  4. Broker->BackItUp FTP->Synology
    6.3k
53 Beiträge 4 Kommentatoren 5.8k Aufrufe 3 Beobachtet
  • B Berlon
    die fehlenden Ordner habe ich erstellt, aber BackItUp beendet seine Arbeit nicht mehr. Der blaue Balken läuft immer weiter.
    Post mal das besher erstellte Log. Auf der Syno sind bisher noch keine Dateien aufgetaucht.
    Started iobroker ...
    [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.6.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"Backup/RPI_IOBroker/IOBroker","dirMinimal":"Backup/RPI_IOBroker/IOBroker","user":"RPI_IOBroker","pass":"****"}
    [DEBUG] [mount] - noserverino option: false
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=RPI_IOBroker,password=****,rw,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.6.10/Backup/RPI_IOBroker/IOBroker /opt/iobroker/backups"
    [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=RPI_IOBroker,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.6.10/Backup/RPI_IOBroker/IOBroker /opt/iobroker/backups"
    [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=RPI_IOBroker,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.6.10/Backup/RPI_IOBroker/IOBroker /opt/iobroker/backups
    mount error: cifs filesystem not supported by the system
    mount error(19): No such device
    Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
    [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount -t cifs -o username=RPI_IOBroker,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.6.10/Backup/RPI_IOBroker/IOBroker /opt/iobroker/backups
    [DEBUG] [iobroker] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.6.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"/Backup/RPI_IOBroker/IOBroker","dirMinimal":"Backup/RPI_IOBroker/IOBroker","user":"RPI_IOBroker","pass":"****","context":{"fileNames":[],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=RPI_IOBroker,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.6.10/Backup/RPI_IOBroker/IOBroker /opt/iobroker/backups\nmount error: cifs filesystem not supported by the system\nmount error(19): No such device\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n"},"done":[],"types":[]},"adapter":null},"dir":"/opt/iobroker","historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"192.168.6.10","debugging":true,"deleteOldBackup":true,"ownDir":true,"dir":"/Backup/RPI_IOBroker/Broker","dirMinimal":"/Backup/RPI_IOBroker/Broker","user":"RPI_IOBroker","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.6.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"Backup/RPI_IOBroker/IOBroker","dirMinimal":"Backup/RPI_IOBroker/IOBroker","user":"RPI_IOBroker","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":""},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"500","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"500","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
    [DEBUG] [iobroker] - host.raspberrypi 9522 states saved
    [DEBUG] [iobroker] - host.raspberrypi 11459 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_10_31-18_16_13_backupiobroker.tar.gz
    [DEBUG] [iobroker] - done
    [DEBUG] [historyDB] - compress from historyDB started ...
    [ERROR] [historyDB] - [IGNORED] Backitup cannot found source "undefined" for compress!
    [DEBUG] [cifs] - done
    [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.6.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"/Backup/RPI_IOBroker/IOBroker","dirMinimal":"Backup/RPI_IOBroker/IOBroker","user":"RPI_IOBroker","pass":"****","backupDir":"/opt/iobroker/backups","deleteBackupAfter":0}
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    [DEBUG] [clean] - done
    [DEBUG] [telegram] - done
    [DEBUG] [telegram] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.6.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"/Backup/RPI_IOBroker/IOBroker","dirMinimal":"Backup/RPI_IOBroker/IOBroker","user":"RPI_IOBroker","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_10_31-18_16_13_backupiobroker.tar.gz","/opt/iobroker/backups/historyDB_2021_10_31-18_16_24_backupiobroker.tar.gz"],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=RPI_IOBroker,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.6.10/Backup/RPI_IOBroker/IOBroker /opt/iobroker/backups\nmount error: cifs filesystem not supported by the system\nmount error(19): No such device\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n","historyDB":"Backitup cannot found source \"undefined\" for compress!"},"done":["iobroker"],"types":["iobroker"]},"adapter":null},"dir":"/opt/iobroker","historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"192.168.6.10","debugging":true,"deleteOldBackup":true,"ownDir":true,"dir":"/Backup/RPI_IOBroker/Broker","dirMinimal":"/Backup/RPI_IOBroker/Broker","user":"RPI_IOBroker","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.6.