  4. Test Adapter Meteoalarm v2.0.x
    6.6k
412 Beiträge 19 Kommentatoren 112.8k Aufrufe 19 Beobachtet
  • da_WoodyD da_Woody
    @jackblackson bei mir hats auch gerade gemeldet.
    meteoalarm.0
    2021-09-29 12:00:12.208	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    meteoalarm.0
    2021-09-29 12:00:12.205	error	result.feed.entry.forEach is not a function
    meteoalarm.0
    2021-09-29 12:00:12.205	error	TypeError: result.feed.entry.forEach is not a function at /opt/iobroker/node_modules/iobroker.meteoalarm/main.js:179:47 at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:304:18) at Parser.emit (events.js:314:20) at SAXParser.onclosetag (/opt/iobroker/node_modules/xml2js/lib/parser.js:262:26) at emit (/opt/iobroker/node_modules/sax/lib/sax.js:624:35) at emitNode (/opt/iobroker/node_modules/sax/lib/sax.js:629:5) at closeTag (/opt/iobroker/node_modules/sax/lib/sax.js:889:7) at SAXParser.write (/opt/iobroker/node_modules/sax/lib/sax.js:1436:13) at Parser.exports.Parser.Parser.parseString (/opt/iobroker/node_modules/xml2js/lib/parser.js:323:31) at Parser.parseString (/opt/iobroker/node_modules/xml2js/lib/parser.js:5:59)
    meteoalarm.0
    2021-09-29 12:00:12.204	error	unhandled promise rejection: result.feed.entry.forEach is not a function
    meteoalarm.0
    2021-09-29 12:00:12.203	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    meteoalarm.1
    2021-09-29 12:00:12.270	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    meteoalarm.1
    2021-09-29 12:00:12.262	error	result.feed.entry.forEach is not a function
    meteoalarm.1
    2021-09-29 12:00:12.262	error	TypeError: result.feed.entry.forEach is not a function at /opt/iobroker/node_modules/iobroker.meteoalarm/main.js:179:47 at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:304:18) at Parser.emit (events.js:314:20) at SAXParser.onclosetag (/opt/iobroker/node_modules/xml2js/lib/parser.js:262:26) at emit (/opt/iobroker/node_modules/sax/lib/sax.js:624:35) at emitNode (/opt/iobroker/node_modules/sax/lib/sax.js:629:5) at closeTag (/opt/iobroker/node_modules/sax/lib/sax.js:889:7) at SAXParser.write (/opt/iobroker/node_modules/sax/lib/sax.js:1436:13) at Parser.exports.Parser.Parser.parseString (/opt/iobroker/node_modules/xml2js/lib/parser.js:323:31) at Parser.parseString (/opt/iobroker/node_modules/xml2js/lib/parser.js:5:59)
    meteoalarm.1
    2021-09-29 12:00:12.262	error	unhandled promise rejection: result.feed.entry.forEach is not a function
    meteoalarm.1
    2021-09-29 12:00:12.261	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    jackblacksonJ Offline
    jackblackson
    #144
    @da_woody @sigi234 Super - bei mir kommt kein Fehler mehr. Könnt ihr bitte mal die 2.0.6 über Github ziehen - über diesen Link: https://github.com/jack-blackson/ioBroker.meteoalarm/tarball/v2.0.6. Dann sollte es keinen Fehler mehr geben.
    • jackblacksonJ jackblackson
      sigi234S Online
      sigi234S Online
      #145
      @jackblackson
      Super, Fehler ist weg. Danke.
      meteoalarm.0
      2021-09-29 14:32:02.510	info	Terminated (NO_ERROR): Without reason
      meteoalarm.0
      2021-09-29 14:32:02.509	info	Updated Weather Alarms for Oberösterreich -> 0 warning(s) found
      meteoalarm.0
      2021-09-29 14:32:02.140	info	starting. Version 2.0.6 in C:/Program Files/iobroker/Home/node_modules/iobroker.meteoalarm, node: v12.22.6, js-controller: 3.3.18
        Aktuelle Test Version 2.0.0
        Veröffentlichungsdatum 03.07.2021
        Github Link https://github.com/jack-blackson/ioBroker.meteoalarm
        Dieser Adapter bietet euch Unwetterwarnungen für ganz Europa.
