  5. Blocky script
Blocky script
86 Beiträge 6 Kommentatoren 12.0k Aufrufe 5 Beobachtet
  • I ingenii
    @cinimod
    dein hinwies ist richtig, Danke
    aber dieser trigger wen ich was am termostat endere mach nur bis Steuere TH10 auf Wahr, er kommt nicht weiter.Eine frage: gibt das ein sin wen für jeder wahr oder falsh ist extra trigger?
      <variables>
        <variable id="SIGD6q1KUTGFjp#3gO^{">offene Fenster</variable>
      </variables>
      <block type="on_ext" id="K,WN,pgM_?_@X4vx9kNn" x="-87" y="-1038">
        <mutation xmlns="http://www.w3.org/1999/xhtml" items="5"></mutation>
        <value name="OID0">
          <shadow type="field_oid" id="g^#UD(O)#46O[YL/yhiu">
            <field name="oid">sonoff.0.ZigBee_Bridge1.ZbReceived_0x1123_Contact</field>
          </shadow>
        </value>
        <value name="OID1">
          <shadow type="field_oid" id="GR{OtJXvaxmJ/8frKVV5">
            <field name="oid">sonoff.0.ZigBee_Bridge1.ZbReceived_0x5982_Contact</field>
          </shadow>
        </value>
        <value name="OID2">
          <shadow type="field_oid" id="AaDu2IdLTc;_8Y^(=#1u">
            <field name="oid">sonoff.0.ZigBee_Bridge1.ZbReceived_0x600E_Contact</field>
          </shadow>
        </value>
        <value name="OID3">
          <shadow type="field_oid" id="gz?y}5:(-k]7M;_c)L@c">
            <field name="oid">sonoff.0.ZigBee_Bridge1.ZbReceived_0x20A3_Contact</field>
          </shadow>
        </value>
        <value name="OID4">
          <shadow type="field_oid" id="f,#bPavRADQa!^9vgT;r">
            <field name="oid">sonoff.0.ZigBee_Bridge1.ZbReceived_0xD449_Contact</field>
          </shadow>
        </value>
        <statement name="STATEMENT">
          <block type="controls_if" id="zr))xYp5q6uk7gWR:FLp">
            <value name="IF0">
              <block type="logic_compare" id="(%ip:yl;!KUbNeYJO=Q.">
                <field name="OP">EQ</field>
                <value name="A">
                  <block type="on_source" id="IQvqF`Ea*52V%WOo$(BG">
                  </block>
                </value>
                <value name="B">
                  <block type="math_number" id="YaM59`_}h-7w]wlp%rz]">
                    <field name="NUM">1</field>
                  </block>
                </value>
              </block>
            </value>
            <statement name="DO0">
              <block type="control" id="hS]=O?t$f/y`yv?xV.9v">
                <field name="OID">sonoff.0.Temparature_wohnzimmer(TH10).POWER</field>
                <value name="VALUE">
                  <block type="logic_boolean" id="@WvR96o@/GT_W,v[-k@;">
                  </block>
                </value>
                <next>
                  <block type="variables_set" id="]qW3c_5Vo7}]mwMJaX]u">
                    <field name="VAR" id="SIGD6q1KUTGFjp#3gO^{">offene Fenster</field>
                      <block type="logic_boolean" id="%|=KaL92,D:1}t?+_kh@">
                      </block>
                    </value>
                  </block>
                </next>
              </block>
            </statement>
            <value name="IF1">
              <block type="logic_operation" id="NI74tl{Cv%y2nnZ2mq(_" inline="false">
                <field name="OP">AND</field>
                <value name="A">
                  <block type="logic_operation" id="nBhW:|6IjFd#]:==r9MT" inline="false">
                    <value name="A">
                      <block type="logic_operation" id="TzDrBAgL)l{6h%e)Nbix" inline="false">
                        <value name="A">
                          <block type="logic_compare" id="H-by~#=i7qLd];I!ss,u">
                            <value name="A">
                              <block type="get_value" id="G{e*#Ck_W4)[t!9NfppK">
                                <field name="OID">sonoff.0.ZigBee_Bridge1.ZbReceived_0x1123_Contact</field>
                              </block>
                            </value>
                            <value name="B">
                              <block type="math_number" id="tV{:u[3b2[XI5;6o#uwv">
                                <field name="NUM">0</field>
                              </block>
                            </value>
                          </block>
                        </value>
                        <value name="B">
                          <block type="logic_compare" id="(Bj)7ZJ(0pgXXEA`sjl4">
                            <value name="A">
                              <block type="get_value" id="CN}w9(9wU2-hnR|}zN~M">
                                <field name="OID">sonoff.0.ZigBee_Bridge1.ZbReceived_0x5982_Contact</field>
                              </block>
                            </value>
                            <value name="B">
                              <block type="math_number" id="qxF?+P?(5WT4+Zh~VDzH">
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </value>
                    <value name="B">
                      <block type="logic_operation" id="iAW5jBZ|80_MVv0zs#04" inline="false">
                        <value name="A">
                          <block type="logic_compare" id="=FJ$#)NF)p%K+ci}.G+{">
                            <value name="A">
                              <block type="get_value" id="b0E:[G*)^Jkwfko9)-UG">
                                <field name="OID">sonoff.0.ZigBee_Bridge1.ZbReceived_0x600E_Contact</field>
                              </block>
                            </value>
                            <value name="B">
                              <block type="math_number" id="y@6zGn;xb0N/DCub4E+j">
                              </block>
