  4. Jeelink Adapter startet nicht mehr
53 Beiträge 14 Kommentatoren 12.9k Aufrufe 13 Beobachtet
  • TepManT TepMan
    Sorry, der Post sollte hier landen: https://forum.iobroker.net/topic/44566/how-to-node-js-für-iobroker-richtig-updaten-2021-edition/150
    Thomas BraunT
    Thomas BraunT
    Most Active Developer
    @tepman
    which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
    iobroker update -i
    iobroker stop
    iobroker fix
    iobroker start
    TepManT 1 Antwort Letzte Antwort
      @tepman
      iobroker update -i
      iobroker stop
      iobroker fix
      iobroker start
      TepManT
      TepManT
      TepMan
      @thomas-braun said in Jeelink Adapter startet nicht mehr:
      Ausgaben der ersten Zeile:
      pi@raspi4:/ $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v14.18.1
      v14.18.1
      6.14.15
      OK:1 http://archive.raspberrypi.org/debian buster InRelease
      OK:2 http://phoscon.de/apt/deconz buster InRelease
      OK:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
      OK:4 https://repos.influxdata.com/debian buster InRelease
      OK:5 https://deb.nodesource.com/node_14.x buster InRelease
      Alle Pakete sind aktuell.
      OK:1 http://phoscon.de/apt/deconz buster InRelease
      OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      OK:3 http://archive.raspberrypi.org/debian buster InRelease
      nodejs:
        Installiert:           14.18.1-deb-1nodesource1
        Installationskandidat: 14.18.1-deb-1nodesource1
        Versionstabelle:
       *** 14.18.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
           10.24.0~dfsg-1~deb10u1 500
      Ausgabe update -i:
      pi@raspi4:/ $ iobroker update -i
      Used repository: stable
      hash unchanged, use cached sources
      update done
      Adapter    "admin"         : 5.1.25   , installed 5.1.25
      Adapter    "alexa2"        : 3.11.2   , installed 3.11.2
      Adapter    "backitup"      : 2.2.2    , installed 2.2.2
      Adapter    "cloud"         : 4.1.0    , installed 4.1.0
      Adapter    "daswetter"     : 3.0.7    , installed 3.0.7
      Adapter    "deconz"        : 1.3.19   , installed 1.3.19
      Adapter    "discovery"     : 2.7.3    , installed 2.7.3
      Adapter    "flot"          : 1.10.7   , installed 1.10.7
      Adapter    "fritzdect"     : 2.1.15   , installed 2.1.15
      Adapter    "icons-addictive-flavour-png": 0.1.0   , installed 0.1.0
      Adapter    "icons-icons8"  : 0.0.1    , installed 0.0.1
      Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
      Adapter    "influxdb"      : 1.9.5    , installed 1.9.5
      Adapter    "info"          : 1.9.8    , installed 1.9.8
      Adapter    "iot"           : 1.8.24   , installed 1.8.24
      Adapter    "iqontrol"      : 1.8.2    , installed 1.8.2
      Adapter    "jarvis"        : 2.2.1    , installed 2.2.1
      Adapter    "javascript"    : 5.2.13   , installed 5.2.13
      Adapter    "jeelink"       : 0.1.3    , installed 0.1.3
      Controller "js-controller" : 3.3.18   , installed 3.3.18
      Adapter    "kodi"          : 2.0.8    , installed 2.0.8
      Adapter    "linkeddevices" : 1.4.3    , installed 1.4.3
      Adapter    "logparser"     : 1.1.0    , installed 1.1.0
      Adapter    "luftdaten"     : 1.0.3    , installed 1.0.3
      Adapter    "mobile"        : 1.0.1    , installed 1.0.1
      Adapter    "mqtt"          : 2.4.0    , installed 2.4.0
      Adapter    "ping"          : 1.5.0    , installed 1.5.0
      Adapter    "pushbullet"    : 0.0.11   , installed 0.0.11
      Adapter    "rpi2"          : 1.3.1    , installed 1.3.1
      Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
      Adapter    "socketio"      : 3.1.4    , installed 3.1.4
      Adapter    "synology"      : 1.1.3    , installed 2.0.1
      Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
      Adapter    "vis"           : 1.4.5    , installed 1.4.5
      Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
      Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
      Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
      Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
      Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
      Adapter    "vis-weather"   : 2.5.3    , installed 2.5.3
      Adapter    "web"           : 3.4.9    , installed 3.4.9
      Fix ist durchgelaufen, Jeelink läuft nach wie vor nicht, gleicher Fehler:
      host.raspi4
      2021-11-20 11:26:03.225	error	instance system.adapter.jeelink.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.raspi4
      2021-11-20 11:26:03.224	error	Caught by controller[0]: }
      host.raspi4
      2021-11-20 11:26:03.224	error	Caught by controller[0]: ]
      host.raspi4
      2021-11-20 11:26:03.224	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/lib/binding/node-v83-linux-arm/bindings.node'
      host.raspi4
      2021-11-20 11:26:03.224	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node',
      host.raspi4
