  4. [gelöst] Alexa Adapter startet nach Update auf 3.10.4 nicht
    6.4k
103 Beiträge 6 Kommentatoren 12.1k Aufrufe 6 Beobachtet
  • apollon77A apollon77
    @skb Naja ok ... aber tu uns mal den gefallen und lass uns die influxdb bitte ausschliessen. also mal kurz aus (der influxdb adapter cached die daten, alles ok).
    SKBS Offline
    SKBS Offline
    SKB
    @apollon77 Habe die influxdb gestoppt.
    Dann den Adapter gestartet.
    ioBroker Log:
    host.ioBroker	2021-10-11 16:10:07.361	warn	instance system.adapter.alexa2.0 terminated due to SIGBUS
    alexa2.0	2021-10-11 16:10:07.162	debug	Alexa-Remote WS-MQTT: Open: wss://dp-gw-na.amazon.de/tcomm/
    alexa2.0	2021-10-11 16:10:07.021	debug	Alexa-Remote: Sending Request with {"host":"alexa.amazon.de","path":"/api/behaviors/v2/automations?limit=2000","method":"GET","timeout":30000,"headers":{}}
    alexa2.0	2021-10-11 16:10:07.021	debug	Alexa-Remote: No authentication check needed (time elapsed 2447)
    syslog:
    Oct 11 16:10:07 ioBroker kernel: [11915.196468] 8<--- cut here ---
    Oct 11 16:10:07 ioBroker kernel: [11915.196503] pgd = 4a9e14fe
    Oct 11 16:10:07 ioBroker kernel: [11915.196514] [059a659e] *pgd=0d4ab003, *pmd=f84e7003
    dmesg:
    [Mo Okt 11 15:48:30 2021] Alignment trap: not handling instruction f4430add at [<b6374b40>]
    [Mo Okt 11 15:48:30 2021] 8<--- cut here ---
    [Mo Okt 11 15:48:30 2021] Unhandled fault: alignment exception (0xa21) at 0x054f564e
    [Mo Okt 11 15:48:30 2021] pgd = 2d9e975c
    [Mo Okt 11 15:48:30 2021] [054f564e] *pgd=0d470003, *pmd=b6e17003
    [Mo Okt 11 16:10:07 2021] Alignment trap: not handling instruction f4430add at [<b636cb40>]
    [Mo Okt 11 16:10:07 2021] 8<--- cut here ---
    [Mo Okt 11 16:10:07 2021] Unhandled fault: alignment exception (0xa21) at 0x059a659e
    [Mo Okt 11 16:10:07 2021] pgd = 4a9e14fe
    [Mo Okt 11 16:10:07 2021] [059a659e] *pgd=0d4ab003, *pmd=f84e7003
    apollon77A HomoranH 2 Antworten Letzte Antwort
    • SKBS SKB
      ioBroker Log:
      syslog:
      dmesg:
      @skb Ok, schade - hätte ja sein können :-)
      SKBS 1 Antwort Letzte Antwort
      • SKBS SKB
        ioBroker Log:
        syslog:
        dmesg:
        @skb sagte in Alexa Adapter startet nach Update auf 3.10.4 nicht mehr:
        oder nur die Instanz?
          SKBS Offline
          SKBS Offline
          SKB
          @homoran Den Adapter habe ich laufen lassen, damit er cached, wie Apollon sagte.
          Den Server via:
          sudo service influxdb stop
          gestoppt.
            SKBS Offline
            SKBS Offline
            SKB
            @apollon77 Wenn man wüsste, was diese Fehler aussagen, könnte man ja weiterschauen. Jedoch sagen mir diese Fehler leider so gut wie überhaupt nichts - sonst wäre es ja einfach :D
            • SKBS SKB
              @skb
              Das sind Fehler im Speichermanagements des Kernels.
              Wo die aber den Ursprung haben ist schwer zu debuggen.
              • apollon77A Offline
                Ich hoffe ich kriege auf das eine oben noch infos, dann kriegen wir vllt noch bissl mehr log
                  SKBS Offline
                  SKBS Offline
                  SKB
                  @apollon77 Von mir? Fehlt noch etwas? Wenn ja, sag' mir kurz, was Du brauchst.
                    @skb
                    SKBS Offline
                    SKBS Offline
                    SKB
                    @thomas-braun Meinst Du diese?
                    [Mo Okt 11 13:07:02 2021] Unhandled fault: alignment exception (0xa21) at 0x04396546
                    [Mo Okt 11 13:07:02 2021] pgd = 6348d82f
                    [Mo Okt 11 13:07:02 2021] [04396546] *pgd=0b5dd003, *pmd=8e081003
                    Die kommen immer, wenn der Adapter versucht zu starten.
                    • SKBS SKB
                      @skb
                      Ja, die Abkürzungen stehen da z. B. für:
                      pgd = page global directory
                      pud = page upper directory
                      pmd = page middle directory
                      Hat also mit der Verwaltung der sog. memory page tables zu tun.
                        @skb
                        SKBS Offline
                        SKBS Offline
                        SKB
                        @thomas-braun Ok, aber sie kommen halt nur dann, wenn die Instanz des Alexa Adapters startet. Sonst kann ich sie nicht finden.
