  5. MAX! Cube Blockly Abwesenheit
    6.8k
867 Beiträge 4 Kommentatoren 251.2k Aufrufe 2 Beobachtet
  • mickymM mickym
    @marko1974 sagte in MAX! Cube Blockly Abwesenheit:
    maxcube.0.info.duty_cycle
    Wir probierens mal - vielleicht wars nur ein Refresh Problem im iobroker.
    Marko1974M Offline
    Marko1974M Offline
    Marko1974
    #426
    @mickym ausser im schlafzimmer sind alle temperaturen jetzt gerade nach plan und alle thermostate stehen auf manuell
    • Marko1974M Marko1974
      mickymM Offline
      mickymM Offline
      mickym
      #427
      @marko1974 OK - habs jetzt trotzdem mal mit Prüfung des Duty Cycles eingebaut:
             "id": "2205188e.903d58",
             "type": "delay",
             "z": "6f3801b9.ba4b6",
             "name": "",
             "pauseType": "delay",
             "timeout": "500",
             "timeoutUnits": "milliseconds",
             "rate": "1",
             "nbRateUnits": "1",
             "rateUnits": "second",
             "randomFirst": "1",
             "randomLast": "5",
             "randomUnits": "seconds",
             "drop": false,
             "x": 2700,
             "y": 1940,
             "wires": [
                     "e9b5e382.974a6"
             "id": "ebe592c3.c37be",
             "type": "switch",
             "name": "Heizungen",
             "property": "room",
             "propertyType": "msg",
             "rules": [
                     "t": "eq",
                     "v": "Kinderzimmer",
                     "vt": "str"
                     "t": "eq",
                     "v": "Schlafzimmer",
                     "vt": "str"
                     "t": "eq",
                     "v": "Wohnzimmer",
                     "vt": "str"
                     "t": "eq",
                     "v": "Flur",
                     "vt": "str"
                     "t": "eq",
                     "v": "Küche",
                     "vt": "str"
                     "t": "eq",
                     "v": "Badezimmer",
                     "vt": "str"
             "checkall": "true",
             "repair": false,
             "outputs": 6,
             "x": 3270,
             "y": 1940,
             "wires": [
                     "4a4ea112.c7d3b",
                     "41c45d50.8d71f4"
                     "9ade3e1b.14c42",
                     "fe0235e6.eb33a8"
                     "698b9132.0080f",
                     "64fd3882.325888"
                     "95c3d776.90eba8",
                     "b1f5572a.744928"
                     "9f25c0da.adf92",
                     "bbc39ae6.0da248"
                     "49c0ac63.da08b4",
                     "80e7e0f5.3624c"
             "id": "e9b5e382.974a6",
             "type": "ioBroker get",
             "name": "dutyCycle",
             "topic": "maxcube.0.info.duty_cycle",
             "attrname": "dutyCycle",
             "payloadType": "value",
             "x": 2890,
             "y": 1940,
             "wires": [
                     "79c9d189.471bf"
             "id": "79c9d189.471bf",
             "type": "switch",
             "name": "dutyCycle > 85 ",
             "property": "dutyCycle",
             "rules": [
                     "t": "lte",
                     "v": "85",
                     "vt": "num"
                     "t": "gt",
                     "v": "85",
                     "vt": "num"
             "checkall": "true",
             "repair": false,
             "outputs": 2,
             "x": 3060,
             "y": 1940,
             "wires": [
                     "ebe592c3.c37be"
                     "819b93dd.6b8"
             "id": "819b93dd.6b8",
             "type": "function",
             "name": "Iobroker Logeintrag",
             "func": "node.warn('Duty Cycle ist über 85%');",
             "outputs": 1,
             "noerr": 0,
             "initialize": "",
             "finalize": "",
             "libs": [],
             "x": 3250,
             "y": 2020,
             "wires": [
      Diese Nodes zwischen Debug und Out Nodes packen:
      • mickymM mickym
        Marko1974M Offline
        Marko1974M Offline
        Marko1974
        #428
        @mickym lass uns morgen weitermachen
          mickymM Offline
          mickymM Offline
          mickym
          #429
          @marko1974
          Ja ich arbeite morgen an einer weiteren Verbesserung - das kannst ja morgen dann einbauen.
          Im Moment wird manuell getriggert - so dass halt Deine Eltern bis der Flow aktiv ist, die Thermostate selbst auf AUTO stellen können.
