  4. History2DB converter
60 Beiträge 14 Kommentatoren 16.0k Aufrufe 13 Beobachtet
  • G
    G
    GerdSo
    Leider ohne Erfolg (history.0 ausgeschaltet)
    C:\Program Files\ioBroker>node node_modules/iobroker.js-controller/iobroker.js stop
    Stopping iobroker controller daemon...
    iobroker controller daemon stopped.
    C:\Program Files\ioBroker>npm i https://github.com/ioBroker/ioBroker.sql/tarball/master
    > sqlite3@3.1.7 install C:\Program Files\ioBroker\node_modules\iobroker.sql\node_modules\sqlite3
    > node-pre-gyp install --fallback-to-build
    [sqlite3] Success: "C:\Program Files\ioBroker\node_modules\iobroker.sql\node_modules\sqlite3\lib\binding\node-v46-win32-ia32\node_sqlite3.node" is installed via remote
    iobroker.sql@1.4.3 node_modules\iobroker.sql
    ├── mysql@2.13.0 (sqlstring@2.2.0, bignumber.js@3.1.2, readable-stream@1.1.14)
    ├── sql-client@0.7.0 (argf@0.0.1, inote-util@0.8.1)
    ├── pg@6.1.2 (packet-reader@0.2.0, pg-connection-string@0.1.3, buffer-writer@1.0.1, semver@4.3.2, pg-types@1.11.0, pg-pool@1.6.0, pgpass@1.0.1)
    ├── mssql@3.3.0 (generic-pool@2.5.4, promise@7.1.1, tedious@1.14.0)
    └── sqlite3@3.1.7 (nan@2.4.0)
    C:\Program Files\ioBroker>iobroker start
    C:\Program Files\ioBroker>node node_modules/iobroker.js-controller/iobroker.js start
    Starting iobroker controller daemon...
    c:\Program Files\ioBroker\node_modules\iobroker.history\converter>node history2db.js sql.0 debug 20170202 "c:\history"
    Send Data to sql.0
    Start at 20170202
    Use historyDir c:\history
    2017-02-14 20:49:09.831  - debug: history.20170202 objectDB connected
    2017-02-14 20:49:09.847  - debug: history.20170202 statesDB connected
    2017-02-14 20:49:09.878  - info: history.0 starting. Version 1.5.2 in c:/Program Files/ioBroker/node_modules/iobroker.history, node: v4.6.2
    No stored earliesDBValues found
    No stored existingDBTypes found
    started processFiles with 0 known db values
    We start earliest at 20170202
    Day 20170202 - history.hm-rega.0.10529.json
      datapoints reduced from 1 --> 1
    Data stored but dbDB not available anymore, break.
    DONE
    • apollon77A
      apollon77A
      Ok, bitte jetzt auch history vom Github aktualisieren, auch Debug drin. Jetzt bin ich gespannt was rauskommt :-)
      • G
        G
        GerdSo
        @apollon77:
        Ok, bitte jetzt auch history vom Github aktualisieren, auch Debug drin. Jetzt bin ich gespannt was rauskommt :-) `
        Ergebnis:
        Send Data to sql.0
        Start at 20170202
        2017-02-14 21:47:29.548  - debug: history.20170202 objectDB connected
        2017-02-14 21:47:29.580  - debug: history.20170202 statesDB connected
        2017-02-14 21:47:29.611  - info: history.0 starting. Version 1.5.2 in c:/Program Files/ioBroker/node_modules/iobroker.history, node: v4.6.2
        Data stored but db not available anymore, break. {"success":true}
        DONE
        Bis auf das {"success":true} gibt es anscheinend keine Änderung 😢
        • apollon77A
          apollon77A
          Grrrrrrrrrr… der Push der Änderung von sql hatte nicht geklappt ... jetzt aber. Bitte neu sql installieren, dann sollte es laufen oder sinnvolle ausgaben geben :-)
          • G
            G
            GerdSo
            @apollon77:
            Grrrrrrrrrr… der Push der Änderung von sql hatte nicht geklappt ... jetzt aber. Bitte neu sql installieren, dann sollte es laufen oder sinnvolle ausgaben geben :-) `
            Das erklärt meine Aussage, dass sich nichts geändert hat zwischen meinem Rechner und der github-Version ;)
            Jetzt passiert mehr bei der Ausgabe und er läuft aktuell immer noch, allerdings wird laut Ausgabe nahezu alles ignoriert. Ab und zu wird ein Datenpunkt am Tag übernommen:````
            Day 20170122 - history.yr.0.forecast.day2.temperature_min.json