                        • SKBS SKB
                          @skb
                          Wenn ich das richtig interpretiere wird da Speicherbereich doppelt zugewiesen:
                            @skb
                            @thomas-braun So verstehe ich es auch ... Da kann der Adapter nix ausrichten - das ist das Problem . Frage ist wer "verantwortlich" ist ...
                              Ok, dann können wir nur mal manuell adapter starten um ggf mehr infos von nodejs zu bekommen.
                              Ala https://github.com/nodejs/help/issues/3168#issuecomment-756720041 müsste man dem nodejs prozess ein --report-signal=SIGBUS --report-on-signal übergeben ...
                              Versuchen gerade rauszufinden wie der Call aussehen muss
                              @apollon77 ich brauche hier noch ne info ... dann versuchen wir das noch obs mehr log gibt
                              • SKBS SKB
                                @skb ok versuchen wir mal was. Stoppe mal den alexa2 adapter (aber vorher Push Connection einschalten falls aus war).
                                Dann per ssh
                                node --report-signal=SIGBUS --report-on-signal /opt/iobroker/node_modules/iobroker.alexa2/main.js --force --logs
                                Kommt dann ggf mehr wenn es crasht?
                                  Dann per ssh
                                  SKBS Offline
                                  SKBS Offline
                                  SKB
                                  @apollon77
                                  Dies ist die Ausgabe:
                                  pi@ioBroker:~ $ node --report-signal=SIGBUS --report-on-signal /opt/iobroker/node_modules/iobroker.alexa2/main.js --force --logs
                                  2021-10-11 16:41:49.559  - error: alexa2.0 (13790) adapter disabled
                                  2021-10-11 16:41:49.568  - info: alexa2.0 (13790) starting. Version 3.10.4 in /opt/iobroker/node_modules/iobroker.alexa2, node: v14.18.0, js-controller: 3.3.18
                                  2021-10-11 16:41:50.130  - debug: alexa2.0 (13790) Alexa-Remote: Use as User-Agent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36
                                  2021-10-11 16:41:50.131  - debug: alexa2.0 (13790) Alexa-Remote: Use as Login-Amazon-URL: amazon.de
                                  2021-10-11 16:41:50.132  - debug: alexa2.0 (13790) Alexa-Remote: Use as Base-URL: alexa.amazon.de
                                  2021-10-11 16:41:50.135  - debug: alexa2.0 (13790) Alexa-Remote: cookie was provided
                                  2021-10-11 16:41:50.138  - debug: alexa2.0 (13790) Alexa-Remote: Sending Request with {"host":"alexa.amazon.de","path":"/api/bootstrap?version=0","method":"GET","timeout":10000,"headers":{}}
                                  2021-10-11 16:41:50.622  - debug: alexa2.0 (13790) Alexa-Remote: Response: {"authentication":{"authenticated":true,"canAccessPrimeMusicContent":true,"customerEmail":"info@skb-web.de","customerId":"AV8T15OWSJBT1","customerName":"Stephan Kreyenborg"}}
                                  2021-10-11 16:41:50.624  - debug: alexa2.0 (13790) Alexa-Remote: Authentication checked: true
                                  2021-10-11 16:41:50.625  - debug: alexa2.0 (13790) Alexa-Remote: No authentication check needed (time elapsed 1)
                                  2021-10-11 16:41:50.626  - debug: alexa2.0 (13790) Alexa-Remote: Sending Request with {"host":"alexa-comms-mobile-service.amazon.de","path":"/accounts","method":"GET","timeout":10000,"headers":{}}
                                  2021-10-11 16:41:51.023  - debug: alexa2.0 (13790) Alexa-Remote: Response: [{"commsId":"amzn1.comms.id.person.amzn1~amzn1.account.AE2K6HEV5O4UZ6LEM2FHPTHLEDXA","directedId":"amzn1.account.AE2K6HEV5O4UZ6LEM2FHPTHLEDXA","phoneCountryCode":"49","phoneNumber":"1729887930","firstName":"Stephan","lastName":"Kreyenborg","phoneticFirstName":null,"phoneticLastName":null,"commsProvisionStatus":"PROVISIONED","isChild":false,"personIdV2":"amzn1.actor.person.oid.A2P02UVLYMB4FY","signedInUser":true,"commsProvisioned":true,"enrolledInAlexa":true,"speakerProvisioned":false}]