          Marko1974M 1 Antwort Letzte Antwort
            mickymM Offline
            mickymM Offline
            mickym
            #430
            @marko1974 Dann Dir eine gute N8 - Morgen zwischen 19-23 bin ich eh anderweitig beschäftigt - aber am Nachmittag hab ich Zeit.
            • mickymM mickym
              @marko1974
              Marko1974M Offline
              Marko1974M Offline
              Marko1974
              #431
              @mickym said in MAX! Cube Blockly Abwesenheit:
              @marko1974
              Der manuelle Zeitplan läuft doch, oder? kann doch auf manuell bleiben. Du musst jetzt immer sagen von welchem AUTO du sprichst. Du sprichst von unserem AUTO. Das neue Manu :-)
              Die Nodes hab ich eingepflanzt
                @marko1974
                mickymM Offline
                mickymM Offline
                mickym
                #432
                @marko1974 Na wenn Du die Nodes schon eingepflanzt hast - dann mach bitte noch mal abwesend - schau ob alles auf 4,5 ist - dann anwesend und dann ob Temperaturen stimmen.
                Wenn das so weit OK ist - müssen wir die Debug NOdes nur deaktivieren und starten den Trigger.
                Die andere Verbesserung üm die kümmern wir uns morgen.
                • mickymM mickym
                  Marko1974M Offline
                  Marko1974M Offline
                  Marko1974
                  #433
                  14.11.2021, 05:03:33node: Kinderzimmer
                  maxcube.0.info.duty_cycle : msg.payload : number
                  4.5
                  14.11.2021, 05:03:33node: Schlafzimmermaxcube.0.info.duty_cycle : msg.payload : number
                  4.5
                  14.11.2021, 05:03:33node: Wohnzimmermaxcube.0.info.duty_cycle : msg.payload : number
                  4.5
                  14.11.2021, 05:03:33node: Flurmaxcube.0.info.duty_cycle : msg.payload : number
                  4.5
                  14.11.2021, 05:03:33node: Küchemaxcube.0.info.duty_cycle : msg.payload : number
                  4.5
                  14.11.2021, 05:03:33node: Badezimmermaxcube.0.info.duty_cycle : msg.payload : number
                  4.5
                    4.5
                    4.5
                    4.5
                    4.5
                    4.5
                    4.5
                    mickymM Offline
                    mickymM Offline
                    mickym
                    #434
                    @marko1974 OK und MAXCube setpoints?
                    • mickymM mickym
                      Marko1974M Offline
                      Marko1974M Offline
                      Marko1974
                      schrieb am zuletzt editiert von Marko1974
                      #435
                      @mickym waren alle auf 4,5
                      umgekehrt
                      14.11.2021, 05:05:01node: Kinderzimmer
                      14.11.2021, 05:05:01node: Schlafzimmermaxcube.0.info.duty_cycle : msg.payload : number
                      14.11.2021, 05:05:02node: Wohnzimmermaxcube.0.info.duty_cycle : msg.payload : number
                      14.11.2021, 05:05:02node: Flurmaxcube.0.info.duty_cycle : msg.payload : number
                      14.11.2021, 05:05:02node: Küchemaxcube.0.info.duty_cycle : msg.payload : number
                      14.11.2021, 05:05:02node: Badezimmermaxcube.0.info.duty_cycle : msg.payload : number
                        umgekehrt
                        mickymM Offline
                        mickymM Offline
                        mickym
                        #436
                        @marko1974 und MAXCube setpoints?
                        • mickymM mickym
                          Marko1974M Offline
                          Marko1974M Offline
                          Marko1974
                          #437
                          @mickym die sehe ich nie im debug aber direkt am ausgang des node. Die sind laut Zeitplan. Im Adapter mal wieder nicht. Dauert wohl. Mich würde interessieren, was en thermostat anzeigt
                            mickymM Offline
                            mickymM Offline
                            mickym
                            #438
                            @marko1974 Wieso siehst Du die nicht im Debug - hast Du nochmal INJECT gedrückt - das sind doch die gleichen Nodes?
                            Marko1974M mickymM 2 Antworten Letzte Antwort
                            • mickymM mickym
                              Marko1974M Offline
                              Marko1974M Offline
                              Marko1974
                              #439
                              @mickym ja hab ich gedrückt aber ich sehe die setpoint dinger da nicht.
                              Vielleicht sehe ich sie morgen :-)
                              • mickymM mickym
                                mickymM Offline
                                mickymM Offline
                                mickym
                                #440
                                @mickym Na ich überlasse es Dir - ob Du es nun scharf schaltest. Du kannst die Trigger Debug Node noch triggern lassen.