            Ignore ID history.yr.0.forecast.day2.temperature_min.json: yr.0.forecast.day2.temperature_min
            Day 20170122 - history.yr.0.forecast.day2.text.json
            Ignore ID history.yr.0.forecast.day2.text.json: yr.0.forecast.day2.text
            Day 20170122 - history.yr.0.forecast.day2.wind_direction.json
            Ignore ID history.yr.0.forecast.day2.wind_direction.json: yr.0.forecast.day2.wind_direction
            Day 20170122 - history.yr.0.forecast.day2.wind_speed.json
            Ignore ID history.yr.0.forecast.day2.wind_speed.json: yr.0.forecast.day2.wind_speed
            Day 20170122 - history.yr.0.forecast.diagram.json
            Ignore ID history.yr.0.forecast.diagram.json: yr.0.forecast.diagram
            Day 20170122 - history.yr.0.forecast.html.json
            Ignore ID history.yr.0.forecast.html.json: yr.0.forecast.html
            Day 20170122 - history.yr.0.forecast.object.json
            Ignore ID history.yr.0.forecast.object.json: yr.0.forecast.object
            Day end
            Day 20170121 - history.admin.0.info.updatesList.json
            Ignore ID history.admin.0.info.updatesList.json: admin.0.info.updatesList
            Day 20170121 - history.admin.0.info.updatesNumber.json
            Ignore ID history.admin.0.info.updatesNumber.json: admin.0.info.updatesNumber
            Day 20170121 - history.dwd.0.warning.begin.json
            Ignore ID history.dwd.0.warning.begin.json: dwd.0.warning.begin
            Day 20170121 - history.dwd.0.warning.description.json
            Ignore ID history.dwd.0.warning.description.json: dwd.0.warning.description
            Day 20170121 - history.dwd.0.warning.end.json
            Ignore ID history.dwd.0.warning.end.json: dwd.0.warning.end
            Day 20170121 - history.dwd.0.warning.headline.json
            Ignore ID history.dwd.0.warning.headline.json: dwd.0.warning.headline
            • apollon77A
              apollon77A
              Jetzt kommen wir zu den zusätzlichen Parametern :-)
              Entweder du lässt vorher "analyzesql.js" laufen damit alle aktuell in sql existierenden Datenpunkt-IDs gesammelt werden und auch nur die konvertiert werden.
              Alternativ –ignoreExistingDBValues setzen beim import-Skript dann sollte das egal sein und alles wird konvertiert - aber dann musst DU beim abbrechen aufpassen das du nicht doubletten erzeugst!
              • G
                G
                GerdSo
                @apollon77:
                Alternativ –ignoreExistingDBValues setzen beim import-Skript dann sollte das egal sein und alles wird konvertiert - aber dann musst DU beim abbrechen aufpassen das du nicht doubletten erzeugst! `
                Ich bin davon ausgegangen, dass ohne die zusätzlichen Parameter die Dubletten vermieden werden und er alle Datenpunkte übernimmt.
                Das passt aber nicht mit dem ignore, dass aktuell protokolliert wird, überein, da er jetzt sehr viele Datenpunkte übernehmen müsste oder verstehe ich da etwas falsch. "analyzesql.js" hatte bei mir bisher eine nahezu leere Datei erzeugt und –simulate protokolliert ja, dass Daten übernommen werden können. Bin etwas ratlos.
                • apollon77A
                  apollon77A
                  Aaaaalso … die Idee war das man nur das nach sql konvertieren will was man auch mit sql loggt. Daher gibt es diese "analyze"-Skripte. Die suchen aus der sql-DB alle Datenpunkte raus die geloggt werden und speichert diese quasi in einer "white-list" für das Konverterskript weil dann auch nur die genommen werden.
                  Daher auch der Effekt, wenn Du ohne dieses analyze und daher mit leerem "welche Datenpunkte gibt es denn"-File den konverter startest, das alles ignoriert wird.
                  "--ignoreExistingDBValues" sagt dem Skript das er genau diese Whitelist ignorieren soll. Damit nimmt er dann alles was im History gefunden wurde egal ob es schon in sql da ist oder nicht.
