  4. Test Adapter KNX v1.0.x
knx adapter
719 Beiträge 93 Kommentatoren 243.6k Aufrufe 85 Beobachtet
  • T Tontechniker
    @loverz
    Achtung! Vor dieser Aktion ein Backup Deiner aktuellen IoBroker-Installation machen!
    Ich würde es ändern mit
    cd /opt/iobroker
    iobroker stop
    npm install iobroker.knx@1.0.20 --production
    iobroker start
    Das hat bis letzte Woche noch funktioniert!
    Dann natürlich die bestehende Instanz KNX 0 (1.0.xx) löschen und die Instanz KNX 0 (Adapter 1.0.20) mit "+" wieder neu erzeugen.
    loverz
    #656
    @tontechniker endet leider im gleichen Ergebnis:
    pi@ioBroker-RasPi4:~ $ cd /opt/iobroker
    pi@ioBroker-RasPi4:/opt/iobroker $ iobroker stop
    pi@ioBroker-RasPi4:/opt/iobroker $ npm install iobroker.knx@1.0.20 --production
    npm WARN deprecated xmldom@0.1.31: Deprecated due to CVE-2021-21366 resolved in 0.5.0
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/eibd/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/string-similarity/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/xpath/package.json'
    npm ERR! code EACCES
    npm ERR! syscall unlink
    npm ERR! path /opt/iobroker/node_modules/iobroker.knx/node_modules/string-similarity/src/index.js
    npm ERR! errno -13
    npm ERR! Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.knx/node_modules/string-similarity/src/index.js'
    npm ERR!  [OperationalError: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.knx/node_modules/string-similarity/src/index.js'] {
    npm ERR!   cause: [Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.knx/node_modules/string-similarity/src/index.js'] {
    npm ERR!     errno: -13,
    npm ERR!     code: 'EACCES',
    npm ERR!     syscall: 'unlink',
    npm ERR!     path: '/opt/iobroker/node_modules/iobroker.knx/node_modules/string-similarity/src/index.js'
    npm ERR!   },
    npm ERR!   path: '/opt/iobroker/node_modules/iobroker.knx/node_modules/string-similarity/src/index.js',
    npm ERR!   parent: 'iobroker.knx'
    npm ERR! }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator.
    npm ERR!     /home/pi/.npm/_logs/2021-09-28T18_51_59_956Z-debug.log
    Er scheint irgendwie Zugriffsprobleme mit irgendwelchen "node_modules" zu haben.
    Wenn ich die Objekte hier sichere:
    Kann ich sie dann nach der Adapterlöschung genau so wiederherstellen, wie ich sie gesichert habe?
    Dann würde ich es mal probieren vor dem Befehl den Adapter bzw. die Instanz zu löschen.
    • L Offline
      loverz
      #657
      Im Übrigen kommen nach dem Neustart des iobroker auch immer folgende Fehlermeldungen vom KNX Adapter:
      host.ioBroker-RasPi4
      2021-09-28 20:56:04.339	info	Restart adapter system.adapter.knx.0 because enabled
      2021-09-28 20:56:04.338	error	instance system.adapter.knx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2021-09-28 20:56:04.338	error	Caught by controller[0]: }
      2021-09-28 20:56:04.337	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.knx/knx.js' ]
      2021-09-28 20:56:04.337	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      2021-09-28 20:56:04.336	error	Caught by controller[0]: at Object.7../dpt2iobroker.js (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:267585) {
      2021-09-28 20:56:04.336	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.knx/knx.js:1:33256
      2021-09-28 20:56:04.336	error	Caught by controller[0]: at _0x266b04 (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:33149)
      2021-09-28 20:56:04.335	error	Caught by controller[0]: at Object.6../DPT-definition.js (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:228392)
      2021-09-28 20:56:04.335	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.knx/knx.js:1:33256
      2021-09-28 20:56:04.334	error	Caught by controller[0]: at _0x266b04 (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:32855)
      2021-09-28 20:56:04.334	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
      2021-09-28 20:56:04.333	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
      2021-09-28 20:56:04.333	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:667:27)
      2021-09-28 20:56:04.333	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
      2021-09-28 20:56:04.332	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.knx/knx.js
      2021-09-28 20:56:04.332	error	Caught by controller[0]: Require stack:
      2021-09-28 20:56:04.331	error	Caught by controller[0]: Error: Cannot find module 'string-similarity'
      2021-09-28 20:56:04.331	error	Caught by controller[0]: ^
      2021-09-28 20:56:04.330	error	Caught by controller[0]: throw err;
      2021-09-28 20:56:04.330	error	Caught by controller[0]: internal/modules/cjs/loader.js:818
      2021-09-28 20:56:00.963	info	instance system.adapter.knx.0 started with pid 6935
      2021-09-28 20:55:30.898	info	Restart adapter system.adapter.knx.0 because enabled
      2021-09-28 20:55:30.897	error	instance system.adapter.knx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2021-09-28 20:55:30.897	error	Caught by controller[0]: }
      2021-09-28 20:55:30.896	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.knx/knx.js' ]