                                stelle die Wiederholung noch auf 1 Minute ein und das Ding ist scharf
                                und die Debug NOdes würde ich halt noch deaktivieren - mit dem Tastendruck - sonst wird halt das Debug Fenster vollgeschrieben - ist aber auch nicht tragisch.
                                Ansonsten Gute N8 und morgen dann noch die Verbesserung. Eigentlich sollte es jetzt funktionieren - habe keine Ahnung warum das was warum nicht siehst.
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  #441
                                  @marko1974 So hier die Optimierungen - damit sollte eigentlich alles funktionieren.
                                  1. Wie gesagt um den Flow scharf zu machen in der Inject Node Trigger alle Minuten die Wiederholung einschalten.
                                  2. Die folgenden Nodes importieren:
                                         "type": "function",
                                         "outputs": 1,
                                         "noerr": 0,
                                         "initialize": "",
                                         "finalize": "",
                                         "libs": [],
                                         "x": 3190,
                                         "y": 1580,
                                         "wires": [
                                         "id": "606898e4.7f9378",
                                         "type": "switch",
                                         "property": "payload",
                                         "rules": [
                                                 "t": "lte",
                                                 "v": "85",
                                                 "vt": "num"
                                                 "t": "gt",
                                                 "v": "85",
                                                 "vt": "num"
                                         "checkall": "true",
                                         "repair": false,
                                         "outputs": 2,
                                         "x": 2920,
                                         "y": 1520,
                                         "wires": [
                                                 "32d2ae90.0e95c2"
                                                 "b0ad5dee.ef2e3",
                                                 "819b93dd.6b8"
                                         "id": "f153425d.2deb7",
                                         "type": "ioBroker in",
                                         "name": "",
                                         "onlyack": "",
                                         "func": "all",
                                         "gap": "",
                                         "fireOnStart": "true",
                                         "x": 2690,
                                         "y": 1520,
                                         "wires": [
                                                 "606898e4.7f9378"
                                         "id": "c3092c6.6072dd",
                                         "type": "inject",
                                         "name": "",
                                         "props": [
                                                 "p": "payload"
                                         "repeat": "",
                                         "crontab": "",
                                         "once": false,
                                         "onceDelay": 0.1,
                                         "topic": "",
                                         "payload": "10",
                                         "payloadType": "num",
                                         "x": 2750,
                                         "y": 1560,
                                         "wires": [
                                                 "606898e4.7f9378"
                                         "id": "32d2ae90.0e95c2",
                                         "type": "change",
                                         "name": "",
                                         "rules": [
                                                 "t": "set",
                                                 "p": "dutyCycleOK",
                                                 "pt": "flow",
                                                 "to": "true",
                                                 "tot": "bool"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 3190,
                                         "y": 1500,
                                         "wires": [
                                         "id": "b0ad5dee.ef2e3",
                                         "type": "change",
                                         "name": "",
                                         "rules": [
                                                 "t": "set",
                                                 "p": "dutyCycleOK",
                                                 "pt": "flow",
                                                 "to": "false",
                                                 "tot": "bool"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 3190,
                                         "y": 1540,
                                         "wires": [
                                         "id": "4206d01a.81378",
                                         "type": "switch",
                                         "name": "dutyCycleOK =true?",
                                         "property": "dutyCycleOK",
                                         "propertyType": "flow",
                                         "rules": [
                                                 "t": "true"
                                         "checkall": "true",
                                         "repair": false,
                                         "outputs": 1,
                                         "x": 2980,
                                         "y": 1940,
                                         "wires": [
                                                 "ebe592c3.c37be"
                                  und gemäß folgender Abbildung einfügen - die vorherige Prüfung auf den DutyCycle löschen:
                                  1. In allen RBE Nodes den Haken wegmachen: Modus für jedes msg.topic separat anwenden
                                  1. Die AUTO Node Templates müssen alle überarbeitet werden
                                  Die Temperatur-Nodes bekommen nun keine payload sondern Objekte:
                                  4408ffef-6fc4-479a-9c91-0bdf15fe7cde-image.png b7b6fc75-339f-4258-b828-a80c56dcb48f-image.png
                                  setpoint ist die gewünschte Temperatur, period wird von 1-5 durchgezählt - je Wochentagscluster.