      2021-11-20 11:26:03.223	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node',
      host.raspi4
      2021-11-20 11:26:03.223	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node',
      host.raspi4
      2021-11-20 11:26:03.223	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/compiled/14.18.1/linux/arm/bindings.node',
      host.raspi4
      2021-11-20 11:26:03.223	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/default/bindings.node',
      host.raspi4
      2021-11-20 11:26:03.223	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/Release/bindings.node',
      host.raspi4
      2021-11-20 11:26:03.222	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/out/Release/bindings.node',
      host.raspi4
      2021-11-20 11:26:03.222	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/Debug/bindings.node',
      host.raspi4
      2021-11-20 11:26:03.222	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/out/Debug/bindings.node',
      host.raspi4
      2021-11-20 11:26:03.222	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node',
      host.raspi4
      2021-11-20 11:26:03.222	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/Debug/bindings.node',
      host.raspi4
      2021-11-20 11:26:03.221	error	Caught by controller[0]: '/opt/iobroker/node_modules/@serialport/bindings/build/bindings.node',
      host.raspi4
      2021-11-20 11:26:03.221	error	Caught by controller[0]: tries: [
      host.raspi4
      2021-11-20 11:26:03.221	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14) {
      host.raspi4
      2021-11-20 11:26:03.221	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/index.js:14:22)
      host.raspi4
      2021-11-20 11:26:03.220	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:93:18)
      host.raspi4
      2021-11-20 11:26:03.220	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
      host.raspi4
      2021-11-20 11:26:03.220	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
      host.raspi4
      2021-11-20 11:26:03.220	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
      host.raspi4
      2021-11-20 11:26:03.219	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
      host.raspi4
      2021-11-20 11:26:03.219	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
      host.raspi4
      2021-11-20 11:26:03.219	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:1:36)
      host.raspi4
      2021-11-20 11:26:03.219	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/@serialport/bindings/node_modules/bindings/bindings.js:126:9)
      host.raspi4
      2021-11-20 11:26:03.218	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/lib/binding/node-v83-linux-arm/bindings.node
      host.raspi4
      2021-11-20 11:26:03.218	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node
      host.raspi4
      2021-11-20 11:26:03.218	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node
      host.raspi4
      2021-11-20 11:26:03.218	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node
      host.raspi4
      2021-11-20 11:26:03.217	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/compiled/14.18.1/linux/arm/bindings.node
      host.raspi4
      2021-11-20 11:26:03.217	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/default/bindings.node
      host.raspi4
      2021-11-20 11:26:03.217	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/Release/bindings.node
      host.raspi4
      2021-11-20 11:26:03.217	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/out/Release/bindings.node
      host.raspi4
      2021-11-20 11:26:03.216	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/Debug/bindings.node
      host.raspi4
      2021-11-20 11:26:03.216	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/out/Debug/bindings.node
      host.raspi4
      2021-11-20 11:26:03.216	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node
      host.raspi4
      2021-11-20 11:26:03.216	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/Debug/bindings.node
      host.raspi4
      2021-11-20 11:26:03.216	error	Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/bindings.node
      host.raspi4
      2021-11-20 11:26:03.215	error	Caught by controller[0]: Error: Could not locate the bindings file. Tried:
      host.raspi4
      2021-11-20 11:26:03.215	error	Caught by controller[0]: ^
      host.raspi4
      2021-11-20 11:26:03.215	error	Caught by controller[0]: throw err;
      host.raspi4
      2021-11-20 11:26:03.214	error	Caught by controller[0]: /opt/iobroker/node_modules/@serialport/bindings/node_modules/bindings/bindings.js:135
      • TepManT TepMan
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v14.18.1
        v14.18.1
        6.14.15
        nodejs:
          Versionstabelle:
        Ausgabe update -i:
        update done
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        host.raspi4
        Thomas BraunT
        Thomas BraunT
        @tepman
        Deinistallier den Adapter mal komplett und dann ziehst du den (nach einem Neustart) wieder rein.
