  4. Wunsch: Pollenflug-(Adapter/wasauchimmer)
269 Beiträge 45 Kommentatoren 104.7k Aufrufe 21 Beobachtet
  • P
    P
    pix
    Hier noch das Biowetter von WetterOnline.
    http://forum.iobroker.net/viewtopic.php … 800#p47090
    Pix
    • M
      M
      moebius
      Hier noch meine Variante in node-red.
      Die Werte stehen dann in einem Array und man kann sie entweder an den iobroker schicken, oder gleich in die Datenbank.
      [{"id":"d5352d.f1122ad","type":"tab","label":"Flow 3"},{"id":"37cd7d6e.23ad32","type":"http request","z":"d5352d.f1122ad","name":"","method":"GET","ret":"txt","url":"http://www.wetteronline.de/pollenvorhersage?gid=10513","tls":"","x":414,"y":151,"wires":[["b06d8502.cd8d08"]]},{"id":"b06d8502.cd8d08","type":"html","z":"d5352d.f1122ad","name":"","tag":".pollentype","ret":"html","as":"multi","x":588,"y":247,"wires":[["bdb2417d.c0527","e1341752.5bda18"]]},{"id":"834494d6.1e4a38","type":"debug","z":"d5352d.f1122ad","name":"","active":true,"console":"false","complete":"true","x":1163,"y":244,"wires":[]},{"id":"b37a6bd9.da2208","type":"inject","z":"d5352d.f1122ad","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":122,"y":101,"wires":[["b0bb7dcb.87f3b"]]},{"id":"b0bb7dcb.87f3b","type":"function","z":"d5352d.f1122ad","name":"user agent","func":"\n\nmsg.headers = {\n        \"user-agent\": \"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/55.0.2883.87 Safari/537.36\",\n    };\nreturn msg;","outputs":1,"noerr":0,"x":228,"y":236,"wires":[["37cd7d6e.23ad32"]]},{"id":"bdb2417d.c0527","type":"html","z":"d5352d.f1122ad","name":"","tag":".burden","ret":"text","as":"multi","x":796,"y":276,"wires":[["f57563ce.2feb4"]]},{"id":"e1341752.5bda18","type":"html","z":"d5352d.f1122ad","name":"","tag":".type","ret":"text","as":"multi","x":773,"y":189,"wires":[["f57563ce.2feb4"]]},{"id":"f57563ce.2feb4","type":"join","z":"d5352d.f1122ad","name":"","mode":"custom","build":"array","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","timeout":"","count":"2","x":988,"y":223,"wires":[["834494d6.1e4a38"]]}]
      • S
        S
        simpixo
        @pix:
        Pollenvorhersage von WetterOnline. `
        Hallo Pix
        ich habe seit neusten ein kleines Problem mit deinem Script….Warum lief es die ganze zeit und jetzt erhalte ich für ein Objekt die folgende Meldung?
        javascript.0	2017-02-06 09:01:31.445	warn	Wrong type of javascript.0.Umwelt.Pollenvorhersage.übermorgen.hasel: "object". Please fix, while deprecated and will not work in next versions.
        javascript.0	2017-02-06 09:01:31.375	warn	Wrong type of javascript.0.Umwelt.Pollenvorhersage.heute.hasel: "object". Please fix, while deprecated and will not work in next versions.
        javascript.0	2017-02-06 09:01:31.352	warn	Wrong type of javascript.0.Umwelt.Pollenvorhersage.morgen.hasel: "object". Please fix, while deprecated and will not work in next versions
        Ich habe jetzt das Hasel Objekt von Zahl auf Objekt geändert und die Info Message ist jetzt verschwunden…. aber warum ist das bei der Hasel anders als bei den anderen??? :shock: Die anderen sind alle auf Zahl eingestellt und es funktioniert problemlos
        Wäre Cool von dir wenn du mir ein Tip geben könntest
        Adrian
        • S
          S
          simpixo
          Keiner eine Idee warum das plötzlich so ist!? [emoji53]
          • apollon77A
            apollon77A
            Ggf hast Bluefox was im js.controller oder javascript-Adapter geändert?