        Da die Website meteoalarm.eu sehr bald abgeschaltet wird, und durch die neue Website meteoalarm.org ersetzt wird, gab es einen sehr große Umbau im Adapter. Hier wurde einiges an der Schnittstelle angepasst.
        Wichtig: Nach der Installation müsst ihr im Setup euer Land und eure Region auswählen - der Link, der bisher genutzt wurde, ist nicht mehr notwendig/funktioniert nicht mehr.
        Es gibt einige große Unterschiede zur vorigen Version:
        • Es gibt keine Objekte mehr für "Today" und "Tomorrow". Dafür gibt es jetzt pro Warnung einen Ordner, wo die Details zu finden sind. Der Gedanke ist, das ihr das HTML Widget nutzt. Weiters gibt es nun level auf der höchsten Ebene - dies ist die höchste Warnstufe, für die es aktuell Alarme gibt. Dies könnt ihr nützen, falls ihr das Widget gerne nur ab einem bestimmten Warnlevel anzeigen möchtet. Das selbe gilt für die Farbe.
        • Alarme werden bis zum Ablaufdatum angezeigt
        • Es ist leider aktuell keine Wetterkarte mehr verfügbar, wird hoffentlich irgendwann wieder kommen
        • Die Länder Schweiz, Portugal und Bulgarien sind leider vorerst nicht mehr verfügbar, da es noch Fehler in der Datenstruktur gibt, welche hoffentlich bald behoben werden.
        Solltet ihr irgendwelche Frage oder Probleme haben, bitte meldet euch einfach. Danke schon jetzt für euer Feedback!
        sigi234S Online
        sigi234S Online
        #146
        @jackblackson
        Hallo, neuer Fehler:
        meteoalarm.0
        2021-10-01 05:32:02.062	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        meteoalarm.0
        2021-10-01 05:32:02.061	info	terminating
        meteoalarm.0
        2021-10-01 05:32:01.973	error	Cannot read property '0' of undefined
        meteoalarm.0
        2021-10-01 05:32:01.973	error	TypeError: Cannot read property '0' of undefined at C:\Program Files\iobroker\Home\node_modules\iobroker.meteoalarm\main.js:173:46 at Parser.<anonymous> (C:\Program Files\iobroker\Home\node_modules\xml2js\lib\parser.js:304:18) at Parser.emit (events.js:314:20) at Parser.EventEmitter.emit (domain.js:483:12) at SAXParser.onclosetag (C:\Program Files\iobroker\Home\node_modules\xml2js\lib\parser.js:262:26) at emit (C:\Program Files\iobroker\Home\node_modules\sax\lib\sax.js:624:35) at emitNode (C:\Program Files\iobroker\Home\node_modules\sax\lib\sax.js:629:5) at closeTag (C:\Program Files\iobroker\Home\node_modules\sax\lib\sax.js:889:7) at SAXParser.write (C:\Program Files\iobroker\Home\node_modules\sax\lib\sax.js:1436:13) at Parser.exports.Parser.Parser.parseString (C:\Program Files\iobroker\Home\node_modules\xml2js\lib\parser.js:323:31)
        meteoalarm.0
        2021-10-01 05:32:01.968	error	unhandled promise rejection: Cannot read property '0' of undefined
        meteoalarm.0
        2021-10-01 05:32:01.968	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        meteoalarm.0
        2021-10-01 05:32:01.676	info	starting. Version 2.0.6 in C:/Program Files/iobroker/Home/node_modules/iobroker.meteoalarm, node: v12.22.6, js-controller: 3.3.18
        Edit:
        gelöst mit Version 2.0.7
        • jackblacksonJ Offline
          jackblackson
          schrieb am zuletzt editiert von jackblackson
          #147
          @sigi234 Heute ist wohl das erste Mal, das es keinen Wetteralarm gibt, der Feed für ganz Österreich ist leer :) Hab es behoben in v2.0.7 - https://github.com/jack-blackson/ioBroker.meteoalarm. Danke für eure Tests!