      2021-09-28 20:55:30.896	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      2021-09-28 20:55:30.895	error	Caught by controller[0]: at Object.7../dpt2iobroker.js (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:267585) {
      2021-09-28 20:55:30.895	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.knx/knx.js:1:33256
      2021-09-28 20:55:30.895	error	Caught by controller[0]: at _0x266b04 (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:33149)
      2021-09-28 20:55:30.894	error	Caught by controller[0]: at Object.6../DPT-definition.js (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:228392)
      2021-09-28 20:55:30.894	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.knx/knx.js:1:33256
      2021-09-28 20:55:30.893	error	Caught by controller[0]: at _0x266b04 (/opt/iobroker/node_modules/iobroker.knx/knx.js:1:32855)
      2021-09-28 20:55:30.893	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
      2021-09-28 20:55:30.892	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
      2021-09-28 20:55:30.892	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:667:27)
      2021-09-28 20:55:30.891	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
      2021-09-28 20:55:30.891	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.knx/knx.js
      2021-09-28 20:55:30.891	error	Caught by controller[0]: Require stack:
      2021-09-28 20:55:30.890	error	Caught by controller[0]: Error: Cannot find module 'string-similarity'
      2021-09-28 20:55:30.890	error	Caught by controller[0]: ^
      2021-09-28 20:55:30.889	error	Caught by controller[0]: throw err;
      2021-09-28 20:55:30.888	error	Caught by controller[0]: internal/modules/cjs/loader.js:818
      Ich muss die KNX Instanz immer nochmal manuell Neustarten, dass sie läuft.
      In den Fehlermeldungen steht auh wieder etwas von "node_modules"
      ->Ich glaube das erste Problem (Downgradeproblem) hängt mit diesem hier zusammen.
      • L Offline
        loverz
        schrieb am zuletzt editiert von loverz
        #658
        also das mit den Objekten Exportieren klappt wie ich mir das vorgestellt habe.
        Nun habe ich den KNX Adapter gelöscht, mit dem Befehl:
        neu installiert.
        v1.0.20 läuft direkt perfekt!
        Werde wohl nie wieder auf ne höhere Version updaten 🐶
        Noch eine kleine Frage:
        Mir wird das hier angeboten:
        sollte man das machen?
        • L loverz
          neu installiert.
          GlasfaserG Offline
          GlasfaserG Offline
          #659
          @loverz sagte in Test Adapter KNX v1.0.x:
          Nein ... nicht machen .
          Bleib bei NPM 6.....
          https://forum.iobroker.net/topic/46758/js-controller-3-3-jetzt-im-stable
          • J Offline
            JojoS
            #660
            ich habe auch noch das Pärchen Problem und schon mehrfach probiert, warum passt das nicht?
            habe den Adapter 1.45 mit loglevel Alles oder Debug gestartet, da kommen auch keine Fehlermeldungen
            L L 3 Antworten Letzte Antwort
            • J JojoS
              lessthanmore
              #661
              @jojos 1/0/0 Hobbykeller Licht links schalten, 1/0/1 Hobbykeller Licht links schalten Status, usw.
              Das gehört zusammen und nicht in unterschiedliche Bereiche.
              • J JojoS
                loverz
                #662
                @jojos deine Gruppenadressen sind nicht so angeordnet, wie sie es sollten.
                GAs sollten so aufgebaut sein:
                Etage/Typ/Raum
                z.B.
                EG/Beleuchtung/Wohnzimmer_schalten
                EG/Beleuchtung/Wohnzimmer_schalten_Status
                oder
                OG/Jalousie/Küche_Jalousie_Position
                OG/Jalousie/Küche_Jalousie_Position_Status
                • J JojoS
                  lessthanmore
                  #663
                  @jojos https://www.knx.org/wAssets/docs/downloads/Marketing/Flyers/KNX-Project-Preparation/KNX-Project-Preparation_de.pdf
                  Ab Seite 11 mal in Ruhe durchlesen. Ist natürlich nur ein Vorschlag.
                  L 1 Antwort Letzte Antwort
                  • L lessthanmore
                    loverz
                    #664
                    @lessthanmore ist doch genau so wie ich vorgeschlagen habe ;)
                    • J Offline
                      JojoS
                      #665
                      Danke für die Antworten. Für die Gruppen gibt es ja verschiedene Schemata, ich hatte erst mit Etage/Typ/Raum angefangen, fand das aber unpraktisch. Im KNX Forum hatte ich verschiedene Diskussionen und Vorschläge gefunden, daher kam dieses.
                      Ich habe jetzt gesehen das in anderen Gruppen doch Pärchen sind, da hatt die Mittelgruppe noch den Anhang 'Status'. Muss ich mir nochmal ansehen, wenn die Nachwirkungen der gestrigen Party abgeklungen sind.
                      • J JojoS
                        loverz
                        #666
                        @jojos Alternativ auf Version 1.0.20, wenn die infrage kommt, dann brauchst du auch keine "Pärchen".