        Ich vermute da muss der Maintainer sonst nochmal in seine dependencies schauen. Mach ein Issue auf.
        Der Adapter ist auch schon 'ewig' nicht mehr angepasst worden:
        jeelink
        github:	0.1.3
        latest:	0.1.3 for 27 months
        stable:	0.1.3 for 27 months
        Der braucht vermutlich etwas Liebe.
          @tepman
          jeelink
          github:	0.1.3
          TepManT
          TepManT
          TepMan
          @thomas-braun lässt sich nicht mehr installieren:
          $ iobroker add jeelink auto --host raspi4
          NPM version: 6.14.15
          npm install iobroker.jeelink@0.1.3 --loglevel error --prefix "/opt/iobroker" (System call)
          In file included from ../src/./serialport.h:6,
          from ../src/serialport.cpp:1:../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete) ^
          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen); ^~~~~~~~~~~~~
          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
          uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate); ^~~~~~~~~~~~~~~
          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose); ^~~~~~~~~~~~~~
          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush); ^~~~~~~~~~~~~~
          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
          ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet); ^~~~~~~~~~~~
          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
          ../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet); ^~~~~~~~~~~~
          ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
          ../src/serialport.cpp:329:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’ results->Set(Nan::New<v8::String>("cts").ToLocalChecked(), Nan::New<v8::Boolean>(data->cts)); ^In file included from /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:67,
          from ../../../nan/nan.h:54, from ../src/./serialport.h:6, from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3670:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>, v8::Local<v8::Value>)’ V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, ^~~/home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3670:37: note: candidate expects 3 arguments, 2 provided/home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3673:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, uint32_t, v8::Local<v8::Value>)’ V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index, ^~~/home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3673:37: note: candidate expects 3 arguments, 2 provided
          ../src/serialport.cpp:330:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’ results->Set(Nan::New<v8::String>("dsr").ToLocalChecked(), Nan::New<v8::Boolean>(data->dsr)); ^In file included from /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:67,
          ../src/serialport.cpp:331:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’ results->Set(Nan::New<v8::String>("dcd").ToLocalChecked(), Nan::New<v8::Boolean>(data->dcd)); ^In file included from /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:67,
          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
          ../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate); ^~~~~~~~~~~~~~~~~~~~
          ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:../src/serialport.cpp:378:106: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::IntegerFactory<v8::Integer>::return_t)’ results->Set(Nan::New<v8::String>("baudRate").ToLocalChecked(), Nan::New<v8::Integer>(data->baudRate)); ^
          In file included from /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:67, from ../../../nan/nan.h:54, from ../src/./serialport.h:6, from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3670:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>, v8::Local<v8::Value>)’ V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, ^~~
          ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain); ^~~~~~~~~~~~~~
          ../src/serialport.cpp: At global scope:../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses] SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) { ^
          ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
          SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) { ^
          In file included from ../../../nan/nan.h:54, from ../src/./serialport.h:6, from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:787:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^
          /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:821:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(serialport, init); ^~~~~~~~~~~
          make: *** [bindings.target.mk:112: Release/obj.target/bindings/src/serialport.o] Fehler 1
          gyp ERR! build error
          gyp ERR! stack Error: `make` failed with exit code: 2
          gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildProcess.emit (events.js:400:28)
          gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)gyp ERR! System Linux 5.10.63-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindingsgyp ERR! node -v v14.18.1gyp ERR! node-gyp -v v5.1.0
          gyp ERR! not ok
          npm ERR! code ELIFECYCLEnpm ERR! errno 1
          npm ERR! @serialport/bindings@2.0.8 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the @serialport/bindings@2.0.8 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
          npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-11-20T10_42_23_958Z-debug.log
          host.raspi4 Cannot install iobroker.jeelink@0.1.3: 1
          ERROR: Process exited with code 25
          So ein Mist...
