  4. Zigbee iobroker Error while opening serialport
    6.6k
231 Beiträge 28 Kommentatoren 64.2k Aufrufe 24 Beobachtet
  • R rebel85
    hi, ich habe auch so ein problem
    proxmox, iobroker auf debian 11,
    usb durchgereicht alles lief. heute ein proxmox update gemacht und später im iobroker geschaut keine verbindung mehr.
    zigbee 3.0 stick
    /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0 -> ../../ttyUSB0
    habe ich auch schon versucht
    gab es nciht ein befehl wo man usb zugriffsrechte erteilen kann?
    anbei mein log
    zigbee.0	2021-11-11 22:09:57.653	error	(26964) Error herdsman start
    zigbee.0	2021-11-11 22:09:57.652	error	(26964) Failed to start Zigbee
    zigbee.0	2021-11-11 22:09:57.652	error	(26964) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    zigbee.0	2021-11-11 22:09:57.546	info	(26964) Installed Version: iobroker.zigbee@1.6.3
    zigbee.0	2021-11-11 22:09:57.536	info	(26964) Starting Zigbee npm ...
    zigbee.0	2021-11-11 22:09:57.536	info	(26964) Try to reconnect. 1 attempts left
    zigbee.0	2021-11-11 22:09:47.534	error	(26964) Error herdsman start
    zigbee.0	2021-11-11 22:09:47.533	error	(26964) Failed to start Zigbee
    zigbee.0	2021-11-11 22:09:47.533	error	(26964) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
    zigbee.0	2021-11-11 22:09:27.551	info	(26964) Installed Version: iobroker.zigbee@1.6.3
    zigbee.0	2021-11-11 22:09:27.272	info	(26964) Starting Zigbee npm ...
    zigbee.0	2021-11-11 22:09:27.212	info	(26964) starting. Version 1.6.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.7, js-controller: 3.3.18
    zigbee.0	2021-11-11 22:09:23.012	info	(24401) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0	2021-11-11 22:09:23.011	info	(24401) terminating
    zigbee.0	2021-11-11 22:09:23.011	warn	(24401) Failed to stop zigbee during startup
    zigbee.0	2021-11-11 22:09:22.929	info	(24401) Zigbee: disabling joining new devices.
    zigbee.0	2021-11-11 22:09:22.926	info	(24401) cleaned everything up...
    zigbee.0	2021-11-11 22:09:22.925	info	(24401) Got terminate signal TERMINATE_YOURSELF
    zigbee.0	2021-11-11 22:08:43.726	error	(24401) getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
    zigbee.0	2021-11-11 22:07:22.068	info	(24401) Installed Version: iobroker.zigbee@1.6.3
    zigbee.0	2021-11-11 22:07:22.066	error	(24401) Error herdsman start
    zigbee.0	2021-11-11 22:07:22.065	error	(24401) Failed to start Zigbee
    zigbee.0	2021-11-11 22:07:22.065	error	(24401) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0 -> ../../ttyUSB0'"
    zigbee.0	2021-11-11 22:07:22.061	info	(24401) Starting Zigbee npm ...
    zigbee.0	2021-11-11 22:07:22.060	info	(24401) Try to reconnect. 1 attempts left
    zigbee.0	2021-11-11 22:07:12.123	info	(24401) Installed Version: iobroker.zigbee@1.6.3
    zigbee.0	2021-11-11 22:07:12.059	error	(24401) Error herdsman start
    zigbee.0	2021-11-11 22:07:12.058	error	(24401) Failed to start Zigbee
    zigbee.0	2021-11-11 22:07:12.058	error	(24401) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0 -> ../../ttyUSB0'"
    zigbee.0	2021-11-11 22:07:11.947	info	(24401) Starting Zigbee npm ...
    zigbee.0	2021-11-11 22:07:11.893	info	(24401) starting. Version 1.6.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.7, js-controller: 3.3.18
    zigbee.0	2021-11-11 22:07:07.745	info	(17885) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0	2021-11-11 22:07:07.745	info	(17885) terminating
    zigbee.0	2021-11-11 22:07:07.744	warn	(17885) Failed to stop zigbee during startup
    das ist mein node output
    user@iobroker:~$ apt policy nodejs
    nodejs:
      Installiert:           12.22.7-deb-1nodesource1
      Installationskandidat: 12.22.7-deb-1nodesource1
      Versionstabelle:
     *** 12.22.7-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_12.x bullseye/main amd64 Packages
         12.22.5~dfsg-2~11u1 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
    user@iobroker:~$ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v12.22.7
    v12.22.7
    8.1.1
    läuft, im adapter gesehen das sendeleistung sich wohl verstellt hatte.... auf norm gesetz und adapter ist grün
    @rebel85
    npm@8 ist zu hoch. Geh auf npm@6.