                            </value>
                          </block>
                        </value>
                        <value name="B">
                          <block type="logic_compare" id="7uPMqgWG]Q790FDLTidp">
                            <value name="A">
                              <block type="get_value" id="5o;cwewhu(gE!B3`kDDT">
                                <field name="OID">sonoff.0.ZigBee_Bridge1.ZbReceived_0x20A3_Contact</field>
                              </block>
                            </value>
                            <value name="B">
                              <block type="math_number" id="]T=$eX#l;JqAc9b,Y}+*">
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
                <value name="B">
                  <block type="logic_compare" id="(OQ76rw~]R]9Q_P/kA`V">
                    <value name="A">
                      <block type="get_value" id="R-*;=g!1Qh_#Zl_G0VM4">
                        <field name="OID">sonoff.0.ZigBee_Bridge1.ZbReceived_0xD449_Contact</field>
                      </block>
                    </value>
                    <value name="B">
                      <block type="math_number" id="aeH:*7-Gn3!c~HF5au^!">
                      </block>
                    </value>
                  </block>
                </value>
              </block>
            </value>
            <statement name="DO1">
              <block type="variables_set" id="ceR.;izW_r3Ty20RG_EX">
                  <block type="logic_boolean" id="D=!E,]q}FEHKUapa+q=2">
                  </block>
                </value>
              </block>
            </statement>
          </block>
        </statement>
        <next>
          <block type="on_ext" id="xDq%i~$rGx~A.83cmM%;">
            <mutation xmlns="http://www.w3.org/1999/xhtml" items="2"></mutation>
            <value name="OID0">
              <shadow type="field_oid" id="S5Ja?RFgi-amy%b3nasc">
                <field name="oid">hm-rpc.1.000E9D8993AF70.1.ACTUAL_TEMPERATURE</field>
              </shadow>
            </value>
            <value name="OID1">
              <shadow type="field_oid" id=",x^o!!V53@cT%;x8@hr]">
                <field name="oid">hm-rpc.1.000E9D8993AF70.1.SET_POINT_TEMPERATURE</field>
              </shadow>
            </value>
              <block type="controls_if" id="^IQpxvAC2OFS~7?Wb54p">
                <value name="IF0">
                  <block type="logic_operation" id="=,{!f,Bw@+IW)fgy6X!," inline="false">
                    <value name="A">
                      <block type="logic_compare" id="wv?fv3Sv#4)xrUA!h,;d">
                        <field name="OP">LT</field>
                        <value name="A">
                          <block type="field_oid" id="Lq8qjAp2+9`o!gUlT+bp">
                          </block>
                        </value>
                        <value name="B">
                          <block type="field_oid" id="tF5CWW~t~IicQF.9T@Yb">
                          </block>
                        </value>
                      </block>
                    </value>
                    <value name="B">
                      <block type="logic_negate" id="g0]-Go:bzYX?[3gMBj,7">
                        <value name="BOOL">
                          <block type="variables_get" id=":vB%}8-l)m2uIW$kGmf^">
                          </block>
                        </value>
                      </block>
                    </value>
                  </block>
                </value>
                  <block type="control" id="BCFn=IlgKqu+C@xy)z`p">
                      <block type="logic_boolean" id="CjsW,Fb567aTJf@*m@?U">
                      </block>
                    </value>
                  </block>
                </statement>
                <value name="IF1">
                  <block type="logic_compare" id="r*KEn=z,[kyIxuL5}P;p">
                    <field name="OP">GT</field>
                    <value name="A">
                      <block type="field_oid" id="1^:mkFciSEdEvK(u_vhn">
                      </block>
                    </value>
                    <value name="B">
                      <block type="field_oid" id="SJp4x+Q.G?cX]Oc6Ik,5">
                      </block>
                    </value>
                  </block>
                </value>
                  <block type="control" id="@*N1BGqFp,k14kZ$emx]">
                      <block type="logic_boolean" id="knxl8#k^UDaS0z/qJVoA">
                      </block>
                    </value>
                  </block>
                </statement>
              </block>
            </statement>
          </block>
        </next>
      </block>
    </xml>
    CinimodC Offline
    CinimodC Offline
    Cinimod
    @ingenii sagte in Blocky script:
    @cinimod
    Nein
    I 1 Antwort Letzte Antwort
    • CinimodC Cinimod
      @cinimod
      Nein
      I Offline
      I Offline
      ingenii
      @cinimod
      Wie ich schon geschrieben hab jetzt ist das Gut.
      Jetzt muss ich noch was anderes ausprobieren.
      ich hab 3 räume und ich muss leider nur ein Realei schalten das heitzung startet.
      ich hab 3 Termostaten und 3 verschiedene Temperatur.
      Wen 1 Raum (Termostat sagt du musst heizen schalte das Relais an das mir die andere räume das gleiche Relais auf Flash setzten und das geht in so ein loop.
      • I ingenii
        @cinimod
        CinimodC Offline
        CinimodC Offline
        Cinimod
        @ingenii
        Erstell dir für jeden Raum einen Datenpunkt, statt dem TH10 Schaltetst du diesen Datanpunkt true/false (ein script für jeden Raum).
