  2. Русский
  3. ioBroker
  4. Скрипты
  5. ioBroker скрипты
  6. Вопросы по написанию скриптов
Geplant Angeheftet Gesperrt Verschoben ioBroker скрипты
358 Beiträge 29 Kommentatoren 131.9k Aufrufe
  • I Offline
    I Offline
    instalator
    #266
    @Izzm:
    Читаю другое свойство, которое точно существует
    Код взял из сообщения instalator.
    var t;
    t = setInterval(function() {
       var v = getState('javascript.0.RealTemp.temp').val;
        log(v);
    }, 2000);
    Вывод в лог в редакторе скриптов
    19:30:57.235	[info]	javascript.0 Start javascript script.js.script
    19:30:57.235	[info]	javascript.0 script.js.script: setInterval(ms=2000)
    19:30:57.236	[info]	javascript.0 script.js.script: registered 0 subscriptions and 0 schedules
    19:30:59.255	[error]	javascript.0 script.js.script: Cannot use sync getState, use callback instead getState("javascript.0.RealTemp.temp", function (err, state){});
    В глобальном логе
    Server-Izzm	2017-02-16 19:30:59.273	info	Restart adapter system.adapter.javascript.0 because enabled
    host.Server-Izzm	2017-02-16 19:30:59.273	error	instance system.adapter.javascript.0 terminated with code 0 (OK)
    javascript.0	2017-02-16 19:30:59.257	info	terminating
    javascript.0	2017-02-16 19:30:59.248	error	at Timer.listOnTimeout (timers.js:92:15)
    javascript.0	2017-02-16 19:30:59.248	error	at wrapper [as _onTimeout] (timers.js:279:11)
    javascript.0	2017-02-16 19:30:59.248	error	at ontimeout [as _repeat] (timers.js:263:34)
    javascript.0	2017-02-16 19:30:59.248	error	at null. (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2044:44)
    javascript.0	2017-02-16 19:30:59.248	error	at Object. (script.js.script:4:67)
    javascript.0	2017-02-16 19:30:59.248	error	TypeError: Cannot read property 'val' of undefined
    javascript.0	2017-02-16 19:30:59.242	error	uncaught exception: Cannot read property 'val' of undefined
    javascript.0	2017-02-16 19:30:59.233	error	script.js.script: Cannot use sync getState, use callback instead getState("javascript.0.RealTemp.temp", function (err, state){});
    А так?
    var t;
       	log(JSON.stringify(state));
    }, 2000);
    Высокий уровень Децибел вреден для здоровья!
    http://blog.instalator.ru/
    • I Offline
      I Offline
      Izzm
      #267
      Вывод в лог. У state в val есть нужное значение.
      19:56:08.143	[info]	javascript.0 Start javascript script.js.script
      19:56:08.144	[info]	javascript.0 script.js.script: setInterval(ms=2000)
      19:56:08.144	[info]	javascript.0 script.js.script: registered 0 subscriptions and 0 schedules
      19:56:10.147	[info]	javascript.0 script.js.script: {"val":24.5,"ack":true,"ts":1487264169069,"q":0,"from":"system.adapter.javascript.0","lc":1487263250738}
      И так работает
      var t;
      var vv;
            log(JSON.stringify(state.val));
            vv=state.val;
         log(vv);
      }, 2000);
      20:05:09.423	[info]	javascript.0 Start javascript script.js.script
      20:05:09.424	[info]	javascript.0 script.js.script: setInterval(ms=2000)
      20:05:09.424	[info]	javascript.0 script.js.script: registered 0 subscriptions and 0 schedules
      20:05:11.424	[info]	javascript.0 script.js.script: undefined
      20:05:11.426	[info]	javascript.0 script.js.script: 24.5
      20:05:13.429	[info]	javascript.0 script.js.script: 24.5
      20:05:13.432	[info]	javascript.0 script.js.script: 24.5
      • BluefoxB Offline
        BluefoxB Offline
        #268
        В настройках javascript есть свойство - Оптимизация состояний. Если убрать его, то getState (bla).val заработает.
          spectrekr
          #269
          Пытаюсь из строки выбрать IP адрес, сделал регулярное выражение и парсю строку.
          ! var reg_ip = new RegExp ('(([0-9]|[1-9][0-9]|1[0-9]{2}|2[0-4][0-9]|25[0-5])\.){3}([1-9]|[1-9][0-9]|1[0-9]{2}|2[0-4][0-9]|25[0-4])'); var ip; var str = "first L2TP UDP packet received from 217.15.203.52"; //var str = "error: WARNING: cannot find message with id = 27946818"; ip = reg_ip.exec(str); if(ip){ log("IP: " + ip[0]); } !
