ├── inherits@2.0.4 deduped │ │ │ │ └─┬ readable-stream@3.6.0 │ │ │ │ ├── inherits@2.0.4 deduped │ │ │ │ ├── string_decoder@1.1.1 deduped │ │ │ │ └── util-deprecate@1.0.2 deduped │ │ │ ├── end-of-stream@1.4.4 deduped │ │ │ ├── fs-constants@1.0.0 │ │ │ ├── inherits@2.0.4 │ │ │ └─┬ readable-stream@3.6.0 │ │ │ ├── inherits@2.0.4 deduped │ │ │ ├── string_decoder@1.1.1 deduped │ │ │ └── util-deprecate@1.0.2 deduped │ │ ├─┬ tunnel-agent@0.6.0 │ │ │ └── safe-buffer@5.1.2 │ │ └── which-pm-runs@1.0.0 │ ├── @types/debounce@1.2.0 extraneous │ ├── @types/debug@4.1.5 extraneous │ ├── @types/jest@26.0.20 extraneous │ ├── @types/mz@2.7.3 extraneous │ ├── @types/nedb@1.8.11 extraneous │ ├── @types/serialport@8.0.1 extraneous │ ├── @typescript-eslint/eslint-plugin@4.16.1 extraneous │ ├── @typescript-eslint/parser@4.16.1 extraneous │ ├── debounce@1.2.0 │ ├─┬ debug@4.3.1 │ │ └── ms@2.1.2 │ ├── eslint@7.21.0 extraneous │ ├── fast-deep-equal@3.1.3 │ ├── jest@26.6.3 extraneous │ ├── mixin-deep@2.0.1 │ ├─┬ mz@2.7.0 │ │ ├── any-promise@1.3.0 │ │ ├── object-assign@4.1.1 │ │ └─┬ thenify-all@1.6.0 │ │ └─┬ thenify@3.3.1 │ │ └── any-promise@1.3.0 deduped │ ├─┬ serialport@9.0.6 │ │ ├─┬ @serialport/binding-mock@9.0.7 │ │ │ ├── @serialport/binding-abstract@9.0.7 deduped │ │ │ └── debug@4.3.1 deduped │ │ ├── @serialport/bindings@9.0.4 deduped │ │ ├── @serialport/parser-byte-length@9.0.7 │ │ ├── @serialport/parser-cctalk@9.0.7 │ │ ├── @serialport/parser-delimiter@9.0.7 │ │ ├── @serialport/parser-inter-byte-timeout@9.0.7 │ │ ├── @serialport/parser-readline@9.0.7 deduped │ │ ├── @serialport/parser-ready@9.0.7 │ │ ├── @serialport/parser-regex@9.0.7 │ │ ├─┬ @serialport/stream@9.0.7 │ │ │ └── debug@4.3.1 deduped │ │ └── debug@4.3.1 deduped │ ├── slip@1.0.2 │ ├── typedoc@0.20.28 extraneous │ ├── typedoc-plugin-markdown@3.6.0 extraneous │ ├── typedoc-plugin-no-inherit@1.2.0 extraneous │ ├── typedoc-plugin-sourcefile-url@1.0.6 extraneous │ └── UNMET PEER DEPENDENCY typescript@4.2.2 extraneous └─┬ zigbee-herdsman-converters@14.0.162 ├─┬ axios@0.21.1 │ └── follow-redirects@1.14.1 ├── buffer-crc32@0.2.13 ├── eslint@7.27.0 extraneous ├── eslint-config-google@0.14.0 extraneous ├── eslint-plugin-jest@24.3.6 extraneous ├─┬ https-proxy-agent@5.0.0 │ ├─┬ agent-base@6.0.2 │ │ └── debug@4.3.1 deduped │ └─┬ debug@4.3.1 │ └── ms@2.1.2 ├── jest@26.6.3 extraneous ├─┬ tar-stream@2.2.0 │ ├─┬ bl@4.1.0 │ │ ├─┬ buffer@5.7.1 │ │ │ ├── base64-js@1.5.1 │ │ │ └── ieee754@1.2.1 │ │ ├── inherits@2.0.4 deduped │ │ └── readable-stream@3.6.0 deduped │ ├─┬ end-of-stream@1.4.4 │ │ └─┬ once@1.4.0 │ │ └── wrappy@1.0.2 │ ├── fs-constants@1.0.0 │ ├── inherits@2.0.4 │ └─┬ readable-stream@3.6.0 │ ├── inherits@2.0.4 deduped │ ├─┬ string_decoder@1.3.0 │ │ └── safe-buffer@5.2.1 │ └── util-deprecate@1.0.2 └─┬ zigbee-herdsman@0.13.107 ├── @babel/cli@7.13.0 extraneous ├── @babel/preset-env@7.13.9 extraneous ├── @babel/preset-typescript@7.13.0 extraneous ├─┬ @serialport/bindings@9.0.4 │ ├─┬ @serialport/binding-abstract@9.0.7 │ │ └── debug@4.3.1 deduped │ ├─┬ @serialport/parser-readline@9.0.7 │ │ └── @serialport/parser-delimiter@9.0.7 deduped │ ├─┬ bindings@1.5.0 │ │ └── file-uri-to-path@1.0.0 │ ├── debug@4.3.1 deduped │ ├── nan@2.14.2 │ └─┬ prebuild-install@6.0.1 │ ├── detect-libc@1.0.3 │ ├── expand-template@2.0.3 │ ├── github-from-package@0.0.0 │ ├── minimist@1.2.5 │ ├── mkdirp-classic@0.5.3 │ ├── napi-build-utils@1.0.2 │ ├─┬ node-abi@2.20.0 │ │ └── semver@5.7.1 │ ├── noop-logger@0.1.1 │ ├─┬ npmlog@4.1.2 │ │ ├─┬ are-we-there-yet@1.1.5 │ │ │ ├── delegates@1.0.0 │ │ │ └─┬ readable-stream@2.3.7 │ │ │ ├── core-util-is@1.0.2 │ │ │ ├── inherits@2.0.4 deduped │ │ │ ├── isarray@1.0.0 │ │ │ ├── process-nextick-args@2.0.1 │ │ │ ├── safe-buffer@5.1.2 deduped │ │ │ ├─┬ string_decoder@1.1.1 │ │ │ │ └── safe-buffer@5.1.2 deduped │ │ │ └── util-deprecate@1.0.2 │ │ ├── console-control-strings@1.1.0 │ │ ├─┬ gauge@2.7.4 │ │ │ ├── aproba@1.2.0 │ │ │ ├── console-control-strings@1.1.0 deduped │ │ │ ├── has-unicode@2.0.1 │ │ │ ├── object-assign@4.1.1 deduped │ │ │ ├── signal-exit@3.0.3 │ │ │ ├─┬ string-width@1.0.2 │ │ │ │ ├── code-point-at@1.1.0 │ │ │ │ ├─┬ is-fullwidth-code-point@1.0.0 │ │ │ │ │ └── number-is-nan@1.0.1 │ │ │ │ └── strip-ansi@3.0.1 deduped │ │ │ ├─┬ strip-ansi@3.0.1 │ │ │ │ └── ansi-regex@2.1.1 │ │ │ └─┬ wide-align@1.1.3 │ │ │ └── string-width@1.0.2 deduped │ │ └── set-blocking@2.0.0 │ ├─┬ pump@3.0.0 │ │ ├─┬ end-of-stream@1.4.4 │ │ │ └── once@1.4.0 deduped │ │ └─┬ once@1.4.0 │ │ └── wrappy@1.0.2 │ ├─┬ rc@1.2.8 │ │ ├── deep-extend@0.6.0 │ │ ├── ini@1.3.8 │ │ ├── minimist@1.2.5 deduped │ │ └── strip-json-comments@2.0.1 │ ├─┬ simple-get@3.1.0 │ │ ├─┬ decompress-response@4.2.1 │ │ │ └── mimic-response@2.1.0 │ │ ├── once@1.4.0 deduped │ │ └── simple-concat@1.0.1 │ ├─┬ tar-fs@2.1.1 │ │ ├── chownr@1.1.4 │ │ ├── mkdirp-classic@0.5.3 deduped │ │ ├── pump@3.0.0 deduped │ │ └─┬ tar-stream@2.2.0 │ │ ├─┬ bl@4.1.0 │ │ │ ├─┬ buffer@5.7.1 │ │ │ │ ├── base64-js@1.5.1 │ │ │ │ └── ieee754@1.2.1 │ │ │ ├── inherits@2.0.4 deduped │ │ │ └─┬ readable-stream@3.6.0 │ │ │ ├── inherits@2.0.4 deduped │ │ │ ├── string_decoder@1.1.1 deduped │ │ │ └── util-deprecate@1.0.2 deduped │ │ ├── end-of-stream@1.4.4 deduped │ │ ├── fs-constants@1.0.0 │ │ ├── inherits@2.0.4 │ │ └─┬ readable-stream@3.6.0 │ │ ├── inherits@2.0.4 deduped │ │ ├── string_decoder@1.1.1 deduped │ │ └── util-deprecate@1.0.2 deduped │ ├─┬ tunnel-agent@0.6.0 │ │ └── safe-buffer@5.1.2 │ └── which-pm-runs@1.0.0 ├── @types/debounce@1.2.0 extraneous ├── @types/debug@4.1.5 extraneous ├── @types/jest@26.0.20 extraneous ├── @types/mz@2.7.3 extraneous ├── @types/nedb@1.8.11 extraneous ├── @types/serialport@8.0.1 extraneous ├── @typescript-eslint/eslint-plugin@4.16.1 extraneous ├── @typescript-eslint/parser@4.16.1 extraneous ├── debounce@1.2.0 ├─┬ debug@4.3.1 │ └── ms@2.1.2 ├── eslint@7.21.0 extraneous ├── fast-deep-equal@3.1.3 ├── jest@26.6.3 extraneous ├── mixin-deep@2.0.1 ├─┬ mz@2.7.0 │ ├── any-promise@1.3.0 │ ├── object-assign@4.1.1 │ └─┬ thenify-all@1.6.0 │ └─┬ thenify@3.3.1 │ └── any-promise@1.3.0 deduped ├─┬ serialport@9.0.6 │ ├─┬ @serialport/binding-mock@9.0.7 │ │ ├── @serialport/binding-abstract@9.0.7 deduped │ │ └── debug@4.3.1 deduped │ ├── @serialport/bindings@9.0.4 deduped │ ├── @serialport/parser-byte-length@9.0.7 │ ├── @serialport/parser-cctalk@9.0.7 │ ├── @serialport/parser-delimiter@9.0.7 │ ├── @serialport/parser-inter-byte-timeout@9.0.7 │ ├── @serialport/parser-readline@9.0.7 deduped │ ├── @serialport/parser-ready@9.0.7 │ ├── @serialport/parser-regex@9.0.7 │ ├─┬ @serialport/stream@9.0.7 │ │ └── debug@4.3.1 deduped │ └── debug@4.3.1 deduped ├── slip@1.0.2 ├── typedoc@0.20.28 extraneous ├── typedoc-plugin-markdown@3.6.0 extraneous ├── typedoc-plugin-no-inherit@1.2.0 extraneous ├── typedoc-plugin-sourcefile-url@1.0.6 extraneous └── UNMET PEER DEPENDENCY typescript@4.2.2 extraneous npm ERR! peer dep missing: @angular/common@>= 5.0.0, required by xmlhttprequest-ts@1.0.1 npm ERR! peer dep missing: @angular/core@>= 5.0.0, required by xmlhttprequest-ts@1.0.1 npm ERR! peer dep missing: typescript@3.9.x || 4.0.x || 4.1.x, required by typedoc@0.20.28 npm ERR! extraneous: @babel/cli@7.13.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/cli npm ERR! extraneous: @babel/preset-env@7.13.9 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/preset-env npm ERR! extraneous: @babel/preset-typescript@7.13.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/preset-typescript npm ERR! extraneous: @types/debounce@1.2.