                                  In den Zeitprofil Nodes - die Abarbeitung der Regeln ändern:
                                  Die folgenden beiden Nodes in den Subflow einarbeiten und zwischen die Temperaturnodes und dem Ausgang setzen:
                                         "id": "985d4e2c.7e5e4",
                                         "type": "switch",
                                         "z": "4c7438ae.bcfe38",
                                         "name": "Neue Periode",
                                         "property": "payload.period",
                                         "rules": [
                                                 "t": "neq",
                                                 "v": "",
                                                 "vt": "prev"
                                         "checkall": "true",
                                         "repair": false,
                                         "outputs": 1,
                                         "x": 1320,
                                         "y": 280,
                                         "wires": [
                                                 "4fa0066a.e80208"
                                         "id": "4fa0066a.e80208",
                                         "type": "change",
                                         "name": "setze payload & topic=Schlafzimmer",
                                         "rules": [
                                                 "t": "set",
                                                 "p": "topic",
                                                 "pt": "msg",
                                                 "to": "'schlafzimmer_auto_period_' & payload.period",
                                                 "tot": "jsonata"
                                                 "t": "set",
                                                 "p": "payload",
                                                 "pt": "msg",
                                                 "to": "payload.setpoint",
                                                 "tot": "msg"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 1590,
                                         "y": 280,
                                         "wires": [
                                  Die topics in der letzten Change Node - anhand des Raumnamens abändern.
                                  1. Wenn die Auto Template Nodes geändert wurden, dann direkt mit der Verzögerungsnode verkabeln - nicht mehr in die rbe Node fließen lassen:
                                  1. Bei allen anderen Nodes
                                  ein Topic definieren - damit man jederzeit den Flow nachvollziehen kann:
                                  Für ein Raum hier mal die 3 Nodes:
                                         "id": "5cd3bef0.e41f8",
                                         "type": "change",
                                         "name": "HEAT = setpoint",
                                         "rules": [
                                                 "t": "set",
                                                 "p": "payload",
                                                 "pt": "msg",
                                                 "to": "desiredTemperature",
                                                 "tot": "msg"
                                                 "t": "set",
                                                 "p": "topic",
                                                 "pt": "msg",
                                                 "to": "badezimmer_heat",
                                                 "tot": "str"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 2160,
                                         "y": 2320,
                                         "wires": [
                                                 "8c12a45.58c5958"
                                         "id": "9703563a.10fbe8",
                                         "type": "change",
                                         "name": "OFF = 4.5",
                                         "rules": [
                                                 "t": "set",
                                                 "p": "payload",
                                                 "pt": "msg",
                                                 "to": "4.5",
                                                 "tot": "num"
                                                 "t": "set",
                                                 "p": "topic",
                                                 "pt": "msg",
                                                 "to": "badezimmer_off",
                                                 "tot": "str"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 2140,
                                         "y": 2360,
                                         "wires": [
                                                 "8c12a45.58c5958"
                                         "id": "d0ae36e3.0d6d68",
                                         "type": "change",
                                         "name": "ECO = ECO",
                                         "rules": [
                                                 "t": "set",
                                                 "p": "payload",
                                                 "pt": "msg",
                                                 "to": "ecoTemperature",
                                                 "tot": "msg"
                                                 "t": "set",
                                                 "p": "topic",
                                                 "pt": "msg",
                                                 "to": "badezimmer_eco",
                                                 "tot": "str"
                                         "action": "",
                                         "property": "",
                                         "from": "",
                                         "to": "",
                                         "reg": false,
                                         "x": 2150,
                                         "y": 2400,
                                         "wires": [
                                                 "8c12a45.58c5958"
                                  Damit sollten nun in Debug Nodes alles zu sehen sein - auch wenn auf AUTO umgeschaltet wird. Und dann halt wieder prüfen, ob die Temperaturen in die setpoints übernommen werden.
