  4. IOBroker Anbindung an einen Kostal Plenticore
1.3k Beiträge 83 Kommentatoren 564.5k Aufrufe 72 Beobachtet
  • DiginixD Diginix
    @martybr
    Der interessante Teil ist dieser:
    2021-10-01 13:45:18.903 - debug: plenticore.0 (558327) Sending post data to request: {"username":"user","nonce":"***"}
    2021-10-01 13:45:18.941 - debug: plenticore.0 (558327) Result of request: {"code":200,"headers":{"content-type":"text/html","expires":"Sun, 02 Jan 2000 11:11:11 GMT"},"body":"
    Sorry, the requested file does not exist on this server.
    2021-10-01 13:45:18.942 - error: plenticore.0 (558327) uncaught exception: Unexpected token < in JSON at position 0
    2021-10-01 13:45:18.943 - error: plenticore.0 (558327) SyntaxError: Unexpected token < in JSON at position 0
    at JSON.parse ()
    at /opt/iobroker/node_modules/iobroker.plenticore/lib/plenticore.js:2455:19
    at IncomingMessage. (/opt/iobroker/node_modules/iobroker.plenticore/lib/plenticore.js:1532:16)
    at IncomingMessage.emit (events.js:412:35)
    at endReadableNT (internal/streams/readable.js:1317:12)
    at processTicksAndRejections (internal/process/task_queues.js:82:21)
    2021-10-01 13:45:18.943 - error: plenticore.0 (558327) Unexpected token < in JSON at position 0
    2021-10-01 13:45:18.944 - debug: plenticore.0 (558327) API connection closed
    2021-10-01 13:45:19.021 - debug: plenticore.0 (558327) Making request to endpoint auth/logout with data {"method":"POST","port":80,"host":"192.168.178.77","path":"/api/v1/auth/logout","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:71.0) Gecko/20100101 Firefox/71.0","Content-Type":"application/json"},"rejectUnauthorized":false}
    2021-10-01 13:45:19.021 - debug: plenticore.0 (558327) Sending post data to request: null
    2021-10-01 13:45:19.021 - info: plenticore.0 (558327) [END] Stopping plenticore adapter...
    2021-10-01 13:45:19.021 - info: plenticore.0 (558327) terminating
    2021-10-01 13:45:19.022 - warn: plenticore.0 (558327) Terminated (UNCAUGHT_EXCEPTION): Without reason
    Irgendwas passt mit den Daten des WR nicht. Welches Model mit welcher Firmware hast du denn?
    MartyBr
    #1112
    @diginix
    Ich habe den Piko 20 Ver. 05.52 mit der FW 06.11
    Martin
    Homematic und Homematic IP
    • M MartyBr
      @diginix
      DiginixD Offline
      DiginixD Offline
      Diginix
      #1113
      @martybr Möglicherweise ist das das Problem. Der Adapter ist für Plenticore und @StrathCole nutzt das WebUI um an die Werte zu kommen. Das vom Piko ist evtl. anders aufgebaut und passt nicht zum Code des Adapters.
      In der Adapter Beschreibung steht: "Adapter for KOSTAL Plenticore Plus inverter (i. e. Plenticore Plus 8.5)"
      Ob der auch mit Piko funktionieren müsste, kann nur @StrathCole selbst beantworten.
      ..:: So long! Tom ::..
      • DiginixD Diginix
        MartyBr
        #1114
        @diginix
        Eigentlich sollten beide WR die gleiche Software haben. Der Plenticore ist leider zu schwach für meine Anlage.
        Vielleicht Melder sich @StrathCole dazu.
        Danke für deine Analyse
        Martin
        • StrathColeS Offline
          StrathColeS Offline
          StrathCole
          #1115
          Hallo.
          Der Piko hat meines Wissens nach eine andere Software mit anderen URLs. Es wird nicht möglich sein, ihn mit diesem Adapter zu nutzen, sorry.