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/debounce npm ERR! extraneous: @types/debug@4.1.5 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/debug npm ERR! extraneous: @types/jest@26.0.20 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/jest npm ERR! extraneous: @types/mz@2.7.3 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/mz npm ERR! extraneous: @types/nedb@1.8.11 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/nedb npm ERR! extraneous: @types/serialport@8.0.1 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/serialport npm ERR! extraneous: @typescript-eslint/eslint-plugin@4.16.1 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/eslint-plugin npm ERR! extraneous: @typescript-eslint/parser@4.16.1 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/parser npm ERR! extraneous: eslint@7.21.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/eslint npm ERR! extraneous: jest@26.6.3 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/jest npm ERR! extraneous: typedoc@0.20.28 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc npm ERR! extraneous: typedoc-plugin-markdown@3.6.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-markdown npm ERR! extraneous: typedoc-plugin-no-inherit@1.2.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-no-inherit npm ERR! extraneous: typedoc-plugin-sourcefile-url@1.0.6 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-sourcefile-url npm ERR! extraneous: eslint@7.27.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint npm ERR! extraneous: eslint-config-google@0.14.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint-config-google npm ERR! extraneous: eslint-plugin-jest@24.3.6 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint-plugin-jest npm ERR! extraneous: jest@26.6.3 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/jest npm ERR! peer dep missing: typescript@3.9.x || 4.0.x || 4.1.x, required by typedoc@0.20.28 npm ERR! extraneous: @babel/cli@7.13.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/cli npm ERR! extraneous: @babel/preset-env@7.13.9 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/preset-env npm ERR! extraneous: @babel/preset-typescript@7.13.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/preset-typescript npm ERR! extraneous: @types/debounce@1.2.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/debounce npm ERR! extraneous: @types/debug@4.1.5 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/debug npm ERR! extraneous: @types/jest@26.0.20 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/jest npm ERR! extraneous: @types/mz@2.7.3 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/mz npm ERR! extraneous: @types/nedb@1.8.11 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/nedb npm ERR! extraneous: @types/serialport@8.0.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/serialport npm ERR! extraneous: @typescript-eslint/eslint-plugin@4.16.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/eslint-plugin npm ERR! extraneous: @typescript-eslint/parser@4.16.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/parser npm ERR! extraneous: eslint@7.21.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/eslint npm ERR! extraneous: jest@26.6.3 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/jest npm ERR! extraneous: typedoc@0.20.28 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc npm ERR! extraneous: typedoc-plugin-markdown@3.6.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-markdown npm ERR! extraneous: typedoc-plugin-no-inherit@1.2.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-no-inherit npm ERR! extraneous: typedoc-plugin-sourcefile-url@1.0.6 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-sourcefile-urlHaben die Error-Meldung irgendeine Auswirkung und müssen beseitigt werden?
Eigentlicht ist mein Ansatz ja Meldungen soweit wie möglich auch zu adressieren.
In dem Fall würde ich allerdings die Finger davon lassen. Das wird sich (vermutlich) mit künftigen Updates auswachsen. -
@thomas-braun Hab ich mir auch gedacht und hoffe natürlich, dass es auch sein wird