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"Backup/RPI_IOBroker/IOBroker","dirMinimal":"Backup/RPI_IOBroker/IOBroker","user":"RPI_IOBroker","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":""},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"500","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"500","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de","time":"31. Oktober 2021 um 18:16 Uhr"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [DEBUG] [historyHTML] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.6.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"/Backup/RPI_IOBroker/IOBroker","dirMinimal":"Backup/RPI_IOBroker/IOBroker","user":"RPI_IOBroker","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_10_31-18_16_13_backupiobroker.tar.gz","/opt/iobroker/backups/historyDB_2021_10_31-18_16_24_backupiobroker.tar.gz"],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=RPI_IOBroker,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.6.10/Backup/RPI_IOBroker/IOBroker /opt/iobroker/backups\nmount error: cifs filesystem not supported by the system\nmount error(19): No such device\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n","historyDB":"Backitup cannot found source \"undefined\" for compress!"},"done":["iobroker"],"types":["iobroker"]},"adapter":null},"dir":"/opt/iobroker","historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"192.168.6.10","debugging":true,"deleteOldBackup":true,"ownDir":true,"dir":"/Backup/RPI_IOBroker/Broker","dirMinimal":"/Backup/RPI_IOBroker/Broker","user":"RPI_IOBroker","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.6.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"Backup/RPI_IOBroker/IOBroker","dirMinimal":"Backup/RPI_IOBroker/IOBroker","user":"RPI_IOBroker","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":""},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"500","systemLang":"de","time":"31. Oktober 2021 um 18:16 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"500","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
    [DEBUG] [historyJSON] start with {"type":"creator","time":"02:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.6.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"/Backup/RPI_IOBroker/IOBroker","dirMinimal":"Backup/RPI_IOBroker/IOBroker","user":"RPI_IOBroker","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_10_31-18_16_13_backupiobroker.tar.gz","/opt/iobroker/backups/historyDB_2021_10_31-18_16_24_backupiobroker.tar.gz"],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=RPI_IOBroker,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.6.10/Backup/RPI_IOBroker/IOBroker /opt/iobroker/backups\nmount error: cifs filesystem not supported by the system\nmount error(19): No such device\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n","historyDB":"Backitup cannot found source \"undefined\" for compress!"},"done":["iobroker"],"types":["iobroker"]},"adapter":null},"dir":"/opt/iobroker","historyDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"192.168.6.10","debugging":true,"deleteOldBackup":true,"ownDir":true,"dir":"/Backup/RPI_IOBroker/Broker","dirMinimal":"/Backup/RPI_IOBroker/Broker","user":"RPI_IOBroker","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.6.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"Backup/RPI_IOBroker/IOBroker","dirMinimal":"Backup/RPI_IOBroker/IOBroker","user":"RPI_IOBroker","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":""},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"500","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"500","systemLang":"de","time":"31. Oktober 2021 um 18:16 Uhr"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
    [DEBUG] [umount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.6.10","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":true,"dir":"/Backup/RPI_IOBroker/IOBroker","dirMinimal":"Backup/RPI_IOBroker/IOBroker","user":"RPI_IOBroker","pass":"****","backupDir":"/opt/iobroker/backups"}
    @berlon sagte in Broker->BackItUp FTP->Synology:
    stimmt der Pfad soweit?
    wenn du ihn am PC aufrufst?
    dein Backup befindet sich auf dem Pi unter DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_10_31-18_16_13_backupiobroker.tar.gz weil der mount nicht klappt
    Wäre jetzt noch herauszufinden warum nicht
    GlasfaserG B 2 Antworten Letzte Antwort
      GlasfaserG Offline
      GlasfaserG Offline
      @Berlon
      Was sagt die Ausgabe von
      cat /proc/filesystems|grep cifs
      auf der Pi
        Berlon
        @homoran said in Broker->BackItUp FTP->Synology:
        im Browser aufgerufen geht der Firefox mit der Oberfläche der Syno auf.
        In Firefox eingegeben geht auch die Oberfläche auf.