                  Daher wenn es immer noch komisch ist: Was ist denn der Output vom analyze-Skript?
                  • G
                    G
                    GerdSo
                    @apollon77:
                    Daher wenn es immer noch komisch ist: Was ist denn der Output vom analyze-Skript? `
                    Ergebnis mit gestopptem history.0, damals lief history.0 noch. Ergebnis ist aber identisch:
                    c:\Program Files\ioBroker\node_modules\iobroker.history\converter>node analyzesql.js
                    Query Data from sql.0
                    2017-02-15 08:03:11.425  - info: history.0 starting. Version 1.5.2 in c:/Program Files/ioBroker/node_modules/iobroker.history, node: v4.6.2
                    Send
                    {"succes":true,"result":{"undefined":{"type":"undefined","ts":1970000}}}
                    Datapoints found: undefined
                    Ergebnis earliestDBValues.json````
                    {"undefined":1487142206553}
                    Ergebnis existingDBTypes.json````
                    • apollon77A
                      apollon77A
                      Was sagt denn das iobroker.Log von sql.0 zu dein zeitunkt? Da sollt auch was geloggt werden. Und schau bitte das sql auf loglevel "info" steht das Du diese Logs siehst.
                      Query result <json>Nochmal zur Klarstellung: sql.0 läuft und es sind Datenpunkte definiert die da hin loggen?!</json>
                      • G
                        G
                        GerdSo
                        @apollon77:
                        Query result <json>Nochmal zur Klarstellung: sql.0 läuft und es sind Datenpunkte definiert die da hin loggen?!</json> `
                        sql.0 läuft und es sind Datenpunkte definiert. Über die Adminoberfläche wurde das logging für sql.0 und history.0 identisch eingestellt, alle Datenpunkte loggen. Ich habe auch ein flot Diagramm auf sql.0 umgestellt und dort werden die Kurven korrekt angezeigt, daher sollten die Werte im sql.0 vorhanden sein.
                        log zum Zeitpunkt der Analyse (history.0 gestoppt)
                        <code>2017-02-17 23:37:54.844  - [31merror[39m: WARNING: cannot find logs with id = 96467210
                        2017-02-17 23:37:55.782  - [31merror[39m: WARNING: cannot find logs with id = 96467638
                        2017-02-17 23:37:55.782  - [31merror[39m: WARNING: cannot find logs with id = 96467639
                        2017-02-17 23:37:55.782  - [31merror[39m: WARNING: cannot find logs with id = 96467640
                        2017-02-17 23:37:55.782  - [31merror[39m: WARNING: cannot find logs with id = 96467641
                        2017-02-17 23:37:55.782  - [31merror[39m: WARNING: cannot find logs with id = 96467642
                        2017-02-17 23:37:55.782  - [31merror[39m: WARNING: cannot find logs with id = 96467643
                        2017-02-17 23:37:55.782  - [31merror[39m: WARNING: cannot find logs with id = 96467644
                        2017-02-17 23:37:55.782  - [31merror[39m: WARNING: cannot find logs with id = 96467645
                        2017-02-17 23:37:55.782  - [31merror[39m: WARNING: cannot find logs with id = 96467646
                        2017-02-17 23:37:55.797  - [31merror[39m: WARNING: cannot find logs with id = 96467647
                        2017-02-17 23:37:55.797  - [31merror[39m: WARNING: cannot find logs with id = 96467648
                        2017-02-17 23:37:55.797  - [31merror[39m: WARNING: cannot find logs with id = 96467649[/code]</code>
                        • apollon77A
                          apollon77A
                          Während der Analyse oder auch beim History-Übertragen kann es zu solchen Logs kommen. Da kommt ein Log-Teilprozess nicht hinterher. Gefühlt nicht so schlimm.
                          Hat deine sql-Instanz Loglevel info?
                          • M
                            M
                            moebius
                            Als ich mit iobroker angefangen hab, hat bei mir die Übernahme von history nach sql auch nicht geklappt.
                            Hab dann mit diesem flow improvisiert. Man muss vorher schon den sql adapter einschalten, damit er
                            die DP's anlegt.