                        @chefkoch009 baut für die Zukunft vielleicht eine Option ein, damit diese Pärchen nicht zwingend nötig sind, da hier echt einige ihre Probleme damit haben.
                        • L loverz
                          JojoS
                          schrieb am zuletzt editiert von JojoS
                          #667
                          @loverz den Umweg über die alte Version möchte ich endlich loswerden, das Problem ist ja auch das dann neuere Datentypen nicht importiert werden. Die 1.20 hatte afaik nicht die true/false Darstellung für bool, das hat Auswirkungen auf Scripte.
                          Ich hatte gestern auch noch mit den Flags gespielt, aber die haben doch keine Auswirkung auf die Pärchenbildung?
                          Ich war gestern auch nicht mehr sicher ob die Pärchen noch gebraucht werden: wenn ich Licht am Schalter ein/ausschalte, dann ändert sich der Status in der Vis trotzdem. Das war doch vorher das Problem? Ich probiere es gleich nochmal.
                          • J JojoS
                            loverz
                            #668
                            @jojos das mit der vis weiß ich nicht, nutze die nicht.
                            1/0 statt true/false ist tatsächlich ein Nachteil der alten Version, aber meine Scripte kommen damit klar. Weiß nicht was da nicht passen soll.
                            • L loverz
                              JojoS
                              #669
                              Hurra, wenn ich den Mittelgruppen auch ein 'Status' anhäge, dann klappt es!
                              Dafür funktioniert jetzt die Vis nicht mehr :(
                              ok, geht wieder. Der KNX Adapter hatte das Netzwerkinterface vergessen, das Feld war leer, warum auch immer.
                              • J JojoS
                                loverz
                                #670
                                @jojos sehr, sehr komisch wie der Adapter auf die „Pärchensuche“ geht 😅
                                Freut mich aber, dass es bei dir mit geringem Aufwand funzt :-)
                                • L loverz
                                  lessthanmore
                                  #671
                                  @loverz Es steht hier schwarz auf weiß: https://github.com/ioBroker/ioBroker.knx#wie-werden-die-datenpunkte-generiert-deutsch
                                  Sogar auf deutsch. Was daran komisch sein soll weißt wohl nur du.
                                  • L lessthanmore
                                    loverz
                                    #672
                                    @lessthanmore es ist komisch, dass der Adapter @JojoS Objekte unterscheiden kann, obwohl sich diese in den Mitteladressen unterscheiden.
                                    In deiner verlinkten Anleitung steht:
                                      1. Herausfinden der Schalt- und Statusaddressen
                                        In dem ETS-Export sind die Schalt- und Statusadressen nicht hinterlegt. Somit führe ich eine Ähnlichkeitsprüfung aller Gruppenadressnamen durch mit der Auswertung auf status und state. Wird ein Pärchen gefunden, dessen
                                        Ähnlichkeit mehr als 90% beträgt, dann wird angenommen, dass die GA1 die Schaltadresse und GA2 die Statusadresse ist. Dabei erhält GA1 das write=true und read=false und GA2 das write=false und read=true. Außerdem werden die DPT abgeglichen aus der jeweilig korrespondierenden GA. Aus diesem Grund ist es schwierig, Pärchen zu finden, wenn die Gruppenadressbeschriftungen nicht konsistent sind.
                                    Bei mir jedoch wird nicht korrekt erkannt:
                                    Wohnzimmer_Spots_Südseite_schalten
                                    Wohnzimmer_Spots_Südseite_Status
                                    hab gerade gerechnet und es sind tatsächlich nur 81,25% Übereinstimmung.
                                    Würden die Pärchen wie folgt heißen:
                                    Wohnzimmer_Spots_Südseite_Hallowiegehtsdennso?_schalten
                                    Wohnzimmer_Spots_Südseite_Hallowiegehtsdennso?_Status
                                    wäre eine korrekte Zuweisung wahrscheinlicher.
                                    Das finde ich persönlich mehr als komisch, da sollte aus meiner Sicht nachgebessert werden.
                                    Klar kann der Entwickler den Adapter programmieren wie er will, letztlich bin ich auch froh, dass er überhaupt einen entwickelt hat, aber ich bleibe dabei: Die Voraussetzungen könnten besser sein ;)
                                    L J GarfonsoG 3 Antworten Letzte Antwort
                                    • L loverz
                                      lessthanmore
                                      #673
                                      @loverz Nicht nur der Name der GA ist entscheidend, sondern u. a. auch deren DPT und die Flags.
                                      Da ich momentan nicht von einer Weiterentwicklung ausgehe ist es eh egal.
                                      • L lessthanmore
                                        loverz
                                        #674
                                        @lessthanmore doch der Adapter wird wohl weiterentwickelt, habe Infos aus guter Quelle ;)
                                        • L Offline
                                          lessthanmore
                                          #675
                                          @Bluefox Kannst du bitte hier etwas zu sagen, du hast doch Zugriff auf den Code.
                                          Danke vorab.
