  4. Was bedeutet diese Meldung
    6.3k
35 Beiträge 4 Kommentatoren 2.0k Aufrufe 3 Beobachtet
  • B Berlon
    @crunchip said in Was bedeutet diese Meldung:
    welche Version vom Admin ist installiert
    v5.1.25
    crunchipC Abwesend
    crunchipC Abwesend
    @berlon sagte in Was bedeutet diese Meldung:
    v5.1.25
    admin - v4.2.1
    • B Berlon
      pi@raspberrypi:~ $ iobroker update -i
      hash unchanged, use cached sources
      update done
      Adapter    "admin"         : 5.1.25   , installed 5.1.25
      Adapter    "alias-manager" : 1.2.3    , installed 1.2.3
      Adapter    "backitup"      : 2.1.17   , installed 2.1.17
      Adapter    "daswetter"     : 3.0.7    , installed 3.0.7
      Adapter    "devices"       : 1.0.9    , installed 1.0.9
      Adapter    "discovery"     : 2.7.0    , installed 2.7.0
      Adapter    "flot"          : 1.10.6   , installed 1.10.6
      Adapter    "heatingcontrol": 2.6.2    , installed 2.6.2
      Adapter    "history"       : 1.9.13   , installed 1.9.13
      Adapter    "hm-rega"       : 3.0.31   , installed 3.0.31
      Adapter    "hm-rpc"        : 1.14.45  , installed 1.14.45
      Adapter    "icons-addictive-flavour-png": 0.1.0   , installed 0.1.0
      Adapter    "info"          : 1.9.8    , installed 1.9.8
      Adapter    "javascript"    : 5.2.8    , installed 5.2.8
      Controller "js-controller" : 3.3.18   , installed 3.3.18
      Adapter    "material"      : 1.0.4    , installed 1.0.4
      Adapter    "node-red"      : 2.4.0    , installed 2.4.0
      Adapter    "openweathermap": 0.1.0    , installed 0.1.0
      Adapter    "ping"          : 1.5.0    , installed 1.5.0
      Adapter    "rpi2"          : 1.3.1    , installed 1.3.1
      Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
      Adapter    "socketio"      : 3.1.4    , installed 3.1.5
      Adapter    "sonoff"        : 2.4.5    , installed 2.4.5
      Adapter    "synology"      : 1.1.3    , installed 1.1.3
      Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
      Adapter    "upnp"          : 1.0.19   , installed 1.0.19
      Adapter    "vis"           : 1.4.4    , installed 1.4.4
      Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
      Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
      Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
      Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
      Adapter    "vis-plumb"     : 1.0.2    , installed 1.0.2
      Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
      Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
      Adapter    "web"           : 3.4.9    , installed 3.4.9
      pi@raspberrypi:~ $
      @berlon
      iobroker upload all
      Da weichen Versionen ab. Einmal alles hochladen.
      Was hast du denn da für eine alte Version wie installiert?
      Bei einer Neuinstallation dürfte da eigentlich ein admin5 installiert werden.
      B 2 Antworten Letzte Antwort
        @berlon
        iobroker upload all
        Berlon
        den uload all mache ich gleich.
        Log posten?
        Thomas BraunT crunchipC 3 Antworten Letzte Antwort
        • B Berlon
          Log posten?
          @berlon
          Nein, den upload durchführen.
            @berlon
            iobroker upload all
            Berlon
            Ich hatte gester eine Cleaninstallatin gemacht. Hatte aber Probleme mit Adaptern.
            Da wurde mir gesagt, ich solle das Backup aus der Syno nehmen und einspielen.
            Habe zwar Bedenken wegen den unterschiedlichen Adminversionen geäußert, das war aber scheinbar kein Problem.
            Nach dem Restor war der Broker wieder so wie ich ihn haben wollte.
            • B Berlon
              Log posten?
              crunchipC Abwesend
              crunchipC Abwesend
              @berlon und nachsehen ob nun admin.0.info.connection vorhanden ist
              • B Berlon
                Log posten?
                @berlon
                Kannst du bitte mal detailliert beschreiben, wie du welche Version des ioBrokers da installiert hast?
                • B Berlon
                  Dann war die Installation auf der Synology noch admin4?
                  Sollte man eh alles aktuell halten.