        Dann noch ein weiters Skript welche die drei Datenpunkte überwacht, und das Relais schaltet wenn mindestens einer der drei Datenpunkte wahr ist, sonst false
        • CinimodC Cinimod
          @ingenii
          I Offline
          I Offline
          ingenii
          @cinimod
          Dantenpunkte hab ich, das hab ich schon gelernt, für Script brauche ich bisschen zeit .Danke für dein zeit.
          • I ingenii
            @cinimod
            CinimodC Offline
            CinimodC Offline
            Cinimod
            @ingenii
            das selbe Prinzip:
            Falls einer der Trigger-Datenpunkte Wahr -> Heizung an
            Falls alle der Datenpunkte Falsch -> Heizung aus
            • CinimodC Cinimod
              @ingenii
              das selbe Prinzip:
              I Offline
              I Offline
              ingenii
              @cinimod
              es steuert nur Falsch
                <variables>
                  <variable id="8YSUs.sSyApb+.X)hAKj">Wert</variable>
                </variables>
                <block type="on_ext" id="PbE+r6ibR_B!K.FQ}Fa$" x="-20" y="-547">
                  <mutation xmlns="http://www.w3.org/1999/xhtml" items="3"></mutation>
                  <value name="OID0">
                    <shadow type="field_oid" id="R*u+`^~1q(-5RFx%o(wQ">
                      <field name="oid">0_userdata.0.Testordner.Kinderzimmer_temp_Heizung</field>
                    </shadow>
                  </value>
                  <value name="OID1">
                    <shadow type="field_oid" id="d(7kaO!c#|rUIt#UbB={">
                      <field name="oid">0_userdata.0.Testordner.Schalfzimmer_temp_Heizung</field>
                    </shadow>
                  </value>
                  <value name="OID2">
                    <shadow type="field_oid" id="%,@ga-xK38tS$Zg=d_y0">
                      <field name="oid">0_userdata.0.Testordner.Wohnzimmer_temp_Wohnzimmer</field>
                    </shadow>
                  </value>
                    <block type="controls_if" id="r*B?@=L`.guY]MLJ.H@.">
                      <value name="IF0">
                        <block type="variables_get" id="k+E7_WDJK*^j!|vQNZ/*">
                          <field name="VAR" id="8YSUs.sSyApb+.X)hAKj">Wert</field>
                        </block>
                      </value>
                        <block type="control" id="B=1I|N7S`4~26PlSAQ-%">
                            <block type="logic_boolean" id="y3;43=:xLQ(0wRm`(^`}">
                            </block>
                          </value>
                        </block>
                      </statement>
                      <value name="IF1">
                        <block type="logic_operation" id="}2~Ew~gv@IZK*(xct$ew" inline="false">
                          <value name="A">
                            <block type="logic_operation" id=",`JZOgL5aBSu8HVPZ0NW" inline="false">
                              <value name="A">
                                <block type="logic_compare" id="r//HYzBmYjm~s0OP1M`z">
                                  <value name="A">
                                    <block type="get_value" id="X%j!o4/4cvnH?_-=y8W-">
                                      <field name="OID">0_userdata.0.Testordner.Kinderzimmer_temp_Heizung</field>
                                    </block>
                                  </value>
                                  <value name="B">
                                    <block type="logic_boolean" id="O=x2`^..rQlbo?6Ng!xs">
                                    </block>
                                  </value>
                                </block>
                              </value>
                              <value name="B">
                                <block type="logic_compare" id="BV^sU|2@;Fh{+tPIUP6*">
                                  <value name="A">
                                    <block type="get_value" id="+=iCY2C6oN%.dQ/^kxe{">
                                      <field name="OID">0_userdata.0.Testordner.Schalfzimmer_temp_Heizung</field>
                                    </block>
                                  </value>
                                  <value name="B">
                                    <block type="logic_boolean" id="Hsk~I1ACC%z$h!rX)wHd">
                                    </block>
                                  </value>
                                </block>
                              </value>
                            </block>
                          </value>
                          <value name="B">
                            <block type="logic_compare" id="Yu*GN1tHPn|]JAtxBnAd">
                              <value name="A">
                                <block type="get_value" id="N;ZrYsp838;u5R=`Lh`H">
                                  <field name="OID">0_userdata.0.Testordner.Wohnzimmer_temp_Wohnzimmer</field>
                                </block>
                              </value>
                              <value name="B">
                                <block type="logic_boolean" id="0h4:VOw~9d0+03^9HqNd">
                                </block>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                        <block type="control" id="QGsS]+Dr|0`!9]b]Eo0Z">
                            <block type="logic_boolean" id="%=;;af{H(h7mui7rXqo+">
                            </block>
                          </value>
                        </block>
                      </statement>
                    </block>
                  </statement>
                </block>
              </xml>
              • I ingenii
                @cinimod
                  <variables>
                  </variables>
                    <value name="OID0">
                      </shadow>
                    </value>
                    <value name="OID1">
                      </shadow>
                    </value>
                    <value name="OID2">
                      </shadow>
                    </value>
                        <value name="IF0">
                          </block>
                        </value>
                              </block>
                            </value>
                          </block>
                        </statement>
                        <value name="IF1">
                            <value name="A">
                                <value name="A">
                                    <value name="A">
                                      </block>
                                    </value>
                                    <value name="B">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <value name="B">
                                    <value name="A">
                                      </block>
                                    </value>
                                    <value name="B">
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                            <value name="B">
                                <value name="A">
                                  </block>
                                </value>
                                <value name="B">
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                              </block>
                            </value>
                          </block>
                        </statement>
                      </block>
                    </statement>
                  </block>
                </xml>
                CinimodC Offline
                CinimodC Offline
                Cinimod
                @ingenii
                seltsam, sollte eigentlich gehen, dachte ich zumindest ...