                                  2021-10-11 16:41:51.025  - debug: alexa2.0 (13790) Alexa-Remote: No authentication check needed (time elapsed 401)
                                  2021-10-11 16:41:51.027  - debug: alexa2.0 (13790) Alexa-Remote: Sending Request with {"host":"alexa.amazon.de","path":"/api/devices-v2/device?cached=true&_=1633963311027","method":"GET","timeout":10000,"headers":{}}
                                  2021-10-11 16:41:51.496  - debug: alexa2.0 (13790) Alexa-Remote: Response: {"devices":[{"accountName":"This Device","appDeviceList":[{"deviceAccountId":"A0861997DUI3R74CCS7X","deviceType":"A2TF17PFR55MTB","serialNumber":"9b152b51d8704399bfc1b33db9fa8214"}],"capabilities":["CUSTOM_ALARM_TONE","ADAPTIVE_LISTENING","SOUND_SETTINGS","TIMERS_AND_ALARMS","VOLUME_SETTING","MICROPHONE","REMINDERS","DIALOG_INTERFACE_VERSION"],"charging":null,"clusterMembers":[],"deviceAccountId":"A0861997DUI3R74CCS7X","deviceFamily":"VOX","deviceOwnerCustomerId":"A1EIP8DVPCTVOF","deviceType":"A2TF17PFR55MTB","deviceTypeFriendlyName":null,"essid":null,"language":null,"macAddress":null,"online":true,"parentClusters":[],"postalCode":null,"registrationId":null,"remainingBatteryLevel":null,"serialNumber":"9b152b51d8704399bfc1b33db9fa8214","softwareVersion":"130050002"},{"accountName":"Marijana's Alexa Apps","appDeviceList":[{"deviceAccountId":"A06654591OVZOCDFF8ZR0","deviceType":"A1DL2DVDQVK3Q","serialNumber":"SMG950FF40469E1060EB598"},{"deviceAccountId":"A01169689K3RKDK3Z6UV","deviceType":"A1DL2DVDQVK3Q","serialNumber":"SMG980F682BCDDF422ED90F"},{"deviceAccountId":"A024247128CGZ5KLLWDXY","deviceType":"A1DL2DVDQVK3Q","serialNumber":"SMT8134A745230E200CDB9"}],"capabilities":["ADAPTIVE_LISTENING","VOLUME_SETTING","MICROPHONE"],"charging":null,"clusterMembers":[],"deviceAccountId":"A06654591OVZOCDFF8ZR0","deviceFamily":"AMAZONMOBILEMUSIC_ANDROID","deviceOwnerCustomerId":"A1EIP8DVPCTVOF","deviceType":"A1DL2DVDQVK3Q","deviceTypeFriendlyName":null,"essid":null,"language":null,"macAddress":null,"online":false,"parentClusters":[],"postalCode":null,"registrationId":null,"remainingBatteryLevel":null,"serialNumber":"SMG950FF40469E1060EB598","softwareVersion":"516110110"},{"accountName":"Stephan's Fire TV stick","appDeviceList":[],"capabilities":["SUPPORTS_SOFTWARE_VERSION","CUSTOM_ALARM_TONE","PERSISTENT_CONNECTION","ADAPTIVE_LISTENING","ARTHUR_TARGET","SOUND_SETTINGS","ASCENDING_ALARM_VOLUME","VOLUME_SETTING","MICROPHONE","REMINDERS","SHARKNADO","SUPPORTS_CONNECTED_HOME_CLOUD_ONLY","ACTIVE_AFTER_FRO","DIALOG_INTERFACE_VERSION","SUPPORTS_LOCALE","SUPPORTS_LOCALE_SWITCH","TIMERS_AND_ALARMS","FLASH_BRIEFING","CHANGE_NAME"],"charging":null,"clusterMembers":[],"deviceAccountId":"A159HL3V8OMRNZ","deviceFamily":"FIRE_TV","deviceOwnerCustomerId":"AV8T15OWSJBT1","deviceType":"ADVBD696BHNV5","deviceTypeFriendlyName":null,"essid":null,"language":null,"macAddress":null,"online":true,"parentClusters":[],"postalCode":null,"registrationId":null,"remainingBatteryLevel":null,"serialNumber":"70940514603302JH","softwareVersion":"662663720"},{"accountName":"Wohnung","appDeviceList":[],"capabilities":["MUSIC_SKILL","TUNE_IN","TIDAL","VOLUME_SETTING","MICROPHONE","PANDORA","AUDIO_PLAYER","AMAZON_MUSIC","KINDLE_BOOKS","AUDIBLE","SALMON","APPLE_MUSIC","SIRIUSXM","DEEZER","I_HEART_RADIO"],"charging":null,"clusterMembers":["G090U610916420KJ","G09183091056058K","G0911M079406180P"],"deviceAccountId":"A00087432OQ8XJFXWT00","deviceFamily":"WHA","deviceOwnerCustomerId":"AV8T15OWSJBT1","deviceType":"A3C9PE6TNYLTCH","deviceTypeFriendlyName":null,"essid":null,"language":null,"macAddress":null,"online":true,"parentClusters":[],"postalCode":null,"registrationId":null,"remainingBatteryLevel":null,"serialNumber":"edbb7e932cf347c7b287a5db19c3ee30","softwareVersion":"0"},{"accountName":"Fire TV