                                  So - nun hoffe ich - wir nähern uns dem final Release. ;)
                                  Marko1974M 2 Antworten Letzte Antwort
                                  • mickymM mickym
                                           "type": "function",
                                           "outputs": 1,
                                           "noerr": 0,
                                           "initialize": "",
                                           "finalize": "",
                                           "libs": [],
                                           "x": 3190,
                                           "y": 1580,
                                           "wires": [
                                           "type": "switch",
                                           "rules": [
                                                   "t": "lte",
                                                   "v": "85",
                                                   "vt": "num"
                                                   "t": "gt",
                                                   "v": "85",
                                                   "vt": "num"
                                           "checkall": "true",
                                           "repair": false,
                                           "outputs": 2,
                                           "x": 2920,
                                           "y": 1520,
                                           "wires": [
                                                   "32d2ae90.0e95c2"
                                                   "b0ad5dee.ef2e3",
                                                   "819b93dd.6b8"
                                           "name": "",
                                           "onlyack": "",
                                           "func": "all",
                                           "gap": "",
                                           "x": 2690,
                                           "y": 1520,
                                           "wires": [
                                                   "606898e4.7f9378"
                                           "type": "inject",
                                           "name": "",
                                           "props": [
                                                   "p": "payload"
                                           "repeat": "",
                                           "crontab": "",
                                           "once": false,
                                           "onceDelay": 0.1,
                                           "topic": "",
                                           "payload": "10",
                                           "x": 2750,
                                           "y": 1560,
                                           "wires": [
                                                   "606898e4.7f9378"
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "dutyCycleOK",
                                                   "pt": "flow",
                                                   "to": "true",
                                                   "tot": "bool"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 3190,
                                           "y": 1500,
                                           "wires": [
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "dutyCycleOK",
                                                   "pt": "flow",
                                                   "to": "false",
                                                   "tot": "bool"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 3190,
                                           "y": 1540,
                                           "wires": [
                                           "type": "switch",
                                           "rules": [
                                                   "t": "true"
                                           "checkall": "true",
                                           "repair": false,
                                           "outputs": 1,
                                           "x": 2980,
                                           "y": 1940,
                                           "wires": [
                                                   "ebe592c3.c37be"
                                           "type": "switch",
                                           "rules": [
                                                   "t": "neq",
                                                   "v": "",
                                                   "vt": "prev"
                                           "checkall": "true",
                                           "repair": false,
                                           "outputs": 1,
                                           "x": 1320,
                                           "y": 280,
                                           "wires": [
                                                   "4fa0066a.e80208"
                                           "type": "change",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "topic",
                                                   "pt": "msg",
                                                   "tot": "jsonata"
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "tot": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 1590,
                                           "y": 280,
                                           "wires": [
                                           "type": "change",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "tot": "msg"
                                                   "t": "set",
                                                   "p": "topic",
                                                   "pt": "msg",
                                                   "tot": "str"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 2160,
                                           "y": 2320,
                                           "wires": [
                                                   "8c12a45.58c5958"
                                           "type": "change",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "to": "4.5",
                                                   "tot": "num"
                                                   "t": "set",
                                                   "p": "topic",
                                                   "pt": "msg",
                                                   "tot": "str"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 2140,
                                           "y": 2360,
                                           "wires": [
                                                   "8c12a45.58c5958"
                                           "type": "change",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "tot": "msg"
                                                   "t": "set",
                                                   "p": "topic",
                                                   "pt": "msg",
                                                   "tot": "str"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 2150,
                                           "y": 2400,
                                           "wires": [
                                                   "8c12a45.58c5958"
                                    Marko1974M Offline
                                    Marko1974M Offline
                                    Marko1974
                                    #442
                                    @mickym moin...bin jetzt direkt vor ort. ...das mit der inject node und dem intervall hab ich nicht verstanden....das ist dafür da wenn ich auf true triggern will und mir den debug ansehen will? ansonsten fange ich nun an alles einzuarbeiten
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      #443
                                      @marko1974 Nein - das ist der Herzschlag des gesamten Flows. Solange keine Wiederholung eingestellt ist - machst Du es einmal, um zu testen, ob alles funktioniert.
                                      Im laufenden Betrieb lässt Du die Inject Node alle Minuten feuern und Du hast ein fertiges System, dass alle Minuten den Zustand ermittelt und reagiert - so wie das der Cube auch macht. Im Prinzip passiert also im laufenden Betrieb EXAKT das gleiche, was Du mit der manuellen Betätigung der Inject Node auch machst. Deswegen, wenn mal was schief läuft die Wiederholung ausschalten, manuell Betätigung und dann an den Stellen Debug Nodes einbauen, wo Du es brauchst. Eine ist ja permanent da - bevor zu den Heizungen gesplittet wird - da siehst Du dann alle Informationen, die in dem Nachrichtenobjekt durch das Lesen der 0_userdata.0 Punkte bereits eingesammelt wurden.
                                      Das true ist nebensächlich - es geht nur darum dass der Flow alle Minuten getriggert wird und nicht jemand manuell die Taste drückt. 😁 Ich hätte auch als payload "Wurzelpfrumpft" nehmen können - zum Schluß wird die mit der zu setzenden Temperatur überschrieben.
