  4. JavaScript
  5. Hilfe bei RSS-feed benötigt !
    1.0k
    6.1k
426 Beiträge 13 Kommentatoren 103.3k Aufrufe 13 Beobachtet
  • NegaleinN Negalein
    @sigi234 sagte in Hilfe bei RSS-feed benötigt !:
    So
    <block xmlns="https://developers.google.com/blockly/xml" type="controls_if" id="D(2|q05JPTdW?}+/iwQ[" x="-12" y="3338">
      <value name="IF0">
        <block type="logic_operation" id="}^~+oPe2X*!gq]fuQ}t+" inline="false">
          <field name="OP">AND</field>
          <value name="A">
            <block type="logic_compare" id=":YeS^D%ln[q??.J#hHNE">
              <field name="OP">NEQ</field>
              <value name="A">
                <block type="on_source" id="e^FRFabk)]IekA~l@q6Q">
                </block>
              </value>
              <value name="B">
                <block type="variables_get" id="l;7o1ojJ6ysMyQRAC$,H">
                  <field name="VAR" id="u=f7LS:}~pBRTOJ2W15I">alte_ansage</field>
                </block>
              </value>
            </block>
          </value>
          <value name="B">
            <block type="logic_compare" id="KWj8Gx@a1ZgljRt2Mx-6">
              <value name="A">
                <block type="on_source" id="[C{VYYZKs%)13q}/5S[Y">
                </block>
              </value>
              <value name="B">
                <block type="text" id="Lq|tXq(AFPyQjm;VD:-o">
                  <field name="TEXT">keine Meldung</field>
                </block>
              </value>
            </block>
          </value>
        </block>
      </value>
      <statement name="DO0">
        <block type="controls_if" id="aa,0.|Hi+[!5/sY2,IHj">
          <value name="IF0">
            <block type="logic_compare" id="qvCT/5E^.%h%w@{Reh~r" inline="false">
              <field name="OP">EQ</field>
              <value name="A">
                <block type="get_value" id="[WiQJv]%@0POHs2=Z+3D">
                  <field name="OID">lgtv.0.states.power</field>
                </block>
              </value>
              <value name="B">
                <block type="logic_operation" id="1D/3)usQ.t23nxT=e~sg">
                  <value name="A">
                    <block type="logic_boolean" id="n|zAozJTSoV$jS~81|Dx">
                    </block>
                  </value>
                  <value name="B">
                    <block type="logic_compare" id="?06sz01k08K48zw%TR@s">
                      <field name="OP">GT</field>
                      <value name="A">
                        <block type="get_value" id="IEF]B|R,vDz^3Og6=D%n">
                          <field name="OID">0_userdata.0.Feuerwehr.Einstzmeldungen_laufend_Anzahl</field>
                        </block>
                      </value>
                      <value name="B">
                        <block type="math_number" id="_=Y;/)qT~LBvXDr+c8$r">
                          <field name="NUM">0</field>
                        </block>
                      </value>
                    </block>
                  </value>
                </block>
              </value>
            </block>
          </value>
            <block type="control_ex" id="EQ/tXk4#g#*0G[XVdYJV" inline="true">
              <field name="TYPE">false</field>
              <value name="OID">
                <shadow type="field_oid" id="KUs7w}t}OtQY2ul!$97N">
                  <field name="oid">lgtv.0.states.popup</field>
                </shadow>
              </value>
              <value name="VALUE">
                <shadow type="logic_boolean" id="|[}(^]POMgrc7$IXXg*;">
                </shadow>
                <block type="text" id="[PPa=uvH7n;IgTP;LTn}">
                  <field name="TEXT">Achtung ! Feuerwehreinsatz</field>
                </block>
              </value>
              <value name="DELAY_MS">
                <shadow type="math_number" id="],$hN2a2*e(F4zI1^h0=">
                </shadow>
              </value>
            </block>
          </statement>
        </block>
      </statement>
    </block>
    dslraserD Offline
    dslraserD Offline
    dslraser
    #332
    @negalein
    Nicht ganz...