            • P
              P
              pix
              Hallo~~@simpixo:~~
              h habe seit neusten ein kleines Problem mit deinem Script…. ` kannst du das Skript mal zitieren oder im Spoiler und Code Tags hier einstellen?
              Pix
              • S
                S
                simpixo
                @pix:
                Pix `
                Hallo Pix
                wie gewünscht hier das Script….
                `/* Pollenflug Parser von wetteronline.de
                http://forum.iobroker.net/viewtopic.php?f=23&t=2799&sid=936235bdac98a70a1d8672897d334a07#p25266
                05.05.2016 erstellt von steinwedel für homoran
                06.05.2016 Anpassung durch pix
                var url = "http://www.wetteronline.de/pollen/waldsee";
                var pfad = "Umwelt.Pollenvorhersage.";
                var logging = true;
                // ab hier nix ändern
                var Pollenarten = ['Hasel','Pappel','Weide','Ulme','Birke','Buche','Ampfer','Roggen','Gräser','Eiche','Wegerich','Beifuß','Ambrosia', 'Erle'];
                var tage_vorhersage = ['heute','morgen','übermorgen'];
                var request = require('request');
                function dpAnlegen(y) {
                    for(var i=0;i<pollenarten.length;i++) {/createstate(pfad/+/tage_vorhersage[y]/'.'/pollenarten[i].tolowercase(),0,/name:/'wetteronline/pollenvorhersage/'/pollenarten[i],/desc:/'vorhersage/für/pollenbelastung/durch/type:/'number'/});/}/function/readpollenwetter(x)/var/options="{" url:/((x="">0) ? url + '?fcdatstr=' + tag(x) : url), // korrekten Link erstellen
                        headers: {
                            'User-Agent': 'Mozilla/5.0 (Windows NT 6.1; WOW64; rv:40.0) Gecko/20100101 Firefox/40.1'
                    try {
                        request(options, function (error, response, body) {
                            if (!error && response.statusCode == 200) {              // kein Fehler, Inhalt in body
                                body=body.replaceAll(String.fromCharCode(13),"");
                                body=body.replaceAll(String.fromCharCode(10),"");
                                body=body.replaceAll(String.fromCharCode(9)," ");
                                body=strip_tags(body);
                                for(var i=0;i<pollenarten.length;i++) 0/60/1000/20160506/{/setstate(pfad/+/tage_vorhersage[x]/'.'/pollenarten[i].tolowercase(),{val:/getpollenindex(pollenarten[i],body),/ack:/true});/if/(logging)/log(pollenarten[i].tolowercase()/'/getpollenindex(pollenarten[i],body));/}/else/log("statuscode="+response.statusCode);
                                log(error,'error');                               // Error beim Einlesen
                    } catch (e) {
                        log('Fehler (try) leseWebseite: ' + e, 'error');
                function strip_tags(data) {
                    var rueckgabe = data.replace(/(&nbsp;|<([^>]+)>)/ig, " ");/return(rueckgabe);/function/getpollenindex(pflanze,/html)/var/code="{'kein':0," 'schwach':1,/'mäßig':2,/'stark':3};/result/;/start="html.indexOf(pflanze)+pflanze.length;" stop="result.indexOf('" ');/return/code[result];/string.prototype.replaceall="function(find," replace)/str="this;" str.replace(new/regexp(find.replace(/([.*+?^="!:${}()|\[\]\/\\])/g," "\\$1"),/'g'),/replace);/};/tag/(abstand)/eingabe/0,/1,/2,/.../jetzt="new" date();/jetzt.sethours(0);/jetzt.setminutes(0);/jetzt.setseconds(0);/jetzt.setmilliseconds(0);/newdate="new" newdate.settime(jetzt.gettime()/(24/*/abstand)/);/heute/anzahl/tage/ins/millisekunden/date="newdate.getDate();" month="newdate.getMonth()+1;" year="newdate.getFullYear();" </10)/?/'0'/:/date;/month;/rueckgabe="year.toString()+month.toString()+date.toString();" log('datum/in/link:/rueckgabe);/(rueckgabe);/ausgabe/z.b./alle/aus/dem/array/durchgehen/(x)/main()/for/(var/x="0;" tage_vorhersage.length;/x++)/dpanlegen(x);/readpollenwetter(x);/main();/schedule("5/*",/main);/<e=""></pollenarten.length;i++)></pollenarten.length;i++)>`[/i][/i][/i][/i][/i][/i][/i]
                • P
                  P
                  pix
                  Hallo Adrian,@simpixo:
                  @pix:
                  Hallo Pix
                  Adrian `
                  Das Skript ist übrigens von steinwedel, nicht von mir: http://forum.iobroker.net/viewtopic.php … a07#p25266
                  Du hast also die States im Reiter Objekte wieder gelöscht und dann das Skript neu gestartet, damit die States neu angelegt werden?