          • TepManT TepMan
            gyp ERR! not ok
            So ein Mist...
            Thomas BraunT
            Thomas BraunT
            @tepman @foxthefox
            Wenn es dich tröstet, bei mir kann man den auch nicht (mehr?) auf Anhieb installieren:
            echad@chet:/opt/iobroker $ iobroker add jeelink
            NPM version: 8.1.2
            npm ERR! code 1
            npm ERR! path /opt/iobroker/node_modules/@serialport/bindings
            npm ERR! command failed
            npm ERR! command sh -c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
            npm ERR! make: Entering directory '/opt/iobroker/node_modules/@serialport/bindings/build'
            npm ERR!   CXX(target) Release/obj.target/bindings/src/serialport.o
            npm ERR! make: Leaving directory '/opt/iobroker/node_modules/@serialport/bindings/build'
            npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
            npm ERR! ../src/serialport.cpp:78:51: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
            npm ERR!    78 |   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
            npm ERR!       |                                                   ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
            npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
            npm ERR! ../src/serialport.cpp:135:53: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
            npm ERR!   135 |   uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
            npm ERR!       |                                                     ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
            npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
            npm ERR! ../src/serialport.cpp:175:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
            npm ERR!   175 |   uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
            npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
            npm ERR! ../src/serialport.cpp:215:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
            npm ERR!   215 |   uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
            npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
            npm ERR! ../src/serialport.cpp:270:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
            npm ERR!   270 |   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
            npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
            npm ERR! ../src/serialport.cpp:314:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
            npm ERR!   314 |   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
            npm ERR! ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
            npm ERR! ../src/serialport.cpp:329:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
            npm ERR!   329 |     results->Set(Nan::New<v8::String>("cts").ToLocalChecked(), Nan::New<v8::Boolean>(data->cts));
            npm ERR!       |        ^
            npm ERR! In file included from /home/iobroker/.cache/node-gyp/17.1.0/include/node/v8-array-buffer.h:13,
            npm ERR!                  from /home/iobroker/.cache/node-gyp/17.1.0/include/node/v8.h:25,
            npm ERR!                  from /home/iobroker/.cache/node-gyp/17.1.0/include/node/node.h:63,
            npm ERR!                  from ../../../nan/nan.h:58,
            npm ERR!                  from ../src/./serialport.h:6,
            npm ERR!                  from ../src/serialport.cpp:1:
            npm ERR! /home/iobroker/.cache/node-gyp/17.1.0/include/node/v8-object.h:244:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>, v8::Local<v8::Value>)’
            npm ERR!   244 |   V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context,
            npm ERR!       |                                     ^~~
            npm ERR! /home/iobroker/.cache/node-gyp/17.1.0/include/node/v8-object.h:244:37: note:   candidate expects 3 arguments, 2 provided
            npm ERR! /home/iobroker/.cache/node-gyp/17.1.0/include/node/v8-object.h:247:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, uint32_t, v8::Local<v8::Value>)’
            npm ERR!   247 |   V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index,
            npm ERR!       |                                     ^~~
            npm ERR! /home/iobroker/.cache/node-gyp/17.1.0/include/node/v8-object.h:247:37: note:   candidate expects 3 arguments, 2 provided
            npm ERR! ../src/serialport.cpp:330:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
            npm ERR!   330 |     results->Set(Nan::New<v8::String>("dsr").ToLocalChecked(), Nan::New<v8::Boolean>(data->dsr));
            npm ERR!       |        ^
            npm ERR!       |                                     ^~~
            npm ERR!       |                                     ^~~
            npm ERR! ../src/serialport.cpp:331:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
            npm ERR!   331 |     results->Set(Nan::New<v8::String>("dcd").ToLocalChecked(), Nan::New<v8::Boolean>(data->dcd));
            npm ERR!       |        ^
            npm ERR!       |                                     ^~~
            npm ERR!       |                                     ^~~
            npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
            npm ERR! ../src/serialport.cpp:363:58: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
            npm ERR!   363 |   uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