Cube","appDeviceList":[],"capabilities":["CUSTOM_ALARM_TONE","MUSIC_SKILL","FAR_FIELD_WAKE_WORD","ARTHUR_TARGET","TIDAL","REMINDERS","GOLDFISH","AUDIO_PLAYER","SUPPORTS_CONNECTED_HOME_CLOUD_ONLY","ACTIVE_AFTER_FRO","AMAZON_MUSIC","KINDLE_BOOKS","TIMERS_ALARMS_NOTIFICATIONS_VOLUME","FLASH_BRIEFING","SET_LOCALE","PAIR_BT_SINK","CHANGE_NAME","SIRIUSXM","SLEEP","I_HEART_RADIO","SUPPORTS_SOFTWARE_VERSION","MULTI_WAKEWORDS_SUPPORTED","BT_PAIRING_FLOW_V2","PERSISTENT_CONNECTION","TUNE_IN","ADAPTIVE_LISTENING","SOUND_SETTINGS","SUPPORT_CALENDAR_ALERT","ASCENDING_ALARM_VOLUME","EARCONS","MICROPHONE","PANDORA","SHARKNADO","DIALOG_INTERFACE_VERSION","VOICE_TRAINING","AUDIBLE","SUPPORTS_LOCALE","SUPPORTS_LOCALE_SWITCH","SALMON","TIMERS_AND_ALARMS","SPEECH_RECOGNIZER_USS","APPLE_MUSIC","DEEZER","DREAM_TRAINING"],"charging":null,"clusterMembers":[],"deviceAccountId":"A07651723SRV0G2RLZ9S","deviceFamily":"FIRE_TV","deviceOwnerCustomerId":"AV8T15OWSJBT1","deviceType":"A2JKHJ0PX4J3L3","deviceTypeFriendlyName":null,"essid":null,"language":null,"macAddress":null,"online":true,"parentClusters":[],"postalCode":null,"registrationId":null,"remainingBatteryLevel":null,"serialNumber":"G0911X03941304ML","softwareVersion":"21039196292"},{"accountName":"Echo Dot Flur","appDeviceList":[],"capabilities":["GADGETS","CUSTOM_ALARM_TONE","MUSIC_SKILL","FAR_FIELD_WAKE_WORD","DS_VOLUME_SETTING","EFDCARDS","REMINDERS","EQUALIZER_CONTROLLER_TREBLE","AUDIO_PLAYER","DEREGISTER_DEVICE","KINDLE_BOOKS","FLASH_BRIEFING","SET_LOCALE","GUARD_EARCON","TAHOE_BYOD","UPDATE_WIFI","MULTI_WAKEWORDS_SUPPORTED","BT_PAIRING_FLOW_V2","PERSISTENT_CONNECTION","ADAPTIVE_LISTENING","TUPLE","PANDORA","EQUALIZER_CONTROLLER_MIDRANGE","AUDIO_CONTROLS","DIALOG_INTERFACE_VERSION","VOICE_TRAINING","SUPPORTS_LOCALE_SWITCH","SALMON","TIMERS_AND_ALARMS","SPEECH_RECOGNIZER_USS","TUPLE_CATEGORY_A","TIDAL","VOLUME_SETTING","GOLDFISH","SUPPORTS_CONNECTED_HOME_CLOUD_ONLY","ACTIVE_AFTER_FRO","LEMUR_ALPHA","AMAZON_MUSIC","TIMERS_ALARMS_NOTIFICATIONS_VOLUME","PAIR_BT_SINK","CHANGE_NAME","SIRIUSXM","PAIR_BT_SOURCE","SLEEP","EQUALIZER_CONTROLLER_BASS","I_HEART_RADIO","SUPPORTS_SOFTWARE_VERSION","TUNE_IN","SOUND_SETTINGS","SUPPORT_CALENDAR_ALERT","ASCENDING_ALARM_VOLUME","EARCONS","MICROPHONE","ALEXA_VOICE","ALEXA_PRESENCE","SET_TIME_ZONE","REQUIRES_OOBE_FOR_SETUP","AUDIBLE","SUPPORTS_LOCALE","APPLE_MUSIC","DEEZER","PAIR_REMOTE","DREAM_TRAINING","POPTART"],"charging":null,"clusterMembers":[],"deviceAccountId":"A01378201SS79J7AJ7XMS","deviceFamily":"ECHO","deviceOwnerCustomerId":"AV8T15OWSJBT1","deviceType":"A1RABVCI4QCIKC","deviceTypeFriendlyName":null,"essid":null,"language":null,"macAddress":null,"online":true,"parentClusters":["edbb7e932cf347c7b287a5db19c3ee30"],"postalCode":null,"registrationId":null,"remainingBatteryLevel":null,"serialNumber":"G0911M079406180P","softwareVersion":"5805753220"},{"accountName":"Echo Dot Küche","appDeviceList":[],"capabilities":["GADGETS","CUSTOM_ALARM_TONE","MUSIC_SKILL","FAR_FIELD_WAKE_WORD","DS_VOLUME_SETTING","EFDCARDS","REMINDERS","EQUALIZER_CONTROLLER_TREBLE","AUDIO_PLAYER","DEREGISTER_DEVICE","KINDLE_BOOKS","FLASH_BRIEFING","SET_LOCALE","GUARD_EARCON","TAHOE_BYOD","UPDATE_WIFI","MULTI_WAKEWORDS_SUPPORTED","BT_PAIRING_FLOW_V2","PERSISTENT_CONNECTION","ADAPTIVE_LISTENING","TUPLE","PANDORA","EQUALIZER_CONTROLLER_MIDRANGE","AUDIO_CONTROLS","DIALOG_INTERFACE_VERSION","VOICE_TRAINING","SUPPORTS_LOCALE_SWITCH","SALMON","TIMERS_AND_ALARMS","SPEECH_RECOGNIZER_USS","TUPLE_CATEGORY_A","TIDAL","VOLUME_SETTING","GOLDFISH","SUPPORTS_CONNECTED_HOME_CLOUD_ONLY","ACTIVE_AFTER_FRO","LEMUR_ALPHA","AMAZON_MUSIC","DEREGISTER_FACTORY_RESET","TIMERS_ALARMS_NOTIFICATIONS_VOLUME","PAIR_BT_SINK","CHANGE_NAME","SIRIUSXM","PAIR_BT_SOURCE","SLEEP","EQUALIZER_CONTROLLER_BASS","I_HEART_RADIO","SUPPORTS_SOFTWARE_VERSION","TUNE_IN","SOUND_SETTINGS","SUPPORT_CALENDAR_ALERT","ASCENDING_ALARM_VOLUME","EARCONS","MICROPHONE","ALEXA_VOICE","ALEXA_PRESENCE","REQUIRES_OOBE_FOR_SETUP","AUDIBLE","SUPPORTS_LOCALE","APPLE_MUSIC","DEEZER","PAIR_REMOTE","DREAM_TRAINING","POPTART"],"charging":null,"clusterMembers":[],"deviceAccountId":"A10336463KM6ANCFBSROV","deviceFamily":"ECHO","deviceOwnerCustomerId":"AV8T15OWSJBT1","deviceType":"A32DOYMUN6DTXA","deviceTypeFriendlyName":null,"essid":null,"language":null,"macAddress":null,"online":true,"parentClusters":["edbb7e932cf347c7b287a5db19c3ee30"],"postalCode":null,"registrationId":null,"remainingBatteryLevel":null,"serialNumber":"G090U610916420KJ","softwareVersion":"5805753476"},{"accountName":"Echo