                                      Wenn dann mal alles funktioniert - können wir ja mal logisch durch den Flow gehen - wenn Du was nicht verstehst - letztlich bist Du der Herr und Meister, der das System befehligt. ;)
                                      • mickymM mickym
                                               "type": "function",
                                               "outputs": 1,
                                               "noerr": 0,
                                               "initialize": "",
                                               "finalize": "",
                                               "libs": [],
                                               "x": 3190,
                                               "y": 1580,
                                               "wires": [
                                               "type": "switch",
                                               "rules": [
                                                       "t": "lte",
                                                       "v": "85",
                                                       "vt": "num"
                                                       "t": "gt",
                                                       "v": "85",
                                                       "vt": "num"
                                               "checkall": "true",
                                               "repair": false,
                                               "outputs": 2,
                                               "x": 2920,
                                               "y": 1520,
                                               "wires": [
                                                       "32d2ae90.0e95c2"
                                                       "b0ad5dee.ef2e3",
                                                       "819b93dd.6b8"
                                               "name": "",
                                               "onlyack": "",
                                               "func": "all",
                                               "gap": "",
                                               "x": 2690,
                                               "y": 1520,
                                               "wires": [
                                                       "606898e4.7f9378"
                                               "type": "inject",
                                               "name": "",
                                               "props": [
                                                       "p": "payload"
                                               "repeat": "",
                                               "crontab": "",
                                               "once": false,
                                               "onceDelay": 0.1,
                                               "topic": "",
                                               "payload": "10",
                                               "x": 2750,
                                               "y": 1560,
                                               "wires": [
                                                       "606898e4.7f9378"
                                               "type": "change",
                                               "name": "",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "dutyCycleOK",
                                                       "pt": "flow",
                                                       "to": "true",
                                                       "tot": "bool"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 3190,
                                               "y": 1500,
                                               "wires": [
                                               "type": "change",
                                               "name": "",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "dutyCycleOK",
                                                       "pt": "flow",
                                                       "to": "false",
                                                       "tot": "bool"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 3190,
                                               "y": 1540,
                                               "wires": [
                                               "type": "switch",
                                               "rules": [
                                                       "t": "true"
                                               "checkall": "true",
                                               "repair": false,
                                               "outputs": 1,
                                               "x": 2980,
                                               "y": 1940,
                                               "wires": [
                                                       "ebe592c3.c37be"
                                               "type": "switch",
                                               "rules": [
                                                       "t": "neq",
                                                       "v": "",
                                                       "vt": "prev"
                                               "checkall": "true",
                                               "repair": false,
                                               "outputs": 1,
                                               "x": 1320,
                                               "y": 280,
                                               "wires": [
                                                       "4fa0066a.e80208"
                                               "type": "change",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "topic",
                                                       "pt": "msg",
                                                       "tot": "jsonata"
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "tot": "msg"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1590,
                                               "y": 280,
                                               "wires": [
                                               "type": "change",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "tot": "msg"
                                                       "t": "set",
                                                       "p": "topic",
                                                       "pt": "msg",
                                                       "tot": "str"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 2160,
                                               "y": 2320,
                                               "wires": [
                                                       "8c12a45.58c5958"
                                               "type": "change",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "to": "4.5",
                                                       "tot": "num"
                                                       "t": "set",
                                                       "p": "topic",
                                                       "pt": "msg",
                                                       "tot": "str"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 2140,
                                               "y": 2360,
                                               "wires": [
                                                       "8c12a45.58c5958"
                                               "type": "change",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "tot": "msg"
                                                       "t": "set",
                                                       "p": "topic",
                                                       "pt": "msg",
                                                       "tot": "str"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 2150,
                                               "y": 2400,
                                               "wires": [
                                                       "8c12a45.58c5958"
                                        Marko1974M Offline
                                        Marko1974M Offline
                                        Marko1974
                                        #444
                                        @mickym
                                        Den brauche ich nochmal in Klarschrift. Ist da n Punkt drin?
                                        Die Temperaturen muss ich dann entsprechen anpassen?
                                        Will da jetzt nichts falsch machen
                                          @mickym
                                          Marko1974M Offline
                                          Marko1974M Offline
                                          Marko1974
                                          #445
                                          @marko1974 Hab ich schon...da nn wäre bei Schlafzimmer:
                                          {"setpoint":5,"period":1}