        • B Berlon
          nicht im Browser - im Dateiexplorer
            Berlon
            mit dem Browser meinte ich den Dateiexplorer. Hier eingegeben
            geht der Firefox mit mit der Oberfläche der Syno auf.
            • B Berlon
              da sollte dann aber das Verzeichnis aufgehen
                Berlon
                bei mir geht mit Eingabe einer IP-Adresse im Dateiexplorer der Firefox auf. Gerade auch mit der IP des RasPi versucht.
                • B Berlon
                  hast du die beide // davor gesetzt?
                  HomoranH B 2 Antworten Letzte Antwort
                  • GlasfaserG Glasfaser
                    @Berlon
                    auf der Pi
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @Berlon
                    @glasfaser sagte in Broker->BackItUp FTP->Synology:
                    @Berlon
                    auf der Pi
                    Teste mal :
                    //192.168.6.10/Backup/RPI_IOBroker /IOBroker
                    //192.168.6.10/Backup /RPI_IOBroker/IOBroker
                      @homoran sagte in Broker->BackItUp FTP->Synology:
                      @Berlon
                      sorry, bei WIN natürlich \\
                        Berlon
                        schrieb am zuletzt editiert von Berlon
                        mit oder ohne Doppelslash, es grüßt immer der FF
                        ok so passiert was.
                        • B Berlon
                          ok so passiert was.
                          @berlon
                          Linux /
                          Windows \
                          Mix nicht möglich.
                            @Berlon
                            @Berlon
                            auf der Pi
                            Teste mal :
                            GlasfaserG Offline
                            GlasfaserG Offline
                            ok so passiert was.
                            \192.168.6.10\Backup\RPI_IOBroker\IOBroker
                            \192.168.6.10\Backup\RPI_IOBroker \IOBroker
                            \192.168.6.10\Backup \RPI_IOBroker \IOBroker
                            EDIT :
                            davor ist natürlich der \\ wird nur hier als \ angezeigt ,
                              ok so passiert was.
                              EDIT :
                              Berlon
                              @glasfaser said in Broker->BackItUp FTP->Synology:
                              hat nach Eingabe der Zugangsdaten vollen Zugriff, auch auf die darüber liegenden Ordner.
                              • B Berlon
                                die wurden aber doch vorhin nicht abgefragt!
                                ich dachte \\192.168.6.10\Backup wäre dein share?
                                hast du die Rechte doch nicht korrekt vergeben, so dass der User erst im Unterverzeichnis abgefragt wird, oder ist das Unterverzeichnis der share?
                                  @Berlon
                                  @Berlon
                                  auf der Pi
                                  Teste mal :
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  @Berlon
                                  @Berlon
                                  auf der Pi
                                  Zum dritten
                                    @Berlon
                                    @Berlon
                                    auf der Pi
                                    Zum dritten
                                    @Berlon
                                    @Berlon
                                    auf der Pi
                                    Zum dritten
                                    Das Leben ist kein Ponyhof!
                                    B GlasfaserG 2 Antworten Letzte Antwort
                                      @Berlon
                                      @Berlon
                                      auf der Pi
                                      Zum dritten
                                      Berlon
                                      so
                                      ich habe Zugriff auf:
                                      auf:
                                      und:
                                      Da sollten die Rechte stimmen.
                                      pi@raspberrypi:~ $ cat /proc/filesystems|grep cifs
                                      pi@raspberrypi:~ $
                                      Keine Ausgabe
                                      Auch mit sudo voran gestellt.
                                      pi@raspberrypi:~ $ sudo cat /proc/filesystems|grep cifs
                                      pi@raspberrypi:~ $
                                      GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
                                      • B Berlon
                                        so
                                        auf:
                                        und:
                                        pi@raspberrypi:~ $
                                        Keine Ausgabe
                                        pi@raspberrypi:~ $
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        @berlon
                                        sudo reboot
                                        danach nochmal prüfen
                                          @berlon
                                          sudo reboot
                                          Berlon
                                          @glasfaser
                                          Immer noch keine Ausgabe
                                          pi@raspberrypi:~ $