    Hat mit dem Problem aber nichts zu tun.
    R 1 Antwort Letzte Antwort
    • R rebel85
      zigbee 3.0 stick
      anbei mein log
      nodejs:
        Versionstabelle:
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v12.22.7
      v12.22.7
      8.1.1
      arteckA Offline
      arteckA Offline
      arteck
      @rebel85 https://www.xmodulo.com/change-usb-device-permission-linux.html
        @rebel85
        rebel85
        das wurde normal so mit installiert
        müsste ich das nach der anleitung deinstallieren und dann in version 6 installieren?
        • R rebel85
          @rebel85
          Nein, das wurde bestimmt nicht mitinstalliert, das Paket nodejs von nodesource packt npm@6 dazu.
          Mach einen --reinstall über apt. Dann sollte es wieder passen.
          https://github.com/nodejs/node/blob/master/doc/changelogs/CHANGELOG_V12.md#12.22.6
          deps: upgrade npm to 6.14.15 (Darcy Clarke) #39856
            @rebel85
            rebel85
            @thomas-braun sagte in Zigbee iobroker Error while opening serialport:
            verstehe grad nicht was du mir sagen willst
            reinstall von node js oder nur von npm?
            npm brauch ich ja dann eine versionsnummer soweit ich weis... währe dann 6.14.15
            • R rebel85
              @rebel85
              Das Paket nodejs über deinen Paketmanager reinstallieren. Das bringt dann npm automatisch in passender Version mit.
              Und die Finger von manuellen globalen Updates von npm lassen. Auch wenn ein entsprechender Hinweis schon mal in der Konsole/im Log auftauchen kann.
              Deine Umschalttaste ist übrigens defekt. Würde ich auch mal nach schauen.
              R 2 Antworten Letzte Antwort
                @rebel85
                rebel85
                schrieb am zuletzt editiert von rebel85
                @rebel85
                ist nichts defekt, einfach mal andere nicht kritisieren wie wer schreibt oder so ;-)
                -3
                • R rebel85
                  @rebel85
                  @rebel85
                  Dann willst du keine Hilfe. Okay, hab ich notiert.
                  • R rebel85
                    @rebel85
                    @rebel85 sagte in Zigbee iobroker Error while opening serialport:
                    @rebel85
                    ist nichts defekt, einfach mal andere nicht kretisieren wie wer schreibt oder so 😉
                    na immer hin konsistent!
                    Aber so etwas ist schwer zu lesen, das muss sich ein Helfender nicht antun
                      @rebel85
                      rebel85
                      da ist wohl wieder jemand auf stress aus, ist schon das 2. mal das du so zu mir bist.
                      -3
                      • R rebel85
                        @rebel85
                        Stress? Nö, ich hab nur keine Lust mir mehr Mühe zu machen.
                        • R rebel85
                          bitte persönliche Angriffe unterlassen
                            @rebel85
                            rebel85
                            @rebel85
                            hat geklappt 6.14.15
                            info:
                            im nachgang hats nicht geklappt da beim update heute im aanschluss der js-controller weg ist
                            kein iobroker fix oder gleichen funktioniert.
                            Fertig mit Fehler: internal/modules/cjs/loader.js:818 throw err; ^Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15) at Function.Module._load (internal/modules/cjs/loader.js:667:27) at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12) at internal/main/run_main_module.js:17:47 { code: 'MODULE_NOT_FOUND', requireStack: []}
                              rebel85
                              hab ich auch nicht vor.
                              keiner mag kritisiert werden. ist nun schon das 2. mal das ich normal frage und schreibe
                              man muss niemanden verbessern oder so, z.b. sind wir hier ja nicht in der schule im deutsch unterricht
                              -2
                              • R rebel85
                                @rebel85 Bitte benutze die korrekte Schreibweise!
                                wie ich bereits schrieb ist so etwas sehr schwer zu entziffern.
                                Das werde ich auch nicht diskutieren
                                Du willst schließlich Hilfe, und ob 25 grad grad zu wenig sind ...