          sigi234S da_WoodyD 2 Antworten Letzte Antwort
            sigi234S Online
            sigi234S Online
            #148
            @jackblackson sagte in Test Adapter Meteoalarm v2.0.x:
            meteoalarm.0
            2021-10-01 07:15:02.690	info	Terminated (NO_ERROR): Without reason
            meteoalarm.0
            2021-10-01 07:15:02.689	info	Updated Weather Alarms for Oberösterreich -> 0 warning(s) found
            meteoalarm.0
            2021-10-01 07:15:02.349	info	starting. Version 2.0.7 in C:/Program Files/iobroker/Home/node_modules/iobroker.meteoalarm, node: v12.22.6, js-controller: 3.3.18
              da_WoodyD Online
              da_WoodyD Online
              #149
              @jackblackson hehe, kommt davon, wenn man nicht scrollt. 2.0.6 gelesen, gleich drübergejubelt. dann erst weiter gescrollt, oops, da is ja noch eine 2.0.7.
              :D
              keine fehlermeldung im moment... 👍
                mrhary
                #150
                Kann man die Anzahl der aktuellen Meldungen irgendwie ausgeben, bräuchte es für meine Benachrichtigungen
                jackblacksonJ 1 Antwort Letzte Antwort
                • M mrhary
                  jackblackson
                  #151
                  @mrhary Aktuell nicht. Du meinst einfach im Hauptordner ein Objekt mit "Anzahl aktive Alarme"?
                  Ich hab dir grad in Version 2.0.8 den Datenpunkt hinzugefügt, du kannst es dir gerne ansehen, einfach über diesen Link installieren: https://github.com/jack-blackson/ioBroker.meteoalarm/tarball/v2.0.8
                  M da_WoodyD 2 Antworten Letzte Antwort
                    mrhary
                    #152
                    @jackblackson cool probier ich dann gleich
                      da_WoodyD Online
                      da_WoodyD Online
                      #153
                      @jackblackson hüstel...
                      welcher wäre das?
                      krawutzikapuzi, plötzlich sind se da... :D
                        sigi234S Online
                        sigi234S Online
                        #154
                        @jackblackson
                        jetzt kommt dieser Fehler: Ev. wegen JS Update?
                        meteoalarm.3
                        2021-11-26 08:48:04.014	error	Fehler: Error: Text data outside of root node.Line: 1Column: 1Char: 1
                        meteoalarm.3
                        2021-11-26 08:24:09.617	error	DB closed
                        meteoalarm.3
                        2021-11-26 08:24:09.617	error	Error: DB closed at Redis.sendCommand (C:\Program Files\iobroker\Home\node_modules\ioredis\built\redis\index.js:628:24) at Redis.get (C:\Program Files\iobroker\Home\node_modules\ioredis\built\commander.js:122:25) at StateRedisClient.setState (C:\Program Files\iobroker\Home\node_modules\@iobroker\db-states-redis\lib\states\statesInRedisClient.js:479:40) at Adapter.setState (C:\Program Files\iobroker\Home\node_modules\iobroker.js-controller\lib\adapter.js:6213:35)
                        meteoalarm.3
                        2021-11-26 08:24:09.608	error	unhandled promise rejection: DB closed
                        meteoalarm.3
                        2021-11-26 08:24:09.607	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        meteoalarm.3
                        2021-11-26 08:24:08.561	error	Fehler: Error: Text data outside of root node.Line: 1Column: 1Char: 1
                        Plattform: Windows
                        RAM: 16 GB
                        Node.js: 14.18.1
                        NPM: 6.14.15
                        JS Controller: 3.3.20
                        Admin: 5.1.28
                        Web: 3.4.16
                        • da_WoodyD Online
                          da_WoodyD Online
                          #155
                          @sigi234 die selben versionen, aber unter linux, keine errors...
