  4. Wasserzähler - Version 2 - all-in-device
    6.8k
wasserzählerversion 2ai on the edgecnnwater meterwater gaugeesp32ov2640neuronale netzehausautomatisierung
3.4k Beiträge 240 Kommentatoren 2.4m Aufrufe 231 Beobachtet
  • J jomjol
    @toki1973 sagte in Wasserzähler - Version 2 - all-in-device:
    @jomjol
    Hier in der Runde 34 ist der Sprung der qm. Genügt dieses Message Log? Oder benötigst du noch ein anderes?
    2021-10-13T19:37:26: CPU Temperature: 50.0
    2021-10-13T19:41:23: task_autodoFlow - next round - Round #33
    2021-10-13T19:41:23: 	FlowControll.doFlow - ClassFlowMakeImage
    2021-10-13T19:41:31: 	FlowControll.doFlow - ClassFlowAlignment
    2021-10-13T19:41:48: 	FlowControll.doFlow - ClassFlowCNNGeneral
    2021-10-13T19:41:59: 	FlowControll.doFlow - ClassFlowCNNGeneral
    2021-10-13T19:42:17: 	FlowControll.doFlow - ClassFlowPostProcessing
    2021-10-13T19:42:17: 	FlowControll.doFlow - ClassFlowMQTT
    2021-10-13T19:42:17: sent publish successful in MQTTPublish, msg_id=62211, wasserza/connection, connected
    2021-10-13T19:42:17: sent publish successful in MQTTPublish, msg_id=55763, wasserza/uptime, 9373
    2021-10-13T19:42:17: sent publish successful in MQTTPublish, msg_id=25312, wasserza/freeMem, 3016240
    2021-10-13T19:42:17: sent publish successful in MQTTPublish, msg_id=20092, wasserza/main/value, 356.6935
    2021-10-13T19:42:17: sent publish successful in MQTTPublish, msg_id=38553, wasserza/main/error, no error
    2021-10-13T19:42:17: sent publish successful in MQTTPublish, msg_id=59939, wasserza/main/rate, 0.021010
    2021-10-13T19:42:17: sent publish successful in MQTTPublish, msg_id=45564, wasserza/main/timestamp, 2021-10-13T19:41:31
    2021-10-13T19:42:17: sent publish successful in MQTTPublish, msg_id=64229, wasserza/main/json, {"value":356.6935,"error":"no error","rate":0.021010,"timestamp":"2021-10-13T19:41:31"}
    2021-10-13T19:42:17: task_autodoFlow - round done
    2021-10-13T19:42:17: CPU Temperature: 49.4
    2021-10-13T19:46:14: task_autodoFlow - next round - Round #34
    2021-10-13T19:46:14: 	FlowControll.doFlow - ClassFlowMakeImage
    2021-10-13T19:46:22: 	FlowControll.doFlow - ClassFlowAlignment
    2021-10-13T19:46:39: 	FlowControll.doFlow - ClassFlowCNNGeneral
    2021-10-13T19:46:50: 	FlowControll.doFlow - ClassFlowCNNGeneral
    2021-10-13T19:47:08: 	FlowControll.doFlow - ClassFlowPostProcessing
    2021-10-13T19:47:08: 	FlowControll.doFlow - ClassFlowMQTT
    2021-10-13T19:47:08: sent publish successful in MQTTPublish, msg_id=31038, wasserza/connection, connected
    2021-10-13T19:47:08: sent publish successful in MQTTPublish, msg_id=35981, wasserza/uptime, 9664
    2021-10-13T19:47:08: sent publish successful in MQTTPublish, msg_id=4997, wasserza/freeMem, 3017908
    2021-10-13T19:47:08: sent publish successful in MQTTPublish, msg_id=14523, wasserza/main/value, 357.5935
    2021-10-13T19:47:08: sent publish successful in MQTTPublish, msg_id=35095, wasserza/main/error, no error
    2021-10-13T19:47:08: sent publish successful in MQTTPublish, msg_id=25084, wasserza/main/rate, 0.185566
    2021-10-13T19:47:08: sent publish successful in MQTTPublish, msg_id=59672, wasserza/main/timestamp, 2021-10-13T19:46:22
    2021-10-13T19:47:08: sent publish successful in MQTTPublish, msg_id=56396, wasserza/main/json, {"value":357.5935,"error":"no error","rate":0.185566,"timestamp":"2021-10-13T19:46:22"}
    2021-10-13T19:47:08: task_autodoFlow - round done
    Das sieht für mich danach aus, als ob einfach die Ziffer 6 falsch erkannt wurde. Hast du MaxRateValue eingestellt?
    toki1973
    #1684
    @jomjol ja den hatte ich auf 3 Welcher Wert wäre denn zu empfehlen?