            npm ERR!       |                                                          ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
            npm ERR! ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
            npm ERR! ../src/serialport.cpp:378:106: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::IntegerFactory<v8::Integer>::return_t)’
            npm ERR!   378 |     results->Set(Nan::New<v8::String>("baudRate").ToLocalChecked(), Nan::New<v8::Integer>(data->baudRate));
            npm ERR!       |        ^
            npm ERR!       |                                     ^~~
            npm ERR!       |                                     ^~~
            npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
            npm ERR! ../src/serialport.cpp:409:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
            npm ERR!   409 |   uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
            npm ERR! ../src/serialport.cpp: At global scope:
            npm ERR! ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
            npm ERR!   430 | SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
            npm ERR!       |                            ^
            npm ERR! ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
            npm ERR!   449 | SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
            npm ERR!       |                              ^
            npm ERR! In file included from ../../../nan/nan.h:58,
            npm ERR! /home/iobroker/.cache/node-gyp/17.1.0/include/node/node.h:843:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
            npm ERR!   843 |       (node::addon_register_func) (regfunc),                          \
            npm ERR! /home/iobroker/.cache/node-gyp/17.1.0/include/node/node.h:877:3: note: in expansion of macro ‘NODE_MODULE_X’
            npm ERR!   877 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
            npm ERR! ../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’
            npm ERR!   483 | NODE_MODULE(serialport, init);
            npm ERR! make: *** [bindings.target.mk:114: Release/obj.target/bindings/src/serialport.o] Error 1
            npm ERR! gyp ERR! build error
            npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
            npm ERR! gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
            npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:390:28)
            npm ERR! gyp ERR! stack     at Process.ChildProcess._handle.onexit (node:internal/child_process:290:12)
            npm ERR! gyp ERR! System Linux 5.10.63-v8+
            npm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
            npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindings
            npm ERR! gyp ERR! node -v v17.1.0
            npm ERR! gyp ERR! node-gyp -v v8.3.0
            npm ERR! gyp ERR! not ok
            npm ERR!     /home/iobroker/.npm/_logs/2021-11-20T12_28_05_361Z-debug.log
            host.chet Cannot install iobroker.jeelink@0.1.3: 1
              @tepman @foxthefox
              NPM version: 8.1.2
              npm ERR! code 1
              npm ERR!       |        ^
              npm ERR!       |                                     ^~~
              npm ERR!       |                                     ^~~
              npm ERR!       |        ^
              npm ERR!       |                                     ^~~
              npm ERR!       |                                     ^~~
              npm ERR!       |        ^
              npm ERR!       |                                     ^~~
              npm ERR!       |                                     ^~~
              npm ERR!       |        ^
              npm ERR!       |                                     ^~~
              npm ERR!       |                                     ^~~
              npm ERR!       |                            ^
              npm ERR!       |                              ^
              TepManT
              TepManT
              TepMan
              @thomas-braun danke, da fühle ich mich dann nicht so ganz allein... ;-)
              Ist schade, weil meine Heizungsregelung da dran hängt, der JeeLink und die TFA Sensoren sind halt super stabil und zuverlässig. Aber vielleicht wirft @foxthefox nochmal einen Blick auf den Adapter.
              • TepManT TepMan
                Thomas BraunT
                Thomas BraunT
                @tepman sagte in Jeelink Adapter startet nicht mehr:
                Dann bleib vorerst auf node12.
                Foxthefox scheint nicht mehr großartig aktiv zu sein. Bedeutet vermutlich für den Adapter jeelink nichts gutes.
                TepManT B 2 Antworten Letzte Antwort
                  TepManT
                  TepManT
                  TepMan
                  @thomas-braun nein, downgraden tue ich jetzt nicht mehr. Verschiebt das Problem ja auch nur. Werde die Sensoren vermutlich gegen Zigbees tauschen.
                  • TepManT TepMan
                    B
                    B
                    Berchemer
                    Will ich eigentlich auch nicht, nur stand da doch unter richtig Updaten und NodeJS der Hinweis, dass man im Zusammenhang mit Serialport:
                    Die einfachste Option ist es dann manuell im richtigen Verzeichnis neu zu bauen.
                    In dem Fall das Verzeichenis mit "bindings" suchen - oben ist das /opt/iobroker/node_modules/serialport/node_modules/bindings ... bei neueren Versionen kann es auch etwas wie /opt/iobroker/node_modules/serialport/node_modules/@serialport/bindings sein.