                          • sigi234S sigi234
                            @jackblackson
                            meteoalarm.3
                            meteoalarm.3
                            meteoalarm.3
                            meteoalarm.3
                            meteoalarm.3
                            meteoalarm.3
                            Plattform: Windows
                            RAM: 16 GB
                            Node.js: 14.18.1
                            NPM: 6.14.15
                            Admin: 5.1.28
                            Web: 3.4.16
                            jackblackson
                            #156
                            @sigi234 hab grad auch auf 3.3.20 aktualisiert, und bei den Adaptern überall auf die Version im Latest, und bekomme diesen Fehler auch nicht. Welche Region fragst du ab?
                            Ich seh aktuell auch noch nichts im Sentry.
                              sigi234S Online
                              sigi234S Online
                              #157
                              @jackblackson
                              Austria - Salzburg
                              • sigi234S sigi234
                                @jackblackson
                                Austria - Salzburg
                                jackblackson
                                #158
                                @sigi234 Hab grad umgestellt, bei mir find ich diesen Fehler nicht, hab grad noch das node.js aktualisiert auf 14. Einziger Unterschied ist, ich habs auf Linux laufen, nicht auf Windows..
                                da_WoodyD sigi234S 2 Antworten Letzte Antwort
                                  da_WoodyD Online
                                  da_WoodyD Online
                                  #159
                                  @jackblackson sieht irgendwie danach aus, das es an windows liegt...
                                    sigi234S Online
                                    sigi234S Online
                                    #160
                                    Auf Version 2.0.8 geupdatet, derzeit kommt kein Fehler.
                                    • sigi234S sigi234
                                      da_WoodyD Online
                                      da_WoodyD Online
                                      #161
                                      @sigi234 na das haste verschwiegen... ;)
                                        sigi234S Online
                                        sigi234S Online
                                        #162
                                        @da_woody sagte in Test Adapter Meteoalarm v2.0.x:
                                        Jetzt kommt das schon wieder: V 2.0.10
                                        meteoalarm.5
                                        2021-12-28 20:54:05.320	error	Fehler: Error: Text data outside of root node.Line: 1Column: 1Char: 1
                                        meteoalarm.4
                                        2021-12-28 20:52:08.398	error	DB closed
                                        meteoalarm.4
                                        2021-12-28 20:52:08.398	error	Error: DB closed at Redis.sendCommand (C:\Program Files\iobroker\Home\node_modules\ioredis\built\redis\index.js:628:24) at Redis.get (C:\Program Files\iobroker\Home\node_modules\ioredis\built\commander.js:122:25) at StateRedisClient.setState (C:\Program Files\iobroker\Home\node_modules\@iobroker\db-states-redis\lib\states\statesInRedisClient.js:479:40) at Adapter.setState (C:\Program Files\iobroker\Home\node_modules\iobroker.js-controller\lib\adapter.js:6215:35)
                                        meteoalarm.4
                                        2021-12-28 20:52:08.388	error	unhandled promise rejection: DB closed
                                        meteoalarm.4
                                        2021-12-28 20:52:08.388	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        meteoalarm.4
                                        2021-12-28 20:52:07.749	error	Fehler: Error: Text data outside of root node.Line: 1Column: 1Char: 2
                                        meteoalarm.5
                                        2021-12-28 20:27:05.600	error	Fehler: Error: Text data outside of root node.Line: 1Column: 1Char: 1
                                        meteoalarm.4
                                        2021-12-28 20:26:05.370	error	Fehler: Error: Text data outside of root node.Line: 1Column: 1Char: 2
                                        meteoalarm.4
                                        2021-12-28 20:00:12.959	error	Fehler: Error: Text data outside of root node.Line: 1Column: 1Char: 2
                                        meteoalarm.5
                                        2021-12-28 20:00:12.233	error	Fehler: Error: Text data outside of root node.Line: 1Column: 1Char: 1
                                        • sigi234S sigi234
                                          meteoalarm.5
                                          meteoalarm.4
                                          meteoalarm.4
                                          meteoalarm.4
                                          meteoalarm.4
                                          meteoalarm.4
                                          meteoalarm.5
                                          meteoalarm.4
                                          meteoalarm.4
                                          meteoalarm.5
                                          jackblackson
                                          #163
                                          @sigi234 Ok..seh da leider nichts im Sentry. Ist das nur einmal bei der Ausführung passiert, oder mehrmals?