    Die 6 wird ja nur beim Übergang auf 7 nicht erkannt
    NUC, PROXMOX, Grafana, Influx, Unify
    • T toki1973
      jomjol
      #1685
      Ich würde den auf 1 oder leicht kleiner stellen. Das sind 1000l Wasser und die verbrauchst du i.d.R. nicht zwischen zwei Messungen. Wenn dann mal eine Ziffer falsch erkannt wird, dann wird der Wert einfach verworfen.
      • J jomjol
        @homecineplexx sagte in Wasserzähler - Version 2 - all-in-device:
        Also bei mir haut das auch nur ganz schlecht hin:
        Meine Wasseruhr zeigt digital 01016 an als
        Value: 996.8434
        Previous Value: 996.84338
        Raw Value: 01006.9356
        Error:
        Rate too high - Read: 1006.9356 - Pre: 996.8434
        kann oder muss ich da irgendwas tun, damit das korrekt funkt?
        danke
        lg
        als version hab ich folgendes drauf:
        Git-Base-Branch: master - v8.5.0 - 2021-10-07
        HTML Version: 10.2.0
        Hier liegt das Problem ja schon in den Rohdaten, denn der angezeigt Wert stimmt nicht mit dem echten überein. Ursache dürfte eine falscher Erkennung sein. Da dein Bild aber sehr unscharf ist, ist das nicht überraschend. Versuche mal, das Bild scharf zu stellen und dann nochmals abwarten.
        homecineplexx
        #1686
        @jomjol said in Wasserzähler - Version 2 - all-in-device:
        Value: 996.8434
        Error:
        danke
        lg
        hallo
        gibts da eine möglichkeit, wie ich das scharf stellen kann?
        danke dir
        lg
        • H homecineplexx
          Value: 996.8434
          Error:
          danke
          lg
          hallo
          danke dir
          lg
          senior1418
          #1687
          @homecineplexx
          habe beim erstem mal mit einem 8-9 Maulschlüssel gegengehalten und mit Kombizange gedreht. Ist einmal der Sicherungslack gebrochen geht's einfach.
          • H Offline
            homecineplexx
            #1688
            @senior1418 said in Wasserzähler - Version 2 - all-in-device:
            @homecineplexx
            bitte was hast du da genau gedreht???? da ist doch nix zum drehen
            M J 2 Antworten Letzte Antwort
            • J jomjol
              @watcherkb Der Kondensator dient zur Spannungsstabilierung. Bei mir hängen 3 ESP32s an einer Stromversorgung und wenn die dann ungünstig ihre LEDs und Kameras anwerfen, dann hilft das (vielleicht :-) ).
              oberfraggerO Offline
              oberfragger
              schrieb am zuletzt editiert von oberfragger
              #1689
              @jomjol Welche Größe hat der Elko? Und wo haste den angeklemmt? Also einfach zwischen GND und VCC?
              Ansonsten aber ziemlich cool die Logik. Aktuell erkennt er die "1" nicht... er weiss aber dass das wohl ne 1 sein soll. ;) Hat das mal unter PreSet Value eingegeben.
              • H homecineplexx
                @homecineplexx
                mameier1234
                #1690
                @homecineplexx Klar ist da was zum drehen... Das Objektiv ist mit einem Lack gesichert, und wie homecineplexx schreibt... wenn der Lack gebrochen ist, dann kann man den Focus einstellen... (aber Vorsichtig !!!! )
                Grüße,
                Martin
                • H homecineplexx
                  @homecineplexx
                  jomjol
                  #1691
                  @homecineplexx
                  @homecineplexx: schau mal ins Wiki auf der Seite Installation, dort ist es der zweite Absatz von oben, inkl. eines Bildes
                  https://github.com/jomjol/AI-on-the-edge-device/wiki/Installation
                  H 1 Antwort Letzte Antwort
                  • oberfraggerO oberfragger
                    jomjol
                    #1692
                    @oberfragger 1000µF und ja zwischen GND und VCC
                    • J jomjol
                      @homecineplexx
                      homecineplexx
                      #1693
                      @jomjol super, dankeschön!!!! das probier ich gleich morgen aus
                      • H homecineplexx
                        senior1418
                        #1694
                        @homecineplexx
                        und am besten vor verdrehen des Objektivs die vorhandene Position mit einem Stift markieren. Versuche zu Anfang mal 90 Grad nach links zu drehen und richte weitere Korrekturen dem Ergebnis endsprechend aus.