                sind deine selbst erstellten Datenpunkte type boolean (logikwert) ?
                dann mach es so :
                   <value name="OID0">
                     </shadow>
                   </value>
                   <value name="OID1">
                     </shadow>
                   </value>
                   <value name="OID2">
                     </shadow>
                   </value>
                       <value name="IF0">
                         <block type="logic_operation" id="HX[~7p30kaYu$)lN#N?|" inline="false">
                           <field name="OP">OR</field>
                           <value name="A">
                             <block type="logic_operation" id="(1lKe/~%[/ym5C0WEI+)" inline="false">
                               <value name="A">
                                 <block type="logic_compare" id="hJ?OQP@wN3Qj7(`eg2RC">
                                   <value name="A">
                                     <block type="get_value" id="=a~[{q/wL_8NvB0GYBKy">
                                     </block>
                                   </value>
                                   <value name="B">
                                     <block type="logic_boolean" id="~)rU]Uf|RxwC*L;6:-ob">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <value name="B">
                                 <block type="logic_compare" id=":Sq$w}$5=)O`pmo=2yf;">
                                   <value name="A">
                                     <block type="get_value" id="AkjL]g},C{TRi-.EI~bP">
                                     </block>
                                   </value>
                                   <value name="B">
                                     <block type="logic_boolean" id=";Dgi8Kou1OA5*{Kno*:B">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                             </block>
                           </value>
                           <value name="B">
                             <block type="logic_compare" id="(d7~t,DzVnE%Uw?Vdt1D">
                               <value name="A">
                                 <block type="get_value" id="lCutf)+r1!K)FN7WmI![">
                                 </block>
                               </value>
                               <value name="B">
                                 <block type="logic_boolean" id="8?~ty)5jrT/G=W1G0Y,7">
                                 </block>
                               </value>
                             </block>
                           </value>
                         </block>
                       </value>
                             </block>
                           </value>
                         </block>
                       </statement>
                       <value name="IF1">
                           <value name="A">
                               <value name="A">
                                   <value name="A">
                                     </block>
                                   </value>
                                   <value name="B">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <value name="B">
                                   <value name="A">
                                     </block>
                                   </value>
                                   <value name="B">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                             </block>
                           </value>
                           <value name="B">
                               <value name="A">
                                 </block>
                               </value>
                               <value name="B">
                                 </block>
                               </value>
                             </block>
                           </value>
                         </block>
                       </value>
                             </block>
                           </value>
                         </block>
                       </statement>
                     </block>
                   </statement>
                 </block>
                </xml>
                I 2 Antworten Letzte Antwort
                • CinimodC Cinimod
                  @ingenii
                  dann mach es so :
                     <value name="OID0">
                       </shadow>
                     </value>
                     <value name="OID1">
                       </shadow>
                     </value>
                     <value name="OID2">
                       </shadow>
                     </value>
                         <value name="IF0">
                             <value name="A">
                                 <value name="A">
                                     <value name="A">
                                       </block>
                                     </value>
                                     <value name="B">
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                                 <value name="B">
                                     <value name="A">
                                       </block>
                                     </value>
                                     <value name="B">
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                               </block>
                             </value>
                             <value name="B">
                                 <value name="A">
                                   </block>
                                 </value>
                                 <value name="B">
                                   </block>
                                 </value>
                               </block>
                             </value>
                           </block>
                         </value>
                               </block>
                             </value>
                           </block>
                         </statement>
                         <value name="IF1">
                             <value name="A">
                                 <value name="A">
                                     <value name="A">
                                       </block>
                                     </value>
                                     <value name="B">
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                                 <value name="B">
                                     <value name="A">
                                       </block>
                                     </value>
                                     <value name="B">
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                               </block>
                             </value>
                             <value name="B">
                                 <value name="A">
                                   </block>
                                 </value>
                                 <value name="B">
                                   </block>
                                 </value>
                               </block>
                             </value>
                           </block>
                         </value>
                               </block>
                             </value>
                           </block>
                         </statement>
                       </block>
                     </statement>
                   </block>
                  </xml>
                  I Offline
                  I Offline
                  ingenii
                  @cinimod
                  Danke muss ich schon schlafen gehen, mach ich morgen weiter, nur zu Info es schaltet bei Wohnzimmer AN und AUS, das ist schon super.