          Viele Grüße
          SolarWatt-Anlage mit 9,6 kWp – KOSTAL Plenticore Plus 10 – BYD B-Box HV 8,96 – Viessmann Vitocal 333g – Zehnder ComfoD 350 (Comfoair 350) mit RS232-Ethernet-Konverter
            MartyBr
            #1116
            @strathcole
            Schade! Danke aber für deine Antwort. 😢
            Martin
            • StrathColeS StrathCole
              Ich habe die Steuerung auch einmal testweise aktiviert. Es funktioniert tatsächlich. Ich hatte noch 40% Ladung in der Batterie und eine Entladung von 700W. Habe dann die externe Steuerung aktiviert und via Modbus das Register 1040 auf 50W gesetzt. Wenige Sekunden später sank die Batterieentladung auf 48W und der Rest wurde aus dem Netz bezogen.
              Ich habe dann mit dem o.g. Trick wieder auf interne Steuerung gestellt und schon hat der Kostal den Registerwert wieder auf ~4750W gesetzt.
              Wichtig ist wohl: Auch wenn man die Steuerung aktiviert und den Wert setzt, schwankt dieser etwas. Habe im Test auf 100W gesetzt und der ModBus Wert schwankte anschließend um ein paar W nach oben und unten.
              mstormi
              schrieb am zuletzt editiert von mstormi
              #1117
              Hallo @StrathCole ,
              EDIT: hab's, war ein Config-Fehler.
              Die Frage nach dem Timeout würde mich aber weiter interessieren.
              ich versuche einen Plenticore zwangsweise zum Laden oder Entladen der Batterie zu bewegen und habe dabei diesen Deinen Post gefunden.
              Mein Problem ist daß nach Senden des unten genannten Ladebefehl 1040 der Plenticore diesen ignoriert d.h. die Ladeleistung nicht anpasst und das Register sofort wieder mit eigenen Werten überschreibt (die Werte sind übrigens nicht statisch sondern wackeln immer um 5 kW).
              Steuerung per Modbus ist natürlich aktiviert und funktioniert grundsätzlich auch.
              Die 'Intelligente Batteriesteuerung' wie es in neuen Firmwaren heisst ist auch deaktiviert. Aber er ignoriert sie
              Muß ich noch irgendetwas anderes in der Konfiguration ändern damit das olle Ding auch auf mich hört ?
              dankbar für jeden Hinweis der zur Ergreifung des Täters führt,
              Grüße MS
              PS: hast Du auch rausgefunden wie das mit dem Timeout funktioniert? Muss man dann innerhalb dieses Zeitfensters den Modbus-Befehl wiederholen damit der Plenticore nicht in den Ich-manage-mich-wieder-selber-Modus springt?
              @strathcole said in IOBroker Anbindung an einen Kostal Plenticore:
              • T tueftler17
                @ukl Eine Möglichkeit wäre das über die Kombination mit dem BYDHVS-Adapter und dem Modbus-Adapter realisieren. Aus dem BYDHVS-Adapter bekommst Du die Spannungen (min, max) heraus. Ich steuere die Ladung damit so, das ich je nach Differenz zwischen kleinster und größter Zellenspannung die Ladeleistung reduziere. Damit möchte ich das balancen verbessern. Und: bei der ersten Zelle mit 3,45 Volt ist Schluss mit laden, egal wie voll der Speicher ist.
                Die Ladung an sich kannst du mit dem Register 1038 steuern. Wenn Du da eine "0" reinschreibst lädt nix mehr.
                Voraussetzung natürlich: Die Modbus-Steuerung für den Plenticore ist freigeschaltet.
                BTW: Die Entladeleistung kannst Du mit dem Register 1040 steuern, wenn mein Speicher fast leer ist entlade ich ihn nur noch mit 500W, ist auch ein Kleiner mit nur 2 Modulen.
                mstormi
                #1118
                @tueftler17 said in IOBroker Anbindung an einen Kostal Plenticore:
                wie kann ich den WR per Modbus denn nach einem Zwangs-Ladebefehl wieder in den Normalmodus versetzen so daß er Überschuß lädt?
                Ich habe gemerkt daß das anscheinend bei Erreichen des Timeouts für externe Batteriesteuerung stattfindet, aber kann ich das auch direkt erzwingen ?