Show Schlafzimmer","appDeviceList":[],"capabilities":["CUSTOM_ALARM_TONE","MUSIC_SKILL","FAR_FIELD_WAKE_WORD","DS_VOLUME_SETTING","EFDCARDS","REMINDERS","EQUALIZER_CONTROLLER_TREBLE","AUDIO_PLAYER","KINDLE_BOOKS","FLASH_BRIEFING","SET_LOCALE","GUARD_EARCON","MULTI_WAKEWORDS_SUPPORTED","BT_PAIRING_FLOW_V2","PERSISTENT_CONNECTION","ADAPTIVE_LISTENING","FACTORY_RESET_DEVICE","TUPLE_CATEGORY_B","TUPLE","PANDORA","EQUALIZER_CONTROLLER_MIDRANGE","AUDIO_CONTROLS","DIALOG_INTERFACE_VERSION","VOICE_TRAINING","SUPPORTS_LOCALE_SWITCH","SALMON","TIMERS_AND_ALARMS","SPEECH_RECOGNIZER_USS","TIDAL","VOLUME_SETTING","GOLDFISH","SUPPORTS_CONNECTED_HOME_CLOUD_ONLY","LEMUR_ALPHA","AMAZON_MUSIC","TIMERS_ALARMS_NOTIFICATIONS_VOLUME","PAIR_BT_SINK","CHANGE_NAME","SIRIUSXM","LIVE_VIEW","SLEEP","EQUALIZER_CONTROLLER_BASS","I_HEART_RADIO","SUPPORTS_SOFTWARE_VERSION","TUNE_IN","SOUND_SETTINGS","SUPPORT_CALENDAR_ALERT","ASCENDING_ALARM_VOLUME","EARCONS","MICROPHONE","ALEXA_VOICE","SHARKNADO","ALEXA_PRESENCE","AUDIBLE","SUPPORTS_LOCALE","APPLE_MUSIC","DEEZER","DREAM_TRAINING","POPTART"],"charging":null,"clusterMembers":[],"deviceAccountId":"A063800733RIXTXAV2E0V","deviceFamily":"KNIGHT","deviceOwnerCustomerId":"AV8T15OWSJBT1","deviceType":"A1Z88NGR2BK6A2","deviceTypeFriendlyName":null,"essid":null,"language":null,"macAddress":null,"online":true,"parentClusters":["edbb7e932cf347c7b287a5db19c3ee30"],"postalCode":null,"registrationId":null,"remainingBatteryLevel":null,"serialNumber":"G09183091056058K","softwareVersion":"5805754756"},{"accountName":"This Device","appDeviceList":[{"deviceAccountId":"A0677275IETJ8P5WNXLX","deviceType":"A2IVLV5VM2W81","serialNumber":"87ba03d8a92b898ff3e2a5c99dfec165"},{"deviceAccountId":"A0305194VW9O0KVSCYQ1","deviceType":"A2TF17PFR55MTB","serialNumber":"0e04d8c1b73441e4a99110c749a5c5b4"},{"deviceAccountId":"A026176610BR5KGLF1W15","deviceType":"A2IVLV5VM2W81","serialNumber":"c0762bc600e4285baf43afb81d34ac9f"},{"deviceAccountId":"A07533506XAPMCE5GKBX","deviceType":"A2IVLV5VM2W81","serialNumber":"21c59241ed82e98a939e5f47592a8d7e"},{"deviceAccountId":"A09012853PV47373YXTQJ","deviceType":"A2IVLV5VM2W81","serialNumber":"21972b82caeee1fdd6a07cc3efcb2ea8"}],"capabilities":["ADAPTIVE_LISTENING","VOLUME_SETTING","MICROPHONE"],"charging":null,"clusterMembers":[],"deviceAccountId":"A09012853PV47373YXTQJ","deviceFamily":"VOX","deviceOwnerCustomerId":"AV8T15OWSJBT1","deviceType":"A2IVLV5VM2W81","deviceTypeFriendlyName":null,"essid":null,"language":null,"macAddress":null,"online":true,"parentClusters":[],"postalCode":null,"registrationId":null,"remainingBatteryLevel":null,"serialNumber":"21972b82caeee1fdd6a07cc3efcb2ea8","softwareVersion":"1"},{"accountName":"Stephan's Alexa Apps","appDeviceList":[{"deviceAccountId":"A06175881I2SREN19MYMG","deviceType":"A1DL2DVDQVK3Q","serialNumber":"SMG985F5B8874995CD23CCC"}],"capabilities":["ADAPTIVE_LISTENING","VOLUME_SETTING","MICROPHONE"],"charging":null,"clusterMembers":[],"deviceAccountId":"A06175881I2SREN19MYMG","deviceFamily":"AMAZONMOBILEMUSIC_ANDROID","deviceOwnerCustomerId":"AV8T15OWSJBT1","deviceType":"A1DL2DVDQVK3Q","deviceTypeFriendlyName":null,"essid":null,"language":null,"macAddress":null,"online":false,"parentClusters":[],"postalCode":null,"registrationId":null,"remainingBatteryLevel":null,"serialNumber":"SMG985F5B8874995CD23CCC","softwareVersion":"516140110"}]}
                                  2021-10-11 16:41:51.499  - debug: alexa2.0 (13790) Alexa-Remote: No authentication check needed (time elapsed 875)