          Из первой строки выводит только первые две декты IP, а из второй все число, хотя на IP оно и близко не похоже.
          • BluefoxB Offline
            BluefoxB Offline
            #270
            Будь проще :)
            var ip = str.match(/\b(\d{1,3}\.\d{1,3}\.\d{1,3}\.\d{1,3})\b/);
            if(ip){
                log("IP: " + ip[1]);
            • I Offline
              I Offline
              Izzm
              #271
              Большое спасибо.
              А то я уже такие костыли понастроил.
                spectrekr
                #272
                Все сдаюсь, "обожаю" асинхронность JS. Есть цикл, надо сообщения выводит с задежркой, чтоб телеграмм не заблочил.
                for (var a in res.result) {
                if(res.result[a].work.indexOf('/1') > 0){
                str = res.result[a].work.replace(new RegExp('/1','g'),' очень низкий');
                        }else
                        if(res.result[a].work.indexOf('/2') > 0){
                            str = res.result[a].work.replace(new RegExp('/2','g'),' _низкий_');
                        }else
                        if(res.result[a].work.indexOf('/3') > 0){
                            str = res.result[a].work.replace(new RegExp('/3','g'),' _средний_');
                        }else
                        if(res.result[a].work.indexOf('/4') > 0){
                            str = res.result[a].work.replace(new RegExp('/4','g'),' _высокий_');
                        }else
                        if(res.result[a].work.indexOf('/5') > 0){
                            str = res.result[a].work.replace(new RegExp('/5','g'),' _очень высокий_');
                        sendTo('telegram.0', {user:   us, text:   '*' + res.result[a].name + '*' + '\n' + str, parse_mode: 'Markdown'});
                  kID
                  #273
                  Пытаюсь проделать следующий финт:
                  На закладке объектов создать в корне папку и наполнить ее разными объектами.
                  Например создать папку Flags и там различные объекты к которым могу обращаться из различных инстанций Javascript.0 или Javascript.1
                  Зачем это. Ну просто обособить свои объекты. Насоздавал например объектов в Javascript.1, а затем нечаяно грохнул его и все потерялось. А так все на месте и к ним можно обратиться из Javascript.0. И соответственно скрипты рассчитанные на одновременную работу с данными могут находится в разных инстанциях.
                  Но почему то не могу создать первоначальную папку в корне, куда потом прятать все содержимое. Позволяет только создать состояние|канал|устройство. Но если создавать любой из этих объектов, то все дочерние визуально лежат рядом.
                  • aurodionovA Offline
                    aurodionovA Offline
                    aurodionov
                    #274
                    Проще создать нужные объекты скриптом
                    CreateState('папка.объект', " ");
                    Пишу с пульта….
                    Пишу с пульта….
                    • I Offline
                      I Offline
                      instalator
                      #275
                      @kID:
                      Чего я неправильно делаю Скриншот 2017-02-25 21.53.53.png `
                      Создай сразу всю ветку. Например kitchen.flag
                        kID
                        #276
                        @aurodionov:
                        CreateState('папка.объект', " "); `
                        Но ведь тогда объект создается в той инстанции откуда скрипт запущен
                        т.е скрип
                        createState('flag.alarm_10min', false);
                        createState('flag.alarm_10min', false );
                        запущенный из javascript.0 создаст эти объекты в дереве javascript.0
                        @instalator:
                        Создай сразу всю ветку. Например kitchen.flag `
                        Я чувствую что не догоняю.
                        Только что понял: Корневое название должно состоять из двух частей разделённых точкой. Тогда оно при дальнейшем наполнении становится родителем. Я же просто создавал "Flag" и оно периодами вообще терялось из списка объектов, потом при обновлении появлялось, и главное к нему не цеплялись дочерние объекты, они просто лежали рядом. Хотя к названию дочерних цеплялся Flag.
                          kID
                          #277
                          Ну чего-то наворотил, но все же работает как-то не так.
                          Скрипт
                          reateState('Flag.0.Alarm_10min', false);
                          createState('Flag.0.Alarm_5min', false);
                          createState('Flag.0.test', 10);
                          setState (("Flag.0.Alarm_5min"), true, true);
                          setState (("Flag.0.test"/*test*/), 20, true);
                          log("Значение" + getState("Flag.0.test").val);
                          Если таких объектов нигде нет, то все создается в дереве javascript.0
                          И далее с этими объектами работаем как обычно
                          Но если я заранее в корне создаю эти объекты
                          то получаю следующее
                          или так
                          Т.е создается объект в дереве javascript.0 а работаем уже с объектом из корня.