                  Und dann werden alle Gräser fehlerfrei abgearbeitet, nur das erste Gras "Hasel" nicht?
                  Das ist tatsächlich seltsam. Das Objekt wird ja in dieser Zeile geschrieben:
                  `setState(pfad + tage_vorhersage[x] + '.' + Pollenarten[i].toLowerCase(),{val: GetPollenIndex(Pollenarten[i],body), ack: true});`
                  Du kannst es mal ohne Ackknowledge probieren:
                  `~~[code]~~setState(pfad + tage_vorhersage[x] + '.' + Pollenarten[i].toLowerCase(), GetPollenIndex(Pollenarten[i],body));`
                  Pix[/i][/i][/code][/i][/i]
                  • S
                    S
                    simpixo
                    @pix:
                    Pix
                    Hallo Pix,
                    oh sorry dachte das wäre dein Script ;) Dann muss ich mal Steinwedel kontaktieren. Dein Vorschlag habe ich übernommen aber leider hilft dieser nicht. Trotzdem Danke!!!
                    Ja klar habe ich alle DP's gelöscht und das Script legt sie auch wieder alle schön an. Komischerweise erhalte ich folgende Fehler im LoG
                    `~~[code]~~javascript.0	2017-02-19 11:58:31.686	info	script.js.Umwelt.Pollenflug_Vorhersage: erle undefined
                    javascript.0	2017-02-19 11:58:31.686	warn	Wrong type of javascript.0.Umwelt.Pollenvorhersage.heute.erle: "undefined". Please fix, while deprecated and will not work in next versions.
                    javascript.0	2017-02-19 11:58:31.681	info	script.js.Umwelt.Pollenflug_Vorhersage: hasel undefined
                    javascript.0	2017-02-19 11:58:31.680	warn	Wrong type of javascript.0.Umwelt.Pollenvorhersage.heute.hasel: "undefined". Please fix, while deprecated and will not work in next versions.
                    [/code]`
                    Alle anderen DP sind in Ordnung und es wird auch kein Fehler ausgegeben
                    Adrian[/i][/i][/code][/i][/i]
                    • HomoranH
                      Hallo zusammen.
                      Warum das nur bei einzelnen auftritt ist mir bei meiner Erklärung natürlich ein Dorn im Auge ;-)
                      Und dann noch js-Legastheniker, aber lernend!
                      Ich kann mich an irgendeinen Post von paul53 (?) erinnern, dass diese Meldung aufgrund der unvollständigen/unrichtigen Deklaration des Datenpunkts herrührt.
                      Ich glaube da war irgendetwas, dass diese Datenpunkte oft nur als "mixed" oder so deklariert würden, aber als Zahl hätten deklariert werden müssen.
                      • S
                        S
                        simpixo
                        Hallo Rainer,
                        Ja aber alle Dp's sind identisch [emoji15]
                        Habe das nämlich schon kontrolliert, alle sind als Zahl deklariert und trotzdem kommen bei den zwei Gräsern die Fehler im log! Und das für heute/morgen/übermorgen
                        Komisch ist das schon [emoji53]
                        Adrian
                        • ThisoftT
                          ThisoftT
                          Thisoft
                          Hast du bei den betreffenden DP's die SQL-Historie aktiviert?