                                  2021-10-11 16:41:51.501  - debug: alexa2.0 (13790) Alexa-Remote: Sending Request with {"host":"alexa.amazon.de","path":"/api/wake-word?_=1633963311500","method":"GET","timeout":10000,"headers":{}}
                                  2021-10-11 16:41:51.696  - debug: alexa2.0 (13790) Alexa-Remote: Response: {"wakeWords":[{"active":true,"deviceSerialNumber":"G0911X03941304ML","deviceType":"A2JKHJ0PX4J3L3","midFieldState":null,"wakeWord":"ALEXA"},{"active":true,"deviceSerialNumber":"G0911M079406180P","deviceType":"A1RABVCI4QCIKC","midFieldState":null,"wakeWord":"ALEXA"},{"active":true,"deviceSerialNumber":"G090U610916420KJ","deviceType":"A32DOYMUN6DTXA","midFieldState":null,"wakeWord":"ALEXA"},{"active":true,"deviceSerialNumber":"G09183091056058K","deviceType":"A1Z88NGR2BK6A2","midFieldState":null,"wakeWord":"ALEXA"}]}
                                  2021-10-11 16:41:51.698  - debug: alexa2.0 (13790) Alexa-Remote: No authentication check needed (time elapsed 1074)
                                  2021-10-11 16:41:51.699  - debug: alexa2.0 (13790) Alexa-Remote: Sending Request with {"host":"alexa.amazon.de","path":"/api/bluetooth?cached=true&_=1633963311699","method":"GET","timeout":10000,"headers":{}}
                                  2021-10-11 16:41:52.261  - debug: alexa2.0 (13790) Alexa-Remote: Response: {"bluetoothStates":[{"deviceSerialNumber":"9b152b51d8704399bfc1b33db9fa8214","deviceType":"A2TF17PFR55MTB","friendlyName":null,"gadgetPaired":false,"online":false,"pairedDeviceList":null,"sconeBattery":null,"sconePaired":false,"softwareVersion":"130050002","streamingState":null},{"deviceSerialNumber":"SMG950FF40469E1060EB598","deviceType":"A1DL2DVDQVK3Q","friendlyName":null,"gadgetPaired":false,"online":false,"pairedDeviceList":null,"sconeBattery":null,"sconePaired":false,"softwareVersion":"516110110","streamingState":null},{"deviceSerialNumber":"70940514603302JH","deviceType":"ADVBD696BHNV5","friendlyName":null,"gadgetPaired":false,"online":false,"pairedDeviceList":null,"sconeBattery":null,"sconePaired":false,"softwareVersion":"662663720","streamingState":null},{"deviceSerialNumber":"edbb7e932cf347c7b287a5db19c3ee30","deviceType":"A3C9PE6TNYLTCH","friendlyName":null,"gadgetPaired":false,"online":false,"pairedDeviceList":null,"sconeBattery":null,"sconePaired":false,"softwareVersion":"0","streamingState":null},{"deviceSerialNumber":"G0911X03941304ML","deviceType":"A2JKHJ0PX4J3L3","friendlyName":"FireTV","gadgetPaired":false,"online":true,"pairedDeviceList":null,"sconeBattery":null,"sconePaired":false,"softwareVersion":"21039196292","streamingState":null},{"deviceSerialNumber":"G0911M079406180P","deviceType":"A1RABVCI4QCIKC","friendlyName":"Echo Dot-80P","gadgetPaired":false,"online":true,"pairedDeviceList":null,"sconeBattery":null,"sconePaired":false,"softwareVersion":"5805753220","streamingState":null},{"deviceSerialNumber":"G090U610916420KJ","deviceType":"A32DOYMUN6DTXA","friendlyName":"Echo-0KJ","gadgetPaired":false,"online":true,"pairedDeviceList":null,"sconeBattery":null,"sconePaired":false,"softwareVersion":"5805753476","streamingState":null},{"deviceSerialNumber":"G09183091056058K","deviceType":"A1Z88NGR2BK6A2","friendlyName":"Echo Show","gadgetPaired":false,"online":true,"pairedDeviceList":null,"sconeBattery":null,"sconePaired":false,"softwareVersion":"5805754756","streamingState":null},{"deviceSerialNumber":"21972b82caeee1fdd6a07cc3efcb2ea8","deviceType":"A2IVLV5VM2W81","friendlyName":null,"gadgetPaired":false,"online":false,"pairedDeviceList":null,"sconeBattery":null,"sconePaired":false,"softwareVersion":"1","streamingState":null},{"deviceSerialNumber":"SMG985F5B8874995CD23CCC","deviceType":"A1DL2DVDQVK3Q","friendlyName":null,"gadgetPaired":false,"online":false,"pairedDeviceList":null,"sconeBattery":null,"sconePaired":false,"softwareVersion":"516140110","streamingState":null}]}
                                  2021-10-11 16:41:52.263  - debug: alexa2.0 (13790) Alexa-Remote: No authentication check needed (time elapsed 1639)