    So:
    Edit:
      <variables>
        <variable id="u=f7LS:}~pBRTOJ2W15I">alte_ansage</variable>
      </variables>
      <block type="controls_if" id="D(2|q05JPTdW?}+/iwQ[" x="-12" y="3338">
        <value name="IF0">
            <value name="A">
                <value name="A">
                  </block>
                </value>
                <value name="B">
                  </block>
                </value>
              </block>
            </value>
            <value name="B">
                <value name="A">
                  </block>
                </value>
                <value name="B">
                  </block>
                </value>
              </block>
            </value>
          </block>
        </value>
            <value name="IF0">
              </block>
            </value>
                <value name="OID">
                  </shadow>
                </value>
                  </shadow>
                  <block type="on_source" id="IV5RWKEqin-vI.K#)k,!">
                  </block>
                </value>
                  </shadow>
                </value>
              </block>
            </statement>
          </block>
        </statement>
      </block>
    </xml>
    • dslraserD dslraser
      @negalein
      Nicht ganz...
      So:
      Edit:
        <variables>
        </variables>
          <value name="IF0">
              <value name="A">
                  <value name="A">
                    </block>
                  </value>
                  <value name="B">
                    </block>
                  </value>
                </block>
              </value>
              <value name="B">
                  <value name="A">
                    </block>
                  </value>
                  <value name="B">
                    </block>
                  </value>
                </block>
              </value>
            </block>
          </value>
              <value name="IF0">
                </block>
              </value>
                  <value name="OID">
                    </shadow>
                  </value>
                    </shadow>
                    </block>
                  </value>
                    </shadow>
                  </value>
                </block>
              </statement>
            </block>
          </statement>
        </block>
      </xml>
      NegaleinN Offline
      NegaleinN Offline
      Negalein
      #333
      @dslraser sagte in Hilfe bei RSS-feed benötigt !:
      Nicht ganz...
      Ah stimmt, ist ja oben schon vorgegeben.
      ° Fixer ---> iob fix
        Nicht ganz...
        dslraserD Offline
        dslraserD Offline
        dslraser
        #334
        @negalein
        eigentlich sogar so...(sollte reichen)
        Feuerwehreinsatz.zip
         <variables>
         </variables>
         <block type="controls_if" id="D(2|q05JPTdW?}+/iwQ[" x="13" y="3213">
           <value name="IF0">
             <block type="logic_operation" id="VH$Qd|l*[sm+~t(*IM(N" inline="false">
               <value name="A">
                   <value name="A">
                       <value name="A">
                         </block>
                       </value>
                       <value name="B">
                         </block>
                       </value>
                     </block>
                   </value>
                   <value name="B">
                       <value name="A">
                         </block>
                       </value>
                       <value name="B">
                         </block>
                       </value>
                     </block>
                   </value>
                 </block>
               </value>
               <value name="B">
                 </block>
               </value>
             </block>
           </value>
               <value name="OID">
                 </shadow>
               </value>
                 </shadow>
                 </block>
               </value>
                 </shadow>
               </value>
             </block>
           </statement>
         </block>
        </xml>
        • dslraserD Offline
          dslraserD Offline
          dslraser
          #335
          für eine VU sollte auch sowas gehen...
          NegaleinN sigi234S 2 Antworten Letzte Antwort
            NegaleinN Offline
            NegaleinN Offline
            Negalein
            #336
            hab ich gleich nach Sigis Frage bei mir eingebaut. 😁
              sigi234S Online
              sigi234S Online
              #337
              @dslraser
              Hallo, wie kann ich Alexa dazu bewegen mir den letzten Einsatz via Sprachbefehl anzusagen?
              • sigi234S sigi234
                @dslraser
                dslraserD Offline
                dslraserD Offline
                dslraser
                #338
                @dslraser
                Wie meinst Du das ? (einen einzelnen bzw. den allerletzten von mehreren ?)
                Oder meinst Du manuell die Ansage nochmal, oder wie ?
                  @dslraser
                  sigi234S Online
                  sigi234S Online
                  #339
                  @dslraser
                  Eigentlich ob aktuell ein Einsatz läuft
                  • sigi234S sigi234
                    @dslraser
                    NegaleinN Offline
                    NegaleinN Offline
                    Negalein
                    #340
                    hier deine DP auswählen.
                    Dann spricht sie.
                    • NegaleinN Offline
                      NegaleinN Offline
                      Negalein
                      #341
                      @dslraser
                      wo müsste ich was einfügen, dass zusätzlich noch an Whatsapp geschickt wird?
                      Nur das hier kopieren wird sicher nicht reichen?