                          Я так понимаю что ситуация как в анекдоте:
                          • Чего-то меня последнее время Гондурас беспокоит
                          • А вы его поменьше чешите
                          Т.е. в корне создавать объекты нельзя!!
                          • I Offline
                            I Offline
                            instalator
                            #278
                            @kID:
                            Скрипт
                            или так
                            Т.е. в корне создавать объекты нельзя!! `
                            Руками можно
                              spectrekr
                              #279
                              Раз вы руками создали в корне, то из скрипта уберите CreateState
                                kID
                                #280
                                @spectrekr:
                                Раз вы руками создали в корне, то из скрипта уберите CreateState `
                                Да я все понял. Я чего хотел показать - что используя одинаковый ID в случае с getState ищется первое вхождение с корня объектов
                                а для createState игнорируется все что выше Javascript.X
                                • I Offline
                                  I Offline
                                  instalator
                                  #281
                                  @kID:
                                  @spectrekr:
                                  а для createState игнорируется все что выше Javascript.X `
                                  Это так работает функция createState. Создает переменные в инстанции Javascript драйвера.
                                    Adav
                                    #282
                                    Появилась задача включать выключать драйвер из скрипта. Необходимость возникла по следующей причине - драйвер, работающий с оборудованием, в случае отключения оборудования продолжает пытаться до него достучаться и слать ошибки в логи. Оборудование не всегда должно быть включенным. Поэтому логично с выключением оборудования принудительно отключать и драйвер, занимающийся его опросом.
                                    Управление драйвером пробовал делать через setState, к примеру в тесте управления включением-выключением history:
                                    setState("system.adapter.history.0.alive", true); и setState("system.adapter.history.0.alive", false);
                                    Оно так работает и я получаю желаемое. Но… отключение драйвера - все нормально, а вот включение всякий раз дает ошибку в логе (но в итоге все равно делает что надо):
                                    history.0 2017-04-27 11:22:54.125 info starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.history, node: v4.8.2
                                    host.AdavHome 2017-04-27 11:22:53.290 info instance system.adapter.history.0 started with pid 11319
                                    host.AdavHome 2017-04-27 11:22:23.277 info Restart adapter system.adapter.history.0 because enabled
                                    host.AdavHome 2017-04-27 11:22:23.276 error instance system.adapter.history.0 terminated with code 7 (Adapter already running)
                                    host.AdavHome 2017-04-27 11:22:22.402 info instance system.adapter.history.0 started with pid 11285
                                    host.AdavHome 2017-04-27 11:22:22.402 info "system.adapter.history.0" enabled
                                    host.AdavHome 2017-04-27 11:22:22.402 info object change system.adapter.history.0
                                    Такое ощущение, что система думает что драйвер уже запущен и сначала его останавливает и только потом запускает. И всякий раз ошибка в лог. Ну и такое отрабатывает заметно медленнее, чем при включении руками.
                                    Может есть какой-то способ сделать это иначе или я что-то не так делаю?
                                    • H Offline
                                      Haus
                                      #283
                                      @Adav:
                                      Может есть какой-то способ сделать это иначе или я что-то не так делаю? `
                                      alive - это ка бы индикатор для чтения
                                      В драйвере Javascript включи опцию Разрешить команду "setObject"
                                      var obj = getObject("system.adapter.history.0");
                                      obj.common.enabled = false;  //or true
                                      setObject("system.adapter.history.0", obj);
                                      js-controller: 1.5.7 / node.js: v8.15.1/ npm: 6.4.1
                                      admin: 3.6.0
                                      javascript: 4.1.10
                                      web: 2.4.1 vis: 1.1.10
                                      cloud: 2.6.2
                                      Server: DELL FX170 / linux: Debian 9.5 Stretch
                                      Adapter: MegaD-2561, Mega-ES…
                                        Adav
                                        #284
                                        Разобрался, все работает, спасибо!
                                        • H Offline
                                          Haus
                                          #285
                                          @Adav:
                                          Function "setObject" is not allowed. Use adapter settings to allow it.
                                          В каком месте у адаптера это разрешается? `
                                          В админке драйвера Javascript включи опцию Разрешить команду "setObject"
                                          admin: 3.6.0
                                          javascript: 4.1.10
                                          cloud: 2.6.2