                    Dann in dieses Verzeichnis wechseln und npm install --production ausführen. Danach den Adapter nochmal sneu starten, das sollte dann tun.
                    Was wäre denn das richtige Verzeichnis bei folgenden Fehlermeldungen des JeeLink:
                    2021-11-21 12:03:51.760	error	instance system.adapter.jeelink.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    2021-11-21 12:03:51.760	error	Caught by controller[0]: }
                    2021-11-21 12:03:51.760	error	Caught by controller[0]: ]
                    2021-11-21 12:03:51.760	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.jeelink/node_modules/@serialport/bindings/lib/binding/node-v83-linux-x64/bindings.node'
                    2021-11-21 12:03:51.760	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.jeelink/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node',
                    2021-11-21 12:03:51.760	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.jeelink/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node',
                    2021-11-21 12:03:51.760	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.jeelink/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node',
                    2021-11-21 12:03:51.760	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.jeelink/node_modules/@serialport/bindings/compiled/14.18.1/linux/x64/bindings.node',
                    2021-11-21 12:03:51.759	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.jeelink/node_modules/@serialport/bindings/build/default/bindings.node',
                    2021-11-21 12:03:51.759	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.jeelink/node_modules/@serialport/bindings/Release/bindings.node',
                    2021-11-21 12:03:51.759	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.jeelink/node_modules/@serialport/bindings/out/Release/bindings.node',
                    2021-11-21 12:03:51.759	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.jeelink/node_modules/@serialport/bindings/Debug/bindings.node',
                    2021-11-21 12:03:51.759	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.jeelink/node_modules/@serialport/bindings/out/Debug/bindings.node',
                    2021-11-21 12:03:51.759	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.jeelink/node_modules/@serialport/bindings/build/Release/bindings.node',
                    2021-11-21 12:03:51.759	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.jeelink/node_modules/@serialport/bindings/build/Debug/bindings.node',
                    2021-11-21 12:03:51.759	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.jeelink/node_modules/@serialport/bindings/build/bindings.node',
                    2021-11-21 12:03:51.759	error	Caught by controller[0]: tries: [
                    2021-11-21 12:03:51.759	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14) {
                    2021-11-21 12:03:51.759	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.jeelink/node_modules/@serialport/bindings/lib/index.js:14:22)
                    2021-11-21 12:03:51.758	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:93:18)
                    2021-11-21 12:03:51.758	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
                    2021-11-21 12:03:51.758	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                    2021-11-21 12:03:51.758	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                    2021-11-21 12:03:51.758	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                    2021-11-21 12:03:51.758	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
                    2021-11-21 12:03:51.758	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.jeelink/node_modules/@serialport/bindings/lib/linux.js:1:36)
                    2021-11-21 12:03:51.758	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:126:9)
                    2021-11-21 12:03:51.758	error	Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.jeelink/node_modules/@serialport/bindings/lib/binding/node-v83-linux-x64/bindings.node
                    2021-11-21 12:03:51.758	error	Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.jeelink/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node
                    2021-11-21 12:03:51.758	error	Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.jeelink/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node
                    2021-11-21 12:03:51.757	error	Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.jeelink/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node
                    2021-11-21 12:03:51.757	error	Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.jeelink/node_modules/@serialport/bindings/compiled/14.18.1/linux/x64/bindings.node
                    2021-11-21 12:03:51.757	error	Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.jeelink/node_modules/@serialport/bindings/build/default/bindings.node
                    2021-11-21 12:03:51.757	error	Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.jeelink/node_modules/@serialport/bindings/Release/bindings.node
                    2021-11-21 12:03:51.757	error	Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.jeelink/node_modules/@serialport/bindings/out/Release/bindings.node
                    2021-11-21 12:03:51.757	error	Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.jeelink/node_modules/@serialport/bindings/Debug/bindings.node
                    2021-11-21 12:03:51.757	error	Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.jeelink/node_modules/@serialport/bindings/out/Debug/bindings.node
                    2021-11-21 12:03:51.757	error	Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.jeelink/node_modules/@serialport/bindings/build/Release/bindings.node
                    2021-11-21 12:03:51.757	error	Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.jeelink/node_modules/@serialport/bindings/build/Debug/bindings.node
                    2021-11-21 12:03:51.757	error	Caught by controller[0]: → /opt/iobroker/node_modules/iobroker.jeelink/node_modules/@serialport/bindings/build/bindings.node
                    2021-11-21 12:03:51.756	error	Caught by controller[0]: Error: Could not locate the bindings file. Tried:
                    2021-11-21 12:03:51.756	error	Caught by controller[0]: ^
                    2021-11-21 12:03:51.756	error	Caught by controller[0]: throw err;
                    2021-11-21 12:03:51.755	error	Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:135
                    in welches man gehen und den Befehl npm install --production ausführen sollte???