                          22 HM-Geräte; PivCCU2 auf RasPi
                          ioBroker-Multihost; Ubuntu-Master auf Intel-Atom und 3 RasPi-Clients
                          • S
                            S
                            simpixo
                            Ja hatte ich aktiv, aber nach dem löschen habe ich sie noch nicht wieder aktiviert!
                            Hat das was damit zutun!?
                            • ThisoftT
                              ThisoftT
                              Thisoft
                              Jein ;)
                              Wenn du sie noch nicht wieder aktiviert hast dürfte der Fehler zwar m.E. nicht auftreten, aber es ist definitiv so dass es Probleme gibt wenn man einen DP früher als Text definiert hatte und dann mal auf Zahl geändert. Die alten (Text)Werte stehen immer noch in der Datenbank und bei einer neuen Abfrage auf Zahlenwerte gibt's dann Ärger. Brauchst du die Werte von früher noch? Wenn nicht solltest Du die aus der Db löschen, zum Löschen einzelner DP's aus der SQL-Db gibt's aktuell im Forum Threads…
                              • S
                                S
                                simpixo
                                Ok das versuche ich mal, guter Ansatz!
                                Vielleicht ist es der Grund! Ich werde berichten
                                Adrian
                                • S
                                  S
                                  simpixo
                                  Hallo
                                  leider hat das nicht geholfen. Der Fehler ist immer noch da auch nachdem ich die Daten aus der DB gelöscht habe
                                  @Steinwedel @steinwedel:
                                  Hilfe :-) `
                                  Weißt du das was da los ist? Wurde auf der Website was geändert? Ich erhalte nämlich die folgenden Fehler ???? :shock:
                                  Danke in voraus
                                  Adrian
                                  • S
                                    S
                                    simpixo
                                    Hallo zusammen
                                    ohne irgendein zutun funktioniert es wieder ohne einen Fehler im Log! Auch die DP´s werden richtig gefüllt ;) komische Sache :roll:
                                    Adrian
                                    • R
                                      R
                                      Romö
                                      Hallo
                                      ich bin ein ioBroker Anfänger und gerade am Zusammenstellen einer individuellen Smarthome Steuerung.
                                      Seit Tagen versuche ich schon das Script zur Polenabfrage hinzubekommen. Leider werden Pollen die größer 0 sind nicht angezeigt.
                                      javascript.0	2018-01-08 14:04:41.396	info	script.js.Wetter.Pollenflug.Pollenflug: hasel undefined
                                      javascript.0	2018-01-08 14:04:41.395	info	script.js.Wetter.Pollenflug.Pollenflug: setForeignState(id=javascript.0.WetterOnline.pollenvorhersage.heute.hasel, state=undefined)
                                      ich verwende folgendes Script:
                                      var url = "https://www.wetteronline.de/pollen/jesenwang";
                                      var pfad = "WetterOnline.pollenvorhersage.";
                                      var logging = true;
                                      var Pollenarten = ['Pappel','Weide','Ulme','Birke','Buche','Ampfer','Roggen','Gräser','Eiche','Wegerich','Beifuß','Ambrosia','Hasel','Erle' ];
                                              headers: {
                                          try {
                                                      body=body.replaceAll(String.fromCharCode(9),"");
                                                      for(var i=0;i<pollenarten.length;i++) 0/60/1000/20160506/{/setstate(pfad/+/tage_vorhersage[x]/'.'/pollenarten[i].tolowercase(),/getpollenindex(pollenarten[i],body));/if/(logging)/log(pollenarten[i].tolowercase()/'/}/else/log("statuscode="+response.statusCode);
                                          } catch (e) {