                  <Danke
                  • CinimodC Cinimod
                    @ingenii
                    dann mach es so :
                       <value name="OID0">
                         </shadow>
                       </value>
                       <value name="OID1">
                         </shadow>
                       </value>
                       <value name="OID2">
                         </shadow>
                       </value>
                           <value name="IF0">
                               <value name="A">
                                   <value name="A">
                                       <value name="A">
                                         </block>
                                       </value>
                                       <value name="B">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <value name="B">
                                       <value name="A">
                                         </block>
                                       </value>
                                       <value name="B">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <value name="B">
                                   <value name="A">
                                     </block>
                                   </value>
                                   <value name="B">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                             </block>
                           </value>
                                 </block>
                               </value>
                             </block>
                           </statement>
                           <value name="IF1">
                               <value name="A">
                                   <value name="A">
                                       <value name="A">
                                         </block>
                                       </value>
                                       <value name="B">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <value name="B">
                                       <value name="A">
                                         </block>
                                       </value>
                                       <value name="B">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <value name="B">
                                   <value name="A">
                                     </block>
                                   </value>
                                   <value name="B">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                             </block>
                           </value>
                                 </block>
                               </value>
                             </block>
                           </statement>
                         </block>
                       </statement>
                     </block>
                    </xml>
                    I Offline
                    I Offline
                    ingenii
                    @cinimod
                    heute getestet Funkcionier perfekt, ich muss jetzt für jeder zimmer (jetzt sind das 4räume) ein Thermostat bestellen zum einstellen direkt.Script anpassen und Fertig.
                    am anfang hast du mich gefragt wie das mit licht so funktioniert kann.
                    in jeden zimmer hab ich T3 von sonoff ,1 Licht ,2 Rollo Auf und 3 Rollo Zu
                    mein einfaches Script:
                    Bis jetzt kein Problem da mit, ich glaub wen da in eine Richtung geht ist das kein Problem, ich schalte wand Schalter mit Sonoff dual in Rollo.
                    Noch einamal Danke
                    • I ingenii
                      @cinimod
                      Noch einamal Danke
                      CinimodC Offline
                      CinimodC Offline
                      Cinimod
                      @ingenii
                      Ja witzig, ich hatte es zufällig gestern noch bei jemandem anderem gesehen.
                      Ich habe noch nie mit dem Block gearbeitet, aber offenbar ist das der einzige Block der tatsächlich keinen Trigger braucht um zu reagieren. Musste erstmal Google´n was mit dem los ist 😇
                      Auch wieder was gelernt ... 😀 👍 Werde ich jetzt bestimmt auch mal nutzen
                      • CinimodC Cinimod
                        @ingenii
                        I Offline
                        I Offline
                        ingenii
                        @cinimod
                        ist mir jetzt eingefallen ideal ist der Script sicher nicht, besser wehre wen ein Fenster offen ist sollte gewunste Temperatur auf zb.12 Grad umstellen, aber ich für mich das da auch super 👍
                        • I ingenii
                          @cinimod
                          CinimodC Offline
                          CinimodC Offline
                          Cinimod
                          @ingenii das lässt sich ja leicht ändern 😉
                          • CinimodC Cinimod
                            I Offline
                            I Offline
                            ingenii
                            schrieb am zuletzt editiert von ingenii
                            @cinimod
                            Hallo ,
                            meine Lieferung von Homematic ist nicht gekommen dann bin ich nur Provisorium aufgebaut und ich hab Geist schalterrung Troc Alle in Datenpunk auf False sind.
                            Danke für jeder Tip
                            • CinimodC Cinimod
                              I Offline
                              I Offline
                              ingenii
                              @cinimod
                              Mein Konfig:
                              Kinderzimmer:
                                <variables>
                                </variables>
                                <block type="comment" id="_9LVB+mDFTm*bn-vUbQ{" x="-88" y="-1062">
                                  <field name="COMMENT">Kinderzimmer</field>
                                  <next>
                                    <block type="on_ext" id="K,WN,pgM_?_@X4vx9kNn">
                                      <value name="OID0">
                                        </shadow>
                                      </value>
                                      <value name="OID1">
                                        </shadow>
                                      </value>
                                      <value name="OID2">
                                        </shadow>
                                      </value>
                                      <value name="OID3">
                                        </shadow>
                                      </value>
                                      <value name="OID4">
                                        </shadow>
                                      </value>
                                          <value name="IF0">
                                              <value name="A">
                                                </block>
                                              </value>
                                              <value name="B">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                                </block>
                                              </value>
                                              <next>
                                                    </block>
                                                  </value>
                                                </block>
                                              </next>
                                            </block>
                                          </statement>
                                          <value name="IF1">
                                              <value name="A">
                                                  <value name="A">
                                                      <value name="A">
                                                          <value name="A">
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                          <value name="A">
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                      <value name="A">
                                                          <value name="A">
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                          <value name="A">
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <value name="B">
                                                  <value name="A">
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                                </block>
                                              </value>
                                            </block>
                                          </statement>
                                        </block>
                                      </statement>
                                      <next>
                                        <block type="on_ext" id="PbE+r6ibR_B!K.FQ}Fa$">
                                          <value name="OID0">
                                              <field name="oid">sonoff.0.Temparature_kinderzimmer(TH10).AM2301_Temperature</field>
                                            </shadow>
                                          </value>
                                          <value name="OID1">
                                              <field name="oid">hm-rpc.1.000A1D8998382C.1.SET_POINT_TEMPERATURE</field>
                                            </shadow>
                                          </value>
                                              <value name="IF0">
                                                  <value name="A">
                                                      <value name="A">
                                                          <field name="OID">sonoff.0.Temparature_kinderzimmer(TH10).AM2301_Temperature</field>
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        <block type="get_value" id="JTFkdm].gf$UMbo%^75a">
                                                          <field name="OID">hm-rpc.1.000A1D8998382C.1.SET_POINT_TEMPERATURE</field>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    <block type="logic_negate" id="uy%HA(W4G:,?!bqWeHm%">
                                                      <value name="BOOL">
                                                        <block type="variables_get" id="d.x;V!*lz-mDZx7[Wa;a">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                                <block type="control" id="#5GKyB|4=F4zr^[k^cQk">
                                                    <block type="logic_boolean" id="wjLU9dHN#h7Y?!IU[;}G">
                                                    </block>
                                                  </value>
                                                </block>
                                              </statement>
                                              <value name="IF1">
                                                <block type="logic_compare" id="9ky*iEK/IP-4$]#(bfJ3">
                                                  <value name="A">
                                                    <block type="get_value" id="bGYSrX7HR^lxGJ)+x_#p">
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    <block type="get_value" id="4h}L8%1PBaP2pIb3+y=z">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                                <block type="control" id="i@!4wAn+FGd4.YpiNN-=">
                                                    <block type="logic_boolean" id="ft~;-EU^W[TB:.[I(TFD">
                                                    </block>
                                                  </value>
                                                </block>