                  Das erklärt aber die Differenzen in den Versionsständen.
                    crunchipC Abwesend
                    crunchipC Abwesend
                    @thomas-braun sagte in Was bedeutet diese Meldung:
                    und "fehlenden" Adaptern, wenn man die zwei Ausgaben vergleicht
                      @berlon
                      Berlon
                      schrieb am zuletzt editiert von Berlon
                      @thomas-braun said in Was bedeutet diese Meldung:
                      Mit RPI-Imager das Image Raspberry PI OS (other) --> Raspberry PI OS Lite (32-bit) auf die SSD
                      Dann wurde mir diese Seite genannt. Danach habe ich dann den Broker Installiert. Danach dann das Backup von der Syno rein.
                      Der upload all ist durch. Braucht ihr irgendwelche Angaben??
                      • B Berlon
                        @berlon
                        Vergleich nochmal die Ausgaben von
                        iobroker list adapters
                        iobroker update -i
                        Sollte jetzt die gleichen Versionen liefern.
                        • B Berlon
                          das hat natürlich wieder die alten Versionen gebracht, wobei das beim admin nicht passieren sollte
                            Berlon
                            Wo find ich das?
                            pi@raspberrypi:~ $ iobroker list adapters
                            system.adapter.admin                   : admin          - v5.1.25
                            system.adapter.alias-manager           : alias-manager  - v1.2.3
                            system.adapter.backitup                : backitup       - v2.1.17
                            system.adapter.cloud                   : cloud          - v3.1.0
                            system.adapter.daswetter               : daswetter      - v3.0.7
                            system.adapter.devices                 : devices        - v1.0.9
                            system.adapter.discovery               : discovery      - v2.7.0
                            system.adapter.flot                    : flot           - v1.10.6
                            system.adapter.fritzdect               : fritzdect      - v0.2.4
                            system.adapter.heatingcontrol          : heatingcontrol - v2.6.2
                            system.adapter.history                 : history        - v1.9.13
                            system.adapter.hm-rega                 : hm-rega        - v3.0.31
                            system.adapter.hm-rpc                  : hm-rpc         - v1.14.45
                            system.adapter.icons-addictive-flavour-png: icons-addictive-flavour-png - v0.1.0
                            system.adapter.info                    : info           - v1.9.8
                            system.adapter.javascript              : javascript     - v5.2.8
                            system.adapter.linux-control           : linux-control  - v1.0.1
                            system.adapter.material                : material       - v1.0.4
                            system.adapter.node-red                : node-red       - v2.4.0
                            system.adapter.openweathermap          : openweathermap - v0.1.0
                            system.adapter.ping                    : ping           - v1.5.0
                            system.adapter.rpi2                    : rpi2           - v1.3.1
                            system.adapter.simple-api              : simple-api     - v2.6.1
                            system.adapter.socketio                : socketio       - v3.1.5
                            system.adapter.sonoff                  : sonoff         - v2.4.5
                            system.adapter.sql                     : sql            - v1.15.7
                            system.adapter.synology                : synology       - v1.1.3
                            system.adapter.terminal                : terminal       - v0.1.2
                            system.adapter.tr-064                  : tr-064         - v4.2.14
                            system.adapter.upnp                    : upnp           - v1.0.19
                            system.adapter.vis                     : vis            - v1.4.4
                            system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.7
                            system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
                            system.adapter.vis-justgage            : vis-justgage   - v1.0.2
                            system.adapter.vis-metro               : vis-metro      - v1.1.2
                            system.adapter.vis-plumb               : vis-plumb      - v1.0.2
                            system.adapter.vis-rgraph              : vis-rgraph     - v0.0.2
                            system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
                            system.adapter.weatherunderground      : weatherunderground - v3.2.1
                            system.adapter.web                     : web            - v3.4.9
                            system.adapter.yamaha                  : yamaha         - v0.4.0
                            update done
                            pi@raspberrypi:~ $
                              @homoran sagte in Was bedeutet diese Meldung:
                              Was wieder meinen 'Ansatz' unterstützt, die Versionen nicht veralten zu lassen. Große Sprünge in den Versionen sind halt immer schwierig.
                              • B Berlon
                                Wo find ich das?
                                update done
                                pi@raspberrypi:~ $
                                Wo find ich das?
                                Auf der Seite Objekte
                                und dann im Baum unter admin.0 -> Info
                                rechts Schraubenschlüssel
                                  Wo find ich das?
                                  Berlon
                                  • B Berlon
                                    @berlon Du hast da wirklich etwas spooky
                                    Mach mal STRG-F5 (oder das Apfel-Äquivalent zum neu laden)
                                    in der 4er Version gibt es den Punkt nämlich nicht
                                      Berlon
                                      Hat man eine Möglichkeit beim Broker ein AutoUpdate zu aktivieren?
                                      • B Berlon
                                        nein
                                        • B Berlon
                                          Nein, und das will man auch nicht.