                                          var rueckgabe = data.replace(/(&nbsp;|<([^>]+)>)/ig, " ");/return(rueckgabe);/function/getpollenindex(pflanze,/html)/var/code="{'kein'" :0,/'schwach'/:1,/'mäßig'/:2,/'stark'/:3};/result/;/start="html.indexOf(pflanze)+pflanze.length;" stop="result.indexOf('" ');/return/code[result];/string.prototype.replaceall="function(find," replace)/str="this;" str.replace(new/regexp(find.replace(/([.*+?^="!:${}()|\[\]\/\\])/g," "\\$1"),/'g'),/replace);/};/tag/(abstand)/eingabe/0,/1,/2,/.../jetzt="new" date();/jetzt.sethours(0);/jetzt.setminutes(0);/jetzt.setseconds(0);/jetzt.setmilliseconds(0);/newdate="new" newdate.settime(jetzt.gettime()/(24/*/abstand)/);/heute/anzahl/tage/ins/millisekunden/date="newdate.getDate();" month="newdate.getMonth()+1;" year="newdate.getFullYear();" </10)/?/'0'/:/date;/month;/rueckgabe="year.toString()+month.toString()+date.toString();" log('datum/in/link:/rueckgabe);/(rueckgabe);/ausgabe/z.b./alle/aus/dem/array/durchgehen/(x)/main()/for/(var/x="0;" tage_vorhersage.length;/x++)/dpanlegen(x);/readpollenwetter(x);/main();/schedule("5/*",/main);<e=""></pollenarten.length;i++)></pollenarten.length;i++)>`
                                      kann mir wer einen Tip geben
                                      Viele Grüße Hans[/i][/i][/i][/i][/i][/i][/i]
                                      • lobomauL
                                        lobomauL
                                        lobomau
                                        @Romö:
                                        Hallo
                                        var logging = true;
                                                headers: {
                                            try {
                                            } catch (e) {
                                        Viele Grüße Hans
                                        "request" als npm Modul ist installiert?
                                        Ich habe es auch eben installiert. Sollte eigentlich für morgen Hasel schwach anzeigen. Tut es aber nicht. Gibt nur Warnungen:
                                        `~~[code]~~javascript.0	2018-01-11 20:43:53.896	info	script.js.common.Pollenflug: erle undefined
                                        javascript.0	2018-01-11 20:43:53.895	warn	at process._tickCallback (internal/process/next_tick.js:104:9)
                                        javascript.0	2018-01-11 20:43:53.895	warn	at _combinedTickCallback (internal/process/next_tick.js:80:11)
                                        javascript.0	2018-01-11 20:43:53.895	warn	at endReadableNT (_stream_readable.js:974:12)
                                        javascript.0	2018-01-11 20:43:53.895	warn	at IncomingMessage.emit (events.js:185:7)
                                        javascript.0	2018-01-11 20:43:53.895	warn	at emitNone (events.js:91:20)
                                        javascript.0	2018-01-11 20:43:53.894	warn	at IncomingMessage.g (events.js:292:16)
                                        javascript.0	2018-01-11 20:43:53.894	warn	at IncomingMessage. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1085:12)
                                        javascript.0	2018-01-11 20:43:53.894	warn	at Request.emit (events.js:188:7)
                                        javascript.0	2018-01-11 20:43:53.893	warn	at emitOne (events.js:96:13)
                                        javascript.0	2018-01-11 20:43:53.893	warn	at Request. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1163:10)
                                        javascript.0	2018-01-11 20:43:53.893	warn	at Request.emit (events.js:191:7)
                                        javascript.0	2018-01-11 20:43:53.893	warn	at emitTwo (events.js:106:13)
                                        javascript.0	2018-01-11 20:43:53.892	warn	at Request.self.callback (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:186:22)
                                        javascript.0	2018-01-11 20:43:53.892	warn	at Request._callback (script.js.common.Pollenflug:43:17)
                                        javascript.0	2018-01-11 20:43:53.888	warn	Wrong type of javascript.0.WetterOnline.pollenvorhersage.übermorgen.erle: "undefined". Please fix, while deprecated and will not work in next versions.
