  4. JavaScript
  5. Script fürTabelle der Batterie Zustände
javascriptmonitoringtemplate
1.4k Beiträge 67 Kommentatoren 821.8k Aufrufe 86 Beobachtet
  • L Langer
    @liv-in-sky
    Habe ein kleines Skript was alle Bosch-Sensoren durch läuft.
    Mit "y" zähle ich die Sensoren, stimmt.
    let y = 0;
    $('bshb.*.hdm:HomeMaticIP:*.BatteryLevel.faults').each(function(id, i) {
        let myvar = getState(id).val;
        log(myvar);
        y++
    log(y);
    Hier die Ausgabe mit log:
    16:42:39.515	info	javascript.0 (799) script.js.common.test: []
    16:42:39.515	info	javascript.0 (799) script.js.common.test: [{'type':'LOW_BATTERY','category':'WARNING'}]
    16:42:39.516	info	javascript.0 (799) script.js.common.test: []
    16:42:39.517	info	javascript.0 (799) script.js.common.test: []
    16:42:39.518	info	javascript.0 (799) script.js.common.test: []
    16:42:39.519	info	javascript.0 (799) script.js.common.test: []
    16:42:39.519	info	javascript.0 (799) script.js.common.test: 45
    45 ist die Anzahl der Sensoren und der 2 von oben ist die leere Batterie.
    Das ist die Info zum dp
      "type": "state",
      "common": {
        "name": "Toilette.BatteryLevel.faults",
        "type": "array",
        "role": "list",
        "read": true,
        "write": false
      "native": {
        "device": {
          "@type": "device",
          "rootDeviceId": "64-da-a0-02-ff-ef",
          "id": "hdm:HomeMaticIP:3014F711A000005A18586C70",
          "deviceServiceIds": [
            "Thermostat",
            "BatteryLevel",
            "ValveTappet",
            "TemperatureLevel",
            "Linking",
            "TemperatureOffset"
          "manufacturer": "BOSCH",
          "roomId": "hz_1",
          "deviceModel": "TRV",
          "serial": "3014F711A000005A18586C70",
          "profile": "GENERIC",
          "name": "Badezimmer unten",
          "status": "AVAILABLE",
          "parentDeviceId": "roomClimateControl_hz_1",
          "childDeviceIds": []
        "deviceService": {
          "@type": "DeviceServiceData",
          "id": "BatteryLevel",
          "deviceId": "hdm:HomeMaticIP:3014F711A000005A18586C70",
          "path": "/devices/hdm:HomeMaticIP:3014F711A000005A18586C70/services/BatteryLevel"
        "state": "faults"
      "_id": "bshb.0.hdm:HomeMaticIP:3014F711A000005A18586C70.BatteryLevel.faults",
      "user": "system.user.admin",
      "ts": 1632378463690
    Kannst Du mir noch mal einen Schubs geben?
    MfG
    Wastl
    liv-in-skyL
    liv-in-skyL
    #1293
    @langer sagte in Script fürTabelle der Batterie Zustände:
    let y = 0;
    was macht
      log(JSON.parse(myvar[0]).type);
    in zeile 5
    was steht dann im log
    L 1 Antwort Letzte Antwort
    • liv-in-skyL liv-in-sky
      let y = 0;
      was macht
      in zeile 5
      L
      L
      Langer
      #1294
      @liv-in-sky
      Alles fertig. Anbei View
      Mache das Skript noch etwas schön. Stelle es Morgen ins Forum.
      1000 Dank und es war super mit Dir zu Telefonieren und zu Arbeiten.
      MfG
      Wastl
      L liv-in-skyL 2 Antworten Letzte Antwort
      • L Langer
        @liv-in-sky
        MfG
        Wastl
        L
        L
        Langer
        #1295
        @liv-in-sky
        Guten Morgen
        anbei das Überarbeite Skript, als txt File.
        Batterie_Status_Bosch.txt
        Bosch ist eingefügt ab Zeile 192.
        MfG
        Wastl
        • L Langer
          @liv-in-sky
          Guten Morgen
          MfG
          Wastl
          liv-in-skyL
          liv-in-skyL
          #1296
          @langer danke - werde es einfügen
          • L Langer
            @liv-in-sky
            MfG
            Wastl
            liv-in-skyL
            liv-in-skyL
            #1297
            @langer
            nur so nebenbei -. du weißt, dass du die farben und die schriftart für dein design angleichen kannst
              @langer
              L
              L
              Langer
              #1298
              @liv-in-sky
              Ich glaube das geht oben in der Variablen Deklaration, oder?