                        @dslraser
                        dslraserD Offline
                        dslraserD Offline
                        dslraser
                        #342
                        @negalein sagte in Hilfe bei RSS-feed benötigt !:
                        @dslraser
                        Ich habe Telegram und E-Mail in eine Funktionen gepackt, dann kann man das Blockly auch importieren wenn man diese Adapter nicht installiert hat (oder eben nur einen von den Adaptern installiert hat)
                        Ich habe kein WhatsApp in ioBroker laufen, keine Ahnung wie die Funktion bzw. der Baustein dann in JS aussieht...?
                        Telegram und E-Mail senden hier
                        Da müsste dann WhatsApp auch hin. Wenn Du es nur für Dich nutzen willst, dann sollte es auch einen Sendto Baustein für WhatsApp geben, den kannst Du dann da in gleicher Art und Weise einbauen.
                        L 1 Antwort Letzte Antwort
                          @dslraser
                          linux150
                          #343
                          @dslraser Hallo
                          Darf ich das nochmal hervorkramen....;-)
                          Funktioniert super bei mir, einzig ich möchte noch gerne die Feuerwehr an Hand ihrer Nummer rausfiltern.
                          Soll heißen, Alexa soll nur anschlagen wenn ein Feuerwehreinsatz für meine Feuerwehr anliegt. Telegram allerdings wäre der ganze Bezirk nett.
                          Ich habe schon mal drübergeschaut, trau mich aber bei der Komplexität des Blockly nicht wirklich drüber, da wie ich mich kenne nachher gar nichts mehr funktioniert.
                          Bitte Danke!!
                          LG
                          Martin
                          • L linux150
                            @dslraser Hallo
                            Bitte Danke!!
                            LG
                            Martin
                            dslraserD Offline
                            dslraserD Offline
                            dslraser
                            #344
                            @linux150 sagte in Hilfe bei RSS-feed benötigt !:
                            @dslraser Hallo
                            Bitte Danke!!
                            LG
                            Martin
                            Ich nutze das gar nicht und habe auch das Blockly nicht mehr. Das war mal für ? irgendwen aus dem Forum hier. Das war bei mir nie im Einsatz.
                            Trau Dich da ran, mach Dir einfach ne Kopie. 🤷
                            sigi234S L 2 Antworten Letzte Antwort
                              @dslraser Hallo
                              Bitte Danke!!
                              LG
                              Martin
                              sigi234S Online
                              sigi234S Online
                              #345
                              Das war mal für ?
                              @sigi234
                                @dslraser Hallo
                                Bitte Danke!!
                                LG
                                Martin
                                linux150
                                #346
                                @dslraser Werds versuchen :-)
                                Hab jetzt mal eine rudimentäre Lösung in dem ich mit dem Parser alles aus der xml "rausparse" was ich brauche.
                                Dann hab ich noch einen Schalter der auf wahr schaltet wenn meine Feuerwehrnummer in der xml vorkommt.
                                Das ist dann der Trigger für das Alexa Script das mir dann die geparsten Werte wie Einsatzkurzstichwort, Einsatztyp, Adresse und Alarmstufe vorlest (während ich mich anziehe :-))
                                Falls noch wer braucht, gerne bei mir melden :-)
                                LG
                                sigi234S NegaleinN 2 Antworten Letzte Antwort
                                • L linux150
                                  LG
                                  sigi234S Online
                                  sigi234S Online
                                  #347
                                  @linux150
                                  Ja, bitte zum Testen
                                  • L linux150
                                    LG
                                    NegaleinN Offline
                                    NegaleinN Offline
                                    Negalein
                                    #348
                                    ich auch bitte
                                    • NegaleinN Offline
                                      NegaleinN Offline
                                      Negalein
                                      #349
                                      @sigi234
                                      Funktioniert es bei dir noch?
                                      https://intranet.ooelfv.at/ ist nicht mehr erreichbar.
                                      Aber irgendwie funktionierts jetzt noch, bzw. anders. Siehe https://ff.ampits.at/?today
                                        @sigi234
                                        sigi234S Online
                                        sigi234S Online
                                        #350
                                        @sigi234
                                        Nein, das System wurde umgestellt.
                                        • sigi234S sigi234
                                          @sigi234
                                          NegaleinN Offline
                                          NegaleinN Offline
                                          Negalein
                                          #351
                                          gibt es eine neue URL?