                                              </statement>
                                            </block>
                                          </statement>
                                        </block>
                                      </next>
                                    </block>
                                  </next>
                                </block>
                              </xml>
                              • I ingenii
                                @cinimod
                                Mein Konfig:
                                Kinderzimmer:
                                  <variables>
                                  </variables>
                                    <next>
                                        <value name="OID0">
                                          </shadow>
                                        </value>
                                        <value name="OID1">
                                          </shadow>
                                        </value>
                                        <value name="OID2">
                                          </shadow>
                                        </value>
                                        <value name="OID3">
                                          </shadow>
                                        </value>
                                        <value name="OID4">
                                          </shadow>
                                        </value>
                                            <value name="IF0">
                                                <value name="A">
                                                  </block>
                                                </value>
                                                <value name="B">
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                                  </block>
                                                </value>
                                                <next>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </next>
                                              </block>
                                            </statement>
                                            <value name="IF1">
                                                <value name="A">
                                                    <value name="A">
                                                        <value name="A">
                                                            <value name="A">
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                            <value name="A">
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                        <value name="A">
                                                            <value name="A">
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                            <value name="A">
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                <value name="B">
                                                    <value name="A">
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </statement>
                                          </block>
                                        </statement>
                                        <next>
                                            <value name="OID0">
                                              </shadow>
                                            </value>
                                            <value name="OID1">
                                              </shadow>
                                            </value>
                                                <value name="IF0">
                                                    <value name="A">
                                                        <value name="A">
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                        <value name="BOOL">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </statement>
                                                <value name="IF1">
                                                    <value name="A">
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </statement>
                                              </block>
                                            </statement>
                                          </block>
                                        </next>
                                      </block>
                                    </next>
                                  </block>
                                </xml>
                                I Offline
                                I Offline
                                ingenii
                                @Cinimod
                                Schalfzimmer:
                                  <variables>
                                  </variables>
                                  <block type="comment" id="/0CV^O!1aoUk:BM=JQvY" x="-62" y="-1062">
                                    <field name="COMMENT">Schlafzimmer</field>
                                    <next>
                                        <value name="OID0">
                                          </shadow>
                                        </value>
                                        <value name="OID1">
                                          </shadow>
                                        </value>
                                        <value name="OID2">
                                          </shadow>
                                        </value>
                                        <value name="OID3">
                                          </shadow>
                                        </value>
                                        <value name="OID4">
                                          </shadow>
                                        </value>
                                            <value name="IF0">
                                                <value name="A">
                                                  </block>
                                                </value>
                                                <value name="B">
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                                  </block>
                                                </value>
                                                <next>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </next>
                                              </block>
                                            </statement>
                                            <value name="IF1">
                                                <value name="A">
                                                    <value name="A">
                                                        <value name="A">
                                                            <value name="A">
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                            <value name="A">
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                        <value name="A">
                                                            <value name="A">
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                            <value name="A">
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                <value name="B">
                                                    <value name="A">
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </statement>
                                          </block>
                                        </statement>
                                        <next>
                                            <value name="OID0">
                                                <field name="oid">sonoff.0.Temparature_Schlafzimmer(TH16).SI7021_Temperature</field>
                                              </shadow>
                                            </value>
                                            <value name="OID1">
                                                <field name="oid">hm-rpc.1.000A1D89983B40.1.SET_POINT_TEMPERATURE</field>
                                              </shadow>
                                            </value>
                                                <value name="IF0">
                                                    <value name="A">
                                                        <value name="A">
                                                            <field name="OID">sonoff.0.Temparature_Schlafzimmer(TH16).SI7021_Temperature</field>
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                            <field name="OID">hm-rpc.1.000A1D89983B40.1.SET_POINT_TEMPERATURE</field>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                        <value name="BOOL">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </statement>
                                                <value name="IF1">
                                                    <value name="A">
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </statement>
                                              </block>
                                            </statement>
                                          </block>
                                        </next>
                                      </block>
                                    </next>
                                  </block>
                                </xml>
                                • I ingenii
                                  @Cinimod
                                  Schalfzimmer:
                                    <variables>
                                    </variables>
                                      <next>
                                          <value name="OID0">
                                            </shadow>
                                          </value>
                                          <value name="OID1">
                                            </shadow>
                                          </value>
                                          <value name="OID2">
                                            </shadow>
                                          </value>
                                          <value name="OID3">
                                            </shadow>
                                          </value>
                                          <value name="OID4">
                                            </shadow>
                                          </value>
                                              <value name="IF0">
                                                  <value name="A">
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                                    </block>
                                                  </value>
                                                  <next>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </next>
                                                </block>
                                              </statement>
                                              <value name="IF1">
                                                  <value name="A">
                                                      <value name="A">
                                                          <value name="A">
                                                              <value name="A">
        </block>
                                                              </value>
                                                              <value name="B">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                              <value name="A">
        </block>
                                                              </value>
                                                              <value name="B">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                          <value name="A">