                            ! "id": "361523f4.0693fc",
                            ! "type": "tab",
                            ! "label": "Sql import historic data"
                            ! "id": "54117af8.894304",
                            ! "type": "file in",
                            ! "z": "361523f4.0693fc",
                            ! "name": "",
                            ! "filename": "/opt/iobroker/iobroker-data/history/20170106/history.admin.0.ws333.Temp3.json",
                            ! "format": "utf8",
                            ! "x": 459,
                            ! "y": 95,
                            ! "wires": [
                            ! "ade70e93.59ded"
                            ! "id": "42a18a7e.9e2744",
                            ! "type": "debug",
                            ! "name": "",
                            ! "active": true,
                            ! "console": "false",
                            ! "complete": "true",
                            ! "x": 1240,
                            ! "y": 331,
                            ! "wires": []
                            ! "id": "ade70e93.59ded",
                            ! "type": "json",
                            ! "name": "",
                            ! "x": 818,
                            ! "y": 171,
                            ! "wires": [
                            ! "2005b14d.5c492e"
                            ! "id": "2005b14d.5c492e",
                            ! "type": "function",
                            ! "name": "Add timestamp",
                            ! "func": "//var dp = msg.filename.match(/[-\w]+[.][\w]+$/i)[0]\nvar dp = msg.filename.match(/^.\/(.)\.(.*)$/i)[1]\n\nvar ma = []\n\nfor (i=0; i<msg.payload.length; ++i)/{\n/ma.push({topic:"insert/into/ts_number/set/id="(select" id/from/iobroker.datapoints/where/type="0" and/name="&quot;+ dp +&quot;" )/,/ts="&quot;" +/msg.payload<i="">[i].ts + ",val=" + msg.payload__.val + ",ack=0,_from=2,q=" + msg.payload__.q, payload: ""})\n ma.push({topic:"insert into ts_string set id=(select id from iobroker.datapoints where type = 1 and name = '"+ dp +"') , ts=" + msg.payload__.ts + ",val=" + msg.payload__.val + ",ack=0,_from=2,q=" + msg.payload__.q, payload: ""})\n ma.push({topic:"insert into ts_bool set id=(select id from iobroker.datapoints where type = 2 and name = '"+ dp +"') , ts=" + msg.payload__.ts + ",val=" + msg.payload__.val + ",ack=0,_from=2,q=" + msg.payload__.q, payload: ""})\n}\nreturn [ma];",
                            ! "outputs": "1",
                            ! "noerr": 0,
                            ! "x": 962,
                            ! "y": 223,
                            ! "wires": [
                            ! "6d4c858b.8562cc"
                            ! "id": "6d4c858b.8562cc",
                            ! "type": "mysql",
                            ! "mydb": "c5d28ccd.2882a",
                            ! "name": "",
                            ! "x": 1102,
                            ! "y": 286,
                            ! "wires": [
                            ! "42a18a7e.9e2744"
                            ! "id": "8b3dd54e.fdff98",
                            ! "type": "inject",
                            ! "name": "",
                            ! "topic": "",
                            ! "payload": "",
                            ! "payloadType": "date",
                            ! "repeat": "",
                            ! "crontab": "",
                            ! "once": false,
                            ! "x": 93,
                            ! "y": 36,
                            ! "wires": [
                            ! "54117af8.894304"
                            ! "id": "c5d28ccd.2882a",
                            ! "type": "MySQLdatabase",
                            ! "z": "",
                            ! "host": "big",
                            ! "port": "3306",
                            ! "db": "iobroker",
                            ! "tz": ""
                            _______________</msg.payload.length;> 1803_clipboard05.jpg
                            • G
                              G
                              GerdSo
                              @apollon77:
                              Hat deine sql-Instanz Loglevel info? `
                              Ja, hatte Loglevel Info. Ich habe Dir gerade per PN das Logging mit Level Debug zugesendet, vielleicht kannst Du damit mehr anfangen.
                              Ich habe mal in der sql-DB nachgesehen und die kennt ca. 500 Datenpunkte die auch vom Namen her gut aussehen, d.h. sehen so aus wie in admin bzw. die history-Dateinamen
                              • G
                                G
                                GerdSo
                                @moebius:
                                die DP's anlegt. `
                                Was macht man mit den Infos im spoiler text? Wo muss ich das importieren?
                                • M
                                  M
                                  moebius
                                  @GerdSo:
                                  Wo muss ich das importieren? ` im adapter node-red. Wenn du 500 DP's importieren willst, muss man noch 2 nodes dranmachen um über das Verzeichnis zu wandern.