              MfG
              Wastl
              Ps.
              Ich versuche gerade aus dem TR-064 Adapter Devices die DP in einer Tabelle darzustellen. Sollten Fragen auftauchen könnte ich Dich nochmals um Hilfe fragen?
              • L Langer
                @liv-in-sky
                MfG
                Wastl
                Ps.
                liv-in-skyL
                liv-in-skyL
                #1299
                @langer
                ja - da kannst du das alles einstellen im setting - zur not machen wir das gemeinsam über anydesk
                @liv-in-sky
                MfG
                Wastl
                Ps.
                klar - da könntest du eine vorlage von mir nutzen - musst halt definieren, wieviele spalten diu haben willst und was darin angezeigt werden soll
                  @langer
                  @liv-in-sky
                  MfG
                  Wastl
                  Ps.
                  L
                  L
                  Langer
                  #1300
                  @liv-in-sky
                  Ich wollte Dein Skript für "IPDevices" hernehmen und anpassen.
                  MfG
                  Wastl
                  • L Langer
                    @liv-in-sky
                    MfG
                    Wastl
                    liv-in-skyL
                    liv-in-skyL
                    #1301
                    @langer joi- geht auch
                      hier ein beispiel für die Anzeige der Sensoren-Batterie-Zustände über ein html-Widget (oder iQontrol) - angelehnt an die scripte für html tabellen: https://forum.iobroker.net/topic/28021/html-table-für-vis-oder-iqontrol-js-und-blockly
                      die MaterialDesign Widgets sind auch mit eingebunden https://forum.iobroker.net/post/389578
                      export der widgets
                      [{"tpl":"tplVis-materialdesign-Icon-List","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","wrapItems":true,"listItemDataMethod":"jsonStringObject","countListItems":"1","vibrateOnMobilDevices":"50","listLayout":"card","itemLayout":"horizontal","listType0":"text","showValueLabel0":"true","listType1":"text","showValueLabel1":"true","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"maxItemsperRow":"4","json_string_oid":"controll-own.0.TABELLEN.AkkuMaterialWidget","labelFontSize":"22","subLabelFontSize":"14","labelFontFamily":"RobotoCondensed-Regular","horizontalIconContainerWidth":"70","buttonHeight":"70","iconHeight":"35","iconItemMinWidth":"300"},"style":{"left":"117px","top":"67px","width":"60.89%","height":"87.71%","overflow-y":"auto"},"widgetSet":"materialdesign"}]
                      [{"tpl":"tplVis-materialdesign-Table","data":{"oid":"controll-own.0.TABELLEN.AkkuMaterialWidgetTable","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","countCols":"4","tableLayout":"standard","showHeader":"true","headerTextSize":"headline6","showColumn0":"true","colType0":"text","textAlign0":"left","showColumn1":"true","colType1":"text","textAlign1":"center","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"showColumn2":"true","colType2":"text","textAlign2":"center","showColumn3":"true","colType3":"image","textAlign3":"center","dataJson":"","colTextSize0":"headline4","label1":"Wert","label0":"Name","label2":"Status","sortKey0":"","fontFamily0":"RobotoCondensed-Regular","padding_left0":"10","colTextColor0":"","colorBackground":"#ffffff","colorHeaderRowBackground":"#424242","colorHeaderRowText":"#b6b9b7","borderColor":"#000000","fontFamily1":"RobotoCondensed-Regular","colTextColor1":"#beb7b7","rowHeight":"19","label3":"Hersteller","imageSize3":"20","padding_right3":"-5","sortKey2":"","showColumn4":false,"colType4":"text","textAlign4":"center","sortKey1":"helpSort"},"style":{"left":"1110px","top":"61px","z-index":"0","width":"587px","height":"926px","overflow-y":"auto"},"widgetSet":"materialdesign"}]
                      die javascript adapter version sollte 4.3.x sein !!!