                                                              <value name="A">
        </block>
                                                              </value>
                                                              <value name="B">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                              <value name="A">
        </block>
                                                              </value>
                                                              <value name="B">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                      <value name="A">
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </statement>
                                            </block>
                                          </statement>
                                          <next>
                                              <value name="OID0">
                                                </shadow>
                                              </value>
                                              <value name="OID1">
                                                </shadow>
                                              </value>
                                                  <value name="IF0">
                                                      <value name="A">
                                                          <value name="A">
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                          <value name="BOOL">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </statement>
                                                  <value name="IF1">
                                                      <value name="A">
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </statement>
                                                </block>
                                              </statement>
                                            </block>
                                          </next>
                                        </block>
                                      </next>
                                    </block>
                                  </xml>
                                  I Offline
                                  I Offline
                                  ingenii
                                  @Cinimod
                                  Datenpunkt:
                                      <mutation xmlns="http://www.w3.org/1999/xhtml" items="4"></mutation>
                                      <value name="OID0">
                                        </shadow>
                                      </value>
                                      <value name="OID1">
                                        </shadow>
                                      </value>
                                      <value name="OID2">
                                        <shadow type="field_oid" id="DC]}pm|WdYkqYH*s(U9Y">
                                          <field name="oid">0_userdata.0.Testordner.Gastezimmer_temp_Heizung</field>
                                        </shadow>
                                      </value>
                                      <value name="OID3">
                                          <field name="oid">0_userdata.0.Testordner.Bad_1og_temp_Heizung</field>
                                        </shadow>
                                      </value>
                                          <value name="IF0">
                                              <value name="A">
                                                  <value name="A">
                                                      <value name="A">
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                      <value name="A">
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <value name="B">
                                                <block type="logic_operation" id="+JV5hbNlN?udb*8%+_wB" inline="false">
                                                  <value name="A">
                                                      <value name="A">
                                                          <field name="OID">0_userdata.0.Testordner.Bad_1og_temp_Heizung</field>
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    <block type="logic_compare" id="#~vQ_5RX|_OzdP,gvbXs">
                                                      <value name="A">
                                                        <block type="get_value" id="NN^Pp*t0!]Ex-q:um~.H">
                                                          <field name="OID">0_userdata.0.Testordner.Gastezimmer_temp_Heizung</field>
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        <block type="logic_boolean" id="12ipKo{9_9HGRQa*E_N1">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                              <field name="OID">sonoff.0.Heizung_R08.POWER8</field>
                                                </block>
                                              </value>
                                              <next>
                                                <block type="control" id="~P;l$0_#%wUL.ixiKHxX">
                                                  <field name="OID">sonoff.0.Heizung_R08.POWER7</field>
                                                    <block type="logic_boolean" id="E^)mfO(7;lQ@6`d3r$5d">
                                                    </block>
                                                  </value>
                                                </block>
                                              </next>
                                            </block>
                                          </statement>
                                          <value name="IF1">
                                              <value name="A">
                                                <block type="logic_operation" id="x0;06[4!-J-wM?6Xg-O:" inline="false">
                                                  <value name="A">
                                                      <value name="A">
                                                          <value name="A">
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                          <value name="A">
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                      <value name="A">
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <value name="B">
                                                <block type="logic_compare" id="/l,p+tv-nab=p0o3q=#]">
                                                  <value name="A">
                                                    <block type="get_value" id="T|(8__(z0vg?@DK,})PM">
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    <block type="logic_boolean" id="b[}@z,E%pfC_t+azaXqk">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                            <block type="control" id="WLLdD.vKC!_^=OYxX*Rp">
                                                <block type="logic_boolean" id="ldc#N@{RI=c{~~U$;#vk">
                                                </block>
                                              </value>
                                              <next>
                                                <block type="control" id="M;TncfhU?kR;[#Dn_Z)_">
                                                    <block type="logic_boolean" id="o@IGbqby.SrxA-ZhATy#">
                                                    </block>
                                                  </value>
                                                </block>
                                              </next>
                                            </block>
                                          </statement>
                                        </block>
                                      </statement>
                                    </block>
                                  </xml>
                                  • I ingenii
                                    @cinimod
                                    Mein Konfig:
                                    Kinderzimmer:
                                      <variables>
                                      </variables>
                                        <next>
                                            <value name="OID0">
                                              </shadow>
                                            </value>
                                            <value name="OID1">
                                              </shadow>
                                            </value>
                                            <value name="OID2">
                                              </shadow>
                                            </value>
                                            <value name="OID3">
                                              </shadow>
                                            </value>
                                            <value name="OID4">
                                              </shadow>
                                            </value>
                                                <value name="IF0">
                                                    <value name="A">
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                      </block>
                                                    </value>
                                                    <next>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </statement>
                                                <value name="IF1">
                                                    <value name="A">
                                                        <value name="A">
                                                            <value name="A">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                            <value name="B">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                            <value name="A">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                            <value name="B">
        <value name="A">
        </block>
        </value>
        <value name="B">
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                        <value name="A">
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </statement>
                                              </block>
                                            </statement>
                                            <next>
                                                <value name="OID0">
                                                  </shadow>
                                                </value>
                                                <value name="OID1">
                                                  </shadow>
                                                </value>
                                                    <value name="IF0">
                                                        <value name="A">
                                                            <value name="A">
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                            <value name="BOOL">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </statement>
                                                    <value name="IF1">
                                                        <value name="A">
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </statement>
                                                  </block>
                                                </statement>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </xml>
                                    I Offline
                                    I Offline
                                    ingenii
                                    @Cinimod
                                    Was gehört hier ?