                    • TepManT TepMan
                      B
                      B
                      Berchemer
                      schrieb am zuletzt editiert von Berchemer
                      Rein interessehalber... Gegen welche?
                        B
                        B
                        Berchemer
                        @thomas-braun sagte in Jeelink Adapter startet nicht mehr:
                        @foxthefox
                        Hatte auch schon versucht auf Github ein Issue aufzumachen, aber das scheint bei Jeelink nicht aktiviert zu sein. Oder habe ich mich völlig verguckt???
                        Kann denn sonst Jemand was mit den Fehlermeldungen anfangen und ggf. eine quick&dirty-Lösung anbieten, bis sich Jemand findet, der sich wieder des JeeLink-Adapters annimmt?
                        Irgendwie möchte ich die vorhandenen über 20 Sensoren nicht gegen Andere austauschen müssen :-(
                        Chris76eC 1 Antwort Letzte Antwort
                        • B Berchemer
                          @foxthefox
                          Chris76eC
                          Chris76eC
                          Chris76e
                          @berchemer
                          habe auch 10 Sensoren, wenn es keine andere Lösung gibt werde ich auf einen Raspberry Pi wieder FHEM drauf machen und die Sensoren über den FHEM Adapter einbinden.
                          • Chris76eC Chris76e
                            @berchemer
                            Thomas BraunT
                            Thomas BraunT
                            @chris76e
                            Bleib doch zunächst mal auf node12. Da muss man ja noch nicht von runterspringen. Bis das erforderlich wird hat sich vermutlich bei dem Adapter schon was getan.
                              @chris76e
                              Chris76eC
                              Chris76eC
                              Chris76e
                              bin ja schon auf node14, kann man einfach wieder zurück auf die 12er version?
                                Thomas BraunT
                                Thomas BraunT
                                @chris76e
                                Klar. Schau in meiner Signatur, da steht drin wie man es macht.
                                rolandmR B 2 Antworten Letzte Antwort
                                  @chris76e
                                  rolandmR
                                  rolandmR
                                  rolandm
                                  @foxthefox
                                  Ich hätte auch gerne wieder einen funktionalen jeelink Adapter
                                  • rolandmR rolandm
                                    @foxthefox
                                    Thomas BraunT
                                    Thomas BraunT
                                    @rolandm
                                    War
                                    ZULETZT ONLINE 19. MAI 2021
                                      @chris76e
                                      B
                                      B
                                      Berchemer
                                      @chris76e
                                      Ganz verstanden habe ich es nicht. Früher stand immer dabei, dass man die alte Node komplett deinstallieren sollte. Das Vorgehen finde ich in den neueren Anleitungen nicht mehr.
                                      Reicht jetzt einfach bei installiertem 14er die Eingabe von unten stehenden Befehlen, wie es in den neueren Anleitungen steht und die 14er ist durch die 12er ersetzt???
                                      curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash -
                                      sudo apt-get install -y nodejs
                                      • B Berchemer
                                        @chris76e
                                        Thomas BraunT
                                        Thomas BraunT
                                        @berchemer
                                        Geht nicht, in deinem Fall.
                                        Die node12 muss von Hand gezielt angegeben werden.
                                        Also den Eintrag zu node14 in der nodesource.list auskommentieren oder durch 12 ersetzen und dann die genaue Version 12 installieren.
                                          @berchemer
                                          B
                                          B
                                          Berchemer
                                          @berchemer
                                          Sorry...
                                          Meinte ich auch...
                                          Hatte vergessen die 14 durch 12 zu ersetzen ;-)
                                          33.2k
                                          84.3k