                                  2021-10-11 16:41:52.264  - debug: alexa2.0 (13790) Alexa-Remote: Sending Request with {"host":"alexa.amazon.de","path":"/api/notifications?cached=true&_=1633963312264","method":"GET","timeout":10000,"headers":{}}
                                  2021-10-11 16:41:52.636  - debug: alexa2.0 (13790) Alexa-Remote: Response: {"notifications":[{"alarmLabel":null,"alarmTime":0,"assigner":null,"automationId":null,"createdDate":1633949250396,"deferredAtTime":null,"deliveryType":null,"deviceName":null,"deviceSerialNumber":"G090U610916420KJ","deviceType":"A32DOYMUN6DTXA","extensibleAttribute":null,"geoLocationTriggerData":null,"id":"A32DOYMUN6DTXA-G090U610916420KJ-c96e4f24-04cf-3832-894a-ad353d3dc589","lastOccurrenceTimeInMilli":0,"lastUpdatedDate":0,"loopCount":null,"mrmGroupContext":null,"musicAlarmId":null,"musicEntity":null,"notificationIndex":"c96e4f24-04cf-3832-894a-ad353d3dc589","originalDate":null,"originalDurationInMillis":240000,"originalTime":null,"personProfile":null,"provider":null,"rRuleData":null,"recurrenceEligibility":false,"recurringPattern":null,"remainingTime":0,"reminderAppLabel":null,"reminderLabel":null,"reminderSubLabel":null,"skillInfo":null,"snoozedToTime":null,"sound":{"displayName":"Simple Timer","folder":null,"id":"system_alerts_melodic_02","isChildDirected":false,"numAssets":0,"pricing":null,"providerId":"ECHO","sampleUrl":"https://s3.amazonaws.com/deeappservice.prod.notificationtones/system_alerts_melodic_02.mp3","sampleVideoUrl":null},"status":"OFF","targetPersonProfiles":null,"timeZoneId":null,"timerLabel":null,"tmwNotificationProperties":null,"triggerTime":1633949490000,"type":"Timer","version":"5"}]}
                                  2021-10-11 16:41:52.639  - debug: alexa2.0 (13790) Alexa-Remote: Initialize WS-MQTT Push Connection
                                  2021-10-11 16:41:52.659  - debug: alexa2.0 (13790) Alexa-Remote: No authentication check needed (time elapsed 2035)
                                  2021-10-11 16:41:52.660  - debug: alexa2.0 (13790) Alexa-Remote: Sending Request with {"host":"alexa.amazon.de","path":"/api/behaviors/entities?skillId=amzn1.ask.1p.music","method":"GET","timeout":10000,"headers":{"Routines-Version":"1.1.210292"}}
                                  2021-10-11 16:41:52.986  - debug: alexa2.0 (13790) Alexa-Remote: Response: [{"id":"AMAZON_MUSIC","displayName":"Amazon Music","description":"Music provider","supportedProperties":["Alexa.Music.PlaySearchPhrase"],"supportedTriggers":[],"supportedOperations":["Alexa.Music.PlaySearchPhrase"],"availability":"AVAILABLE","icon":null,"providerData":{"isDefaultMusicProvider":true,"isDefaultStationProvider":true}},{"id":"TUNEIN","displayName":"TuneIn","description":"Music provider","supportedProperties":["Alexa.Music.PlaySearchPhrase"],"supportedTriggers":[],"supportedOperations":["Alexa.Music.PlaySearchPhrase"],"availability":"AVAILABLE","icon":null,"providerData":{"isDefaultMusicProvider":false,"isDefaultStationProvider":false}},{"id":"CLOUDPLAYER","displayName":"My Library","description":"Music provider","supportedProperties":["Alexa.Music.PlaySearchPhrase"],"supportedTriggers":[],"supportedOperations":["Alexa.Music.PlaySearchPhrase"],"availability":"AVAILABLE","icon":null,"providerData":{"isDefaultMusicProvider":false,"isDefaultStationProvider":false}},{"id":"DEFAULT","displayName":"","description":"Default Music provider","supportedProperties":["Alexa.Music.PlaySearchPhrase"],"supportedTriggers":[],"supportedOperations":["Alexa.Music.PlaySearchPhrase"],"availability":"AVAILABLE","icon":null,"providerData":{"isDefaultMusicProvider":false,"isDefaultStationProvider":false}}]
                                  2021-10-11 16:41:52.988  - debug: alexa2.0 (13790) Alexa-Remote: No authentication check needed (time elapsed 2364)
                                  2021-10-11 16:41:52.989  - debug: alexa2.0 (13790) Alexa-Remote: Sending Request with {"host":"alexa.amazon.de","path":"/api/behaviors/v2/automations?limit=2000","method":"GET","timeout":30000,"headers":{}}