                                    Switch oder State ?
                                    • I ingenii
                                      @Cinimod
                                      Was gehört hier ?
                                      Switch oder State ?
                                      CinimodC Offline
                                      CinimodC Offline
                                      Cinimod
                                      @Cinimod
                                      Was gehört hier ?
                                      Switch oder State ?
                                      State
                                      Was genau ist denn jetzt dein Problem ?
                                      • CinimodC Cinimod
                                        @Cinimod
                                        Was gehört hier ?
                                        Switch oder State ?
                                        State
                                        I Offline
                                        I Offline
                                        ingenii
                                        @cinimod
                                        es hat immer was Heizung für 1 bis 2 Minuten eingeschaltet auch wen Temperatur zu hoch wahr.Problem wahr das ich immer zu spät gesehen hab und nicht nachvollziehen kann von wo das kommt.
                                        Dann Detail suche und bin drauf gekommen das ein Temp sensor bei Sonoff kaputt ist liefert ab und zu verschiedene Daten.
                                        Jetzt passt alles,
                                        • CinimodC Cinimod
                                          @Cinimod
                                          Was gehört hier ?
                                          Switch oder State ?
                                          State
                                          I Offline
                                          I Offline
                                          ingenii
                                          #66
                                          @cinimod
                                          hab ein kleines Problem, in Verwendung sind deine Scripts .In Wohnzimmer passiert das mir etwas Datenpunkt auf False steuert und ich weiß nicht was. Ich hab schon ein neuen Datenpunk erstellt das der nicht unabsichtlich irgendwo in anders drinnen ist und passiert wieder, ich stelle Set Point Temp um 2 Grad mehr das ich weiss das sicher Heizung ganze zeit lauf.
                                          Es ist ein Fußboden Heizung deswegen rennt Heizung nur cca 45 Minuten und Dann geht automatisch heizung auf OFF aber nicht Datenpunkt denn steuere ich mit einem Script der heist Restart Datenpunk aber bei dem hab ich 90Minuten also muss Heizung starten(Datenpunk) und Datenpunk wen Temp nicht erreicht Set Temp musst erst nach 90Minuten auf Datenpunkt False und dan soll wieder Staten, aber bei mir auch wen ich dieser Neustart Datenpunk deaktiviere geht jeden cca 10 Minuten Datenpunk auf False und gleich wieder auf True.
                                          Script :
                                            <block type="on_ext" id="xDq%i~$rGx~A.83cmM%;" x="-287" y="-787">
                                              <value name="OID0">
                                                  <field name="oid">hm-rpc.1.000A9D899F65CB.1.ACTUAL_TEMPERATURE</field>
                                                </shadow>
                                              </value>
                                              <value name="OID1">
                                                  <field name="oid">hm-rpc.1.000A9D899F65CB.1.SET_POINT_TEMPERATURE</field>
                                                </shadow>
                                              </value>
                                                  <value name="IF0">
                                                      <value name="A">
                                                        <block type="get_value" id="~FmMS%jS(50Pu}fG;xD(">
                                                          <field name="OID">hm-rpc.1.000A9D899F65CB.1.ACTUAL_TEMPERATURE</field>
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        <block type="get_value" id="29K2ZhjmlM^.$R%?*O?r">
                                                          <field name="OID">hm-rpc.1.000A9D899F65CB.1.SET_POINT_TEMPERATURE</field>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                      <field name="OID">0_userdata.0.Testordner.Wohnzimmer_heizung</field>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </statement>
                                                  <value name="IF1">
                                                      <field name="OP">GTE</field>
                                                      <value name="A">
                                                        <block type="get_value" id="2T7[PNo`#A#Y.u(Q`c*H">
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        <block type="get_value" id="E+-PcFA;?0rjyn;u~35W">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </statement>
                                                </block>
                                              </statement>
                                            </block>
                                          </xml>
                                          Restart Datenpunkt
                                            <block type="on" id="g^ts;K(Z?cyM6vDaU%4X" x="-162" y="-420">
                                              <field name="CONDITION">true</field>
                                                <block type="control" id="J.Vb7Iz{qxWpi`hHY_:6">
                                                  <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="true"></mutation>
                                                  <field name="DELAY_MS">90</field>
                                                  <field name="UNIT">min</field>
                                                    <block type="logic_boolean" id="tw;W8Kimp?RG,kGR5}(e">
                                                    </block>
                                                  </value>
                                                </block>
                                              </statement>
                                            </block>
                                          </xml>