                          micklafisch
                          #1695
                          ich hab seit dem Update auf die Version 8.5.0 ein Problem, dass das MQTT nicht mehr funktioniert.
                          Ich kam von der Version 7.0.1. Die Daten in der config.ini wurden nicht verändert. Ich habe auch testweise den Part MQTT in der config.ini einmal deaktiviert/reboot/neu aktiviert/reboot. Danach auch nochmal alle MQTT Daten neu eingetragen, wieder reboot, aber trotzdem werden keine Daten an ioBroker gesendet.
                          Der Adapter in ioB ist bereit (wenn ich z.b. eine Tasmota Steckdose auf MQTT aktiviere werden sofort die Daten empfangen). Aus dem Log werde ich nicht schlau:
                          2021-10-22T09:16:47: Time zone set to CET-1CEST,M3.5.0,M10.5.0/3
                          2021-10-22T09:16:47: =============================================================================================
                          2021-10-22T09:16:47: =================================== Main Started ============================================
                          2021-10-22T09:16:51: Time zone set to CET-1CEST
                          2021-10-22T09:16:51: task_autodoFlow - next round - Round #1
                          2021-10-22T09:16:51: 	FlowControll.doFlow - ClassFlowMakeImage
                          2021-10-22T09:16:59: 	FlowControll.doFlow - ClassFlowAlignment
                          2021-10-22T09:17:19: 	FlowControll.doFlow - ClassFlowCNNGeneral
                          2021-10-22T09:17:33: 	FlowControll.doFlow - ClassFlowCNNGeneral
                          2021-10-22T09:17:50: 	FlowControll.doFlow - ClassFlowPostProcessing
                          2021-10-22T09:17:50: task_autodoFlow - round done
                          2021-10-22T09:17:50: CPU Temperature: 53.3
                          2021-10-22T09:17:54: info_get_handler
                          2021-10-22T09:21:42: task_autodoFlow - next round - Round #2
                          2021-10-22T09:21:42: 	FlowControll.doFlow - ClassFlowMakeImage
                          2021-10-22T09:21:50: 	FlowControll.doFlow - ClassFlowAlignment
                          2021-10-22T09:22:10: 	FlowControll.doFlow - ClassFlowCNNGeneral
                          2021-10-22T09:22:24: 	FlowControll.doFlow - ClassFlowCNNGeneral
                          2021-10-22T09:22:29: download_get_handler
                          2021-10-22T09:22:30: download_get_handler
                          2021-10-22T09:22:41: 	FlowControll.doFlow - ClassFlowPostProcessing
                          2021-10-22T09:22:41: task_autodoFlow - round done
                          2021-10-22T09:22:41: CPU Temperature: 53.3
                          2021-10-22T09:22:57: download_get_handler
                          2021-10-22T09:23:20: delete_post_handler
                          2021-10-22T09:23:20: download_get_handler
                          2021-10-22T09:23:20: upload_post_handler
                          2021-10-22T09:23:27: handler_reboot
                          2021-10-22T09:23:27: Reboot in 5sec
                          2021-10-22T09:23:44: Time zone set to CET-1CEST,M3.5.0,M10.5.0/3
                          2021-10-22T09:23:44: =============================================================================================
                          2021-10-22T09:23:44: =================================== Main Started ============================================
                          2021-10-22T09:23:48: Time zone set to CET-1CEST
                          2021-10-22T09:23:48: task_autodoFlow - next round - Round #1
                          2021-10-22T09:23:48: 	FlowControll.doFlow - ClassFlowMakeImage
                          2021-10-22T09:23:56: 	FlowControll.doFlow - ClassFlowAlignment
                          2021-10-22T09:24:17: 	FlowControll.doFlow - ClassFlowCNNGeneral
                          2021-10-22T09:24:30: 	FlowControll.doFlow - ClassFlowCNNGeneral
                          2021-10-22T09:24:47: 	FlowControll.doFlow - ClassFlowPostProcessing
                          2021-10-22T09:24:47: 	FlowControll.doFlow - ClassFlowMQTT
                          2021-10-22T09:24:47: task_autodoFlow - round done
                          2021-10-22T09:24:47: CPU Temperature: 53.3
                          2021-10-22T09:28:39: task_autodoFlow - next round - Round #2
                          2021-10-22T09:28:39: 	FlowControll.doFlow - ClassFlowMakeImage
                          2021-10-22T09:28:47: 	FlowControll.doFlow - ClassFlowAlignment
                          2021-10-22T09:29:08: 	FlowControll.doFlow - ClassFlowCNNGeneral
                          2021-10-22T09:29:21: 	FlowControll.doFlow - ClassFlowCNNGeneral
                          2021-10-22T09:29:38: 	FlowControll.doFlow - ClassFlowPostProcessing
                          2021-10-22T09:29:38: 	FlowControll.doFlow - ClassFlowMQTT
                          2021-10-22T09:29:38: task_autodoFlow - round done
                          2021-10-22T09:29:38: CPU Temperature: 45.6
                          2021-10-22T09:31:42: info_get_handler
                          2021-10-22T09:31:43: download_get_handler
                          2021-10-22T09:31:45: download_get_handler
                          Was übersehe ich denn hier?