                                  2021-10-11 16:41:53.122  - debug: alexa2.0 (13790) Alexa-Remote WS-MQTT: Open: wss://dp-gw-na.amazon.de/tcomm/
                                  2021-10-11 16:41:53.126  - debug: alexa2.0 (13790) Alexa-Remote WS-MQTT: Incoming RAW message: 307833376131623630372030783030303030303963207b2270726f746f636f6c4e616d65223a22413a46222c22706172616d6574657273223a7b22416c70686150726f746f636f6c48616e646c65722e6d6178467261676d656e7453697a65223a223136303030222c22416c70686150726f746f636f6c48616e646c65722e7265636569766557696e646f7753697a65223a223136227d7d54554e45
                                  2021-10-11 16:41:53.128  - debug: alexa2.0 (13790) Alexa-Remote WS-MQTT: Incoming message: {"service":"TUNE","checksum":933344775,"content":{"protocolName":"A:F","parameters":{"AlphaProtocolHandler.maxFragmentSize":"16000","AlphaProtocolHandler.receiveWindowSize":"16"}}}
                                  2021-10-11 16:41:53.129  - debug: alexa2.0 (13790) Alexa-Remote WS-MQTT: Detected protocol A:F
                                  2021-10-11 16:41:53.132  - debug: alexa2.0 (13790) Alexa-Remote WS-MQTT: A:F Initialization Msg 2 sent: 307866653838626335322030783030303030303963207b2270726f746f636f6c4e616d65223a22413a46222c22706172616d6574657273223a7b22416c70686150726f746f636f6c48616e646c65722e7265636569766557696e646f7753697a65223a223136222c22416c70686150726f746f636f6c48616e646c65722e6d6178467261676d656e7453697a65223a223136303030227d7d54554e45
                                  2021-10-11 16:41:53.137  - debug: alexa2.0 (13790) Alexa-Remote WS-MQTT: A:F Initialization Msg 3 (Register Connection) sent: 4d534700000362171deea9660000000181f5ca86000000e447574d204d5347203078303030306234373920307830303030303033622075726e3a74636f6d6d2d656e64706f696e743a6465766963653a646576696365547970653a303a64657669636553657269616c4e756d6265723a3020307830303030303034312075726e3a74636f6d6d2d656e64706f696e743a736572766963653a736572766963654e616d653a446565576562736974654d6573736167696e6753657276696365207b22636f6d6d616e64223a2252454749535445525f434f4e4e454354494f4e227d46414245
                                  2021-10-11 16:41:53.139  - debug: alexa2.0 (13790) Alexa-Remote WS-MQTT: Send First Ping
                                  Speicherzugriffsfehler
                                  • SKBS SKB
                                    @apollon77
                                    Das passt zur Vermutung ... hätte aber bissl mehr erhofft :-)
                                      SKBS Offline
                                      SKBS Offline
                                      SKB
                                      @apollon77 Speicherzugriffsfehler ist wieder so eine "allgemeine Meldung", die alles heissen kann.
                                      SD-Card, RAM ...
                                      • SKBS Offline
                                        SKBS Offline
                                        SKB
                                        Habe einmal folgenden Befehl laufen lassen. An der Karte scheint es nicht zu liegen, wenn man sich auf die Ausgabe verlassen kann.
                                        root@ioBroker:/# time badblocks -sv /dev/mmcblk0p2 -o mmcblk0p2.log
                                        Checking blocks 0 to 62255103
                                        Checking for bad blocks (read-only test): done
                                        Pass completed, 0 bad blocks found. (0/0/0 errors)
                                        real    33m41,984s
                                        user    0m1,289s
                                        sys     0m29,628s
                                        • SKBS SKB
                                          real    33m41,984s
                                          user    0m1,289s
                                          sys     0m29,628s
                                          @skb
                                          Warum springst du da jetzt als root herum?