                Sehr schön übrigens auch der Timeout hat einen Default 180s aber die Plenticore-UI erlaubt nur Werte von 1-60s
                • SimmlyS Simmly
                  @strathcole Danke für die schnelle Antwort...damit hatte ich nicht gerechnet und erst heute geschaut!
                  Ich versuche ein wenig konkreter zu werden:
                  Hier kommt z.B. meine gestrige Ertragskurve im VIS:
                  Ich möchte hier zusätzlich den Verlauf der Prognosewerte für diesen Tag darstellen - das Diagram habe ich mit FLOT erstellt. Ich finde keinen DP im Adapter, der die Zeitserie der Prognose abbildet. Kannst Du mir nochmal helfen wie Du die Prognosewerte im VIS angezeigt bekommst? Vielen Dank im Voraus!
                  gjo
                  schrieb am zuletzt editiert von gjo
                  #1119
                  @simmly Hallo,
                  neben den aktuellen Werten, stellt der Adapter ja auch unter day1 Werte für den Forecast des anstehenden Tages zur Verfügung. Nur wie stelle ich die sinnvoll und korrekt dar. Gerechnet wird wie ich verstanden habe der vorhergesagte Ertrag ab Sonnenaufgang.
                  Hat da jemand schon eine Darstellung in Flot o.ä. gebastelt? Im Grunde genommen soll ab Zeitpunkt jetzt eine Kurve (hier in rot) mit dem power forecast day 1 erscheinen.
                  • G gjo
                    @simmly Hallo,
                    DiginixD Offline
                    DiginixD Offline
                    Diginix
                    #1120
                    @gjo Hier hatte ich mein Diagramm mal gezeigt.
                    https://forum.iobroker.net/post/407448
                    oder
                    https://forum.iobroker.net/post/399200
                    oder
                    https://forum.iobroker.net/post/386377
                    G 1 Antwort Letzte Antwort
                    • DiginixD Diginix
                      oder
                      oder
                      gjo
                      #1121
                      @diginix Hi,
                      Danke dafür. Das sind Diagramme des vergangenen Tags. Ich wollte hingegen ein Diagramm der Vorhersage. In meinem Beispielbild sind die blaue / grüne Linien der akteulle Wert ... rot sollte dann die Vorhersage sein.
                      Ableitend daraus könnte man manuell festlegen wann man die Waschmaschine etc. startet.
                      • G gjo
                        @diginix Hi,
                        DiginixD Offline
                        DiginixD Offline
                        Diginix
                        #1122
                        @gjo K.a. ob Flot, Grafana usw. bereits Grafen zeichnen wenn die Werte der X Achse aus der Zukunft stammen.
                        • H Offline
                          HomeUser
                          #1123
                          erstmal vielen Dank, dass es diesen Adapter gibt :-)
                          Bevor ich die Prognose in blindem Vertrauen zur Steuerung aktiviere, habe ich erstmal meine Daten eingetragen und ein paar Tage beobachtet, ob ich alles richtig eingestellt habe und die Prognose passt.
                          Damit ich es verstehen kann, habe ich die Prognose und die generierte Energie aufgezeichnet: braun ist die Prognose; blau die angepasste Prognose und grün die Ist-Werte.
                          Dabei bekomme ich folgendes Bild:
                          Ist das ein normaler Verlauf und ich kann mit gutem Gewissen die Steuerung durch den Adapter aktivieren?
                          Mich irritiert, dass die Prognose absinkt sobald der Ist-Wert steigt.
                          Vielleicht gab es die Frage auch schon mal in diesem Forum. Aber bei >1000 Einträgen.....
                          StrathColeS 1 Antwort Letzte Antwort
                          • H HomeUser
                            StrathColeS Offline
                            StrathColeS Offline
                            StrathCole
                            schrieb am zuletzt editiert von StrathCole
                            #1124
                            @homeuser ich muss da noch irgendwo einen Bug haben. Der Wert sinkt auch bei mir ab. Im Moment ist es besser, sich nach dem korrigierten Wert zu richten. Scheinbar macht der Adapter aktuell etwas bei der "heutigen" Prognose für schon vergangene Stunden falsch.