                          • J jomjol
                            ich möchte in diesem Thread den Wasserzähler in der Version 2 vorstellen und diskutieren. In Version 1 waren 2 Komponeten notwendig (Hardware mit Kameraaufnahme, Docker-Server zur Auswertung). Das Zusammenspiel und die Konfiguration waren nicht immer ganz einfach.
                            Daher habe ich eine Nachfolgegeneration entwickelt, bei der alles in einem all-included Device umgesetzt ist und es noch um eine Web-basierte graphische Oberfläche zur einfachen Konfiguration ergänzt.
                            Das Grundprinzip basiert unverändert auf einem ESP32-Modul mit Kamera, welches regelmäßig ein Bild aufnimmt und durch Bilderkennung (Neuronale Netze, CNN) auswertet und den Zählerstand digitalisiert zur Verfügung stellt:
                            Hier ein Eindruck der graphischen Benutzeroberfläche:
                            Die Hardware ist wieder auf Thingiverse veröffentlicht, die Software könnt ihr als Firmware oder zum selber kompilieren auf GitHub finden. Dort gibt es auch ein Wiki mit Installations- und Konfigurationsanleitung.
                            • Hardware: https://www.thingiverse.com/thing:4573481
                            • Software/Wiki: https://github.com/jomjol/AI-on-the-edge-device/wiki
                            Ich stehe hier gerne wieder für Feedback, Fragen oder einfach zur Hilfe zur Verfügung und freue mich, wenn dieser Thread genauso intensiv genutzt wird, wie bei der Version 1 (>1k Beiträge und >22k Aufrufe).
                            Beste Grüße und viel Spass beim Nachbauen,
                            Jomjol
                            P.S.: die neue Software ist sehr flexibel aufgebaut und kann grundsätzlich auch Bildererkennung / Neuronale Netze für andere Zwecke eingesetzt werden. Wer eine gute Idee oder Anregung hat oder bei eine Modifikation Unterstützung braucht - bitte auch gerne einfach hier posten.
                            HasontH Offline
                            HasontH Offline
                            Hasont
                            #1696
                            @jomjol
                            Hallo Jamjol, nach langer Zeit möchte ich mal wieder meinen Gas- und Wasserzähler von 6.4 auf die neueste Version 8.5 oder 9 hochrüsten.
                            Die Version 6.4 hat mir während meiner Reisen mit dem WoMo keinerlei Probleme gemacht und über GPIO das Wasser bei Verbrauch > 10l außerhalb vordefinierter Gießzeiten sauber abgeschaltet. Kam aber nur ganz selten vor wenn er mal einen Reset gemacht hat und falsch ausgelesen hatte. Besser so als das Haus unter Wasser;-)
                            Nun habe ich gestern beim Gaszähler angefangen das Update auf 8.5 zu machen. Läuft soweit erstmal ganz gut und auch die von mir später benötigten GPIOs für den Wasserzaehler konnte ich konfigurieren.
                            Leider wird über mqtt aber jetzt ein anderer Pfad ausgegeben (statt Gaszaehler/Zahlerstand jetzt Gaszaehler/main/value) was natürlich alle Verknüpfungen zu SourceAnalytics und meinen Programmen durcheinander bringt. Wie könnte ich das am einfachsten lösen?
                            Dann habe ich noch festgestellt, dass es bereits eine Version 9 gibt in der aber die GPIOs nicht mehr wie in der 8.5v konfigurierbar sind. Für mich somit nicht nutzbar. Bleibt das so und gab es einen Grund das wieder rauszunehmen?