                      anzulegen und in das script einzutragen sind folgende datenpunkte
                      • ein datenpunkt für die vis-anzeige unter dpVIS - ganz oben - im script - anschliessend kann man die tabelle so einstellen, dass sie in eure vis paßt (übr ein standard-html-widget mit binding auf diesen selbst-angelegten-datenpunkt)- ein html datei kann auf wunsch geschrieben werden - damit kann auch in iQontrol ein popup "gefüttert" werden und als anzeige dienen. auch die werte für warnung oder alarm sind einzutragen
                      • ein datenpunkt für die anzahl der devices mit alarm (im script beschrieben)
                      • ein datenpunkt für eine liste mit den devices mit einem alarm (im script beschrieben)
                      wie legt man einen datenpunkt an: https://forum.iobroker.net/post/400338
                      Script zum download bzw. mit Chrome!!! kopieren
                      https://github.com/liv-in-sky/battery-iobroker-vis-table
                      • bisher integriert
                      hersteller
                      iogok.png iogo adapter
                      tadok.jpg tado
                      homeek.jpg homee
                      netatmok.jpg netatmo
                      zwavek.jpg zwave
                      fritzk.png fritzDect theermostate
                      xiaomki.png xiaomi, mihome
                      homematick.jpg homematic, homematic-Ip
                      huek.jpg hue, hue-ext
                      zwavek.jpg zwave
                      tradfrik.png tradfri
                      fullyk.png fully browser adapter
                      zigbeek.jpg zigbee
                      deconzk.png deconz
                      sonoffk.png sonoff zb bridge
                      busware-cul.png cul adapter
                      rademacher.png rademacher homepilot
                      shellyk.jpg shelly
                      boschk.png bosch
                      hamk.png ham (homebridge)
                      nuki-extended
                      Horst BöttcherH
                      Horst BöttcherH
                      Horst Böttcher
                      #1302
                      @liv-in-sky
                      wie bekommt man nuki dazugefügt
                      ioBroker auf Proxmox (Debian) auf LENOVO PC Thinkcentre als Produktivsystem
                      liv-in-skyL L 2 Antworten Letzte Antwort
                      • Horst BöttcherH Horst Böttcher
                        @liv-in-sky
                        liv-in-skyL
                        liv-in-skyL
                        #1303
                        @horst-böttcher
                        da müßte ich mal die datenpunkte sehen - kannst du mal ein bild der objecte unter dem adapter zeigen ?
                          @liv-in-sky
                          L
                          L
                          locito09
                          #1304
                          @horst-böttcher
                          Nuki zeigt ja den Batterie stand in Prozent an
                          Horst BöttcherH 1 Antwort Letzte Antwort
                          • L locito09
                            @horst-böttcher
                            Horst BöttcherH
                            Horst BöttcherH
                            Horst Böttcher
                            #1305
                            @locito09
                            !mal opener und smartlock gesteuert über nuki-extended adapter
                              @locito09
                              liv-in-skyL
                              liv-in-skyL
                              #1306
                              @horst-böttcher
                              werd ich die nächsten tage ansehen
                              gehe bitte in den object tab und makiere nuki-extended
                              anschliessend kannst du oben auf datei json export gehen - diese datei bitte im forum posten
                              stimmt das:
                              beim opener ist es der dp batteryCritical
                              beim smartlock ist der dp auch batteryCritical
                              das wäre am einfachsten umzusetzen
                                @horst-böttcher
                                stimmt das:
                                Horst BöttcherH
                                Horst BöttcherH
                                Horst Böttcher
                                #1307
                                @liv-in-sky musste ich leider extern machen für hier war es zu gross Link Text
                                  liv-in-skyL
                                  liv-in-skyL
                                  #1308
                                  @horst-böttcher
                                  du kannst es als txt-datei hier reinsetzen/-ziehen - nichtr den inhalt rein-kopieren
                                  dann kasnn es nicht zu groß sein
                                    @horst-böttcher
                                    Horst BöttcherH
                                    Horst BöttcherH
                                    Horst Böttcher
                                    #1309
                                    @liv-in-sky nuki-extended.txt
                                      liv-in-skyL
                                      liv-in-skyL
                                      #1310
                                      @horst-böttcher
                                      teste mal das script - hier zum download
                                      du mußt oben im setting nuki=true setzen
                                        @horst-böttcher
                                        Horst BöttcherH
                                        Horst BöttcherH
                                        Horst Böttcher
                                        #1311
                                        @liv-in-sky
                                        ja es schein zu gehen ab wieviel prozent zeigt er low an
                                          @liv-in-sky
                                          liv-in-skyL
                                          liv-in-skyL
                                          #1312
                                          @horst-böttcher
                                          weiß ich nicht - nutze den adapter ncht - da musst du im passendem thread nachfragen (wegen prozent)
                                          zieh das widget mal etwas in die breite - sieht besser aus
                                          farben , hintergrund schriftart kann alles eingestellt werden
                                          84.1k