                            Komme im Moment nicht dazu, das zu untersuchen.
                            H 1 Antwort Letzte Antwort
                              HomeUser
                              #1125
                              seit einigen Tagen habe ich die Lade-Steuerung durch den Adapter aktiviert und probiere noch zu verstehen wie (gut) er steuert,
                              Heute hatte ich folgendes Verhalten:
                              Gestern war ein guter Tag (viel Sonne). Für heute ist extrem wenig Sonne in der Vorhersage. Heute Nacht wurde der Speicher nur bis 40% entladen und der restliche Nachtbedarf aus dem Netz geholt.
                              Ist dies das vorgesehene Verhalten? Wenn je, warum?
                              • H HomeUser
                                StrathColeS Offline
                                StrathColeS Offline
                                StrathCole
                                #1126
                                @homeuser was hast du denn im Adapter bei max MinSoC eingetragen? Mehr als 8-10% sollten es nicht sein.
                                H U 2 Antworten Letzte Antwort
                                  HomeUser
                                  #1127
                                  Danke für die prompte Antwort. Dann liegt da wohl mein Fehler. Ich hatte die Werte drin gelassen, die eingetragen waren (woher die kommen, weiß ich nicht).
                                  Das sind:
                                  • Minimaler SoC zur Aktivierung des Batteriemanagements: 10
                                  • Maximaler MinSoC (%): 40
                                  • Minimum MinSoC (%): 5
                                  Welche Werte wären gut für Einsteiger? Mit SoC-Überlegungen habe ich mich bisher nicht beschäftigt.
                                  Und noch eine andere Frage: Ist der Wert plenticore.0.scb.statistic.EnergyFlow.YieldDay die PV-Produktion des Tages oder PV+Speicher? Ich frage, weil ich dachte, dass es die PV-Produktion sei, aber gestern schon morgens bei Dunkelheit ein Wert drin war. Vielleicht muss ich das aber auch noch ein paar Tage beobachten.
                                  • H HomeUser
                                    Das sind:
                                    StrathColeS Offline
                                    StrathColeS Offline
                                    StrathCole
                                    #1128
                                    @homeuser einfach die 40 in 8 oder 10 ändern.
                                    Yield ist immer Verbrauch aus PV plus Speicher.
                                      HomeUser
                                      #1129
                                      @strathcole
                                      Danke. Donate ist unterwegs - Für den Adapter und den tollen Support.
                                      Gibt es einen Wert für die von PV erzeugten Leistung (Tag/Monat/Jahr)?
                                      • H HomeUser
                                        @strathcole
                                        StrathColeS Offline
                                        StrathColeS Offline
                                        StrathCole
                                        #1130
                                        @homeuser danke.
                                        Der Yield + aktueller Speicherinhalt. Das müsste die Produktion sein, wenn ich es richtig im Kopf habe.
                                          U Offline
                                          U Offline
                                          ukl
                                          #1131
                                          @strathcole sagte in IOBroker Anbindung an einen Kostal Plenticore:
                                          @homeuser sagte in IOBroker Anbindung an einen Kostal Plenticore:
                                          Ist denn das Verhalten nicht in Ordnung, wenn die Prognose für die nächsten Tage sagt, dass sehr wenig oder keine Sonne scheint? Dann muss doch der minSoC relativ hoch sein (>20%) um die Zwangsladung für die nächsten Tage zu umgehen - dass ist doch der Sinn der Steuerung.
                                          Ein Wert von 8-10% für den max MinSoC ist doch viel zu klein, oder habe ich da etwas nicht verstanden?
                                          In der dunklen Jahreszeit gibt es doch schon mal mehrere Tage wo nichts von der Sonne kommt und das regelt doch der Adapter mit der dynamischen minSoC Anpassung - @strathcole ist so richtig?
                                          TRINA_HoneyM_330-340W: 9,86kwp, Plentcore Plus 8.5, BYD HVS10.2