                            Danke schon mal für euere Antworten und Gruß aus Franken
                            HORST
                            J oberfraggerO 2 Antworten Letzte Antwort
                            • HasontH Hasont
                              @jomjol
                              HORST
                              jomjol
                              #1697
                              @hasont Hallo Horst,
                              den Pfad bei dem MQTT kannst du nicht mehr konfigurieren. Ich musste es standartisieren, da du jetzt mehrere Zähler pro Bild definieren kannst und dementsprechend mehrere Ausgaben per MQTT notwendig sind.
                              Die GPIOs kannst du weiterhin konfigurieren, du musst nur oben auf den Expertenmodus schalten, dann sollten eigentlich auch in der Version 9 alle Parameter wieder auftauchen.
                              Beste Grüße,
                              jomjol
                              HasontH 1 Antwort Letzte Antwort
                              • J jomjol
                                Beste Grüße,
                                jomjol
                                HasontH Offline
                                HasontH Offline
                                Hasont
                                #1698
                                @jomjol sagte in Wasserzähler - Version 2 - all-in-device:
                                Beste Grüße,
                                jomjol
                                Danke für die schnelle Antwort, mal sehen ob ich bei SourceAnalytics ev. einen Tip bekomme um den Pfad zu ändern. In meinen Programmen kann ich das ja nachtragen. So wie ich das sehe würde SourceAnalytics aber komplett neu aufbauen was nicht so schön ist.
                                LG Horst
                                • HasontH Hasont
                                  @jomjol
                                  HORST
                                  oberfragger
                                  #1699
                                  @hasont Hi,
                                  wie kann man das OTA-Update machen? Ich bin im Moment auf Version "master - v8.2.0 - 2021-08-24" und so richtig habe ich die Anleitung nicht verstanden.
                                  Kannst du 1-2 Sätze dazu vielleicht schreiben?
                                  Dank dir.
                                  In der Anleitung für externe LEDs hast du nun 470µF referenziert. Als Nachbauer und elektrik Noob wil ich die Dinger nun auf Ebay kaufen. Da muss ich noch ne Spannung auswählen. Bei 470µF kann ich 16v oder 25v wählen. Die ESPs laufen ja auf 5V...
                                  Also einfach 16V 470µF nehmen?
                                  Außerdem habe ich noch 390Ohm Widerstände rumfliegen. Reichen die auch oder sollten das 370Ohm sein.
                                  J HasontH S 3 Antworten Letzte Antwort
                                    @hasont Hi,
                                    Dank dir.
                                    jomjol
                                    #1700
                                    @oberfragger
                                    OTA: Ich habe eine kurze Anleitung ins Wiki gepackt: https://github.com/jomjol/AI-on-the-edge-device/wiki/Update
                                    Bauteile:
                                    • 16V 470µF funktionieren
                                    • 390 Ohm ? --> einfach probieren da kannst du nicht viel kaputt machen
                                      Bin aber auch kein Elektroniker.
                                      @hasont Hi,
                                      Dank dir.
                                      HasontH Offline
                                      HasontH Offline
                                      Hasont
                                      #1701
                                      @oberfragger
                                      Hallo, du holst dir das Firmware Update.
                                      Interesant ist beim Update nur Firmware, HTML und SD Karte
                                      Du kannst das Update auch ohne neue Files auf der SD Karte machen aber da hab ich schon schlechte Erfahrungen gemacht.
                                      Im Browser deinen Zähler aufrufen
                                      1.) Unter System/ OTA Update auswählen und Firmware und HTML updaten.
                                      2.) Danach formatiere ich die SD und kopiere die neuen Daten.
                                      Die alten Daten kann man ja mal aufheben falls man zurück möchte.
                                      Wie gesagt muss die SD nicht zwingend neu beschrieben werden. Ist ja eh Schritt 2
                                      oberfraggerO 1 Antwort Letzte Antwort
                                      • HasontH Hasont
                                        @oberfragger
                                        oberfragger
                                        #1702
                                        @hasont said in Wasserzähler - Version 2 - all-in-device:
                                        Ich Blindfisch... es gibt einen Unterordner "firmware"...🤦‍♂️
                                        Hat geklappt: master - v9.0.0 - 2021-10-23
                                          @hasont Hi,
                                          Dank dir.
                                          stan23
                                          #1703
                                          @oberfragger said in Wasserzähler - Version 2 - all-in-device:
                                          330 Ohm ist der nächste Wert den ich im "Lager" hatte.
                                          Das funktioniert auch. Der Wert muss nicht genau passen.
                                          Viele Grüße
                                          Marco