                                  • G
                                    G
                                    GerdSo
                                    @GerdSo:
                                    @apollon77:
                                    Ich habe mal in der sql-DB nachgesehen und die kennt ca. 500 Datenpunkte die auch vom Namen her gut aussehen, d.h. sehen so aus wie in admin bzw. die history-Dateinamen `
                                    Hallo apollon77, danke für die Rückmeldung per PN. Deine neue Version 1.4.5 erzeugt jetzt vernünftige Ergebnisse bei analyze.js. Allerdings scheint die Übertragung mit history2db.js weiterhin nicht zu laufen:
                                    Send Data to sql.0
                                    Use historyDir c:\Program Files\ioBroker\iobroker-data\history-data
                                    2017-02-18 20:46:28.224  - debug: history.0 objectDB connected
                                    2017-02-18 20:46:28.255  - debug: history.0 statesDB connected
                                    2017-02-18 20:46:28.333  - info: history.0 starting. Version 1.5.2 in c:/Program Files/ioBroker/node_modules/iobroker.history, node: v4.6.2
                                    EarliesDBValues initialized from cache 667
                                    ExistingDBTypes initialized from cache 720
                                    started processFiles with 667 known db values
                                    We start earliest at 20170218
                                    DONE
                                    • apollon77A
                                      apollon77A
                                      Da fehlen Parameter! Da muss noch Das Datum und vor allem der Pfad dran!
                                      node history2db.js sql.0 debug 20170218<pfad></pfad>
                                      • G
                                        G
                                        GerdSo
                                        @apollon77:
                                        node history2db.js sql.0 debug 20170218<pfad></pfad> `
                                        Hi, stimmt. Derzeit ist er beim Übertragen und es sieht gut aus. Dauert noch etwas, da er etwas über 10 Monate übertragen muss. Danke für Deine Hilfe!
                                        • G
                                          G
                                          GerdSo
                                          Gibt doch noch Probleme. iobroker.log meldet dauernd Fehler:
                                          sql.0	2017-02-18 22:49:53.292	error	sql.0 Error: ER_CON_COUNT_ERROR: Too many connections
                                          sql.0	2017-02-18 22:49:52.636	error	sql.0 Cannot insert INSERT INTO `iobroker`.ts_bool (id, ts, val, ack, _from, q) VALUES(547, 2017001, false, 1, 3, 0);: Error: ER_DUP_ENTRY: Duplicate entry '547-2017001' for key 'PRIMARY'
                                          sql.0	2017-02-18 22:49:52.636	error	sql.0 Cannot insert INSERT INTO `iobroker`.ts_bool (id, ts, val, ack, _from, q) VALUES(547, 2017000, false, 1, 3, 0);: Error: ER_DUP_ENTRY: Duplicate entry '547-2017000' for key 'PRIMARY'
                                          sql.0	2017-02-18 22:49:52.261	error	sql.0 Cannot insert INSERT INTO `iobroker`.ts_bool (id, ts, val, ack, _from, q) VALUES(529, 2017001, false, 1, 3, 0);: Error: ER_DUP_ENTRY: Duplicate entry '529-2017001' for key 'PRIMARY'
                                          sql.0	2017-02-18 22:49:52.261	error	sql.0 Cannot insert INSERT INTO `iobroker`.ts_bool (id, ts, val, ack, _from, q) VALUES(529, 2017000, false, 1, 3, 0);: Error: ER_DUP_ENTRY: Duplicate entry '529-2017000' for key 'PRIMARY'
                                          sql.0	2017-02-18 22:49:51.917	error	sql.0 Cannot insert INSERT INTO `iobroker`.ts_bool (id, ts, val, ack, _from, q) VALUES(545, 2017001, false, 1, 3, 0);: Error: ER_DUP_ENTRY: Duplicate entry '545-2017001' for key 'PRIMARY'
                                          sql.0	2017-02-18 22:49:51.917	error	sql.0 Cannot insert INSERT INTO `iobroker`.ts_bool (id, ts, val, ack, _from, q) VALUES(545, 2017000, false, 1, 3, 0);: Error: ER_DUP_ENTRY: Duplicate entry '545-2017000' for key 'PRIMARY'
                                          84.2k