                                • R rebel85
                                  @rebel85
                                  Mit der schludrigen Schreibweise machst du es Helfern schwerer deinen Text zulesen und richtig zu verstehen.
                                  Das Forum ist ein Schriftmedium und die Groß/Kleinschreibung ist ja nicht aus Langeweile entstanden, sondern weil man Deutsch einfach flüssiger lesen kann, wenn man sich an die allgemein üblichen Schreibweisen hält.
                                  Und ein wenig Anspruch sollte man an seine eigenen Anfragen in einem Forum halt auch haben.
                                  Ich werde dann künftig draus lesen: Dem ist sein Anliegen offenbar nicht so wichtig, dass es leicht gelesen werden kann.
                                  OmnedonO 1 Antwort Letzte Antwort
                                    @rebel85
                                    OmnedonO Online
                                    OmnedonO Online
                                    Omnedon
                                    ich bekomme leider meinen Zigbee Adapter nicht zum Laufen:
                                    zigbee.0 PID Zeit error Nachricht
                                    zigbee.0 944	2021-12-20 10:20:46.402	error	Error herdsman start
                                    zigbee.0 944	2021-12-20 10:20:46.401	error	Failed to start Zigbee
                                    zigbee.0 944	2021-12-20 10:20:46.401	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                                    zigbee.0 944	2021-12-20 10:20:36.208	error	Error herdsman start
                                    zigbee.0 944	2021-12-20 10:20:36.204	error	Failed to start Zigbee
                                    zigbee.0 944	2021-12-20 10:20:36.202	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                                    zigbee.0 944	2021-12-20 10:20:36.199	error	Re-commissioning your network will require re-pairing of all devices!
                                    zigbee.0 944	2021-12-20 10:20:36.197	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
                                    zigbee.0 944	2021-12-20 10:20:36.196	error	Please update configuration to prevent further issues.
                                    zigbee.0 944	2021-12-20 10:20:36.195	error	- Channel List: configured=11, adapter=14
                                    zigbee.0 944	2021-12-20 10:20:36.193	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
                                    zigbee.0 944	2021-12-20 10:20:36.192	error	- Extended PAN ID: configured=00124b00229819e0, adapter=ddddddddddddddda
                                    zigbee.0 944	2021-12-20 10:20:36.190	error	- PAN ID: configured=6754, adapter=6755
                                    zigbee.0 944	2021-12-20 10:20:36.189	error	Configuration is not consistent with adapter state/backup!
                                    zigbee.0 715	2021-12-20 10:20:17.803	error	getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
                                    Den Port habe ich über
                                    ls -l /dev/serial/by-id
                                    insgesamt 0
                                    lrwxrwxrwx 1 root root 13 Dez 19 15:25 usb-1a86_USB_Serial-if00-port0 -> ../../ttyUSB0
                                    auf ttyUSB0 eingestellt:
                                    Vielen Dank für die Hilfe!
                                    Viele Grüße
                                    • OmnedonO Omnedon
                                      insgesamt 0
                                      Viele Grüße
                                      @omnedon sagte in Zigbee iobroker Error while opening serialport:
                                      Du sollst aber auf
                                      umstellen.
                                      Und die einzelnen Einstellungen sollten übereinstimmen:
                                      OmnedonO AsgothianA 2 Antworten Letzte Antwort
                                        Du sollst aber auf
                                        umstellen.
                                        OmnedonO Online
                                        OmnedonO Online
                                        Omnedon
                                        danke für die schnelle Antwort!
                                        Die "configured" Werte kann ich in der Instanz ändern und wo kann ich die "adapter"-Werte anpassen?
                                          Du sollst aber auf
                                          umstellen.
                                          AsgothianA Offline
                                          AsgothianA Offline
                                          Asgothian
                                          Du sollst aber auf
                                          umstellen.
                                          Ist irrelevant. Der Fehler hat nichts mit dem Port zu tun.
                                          @Omnedon
                                          Das von Dir gepostet Log beinhaltet:
                                          • den Grund warum es nicht läuft:
                                          • was genau nicht übereinstimmt:
                                          • Was zu tun ist um den adapter trotzdem zu starten (wenn die Konfigurationsanpassung absichtlich ist)
                                          • Was passiert wenn Du das tust:
                                          Du hast also 2 Möglichkeiten:
                                          • Konfiguration so einstellen wie es im backup steht
                                          • backup löschen, neu starten, alles neu pairen.
                                          A.