                                        javascript.0	2018-01-11 20:43:53.887	info	script.js.common.Pollenflug: hasel undefined
                                        javascript.0	2018-01-11 20:43:53.887	warn	at process._tickCallback (internal/process/next_tick.js:104:9)
                                        javascript.0	2018-01-11 20:43:53.887	warn	at _combinedTickCallback (internal/process/next_tick.js:80:11)
                                        javascript.0	2018-01-11 20:43:53.886	warn	at endReadableNT (_stream_readable.js:974:12)
                                        javascript.0	2018-01-11 20:43:53.886	warn	at IncomingMessage.emit (events.js:185:7)
                                        javascript.0	2018-01-11 20:43:53.886	warn	at emitNone (events.js:91:20)
                                        javascript.0	2018-01-11 20:43:53.885	warn	at IncomingMessage.g (events.js:292:16)
                                        javascript.0	2018-01-11 20:43:53.885	warn	at IncomingMessage. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1085:12)
                                        javascript.0	2018-01-11 20:43:53.885	warn	at Request.emit (events.js:188:7)
                                        javascript.0	2018-01-11 20:43:53.885	warn	at emitOne (events.js:96:13)
                                        javascript.0	2018-01-11 20:43:53.884	warn	at Request. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1163:10)
                                        javascript.0	2018-01-11 20:43:53.884	warn	at Request.emit (events.js:191:7)
                                        javascript.0	2018-01-11 20:43:53.884	warn	at emitTwo (events.js:106:13)
                                        javascript.0	2018-01-11 20:43:53.884	warn	at Request.self.callback (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:186:22)
                                        javascript.0	2018-01-11 20:43:53.883	warn	at Request._callback (script.js.common.Pollenflug:43:17)
                                        javascript.0	2018-01-11 20:43:53.882	warn	Wrong type of javascript.0.WetterOnline.pollenvorhersage.übermorgen.hasel: "undefined". Please fix, while deprecated and will not work in next versions.
                                        javascript.0	2018-01-11 20:43:53.881	info	script.js.common.Pollenflug: ambrosia 0
                                        javascript.0	2018-01-11 20:43:53.880	info	script.js.common.Pollenflug: beifuß 0
                                        javascript.0	2018-01-11 20:43:53.880	info	script.js.common.Pollenflug: wegerich 0
                                        javascript.0	2018-01-11 20:43:53.879	info	script.js.common.Pollenflug: eiche 0
                                        javascript.0	2018-01-11 20:43:53.878	info	script.js.common.Pollenflug: gräser 0
                                        javascript.0	2018-01-11 20:43:53.878	info	script.js.common.Pollenflug: roggen 0
                                        javascript.0	2018-01-11 20:43:53.877	info	script.js.common.Pollenflug: ampfer 0
                                        javascript.0	2018-01-11 20:43:53.877	info	script.js.common.Pollenflug: buche 0
                                        javascript.0	2018-01-11 20:43:53.876	info	script.js.common.Pollenflug: birke 0
                                        javascript.0	2018-01-11 20:43:53.874	info	script.js.common.Pollenflug: ulme 0
                                        javascript.0	2018-01-11 20:43:53.873	info	script.js.common.Pollenflug: weide 0
                                        javascript.0	2018-01-11 20:43:53.872	info	script.js.common.Pollenflug: pappel 0
                                        javascript.0	2018-01-11 20:43:53.850	info	script.js.common.Pollenflug: erle undefined[/code]`[/i][/i][/i][/i][/i][/i][/i]
                                        Host: NUC8i3 mit Proxmox:
                                        • Slave: Pi4
                                          Hallo Zusammen,
                                          habe das gleiche Problem mit dem Script…. denke mal, die Website wurde geändert... hab mal kurz draufeschaut in der Tabelle mit den Pollen sind keine Zahlen mehr sondern Symbole (icons) mit dem entsprechenden Wert, denke mals das "parsing" muss hier angepasst werden.
                                          Equilora
                                          84.2k
